TempestOnlineMap.cpp
00001 /*
00002  * =====================================================================================
00003  *
00004  *       Filename:  TempestOnlineMap.hpp
00005  *
00006  *    Description:  Interface to the TempestRemap library to compute the consistent,
00007  *                  and accurate high-order conservative remapping weights for overlap
00008  *                  grids on the sphere in climate simulations.
00009  *
00010  *         Author:  Vijay S. Mahadevan (vijaysm), [email protected]
00011  *
00012  * =====================================================================================
00013  */
00014
00015 #include "Announce.h"
00016 #include "DataArray3D.h"
00017 #include "FiniteElementTools.h"
00018 #include "TriangularQuadrature.h"
00019 #include "GaussQuadrature.h"
00020 #include "GaussLobattoQuadrature.h"
00021 #include "SparseMatrix.h"
00022 #include "STLStringHelper.h"
00023 #include "LinearRemapFV.h"
00024
00025 #include "moab/Remapping/TempestOnlineMap.hpp"
00026 #include "DebugOutput.hpp"
00027 #include "moab/TupleList.hpp"
00028
00029 #include <fstream>
00030 #include <cmath>
00031 #include <cstdlib>
00032
00033 #ifdef MOAB_HAVE_NETCDFPAR
00034 #include "netcdfcpp_par.hpp"
00035 #else
00036 #include "netcdfcpp.h"
00037 #endif
00038
00039 ///////////////////////////////////////////////////////////////////////////////
00040
00041 // #define VERBOSE
00042 // #define VVERBOSE
00043 // #define CHECK_INCREASING_DOF
00044
00045 ///////////////////////////////////////////////////////////////////////////////
00046
00047 #define MPI_CHK_ERR( err )                                          \
00048     if( err )                                                       \
00049     {                                                               \
00050         std::cout << "MPI Failure. ErrorCode (" << ( err ) << ") "; \
00051         std::cout << "\nMPI Aborting... \n";                        \
00052         return moab::MB_FAILURE;                                    \
00053     }
00054
00055 moab::TempestOnlineMap::TempestOnlineMap( moab::TempestRemapper* remapper ) : OfflineMap(), m_remapper( remapper )
00056 {
00057     // Get the references for the MOAB core objects
00058     m_interface = m_remapper->get_interface();
00059 #ifdef MOAB_HAVE_MPI
00060     m_pcomm = m_remapper->get_parallel_communicator();
00061 #endif
00062
00063     // Update the references to the meshes
00064     m_meshInput    = remapper->GetMesh( moab::Remapper::SourceMesh );
00065     m_meshInputCov = remapper->GetCoveringMesh();
00066     m_meshOutput   = remapper->GetMesh( moab::Remapper::TargetMesh );
00067     m_meshOverlap  = remapper->GetMesh( moab::Remapper::OverlapMesh );
00068
00069     is_parallel = false;
00070     is_root     = true;
00071     rank        = 0;
00072     root_proc   = rank;
00073     size        = 1;
00074 #ifdef MOAB_HAVE_MPI
00075     int flagInit;
00076     MPI_Initialized( &flagInit );
00077     if( flagInit )
00078     {
00079         is_parallel = true;
00080         assert( m_pcomm != NULL );
00081         rank    = m_pcomm->rank();
00082         size    = m_pcomm->size();
00083         is_root = ( rank == 0 );
00084     }
00085 #endif
00086
00087     // Compute and store the total number of source and target DoFs corresponding
00088     // to number of rows and columns in the mapping.
00089
00090     // Initialize dimension information from file
00091     this->setup_sizes_dimensions();
00092
00093     // Build a matrix of source and target discretization so that we know how to assign
00094     // the global DoFs in parallel for the mapping weights
00095     // For example, FV->FV: rows X cols = faces_source X faces_target
00096 }
00097
00098 void moab::TempestOnlineMap::setup_sizes_dimensions()
00099 {
00100     if( m_meshInputCov )
00101     {
00102         std::vector< std::string > dimNames;
00103         std::vector< int > dimSizes;
00104         if( m_remapper->m_source_type == moab::TempestRemapper::RLL && m_remapper->m_source_metadata.size() )
00105         {
00106             dimNames.push_back( "lat" );
00107             dimNames.push_back( "lon" );
00108             dimSizes.resize( 2, 0 );
00109             dimSizes[0] = m_remapper->m_source_metadata[1];
00110             dimSizes[1] = m_remapper->m_source_metadata[2];
00111         }
00112         else
00113         {
00114             dimNames.push_back( "num_elem" );
00115             dimSizes.push_back( m_meshInputCov->faces.size() );
00116         }
00117
00118         this->InitializeSourceDimensions( dimNames, dimSizes );
00119     }
00120
00121     if( m_meshOutput )
00122     {
00123         std::vector< std::string > dimNames;
00124         std::vector< int > dimSizes;
00125         if( m_remapper->m_target_type == moab::TempestRemapper::RLL && m_remapper->m_target_metadata.size() )
00126         {
00127             dimNames.push_back( "lat" );
00128             dimNames.push_back( "lon" );
00129             dimSizes.resize( 2, 0 );
00130             dimSizes[0] = m_remapper->m_target_metadata[1];
00131             dimSizes[1] = m_remapper->m_target_metadata[2];
00132         }
00133         else
00134         {
00135             dimNames.push_back( "num_elem" );
00136             dimSizes.push_back( m_meshOutput->faces.size() );
00137         }
00138
00139         this->InitializeTargetDimensions( dimNames, dimSizes );
00140     }
00141 }
00142
00143 ///////////////////////////////////////////////////////////////////////////////
00144
00145 moab::TempestOnlineMap::~TempestOnlineMap()
00146 {
00147     m_interface = NULL;
00148 #ifdef MOAB_HAVE_MPI
00149     m_pcomm = NULL;
00150 #endif
00151     m_meshInput   = NULL;
00152     m_meshOutput  = NULL;
00153     m_meshOverlap = NULL;
00154 }
00155
00156 ///////////////////////////////////////////////////////////////////////////////
00157
00158 moab::ErrorCode moab::TempestOnlineMap::SetDOFmapTags( const std::string srcDofTagName,
00159                                                        const std::string tgtDofTagName )
00160 {
00161     moab::ErrorCode rval;
00162
00163     int tagSize = 0;
00164     tagSize     = ( m_eInputType == DiscretizationType_FV ? 1 : m_nDofsPEl_Src * m_nDofsPEl_Src );
00165     rval =
00166         m_interface->tag_get_handle( srcDofTagName.c_str(), tagSize, MB_TYPE_INTEGER, this->m_dofTagSrc, MB_TAG_ANY );
00167
00168     if( rval == moab::MB_TAG_NOT_FOUND && m_eInputType != DiscretizationType_FV )
00169     {
00170         int ntot_elements = 0, nelements = m_remapper->m_source_entities.size();
00171 #ifdef MOAB_HAVE_MPI
00172         int ierr = MPI_Allreduce( &nelements, &ntot_elements, 1, MPI_INT, MPI_SUM, m_pcomm->comm() );
00173         if( ierr != 0 ) MB_CHK_SET_ERR( MB_FAILURE, "MPI_Allreduce failed to get total source elements" );
00174 #else
00175         ntot_elements = nelements;
00176 #endif
00177
00178         rval = m_remapper->GenerateCSMeshMetadata( ntot_elements, m_remapper->m_covering_source_entities,
00179                                                    &m_remapper->m_source_entities, srcDofTagName, m_nDofsPEl_Src );MB_CHK_ERR( rval );
00180
00181         rval = m_interface->tag_get_handle( srcDofTagName.c_str(), m_nDofsPEl_Src * m_nDofsPEl_Src, MB_TYPE_INTEGER,
00182                                             this->m_dofTagSrc, MB_TAG_ANY );MB_CHK_ERR( rval );
00183     }
00184     else
00185         MB_CHK_ERR( rval );
00186
00187     tagSize = ( m_eOutputType == DiscretizationType_FV ? 1 : m_nDofsPEl_Dest * m_nDofsPEl_Dest );
00188     rval =
00189         m_interface->tag_get_handle( tgtDofTagName.c_str(), tagSize, MB_TYPE_INTEGER, this->m_dofTagDest, MB_TAG_ANY );
00190     if( rval == moab::MB_TAG_NOT_FOUND && m_eOutputType != DiscretizationType_FV )
00191     {
00192         int ntot_elements = 0, nelements = m_remapper->m_target_entities.size();
00193 #ifdef MOAB_HAVE_MPI
00194         int ierr = MPI_Allreduce( &nelements, &ntot_elements, 1, MPI_INT, MPI_SUM, m_pcomm->comm() );
00195         if( ierr != 0 ) MB_CHK_SET_ERR( MB_FAILURE, "MPI_Allreduce failed to get total source elements" );
00196 #else
00197         ntot_elements = nelements;
00198 #endif
00199
00200         rval = m_remapper->GenerateCSMeshMetadata( ntot_elements, m_remapper->m_target_entities, NULL, tgtDofTagName,
00201                                                    m_nDofsPEl_Dest );MB_CHK_ERR( rval );
00202
00203         rval = m_interface->tag_get_handle( tgtDofTagName.c_str(), m_nDofsPEl_Dest * m_nDofsPEl_Dest, MB_TYPE_INTEGER,
00204                                             this->m_dofTagDest, MB_TAG_ANY );MB_CHK_ERR( rval );
00205     }
00206     else
00207         MB_CHK_ERR( rval );
00208
00209     return moab::MB_SUCCESS;
00210 }
00211
00212 ///////////////////////////////////////////////////////////////////////////////
00213
00214 moab::ErrorCode moab::TempestOnlineMap::SetDOFmapAssociation( DiscretizationType srcType,
00215                                                               bool isSrcContinuous,
00216                                                               DataArray3D< int >* srcdataGLLNodes,
00217                                                               DataArray3D< int >* srcdataGLLNodesSrc,
00218                                                               DiscretizationType destType,
00219                                                               bool isTgtContinuous,
00220                                                               DataArray3D< int >* tgtdataGLLNodes )
00221 {
00222     moab::ErrorCode rval;
00223     std::vector< bool > dgll_cgll_row_ldofmap, dgll_cgll_col_ldofmap, dgll_cgll_covcol_ldofmap;
00224     std::vector< int > src_soln_gdofs, locsrc_soln_gdofs, tgt_soln_gdofs;
00225
00226     // We are assuming that these are element based tags that are sized: np * np
00227     m_srcDiscType  = srcType;
00228     m_destDiscType = destType;
00229
00230     bool vprint = is_root && false;
00231
00232 #ifdef VVERBOSE
00233     {
00234         src_soln_gdofs.resize( m_remapper->m_covering_source_entities.size() * m_nDofsPEl_Src * m_nDofsPEl_Src, -1 );
00235         rval = m_interface->tag_get_data( m_dofTagSrc, m_remapper->m_covering_source_entities, &src_soln_gdofs[0] );MB_CHK_ERR( rval );
00236         locsrc_soln_gdofs.resize( m_remapper->m_source_entities.size() * m_nDofsPEl_Src * m_nDofsPEl_Src );
00237         rval = m_interface->tag_get_data( m_dofTagSrc, m_remapper->m_source_entities, &locsrc_soln_gdofs[0] );MB_CHK_ERR( rval );
00238         tgt_soln_gdofs.resize( m_remapper->m_target_entities.size() * m_nDofsPEl_Dest * m_nDofsPEl_Dest );
00239         rval = m_interface->tag_get_data( m_dofTagDest, m_remapper->m_target_entities, &tgt_soln_gdofs[0] );MB_CHK_ERR( rval );
00240
00241         if( is_root )
00242         {
00243             {
00244                 std::ofstream output_file( "sourcecov-gids-0.txt" );
00245                 output_file << "I, GDOF\n";
00246                 for( unsigned i = 0; i < src_soln_gdofs.size(); ++i )
00247                     output_file << i << ", " << src_soln_gdofs[i] << "\n";
00248
00249                 output_file << "ELEMID, IDOF, LDOF, GDOF, NDOF\n";
00250                 m_nTotDofs_SrcCov = 0;
00251                 if( isSrcContinuous )
00252                     dgll_cgll_covcol_ldofmap.resize(
00253                         m_remapper->m_covering_source_entities.size() * m_nDofsPEl_Src * m_nDofsPEl_Src, false );
00254                 for( unsigned j = 0; j < m_remapper->m_covering_source_entities.size(); j++ )
00255                 {
00256                     for( int p = 0; p < m_nDofsPEl_Src; p++ )
00257                     {
00258                         for( int q = 0; q < m_nDofsPEl_Src; q++ )
00259                         {
00260                             const int localDOF  = ( *srcdataGLLNodes )[p][q][j] - 1;
00261                             const int offsetDOF = j * m_nDofsPEl_Src * m_nDofsPEl_Src + p * m_nDofsPEl_Src + q;
00262                             if( isSrcContinuous && !dgll_cgll_covcol_ldofmap[localDOF] )
00263                             {
00264                                 m_nTotDofs_SrcCov++;
00265                                 dgll_cgll_covcol_ldofmap[localDOF] = true;
00266                             }
00267                             output_file << m_remapper->lid_to_gid_covsrc[j] << ", " << offsetDOF << ", " << localDOF
00268                                         << ", " << src_soln_gdofs[offsetDOF] << ", " << m_nTotDofs_SrcCov << "\n";
00269                         }
00270                     }
00271                 }
00272                 output_file.flush();  // required here
00273                 output_file.close();
00274                 dgll_cgll_covcol_ldofmap.clear();
00275             }
00276
00277             {
00278                 std::ofstream output_file( "source-gids-0.txt" );
00279                 output_file << "I, GDOF\n";
00280                 for( unsigned i = 0; i < locsrc_soln_gdofs.size(); ++i )
00281                     output_file << i << ", " << locsrc_soln_gdofs[i] << "\n";
00282
