MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 ! This program shows how to do an imoab_coupler type test in fortran 90 00002 ! the atm and ocean files are read from repo, meshes are migrated to coupler pes, 00003 ! the intx is caried on, weight generation,; tag migration and projection, 00004 ! migrate back to ocean pes, and compare against baseline1.txt 00005 ! cannot change source/target files, or the layout, just test the imoab 00006 ! calls, that need to give the same results as C=++ equivalent test (imoab_coupler) 00007 ! between atm SE and ocn FV 00008 00009 SUBROUTINE errorout(ierr, message) 00010 integer ierr 00011 character*(*) message 00012 if (ierr .ne. 0) then 00013 print *, message 00014 call exit(1) 00015 end if 00016 return 00017 end 00018 ! 00019 #include "moab/MOABConfig.h" 00020 00021 #ifndef MOAB_MESH_DIR 00022 #error Specify MOAB_MESH_DIR path 00023 #endif 00024 00025 program imoab_coupler_fortran 00026 00027 use iso_c_binding 00028 use iMOAB 00029 00030 #include "mpif.h" 00031 #include "moab/MOABConfig.h" 00032 !implicit none 00033 integer :: m ! for number of arguments ; if less than 1, exit 00034 integer :: global_comm 00035 integer :: rankInGlobalComm, numProcesses 00036 integer :: ierr 00037 integer :: my_id, num_procs 00038 integer :: jgroup ! group for global comm 00039 character(:), allocatable :: atmFileName 00040 character(:), allocatable :: ocnFileName 00041 character(:), allocatable :: baselineFileName 00042 character(:), allocatable :: readopts, fileWriteOptions 00043 character :: appname*128 00044 character(:), allocatable :: weights_identifier1 00045 character(:), allocatable :: disc_methods1, disc_methods2, dof_tag_names1, dof_tag_names2 00046 integer :: disc_orders1, disc_orders2 00047 character(:), allocatable :: atmocn_map_file_name, intx_from_file_identifier 00048 00049 ! all groups and comms are on the same number of processes, for simplicity 00050 integer :: atmGroup, atmComm, ocnGroup, ocnComm, cplGroup, cplComm 00051 integer :: atmCouComm, ocnCouComm 00052 00053 integer :: cmpatm, cplatm, cmpocn, cplocn, atmocnid ! global IDs 00054 integer :: cmpAtmPID, cplAtmPID ! iMOAB app ids 00055 integer :: cmpOcnPID, cplOcnPID ! iMOAB app ids 00056 integer :: cplAtmOcnPID ! intx pid 00057 integer :: nghlay, partScheme, context_id 00058 integer :: fNoBubble, fMonotoneTypeID, fVolumetric, fNoConserve, fValidate, fInverseDistanceMap 00059 00060 integer, dimension(2) :: tagIndex 00061 integer, dimension (2) :: tagTypes! { DENSE_DOUBLE, DENSE_DOUBLE } 00062 integer :: atmCompNDoFs ! = disc_orders[0] * disc_orders[0], 00063 integer :: ocnCompNDoFs ! = 1 /*FV*/ 00064 character(:), allocatable :: bottomFields, bottomProjectedFields 00065 integer, dimension(3) :: nverts, nelem, nblocks, nsbc, ndbc 00066 double precision, allocatable :: vals(:) ! to set the double values to 0 00067 integer :: i ! for loops 00068 integer :: storLeng, eetype ! for tags defs 00069 character(:), allocatable :: concat_fieldname, concat_fieldnameT, outputFileOcn 00070 integer :: tagIndexIn2 ! not really needed 00071 integer :: dummyCpl, dummyRC, dummyType 00072 00073 cmpatm = 5 00074 cplatm = 6 00075 cmpocn = 17 00076 cplocn = 18 00077 atmocnid = 618 00078 00079 call mpi_init(ierr) 00080 call errorout(ierr,'mpi_init') 00081 call mpi_comm_rank (MPI_COMM_WORLD, my_id, ierr) 00082 call errorout(ierr, 'fail to get MPI rank') 00083 00084 call mpi_comm_size (MPI_COMM_WORLD, num_procs, ierr) 00085 call errorout(ierr, 