, including all inherited members.
| _fileId | moab::NCHelper | [protected] |
| _fileSet | moab::NCHelper | [protected] |
| _opts | moab::NCHelper | [protected] |
| _readNC | moab::NCHelper | [protected] |
| check_existing_mesh() | moab::ScdNCHelper | [private, virtual] |
| create_attrib_string(const std::map< std::string, ReadNC::AttData > &attMap, std::string &attString, std::vector< int > &attLen) | moab::NCHelper | [protected] |
| create_conventional_tags(const std::vector< int > &tstep_nums) | moab::NCHelper | |
| create_dummy_variables() | moab::NCHelper | [protected] |
| create_mesh(Range &faces) | moab::ScdNCHelper | [private, virtual] |
| create_quad_coordinate_tag() | moab::ScdNCHelper | [private] |
| dummyVarNames | moab::NCHelper | [protected] |
| gCDims | moab::ScdNCHelper | [protected] |
| gDims | moab::ScdNCHelper | [protected] |
| get_mesh_type_name()=0 | moab::NCHelper | [pure virtual] |
| get_nc_helper(ReadNC *readNC, int fileId, const FileOptions &opts, EntityHandle fileSet) | moab::NCHelper | [static] |
| get_tag_to_nonset(ReadNC::VarData &var_data, int tstep_num, Tag &tagh, int num_lev) | moab::NCHelper | [protected] |
| get_tag_to_set(ReadNC::VarData &var_data, int tstep_num, Tag &tagh) | moab::NCHelper | [protected] |
| globallyPeriodic | moab::ScdNCHelper | [protected] |
| iCDim | moab::ScdNCHelper | [protected] |
| iDim | moab::ScdNCHelper | [protected] |
| ignoredVarNames | moab::NCHelper | [protected] |
| ilCVals | moab::ScdNCHelper | [protected] |
| ilVals | moab::ScdNCHelper | [protected] |
| init_mesh_vals()=0 | moab::NCHelper | [pure virtual] |
| jCDim | moab::ScdNCHelper | [protected] |
| jDim | moab::ScdNCHelper | [protected] |
| jlCVals | moab::ScdNCHelper | [protected] |
| jlVals | moab::ScdNCHelper | [protected] |
| kji_to_jik(size_t ni, size_t nj, size_t nk, void *dest, T *source) | moab::ScdNCHelper | [inline, private] |
| lCDims | moab::ScdNCHelper | [protected] |
| lDims | moab::ScdNCHelper | [protected] |
| levDim | moab::NCHelper | [protected] |
| levVals | moab::NCHelper | [protected] |
| locallyPeriodic | moab::ScdNCHelper | [protected] |
| NCHelper(ReadNC *readNC, int fileId, const FileOptions &opts, EntityHandle fileSet) | moab::NCHelper | [inline] |
| nLevels | moab::NCHelper | [protected] |
| nTimeSteps | moab::NCHelper | [protected] |
| read_coordinate(const char *var_name, int lmin, int lmax, std::vector< double > &cvals) | moab::NCHelper | [protected] |
| read_scd_variables_to_nonset(std::vector< ReadNC::VarData > &vdatas, std::vector< int > &tstep_nums) | moab::ScdNCHelper | [private] |
| read_scd_variables_to_nonset_allocate(std::vector< ReadNC::VarData > &vdatas, std::vector< int > &tstep_nums) | moab::ScdNCHelper | [private] |
| read_variables(std::vector< std::string > &var_names, std::vector< int > &tstep_nums) | moab::ScdNCHelper | [private, virtual] |
| read_variables_setup(std::vector< std::string > &var_names, std::vector< int > &tstep_nums, std::vector< ReadNC::VarData > &vdatas, std::vector< ReadNC::VarData > &vsetdatas) | moab::NCHelper | [protected] |
| read_variables_to_set(std::vector< ReadNC::VarData > &vdatas, std::vector< int > &tstep_nums) | moab::NCHelper | [protected] |
| ScdNCHelper(ReadNC *readNC, int fileId, const FileOptions &opts, EntityHandle fileSet) | moab::ScdNCHelper | [inline] |
| tDim | moab::NCHelper | [protected] |
| tVals | moab::NCHelper | [protected] |
| update_time_tag_vals() | moab::NCHelper | |
| ~NCHelper() | moab::NCHelper | [inline, virtual] |
| ~ScdNCHelper() | moab::ScdNCHelper | [inline, virtual] |
