MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 00002 SUBROUTINE errorout(ierr, message) 00003 integer ierr 00004 character*(*) message 00005 if (ierr.ne.0) then 00006 print *, message 00007 call exit (1) 00008 end if 00009 return 00010 end 00011 00012 program fdriver 00013 00014 use iso_c_binding 00015 use iMOAB 00016 00017 #include "moab/MOABConfig.h" 00018 #ifdef MOAB_HAVE_MPI 00019 include 'mpif.h' 00020 #endif 00021 00022 #ifndef MOAB_MESH_DIR 00023 #error Specify MOAB_MESH_DIR path 00024 #endif 00025 00026 integer ierr, num_procs, my_id 00027 integer pid 00028 integer compid 00029 character :: appname*32 00030 character :: filename*1024 00031 character :: fname*1024 00032 character :: readopts*1024 00033 integer ngv, nge, ndim, nparts 00034 integer nghlay 00035 integer nverts(3), nelem(3), nblocks(3), nsbc(3), ndbc(3) 00036 ! large enough work arrays 00037 integer iwork(100000) 00038 double precision dwork(100000) 00039 ! indices in work arrays for vertex ids, ranks, coordinates 00040 integer vID, vRA, vCO 00041 ! 00042 ! indices for free memory (index in integer or double work arrays) 00043 integer ifree, dfree 00044 ! size of coordinates array 00045 integer nCO 00046 integer bID 00047 ! for some tags in the file 00048 character :: tagname1*128, tagname2*128 00049 integer tagtype(2), enttype(2), num_co 00050 integer tagindex(2) 00051 integer ntsync 00052 00053 integer eRA, beID, eID 00054 ! vertices per element, number of elements in block 00055 integer vpere, nebl, blockID 00056 ! iWORK(eCO) start for connectivity 00057 integer sizeconn, eCO 00058 ! IWORK(egID) , IWORK(elID) starts for global el ID, local elem ID 00059 integer egID, elID, eOWN 00060 integer iTAG, dTAG 00061 00062 ! indices for surface BC element, reference surf BC, value 00063 integer isBC, irBC, ivBC 00064 00065 character outfile*1024, wopts*1024 00066 my_id = 0 00067 fname = 'unittest/io/p8ex1.h5m'//C_NULL_CHAR 00068 00069 #ifdef MOAB_HAVE_MPI 00070 call MPI_INIT ( ierr ) 00071 call errorout(ierr, 'fail to initialize MPI') 00072 00073 ! find out MY process ID, and how many processes were started. 00074 00075 call MPI_COMM_RANK (MPI_COMM_WORLD, my_id, ierr) 00076 call errorout(ierr, 'fail to get MPI rank') 00077 00078 call MPI_COMM_SIZE (MPI_COMM_WORLD, num_procs, ierr) 00079 call errorout(ierr, 'fail to get MPI size') 00080 00081 if (my_id .eq. 0) then 00082 print *, " I'm process ", my_id, " out of ", num_procs, " processes." 00083 end if 00084 #endif 00085 00086 ierr = iMOAB_Initialize() 00087 call errorout(ierr, 'fail to initialize iMOAB') 00088 00089 appname = 'PROTEUS'//C_NULL_CHAR 00090 ! give a unique external id; here we just use 8? 00091 compid = 8 00092 ! number of ghost layers needed by application 00093 nghlay = 0 00094 00095 00096 #ifdef MOAB_HAVE_MPI 00097 ierr = iMOAB_RegisterApplication(appname, MPI_COMM_WORLD, compid, pid) 00098 #else 00099 ierr = iMOAB_RegisterApplication(appname, compid, pid) 00100 #endif 00101 call errorout(ierr, 'fail to register application') 00102 00103 filename = MOAB_MESH_DIR//fname 00104 ierr = iMOAB_ReadHeaderInfo ( filename, ngv, nge, ndim, nparts) 00105 call errorout(ierr, 'fail to read header info') 00106 00107 if (0.eq.my_id) then 00108 print *, filename, ' has ', nparts, ' parts in partition', ngv, ' vertices ', nge, ' elements of dimension ', ndim 00109 endif 00110 #ifdef MOAB_HAVE_MPI 00111 nghlay = 1 00112 readopts='PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION;'// & 00113 'PARALLEL_RESOLVE_SHARED_ENTS'//C_NULL_CHAR 00114 #else 00115 readopts=C_NULL_CHAR 00116 #endif 00117 