00283                 output_file << "ELEMID, IDOF, LDOF, GDOF, NDOF\n";
00284                 m_nTotDofs_Src = 0;
00285                 if( isSrcContinuous )
00286                     dgll_cgll_col_ldofmap.resize(
00287                         m_remapper->m_source_entities.size() * m_nDofsPEl_Src * m_nDofsPEl_Src, false );
00288                 for( unsigned j = 0; j < m_remapper->m_source_entities.size(); j++ )
00289                 {
00290                     for( int p = 0; p < m_nDofsPEl_Src; p++ )
00291                     {
00292                         for( int q = 0; q < m_nDofsPEl_Src; q++ )
00293                         {
00294                             const int localDOF  = ( *srcdataGLLNodesSrc )[p][q][j] - 1;
00295                             const int offsetDOF = j * m_nDofsPEl_Src * m_nDofsPEl_Src + p * m_nDofsPEl_Src + q;
00296                             if( isSrcContinuous && !dgll_cgll_col_ldofmap[localDOF] )
00297                             {
00298                                 m_nTotDofs_Src++;
00299                                 dgll_cgll_col_ldofmap[localDOF] = true;
00300                             }
00301                             output_file << m_remapper->lid_to_gid_src[j] << ", " << offsetDOF << ", " << localDOF
00302                                         << ", " << locsrc_soln_gdofs[offsetDOF] << ", " << m_nTotDofs_Src << "\n";
00303                         }
00304                     }
00305                 }
00306                 output_file.flush();  // required here
00307                 output_file.close();
00308                 dgll_cgll_col_ldofmap.clear();
00309             }
00310
00311             {
00312                 std::ofstream output_file( "target-gids-0.txt" );
00313                 output_file << "I, GDOF\n";
00314                 for( unsigned i = 0; i < tgt_soln_gdofs.size(); ++i )
00315                     output_file << i << ", " << tgt_soln_gdofs[i] << "\n";
00316
00317                 output_file << "ELEMID, IDOF, GDOF, NDOF\n";
00318                 m_nTotDofs_Dest = 0;
00319
00320                 for( unsigned i = 0; i < tgt_soln_gdofs.size(); ++i )
00321                 {
00322                     output_file << m_remapper->lid_to_gid_tgt[i] << ", " << i << ", " << tgt_soln_gdofs[i] << ", "
00323                                 << m_nTotDofs_Dest << "\n";
00324                     m_nTotDofs_Dest++;
00325                 }
00326
00327                 output_file.flush();  // required here
00328                 output_file.close();
00329             }
00330         }
00331         else
00332         {
00333             {
00334                 std::ofstream output_file( "sourcecov-gids-1.txt" );
00335                 output_file << "I, GDOF\n";
00336                 for( unsigned i = 0; i < src_soln_gdofs.size(); ++i )
00337                     output_file << i << ", " << src_soln_gdofs[i] << "\n";
00338
00339                 output_file << "ELEMID, IDOF, LDOF, GDOF, NDOF\n";
00340                 m_nTotDofs_SrcCov = 0;
00341                 if( isSrcContinuous )
00342                     dgll_cgll_covcol_ldofmap.resize(
00343                         m_remapper->m_covering_source_entities.size() * m_nDofsPEl_Src * m_nDofsPEl_Src, false );
00344                 for( unsigned j = 0; j < m_remapper->m_covering_source_entities.size(); j++ )
00345                 {
00346                     for( int p = 0; p < m_nDofsPEl_Src; p++ )
00347                     {
00348                         for( int q = 0; q < m_nDofsPEl_Src; q++ )
00349                         {
00350                             const int localDOF  = ( *srcdataGLLNodes )[p][q][j] - 1;
00351                             const int offsetDOF = j * m_nDofsPEl_Src * m_nDofsPEl_Src + p * m_nDofsPEl_Src + q;
00352                             if( isSrcContinuous && !dgll_cgll_covcol_ldofmap[localDOF] )
00353                             {
00354                                 m_nTotDofs_SrcCov++;
00355                                 dgll_cgll_covcol_ldofmap[localDOF] = true;
00356                             }
00357                             output_file << m_remapper->lid_to_gid_covsrc[j] << ", " << offsetDOF << ", " << localDOF
00358                                         << ", " << src_soln_gdofs[offsetDOF] << ", " << m_nTotDofs_SrcCov << "\n";
00359                         }
00360                     }
00361                 }
00362                 output_file.flush();  // required here
00363                 output_file.close();
00364                 dgll_cgll_covcol_ldofmap.clear();
00365             }
00366
00367             {
00368                 std::ofstream output_file( "source-gids-1.txt" );
00369                 output_file << "I, GDOF\n";
00370                 for( unsigned i = 0; i < locsrc_soln_gdofs.size(); ++i )
00371                     output_file << i << ", " << locsrc_soln_gdofs[i] << "\n";
00372
00373                 output_file << "ELEMID, IDOF, LDOF, GDOF, NDOF\n";
00374                 m_nTotDofs_Src = 0;
00375                 if( isSrcContinuous )
00376                     dgll_cgll_col_ldofmap.resize(
00377                         m_remapper->m_source_entities.size() * m_nDofsPEl_Src * m_nDofsPEl_Src, false );
00378                 for( unsigned j = 0; j < m_remapper->m_source_entities.size(); j++ )
00379                 {
00380                     for( int p = 0; p < m_nDofsPEl_Src; p++ )
00381                     {
00382                         for( int q = 0; q < m_nDofsPEl_Src; q++ )
00383                         {
00384                             const int localDOF  = ( *srcdataGLLNodesSrc )[p][q][j] - 1;
00385                             const int offsetDOF = j * m_nDofsPEl_Src * m_nDofsPEl_Src + p * m_nDofsPEl_Src + q;
00386                             if( isSrcContinuous && !dgll_cgll_col_ldofmap[localDOF] )
00387                             {
00388                                 m_nTotDofs_Src++;
00389                                 dgll_cgll_col_ldofmap[localDOF] = true;
00390                             }
00391                             output_file << m_remapper->lid_to_gid_src[j] << ", " << offsetDOF << ", " << localDOF
00392                                         << ", " << locsrc_soln_gdofs[offsetDOF] << ", " << m_nTotDofs_Src << "\n";
00393                         }
00394                     }
00395                 }
00396                 output_file.flush();  // required here
00397                 output_file.close();
00398                 dgll_cgll_col_ldofmap.clear();
00399             }
00400
00401             {
00402                 std::ofstream output_file( "target-gids-1.txt" );
00403                 output_file << "I, GDOF\n";
00404                 for( unsigned i = 0; i < tgt_soln_gdofs.size(); ++i )
00405                     output_file << i << ", " << tgt_soln_gdofs[i] << "\n";
00406
00407                 output_file << "ELEMID, IDOF, GDOF, NDOF\n";
00408                 m_nTotDofs_Dest = 0;
00409
00410                 for( unsigned i = 0; i < tgt_soln_gdofs.size(); ++i )
00411                 {
00412                     output_file << m_remapper->lid_to_gid_tgt[i] << ", " << i << ", " << tgt_soln_gdofs[i] << ", "
00413                                 << m_nTotDofs_Dest << "\n";
00414                     m_nTotDofs_Dest++;
00415                 }
00416
00417                 output_file.flush();  // required here
00418                 output_file.close();
00419             }
00420         }
00421     }
00422 #endif
00423
00424     // Now compute the mapping and store it for the covering mesh
00425     int srcTagSize = ( m_eInputType == DiscretizationType_FV ? 1 : m_nDofsPEl_Src * m_nDofsPEl_Src );
00426     if( m_remapper->point_cloud_source )
00427     {
00428         assert( m_nDofsPEl_Src == 1 );
00429         col_gdofmap.resize( m_remapper->m_covering_source_vertices.size(), UINT_MAX );
00430         col_dtoc_dofmap.resize( m_remapper->m_covering_source_vertices.size(), UINT_MAX );
00431         src_soln_gdofs.resize( m_remapper->m_covering_source_vertices.size(), UINT_MAX );
00432         rval = m_interface->tag_get_data( m_dofTagSrc, m_remapper->m_covering_source_vertices, &src_soln_gdofs[0] );MB_CHK_ERR( rval );
00433         srcTagSize = 1;
00434     }
00435     else
00436     {
00437         col_gdofmap.resize( m_remapper->m_covering_source_entities.size() * srcTagSize, UINT_MAX );
00438         col_dtoc_dofmap.resize( m_remapper->m_covering_source_entities.size() * srcTagSize, UINT_MAX );
00439         src_soln_gdofs.resize( m_remapper->m_covering_source_entities.size() * srcTagSize, UINT_MAX );
00440         rval = m_interface->tag_get_data( m_dofTagSrc, m_remapper->m_covering_source_entities, &src_soln_gdofs[0] );MB_CHK_ERR( rval );
00441     }
00442
00443     // std::cout << "TOnlineMap: Process: " << rank << " and covering entities = [" <<
00444     // col_dofmap.size() << ", " << src_soln_gdofs.size() << "]\n"; MPI_Barrier(MPI_COMM_WORLD);
00445
00446 #ifdef ALTERNATE_NUMBERING_IMPLEMENTATION
00447     unsigned maxSrcIndx = 0;
00448
00449     // for ( unsigned j = 0; j < m_covering_source_entities.size(); j++ )
00450     std::vector< int > locdofs( srcTagSize );
00451     std::map< Node, moab::EntityHandle > mapLocalMBNodes;
00452     double elcoords[3];
00453     for( unsigned iel = 0; iel < m_remapper->m_covering_source_entities.size(); ++iel )
00454     {
00455         EntityHandle eh = m_remapper->m_covering_source_entities[iel];
00456         rval            = m_interface->get_coords( &eh, 1, elcoords );MB_CHK_ERR( rval );
00457         Node elCentroid( elcoords[0], elcoords[1], elcoords[2] );
00458         mapLocalMBNodes.insert( std::pair< Node, moab::EntityHandle >( elCentroid, eh ) );
00459     }
00460
00461     const NodeVector& nodes = m_remapper->m_covering_source->nodes;
00462     for( unsigned j = 0; j < m_remapper->m_covering_source->faces.size(); j++ )
00463     {
00464         const Face& face = m_remapper->m_covering_source->faces[j];
00465
00466         Node centroid;
00467         centroid.x = centroid.y = centroid.z = 0.0;
00468         for( unsigned l = 0; l < face.edges.size(); ++l )
00469         {
00470             centroid.x += nodes[face[l]].x;
00471             centroid.y += nodes[face[l]].y;
00472             centroid.z += nodes[face[l]].z;
00473         }
00474         const double factor = 1.0 / face.edges.size();
00475         centroid.x *= factor;
00476         centroid.y *= factor;
00477         centroid.z *= factor;
00478
00479         EntityHandle current_eh;
00480         if( mapLocalMBNodes.find( centroid ) != mapLocalMBNodes.end() )
00481         {
00482             current_eh = mapLocalMBNodes[centroid];
00483         }
00484
00485         rval = m_interface->tag_get_data( m_dofTagSrc, &current_eh, 1, &locdofs[0] );MB_CHK_ERR( rval );
00486         for( int p = 0; p < m_nDofsPEl_Src; p++ )
00487         {
00488             for( int q = 0; q < m_nDofsPEl_Src; q++ )
00489             {
00490                 const int localDOF  = ( *srcdataGLLNodes )[p][q][j] - 1;
00491                 const int offsetDOF = p * m_nDofsPEl_Src + q;
00492                 maxSrcIndx          = ( localDOF > maxSrcIndx ? localDOF : maxSrcIndx );
00493                 std::cout << "Col: " << current_eh << ", " << m_remapper->lid_to_gid_covsrc[j] << ", " << offsetDOF
00494                           << ", " << localDOF << ", " << locdofs[offsetDOF] - 1 << ", " << maxSrcIndx << "\n";
00495             }
00496         }
00497     }
00498 #endif
00499
00500     m_nTotDofs_SrcCov = 0;
00501     if( srcdataGLLNodes == NULL )
00502     { /* we only have a mapping for elements as DoFs */
00503         for( unsigned i = 0; i < col_gdofmap.size(); ++i )
00504         {
00505             assert( src_soln_gdofs[i] > 0 );
00506             col_gdofmap[i]     = src_soln_gdofs[i] - 1;
00507             col_dtoc_dofmap[i] = i;
00508             if( vprint ) std::cout << "Col: " << i << ", " << col_gdofmap[i] << "\n";
00509             m_nTotDofs_SrcCov++;
00510         }
00511     }
00512     else
00513     {
00514         if( isSrcContinuous )
00515             dgll_cgll_covcol_ldofmap.resize( m_remapper->m_covering_source_entities.size() * srcTagSize, false );
00516         // Put these remap coefficients into the SparseMatrix map
00517         for( unsigned j = 0; j < m_remapper->m_covering_source_entities.size(); j++ )
00518         {
00519             for( int p = 0; p < m_nDofsPEl_Src; p++ )
00520             {
00521                 for( int q = 0; q < m_nDofsPEl_Src; q++ )
00522                 {
00523                     const int localDOF  = ( *srcdataGLLNodes )[p][q][j] - 1;
00524                     const int offsetDOF = j * srcTagSize + p * m_nDofsPEl_Src + q;
00525                     if( isSrcContinuous && !dgll_cgll_covcol_ldofmap[localDOF] )
00526                     {
00527                         m_nTotDofs_SrcCov++;
00528                         dgll_cgll_covcol_ldofmap[localDOF] = true;
00529                     }
00530                     if( !isSrcContinuous ) m_nTotDofs_SrcCov++;
00531                     assert( src_soln_gdofs[offsetDOF] > 0 );
