MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /** 00002 * MOAB, a Mesh-Oriented datABase, is a software component for creating, 00003 * storing and accessing finite element mesh data. 00004 * 00005 * Copyright 2004 Sandia Corporation. Under the terms of Contract 00006 * DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government 00007 * retains certain rights in this software. 00008 * 00009 * This library is free software; you can redistribute it and/or 00010 * modify it under the terms of the GNU Lesser General Public 00011 * License as published by the Free Software Foundation; either 00012 * version 2.1 of the License, or (at your option) any later version. 00013 * 00014 */ 00015 00016 #ifdef WIN32 00017 #ifdef _DEBUG 00018 // turn off warnings that say they debugging identifier has been truncated 00019 // this warning comes up when using some STL containers 00020 #pragma warning( disable : 4786 ) 00021 #endif 00022 #endif 00023 00024 #include <iostream> 00025 #include "moab/Core.hpp" 00026 #include "TestUtil.hpp" 00027 00028 #ifndef IS_BUILDING_MB 00029 #define IS_BUILDING_MB 00030 #endif 00031 00032 #include "Internals.hpp" 00033 #include "TestUtil.hpp" 00034 00035 using namespace moab; 00036 00037 int main() 00038 { 00039 Interface* iface = new Core; 00040 00041 std::string filename; 00042 00043 #ifdef MOAB_HAVE_HDF5 00044 filename = TestDir + "unittest/testquad-cyl.h5m"; 00045 #else 00046 filename = TestDir + "unittest/hexes_mixed.vtk"; 00047 #endif 00048 00049 ErrorCode err; 00050 err = iface->load_mesh( filename.c_str() );CHECK_ERR( err ); 00051 00052 Range quads, verts; 00053 err = iface->get_entities_by_dimension( 0, 0, verts );CHECK_ERR( err ); 00054 err = iface->get_entities_by_dimension( 0, 2, quads );CHECK_ERR( err ); 00055 00056 for( Range::iterator it = verts.begin(); it != verts.end(); it++ ) 00057 std::cout << "verts[" << ( *it - *verts.begin() ) << "] = " << *it << std::endl; 00058 00059 std::vector< EntityHandle > conn; 00060 for( Range::iterator it = quads.begin(); it != quads.end(); it++ ) 00061 { 00062 conn.clear(); 00063 err = iface->get_connectivity( &*it, 1, conn );CHECK_ERR( err ); 00064 std::cout << "quads[" << ( *it - *quads.begin() ) << "] = " << *it << " :: conn = [" << conn[0] << ", " 00065 << conn[1] << ", " << conn[2] << ", " << conn[3] << "]" << std::endl; 00066 } 00067 00068 std::vector< EntityHandle > nodes; 00069 int error; 00070 EntityHandle h = CREATE_HANDLE( MBQUAD, MB_START_ID, error ); 00071 CHECK_EQUAL( 0, error ); 00072 std::cout << "h = " << h << std::endl; 00073 00074 err = iface->get_adjacencies( &h, 1, 0, true, nodes );CHECK_ERR( err ); 00075 00076 for( int i = 0; i < (int)nodes.size(); i++ ) 00077 std::cout << "nodes[" << i << "] = " << nodes[i] << " "; 00078 std::cout << std::endl; 00079 00080 std::vector< EntityHandle > edgs; 00081 err = iface->get_adjacencies( &h, 1, 1, true, edgs );CHECK_ERR( err ); 00082 00083 for( int i = 0; i < (int)edgs.size(); i++ ) 00084 std::cout << "edgs[" << i << "] = " << edgs[i] << " "; 00085 std::cout << std::endl; 00086 00087 // faces to nodes 00088 00089 for( unsigned int i = 0; i < edgs.size(); i++ ) 00090 { 00091 nodes.clear(); 00092 err = iface->get_adjacencies( &edgs[i], 1, 0, true, nodes );CHECK_ERR( err ); 00093 std::cout << "edge " << ID_FROM_HANDLE( edgs[i] ) << std::endl; 00094 std::cout << "nodes = "; 00095 for( unsigned int j = 0; j < nodes.size(); j++ ) 00096 std::cout << nodes[j] << " "; 00097 std::cout << std::endl; 00098 } 00099 00100 delete iface; 00101 00102 return 0; 00103 }