'fail to get MPI size') 00086 call mpi_comm_dup(MPI_COMM_WORLD, global_comm, ierr) 00087 call errorout(ierr, 'fail to get global comm duplicate') 00088 00089 call MPI_Comm_group( global_comm, jgroup, ierr ); ! all processes in jgroup 00090 call errorout(ierr, 'fail to get joint group') 00091 ! readopts( "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION;PARALLEL_RESOLVE_SHARED_ENTS" ) 00092 ! readoptsLnd( "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION" ) 00093 atmFileName = & 00094 MOAB_MESH_DIR & 00095 //'unittest/wholeATM_T.h5m'//C_NULL_CHAR 00096 ocnFileName = & 00097 MOAB_MESH_DIR & 00098 //'unittest/recMeshOcn.h5m'//C_NULL_CHAR 00099 baselineFileName = & 00100 MOAB_MESH_DIR & 00101 //'unittest/baseline1.txt'//C_NULL_CHAR 00102 00103 ! all comms span the whole world, for simplicity 00104 atmComm = MPI_COMM_NULL 00105 ocnComm = MPI_COMM_NULL 00106 cplComm = MPI_COMM_NULL 00107 atmCouComm = MPI_COMM_NULL 00108 ocnCouComm = MPI_COMM_NULL 00109 call mpi_comm_dup(global_comm, atmComm, ierr) 00110 call mpi_comm_dup(global_comm, ocnComm, ierr) 00111 call mpi_comm_dup(global_comm, cplComm, ierr) 00112 call mpi_comm_dup(global_comm, atmCouComm, ierr) 00113 call mpi_comm_dup(global_comm, ocnCouComm, ierr) 00114 00115 ! all groups of interest are easy breezy 00116 call MPI_Comm_group( atmComm, atmGroup, ierr ) 00117 call MPI_Comm_group( ocnComm, ocnGroup, ierr ) 00118 call MPI_Comm_group( cplComm, cplGroup, ierr ) 00119 00120 readopts ='PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION;PARALLEL_RESOLVE_SHARED_ENTS'//C_NULL_CHAR 00121 nghlay = 0 ! no ghost layers 00122 #ifdef MOAB_HAVE_ZOLTAN 00123 partScheme = 2 ! RCB with zoltan 00124 #else 00125 partScheme = 0 ! Trivial partitioner 00126 #endif 00127 00128 if (my_id .eq. 0) then 00129 print *, ' number of tasks: ', num_procs 00130 print *, ' Atm file: ', atmFileName 00131 print *, ' Ocn file: ', ocnFileName 00132 print *, ' baseline file: ', baselineFileName 00133 print *, ' using partitioner: ', partScheme 00134 end if 00135 00136 ierr = iMOAB_Initialize() 00137 appname = 'ATM'//C_NULL_CHAR 00138 ierr = iMOAB_RegisterApplication(appname, atmComm, cmpatm, cmpatmPid) 00139 appname = 'ATMX'//C_NULL_CHAR 00140 ierr = iMOAB_RegisterApplication(appname, cplComm, cplatm, cplatmPid) 00141 appname = 'OCN'//C_NULL_CHAR 00142 ierr = iMOAB_RegisterApplication(appname, ocnComm, cmpocn, cmpocnPid) 00143 appname = 'OCNX'//C_NULL_CHAR 00144 ierr = iMOAB_RegisterApplication(appname, cplComm, cplocn, cplocnPid) 00145 00146 appname = 'ATMOCN'//C_NULL_CHAR 00147 ierr = iMOAB_RegisterApplication(appname, cplComm, atmocnid, cplAtmOcnPID) 00148 00149 ! read atm and migrate 00150 if (atmComm .NE. MPI_COMM_NULL) then 00151 ierr = iMOAB_LoadMesh(cmpatmPid, atmFileName, readopts, nghlay) 00152 call errorout(ierr, 'fail to load atm') 00153 ierr = iMOAB_SendMesh(cmpatmPid, atmCouComm, cplGroup, cplatm, partScheme) 00154 call errorout(ierr, 'fail to send atm') 00155 end if 00156 if (cplComm .NE. MPI_COMM_NULL) then 00157 ierr = iMOAB_ReceiveMesh(cplatmPid, atmCouComm, atmGroup, cmpatm) ! 00158 call errorout(ierr, 'fail to receive atm') 00159 end if 00160 00161 ! we can now free the sender buffers 00162 if (atmComm .NE. MPI_COMM_NULL) then 00163 context_id = cplatm 00164 ierr = iMOAB_FreeSenderBuffers(cmpatmPid, context_id) 00165 call errorout(ierr, 'fail to free atm buffers') 00166 end if 00167 00168 ! read ocn and migrate 00169 if (ocnComm .NE. MPI_COMM_NULL) then 00170 ierr = iMOAB_LoadMesh(cmpocnPid, ocnFileName, readopts, nghlay) 00171 call errorout(ierr, 'fail to load ocn') 00172 ierr = iMOAB_SendMesh(cmpocnPid, ocnCouComm, cplGroup, cplocn, partScheme) 00173 call errorout(ierr, 'fail to send ocn') 00174 end if 00175 if (cplComm .NE. MPI_COMM_NULL) then 00176 ierr = iMOAB_ReceiveMesh(cplocnPid, ocnCouComm, ocnGroup, cmpocn) ! 