00532                     col_gdofmap[localDOF]      = src_soln_gdofs[offsetDOF] - 1;
00533                     col_dtoc_dofmap[offsetDOF] = localDOF;
00534                     if( vprint )
00535                         std::cout << "Col: " << m_remapper->lid_to_gid_covsrc[j] << ", " << offsetDOF << ", "
00536                                   << localDOF << ", " << col_gdofmap[offsetDOF] << ", " << m_nTotDofs_SrcCov << "\n";
00537                 }
00538             }
00539         }
00540     }
00541
00542     if( m_remapper->point_cloud_source )
00543     {
00544         assert( m_nDofsPEl_Src == 1 );
00545         srccol_gdofmap.resize( m_remapper->m_source_vertices.size(), UINT_MAX );
00546         srccol_dtoc_dofmap.resize( m_remapper->m_covering_source_vertices.size(), UINT_MAX );
00547         locsrc_soln_gdofs.resize( m_remapper->m_source_vertices.size(), UINT_MAX );
00548         rval = m_interface->tag_get_data( m_dofTagSrc, m_remapper->m_source_vertices, &locsrc_soln_gdofs[0] );MB_CHK_ERR( rval );
00549     }
00550     else
00551     {
00552         srccol_gdofmap.resize( m_remapper->m_source_entities.size() * srcTagSize, UINT_MAX );
00553         srccol_dtoc_dofmap.resize( m_remapper->m_source_entities.size() * srcTagSize, UINT_MAX );
00554         locsrc_soln_gdofs.resize( m_remapper->m_source_entities.size() * srcTagSize, UINT_MAX );
00555         rval = m_interface->tag_get_data( m_dofTagSrc, m_remapper->m_source_entities, &locsrc_soln_gdofs[0] );MB_CHK_ERR( rval );
00556     }
00557
00558     // Now compute the mapping and store it for the original source mesh
00559     m_nTotDofs_Src = 0;
00560     if( srcdataGLLNodesSrc == NULL )
00561     { /* we only have a mapping for elements as DoFs */
00562         for( unsigned i = 0; i < srccol_gdofmap.size(); ++i )
00563         {
00564             assert( locsrc_soln_gdofs[i] > 0 );
00565             srccol_gdofmap[i]     = locsrc_soln_gdofs[i] - 1;
00566             srccol_dtoc_dofmap[i] = i;
00567             m_nTotDofs_Src++;
00568         }
00569     }
00570     else
00571     {
00572         if( isSrcContinuous ) dgll_cgll_col_ldofmap.resize( m_remapper->m_source_entities.size() * srcTagSize, false );
00573         // Put these remap coefficients into the SparseMatrix map
00574         for( unsigned j = 0; j < m_remapper->m_source_entities.size(); j++ )
00575         {
00576             for( int p = 0; p < m_nDofsPEl_Src; p++ )
00577             {
00578                 for( int q = 0; q < m_nDofsPEl_Src; q++ )
00579                 {
00580                     const int localDOF  = ( *srcdataGLLNodesSrc )[p][q][j] - 1;
00581                     const int offsetDOF = j * srcTagSize + p * m_nDofsPEl_Src + q;
00582                     if( isSrcContinuous && !dgll_cgll_col_ldofmap[localDOF] )
00583                     {
00584                         m_nTotDofs_Src++;
00585                         dgll_cgll_col_ldofmap[localDOF] = true;
00586                     }
00587                     if( !isSrcContinuous ) m_nTotDofs_Src++;
00588                     assert( locsrc_soln_gdofs[offsetDOF] > 0 );
00589                     srccol_gdofmap[localDOF]      = locsrc_soln_gdofs[offsetDOF] - 1;
00590                     srccol_dtoc_dofmap[offsetDOF] = localDOF;
00591                 }
00592             }
00593         }
00594     }
00595
00596     int tgtTagSize = ( m_eOutputType == DiscretizationType_FV ? 1 : m_nDofsPEl_Dest * m_nDofsPEl_Dest );
00597     if( m_remapper->point_cloud_target )
00598     {
00599         assert( m_nDofsPEl_Dest == 1 );
00600         row_gdofmap.resize( m_remapper->m_target_vertices.size(), UINT_MAX );
00601         row_dtoc_dofmap.resize( m_remapper->m_target_vertices.size(), UINT_MAX );
00602         tgt_soln_gdofs.resize( m_remapper->m_target_vertices.size(), UINT_MAX );
00603         rval = m_interface->tag_get_data( m_dofTagDest, m_remapper->m_target_vertices, &tgt_soln_gdofs[0] );MB_CHK_ERR( rval );
00604         tgtTagSize = 1;
00605     }
00606     else
00607     {
00608         row_gdofmap.resize( m_remapper->m_target_entities.size() * tgtTagSize, UINT_MAX );
00609         row_dtoc_dofmap.resize( m_remapper->m_target_entities.size() * tgtTagSize, UINT_MAX );
00610         tgt_soln_gdofs.resize( m_remapper->m_target_entities.size() * tgtTagSize, UINT_MAX );
00611         rval = m_interface->tag_get_data( m_dofTagDest, m_remapper->m_target_entities, &tgt_soln_gdofs[0] );MB_CHK_ERR( rval );
00612     }
00613
00614     // Now compute the mapping and store it for the target mesh
00615     // To access the GID for each row: row_gdofmap [ row_ldofmap [ 0 : local_ndofs ] ] = GDOF
00616     m_nTotDofs_Dest = 0;
00617     if( tgtdataGLLNodes == NULL )
00618     { /* we only have a mapping for elements as DoFs */
00619         for( unsigned i = 0; i < row_gdofmap.size(); ++i )
00620         {
00621             assert( tgt_soln_gdofs[i] > 0 );
00622             row_gdofmap[i]     = tgt_soln_gdofs[i] - 1;
00623             row_dtoc_dofmap[i] = i;
00624             if( vprint ) std::cout << "Row: " << i << ", " << row_gdofmap[i] << "\n";
00625             m_nTotDofs_Dest++;
00626         }
00627     }
00628     else
00629     {
00630         if( isTgtContinuous ) dgll_cgll_row_ldofmap.resize( m_remapper->m_target_entities.size() * tgtTagSize, false );
00631         // Put these remap coefficients into the SparseMatrix map
00632         for( unsigned j = 0; j < m_remapper->m_target_entities.size(); j++ )
00633         {
00634             for( int p = 0; p < m_nDofsPEl_Dest; p++ )
00635             {
00636                 for( int q = 0; q < m_nDofsPEl_Dest; q++ )
00637                 {
00638                     const int localDOF  = ( *tgtdataGLLNodes )[p][q][j] - 1;
00639                     const int offsetDOF = j * tgtTagSize + p * m_nDofsPEl_Dest + q;
00640                     if( isTgtContinuous && !dgll_cgll_row_ldofmap[localDOF] )
00641                     {
00642                         m_nTotDofs_Dest++;
00643                         dgll_cgll_row_ldofmap[localDOF] = true;
00644                     }
00645                     if( !isTgtContinuous ) m_nTotDofs_Dest++;
00646                     assert( tgt_soln_gdofs[offsetDOF] > 0 );
00647                     row_gdofmap[localDOF]      = tgt_soln_gdofs[offsetDOF] - 1;
00648                     row_dtoc_dofmap[offsetDOF] = localDOF;
00649                     if( vprint )
00650                         std::cout << "Row: " << m_remapper->lid_to_gid_tgt[j] << ", " << offsetDOF << ", " << localDOF
00651                                   << ", " << row_gdofmap[offsetDOF] << ", " << m_nTotDofs_Dest << "\n";
00652                 }
00653             }
00654         }
00655     }
00656
00657     // Let us also allocate the local representation of the sparse matrix
00658 #if defined( MOAB_HAVE_EIGEN3 ) && defined( VERBOSE )
00659     if( vprint )
00660     {
00661         std::cout << "[" << rank << "]"
00662                   << "DoFs: row = " << m_nTotDofs_Dest << ", " << row_gdofmap.size() << ", col = " << m_nTotDofs_Src
00663                   << ", " << m_nTotDofs_SrcCov << ", " << col_gdofmap.size() << "\n";
00664         // std::cout << "Max col_dofmap: " << maxcol << ", Min col_dofmap" << mincol << "\n";
00665     }
00666 #endif
00667
00668     // check monotonicity of row_gdofmap and col_gdofmap
00669 #ifdef CHECK_INCREASING_DOF
00670     for( size_t i = 0; i < row_gdofmap.size() - 1; i++ )
00671     {
00672         if( row_gdofmap[i] > row_gdofmap[i + 1] )
00673             std::cout << " on rank " << rank << " in row_gdofmap[" << i << "]=" << row_gdofmap[i] << " > row_gdofmap["
00674                       << i + 1 << "]=" << row_gdofmap[i + 1] << " \n";
00675     }
00676     for( size_t i = 0; i < col_gdofmap.size() - 1; i++ )
00677     {
00678         if( col_gdofmap[i] > col_gdofmap[i + 1] )
00679             std::cout << " on rank " << rank << " in col_gdofmap[" << i << "]=" << col_gdofmap[i] << " > col_gdofmap["
00680                       << i + 1 << "]=" << col_gdofmap[i + 1] << " \n";
00681     }
00682 #endif
00683
00684     return moab::MB_SUCCESS;
00685 }
00686
00687 moab::ErrorCode moab::TempestOnlineMap::set_col_dc_dofs( std::vector< int >& values_entities )
00688 {
00689     // col_gdofmap has global dofs , that should be in the list of values, such that
00690     // row_dtoc_dofmap[offsetDOF] = localDOF;
00691     // //  we need to find col_dtoc_dofmap such that: col_gdofmap[ col_dtoc_dofmap[i] ] == values_entities [i];
00692     // we know that col_gdofmap[0..(nbcols-1)] = global_col_dofs -> in values_entities
00693     // form first inverse
00694
00695     col_dtoc_dofmap.resize( values_entities.size() );
00696     for( int j = 0; j < (int)values_entities.size(); j++ )
00697     {
00698         if( colMap.find( values_entities[j] - 1 ) != colMap.end() )
00699             col_dtoc_dofmap[j] = colMap[values_entities[j] - 1];
00700         else
00701         {
00702             col_dtoc_dofmap[j] = -1;  // signal that this value should not be used in
00703             // std::cout <<"values_entities[j] -  1: " << values_entities[j] -  1 <<" at index j = " << j <<  " not
00704             // found in colMap \n";
00705         }
00706     }
00707     return moab::MB_SUCCESS;
00708 }
00709
00710 moab::ErrorCode moab::TempestOnlineMap::set_row_dc_dofs( std::vector< int >& values_entities )
00711 {
00712     // row_dtoc_dofmap = values_entities; // needs to point to local
00713     //  we need to find row_dtoc_dofmap such that: row_gdofmap[ row_dtoc_dofmap[i] ] == values_entities [i];
00714
00715     row_dtoc_dofmap.resize( values_entities.size() );
00716     for( int j = 0; j < (int)values_entities.size(); j++ )
00717     {
00718         if( rowMap.find( values_entities[j] - 1 ) != rowMap.end() )
00719             row_dtoc_dofmap[j] = rowMap[values_entities[j] - 1];  // values are 1 based, but rowMap, colMap are not
00720         else
00721         {
00722             row_dtoc_dofmap[j] = -1;  // not all values are used
00723             // std::cout <<"values_entities[j] -  1: " << values_entities[j] -  1 <<" at index j = " << j <<  " not
00724             // found in rowMap \n";
00725         }
00726     }
00727     return moab::MB_SUCCESS;
00728 }
00729 ///////////////////////////////////////////////////////////////////////////////
00730
00731 moab::ErrorCode moab::TempestOnlineMap::GenerateRemappingWeights( std::string strInputType,
00732        std::string strOutputType,
00733        const GenerateOfflineMapAlgorithmOptions& mapOptions,
00734        const std::string& srcDofTagName,
00735        const std::string& tgtDofTagName )
00736 {
00737     NcError error( NcError::silent_nonfatal );
00738
00739     moab::DebugOutput dbgprint( std::cout, rank, 0 );
00740     dbgprint.set_prefix( "[TempestOnlineMap]: " );
00741     moab::ErrorCode rval;
00742
00743     const bool m_bPointCloudSource = ( m_remapper->point_cloud_source );
00744     const bool m_bPointCloudTarget = ( m_remapper->point_cloud_target );
00745     const bool m_bPointCloud       = m_bPointCloudSource || m_bPointCloudTarget;
00746
00747     try
00748     {
00749         // Check command line parameters (data type arguments)
00750         STLStringHelper::ToLower( strInputType );
00751         STLStringHelper::ToLower( strOutputType );
00752
00753         DiscretizationType eInputType;
00754         DiscretizationType eOutputType;
00755
00756         if( strInputType == "fv" )
00757         {
00758             eInputType = DiscretizationType_FV;
00759         }
00760         else if( strInputType == "cgll" )
00761         {
00762             eInputType = DiscretizationType_CGLL;
00763         }
00764         else if( strInputType == "dgll" )
00765         {
00766             eInputType = DiscretizationType_DGLL;
00767         }
00768         else if( strInputType == "pcloud" )
00769         {
00770             eInputType = DiscretizationType_PCLOUD;
00771         }
00772         else
00773         {
00774             _EXCEPTION1( "Invalid \"in_type\" value (%s), expected [fv|cgll|dgll]", strInputType.c_str() );
00775         }
00776
00777         if( strOutputType == "fv" )
00778         {
00779             eOutputType = DiscretizationType_FV;
00780         }
00781         else if( strOutputType == "cgll" )
00782         {
00783             eOutputType = DiscretizationType_CGLL;
00784         }
00785         else if( strOutputType == "dgll" )
00786         {
00787             eOutputType = DiscretizationType_DGLL;
00788         }
00789         else if( strOutputType == "pcloud" )
00790         {
00791             eOutputType = DiscretizationType_PCLOUD;
00792         }
00793         else
00794         {
00795             _EXCEPTION1( "Invalid \"out_type\" value (%s), expected [fv|cgll|dgll]", strOutputType.c_str() );
00796         }
00797
00798         // set all required input params
00799         m_bConserved  = !mapOptions.fNoConservation;
00800         m_eInputType  = eInputType;
00801         m_eOutputType = eOutputType;
00802
00803         // Method flags
00804         std::string strMapAlgorithm( "" );
00805         int nMonotoneType = ( mapOptions.fMonotone ) ? ( 1 ) : ( 0 );
00806
