, including all inherited members.
add_histogram_assessment(QualityMetric *qm, double min, double max, int intervals, double power_mean=0.0, const char *metric_value_tag_name=0, const char *metric_label=0) | MBMesquite::QualityAssessor | |
add_quality_assessment(QualityMetric *metric, int histogram_intervals=0, double power_mean=0.0, const char *metric_value_tag_name=0, const char *metric_label=0) | MBMesquite::QualityAssessor | |
assessList | MBMesquite::QualityAssessor | [private] |
disable_printing_results() | MBMesquite::QualityAssessor | [inline] |
dont_tag_fixed_elements() | MBMesquite::QualityAssessor | [inline] |
dont_tag_inverted_elements() | MBMesquite::QualityAssessor | [inline] |
element_name_as_string(int enum_name) | MBMesquite::QualityAssessor | [private, static] |
elementTypeCount | MBMesquite::QualityAssessor | [private] |
find_or_add(QualityMetric *qm, const char *label=0) | MBMesquite::QualityAssessor | [private] |
find_stopping_assessment() | MBMesquite::QualityAssessor | [private] |
fixedTagName | MBMesquite::QualityAssessor | [private] |
get_all_results() const | MBMesquite::QualityAssessor | [inline] |
get_inverted_element_count(int &inverted_elems, int &inverted_samples, MsqError &err) | MBMesquite::QualityAssessor | |
get_name() const | MBMesquite::QualityAssessor | [inline, virtual] |
get_results(QualityMetric *metric) const | MBMesquite::QualityAssessor | |
get_results(const char *metric_name) const | MBMesquite::QualityAssessor | |
get_tag(Mesh *mesh, std::string name, Mesh::TagType type, unsigned size, MsqError &err) | MBMesquite::QualityAssessor | [private] |
get_terminal_width() const | MBMesquite::QualityAssessor | [private] |
initialize_queue(MeshDomainAssoc *mesh_and_domain, const Settings *settings, MsqError &err) | MBMesquite::QualityAssessor | [virtual] |
initialize_vertex_byte(MeshDomainAssoc *mesh_and_domain, const Settings *settings, MsqError &err) | MBMesquite::Instruction | [static] |
invalid_elements() const | MBMesquite::QualityAssessor | |
invalid_values | MBMesquite::QualityAssessor | [private] |
invertedTagName | MBMesquite::QualityAssessor | [private] |
list_type typedef | MBMesquite::QualityAssessor | |
loop_over_mesh(MeshDomainAssoc *mesh_and_domain, const Settings *settings, MsqError &err) | MBMesquite::QualityAssessor | [virtual] |
loop_over_mesh(ParallelMesh *mesh, MeshDomain *domain, const Settings *settings, MsqError &err) | MBMesquite::QualityAssessor | [virtual] |
loop_over_mesh_internal(MeshDomainAssoc *mesh_and_domain, const Settings *settings, ParallelHelper *helper, MsqError &err) | MBMesquite::QualityAssessor | [private] |
measure_free_samples_only(bool yesno) | MBMesquite::QualityAssessor | [inline] |
measuring_free_samples_only() const | MBMesquite::QualityAssessor | [inline] |
myData | MBMesquite::QualityAssessor | [private] |
operator=(const QualityAssessor ©) | MBMesquite::QualityAssessor | |
outputStream | MBMesquite::QualityAssessor | [private] |
print_summary(std::ostream &stream) const | MBMesquite::QualityAssessor | |
printSummary | MBMesquite::QualityAssessor | [private] |
QualityAssessor(bool print_summary_to_std_out=true, bool free_elements_only=true, const char *inverted_element_tag_name=0, std::string name=std::string()) | MBMesquite::QualityAssessor | |
QualityAssessor(std::ostream &output_stream, bool free_elements_only=true, const char *inverted_element_tag_name=0, std::string name=std::string()) | MBMesquite::QualityAssessor | |
QualityAssessor(std::ostream &output_stream, QualityMetric *metric, int histogram_intervals=0, double power_mean=0.0, bool free_elements_only=true, const char *metric_value_tag_name=0, const char *inverted_element_tag_name=0, std::string name=std::string()) | MBMesquite::QualityAssessor | |
QualityAssessor(QualityMetric *metric, int histogram_intervals=0, double power_mean=0.0, bool free_elements_only=true, const char *metric_value_tag_name=0, bool print_summary_to_std_out=true, const char *inverted_element_tag_name=0, std::string name=std::string()) | MBMesquite::QualityAssessor | |
QualityAssessor(const QualityAssessor ©) | MBMesquite::QualityAssessor | |
qualityAssessorName | MBMesquite::QualityAssessor | [private] |
reset_data() | MBMesquite::QualityAssessor | |
round_to_3_significant_digits(double number) | MBMesquite::QualityAssessor | [private, static] |
scale_histograms(QualityAssessor *optimal) | MBMesquite::QualityAssessor | |
set_name(std::string name) | MBMesquite::QualityAssessor | [inline] |
set_stopping_assessment(QualityMetric *metric, int histogram_intervals=0, double power_mean=0.0, const char *metric_value_tag_name=0, const char *metric_label=0) | MBMesquite::QualityAssessor | |
skipFixedSamples | MBMesquite::QualityAssessor | [private] |
tag_fixed_elements(std::string tagname) | MBMesquite::QualityAssessor | [inline] |
tag_inverted_elements(std::string tagname) | MBMesquite::QualityAssessor | [inline] |
tagging_fixed_elements() const | MBMesquite::QualityAssessor | [inline] |
tagging_inverted_elements() const | MBMesquite::QualityAssessor | [inline] |
~Instruction() | MBMesquite::Instruction | [virtual] |
~QualityAssessor() | MBMesquite::QualityAssessor | [virtual] |
