, including all inherited members.
| _degrees_out | moab::HiReconstruction | [protected] |
| _dim | moab::HiReconstruction | [protected] |
| _geom | moab::HiReconstruction | [protected] |
| _hasderiv | moab::HiReconstruction | [protected] |
| _hasfittings | moab::HiReconstruction | [protected] |
| _incells | moab::HiReconstruction | [protected] |
| _inedges | moab::HiReconstruction | [protected] |
| _infaces | moab::HiReconstruction | [protected] |
| _initfittings | moab::HiReconstruction | [protected] |
| _interps | moab::HiReconstruction | [protected] |
| _inverts | moab::HiReconstruction | [protected] |
| _local_coords | moab::HiReconstruction | [protected] |
| _local_fit_coeffs | moab::HiReconstruction | [protected] |
| _MAXPNTS | moab::HiReconstruction | [protected] |
| _mesh2rec | moab::HiReconstruction | [protected] |
| _MINEPS | moab::HiReconstruction | [protected] |
| _MINPNTS | moab::HiReconstruction | [protected] |
| _nv2rec | moab::HiReconstruction | [protected] |
| _vertID2coeffID | moab::HiReconstruction | [protected] |
| _verts2rec | moab::HiReconstruction | [protected] |
| ahf | moab::HiReconstruction | [protected] |
| average_vertex_normal(const EntityHandle vid, double *nrm) | moab::HiReconstruction | [protected] |
| average_vertex_tangent(const EntityHandle vid, double *tang) | moab::HiReconstruction | [protected] |
| check_barycentric_coords(const int nws, const double *naturalcoords) | moab::HiReconstruction | [protected] |
| compute_average_vertex_normals_surf() | moab::HiReconstruction | [protected] |
| compute_average_vertex_tangents_curve() | moab::HiReconstruction | [protected] |
| compute_weights(const int nrows, const int ncols, const double *us, const int nngbs, const double *ngbnrms, const int degree, const double toler, double *ws) | moab::HiReconstruction | [protected] |
| estimate_num_ghost_layers(int degree, bool interp=false) | moab::HiReconstruction | [inline, static] |
| estimate_num_rings(int degree, bool interp) | moab::HiReconstruction | [protected] |
| eval_vander_bivar_cmf(const int npts2fit, const double *us, const int ndim, double *bs, int degree, const double *ws, const bool interp, const bool safeguard, int *degree_out, int *degree_pnt, int *degree_qr) | moab::HiReconstruction | [protected] |
| eval_vander_univar_cmf(const int npts2fit, const double *us, const int ndim, double *bs, int degree, const double *ws, const bool interp, const bool safeguard, int *degree_out) | moab::HiReconstruction | [protected] |
| get_fittings_data(EntityHandle vid, GEOMTYPE &geomtype, std::vector< double > &coords, int °ree_out, std::vector< double > &coeffs, bool &interp) | moab::HiReconstruction | |
| get_normals_surf(const Range &vertsh, double *nrms) | moab::HiReconstruction | [protected] |
| get_tangents_curve(const Range &vertsh, double *tangs) | moab::HiReconstruction | [protected] |
| hiproj_walf_around_vertex(EntityHandle vid, const int npts2fit, const double *coords2fit, double *hiproj_new) | moab::HiReconstruction | |
| hiproj_walf_in_element(EntityHandle elem, const int nvpe, const int npts2fit, const double *naturalcoords2fit, double *newcoords) | moab::HiReconstruction | |
| HiReconstruction(Core *impl, ParallelComm *comm=0, EntityHandle meshIn=0, int minpnts=5, bool recwhole=true) | moab::HiReconstruction | |
| HiReconstruction(const HiReconstruction &source) | moab::HiReconstruction | [protected] |
| initialize(bool recwhole) | moab::HiReconstruction | |
| initialize_3Dcurve_geom(const int degree) | moab::HiReconstruction | [protected] |
| initialize_3Dcurve_geom(const size_t npts, const int *degrees) | moab::HiReconstruction | [protected] |
| initialize_surf_geom(const int degree) | moab::HiReconstruction | [protected] |
| initialize_surf_geom(const size_t npts, const int *degrees) | moab::HiReconstruction | [protected] |
| mbImpl | moab::HiReconstruction | [protected] |
| obtain_nring_ngbvs(const EntityHandle vid, int ring, const int minpnts, Range &ngbvs) | moab::HiReconstruction | [protected] |
| operator=(const HiReconstruction &right) | moab::HiReconstruction | [protected] |
| pcomm | moab::HiReconstruction | [protected] |
| polyfit3d_curve_get_coeff(const int nverts, const double *ngbcors, const double *ngbtangs, int degree, const bool interp, const bool safeguard, const int ncoords, double *coords, const int ncoeffs, double *coeffs, int *degree_out) | moab::HiReconstruction | [protected] |
| polyfit3d_surf_get_coeff(const int nverts, const double *ngbcors, const double *ngbnrms, int degree, const bool interp, const bool safeguard, const int ncoords, double *coords, const int ncoeffs, double *coeffs, int *degree_out, int *degree_pnt, int *degree_qr) | moab::HiReconstruction | [protected] |
| polyfit3d_walf_curve_vertex(const EntityHandle vid, const bool interp, int degree, int minpnts, const bool safeguard, const int ncoords, double *coords, int *degree_out, const int ncoeffs, double *coeffs) | moab::HiReconstruction | |
| polyfit3d_walf_surf_vertex(const EntityHandle vid, const bool interp, int degree, int minpnts, const bool safeguard, const int ncoords, double *coords, int *degree_out, const int ncoeffs, double *coeffs) | moab::HiReconstruction | |
| reconstruct3D_curve_geom(int degree, bool interp, bool safeguard, bool reset=false) | moab::HiReconstruction | |
| reconstruct3D_curve_geom(size_t npts, int *degrees, bool *interps, bool safeguard, bool reset=false) | moab::HiReconstruction | |
| reconstruct3D_surf_geom(int degree, bool interp, bool safeguard, bool reset=false) | moab::HiReconstruction | |
| reconstruct3D_surf_geom(size_t npts, int *degrees, bool *interps, bool safeguard, bool reset=false) | moab::HiReconstruction | |
| vertex_get_incident_elements(const EntityHandle &vid, const int elemdim, std::vector< EntityHandle > &adjents) | moab::HiReconstruction | [protected] |
| walf3d_curve_vertex_eval(const double *local_origin, const double *local_coords, const int local_deg, const double *local_coeffs, const bool interp, const int npts2fit, const double *coords2fit, double *hiproj_new) | moab::HiReconstruction | |
| walf3d_surf_vertex_eval(const double *local_origin, const double *local_coords, const int local_deg, const double *local_coeffs, const bool interp, const int npts2fit, const double *coords2fit, double *hiproj_new) | moab::HiReconstruction | |
| ~HiReconstruction() | moab::HiReconstruction | |