00807         // Make an index of method arguments
00808         std::set< std::string > setMethodStrings;
00809         {
00810             int iLast = 0;
00811             for( size_t i = 0; i <= mapOptions.strMethod.length(); i++ )
00812             {
00813                 if( ( i == mapOptions.strMethod.length() ) || ( mapOptions.strMethod[i] == ';' ) )
00814                 {
00815                     std::string strMethodString = mapOptions.strMethod.substr( iLast, i - iLast );
00816                     STLStringHelper::RemoveWhitespaceInPlace( strMethodString );
00817                     if( strMethodString.length() > 0 )
00818                     {
00819                         setMethodStrings.insert( strMethodString );
00820                     }
00821                     iLast = i + 1;
00822                 }
00823             }
00824         }
00825
00826         for( auto it : setMethodStrings )
00827         {
00828             // Piecewise constant monotonicity
00829             if( it == "mono2" )
00830             {
00831                 if( nMonotoneType != 0 )
00832                 {
00833                     _EXCEPTIONT( "Multiple monotonicity specifications found (--mono) or (--method \"mono#\")" );
00834                 }
00835                 if( ( m_eInputType == DiscretizationType_FV ) && ( m_eOutputType == DiscretizationType_FV ) )
00836                 {
00837                     _EXCEPTIONT( "--method \"mono2\" is only used when remapping to/from CGLL or DGLL grids" );
00838                 }
00839                 nMonotoneType = 2;
00840
00841                 // Piecewise linear monotonicity
00842             }
00843             else if( it == "mono3" )
00844             {
00845                 if( nMonotoneType != 0 )
00846                 {
00847                     _EXCEPTIONT( "Multiple monotonicity specifications found (--mono) or (--method \"mono#\")" );
00848                 }
00849                 if( ( m_eInputType == DiscretizationType_FV ) && ( m_eOutputType == DiscretizationType_FV ) )
00850                 {
00851                     _EXCEPTIONT( "--method \"mono3\" is only used when remapping to/from CGLL or DGLL grids" );
00852                 }
00853                 nMonotoneType = 3;
00854
00855                 // Volumetric remapping from FV to GLL
00856             }
00857             else if( it == "volumetric" )
00858             {
00859                 if( ( m_eInputType != DiscretizationType_FV ) || ( m_eOutputType == DiscretizationType_FV ) )
00860                 {
00861                     _EXCEPTIONT( "--method \"volumetric\" may only be used for FV->CGLL or FV->DGLL remapping" );
00862                 }
00863                 strMapAlgorithm = "volumetric";
00864
00865                 // Inverse distance mapping
00866             }
00867             else if( it == "invdist" )
00868             {
00869                 if( ( m_eInputType != DiscretizationType_FV ) || ( m_eOutputType != DiscretizationType_FV ) )
00870                 {
00871                     _EXCEPTIONT( "--method \"invdist\" may only be used for FV->FV remapping" );
00872                 }
00873                 strMapAlgorithm = "invdist";
00874
00875                 // Delaunay triangulation mapping
00876             }
00877             else if( it == "delaunay" )
00878             {
00879                 if( ( m_eInputType != DiscretizationType_FV ) || ( m_eOutputType != DiscretizationType_FV ) )
00880                 {
00881                     _EXCEPTIONT( "--method \"delaunay\" may only be used for FV->FV remapping" );
00882                 }
00883                 strMapAlgorithm = "delaunay";
00884
00885                 // Bilinear
00886             }
00887             else if( it == "bilin" )
00888             {
00889                 if( ( m_eInputType != DiscretizationType_FV ) || ( m_eOutputType != DiscretizationType_FV ) )
00890                 {
00891                     _EXCEPTIONT( "--method \"bilin\" may only be used for FV->FV remapping" );
00892                 }
00893                 strMapAlgorithm = "fvbilin";
00894
00895                 // Integrated bilinear (same as mono3 when source grid is CGLL/DGLL)
00896             }
00897             else if( it == "intbilin" )
00898             {
00899                 if( m_eOutputType != DiscretizationType_FV )
00900                 {
00901                     _EXCEPTIONT( "--method \"intbilin\" may only be used when mapping to FV." );
00902                 }
00903                 if( m_eInputType == DiscretizationType_FV )
00904                 {
00905                     strMapAlgorithm = "fvintbilin";
00906                 }
00907                 else
00908                 {
00909                     strMapAlgorithm = "mono3";
00910                 }
00911
00912                 // Integrated bilinear with generalized Barycentric coordinates
00913             }
00914             else if( it == "intbilingb" )
00915             {
00916                 if( ( m_eInputType != DiscretizationType_FV ) || ( m_eOutputType != DiscretizationType_FV ) )
00917                 {
00918                     _EXCEPTIONT( "--method \"intbilingb\" may only be used for FV->FV remapping" );
00919                 }
00920                 strMapAlgorithm = "fvintbilingb";
00921             }
00922             else
00923             {
00924                 _EXCEPTION1( "Invalid --method argument \"%s\"", it.c_str() );
00925             }
00926         }
00927
00928         m_nDofsPEl_Src =
00929             ( m_eInputType == DiscretizationType_FV || m_eInputType == DiscretizationType_PCLOUD ? 1
00930        : mapOptions.nPin );
00931         m_nDofsPEl_Dest =
00932             ( m_eOutputType == DiscretizationType_FV || m_eOutputType == DiscretizationType_PCLOUD ? 1
00933        : mapOptions.nPout );
00934
00935         rval = SetDOFmapTags( srcDofTagName, tgtDofTagName );MB_CHK_ERR( rval );
00936
00937         ///   the tag should be created already in the e3sm workflow; if not, create it here
00938         Tag areaTag;
00939         rval = m_interface->tag_get_handle( "aream", 1, MB_TYPE_DOUBLE, areaTag,
00940                                              MB_TAG_DENSE |  MB_TAG_EXCL | MB_TAG_CREAT );
00941         if ( MB_ALREADY_ALLOCATED == rval )
00942         {
00943             if( is_root ) dbgprint.printf( 0, "aream tag already defined \n" );
00944         }
00945
00946         double dTotalAreaInput = 0.0, dTotalAreaOutput = 0.0;
00947         if( !m_bPointCloudSource )
00948         {
00949             // Calculate Input Mesh Face areas
00950             if( is_root ) dbgprint.printf( 0, "Calculating input mesh Face areas\n" );
00951             double dTotalAreaInput_loc = m_meshInput->CalculateFaceAreas( mapOptions.fSourceConcave );
00952             rval = m_interface->tag_set_data( areaTag, m_remapper->m_source_entities, m_meshInput->vecFaceArea );MB_CHK_ERR( rval );
00953             dTotalAreaInput            = dTotalAreaInput_loc;
00954 #ifdef MOAB_HAVE_MPI
00955             if( m_pcomm )
00956                 MPI_Reduce( &dTotalAreaInput_loc, &dTotalAreaInput, 1, MPI_DOUBLE, MPI_SUM, 0, m_pcomm->comm() );
00957 #endif
00958             if( is_root ) dbgprint.printf( 0, "Input Mesh Geometric Area: %1.15e\n", dTotalAreaInput );
00959
00960             // Input mesh areas
00961             m_meshInputCov->CalculateFaceAreas( mapOptions.fSourceConcave );
00962             // we do not need to set the area on coverage mesh, only on source and target meshes
00963             // rval = m_interface->tag_set_data( areaTag, m_remapper->m_covering_source_entities, m_meshInputCov->vecFaceArea );MB_CHK_ERR( rval );
00964         }
00965
00966         if( !m_bPointCloudTarget )
00967         {
00968             // Calculate Output Mesh Face areas
00969             if( is_root ) dbgprint.printf( 0, "Calculating output mesh Face areas\n" );
00970             double dTotalAreaOutput_loc = m_meshOutput->CalculateFaceAreas( mapOptions.fTargetConcave );
00971             dTotalAreaOutput            = dTotalAreaOutput_loc;
00972 #ifdef MOAB_HAVE_MPI
00973             if( m_pcomm )
00974                 MPI_Reduce( &dTotalAreaOutput_loc, &dTotalAreaOutput, 1, MPI_DOUBLE, MPI_SUM, 0, m_pcomm->comm() );
00975 #endif
00976             if( is_root ) dbgprint.printf( 0, "Output Mesh Geometric Area: %1.15e\n", dTotalAreaOutput );
00977             rval = m_interface->tag_set_data( areaTag, m_remapper->m_target_entities, m_meshOutput->vecFaceArea );MB_CHK_ERR( rval );
00978         }
00979
00980         if( !m_bPointCloud )
00981         {
00982             // Calculate Face areas
00983             if( is_root ) dbgprint.printf( 0, "Calculating overlap mesh Face areas\n" );
00984             double dTotalAreaOverlap_loc = m_meshOverlap->CalculateFaceAreas( false );
00985             double dTotalAreaOverlap     = dTotalAreaOverlap_loc;
00986 #ifdef MOAB_HAVE_MPI
00987             if( m_pcomm )
00988                 MPI_Reduce( &dTotalAreaOverlap_loc, &dTotalAreaOverlap, 1, MPI_DOUBLE, MPI_SUM, 0, m_pcomm->comm() );
00989 #endif
00990             if( is_root ) dbgprint.printf( 0, "Overlap Mesh Area: %1.15e\n", dTotalAreaOverlap );
00991
00992             // Correct areas to match the areas calculated in the overlap mesh
00993             // if (fCorrectAreas) // In MOAB-TempestRemap, we will always keep this to be true
00994             {
00995                 if( is_root ) dbgprint.printf( 0, "Correcting source/target areas to overlap mesh areas\n" );
00996                 DataArray1D< double > dSourceArea( m_meshInputCov->faces.size() );
00997                 DataArray1D< double > dTargetArea( m_meshOutput->faces.size() );
00998
00999                 assert( m_meshOverlap->vecSourceFaceIx.size() == m_meshOverlap->faces.size() );
01000                 assert( m_meshOverlap->vecTargetFaceIx.size() == m_meshOverlap->faces.size() );
01001                 assert( m_meshOverlap->vecFaceArea.GetRows() == m_meshOverlap->faces.size() );
01002
01003                 assert( m_meshInputCov->vecFaceArea.GetRows() == m_meshInputCov->faces.size() );
01004                 assert( m_meshOutput->vecFaceArea.GetRows() == m_meshOutput->faces.size() );
01005
01006                 for( size_t i = 0; i < m_meshOverlap->faces.size(); i++ )
01007                 {
01008                     if( m_meshOverlap->vecSourceFaceIx[i] < 0 || m_meshOverlap->vecTargetFaceIx[i] < 0 )
01009                         continue;  // skip this cell since it is ghosted
01010
01011                     // let us recompute the source/target areas based on overlap mesh areas
01012                     assert( static_cast< size_t >( m_meshOverlap->vecSourceFaceIx[i] ) < m_meshInputCov->faces.size() );
01013                     dSourceArea[m_meshOverlap->vecSourceFaceIx[i]] += m_meshOverlap->vecFaceArea[i];
01014                     assert( static_cast< size_t >( m_meshOverlap->vecTargetFaceIx[i] ) < m_meshOutput->faces.size() );
01015                     dTargetArea[m_meshOverlap->vecTargetFaceIx[i]] += m_meshOverlap->vecFaceArea[i];
01016                 }
01017
01018                 for( size_t i = 0; i < m_meshInputCov->faces.size(); i++ )
01019                 {
01020                     if( fabs( dSourceArea[i] - m_meshInputCov->vecFaceArea[i] ) < 1.0e-10 )
01021                     {
01022                         m_meshInputCov->vecFaceArea[i] = dSourceArea[i];
01023                     }
01024                 }
01025                 for( size_t i = 0; i < m_meshOutput->faces.size(); i++ )
01026                 {
01027                     if( fabs( dTargetArea[i] - m_meshOutput->vecFaceArea[i] ) < 1.0e-10 )
01028                     {
01029                         m_meshOutput->vecFaceArea[i] = dTargetArea[i];
01030                     }
01031                 }
01032             }
01033
01034             // Set source mesh areas in map
01035             if( !m_bPointCloudSource && eInputType == DiscretizationType_FV )
01036             {
01037                 this->SetSourceAreas( m_meshInputCov->vecFaceArea );
01038                 if( m_meshInputCov->vecMask.size() )
01039                 {
01040                     this->SetSourceMask( m_meshInputCov->vecMask );
01041                 }
01042             }
01043
01044             // Set target mesh areas in map
01045             if( !m_bPointCloudTarget && eOutputType == DiscretizationType_FV )
01046             {
01047                 this->SetTargetAreas( m_meshOutput->vecFaceArea );
01048                 if( m_meshOutput->vecMask.size() )
01049                 {
01050                     this->SetTargetMask( m_meshOutput->vecMask );
01051                 }
01052             }
01053
01054             /*
01055                 // Recalculate input mesh area from overlap mesh
01056                 if (fabs(dTotalAreaOverlap - dTotalAreaInput) > 1.0e-10) {
01057                     dbgprint.printf(0, "Overlap mesh only covers a sub-area of the sphere\n");
01058                     dbgprint.printf(0, "Recalculating source mesh areas\n");
01059                     dTotalAreaInput = m_meshInput->CalculateFaceAreasFromOverlap(m_meshOverlap);