00118 ! now let us load the mesh in parallel 00119 ierr = iMOAB_LoadMesh(pid, filename, readopts, nghlay) 00120 call errorout(ierr, 'fail to read file in parallel') 00121 00122 ! number of vertices/elements/blocks/sidesets in the mesh 00123 ierr = iMOAB_GetMeshInfo(pid, nverts, nelem, nblocks, nsbc, ndbc) 00124 call errorout(ierr, 'fail to get mesh info') 00125 00126 vID = 1 00127 ierr = iMOAB_GetVertexID(pid, nverts(3), IWORK(vID) ) 00128 call errorout(ierr, 'failed to get vertex id info') 00129 00130 vRA = vID + nverts(3) 00131 ierr = iMOAB_GetVertexOwnership(pid, nverts(3), IWORK(vRA) ) 00132 call errorout(ierr, 'failed to get vertex owner ranks') 00133 00134 ifree = vRA + nverts(3) 00135 00136 ! double * coords = (double*) malloc(3*nverts[2]*sizeof(double)); 00137 vCO = 1 00138 nCO = 3 * nverts(3) 00139 00140 ierr = iMOAB_GetVisibleVerticesCoordinates(pid, nCO, DWORK(vCO)) 00141 print *, 'nCO = ', nCO 00142 print *, 'ierr = ', ierr 00143 call errorout(ierr, 'failed to get coordinates') 00144 dfree = vCO + 3 * nverts(3) 00145 00146 bID = ifree 00147 ierr = iMOAB_GetBlockID(pid, nblocks(3), IWORK(bID)) 00148 call errorout(ierr, 'failed to get block info') 00149 ifree = ifree + nblocks(3) 00150 00151 ! the 2 tags used in this example exist in the file, already 00152 ! first tag, INTFIELD is on vertices, integer 00153 ! second tag DFIELD is on elements, double 00154 tagtype(1)=0 !dense, int 00155 tagtype(2)=1 !dense, double 00156 enttype(1)=0 ! on verts 00157 enttype(2)=1 ! on elem 00158 num_co = 1 00159 tagname1 ='INTFIELD'//C_NULL_CHAR 00160 ierr = iMOAB_DefineTagStorage(pid, tagname1, tagtype(1), num_co, tagindex(1) ) 00161 call errorout(ierr, 'failed to get tag INTFIELD') 00162 00163 tagname2 ='DFIELD'//C_NULL_CHAR 00164 ierr = iMOAB_DefineTagStorage(pid, tagname2, tagtype(2), num_co, tagindex(2) ) 00165 call errorout(ierr, 'failed to get tag DFIELD') 00166 00167 ! synchronize one of the tags only, just to see what happens 00168 ! put in the sync array just first tag index (INTFIELD) 00169 ntsync =2 00170 00171 ierr = iMOAB_SynchronizeTags(pid, ntsync, tagIndex, tagType ) 00172 call errorout(ierr, 'failed to sync tag INTFIELD') 00173 00174 ! start printing some information, retrieved from each task 00175 do irk=0, num_procs-1 00176 if (irk .eq. my_id) then 00177 00178 ! printf some of the block info */ 00179 print *, 'on rank ', my_id, ' there are ' 00180 print *, nverts(3), ' visible vertices of which ',nverts(1), ' local ', nverts(2), ' ghost' 00181 print *, nblocks(3), ' visible blocks' 00182 print *, nsbc(3), ' visible Neumann BCs' 00183 print *, ndbc(3), ' visible dirichlet BCs' 00184 00185 print *, 'on rank ', my_id, ' vertex info:' 00186 do i=1,nverts(3) 00187 write(*, 100) i, IWORK(vRA+i-1), IWORK( vID+i-1), DWORK(vCO+3*i-3), DWORK(vCO+3*i-2), DWORK(vCO+3*i-1) 00188 100 FORMAT(' vertex local id ', I3, ' rank ID', I3, ' global ID:', I3, ' coords:', 3F11.3) 00189 enddo 00190 00191 eID = ifree 00192 beID = eID + nelem(3) 00193 eRA = beID + nelem(3) 00194 ierr = iMOAB_GetVisibleElementsInfo(pid, nelem(3),IWORK(eID), IWORK(eRA), IWORK(beID) ) 00195 call errorout(ierr, 'failed to get all elem info') 00196 ifree = eRA + nelem(3) 00197 do i=1, nelem(3) 00198 write(*, 101) IWORK(eID+i-1), IWORK(eRA+i-1), IWORK(beID+i-1) 00199 101 FORMAT( ' global ID ', I5, ' rank: ', I3, ' block ID: ', I4) 00200 enddo 00201 00202 do i=1,nblocks(3) 00203 00204 print *,' block index:', i, ' block ID ', IWORK(bID+i-1) 00205 blockID = IWORK(bID+i-1) 00206 ierr = iMOAB_GetBlockInfo(pid, blockID , vpere, nebl) 00207 call errorout(ierr, 