MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 #ifndef MOAB_PARAMETRIZER_HPP 00002 #define MOAB_PARAMETRIZER_HPP 00003 #include "moab/Matrix3.hpp" 00004 #include "moab/CartVect.hpp" 00005 #include "moab/ElemUtil.hpp" 00006 namespace moab 00007 { 00008 00009 namespace element_utility 00010 { 00011 // non-exported functionality 00012 namespace 00013 { 00014 00015 template < typename Moab, typename Entity_handle, typename Points > 00016 void get_moab_points( Moab& moab, Entity_handle eh, Points& points ) 00017 { 00018 const Entity_handle* connectivity_begin; 00019 int num_vertices; 00020 moab.get_connectivity( eh, connectivity_begin, num_vertices ); 00021 // TODO: This is hacky, it works correctly since 00022 // CartVect is only double d[ 3], with a default 00023 // constructor.. get_coords() should be 00024 // flexible enough to allow other types.. 00025 points.resize( num_vertices ); 00026 moab.get_coords( connectivity_begin, num_vertices, &( points[0][0] ) ); 00027 } 00028 00029 } // namespace 00030 00031 template < typename Element_map > 00032 class Element_parametrizer 00033 { 00034 public: 00035 // public types 00036 typedef Element_map Map; 00037 00038 private: 00039 typedef Element_parametrizer< Map > Self; 00040 00041 public: // public functionality 00042 Element_parametrizer() : map() {} 00043 Element_parametrizer( const Self& f ) : map( f.map ) {} 00044 00045 public: 00046 template < typename Moab, typename Entity_handle, typename Point > 00047 std::pair< bool, Point > operator()( Moab& moab, const Entity_handle& eh, const Point& point, const double tol ) 00048 { 00049 typedef std::vector< moab::CartVect > Points; 00050 Points points; 00051 get_moab_points( moab, eh, points ); 00052 return map( moab, eh, points, point, tol ); 00053 } 00054 00055 private: 00056 Element_map map; 00057 }; // class Element_parametrizer 00058 00059 class Parametrizer 00060 { 00061 private: 00062 typedef Parametrizer Self; 00063 typedef moab::EntityHandle Entity_handle; 00064 00065 public: // public functionality 00066 Parametrizer() : hex_map(), tet_map() {} 00067 Parametrizer( const Self& f ) : hex_map( f.hex_map ), tet_map( f.tet_map ) {} 00068 00069 public: 00070 template < typename Moab, typename Entity_handle, typename Point > 00071 std::pair< bool, Point > operator()( Moab& moab, const Entity_handle& eh, const Point& point ) 00072 { 00073 // get entity 00074 typedef std::vector< moab::CartVect > Points; 00075 Points points; 00076 get_moab_points( moab, eh, points ); 00077 // get type 00078 switch( moab.type_from_handle( eh ) ) 00079 { 00080 case moab::MBHEX: 00081 return hex_map( moab, eh, points, point ); 00082 case moab::MBTET: 00083 return tet_map( moab, eh, points, point ); 00084 // TODO: not correct.. 00085 // TODO: add quadratic hex, and a proper case for 00086 // spectral hex 00087 default: 00088 quadratic_hex_map( moab, eh, points, point ); 00089 return spectral_hex_map( moab, eh, points, point ); 00090 std::cerr << "Element type not supported" << std::endl; 00091 return make_pair( false, Point( 3, 0.0 ) ); 00092 } 00093 } 00094 template < typename Moab, typename Entity_handle, typename Point > 00095 void interpolate( Moab& moab, const Entity_handle& eh, const Point& natural_coords ) 00096 { 00097 // get field values from moab tag, 00098 // then 00099 // evaluate_scalar_field(); 00100 } 00101 00102 private: 00103 Linear_hex_map< moab::Matrix3 > hex_map; 00104 Linear_tet_map< Entity_handle, moab::Matrix3 > tet_map; 00105 Spectral_hex_map< moab::Matrix3 > spectral_hex_map; 00106 Quadratic_hex_map< moab::Matrix3 > quadratic_hex_map; 00107 }; // class Parametrizer 00108 00109 } // namespace element_utility 00110 } // namespace moab 00111 #endif // MOAB_PARAMETRIZER_HPP