01060                     dbgprint.printf(0, "New Input Mesh Geometric Area: %1.15e\n", dTotalAreaInput);
01061                 }
01062             */
01063         }
01064
01065         // Finite volume input / Finite volume output
01066         if( ( eInputType == DiscretizationType_FV ) && ( eOutputType == DiscretizationType_FV ) )
01067         {
01068             // Generate reverse node array and edge map
01069             if( m_meshInputCov->revnodearray.size() == 0 ) m_meshInputCov->ConstructReverseNodeArray();
01070             if( m_meshInputCov->edgemap.size() == 0 ) m_meshInputCov->ConstructEdgeMap( false );
01071
01072             // Initialize coordinates for map
01073             this->InitializeSourceCoordinatesFromMeshFV( *m_meshInputCov );
01074             this->InitializeTargetCoordinatesFromMeshFV( *m_meshOutput );
01075
01076             // Finite volume input / Finite element output
01077             rval = this->SetDOFmapAssociation( eInputType, false, NULL, NULL, eOutputType, false, NULL );MB_CHK_ERR( rval );
01078
01079             // Construct remap for FV-FV
01080             if( is_root ) dbgprint.printf( 0, "Calculating remap weights\n" );
01081
01082             // Construct OfflineMap
01083             if( strMapAlgorithm == "invdist" )
01084             {
01085                 if( is_root ) AnnounceStartBlock( "Calculating map (invdist)" );
01086                 LinearRemapFVtoFVInvDist( *m_meshInputCov, *m_meshOutput, *m_meshOverlap, *this );
01087             }
01088             else if( strMapAlgorithm == "delaunay" )
01089             {
01090                 if( is_root ) AnnounceStartBlock( "Calculating map (delaunay)" );
01091                 LinearRemapTriangulation( *m_meshInputCov, *m_meshOutput, *m_meshOverlap, *this );
01092             }
01093             else if( strMapAlgorithm == "fvintbilin" )
01094             {
01095                 if( is_root ) AnnounceStartBlock( "Calculating map (intbilin)" );
01096                 LinearRemapIntegratedBilinear( *m_meshInputCov, *m_meshOutput, *m_meshOverlap, *this );
01097             }
01098             else if( strMapAlgorithm == "fvintbilingb" )
01099             {
01100                 if( is_root ) AnnounceStartBlock( "Calculating map (intbilingb)" );
01101                 LinearRemapIntegratedGeneralizedBarycentric( *m_meshInputCov, *m_meshOutput, *m_meshOverlap, *this );
01102             }
01103             else if( strMapAlgorithm == "fvbilin" )
01104             {
01105                 if( is_root ) AnnounceStartBlock( "Calculating map (bilin)" );
01106                 LinearRemapBilinear( *m_meshInputCov, *m_meshOutput, *m_meshOverlap, *this );
01107             }
01108             else
01109             {
01110                 if( is_root ) AnnounceStartBlock( "Calculating map (default)" );
01111                 // LinearRemapFVtoFV( *m_meshInputCov, *m_meshOutput, *m_meshOverlap,
01112                 //                   ( mapOptions.fMonotone ) ? ( 1 ) : ( mapOptions.nPin ), *this );
01113                 LinearRemapFVtoFV_Tempest_MOAB( ( mapOptions.fMonotone ? 1 : mapOptions.nPin ) );
01114             }
01115         }
01116         else if( eInputType == DiscretizationType_FV )
01117         {
01118             DataArray3D< double > dataGLLJacobian;
01119
01120             if( is_root ) dbgprint.printf( 0, "Generating output mesh meta data\n" );
01121             double dNumericalArea_loc = GenerateMetaData( *m_meshOutput, mapOptions.nPout, mapOptions.fNoBubble,
01122                                                           dataGLLNodesDest, dataGLLJacobian );
01123
01124             double dNumericalArea = dNumericalArea_loc;
01125 #ifdef MOAB_HAVE_MPI
01126             if( m_pcomm )
01127                 MPI_Reduce( &dNumericalArea_loc, &dNumericalArea, 1, MPI_DOUBLE, MPI_SUM, 0, m_pcomm->comm() );
01128 #endif
01129             if( is_root ) dbgprint.printf( 0, "Output Mesh Numerical Area: %1.15e\n", dNumericalArea );
01130
01131             // Initialize coordinates for map
01132             this->InitializeSourceCoordinatesFromMeshFV( *m_meshInputCov );
01133             this->InitializeTargetCoordinatesFromMeshFE( *m_meshOutput, mapOptions.nPout, dataGLLNodesDest );
01134
01135             // Generate the continuous Jacobian
01136             bool fContinuous = ( eOutputType == DiscretizationType_CGLL );
01137
01138             if( eOutputType == DiscretizationType_CGLL )
01139             {
01140                 GenerateUniqueJacobian( dataGLLNodesDest, dataGLLJacobian, this->GetTargetAreas() );
01141             }
01142             else
01143             {
01144                 GenerateDiscontinuousJacobian( dataGLLJacobian, this->GetTargetAreas() );
01145             }
01146
01147             // Generate reverse node array and edge map
01148             if( m_meshInputCov->revnodearray.size() == 0 ) m_meshInputCov->ConstructReverseNodeArray();
01149             if( m_meshInputCov->edgemap.size() == 0 ) m_meshInputCov->ConstructEdgeMap( false );
01150
01151             // Finite volume input / Finite element output
01152             rval = this->SetDOFmapAssociation( eInputType, false, NULL, NULL, eOutputType,
01153                                                ( eOutputType == DiscretizationType_CGLL ), &dataGLLNodesDest );MB_CHK_ERR( rval );
01154
01155             // Generate remap weights
01156             if( strMapAlgorithm == "volumetric" )
01157             {
01158                 if( is_root ) dbgprint.printf( 0, "Calculating remapping weights for FV->GLL (volumetric)\n" );
01159                 LinearRemapFVtoGLL_Volumetric( *m_meshInputCov, *m_meshOutput, *m_meshOverlap, dataGLLNodesDest,
01160                                                dataGLLJacobian, this->GetTargetAreas(), mapOptions.nPin, *this,
01161                                                nMonotoneType, fContinuous, mapOptions.fNoConservation );
01162             }
01163             else
01164             {
01165                 if( is_root ) dbgprint.printf( 0, "Calculating remapping weights for FV->GLL\n" );
01166                 LinearRemapFVtoGLL( *m_meshInputCov, *m_meshOutput, *m_meshOverlap, dataGLLNodesDest, dataGLLJacobian,
01167                                     this->GetTargetAreas(), mapOptions.nPin, *this, nMonotoneType, fContinuous,
01168                                     mapOptions.fNoConservation );
01169             }
01170         }
01171         else if( ( eInputType == DiscretizationType_PCLOUD ) || ( eOutputType == DiscretizationType_PCLOUD ) )
01172         {
01173             DataArray3D< double > dataGLLJacobian;
01174             if( !m_bPointCloudSource )
01175             {
01176                 // Generate reverse node array and edge map
01177                 if( m_meshInputCov->revnodearray.size() == 0 ) m_meshInputCov->ConstructReverseNodeArray();
01178                 if( m_meshInputCov->edgemap.size() == 0 ) m_meshInputCov->ConstructEdgeMap( false );
01179
01180                 // Initialize coordinates for map
01181                 if( eInputType == DiscretizationType_FV )
01182                 {
01183                     this->InitializeSourceCoordinatesFromMeshFV( *m_meshInputCov );
01184                 }
01185                 else
01186                 {
01187                     if( is_root ) dbgprint.printf( 0, "Generating input mesh meta data\n" );
01188                     DataArray3D< double > dataGLLJacobianSrc;
01189                     GenerateMetaData( *m_meshInputCov, mapOptions.nPin, mapOptions.fNoBubble, dataGLLNodesSrcCov,
01190                                       dataGLLJacobian );
01191                     GenerateMetaData( *m_meshInput, mapOptions.nPin, mapOptions.fNoBubble, dataGLLNodesSrc,
01192                                       dataGLLJacobianSrc );
01193                 }
01194             }
01195             // else { /* Source is a point cloud dataset */ }
01196
01197             if( !m_bPointCloudTarget )
01198             {
01199                 // Generate reverse node array and edge map
01200                 if( m_meshOutput->revnodearray.size() == 0 ) m_meshOutput->ConstructReverseNodeArray();
01201                 if( m_meshOutput->edgemap.size() == 0 ) m_meshOutput->ConstructEdgeMap( false );
01202
01203                 // Initialize coordinates for map
01204                 if( eOutputType == DiscretizationType_FV )
01205                 {
01206                     this->InitializeSourceCoordinatesFromMeshFV( *m_meshOutput );
01207                 }
01208                 else
01209                 {
01210                     if( is_root ) dbgprint.printf( 0, "Generating output mesh meta data\n" );
01211                     GenerateMetaData( *m_meshOutput, mapOptions.nPout, mapOptions.fNoBubble, dataGLLNodesDest,
01212                                       dataGLLJacobian );
01213                 }
01214             }
01215             // else { /* Target is a point cloud dataset */ }
01216
01217             // Finite volume input / Finite element output
01218             rval = this->SetDOFmapAssociation(
01219                 eInputType, ( eInputType == DiscretizationType_CGLL ),
01220                 ( m_bPointCloudSource || eInputType == DiscretizationType_FV ? NULL : &dataGLLNodesSrcCov ),
01221                 ( m_bPointCloudSource || eInputType == DiscretizationType_FV ? NULL : &dataGLLNodesSrc ), eOutputType,
01222                 ( eOutputType == DiscretizationType_CGLL ), ( m_bPointCloudTarget ? NULL : &dataGLLNodesDest ) );MB_CHK_ERR( rval );
01223
01224             // Construct remap
01225             if( is_root ) dbgprint.printf( 0, "Calculating remap weights with Nearest-Neighbor method\n" );
01226             rval = LinearRemapNN_MOAB( true /*use_GID_matching*/, false /*strict_check*/ );MB_CHK_ERR( rval );
01227         }
01228         else if( ( eInputType != DiscretizationType_FV ) && ( eOutputType == DiscretizationType_FV ) )
01229         {
01230             DataArray3D< double > dataGLLJacobianSrc, dataGLLJacobian;
01231
01232             if( is_root ) dbgprint.printf( 0, "Generating input mesh meta data\n" );
01233             // double dNumericalAreaCov_loc =
01234             GenerateMetaData( *m_meshInputCov, mapOptions.nPin, mapOptions.fNoBubble, dataGLLNodesSrcCov,
01235                               dataGLLJacobian );
01236
01237             double dNumericalArea_loc = GenerateMetaData( *m_meshInput, mapOptions.nPin, mapOptions.fNoBubble,
01238                                                           dataGLLNodesSrc, dataGLLJacobianSrc );
01239
01240             // if ( is_root ) dbgprint.printf ( 0, "Input Mesh: Coverage Area: %1.15e, Output Area:
01241             // %1.15e\n", dNumericalAreaCov_loc, dTotalAreaOutput_loc );
01242             // assert(dNumericalAreaCov_loc >= dTotalAreaOutput_loc);
01243
01244             double dNumericalArea = dNumericalArea_loc;
01245 #ifdef MOAB_HAVE_MPI
01246             if( m_pcomm )
01247                 MPI_Reduce( &dNumericalArea_loc, &dNumericalArea, 1, MPI_DOUBLE, MPI_SUM, 0, m_pcomm->comm() );
01248 #endif
01249             if( is_root )
01250             {
01251                 dbgprint.printf( 0, "Input Mesh Numerical Area: %1.15e\n", dNumericalArea );
01252
01253                 if( fabs( dNumericalArea - dTotalAreaInput ) > 1.0e-12 )
01254                 {
01255                     dbgprint.printf( 0, "WARNING: Significant mismatch between input mesh "
01256                                         "numerical area and geometric area\n" );
01257                 }
01258             }
01259
01260             if( dataGLLNodesSrcCov.GetSubColumns() != m_meshInputCov->faces.size() )
01261             {
01262                 _EXCEPTIONT( "Number of element does not match between metadata and "
01263                              "input mesh" );
01264             }
01265
01266             // Initialize coordinates for map
01267             this->InitializeSourceCoordinatesFromMeshFE( *m_meshInputCov, mapOptions.nPin, dataGLLNodesSrcCov );
01268             this->InitializeTargetCoordinatesFromMeshFV( *m_meshOutput );
01269
01270             // Generate the continuous Jacobian for input mesh
01271             bool fContinuousIn = ( eInputType == DiscretizationType_CGLL );
01272
01273             if( eInputType == DiscretizationType_CGLL )
01274             {
01275                 GenerateUniqueJacobian( dataGLLNodesSrcCov, dataGLLJacobian, this->GetSourceAreas() );
01276             }
01277             else
01278             {
01279                 GenerateDiscontinuousJacobian( dataGLLJacobian, this->GetSourceAreas() );
01280             }
01281
01282             // Finite element input / Finite volume output
01283             rval = this->SetDOFmapAssociation( eInputType, ( eInputType == DiscretizationType_CGLL ),
01284                                                &dataGLLNodesSrcCov, &dataGLLNodesSrc, eOutputType, false, NULL );MB_CHK_ERR( rval );
01285
01286             // Generate remap
01287             if( is_root ) dbgprint.printf( 0, "Calculating remap weights\n" );
01288
