, including all inherited members.
| _ntot | moab::Coupler | [private] |
| _spectralSource | moab::Coupler | [private] |
| _spectralTarget | moab::Coupler | [private] |
| _xm1Tag | moab::Coupler | [private] |
| _ym1Tag | moab::Coupler | [private] |
| _zm1Tag | moab::Coupler | [private] |
| all_boxes() const | moab::Coupler | [inline] |
| allBoxes | moab::Coupler | [private] |
| apply_group_norm_factor(std::vector< std::vector< EntityHandle > > &entity_sets, std::vector< double > &norm_factors, const char *norm_tag, Coupler::IntegType integ_type) | moab::Coupler | |
| consolidate_tuples(TupleList **all_tuples, unsigned int num_tuples, TupleList **unique_tuples) | moab::Coupler | |
| CONSTANT enum value | moab::Coupler | |
| constant_interp(EntityHandle elem, Tag tag, double &field) | moab::Coupler | [private] |
| Coupler(Interface *impl, ParallelComm *pc, Range &local_elems, int coupler_id, bool init_tree=true, int max_ent_dim=3) | moab::Coupler | |
| create_tuples(Range &ent_sets, const char **tag_names, unsigned int num_tags, TupleList **tuples) | moab::Coupler | |
| create_tuples(Range &ent_sets, Tag *tag_handles, unsigned int num_tags, TupleList **tuples) | moab::Coupler | |
| do_normalization(const char *norm_tag, std::vector< std::vector< EntityHandle > > &entity_sets, std::vector< std::vector< EntityHandle > > &entity_groups, Coupler::IntegType integ_type, int num_integ_pts) | moab::Coupler | |
| get_gl_points_on_elements(Range &targ_elems, std::vector< double > &vpos, int &numPointsOfInterest) | moab::Coupler | |
| get_group_integ_vals(std::vector< std::vector< EntityHandle > > &groups, std::vector< double > &integ_vals, const char *norm_tag, int num_integ_pts, Coupler::IntegType integ_type) | moab::Coupler | |
| get_matching_entities(EntityHandle root_set, const char **tag_names, const char **tag_values, int num_tags, std::vector< std::vector< EntityHandle > > *entity_sets, std::vector< std::vector< EntityHandle > > *entity_groups) | moab::Coupler | |
| get_matching_entities(EntityHandle root_set, Tag *tag_handles, const char **tag_values, int num_tags, std::vector< std::vector< EntityHandle > > *entity_sets, std::vector< std::vector< EntityHandle > > *entity_groups) | moab::Coupler | |
| initialize_spectral_elements(EntityHandle rootSource, EntityHandle rootTarget, bool &specSou, bool &specTar) | moab::Coupler | |
| initialize_tree() | moab::Coupler | |
| IntegType enum name | moab::Coupler | |
| interp_field(EntityHandle elem, CartVect nat_coord, Tag tag, double &field) | moab::Coupler | [private] |
| interpolate(Coupler::Method method, Tag tag, double *interp_vals, TupleList *tl=NULL, bool normalize=true) | moab::Coupler | [inline] |
| interpolate(Coupler::Method method, const std::string &tag_name, double *interp_vals, TupleList *tl=NULL, bool normalize=true) | moab::Coupler | |
| interpolate(Coupler::Method *methods, const std::string *tag_names, int *points_per_method, int num_methods, double *interp_vals, TupleList *tl=NULL, bool normalize=true) | moab::Coupler | |
| interpolate(Coupler::Method *methods, Tag *tag_names, int *points_per_method, int num_methods, double *interp_vals, TupleList *tl=NULL, bool normalize=true) | moab::Coupler | |
| LINEAR_FE enum value | moab::Coupler | |
| local_root() const | moab::Coupler | [inline] |
| localRoot | moab::Coupler | [private] |
| locate_points(double *xyz, unsigned int num_points, double rel_eps=0.0, double abs_eps=0.0, TupleList *tl=NULL, bool store_local=true) | moab::Coupler | |
| locate_points(Range &ents, double rel_eps=0.0, double abs_eps=0.0, TupleList *tl=NULL, bool store_local=true) | moab::Coupler | |
| mapped_pts() const | moab::Coupler | [inline] |
| mappedPts | moab::Coupler | [private] |
| max_dim | moab::Coupler | [private] |
| mb_impl() const | moab::Coupler | [inline] |
| mbImpl | moab::Coupler | [private] |
| Method enum name | moab::Coupler | |
| my_id() const | moab::Coupler | [inline] |
| my_pc() const | moab::Coupler | [inline] |
| my_range() const | moab::Coupler | [inline] |
| my_tree() const | moab::Coupler | [inline] |
| myId | moab::Coupler | [private] |
| myPc | moab::Coupler | [private] |
| myRange | moab::Coupler | [private] |
| myTree | moab::Coupler | [private] |
| nat_param(double xyz[3], std::vector< EntityHandle > &entities, std::vector< CartVect > &nat_coords, double epsilon=0.0) | moab::Coupler | [private] |
| normalize_mesh(EntityHandle root_set, const char *norm_tag, Coupler::IntegType integ_type, int num_integ_pts) | moab::Coupler | |
| normalize_subset(EntityHandle root_set, const char *norm_tag, const char **tag_names, int num_tags, const char **tag_values, Coupler::IntegType integ_type, int num_integ_pts) | moab::Coupler | |
| normalize_subset(EntityHandle root_set, const char *norm_tag, Tag *tag_handles, int num_tags, const char **tag_values, Coupler::IntegType integ_type, int num_integ_pts) | moab::Coupler | |
| num_its() const | moab::Coupler | [inline] |
| numIts | moab::Coupler | [private] |
| QUADRATIC_FE enum value | moab::Coupler | |
| set_spherical(bool arg1=true) | moab::Coupler | [inline] |
| SPECTRAL enum value | moab::Coupler | |
| spherical | moab::Coupler | [private] |
| SPHERICAL enum value | moab::Coupler | |
| target_ents() const | moab::Coupler | [inline] |
| targetEnts | moab::Coupler | [private] |
| targetPts | moab::Coupler | [private] |
| test_local_box(double *xyz, int from_proc, int remote_index, int index, bool &point_located, double rel_eps=0.0, double abs_eps=0.0, TupleList *tl=NULL) | moab::Coupler | [private] |
| VOLUME enum value | moab::Coupler | |
| ~Coupler() | moab::Coupler | [virtual] |