00177 call errorout(ierr, 'fail to receive ocn') 00178 end if 00179 00180 ! we can now free the sender buffers 00181 if (ocnComm .NE. MPI_COMM_NULL) then 00182 context_id = cplocn 00183 ierr = iMOAB_FreeSenderBuffers(cmpocnPid, context_id) 00184 call errorout(ierr, 'fail to free ocn buffers') 00185 end if 00186 00187 if (cplComm .NE. MPI_COMM_NULL) then 00188 ierr = iMOAB_ComputeMeshIntersectionOnSphere(cplAtmPID, cplOcnPID, cplAtmOcnPID) 00189 ! coverage mesh was computed here, for cplAtmPID, atm on coupler pes 00190 ! basically, atm was redistributed according to target (ocean) partition, to "cover" the 00191 !ocean partitions check if intx valid, write some h5m intx file 00192 call errorout(ierr, 'cannot compute intersection') 00193 end if 00194 00195 if (atmCouComm .NE. MPI_COMM_NULL) then 00196 ! the new graph will be for sending data from atm comp to coverage mesh. 00197 ! it involves initial atm app; cmpAtmPID; also migrate atm mesh on coupler pes, cplAtmPID 00198 ! results are in cplAtmOcnPID, intx mesh; remapper also has some info about coverage mesh 00199 ! after this, the sending of tags from atm pes to coupler pes will use the new par comm 00200 ! graph, that has more precise info about what to send for ocean cover ; every time, we 00201 ! will use the element global id, which should uniquely identify the element 00202 ierr = iMOAB_CoverageGraph(atmCouComm, cmpAtmPID, cplAtmPID, cplAtmOcnPID, cmpatm, cplatm, cplocn) ! it happens over joint communicator 00203 call errorout(ierr, 'cannot recompute direct coverage graph for ocean') 00204 end if 00205 00206 weights_identifier1 = 'scalar'//C_NULL_CHAR 00207 disc_methods1 = 'cgll'//C_NULL_CHAR 00208 disc_methods2 = 'fv'//C_NULL_CHAR 00209 disc_orders1 = 4 00210 disc_orders2 = 1 00211 dof_tag_names1 = 'GLOBAL_DOFS'//C_NULL_CHAR 00212 dof_tag_names2 = 'GLOBAL_ID'//C_NULL_CHAR 00213 ! fMonotoneTypeID = 0, fVolumetric = 0, fValidate = 1, fNoConserve = 0, fNoBubble = 1 00214 fNoBubble = 1 00215 fMonotoneTypeID = 0 00216 fVolumetric = 0 00217 fNoConserve = 0 00218 fValidate = 1 00219 fInverseDistanceMap = 0 00220 00221 if (cplComm .NE. MPI_COMM_NULL) then 00222 00223 ierr = iMOAB_ComputeScalarProjectionWeights( & 00224 cplAtmOcnPID, weights_identifier1, disc_methods1, disc_orders1, & 00225 disc_methods2, disc_orders2, fNoBubble, fMonotoneTypeID, fVolumetric, fInverseDistanceMap, fNoConserve, & 00226 fValidate, dof_tag_names1, dof_tag_names2) 00227 call errorout(ierr, 'cannot compute scalar projection weights') 00228 00229 #ifdef MOAB_HAVE_NETCDF 00230 atmocn_map_file_name = 'atm_ocn_map_f.nc'//C_NULL_CHAR 00231 ierr = iMOAB_WriteMappingWeightsToFile( cplAtmOcnPID, weights_identifier1, atmocn_map_file_name) 00232 call errorout(ierr, 'failed to write map file to disk') 00233 intx_from_file_identifier = 'map-from-file'//C_NULL_CHAR 00234 dummyCpl = -1 00235 dummyRC = -1 00236 dummyType = 0 00237 ierr = iMOAB_LoadMappingWeightsFromFile( cplAtmOcnPID, dummyCpl, dummyRC, dummyType, & 00238 intx_from_file_identifier, atmocn_map_file_name) 00239 call errorout(ierr, 'failed to load map file from disk') 00240 #endif 00241 end if 00242 00243 ! start copy 00244 tagTypes(1) = 1 ! somehow, DENSE_DOUBLE give 0, while it should be 1; maybe moab::DENSE_DOUBLE ? 