MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /* Test mhdf library on top of Parallel HDF5. 00002 * 00003 * Call mhdf API similar to how WriteHDF5Parallel does, 00004 * but avoid any of our own parallel communiation. 00005 * 00006 * Output will be composed of: 00007 * a 1-D array of hexes, one per processor, where the first 00008 * process writes all the nodes for its hex and every other 00009 * process writes the right 4 nodes of its hex. 00010 * a set containing all of the hexes 00011 * a set containing all of the nodes 00012 * a set per processor containing all of the entities written by that proc 00013 * a tag specifying the process ID that wrote each entity. 00014 */ 00015 00016 #include "mhdf.h" 00017 00018 #include <time.h> 00019 #include <stdlib.h> 00020 #include <stdio.h> 00021 #include <assert.h> 00022 00023 #include <H5Ppublic.h> 00024 #include <H5Tpublic.h> 00025 #include <H5Epublic.h> 00026 #include <H5FDmpi.h> 00027 #include <H5FDmpio.h> 00028 00029 #ifdef H5_HAVE_PARALLEL 00030 00031 const char filename[] = "mhdf_ll.h5m"; 00032 const char proc_tag_name[] = "proc_id"; 00033 const char elem_handle[] = "Hex"; 00034 00035 int RANK; 00036 int NUM_PROC; 00037 00038 #define CHECK( A ) check( &( A ), __LINE__ ) 00039 void check( mhdf_Status* status, int line ) 00040 { 00041 if( mhdf_isError( status ) ) 00042 { 00043 fprintf( stderr, "%d: ERROR at line %d: \"%s\"\n", RANK, line, mhdf_message( status ) ); 00044 abort(); 00045 } 00046 } 00047 00048 typedef int handle_id_t; 00049 #define id_type H5T_NATIVE_INT 00050 00051 /* create file layout in serial */ 00052 void create_file() 00053 { 00054 const char* elem_types[1] = { elem_handle }; 00055 const int num_elem_types = sizeof( elem_types ) / sizeof( elem_types[0] ); 00056 const int num_nodes = 4 + 4 * NUM_PROC; 00057 const int num_hexes = NUM_PROC; 00058 const int num_sets = 2 + NUM_PROC; 00059 const int set_data_size = num_hexes + num_nodes + num_hexes + num_nodes; 00060 const int num_tag_vals = num_hexes + num_nodes + num_sets - 2; 00061 const char* history[] = { __FILE__, NULL }; 00062 const int history_size = sizeof( history ) / sizeof( history[0] ); 00063 int default_tag_val = NUM_PROC; 00064 hid_t data, tagdata[2]; 00065 long junk; 00066 00067 mhdf_Status status; 00068 mhdf_FileHandle file; 00069 00070 time_t t; 00071 t = time( NULL ); 00072 history[1] = ctime( &t ); 00073 00074 file = mhdf_createFile( filename, 1, elem_types, num_elem_types, id_type, &status ); 00075 CHECK( status ); 00076 00077 mhdf_writeHistory( file, history, history_size, &status ); 00078 CHECK( status ); 00079 00080 data = mhdf_createNodeCoords( file, 3, num_nodes, &junk, &status ); 00081 CHECK( status ); 00082 mhdf_closeData( file, data, &status ); 00083 CHECK( status ); 00084 00085 mhdf_addElement( file, elem_types[0], 0, &status ); 00086 CHECK( status ); 00087 data = mhdf_createConnectivity( file, elem_handle, 8, num_hexes, &junk, &status ); 00088 CHECK( status ); 00089 mhdf_closeData( file, data, &status ); 00090 CHECK( status ); 00091 00092 data = mhdf_createSetMeta( file, num_sets, &junk, &status ); 00093 CHECK( status ); 00094 mhdf_closeData( file, data, &status ); 00095 CHECK( status ); 00096 00097 data = mhdf_createSetData( file, set_data_size, &status ); 00098 CHECK( status ); 00099 mhdf_closeData( file, data, &status ); 00100 CHECK( status ); 00101 00102 mhdf_createTag( file, proc_tag_name, mhdf_INTEGER, 1, mhdf_DENSE_TYPE, &default_tag_val, &default_tag_val, 0, 0, 00103 &status ); 00104 CHECK( status ); 00105 00106 mhdf_createSparseTagData( file, proc_tag_name, num_tag_vals, tagdata, &status ); 00107 CHECK( status ); 00108 