MBMesquite::AWShapeSizeB1 Class Reference
#include <AWShapeSizeB1.hpp>
+ Inheritance diagram for MBMesquite::AWShapeSizeB1:
+ Collaboration diagram for MBMesquite::AWShapeSizeB1:
Public Member Functions
virtual MESQUITE_EXPORT ~AWShapeSizeB1 ()
virtual MESQUITE_EXPORT std::string get_name () const
virtual MESQUITE_EXPORT bool evaluate (const MsqMatrix< 2, 2 > &A, const MsqMatrix< 2, 2 > &W, double &result, MsqError &err)
 Evaluate \(\mu(A,W)\).
virtual MESQUITE_EXPORT bool evaluate (const MsqMatrix< 3, 3 > &A, const MsqMatrix< 3, 3 > &W, double &result, MsqError &err)
Detailed Description
\( | A - A^{-t} W^t W |^2 \)
Definition at line 43 of file AWShapeSizeB1.hpp.
Definition at line 47 of file AWShapeSizeB1.cpp.
Member Function Documentation
bool MBMesquite::AWShapeSizeB1::evaluate ( const MsqMatrix< 2, 2 > &  A,
const MsqMatrix< 2, 2 > &  W,
double &  result,
MsqError err
) [virtual]
Parameters:
A2x2 active matrix
W2x2 target matrix
resultOutput: value of function
Returns:
false if function cannot be evaluated for given A and W (e.g. division by zero, etc.), true otherwise.
Reimplemented from MBMesquite::AWMetric.
Definition at line 49 of file AWShapeSizeB1.cpp.
References MBMesquite::MsqError::BARRIER_VIOLATED, MBMesquite::barrier_violated_msg_aw, MBMesquite::det(), MBMesquite::AWMetric::invalid_determinant(), MSQ_SETERR, MBMesquite::sqr_Frobenius(), MBMesquite::transpose(), and MBMesquite::transpose_adj().
    const double alpha = det( A );
    if( AWMetric::invalid_determinant( alpha ) )
        MSQ_SETERR( err )( barrier_violated_msg_aw, MsqError::BARRIER_VIOLATED );
        return false;
    result = sqr_Frobenius( A - 1 / alpha * transpose_adj( A ) * transpose( W ) * W );
    return true;
bool MBMesquite::AWShapeSizeB1::evaluate ( const MsqMatrix< 3, 3 > &  A,
const MsqMatrix< 3, 3 > &  W,
double &  result,
MsqError err
) [virtual]
Parameters:
A3x3 active matrix
W3x3 target matrix
Returns:
Definition at line 62 of file AWShapeSizeB1.cpp.
        return false;
    return true;
std::string MBMesquite::AWShapeSizeB1::get_name ( ) const [virtual]
Reimplemented from MBMesquite::AWMetricBarrier.
Definition at line 42 of file AWShapeSizeB1.cpp.
    return "AWShapeSizeB1";
List of all members.
