MBMesquite::ParallelHelperImpl Member List
This is the complete list of members for MBMesquite::ParallelHelperImpl, including all inherited members.
Blocking enum valueMBMesquite::ParallelHelperImpl
BlockingAvoidAllReduce enum valueMBMesquite::ParallelHelperImpl
comm_smoothed_vtx_b(MsqError &err)MBMesquite::ParallelHelperImpl [private]
comm_smoothed_vtx_b_no_all(MsqError &err)MBMesquite::ParallelHelperImpl [private]
comm_smoothed_vtx_nb(MsqError &err)MBMesquite::ParallelHelperImpl [private]
comm_smoothed_vtx_nb_no_all(MsqError &err)MBMesquite::ParallelHelperImpl [private]
comm_smoothed_vtx_tnb(MsqError &err)MBMesquite::ParallelHelperImpl [private]
comm_smoothed_vtx_tnb_no_all(MsqError &err)MBMesquite::ParallelHelperImpl [private]
communicate_all_true(bool &value, MsqError &err) const MBMesquite::ParallelHelperImpl [protected, virtual]
communicate_any_true(bool &value, MsqError &err) const MBMesquite::ParallelHelperImpl [protected, virtual]
communicate_first_independent_set(MsqError &err)MBMesquite::ParallelHelperImpl [protected, virtual]
communicate_histogram_to_zero(std::vector< int > &histogram, MsqError &) const MBMesquite::ParallelHelperImpl [protected, virtual]
communicate_min_max_to_all(double *minimum, double *maximum, MsqError &) const MBMesquite::ParallelHelperImpl [protected, virtual]
communicate_min_max_to_zero(double *minimum, double *maximum, MsqError &) const MBMesquite::ParallelHelperImpl [protected, virtual]
communicate_next_independent_set(MsqError &err)MBMesquite::ParallelHelperImpl [protected, virtual]
communicate_power_sum_to_zero(double *pMean, MsqError &) const MBMesquite::ParallelHelperImpl [protected, virtual]
communicate_sums_to_zero(size_t *freeElementCount, int *invertedElementCount, size_t *elementCount, int *invertedSampleCount, size_t *sampleCount, long unsigned int *count, long unsigned int *invalid, double *sum, double *sqrSum, MsqError &) const MBMesquite::ParallelHelperImpl [protected, virtual]
communication_modelMBMesquite::ParallelHelperImpl [private]
CommunicationModel enum nameMBMesquite::ParallelHelperImpl
communicatorMBMesquite::ParallelHelperImpl [private]
compute_first_independent_set(std::vector< Mesh::VertexHandle > &fixed_vertices)MBMesquite::ParallelHelperImpl [protected, virtual]
compute_independent_set()MBMesquite::ParallelHelperImpl [private]
compute_next_independent_set()MBMesquite::ParallelHelperImpl [protected, virtual]
exportProcMBMesquite::ParallelHelperImpl [private]
exportVtxGIDsMBMesquite::ParallelHelperImpl [private]
exportVtxLIDsMBMesquite::ParallelHelperImpl [private]
generate_random_numbersMBMesquite::ParallelHelperImpl [private]
get_next_partition_boundary_vertex(MBMesquite::Mesh::VertexHandle &vertex_handle)MBMesquite::ParallelHelperImpl [protected, virtual]
get_nprocs() const MBMesquite::ParallelHelperImpl [protected, virtual]
get_rank() const MBMesquite::ParallelHelperImpl [protected, virtual]
global_work_remainsMBMesquite::ParallelHelperImpl [private]
in_independent_setMBMesquite::ParallelHelperImpl [private]
is_our_element(Mesh::ElementHandle element_handle, MsqError &err) const MBMesquite::ParallelHelperImpl [protected, virtual]
is_our_vertex(Mesh::VertexHandle vertex_handle, MsqError &err) const MBMesquite::ParallelHelperImpl [protected, virtual]
iterationMBMesquite::ParallelHelperImpl [private]