mhdf_closeData( file, tagdata[0], &status ); 00109 CHECK( status ); 00110 mhdf_closeData( file, tagdata[1], &status ); 00111 CHECK( status ); 00112 00113 mhdf_closeFile( file, &status ); 00114 CHECK( status ); 00115 } 00116 00117 void write_file_data() 00118 { 00119 const int total_num_nodes = 4 + 4 * NUM_PROC; 00120 const int total_num_hexes = NUM_PROC; 00121 long first_node, first_elem, first_set, count, ntag; 00122 unsigned long ucount; 00123 mhdf_index_t set_desc[4] = { 0, -1, -1, 0 }; 00124 hid_t handle, handles[2]; 00125 mhdf_Status status; 00126 mhdf_FileHandle file; 00127 int num_node, offset, dim; 00128 double coords[3 * 8] = { 0.0, 0.0, 0.0, 0.0, 1.0, 0.0, 0.0, 1.0, 1.0, 0.0, 0.0, 1.0, 00129 0.0, 0.0, 0.0, 0.0, 1.0, 0.0, 0.0, 1.0, 1.0, 0.0, 0.0, 1.0 }; 00130 handle_id_t list[10]; 00131 int i, tagdata[10]; 00132 for( i = 0; i < 10; i++ ) 00133 tagdata[i] = RANK; 00134 00135 /* open file */ 00136 handle = H5Pcreate( H5P_FILE_ACCESS ); 00137 H5Pset_fapl_mpio( handle, MPI_COMM_WORLD, MPI_INFO_NULL ); 00138 file = mhdf_openFileWithOpt( filename, 1, &ucount, id_type, handle, &status ); 00139 CHECK( status ); 00140 H5Pclose( handle ); 00141 00142 /* write node coordinates */ 00143 if( 0 == RANK ) 00144 { 00145 num_node = 8; 00146 offset = 0; 00147 coords[12] = coords[15] = coords[18] = coords[21] = 1.0; 00148 } 00149 else 00150 { 00151 num_node = 4; 00152 offset = 4 + 4 * RANK; 00153 coords[0] = coords[3] = coords[6] = coords[9] = 1.0 + RANK; 00154 } 00155 handle = mhdf_openNodeCoords( file, &count, &dim, &first_node, &status ); 00156 CHECK( status ); 00157 assert( count == total_num_nodes ); 00158 assert( dim == 3 ); 00159 mhdf_writeNodeCoords( handle, offset, num_node, coords, &status ); 00160 CHECK( status ); 00161 mhdf_closeData( file, handle, &status ); 00162 CHECK( status ); 00163 00164 /* write hex connectivity */ 00165 for( i = 0; i < 8; ++i ) 00166 list[i] = 4 * RANK + i + first_node; 00167 handle = mhdf_openConnectivity( file, elem_handle, &dim, &count, &first_elem, &status ); 00168 CHECK( status ); 00169 assert( count == total_num_hexes ); 00170 assert( 8 == dim ); 00171 mhdf_writeConnectivity( handle, RANK, 1, id_type, list, &status ); 00172 CHECK( status ); 00173 mhdf_closeData( file, handle, &status ); 00174 CHECK( status ); 00175 00176 /* write set descriptions */ 00177 handle = mhdf_openSetMeta( file, &count, &first_set, &status ); 00178 CHECK( status ); 00179 assert( count == 2 + NUM_PROC ); 00180 00181 /* write set descriptions for per-proc sets */ 00182 set_desc[0] = total_num_nodes + total_num_hexes + 9 + 5 * RANK - 1; 00183 mhdf_writeSetMeta( handle, 2 + RANK, 1, MHDF_INDEX_TYPE, set_desc, &status ); 00184 CHECK( status ); 00185 00186 /* write set descriptions for multi-proc sets */ 00187 if( 0 == RANK ) 00188 { 00189 set_desc[0] = total_num_nodes - 1; 00190 mhdf_writeSetMeta( handle, 0, 1, MHDF_INDEX_TYPE, set_desc, &status ); 00191 CHECK( status ); 00192 set_desc[0] += total_num_hexes; 00193 mhdf_writeSetMeta( handle, 1, 1, MHDF_INDEX_TYPE, set_desc, &status ); 00194 CHECK( status ); 00195 } 00196 00197 mhdf_closeData( file, handle, &status ); 00198 CHECK( status ); 00199 00200 /* write set contents */ 00201 00202 handle = mhdf_openSetData( file, &count, &status ); 00203 CHECK( status ); 00204 assert( 2 * total_num_nodes + 2 * total_num_hexes == count ); 00205 00206 /* write per-proc sets */ 00207 if( 0 == RANK ) 00208 { 00209 count = 9; 00210 offset = total_num_nodes + total_num_hexes; 00211 for( i = 0; i < 8; ++i ) 00212 list[i] = first_node + i; 00213 list[8] = first_elem; 00214 } 00215 else 00216 { 00217 count = 5; 00218 offset = total_num_nodes + total_num_hexes + 4 + 5 * RANK; 00219 for( i = 0; i < 4; ++i ) 00220 list[i] = 4 + 4 * RANK + first_node + i; 00221 list[4] = RANK + first_elem; 00222 } 00223 mhdf_writeSetData( handle, offset, count, id_type, list, &status ); 00224 CHECK( status ); 00225 00226 /* write multi-proc sets */ 00227 /* write nodes */ 00228 offset = ( 0 == RANK ) ? 