MOAB
4.9.3pre
00001 // This file is part of Eigen, a lightweight C++ template library 00002 // for linear algebra. 00003 // 00004 // Copyright (C) 2009 Gael Guennebaud <[email protected]> 00005 // Copyright (C) 2009 Hauke Heibel <[email protected]> 00006 // 00007 // This Source Code Form is subject to the terms of the Mozilla 00008 // Public License v. 2.0. If a copy of the MPL was not distributed 00009 // with this file, You can obtain one at http://mozilla.org/MPL/2.0/. 00010 00011 #ifndef EIGEN_STL_DETAILS_H 00012 #define EIGEN_STL_DETAILS_H 00013 00014 #ifndef EIGEN_ALIGNED_ALLOCATOR 00015 #define EIGEN_ALIGNED_ALLOCATOR Eigen::aligned_allocator 00016 #endif 00017 00018 namespace Eigen { 00019 00020 // This one is needed to prevent reimplementing the whole std::vector. 00021 template <class T> 00022 class aligned_allocator_indirection : public EIGEN_ALIGNED_ALLOCATOR<T> 00023 { 00024 public: 00025 typedef size_t size_type; 00026 typedef ptrdiff_t difference_type; 00027 typedef T* pointer; 00028 typedef const T* const_pointer; 00029 typedef T& reference; 00030 typedef const T& const_reference; 00031 typedef T value_type; 00032 00033 template<class U> 00034 struct rebind 00035 { 00036 typedef aligned_allocator_indirection<U> other; 00037 }; 00038 00039 aligned_allocator_indirection() {} 00040 aligned_allocator_indirection(const aligned_allocator_indirection& ) : EIGEN_ALIGNED_ALLOCATOR<T>() {} 00041 aligned_allocator_indirection(const EIGEN_ALIGNED_ALLOCATOR<T>& ) {} 00042 template<class U> 00043 aligned_allocator_indirection(const aligned_allocator_indirection<U>& ) {} 00044 template<class U> 00045 aligned_allocator_indirection(const EIGEN_ALIGNED_ALLOCATOR<U>& ) {} 00046 ~aligned_allocator_indirection() {} 00047 }; 00048 00049 #if EIGEN_COMP_MSVC 00050 00051 // sometimes, MSVC detects, at compile time, that the argument x 00052 // in std::vector::resize(size_t s,T x) won't be aligned and generate an error 00053 // even if this function is never called. Whence this little wrapper. 00054 #define EIGEN_WORKAROUND_MSVC_STL_SUPPORT(T) \ 00055 typename Eigen::internal::conditional< \ 00056 Eigen::internal::is_arithmetic<T>::value, \ 00057 T, \ 00058 Eigen::internal::workaround_msvc_stl_support<T> \ 00059 >::type 00060 00061 namespace internal { 00062 template<typename T> struct workaround_msvc_stl_support : public T 00063 { 00064 inline workaround_msvc_stl_support() : T() {} 00065 inline workaround_msvc_stl_support(const T& other) : T(other) {} 00066 inline operator T& () { return *static_cast<T*>(this); } 00067 inline operator const T& () const { return *static_cast<const T*>(this); } 00068 template<typename OtherT> 00069 inline T& operator=(const OtherT& other) 00070 { T::operator=(other); return *this; } 00071 inline workaround_msvc_stl_support& operator=(const workaround_msvc_stl_support& other) 00072 { T::operator=(other); return *this; } 00073 }; 00074 } 00075 00076 #else 00077 00078 #define EIGEN_WORKAROUND_MSVC_STL_SUPPORT(T) T 00079 00080 #endif 00081 00082 } 00083 00084 #endif // EIGEN_STL_DETAILS_H