meshMBMesquite::ParallelHelperImpl [private]
neighbourProcMBMesquite::ParallelHelperImpl [private]
neighbourProcRecvMBMesquite::ParallelHelperImpl [private]
neighbourProcRecvRemainMBMesquite::ParallelHelperImpl [private]
neighbourProcSendMBMesquite::ParallelHelperImpl [private]
neighbourProcSendRemainMBMesquite::ParallelHelperImpl [private]
next_vtx_partition_boundaryMBMesquite::ParallelHelperImpl [private]
NonBlocking enum valueMBMesquite::ParallelHelperImpl
NonBlockingAvoidAllReduce enum valueMBMesquite::ParallelHelperImpl
nprocsMBMesquite::ParallelHelperImpl [private]
num_already_recv_verticesMBMesquite::ParallelHelperImpl [private]
num_already_smoothed_verticesMBMesquite::ParallelHelperImpl [private]
num_exportVtxMBMesquite::ParallelHelperImpl [private]
num_vertexMBMesquite::ParallelHelperImpl [private]
num_vtx_partition_boundaryMBMesquite::ParallelHelperImpl [private]
num_vtx_partition_boundary_localMBMesquite::ParallelHelperImpl [private]
num_vtx_partition_boundary_remoteMBMesquite::ParallelHelperImpl [private]
ParallelHelperImpl()MBMesquite::ParallelHelperImpl
part_gidMBMesquite::ParallelHelperImpl [private]
part_proc_ownerMBMesquite::ParallelHelperImpl [private]
part_rand_numberMBMesquite::ParallelHelperImpl [private]
part_smoothed_flagMBMesquite::ParallelHelperImpl [private]
part_verticesMBMesquite::ParallelHelperImpl [private]
QualityAssessor classMBMesquite::ParallelHelperImpl [friend]
rankMBMesquite::ParallelHelperImpl [private]
set_communication_model(int model, MsqError &err)MBMesquite::ParallelHelperImpl [virtual]
set_communicator(size_t comm)MBMesquite::ParallelHelperImpl [virtual]
set_communicator(const void *comm)MBMesquite::ParallelHelperImpl [inline]
set_generate_random_numbers(int grn, MsqError &err)MBMesquite::ParallelHelperImpl [virtual]
set_parallel_mesh(ParallelMesh *mesh)MBMesquite::ParallelHelperImpl [virtual]
smoothing_close(MsqError &err)MBMesquite::ParallelHelperImpl [protected, virtual]
smoothing_init(MsqError &err)MBMesquite::ParallelHelperImpl [protected, virtual]
total_num_vertices_to_recvMBMesquite::ParallelHelperImpl [private]
total_num_vertices_to_smoothMBMesquite::ParallelHelperImpl [private]
TrulyNonBlocking enum valueMBMesquite::ParallelHelperImpl
TrulyNonBlockingAvoidAllReduce enum valueMBMesquite::ParallelHelperImpl
unghost_num_procsMBMesquite::ParallelHelperImpl [private]
unghost_num_vtxMBMesquite::ParallelHelperImpl [private]
unghost_procsMBMesquite::ParallelHelperImpl [private]
unghost_procs_num_vtxMBMesquite::ParallelHelperImpl [private]
unghost_procs_offsetMBMesquite::ParallelHelperImpl [private]
unghost_verticesMBMesquite::ParallelHelperImpl [private]
update_gidMBMesquite::ParallelHelperImpl [private]
update_num_procsMBMesquite::ParallelHelperImpl [private]
update_num_vtxMBMesquite::ParallelHelperImpl [private]
update_procsMBMesquite::ParallelHelperImpl [private]
update_procs_num_vtxMBMesquite::ParallelHelperImpl [private]
update_procs_offsetMBMesquite::ParallelHelperImpl [private]
VertexMover classMBMesquite::ParallelHelperImpl [friend]
vid_mapMBMesquite::ParallelHelperImpl [private]
vtx_in_partition_boundaryMBMesquite::ParallelHelperImpl [private]
vtx_off_proc_listMBMesquite::ParallelHelperImpl [private]
~ParallelHelper()MBMesquite::ParallelHelper [inline, virtual]
~ParallelHelperImpl()MBMesquite::ParallelHelperImpl