01289             if( strMapAlgorithm == "volumetric" )
01290             {
01291                 _EXCEPTIONT( "Unimplemented: Volumetric currently unavailable for"
01292                              "GLL input mesh" );
01293             }
01294
01295             LinearRemapSE4_Tempest_MOAB( dataGLLNodesSrcCov, dataGLLJacobian, nMonotoneType, fContinuousIn,
01296                                          mapOptions.fNoConservation );
01297         }
01298         else if( ( eInputType != DiscretizationType_FV ) && ( eOutputType != DiscretizationType_FV ) )
01299         {
01300             DataArray3D< double > dataGLLJacobianIn, dataGLLJacobianSrc;
01301             DataArray3D< double > dataGLLJacobianOut;
01302
01303             // Input metadata
01304             if( is_root ) dbgprint.printf( 0, "Generating input mesh meta data\n" );
01305             GenerateMetaData( *m_meshInputCov, mapOptions.nPin, mapOptions.fNoBubble, dataGLLNodesSrcCov,
01306                               dataGLLJacobianIn );
01307
01308             double dNumericalAreaSrc_loc = GenerateMetaData( *m_meshInput, mapOptions.nPin, mapOptions.fNoBubble,
01309                                                              dataGLLNodesSrc, dataGLLJacobianSrc );
01310             double dNumericalAreaIn      = dNumericalAreaSrc_loc;
01311 #ifdef MOAB_HAVE_MPI
01312             if( m_pcomm )
01313                 MPI_Reduce( &dNumericalAreaSrc_loc, &dNumericalAreaIn, 1, MPI_DOUBLE, MPI_SUM, 0, m_pcomm->comm() );
01314 #endif
01315             if( is_root )
01316             {
01317                 dbgprint.printf( 0, "Input Mesh Numerical Area: %1.15e\n", dNumericalAreaIn );
01318
01319                 if( fabs( dNumericalAreaIn - dTotalAreaInput ) > 1.0e-12 )
01320                 {
01321                     dbgprint.printf( 0, "WARNING: Significant mismatch between input mesh "
01322                                         "numerical area and geometric area\n" );
01323                 }
01324             }
01325
01326             // Output metadata
01327             if( is_root ) dbgprint.printf( 0, "Generating output mesh meta data\n" );
01328             double dNumericalAreaOut_loc = GenerateMetaData( *m_meshOutput, mapOptions.nPout, mapOptions.fNoBubble,
01329                                                              dataGLLNodesDest, dataGLLJacobianOut );
01330             double dNumericalAreaOut     = dNumericalAreaOut_loc;
01331 #ifdef MOAB_HAVE_MPI
01332             if( m_pcomm )
01333                 MPI_Reduce( &dNumericalAreaOut_loc, &dNumericalAreaOut, 1, MPI_DOUBLE, MPI_SUM, 0, m_pcomm->comm() );
01334 #endif
01335             if( is_root )
01336             {
01337                 dbgprint.printf( 0, "Output Mesh Numerical Area: %1.15e\n", dNumericalAreaOut );
01338
01339                 if( fabs( dNumericalAreaOut - dTotalAreaOutput ) > 1.0e-12 )
01340                 {
01341                     if( is_root )
01342                         dbgprint.printf( 0, "WARNING: Significant mismatch between output mesh "
01343                                             "numerical area and geometric area\n" );
01344                 }
01345             }
01346
01347             // Initialize coordinates for map
01348             this->InitializeSourceCoordinatesFromMeshFE( *m_meshInputCov, mapOptions.nPin, dataGLLNodesSrcCov );
01349             this->InitializeTargetCoordinatesFromMeshFE( *m_meshOutput, mapOptions.nPout, dataGLLNodesDest );
01350
01351             // Generate the continuous Jacobian for input mesh
01352             bool fContinuousIn = ( eInputType == DiscretizationType_CGLL );
01353
01354             if( eInputType == DiscretizationType_CGLL )
01355             {
01356                 GenerateUniqueJacobian( dataGLLNodesSrcCov, dataGLLJacobianIn, this->GetSourceAreas() );
01357             }
01358             else
01359             {
01360                 GenerateDiscontinuousJacobian( dataGLLJacobianIn, this->GetSourceAreas() );
01361             }
01362
01363             // Generate the continuous Jacobian for output mesh
01364             bool fContinuousOut = ( eOutputType == DiscretizationType_CGLL );
01365
01366             if( eOutputType == DiscretizationType_CGLL )
01367             {
01368                 GenerateUniqueJacobian( dataGLLNodesDest, dataGLLJacobianOut, this->GetTargetAreas() );
01369             }
01370             else
01371             {
01372                 GenerateDiscontinuousJacobian( dataGLLJacobianOut, this->GetTargetAreas() );
01373             }
01374
01375             // Input Finite Element to Output Finite Element
01376             rval = this->SetDOFmapAssociation( eInputType, ( eInputType == DiscretizationType_CGLL ),
01377                                                &dataGLLNodesSrcCov, &dataGLLNodesSrc, eOutputType,
01378                                                ( eOutputType == DiscretizationType_CGLL ), &dataGLLNodesDest );MB_CHK_ERR( rval );
01379
01380             // Generate remap
01381             if( is_root ) dbgprint.printf( 0, "Calculating remap weights\n" );
01382
01383             LinearRemapGLLtoGLL2_MOAB( dataGLLNodesSrcCov, dataGLLJacobianIn, dataGLLNodesDest, dataGLLJacobianOut,
01384                                        this->GetTargetAreas(), mapOptions.nPin, mapOptions.nPout, nMonotoneType,
01385                                        fContinuousIn, fContinuousOut, mapOptions.fNoConservation );
01386         }
01387         else
01388         {
01389             _EXCEPTIONT( "Not implemented" );
01390         }
01391
01392 #ifdef MOAB_HAVE_EIGEN3
01393         copy_tempest_sparsemat_to_eigen3();
01394 #endif
01395
01396 #ifdef MOAB_HAVE_MPI
01397         {
01398             // Remove ghosted entities from overlap set
01399             moab::Range ghostedEnts;
01400             rval = m_remapper->GetOverlapAugmentedEntities( ghostedEnts );MB_CHK_ERR( rval );
01401             moab::EntityHandle m_meshOverlapSet = m_remapper->GetMeshSet( moab::Remapper::OverlapMesh );
01402             rval                                = m_interface->remove_entities( m_meshOverlapSet, ghostedEnts );MB_CHK_SET_ERR( rval, "Deleting ghosted entities failed" );
01403         }
01404 #endif
01405         // Verify consistency, conservation and monotonicity, globally
01406         if( !mapOptions.fNoCheck )
01407         {
01408             if( is_root ) dbgprint.printf( 0, "Verifying map" );
01409             this->IsConsistent( 1.0e-8 );
01410             if( !mapOptions.fNoConservation ) this->IsConservative( 1.0e-8 );
01411
01412             if( nMonotoneType != 0 )
01413             {
01414                 this->IsMonotone( 1.0e-12 );
01415             }
01416         }
01417     }
01418     catch( Exception& e )
01419     {
01420         dbgprint.printf( 0, "%s", e.ToString().c_str() );
01421         return ( moab::MB_FAILURE );
01422     }
01423     catch( ... )
01424     {
01425         return ( moab::MB_FAILURE );
01426     }
01427     return moab::MB_SUCCESS;
01428 }
01429
01430 ///////////////////////////////////////////////////////////////////////////////
01431
01432 int moab::TempestOnlineMap::IsConsistent( double dTolerance )
01433 {
01434 #ifndef MOAB_HAVE_MPI
01435
01436     return OfflineMap::IsConsistent( dTolerance );
01437
01438 #else
01439
01440     // Get map entries
01441     DataArray1D< int > dataRows;
01442     DataArray1D< int > dataCols;
01443     DataArray1D< double > dataEntries;
01444
01445     // Calculate row sums
01446     DataArray1D< double > dRowSums;
01447     m_mapRemap.GetEntries( dataRows, dataCols, dataEntries );
01448     dRowSums.Allocate( m_mapRemap.GetRows() );
01449
01450     for( unsigned i = 0; i < dataRows.GetRows(); i++ )
01451     {
01452         dRowSums[dataRows[i]] += dataEntries[i];
01453     }
01454
01455     // Verify all row sums are equal to 1
01456     int fConsistent = 0;
01457     for( unsigned i = 0; i < dRowSums.GetRows(); i++ )
01458     {
01459         if( fabs( dRowSums[i] - 1.0 ) > dTolerance )
01460         {
01461             fConsistent++;
01462             int rowGID = row_gdofmap[i];
01463             Announce( "TempestOnlineMap is not consistent in row %i (%1.15e)", rowGID, dRowSums[i] );
01464         }
01465     }
01466
01467     int ierr;
01468     int fConsistentGlobal = 0;
01469     ierr = MPI_Allreduce( &fConsistent, &fConsistentGlobal, 1, MPI_INT, MPI_SUM, m_pcomm->comm() );
01470     if( ierr != MPI_SUCCESS ) return -1;
01471
01472     return fConsistentGlobal;
01473 #endif
01474 }
01475
01476 ///////////////////////////////////////////////////////////////////////////////
01477
01478 int moab::TempestOnlineMap::IsConservative( double dTolerance )
01479 {
01480 #ifndef MOAB_HAVE_MPI
01481
01482     return OfflineMap::IsConservative( dTolerance );
01483
01484 #else
01485     // return OfflineMap::IsConservative(dTolerance);
01486
01487     int ierr;
01488     // Get map entries
01489     DataArray1D< int > dataRows;
01490     DataArray1D< int > dataCols;
01491     DataArray1D< double > dataEntries;
01492     const DataArray1D< double >& dTargetAreas = this->GetTargetAreas();
01493     const DataArray1D< double >& dSourceAreas = this->GetSourceAreas();
01494
01495     // Calculate column sums
01496     std::vector< int > dColumnsUnique;
01497     std::vector< double > dColumnSums;
01498
01499     int nColumns = m_mapRemap.GetColumns();
01500     m_mapRemap.GetEntries( dataRows, dataCols, dataEntries );
01501     dColumnSums.resize( m_nTotDofs_SrcCov, 0.0 );
01502     dColumnsUnique.resize( m_nTotDofs_SrcCov, -1 );
01503
01504     for( unsigned i = 0; i < dataEntries.GetRows(); i++ )
01505     {
01506         dColumnSums[dataCols[i]] += dataEntries[i] * dTargetAreas[dataRows[i]] / dSourceAreas[dataCols[i]];
01507
01508         assert( dataCols[i] < m_nTotDofs_SrcCov );
01509
01510         // GID for column DoFs: col_gdofmap[ col_ldofmap [ dataCols[i] ] ]
01511         int colGID = this->GetColGlobalDoF( dataCols[i] );  // col_gdofmap[ col_ldofmap [ dataCols[i] ] ];
01512         // int colGID = col_gdofmap[ col_ldofmap [ dataCols[i] ] ];
01513         dColumnsUnique[dataCols[i]] = colGID;
01514
01515         // std::cout << "Column dataCols[i]=" << dataCols[i] << " with GID = " << colGID <<
01516         // std::endl;
01517     }
01518
01519     int rootProc = 0;
01520     std::vector< int > nElementsInProc;
01521     const int nDATA = 3;
01522     if( !rank ) nElementsInProc.resize( size * nDATA );
01523     int senddata[nDATA] = {nColumns, m_nTotDofs_SrcCov, m_nTotDofs_Src};
01524     ierr = MPI_Gather( senddata, nDATA, MPI_INT, nElementsInProc.data(), nDATA, MPI_INT, rootProc, m_pcomm->comm() );
01525     if( ierr != MPI_SUCCESS ) return -1;
01526
01527     int nTotVals = 0, nTotColumns = 0, nTotColumnsUnq = 0;
01528     std::vector< int > dColumnIndices;
01529     std::vector< double > dColumnSourceAreas;
01530     std::vector< double > dColumnSumsTotal;
01531     std::vector< int > displs, rcount;
01532     if( rank == rootProc )
01533     {
01534         displs.resize( size + 1, 0 );
01535         rcount.resize( size, 0 );
01536         int gsum = 0;
01537         for( int ir = 0; ir < size; ++ir )
01538         {
01539             nTotVals += nElementsInProc[ir * nDATA];
01540             nTotColumns += nElementsInProc[ir * nDATA + 1];
01541             nTotColumnsUnq += nElementsInProc[ir * nDATA + 2];
01542
01543             displs[ir] = gsum;
01544             rcount[ir] = nElementsInProc[ir * nDATA + 1];
01545             gsum += rcount[ir];
01546
01547             // printf("%d: nTotColumns: %d, Displs: %d, rcount: %d, gsum = %d\n", ir, nTotColumns,
01548             // displs[ir], rcount[ir], gsum);
01549         }
01550
01551         dColumnIndices.resize( nTotColumns, -1 );
01552         dColumnSumsTotal.resize( nTotColumns, 0.0 );
01553         // dColumnSourceAreas.resize ( nTotColumns, 0.0 );
01554     }
01555
01556     // Gather all ColumnSums to root process and accumulate
01557     // We expect that the sums of all columns equate to 1.0 within user specified tolerance
01558     // Need to do a gatherv here since different processes have different number of elements
01559     // MPI_Reduce(&dColumnSums[0], &dColumnSumsTotal[0], m_mapRemap.GetColumns(), MPI_DOUBLE,
01560     // MPI_SUM, 0, m_pcomm->comm());
01561     ierr = MPI_Gatherv( &dColumnsUnique[0], m_nTotDofs_SrcCov, MPI_INT, &dColumnIndices[0], rcount.data(),
01562                         displs.data(), MPI_INT, rootProc, m_pcomm->comm() );
01563     if( ierr != MPI_SUCCESS ) return -1;
01564     ierr = MPI_Gatherv( &dColumnSums[0], m_nTotDofs_SrcCov, MPI_DOUBLE, &dColumnSumsTotal[0], rcount.data(),
01565                         displs.data(), MPI_DOUBLE, rootProc, m_pcomm->comm() );
01566     if( ierr != MPI_SUCCESS ) return -1;
01567     // ierr = MPI_Gatherv ( &dSourceAreas[0], m_nTotDofs_SrcCov, MPI_DOUBLE, &dColumnSourceAreas[0],
01568     // rcount.data(), displs.data(), MPI_DOUBLE, rootProc, m_pcomm->comm() ); if ( ierr !=
01569     // MPI_SUCCESS ) return -1;
01570
01571     // Clean out unwanted arrays now
01572     dColumnSums.clear();
01573     dColumnsUnique.clear();
01574