0 : 4 + 4 * RANK; 00229 mhdf_writeSetData( handle, offset, count - 1, id_type, list, &status ); 00230 CHECK( status ); 00231 /* write hex */ 00232 offset = total_num_nodes + RANK; 00233 mhdf_writeSetData( handle, offset, 1, id_type, list + count - 1, &status ); 00234 CHECK( status ); 00235 00236 mhdf_closeData( file, handle, &status ); 00237 CHECK( status ); 00238 00239 /* write tag data */ 00240 offset = ( 0 == RANK ) ? 0 : 4 + 4 * RANK; 00241 offset += 2 * RANK; 00242 list[count++] = first_set + 2 + RANK; 00243 mhdf_openSparseTagData( file, proc_tag_name, &ntag, &ntag, handles, &status ); 00244 CHECK( status ); 00245 assert( ntag == total_num_nodes + total_num_hexes + NUM_PROC ); 00246 mhdf_writeSparseTagEntities( handles[0], offset, count, id_type, list, &status ); 00247 CHECK( status ); 00248 mhdf_writeTagValues( handles[1], offset, count, H5T_NATIVE_INT, tagdata, &status ); 00249 CHECK( status ); 00250 mhdf_closeData( file, handles[0], &status ); 00251 CHECK( status ); 00252 mhdf_closeData( file, handles[1], &status ); 00253 CHECK( status ); 00254 00255 /* done */ 00256 mhdf_closeFile( file, &status ); 00257 CHECK( status ); 00258 } 00259 00260 /* Define a dummy error handler to register with HDF5. 00261 * This function doesn't do anything except pass the 00262 * error on to the default handler that would have been 00263 * called anyway. It's only purpose is to provide a 00264 * spot to set a break point so we can figure out where 00265 * (in our code) that we made an invalid call into HDF5 00266 */ 00267 #if defined( H5E_auto_t_vers ) && H5E_auto_t_vers > 1 00268 herr_t ( *default_handler )( hid_t, void* ); 00269 static herr_t handle_hdf5_error( hid_t stack, void* data ) 00270 #else 00271 herr_t ( *default_handler )( void* ); 00272 static herr_t handle_hdf5_error( void* data ) 00273 #endif 00274 { 00275 herr_t result = 0; 00276 if( default_handler ) 00277 #if defined( H5E_auto_t_vers ) && H5E_auto_t_vers > 1 00278 result = (default_handler)( stack, data ); 00279 #else 00280 result = (default_handler)( data ); 00281 #endif 00282 assert( 0 ); 00283 return result; 00284 } 00285 00286 #endif /* #ifdef H5_HAVE_PARALLEL */ 00287 00288 int main( int argc, char* argv[] ) 00289 { 00290 #ifdef H5_HAVE_PARALLEL 00291 int rval; 00292 void* data; 00293 herr_t err; 00294 00295 #if defined( H5Eget_auto_vers ) && H5Eget_auto_vers > 1 00296 err = H5Eget_auto( H5E_DEFAULT, &default_handler, &data ); 00297 #else 00298 err = H5Eget_auto( &default_handler, &data ); 00299 #endif 00300 if( err >= 0 ) 00301 { 00302 #if defined( H5Eset_auto_vers ) && H5Eset_auto_vers > 1 00303 H5Eset_auto( H5E_DEFAULT, &handle_hdf5_error, data ); 00304 #else 00305 H5Eset_auto( &handle_hdf5_error, data ); 00306 #endif 00307 } 00308 00309 rval = MPI_Init( &argc, &argv ); 00310 if( rval ) return rval; 00311 rval = MPI_Comm_rank( MPI_COMM_WORLD, &RANK ); 00312 if( rval ) return rval; 00313 rval = MPI_Comm_size( MPI_COMM_WORLD, &NUM_PROC ); 00314 if( rval ) return rval; 00315 00316 if( RANK == 0 ) create_file(); 00317 00318 /* Wait for rank 0 to finish creating the file, otherwise rank 1 may find it to be invalid */ 00319 rval = MPI_Barrier( MPI_COMM_WORLD ); 00320 if( rval ) return rval; 00321 00322 write_file_data(); 00323 00324 MPI_Finalize(); 00325 #endif 00326 return 0; 00327 }
