, including all inherited members.
| aBODY enum value | moab::Tqdcfr | |
| acisb enum value | moab::Tqdcfr | |
| acisDumpFile | moab::Tqdcfr | [private] |
| acist enum value | moab::Tqdcfr | |
| aEDGE enum value | moab::Tqdcfr | |
| ATTRIB enum value | moab::Tqdcfr | |
| attribVectorTag | moab::Tqdcfr | |
| aVERTEX enum value | moab::Tqdcfr | |
| BAR enum value | moab::Tqdcfr | [private] |
| BAR2 enum value | moab::Tqdcfr | [private] |
| BAR3 enum value | moab::Tqdcfr | [private] |
| BEAM enum value | moab::Tqdcfr | [private] |
| BEAM2 enum value | moab::Tqdcfr | [private] |
| BEAM3 enum value | moab::Tqdcfr | [private] |
| beforeEnts | moab::Tqdcfr | |
| block_type_to_mb_type | moab::Tqdcfr | [private, static] |
| blockTag | moab::Tqdcfr | |
| BODY enum value | moab::Tqdcfr | [private] |
| categoryTag | moab::Tqdcfr | |
| char_buf | moab::Tqdcfr | |
| check_contiguous(const unsigned int num_ents, int &contig, unsigned int &min_id, unsigned int &max_id) | moab::Tqdcfr | |
| COEDGE enum value | moab::Tqdcfr | |
| convert_nodesets_sidesets() | moab::Tqdcfr | [private] |
| CONVERT_TO_INTS(unsigned int num_ents) | moab::Tqdcfr | |
| create_set(EntityHandle &h, unsigned int flags=MESHSET_SET) | moab::Tqdcfr | |
| cub_elem_num_verts | moab::Tqdcfr | [private, static] |
| cub_elem_num_verts_len | moab::Tqdcfr | [private, static] |
| cubFile | moab::Tqdcfr | |
| cubIdTag | moab::Tqdcfr | |
| cubMOABVertexMap | moab::Tqdcfr | [private] |
| currElementIdOffset | moab::Tqdcfr | |
| currVHandleOffset | moab::Tqdcfr | |
| CURVE enum value | moab::Tqdcfr | [private] |
| dbl_buf | moab::Tqdcfr | |
| EDGE enum value | moab::Tqdcfr | [private] |
| entityNameTag | moab::Tqdcfr | |
| exodusmesh enum value | moab::Tqdcfr | |
| FACE enum value | moab::Tqdcfr | |
| facet enum value | moab::Tqdcfr | |
| factory(Interface *) | moab::Tqdcfr | [static] |
| fileTOC | moab::Tqdcfr | |
| find_model(const unsigned int model_type) | moab::Tqdcfr | |
| FREADC(unsigned num_ents) | moab::Tqdcfr | |
| FREADCA(unsigned num_ents, char *arrat) | moab::Tqdcfr | |
| FREADD(unsigned num_ents) | moab::Tqdcfr | |
| FREADDA(unsigned num_ents, double *array) | moab::Tqdcfr | |
| FREADI(unsigned num_ents) | moab::Tqdcfr | |
| FREADIA(unsigned num_ents, unsigned int *array) | moab::Tqdcfr | |
| FSEEK(unsigned offset) | moab::Tqdcfr | |
| geom_categories | moab::Tqdcfr | [private, static] |
| geomTag | moab::Tqdcfr | |
| get_entities(const unsigned int *mem_types, int *id_buf, const unsigned int id_buf_size, const bool is_group, std::vector< EntityHandle > &entities) | moab::Tqdcfr | [private] |
| get_entities(const unsigned int this_type, int *id_buf, const unsigned int id_buf_size, std::vector< EntityHandle > &entities, std::vector< EntityHandle > &excl_entities) | moab::Tqdcfr | [private] |
| get_mesh_entities(const unsigned int this_type, int *id_buf, const unsigned id_buf_size, std::vector< EntityHandle > &entities, std::vector< EntityHandle > &excl_entities) | moab::Tqdcfr | [private] |