01575     // Verify all column sums equal the input Jacobian
01576     int fConservative = 0;
01577     if( rank == rootProc )
01578     {
01579         displs[size] = ( nTotColumns );
01580         // std::vector<double> dColumnSumsOnRoot(nTotColumnsUnq, 0.0);
01581         std::map< int, double > dColumnSumsOnRoot;
01582         // std::map<int, double> dColumnSourceAreasOnRoot;
01583         for( int ir = 0; ir < size; ir++ )
01584         {
01585             for( int ips = displs[ir]; ips < displs[ir + 1]; ips++ )
01586             {
01587                 if( dColumnIndices[ips] < 0 ) continue;
01588                 // printf("%d, %d: dColumnIndices[ips]: %d\n", ir, ips, dColumnIndices[ips]);
01589                 assert( dColumnIndices[ips] < nTotColumnsUnq );
01590                 dColumnSumsOnRoot[dColumnIndices[ips]] += dColumnSumsTotal[ips];  // / dColumnSourceAreas[ips];
01591                 // dColumnSourceAreasOnRoot[ dColumnIndices[ips] ] = dColumnSourceAreas[ips];
01592                 // dColumnSourceAreas[ dColumnIndices[ips] ]
01593             }
01594         }
01595
01596         for( std::map< int, double >::iterator it = dColumnSumsOnRoot.begin(); it != dColumnSumsOnRoot.end(); ++it )
01597         {
01598             // if ( fabs ( it->second - dColumnSourceAreasOnRoot[it->first] ) > dTolerance )
01599             if( fabs( it->second - 1.0 ) > dTolerance )
01600             {
01601                 fConservative++;
01602                 Announce( "TempestOnlineMap is not conservative in column "
01603                           // "%i (%1.15e)", it->first, it->second );
01604                           "%i (%1.15e)",
01605                           it->first, it->second /* / dColumnSourceAreasOnRoot[it->first] */ );
01606             }
01607         }
01608     }
01609
01610     // TODO: Just do a broadcast from root instead of a reduction
01611     ierr = MPI_Bcast( &fConservative, 1, MPI_INT, rootProc, m_pcomm->comm() );
01612     if( ierr != MPI_SUCCESS ) return -1;
01613
01614     return fConservative;
01615 #endif
01616 }
01617
01618 ///////////////////////////////////////////////////////////////////////////////
01619
01620 int moab::TempestOnlineMap::IsMonotone( double dTolerance )
01621 {
01622 #ifndef MOAB_HAVE_MPI
01623
01624     return OfflineMap::IsMonotone( dTolerance );
01625
01626 #else
01627
01628     // Get map entries
01629     DataArray1D< int > dataRows;
01630     DataArray1D< int > dataCols;
01631     DataArray1D< double > dataEntries;
01632
01633     m_mapRemap.GetEntries( dataRows, dataCols, dataEntries );
01634
01635     // Verify all entries are in the range [0,1]
01636     int fMonotone = 0;
01637     for( unsigned i = 0; i < dataRows.GetRows(); i++ )
01638     {
01639         if( ( dataEntries[i] < -dTolerance ) || ( dataEntries[i] > 1.0 + dTolerance ) )
01640         {
01641             fMonotone++;
01642
01643             Announce( "TempestOnlineMap is not monotone in entry (%i): %1.15e", i, dataEntries[i] );
01644         }
01645     }
01646
01647     int ierr;
01648     int fMonotoneGlobal = 0;
01649     ierr = MPI_Allreduce( &fMonotone, &fMonotoneGlobal, 1, MPI_INT, MPI_SUM, m_pcomm->comm() );
01650     if( ierr != MPI_SUCCESS ) return -1;
01651
01652     return fMonotoneGlobal;
01653 #endif
01654 }
01655
01656 ///////////////////////////////////////////////////////////////////////////////
01657
01658 moab::ErrorCode moab::TempestOnlineMap::ApplyWeights( moab::Tag srcSolutionTag,
01659                                                       moab::Tag tgtSolutionTag,
01660                                                       bool transpose )
01661 {
01662     moab::ErrorCode rval;
01663
01664     std::vector< double > solSTagVals;
01665     std::vector< double > solTTagVals;
01666
01667     moab::Range sents, tents;
01668     if( m_remapper->point_cloud_source || m_remapper->point_cloud_target )
01669     {
01670         if( m_remapper->point_cloud_source )
01671         {
01672             moab::Range& covSrcEnts = m_remapper->GetMeshVertices( moab::Remapper::CoveringMesh );
01673             solSTagVals.resize( covSrcEnts.size(), -1.0 );
01674             sents = covSrcEnts;
01675         }
01676         else
01677         {
01678             moab::Range& covSrcEnts = m_remapper->GetMeshEntities( moab::Remapper::CoveringMesh );
01679             solSTagVals.resize( covSrcEnts.size() * this->GetSourceNDofsPerElement() * this->GetSourceNDofsPerElement(),
01680                                 -1.0 );
01681             sents = covSrcEnts;
01682         }
01683         if( m_remapper->point_cloud_target )
01684         {
01685             moab::Range& tgtEnts = m_remapper->GetMeshVertices( moab::Remapper::TargetMesh );
01686             solTTagVals.resize( tgtEnts.size(), -1.0 );
01687             tents = tgtEnts;
01688         }
01689         else
01690         {
01691             moab::Range& tgtEnts = m_remapper->GetMeshEntities( moab::Remapper::TargetMesh );
01692             solTTagVals.resize(
01693                 tgtEnts.size() * this->GetDestinationNDofsPerElement() * this->GetDestinationNDofsPerElement(), -1.0 );
01694             tents = tgtEnts;
01695         }
01696     }
01697     else
01698     {
01699         moab::Range& covSrcEnts = m_remapper->GetMeshEntities( moab::Remapper::CoveringMesh );
01700         moab::Range& tgtEnts    = m_remapper->GetMeshEntities( moab::Remapper::TargetMesh );
01701         solSTagVals.resize( covSrcEnts.size() * this->GetSourceNDofsPerElement() * this->GetSourceNDofsPerElement(),
01702                             -1.0 );
01703         solTTagVals.resize(
01704             tgtEnts.size() * this->GetDestinationNDofsPerElement() * this->GetDestinationNDofsPerElement(), -1.0 );
01705
01706         sents = covSrcEnts;
01707         tents = tgtEnts;
01708     }
01709
01710     // The tag data is np*np*n_el_src
01711     rval = m_interface->tag_get_data( srcSolutionTag, sents, &solSTagVals[0] );MB_CHK_SET_ERR( rval, "Getting local tag data failed" );
01712
01713     // Compute the application of weights on the suorce solution data and store it in the
01714     // destination solution vector data Optionally, can also perform the transpose application of
01715     // the weight matrix. Set the 3rd argument to true if this is needed
01716     rval = this->ApplyWeights( solSTagVals, solTTagVals, transpose );MB_CHK_SET_ERR( rval, "Applying remap operator onto source vector data failed" );
01717
01718     // The tag data is np*np*n_el_dest
01719     rval = m_interface->tag_set_data( tgtSolutionTag, tents, &solTTagVals[0] );MB_CHK_SET_ERR( rval, "Setting local tag data failed" );
01720
01721     return moab::MB_SUCCESS;
01722 }
01723
01724 moab::ErrorCode moab::TempestOnlineMap::DefineAnalyticalSolution( moab::Tag& solnTag,
01725        const std::string& solnName,
01726        moab::Remapper::IntersectionContext ctx,
01727        sample_function testFunction,
01728        moab::Tag* clonedSolnTag,
01729        std::string cloneSolnName )
01730 {
01731     moab::ErrorCode rval;
01732     const bool outputEnabled = ( is_root );
01733     int discOrder;
01734     DiscretizationType discMethod;
01735     moab::EntityHandle meshset;
01736     moab::Range entities;
01737     Mesh* trmesh;
01738     switch( ctx )
01739     {
01740         case Remapper::SourceMesh:
01741             meshset    = m_remapper->m_covering_source_set;
01742             trmesh     = m_remapper->m_covering_source;
01743             entities   = ( m_remapper->point_cloud_source ? m_remapper->m_covering_source_vertices
01744                                                         : m_remapper->m_covering_source_entities );
01745             discOrder  = m_nDofsPEl_Src;
01746             discMethod = m_eInputType;
01747             break;
01748
01749         case Remapper::TargetMesh:
01750             meshset = m_remapper->m_target_set;
01751             trmesh  = m_remapper->m_target;
01752             entities =
01753                 ( m_remapper->point_cloud_target ? m_remapper->m_target_vertices : m_remapper->m_target_entities );
01754             discOrder  = m_nDofsPEl_Dest;
01755             discMethod = m_eOutputType;
01756             break;
01757
01758         default:
01759             if( outputEnabled )
01760                 std::cout << "Invalid context specified for defining an analytical solution tag" << std::endl;
01761             return moab::MB_FAILURE;
01762     }
01763
01764     // Let us create teh solution tag with appropriate information for name, discretization order
01765     // (DoF space)
01766     rval = m_interface->tag_get_handle( solnName.c_str(), discOrder * discOrder, MB_TYPE_DOUBLE, solnTag,
01767                                         MB_TAG_DENSE | MB_TAG_CREAT );MB_CHK_ERR( rval );
01768     if( clonedSolnTag != NULL )
01769     {
01770         if( cloneSolnName.size() == 0 )
01771         {
01772             cloneSolnName = solnName + std::string( "Cloned" );
01773         }
01774         rval = m_interface->tag_get_handle( cloneSolnName.c_str(), discOrder * discOrder, MB_TYPE_DOUBLE,
01775                                             *clonedSolnTag, MB_TAG_DENSE | MB_TAG_CREAT );MB_CHK_ERR( rval );
01776     }
01777
01778     // Triangular quadrature rule
01779     const int TriQuadratureOrder = 10;
01780
01781     if( outputEnabled ) std::cout << "Using triangular quadrature of order " << TriQuadratureOrder << std::endl;
01782
01783     TriangularQuadratureRule triquadrule( TriQuadratureOrder );
01784
01785     const int TriQuadraturePoints = triquadrule.GetPoints();
01786
01787     const DataArray2D< double >& TriQuadratureG = triquadrule.GetG();
01788     const DataArray1D< double >& TriQuadratureW = triquadrule.GetW();
01789
01790     // Output data
01791     DataArray1D< double > dVar;
01792     DataArray1D< double > dVarMB;  // re-arranged local MOAB vector
01793
01794     // Nodal geometric area
01795     DataArray1D< double > dNodeArea;
01796
01797     // Calculate element areas
01798     // trmesh->CalculateFaceAreas(fContainsConcaveFaces);
01799
01800     if( discMethod == DiscretizationType_CGLL || discMethod == DiscretizationType_DGLL )
01801     {
01802         /* Get the spectral points and sample the functionals accordingly */
01803         const bool fGLL          = true;
01804         const bool fGLLIntegrate = false;
01805
01806         // Generate grid metadata
01807         DataArray3D< int > dataGLLNodes;
01808         DataArray3D< double > dataGLLJacobian;
01809
01810         GenerateMetaData( *trmesh, discOrder, false, dataGLLNodes, dataGLLJacobian );
01811
01812         // Number of elements
01813         int nElements = trmesh->faces.size();
01814
01815         // Verify all elements are quadrilaterals
01816         for( int k = 0; k < nElements; k++ )
01817         {
01818             const Face& face = trmesh->faces[k];
01819
01820             if( face.edges.size() != 4 )
01821             {
01822                 _EXCEPTIONT( "Non-quadrilateral face detected; "
01823                              "incompatible with --gll" );
01824             }
01825         }
01826
01827         // Number of unique nodes
01828         int iMaxNode = 0;
01829         for( int i = 0; i < discOrder; i++ )
01830         {
01831             for( int j = 0; j < discOrder; j++ )
01832             {
01833                 for( int k = 0; k < nElements; k++ )
01834                 {
01835                     if( dataGLLNodes[i][j][k] > iMaxNode )
01836                     {
01837                         iMaxNode = dataGLLNodes[i][j][k];
01838                     }
01839                 }
01840             }
01841         }
01842
01843         // Get Gauss-Lobatto quadrature nodes
01844         DataArray1D< double > dG;
01845         DataArray1D< double > dW;
01846
01847         GaussLobattoQuadrature::GetPoints( discOrder, 0.0, 1.0, dG, dW );
01848
01849         // Get Gauss quadrature nodes
01850         const int nGaussP = 10;
01851
01852         DataArray1D< double > dGaussG;
01853         DataArray1D< double > dGaussW;
01854
01855         GaussQuadrature::GetPoints( nGaussP, 0.0, 1.0, dGaussG, dGaussW );
01856
01857         // Allocate data
01858         dVar.Allocate( iMaxNode );
01859         dVarMB.Allocate( discOrder * discOrder * nElements );
01860         dNodeArea.Allocate( iMaxNode );
01861
01862         // Sample data
01863         for( int k = 0; k < nElements; k++ )
01864         {
01865             const Face& face = trmesh->faces[k];
01866
01867             // Sample data at GLL nodes
01868             if( fGLL )
01869             {
01870                 for( int i = 0; i < discOrder; i++ )
01871                 {
01872                     for( int j = 0; j < discOrder; j++ )
01873                     {
01874
01875                         // Apply local map
01876                         Node node;
01877                         Node dDx1G;
01878                         Node dDx2G;
01879
01880                         ApplyLocalMap( face, trmesh->nodes, dG[i], dG[j], node, dDx1G, dDx2G );
01881
01882                         // Sample data at this point