00245 tagTypes(2) = 1 ! ! DENSE_DOUBLE 00246 atmCompNDoFs = disc_orders1*disc_orders1 00247 ocnCompNDoFs = 1 ! /*FV*/ 00248 00249 bottomFields = 'a2oTbot:a2oUbot:a2oVbot'//C_NULL_CHAR 00250 bottomProjectedFields = 'a2oTbot_proj:a2oUbot_proj:a2oVbot_proj'//C_NULL_CHAR 00251 00252 if (cplComm .NE. MPI_COMM_NULL) then 00253 ierr = iMOAB_DefineTagStorage(cplAtmPID, bottomFields, tagTypes(1), atmCompNDoFs, tagIndex(1)) 00254 call errorout(ierr, 'failed to define the field tags a2oTbot:a2oUbot:a2oVbot ') 00255 ierr = iMOAB_DefineTagStorage(cplOcnPID, bottomProjectedFields, tagTypes(2), ocnCompNDoFs, tagIndex(2)) 00256 call errorout(ierr, 'failed to define the field tags a2oTbot_proj:a2oUbot_proj:a2oVbot_proj') 00257 end if 00258 00259 ! make the tag 0, to check we are actually sending needed data 00260 if (cplAtmPID .ge. 0) then 00261 00262 ! Each process in the communicator will have access to a local mesh instance, which 00263 ! will contain the original cells in the local partition and ghost entities. Number of 00264 ! vertices, primary cells, visible blocks, number of sidesets and nodesets boundary 00265 ! conditions will be returned in numProcesses 3 arrays, for local, ghost and total 00266 ! numbers. 00267 00268 ierr = iMOAB_GetMeshInfo(cplAtmPID, nverts, nelem, nblocks, nsbc, ndbc) 00269 call errorout(ierr, 'failed to get num primary elems') 00270 storLeng = nelem(3)*atmCompNDoFs*3 ! 3 tags 00271 allocate (vals(storLeng)) 00272 eetype = 1 ! double type 00273 00274 do i = 1, storLeng 00275 vals(:) = 0. 00276 end do 00277 00278 ! set the tag values to 0.0 00279 ierr = iMOAB_SetDoubleTagStorage(cplAtmPID, bottomFields, storLeng, eetype, vals) 00280 call errorout(ierr, 'cannot make tag nul') 00281 00282 end if 00283 00284 ! Define the field variables to project 00285 concat_fieldname = 'a2oTbot:a2oUbot:a2oVbot'//C_NULL_CHAR 00286 concat_fieldnameT = 'a2oTbot_proj:a2oUbot_proj:a2oVbot_proj'//C_NULL_CHAR 00287 00288 if (atmComm .NE. MPI_COMM_NULL) then 00289 00290 ! As always, use nonblocking sends 00291 ! this is for projection to ocean: 00292 ierr = iMOAB_SendElementTag(cmpAtmPID, concat_fieldname, atmCouComm, cplocn) 00293 call errorout(ierr, 'cannot send tag values') 00294 00295 end if 00296 00297 if (cplComm .NE. MPI_COMM_NULL) then 00298 !// receive on atm on coupler pes, that was redistributed according to coverage 00299 ierr = iMOAB_ReceiveElementTag(cplAtmPID, concat_fieldname, atmCouComm, cplocn) 00300 call errorout(ierr, 'cannot receive tag values') 00301 end if 00302 00303 ! we can now free the sender buffers 00304 if (atmComm .NE. MPI_COMM_NULL) then 00305 00306 ierr = iMOAB_FreeSenderBuffers(cmpAtmPID, cplocn) !context is for ocean 00307 call errorout(ierr, 'cannot free buffers used to resend atm tag towards the coverage mesh') 00308 00309 end if 00310 if (cplComm .ne. MPI_COMM_NULL) then 00311 00312 outputFileOcn = "AtmOnCplF.h5m"//C_NULL_CHAR 00313 fileWriteOptions = 'PARALLEL=WRITE_PART'//C_NULL_CHAR 00314 ierr = iMOAB_WriteMesh(cplAtmPID, outputFileOcn, fileWriteOptions) 00315 call errorout(ierr, 'could not write AtmOnCpl.h5m to disk') 00316 00317 end if 00318 if (cplComm .ne. MPI_COMM_NULL) then 00319 00320 ! We have the remapping weights now. Let us apply the weights onto the tag we defined 00321 ! on the source mesh and get the projection on the target mesh 00322 