| get_names(MetaDataContainer &md, unsigned int set_index, EntityHandle seth) | moab::Tqdcfr | [private] |
| get_ref_entities(const unsigned int this_type, int *id_buf, const unsigned id_buf_size, std::vector< EntityHandle > &entities) | moab::Tqdcfr | [private] |
| gidSetMap | moab::Tqdcfr | |
| globalIdTag | moab::Tqdcfr | |
| GROUP enum value | moab::Tqdcfr | [private] |
| group_type_to_mb_type | moab::Tqdcfr | [private, static] |
| hasMidNodesTag | moab::Tqdcfr | |
| HEX enum value | moab::Tqdcfr | [private] |
| HEX20 enum value | moab::Tqdcfr | [private] |
| HEX27 enum value | moab::Tqdcfr | [private] |
| HEX8 enum value | moab::Tqdcfr | [private] |
| HEX9 enum value | moab::Tqdcfr | [private] |
| HEXeight enum value | moab::Tqdcfr | [private] |
| HEXSHELL enum value | moab::Tqdcfr | [private] |
| int_buf | moab::Tqdcfr | |
| interpret_acis_records(std::vector< AcisRecord > &records) | moab::Tqdcfr | [private] |
| INVALID_ELEMENT_TYPE enum value | moab::Tqdcfr | [private] |
| load_file(const char *file_name, const EntityHandle *file_set, const FileOptions &opts, const SubsetList *subset_list=0, const Tag *file_id_tag=0) | moab::Tqdcfr | [virtual] |
| LOOP enum value | moab::Tqdcfr | |
| LUMP enum value | moab::Tqdcfr | |
| mdbImpl | moab::Tqdcfr | |
| mFileSet | moab::Tqdcfr | [private] |
| modelEntries | moab::Tqdcfr | |
| modelMetaData | moab::Tqdcfr | |
| mp_type_to_mb_type | moab::Tqdcfr | [private, static] |
| NODE enum value | moab::Tqdcfr | [private] |
| nsTag | moab::Tqdcfr | |
| parse_acis_attribs(const unsigned int entity_rec_num, std::vector< AcisRecord > &records) | moab::Tqdcfr | [private] |
| printedElemWarning | moab::Tqdcfr | [private] |
| printedSeqWarning | moab::Tqdcfr | [private] |
| process_record(AcisRecord &this_record) | moab::Tqdcfr | [private] |
| process_sideset_10(const int this_type, const int num_ents, const int sense_size, std::vector< EntityHandle > &ss_entities, Tqdcfr::SidesetHeader *sideseth) | moab::Tqdcfr | [private] |
| process_sideset_11(std::vector< EntityHandle > &ss_entities, int num_wrts, Tqdcfr::SidesetHeader *sideseth) | moab::Tqdcfr | [private] |
| put_into_set(EntityHandle set_handle, std::vector< EntityHandle > &entities, std::vector< EntityHandle > &excl_entities) | moab::Tqdcfr | [private] |
| PYRAMID enum value | moab::Tqdcfr | [private] |
| PYRAMID13 enum value | moab::Tqdcfr | [private] |
| PYRAMID18 enum value | moab::Tqdcfr | [private] |
| PYRAMID5 enum value | moab::Tqdcfr | [private] |
| PYRAMID8 enum value | moab::Tqdcfr | [private] |
| PYRAMIDfive enum value | moab::Tqdcfr | [private] |
| QUAD enum value | moab::Tqdcfr | [private] |
| QUAD4 enum value | moab::Tqdcfr | [private] |
| QUAD5 enum value | moab::Tqdcfr | [private] |
| QUAD8 enum value | moab::Tqdcfr | [private] |
| QUAD9 enum value | moab::Tqdcfr | [private] |
| QUADfour enum value | moab::Tqdcfr | [private] |
| read_acis_records(const char *sat_file_name=0) | moab::Tqdcfr | [private] |