01883                         double dNodeLon = atan2( node.y, node.x );
01884                         if( dNodeLon < 0.0 )
01885                         {
01886                             dNodeLon += 2.0 * M_PI;
01887                         }
01888                         double dNodeLat = asin( node.z );
01889
01890                         double dSample = ( *testFunction )( dNodeLon, dNodeLat );
01891
01892                         dVar[dataGLLNodes[j][i][k] - 1] = dSample;
01893                     }
01894                 }
01895                 // High-order Gaussian integration over basis function
01896             }
01897             else
01898             {
01899                 DataArray2D< double > dCoeff( discOrder, discOrder );
01900
01901                 for( int p = 0; p < nGaussP; p++ )
01902                 {
01903                     for( int q = 0; q < nGaussP; q++ )
01904                     {
01905
01906                         // Apply local map
01907                         Node node;
01908                         Node dDx1G;
01909                         Node dDx2G;
01910
01911                         ApplyLocalMap( face, trmesh->nodes, dGaussG[p], dGaussG[q], node, dDx1G, dDx2G );
01912
01913                         // Cross product gives local Jacobian
01914                         Node nodeCross = CrossProduct( dDx1G, dDx2G );
01915
01916                         double dJacobian =
01917                             sqrt( nodeCross.x * nodeCross.x + nodeCross.y * nodeCross.y + nodeCross.z * nodeCross.z );
01918
01919                         // Find components of quadrature point in basis
01920                         // of the first Face
01921                         SampleGLLFiniteElement( 0, discOrder, dGaussG[p], dGaussG[q], dCoeff );
01922
01923                         // Sample data at this point
01924                         double dNodeLon = atan2( node.y, node.x );
01925                         if( dNodeLon < 0.0 )
01926                         {
01927                             dNodeLon += 2.0 * M_PI;
01928                         }
01929                         double dNodeLat = asin( node.z );
01930
01931                         double dSample = ( *testFunction )( dNodeLon, dNodeLat );
01932
01933                         // Integrate
01934                         for( int i = 0; i < discOrder; i++ )
01935                         {
01936                             for( int j = 0; j < discOrder; j++ )
01937                             {
01938
01939                                 double dNodalArea = dCoeff[i][j] * dGaussW[p] * dGaussW[q] * dJacobian;
01940
01941                                 dVar[dataGLLNodes[i][j][k] - 1] += dSample * dNodalArea;
01942
01943                                 dNodeArea[dataGLLNodes[i][j][k] - 1] += dNodalArea;
01944                             }
01945                         }
01946                     }
01947                 }
01948             }
01949         }
01950
01951         // Divide by area
01952         if( fGLLIntegrate )
01953         {
01954             for( size_t i = 0; i < dVar.GetRows(); i++ )
01955             {
01956                 dVar[i] /= dNodeArea[i];
01957             }
01958         }
01959
01960         // Let us rearrange the data based on DoF ID specification
01961         if( ctx == Remapper::SourceMesh )
01962         {
01963             for( unsigned j = 0; j < entities.size(); j++ )
01964                 for( int p = 0; p < discOrder; p++ )
01965                     for( int q = 0; q < discOrder; q++ )
01966                     {
01967                         const int offsetDOF = j * discOrder * discOrder + p * discOrder + q;
01968                         dVarMB[offsetDOF]   = dVar[col_dtoc_dofmap[offsetDOF]];
01969                     }
01970         }
01971         else
01972         {
01973             for( unsigned j = 0; j < entities.size(); j++ )
01974                 for( int p = 0; p < discOrder; p++ )
01975                     for( int q = 0; q < discOrder; q++ )
01976                     {
01977                         const int offsetDOF = j * discOrder * discOrder + p * discOrder + q;
01978                         dVarMB[offsetDOF]   = dVar[row_dtoc_dofmap[offsetDOF]];
01979                     }
01980         }
01981
01982         // Set the tag data
01983         rval = m_interface->tag_set_data( solnTag, entities, &dVarMB[0] );MB_CHK_ERR( rval );
01984     }
01985     else
01986     {
01987         // assert( discOrder == 1 );
01988         if( discMethod == DiscretizationType_FV )
01989         {
01990             /* Compute an element-wise integral to store the sampled solution based on Quadrature
01991              * rules */
01992             // Resize the array
01993             dVar.Allocate( trmesh->faces.size() );
01994
01995             std::vector< Node >& nodes = trmesh->nodes;
01996
01997             // Loop through all Faces
01998             for( size_t i = 0; i < trmesh->faces.size(); i++ )
01999             {
02000                 const Face& face = trmesh->faces[i];
02001
02002                 // Loop through all sub-triangles
02003                 for( size_t j = 0; j < face.edges.size() - 2; j++ )
02004                 {
02005
02006                     const Node& node0 = nodes[face[0]];
02007                     const Node& node1 = nodes[face[j + 1]];
02008                     const Node& node2 = nodes[face[j + 2]];
02009
02010                     // Triangle area
02011                     Face faceTri( 3 );
02012                     faceTri.SetNode( 0, face[0] );
02013                     faceTri.SetNode( 1, face[j + 1] );
02014                     faceTri.SetNode( 2, face[j + 2] );
02015
02016                     double dTriangleArea = CalculateFaceArea( faceTri, nodes );
02017
02018                     // Calculate the element average
02019                     double dTotalSample = 0.0;
02020
02021                     // Loop through all quadrature points
02022                     for( int k = 0; k < TriQuadraturePoints; k++ )
02023                     {
02024                         Node node( TriQuadratureG[k][0] * node0.x + TriQuadratureG[k][1] * node1.x +
02025                                        TriQuadratureG[k][2] * node2.x,
02026                                    TriQuadratureG[k][0] * node0.y + TriQuadratureG[k][1] * node1.y +
02027                                        TriQuadratureG[k][2] * node2.y,
02028                                    TriQuadratureG[k][0] * node0.z + TriQuadratureG[k][1] * node1.z +
02029                                        TriQuadratureG[k][2] * node2.z );
02030
02031                         double dMagnitude = node.Magnitude();
02032                         node.x /= dMagnitude;
02033                         node.y /= dMagnitude;
02034                         node.z /= dMagnitude;
02035
02036                         double dLon = atan2( node.y, node.x );
02037                         if( dLon < 0.0 )
02038                         {
02039                             dLon += 2.0 * M_PI;
02040                         }
02041                         double dLat = asin( node.z );
02042
02043                         double dSample = ( *testFunction )( dLon, dLat );
02044
02045                         dTotalSample += dSample * TriQuadratureW[k] * dTriangleArea;
02046                     }
02047
02048                     dVar[i] += dTotalSample / trmesh->vecFaceArea[i];
02049                 }
02050             }
02051             rval = m_interface->tag_set_data( solnTag, entities, &dVar[0] );MB_CHK_ERR( rval );
02052         }
02053         else /* discMethod == DiscretizationType_PCLOUD */
02054         {
02055             /* Get the coordinates of the vertices and sample the functionals accordingly */
02056             std::vector< Node >& nodes = trmesh->nodes;
02057
02058             // Resize the array
02059             dVar.Allocate( nodes.size() );
02060
02061             for( size_t j = 0; j < nodes.size(); j++ )
02062             {
02063                 Node& node        = nodes[j];
02064                 double dMagnitude = node.Magnitude();
02065                 node.x /= dMagnitude;
02066                 node.y /= dMagnitude;
02067                 node.z /= dMagnitude;
02068                 double dLon = atan2( node.y, node.x );
02069                 if( dLon < 0.0 )
02070                 {
02071                     dLon += 2.0 * M_PI;
02072                 }
02073                 double dLat = asin( node.z );
02074
02075                 double dSample = ( *testFunction )( dLon, dLat );
02076                 dVar[j]        = dSample;
02077             }
02078
02079             rval = m_interface->tag_set_data( solnTag, entities, &dVar[0] );MB_CHK_ERR( rval );
02080         }
02081     }
02082
02083     return moab::MB_SUCCESS;
02084 }
02085
02086 moab::ErrorCode moab::TempestOnlineMap::ComputeMetrics( moab::Remapper::IntersectionContext ctx,
02087                                                         moab::Tag& exactTag,
02088                                                         moab::Tag& approxTag,
02089                                                         std::map< std::string, double >& metrics,
02090                                                         bool verbose )
02091 {
02092     moab::ErrorCode rval;
02093     const bool outputEnabled = ( is_root );
02094     int discOrder;
02095     DiscretizationType discMethod;
02096     moab::EntityHandle meshset;
02097     moab::Range entities;
02098     Mesh* trmesh;
02099     switch( ctx )
02100     {
02101         case Remapper::SourceMesh:
02102             meshset    = m_remapper->m_covering_source_set;
02103             trmesh     = m_remapper->m_covering_source;
02104             entities   = ( m_remapper->point_cloud_source ? m_remapper->m_covering_source_vertices
02105                                                         : m_remapper->m_covering_source_entities );
02106             discOrder  = m_nDofsPEl_Src;
02107             discMethod = m_eInputType;
02108             break;
02109
02110         case Remapper::TargetMesh:
02111             meshset = m_remapper->m_target_set;
02112             trmesh  = m_remapper->m_target;
02113             entities =
02114                 ( m_remapper->point_cloud_target ? m_remapper->m_target_vertices : m_remapper->m_target_entities );
02115             discOrder  = m_nDofsPEl_Dest;
02116             discMethod = m_eOutputType;
02117             break;
02118
02119         default:
02120             if( outputEnabled )
02121                 std::cout << "Invalid context specified for defining an analytical solution tag" << std::endl;
02122             return moab::MB_FAILURE;
02123     }
02124
02125     // Let us create teh solution tag with appropriate information for name, discretization order
02126     // (DoF space)
02127     std::string exactTagName, projTagName;
02128     const int ntotsize = entities.size() * discOrder * discOrder;
02129     int ntotsize_glob  = 0;
02130     std::vector< double > exactSolution( ntotsize, 0.0 ), projSolution( ntotsize, 0.0 );
02131     rval = m_interface->tag_get_name( exactTag, exactTagName );MB_CHK_ERR( rval );
02132     rval = m_interface->tag_get_data( exactTag, entities, &exactSolution[0] );MB_CHK_ERR( rval );
02133     rval = m_interface->tag_get_name( approxTag, projTagName );MB_CHK_ERR( rval );
02134     rval = m_interface->tag_get_data( approxTag, entities, &projSolution[0] );MB_CHK_ERR( rval );
02135
02136     std::vector< double > errnorms( 3, 0.0 ), globerrnorms( 3, 0.0 );  //  L1Err, L2Err, LinfErr
02137     for( int i = 0; i < ntotsize; ++i )
02138     {
02139         const double error = fabs( exactSolution[i] - projSolution[i] );
02140         errnorms[0] += error;
02141         errnorms[1] += error * error;
02142         errnorms[2] = ( error > errnorms[2] ? error : errnorms[2] );
02143     }
02144 #ifdef MOAB_HAVE_MPI
02145     if( m_pcomm )
02146     {
02147         MPI_Reduce( &ntotsize, &ntotsize_glob, 1, MPI_INT, MPI_SUM, 0, m_pcomm->comm() );
02148         MPI_Reduce( &errnorms[0], &globerrnorms[0], 2, MPI_DOUBLE, MPI_SUM, 0, m_pcomm->comm() );
02149         MPI_Reduce( &errnorms[2], &globerrnorms[2], 1, MPI_DOUBLE, MPI_MAX, 0, m_pcomm->comm() );
02150     }
02151 #else
02152     ntotsize_glob = ntotsize;
02153     globerrnorms = errnorms;
02154 #endif
02155     globerrnorms[0] = ( globerrnorms[0] / ntotsize_glob );
02156     globerrnorms[1] = std::sqrt( globerrnorms[1] / ntotsize_glob );
02157
02158     metrics.clear();
02159     metrics["L1Error"]   = globerrnorms[0];
02160     metrics["L2Error"]   = globerrnorms[1];
02161     metrics["LinfError"] = globerrnorms[2];
02162
02163     if( verbose && is_root )
02164     {
02165         std::cout << "Error metrics when comparing " << projTagName << " against " << exactTagName << std::endl;
02166         std::cout << "\t L_1 error   = " << globerrnorms[0] << std::endl;
02167         std::cout << "\t L_2 error   = " << globerrnorms[1] << std::endl;
02168         std::cout << "\t L_inf error = " << globerrnorms[2] << std::endl;
02169     }
02170
02171     return moab::MB_SUCCESS;
02172 }
