Mesh Oriented datABase
(version 5.4.1)
Defines | |
#define | ERRORR(a) |
Functions | |
int | main (int argc, char *argv[]) |
#define ERRORR | ( | a | ) |
{ \ if( iBase_SUCCESS != err ) \ { \ std::cout << ( a ) << std::endl; \ return err; \ } \ }
ListSetsNTags: list sets & tags from a mesh
This program shows how to read and list sets and tags from a mesh
Usage: SetsNTags <mesh_file_name>
Definition at line 15 of file ListSetsNTagsCXX.cpp.
Referenced by main().
int main | ( | int | argc, |
char * | argv[] | ||
Definition at line 24 of file ListSetsNTagsCXX.cpp.
References ERRORR, iBase_DOUBLE, iBase_INTEGER, iMesh_dtor, iMesh_getAllEntSetTags, iMesh_getEntSetDblData, iMesh_getEntSetIntData, iMesh_getEntSets, iMesh_getRootSet, iMesh_getTagName, iMesh_getTagType, iMesh_load, iMesh_newMesh, mesh, and root_set.
{ const char* filename; bool read_par = false; if( argc < 2 || !strcmp( argv[1], "-h" ) ) { std::cout << "Usage: " << argv[0] << " <filename> [-p]" << std::endl; return 0; } else { // Check command line arg filename = argv[1]; if( argc > 2 && !strcmp( argv[2], "-p" ) ) read_par = true; } // create the Mesh instance iMesh_Instance mesh; int err; iMesh_newMesh( NULL, &mesh, &err, 0 );ERRORR( "Error creating new mesh.\n" ); iBase_EntitySetHandle root_set; iMesh_getRootSet( mesh, &root_set, &err );ERRORR( "Couldn't get root set." ); // load the mesh if( read_par ) { const char* opt = " moab:PARALLEL=READ_PART moab:PARTITION=PARALLEL_PARTITION moab:PARTITION_DISTRIBUTE " "moab:PARALLEL_RESOLVE_SHARED_ENTS moab:DEBUG_PIO=2 moab:DEBUG_IO=2 moab:SETS=SETS "; iMesh_load( mesh, root_set, filename, opt, &err, strlen( filename ), strlen( opt ) ); } else iMesh_load( mesh, root_set, filename, NULL, &err, strlen( filename ), 0 );ERRORR( "Couldn't load mesh." ); // get all sets iBase_EntitySetHandle* sets = NULL; int sets_alloc = 0, sets_size; iMesh_getEntSets( mesh, root_set, 1, &sets, &sets_alloc, &sets_size, &err );ERRORR( "Couldn't get all sets." ); // iterate through them, checking whether they have tags iBase_TagHandle* tags = NULL; int tags_alloc = 0, tags_size; int i, j; for( i = 0; i < sets_size; i++ ) { // get connectivity iMesh_getAllEntSetTags( mesh, sets[i], &tags, &tags_alloc, &tags_size, &err );ERRORR( "Failed to get ent set tags." ); if( 0 != tags_size ) { std::cout << "Set " << sets[i] << "; Tags:" << std::endl; // list tag names on this set for( j = 0; j < tags_size; j++ ) { char tname[128]; std::vector< int > int_val; std::vector< double > dbl_val; iMesh_getTagName( mesh, tags[j], tname, &err, sizeof( tname ) ); tname[sizeof( tname ) - 1] = '\0'; int tag_type, tag_size; iMesh_getTagType( mesh, tags[j], &tag_type, &err );ERRORR( "Failed to get tag type." ); iMesh_getTagType( mesh, tags[j], &tag_size, &err );ERRORR( "Failed to get tag size." ); if( iBase_INTEGER == tag_type ) { int_val.resize( tag_size ); iMesh_getEntSetIntData( mesh, sets[i], tags[j], &int_val[0], &err );ERRORR( "Failed to get int data type." ); std::cout << tname << " = " << int_val[0]; if( tag_size > 1 ) for( int k = 1; k < tag_size; i++ ) std::cout << ", " << int_val[k]; std::cout << std::endl; } else if( iBase_DOUBLE == tag_type ) { dbl_val.resize( tag_size ); iMesh_getEntSetDblData( mesh, sets[i], tags[j], &dbl_val[0], &err ); std::cout << tname << " = " << dbl_val[0]; if( tag_size > 1 ) for( int k = 1; k < tag_size; i++ ) std::cout << ", " << dbl_val[k]; std::cout << std::endl; } else std::cout << tname << " (opaque) " << std::endl; } } std::cout << std::endl; free( tags ); tags = NULL; tags_alloc = 0; } free( sets ); iMesh_dtor( mesh, &err );ERRORR( "Failed to destruct interface." ); return 0; }