| read_block(const unsigned int blindex, const double data_version, ModelEntry *model, BlockHeader *blockh) | moab::Tqdcfr | |
| read_elements(ModelEntry *model, GeomHeader *entity) | moab::Tqdcfr | |
| read_file_header() | moab::Tqdcfr | |
| read_group(const unsigned int gr_index, ModelEntry *model, GroupHeader *grouph) | moab::Tqdcfr | |
| read_md_string(std::string &name) | moab::Tqdcfr | |
| read_meta_data(const unsigned int metadata_offset, MetaDataContainer &mc) | moab::Tqdcfr | |
| read_model_entries() | moab::Tqdcfr | |
| read_nodes(const unsigned int gindex, ModelEntry *model, GeomHeader *entity) | moab::Tqdcfr | |
| read_nodeset(const unsigned int nsindex, ModelEntry *model, NodesetHeader *nodeseth) | moab::Tqdcfr | |
| read_sideset(const unsigned int ssindex, const double data_version, ModelEntry *model, SidesetHeader *sideseth) | moab::Tqdcfr | |
| read_tag_values(const char *file_name, const char *tag_name, const FileOptions &opts, std::vector< int > &tag_values_out, const SubsetList *subset_list=0) | moab::Tqdcfr | [virtual] |
| readUtilIface | moab::Tqdcfr | |
| reset_record(AcisRecord &this_record) | moab::Tqdcfr | [private] |
| SHEL enum value | moab::Tqdcfr | [private] |
| SHELL enum value | moab::Tqdcfr | |
| SHELL4 enum value | moab::Tqdcfr | [private] |
| SHELL8 enum value | moab::Tqdcfr | [private] |
| SHELL9 enum value | moab::Tqdcfr | [private] |
| SPHERE_EXO enum value | moab::Tqdcfr | [private] |
| SPRING enum value | moab::Tqdcfr | [private] |
| ssTag | moab::Tqdcfr | |
| SURFACE enum value | moab::Tqdcfr | [private] |
| swapForEndianness | moab::Tqdcfr | |
| TET enum value | moab::Tqdcfr | [private] |
| TETRA10 enum value | moab::Tqdcfr | [private] |
| TETRA14 enum value | moab::Tqdcfr | [private] |
| TETRA4 enum value | moab::Tqdcfr | [private] |
| TETRA8 enum value | moab::Tqdcfr | [private] |
| TETRAfour enum value | moab::Tqdcfr | [private] |
| Tqdcfr(Interface *impl) | moab::Tqdcfr | |
| TRI enum value | moab::Tqdcfr | [private] |
| TRI3 enum value | moab::Tqdcfr | [private] |
| TRI6 enum value | moab::Tqdcfr | [private] |
| TRI7 enum value | moab::Tqdcfr | [private] |
| TRISHELL enum value | moab::Tqdcfr | [private] |
| TRISHELL3 enum value | moab::Tqdcfr | [private] |
| TRISHELL6 enum value | moab::Tqdcfr | [private] |
| TRISHELL7 enum value | moab::Tqdcfr | [private] |
| TRIthree enum value | moab::Tqdcfr | [private] |
| TRUSS enum value | moab::Tqdcfr | [private] |
| TRUSS2 enum value | moab::Tqdcfr | [private] |
| TRUSS3 enum value | moab::Tqdcfr | [private] |
| type_from_cub_type(const unsigned int cub_type, const unsigned int nodes_per_elem) | moab::Tqdcfr | |
| uidSetMap | moab::Tqdcfr | |
| uint_buf | moab::Tqdcfr | |
| uniqueIdTag | moab::Tqdcfr | |
| UNKNOWN enum value | moab::Tqdcfr | |
| VERTEX enum value | moab::Tqdcfr | [private] |
| VOLUME enum value | moab::Tqdcfr | [private] |
| ~ReaderIface() | moab::ReaderIface | [inline, virtual] |
| ~Tqdcfr() | moab::Tqdcfr | |