'failed to elem block info') 00208 print *, ' has' , nebl, ' elements with ', vpere, 'verts' 00209 00210 sizeconn = nebl * vpere 00211 eCO = ifree 00212 ierr = iMOAB_GetBlockElementConnectivities(pid, blockID, sizeconn, IWORK(eCO) ) 00213 print *, ierr 00214 call errorout(ierr, 'failed to get block elem connectivity') 00215 00216 ifree = ifree + sizeconn 00217 eOWN = ifree 00218 ierr = iMOAB_GetElementOwnership(pid, blockID, nebl, IWORK(eOWN)) 00219 call errorout(ierr, 'failed to get block elem ownership') 00220 ifree = ifree+nebl 00221 00222 egID = ifree 00223 elID = ifree + nebl 00224 ierr = iMOAB_GetElementID(pid, blockID, nebl, IWORK(egID), IWORK(elID) ) 00225 call errorout(ierr, 'failed to get block elem IDs') 00226 ifree = elID + nebl 00227 00228 do j=1, nebl 00229 write (*, 102) j, IWORK(eOWN+j-1),IWORK(egID+j-1), IWORK(elID+j-1), (IWORK(eCO-1+(j-1)*vpere+k), k=1,vpere) 00230 102 FORMAT(' elem ', I3, ' owned by', I3, ' gid:', I3, ' lid:', I3, ' : ', 10I5) 00231 enddo 00232 enddo 00233 00234 ! query int tag values on vertices 00235 iTAG= ifree 00236 00237 ierr = iMOAB_GetIntTagStorage(pid, tagname1, nverts(3), enttype(1), IWORK(iTAG) ) 00238 call errorout(ierr, 'failed to get INTFIELD tag') 00239 ifree = iTAG + nverts(3) 00240 print * , 'INTFIELD tag values' 00241 write(*, 103) (IWORK(iTAG+k-1), k=1,nverts(3) ) 00242 103 FORMAT (10I8) 00243 00244 dTAG = dfree 00245 ! query double tag values on elements 00246 00247 ierr = iMOAB_GetDoubleTagStorage(pid, tagname2, nelem(3), entType(2), DWORK(dTAG) ) 00248 call errorout(ierr, 'failed to get DFIELD tag') 00249 dfree = dTAG + nelem(3) 00250 print *, 'DFIELD tag values: (not exchanged) ' 00251 write (*, 104) (DWORK(dTAG+k-1), k=1,nelem(3) ) 00252 104 FORMAT ( 10F7.2 ) 00253 00254 ! query surface BCs 00255 isBC = ifree 00256 irBC = isBC + nsbc(3) 00257 ivBC = irBC + nsbc(3) 00258 00259 ierr = iMOAB_GetPointerToSurfaceBC(pid, nsbc(3), IWORK(isBC),IWORK(irBC), IWORK(ivBC)) 00260 call errorout(ierr, 'failed to get surf boundary conditions') 00261 ifree = ivBC + nsbc(3) 00262 print * , 'Surface boundary conditions ' 00263 write (*, 105) (IWORK(isBC+k-1),IWORK(irBC+k-1), IWORK(ivBC+k-1), k=1, nsbc(3)) 00264 105 FORMAT (' elem localID: ', I3, ' side:', I1, ' val:', I4) 00265 00266 ! query vertex BCs 00267 iveBC = ifree 00268 ivaBC = iveBC + ndbc(3) 00269 00270 ierr = iMOAB_GetPointerToVertexBC(pid, ndbc(3), IWORK(iveBC),IWORK(ivaBC)) 00271 call errorout(ierr, 'failed to get vertex boundary conditions') 00272 ifree = ivaBC + ndbc(3) 00273 00274 print *, ' Vertex boundary conditions:' 00275 write (*, 106) (IWORK(iveBC+k-1),IWORK(ivaBC+k-1), k=1, ndbc(3)) 00276 106 FORMAT (' vertex: ', I3, ' BC:', I6 ) 00277 00278 endif 00279 00280 #ifdef MOAB_HAVE_MPI 00281 call MPI_Barrier(MPI_COMM_WORLD, ierr) 00282 #endif 00283 call errorout(ierr, 'fail at barrier') 00284 enddo 00285 00286 outfile = 'fnew2.h5m'//C_NULL_CHAR 00287 #ifdef MOAB_HAVE_MPI 00288 wopts = 'PARALLEL=WRITE_PART'//C_NULL_CHAR 00289 #else 00290 wopts=C_NULL_CHAR 00291 #endif 00292 00293 ! write out the mesh file to disk 00294 ierr = iMOAB_WriteMesh(pid, outfile, wopts) 00295 call errorout(ierr, 'fail to write the mesh file') 00296 00297 ! all done. de-register and finalize 00298 ierr = iMOAB_DeregisterApplication(pid) 00299 call errorout(ierr, 'fail to deregister application') 00300 00301 ierr = iMOAB_Finalize() 00302 call errorout(ierr, 'fail to finalize iMOAB') 00303 00304 #ifdef MOAB_HAVE_MPI 00305 call MPI_FINALIZE ( ierr ) 00306 #endif 00307 call errorout(ierr, 'fail to finalize MPI') 00308 00309 stop 00310 end