ierr = iMOAB_ApplyScalarProjectionWeights(cplAtmOcnPID, weights_identifier1, concat_fieldname, & 00323 concat_fieldnameT) 00324 call errorout(ierr, 'failed to compute projection weight application') 00325 00326 outputFileOcn = "OcnOnCplF.h5m"//C_NULL_CHAR 00327 fileWriteOptions = 'PARALLEL=WRITE_PART'//C_NULL_CHAR 00328 ierr = iMOAB_WriteMesh(cplOcnPID, outputFileOcn, fileWriteOptions) 00329 call errorout(ierr, 'could not write OcnOnCpl.h5m to disk') 00330 00331 end if 00332 ! send the projected tag back to ocean pes, with send/receive tag 00333 ! first makje sure the tags are defined, otherwise they cannot be received 00334 if (ocnComm .ne. MPI_COMM_NULL) then 00335 00336 ierr = iMOAB_DefineTagStorage(cmpOcnPID, bottomProjectedFields, tagTypes(2), ocnCompNDoFs, tagIndexIn2) 00337 call errorout(ierr, 'failed to define the field tag for receiving back the tag a2oTbot_proj, on ocn pes') 00338 00339 end if 00340 00341 ! send the tag to ocean pes, from ocean mesh on coupler pes 00342 ! from couComm, using common joint comm ocn_coupler 00343 ! as always, use nonblocking sends 00344 ! original graph (context is -1_ 00345 if (cplComm .ne. MPI_COMM_NULL) then 00346 context_id = cmpocn 00347 ierr = iMOAB_SendElementTag(cplOcnPID, concat_fieldnameT, ocnCouComm, context_id) 00348 call errorout(ierr, 'cannot send tag values back to ocean pes') 00349 end if 00350 00351 if (ocnComm .ne. MPI_COMM_NULL) then 00352 context_id = cplocn 00353 ierr = iMOAB_ReceiveElementTag(cmpOcnPID, concat_fieldnameT, ocnCouComm, context_id) 00354 call errorout(ierr, 'cannot receive tag values from ocean mesh on coupler pes') 00355 end if 00356 00357 if (cplComm .ne. MPI_COMM_NULL) then 00358 context_id = cmpocn 00359 ierr = iMOAB_FreeSenderBuffers(cplOcnPID, context_id) 00360 call errorout(ierr, 'cannot free sender buffers on coupler') 00361 end if 00362 00363 if (ocnComm .ne. MPI_COMM_NULL) then 00364 00365 outputFileOcn = "OcnWithProjF.h5m"//C_NULL_CHAR 00366 fileWriteOptions = 'PARALLEL=WRITE_PART'//C_NULL_CHAR 00367 if (my_id .eq. 0) then 00368 print *, ' Writing ocean mesh file with projected solution to disk: ', outputFileOcn 00369 end if 00370 ierr = iMOAB_WriteMesh(cmpOcnPID, outputFileOcn, fileWriteOptions) 00371 call errorout(ierr, 'could not write OcnWithProjF.h5m to disk') 00372 00373 end if 00374 00375 ! free up resources 00376 ierr = iMOAB_DeregisterApplication(cplAtmOcnPID) 00377 call errorout(ierr, 'could not de-register OCN component') 00378 00379 ierr = iMOAB_DeregisterApplication(cplOcnPID) 00380 call errorout(ierr, 'could not de-register OCN component') 00381 ierr = iMOAB_DeregisterApplication(cmpOcnPID) 00382 call errorout(ierr, 'could not de-register OCN component') 00383 ierr = iMOAB_DeregisterApplication(cplAtmPID) 00384 call errorout(ierr, 'could not de-register OCN component') 00385 ierr = iMOAB_DeregisterApplication(cmpAtmPID) 00386 call errorout(ierr, 'could not de-register OCN component') 00387 00388 ! Free all MPI datastructures 00389 call MPI_Comm_free(atmComm, ierr) 00390 call MPI_Group_free(atmGroup, ierr) 00391 call MPI_Comm_free(ocnComm, ierr) 00392 call MPI_Group_free(ocnGroup, ierr) 00393 call MPI_Comm_free(cplComm, ierr) 00394 call MPI_Group_free(cplGroup, ierr) 00395 00396 call MPI_Comm_free(atmCouComm, ierr) 00397 call MPI_Comm_free(ocnCouComm, ierr) 00398 call MPI_Comm_free(global_comm, ierr) 00399 call MPI_Group_free(jgroup, ierr) 00400 call MPI_Finalize(ierr) 00401 00402 end program imoab_coupler_fortran
