MOAB
4.9.3pre
Stores a set of parameters controlling the way matrices are printed. More...
#include <IO.h>
Public Member Functions | |
| IOFormat (int _precision=StreamPrecision, int _flags=0, const std::string &_coeffSeparator=" ", const std::string &_rowSeparator="\n", const std::string &_rowPrefix="", const std::string &_rowSuffix="", const std::string &_matPrefix="", const std::string &_matSuffix="") | |
Public Attributes | |
| std::string | matPrefix |
| std::string | matSuffix |
| std::string | rowPrefix |
| std::string | rowSuffix |
| std::string | rowSeparator |
| std::string | rowSpacer |
| std::string | coeffSeparator |
| int | precision |
| int | flags |
List of available parameters:
StreamPrecision and FullPrecision. The default is the special value StreamPrecision which means to use the stream's own precision setting, as set for instance using cout.precision(3). The other special value FullPrecision means that the number of digits will be computed to match the full precision of each floating-point type.DontAlignCols which allows to disable the alignment of columns, resulting in faster code.Example:
Output:
| Eigen::IOFormat::IOFormat | ( | int | _precision = StreamPrecision, |
| int | _flags = 0, |
| const std::string & | _coeffSeparator = " ", |
| const std::string & | _rowSeparator = "\n", |
| const std::string & | _rowPrefix = "", |
| const std::string & | _rowSuffix = "", |
| const std::string & | _matPrefix = "", |
| const std::string & | _matSuffix = "" |
| ) | [inline] |
Default constructor, see class IOFormat for the meaning of the parameters
Definition at line 53 of file IO.h.
: matPrefix(_matPrefix), matSuffix(_matSuffix), rowPrefix(_rowPrefix), rowSuffix(_rowSuffix), rowSeparator(_rowSeparator), rowSpacer(""), coeffSeparator(_coeffSeparator), precision(_precision), flags(_flags) { // TODO check if rowPrefix, rowSuffix or rowSeparator contains a newline // don't add rowSpacer if columns are not to be aligned if((flags & DontAlignCols)) return; int i = int(matSuffix.length())-1; while (i>=0 && matSuffix[i]!='\n') { rowSpacer += ' '; i--; } }
| std::string Eigen::IOFormat::coeffSeparator |
| std::string Eigen::IOFormat::matPrefix |
| std::string Eigen::IOFormat::matSuffix |
| std::string Eigen::IOFormat::rowPrefix |
| std::string Eigen::IOFormat::rowSeparator |
| std::string Eigen::IOFormat::rowSpacer |
| std::string Eigen::IOFormat::rowSuffix |
