moab::NCHelperDomain Member List
This is the complete list of members for moab::NCHelperDomain, including all inherited members.
_fileIdmoab::NCHelper [protected]
_fileSetmoab::NCHelper [protected]
_optsmoab::NCHelper [protected]
_readNCmoab::NCHelper [protected]
can_read_file(ReadNC *readNC, int fileId)moab::NCHelperDomain [static]
create_attrib_string(const std::map< std::string, ReadNC::AttData > &attMap, std::string &attString, std::vector< int > &attLen)moab::NCHelper [protected]
create_conventional_tags(const std::vector< int > &tstep_nums)moab::NCHelper
create_dummy_variables()moab::NCHelper [protected]
create_mesh(Range &faces)moab::NCHelperDomain [virtual]
dummyVarNamesmoab::NCHelper [protected]
gCDimsmoab::ScdNCHelper [protected]
gDimsmoab::ScdNCHelper [protected]
get_mesh_type_name()moab::NCHelperDomain [inline, private, virtual]
get_nc_helper(ReadNC *readNC, int fileId, const FileOptions &opts, EntityHandle fileSet)moab::NCHelper [static]
get_tag_to_nonset(ReadNC::VarData &var_data, int tstep_num, Tag &tagh, int num_lev)moab::NCHelper [protected]
get_tag_to_set(ReadNC::VarData &var_data, int tstep_num, Tag &tagh)moab::NCHelper [protected]
globallyPeriodicmoab::ScdNCHelper [protected]
iCDimmoab::ScdNCHelper [protected]
iDimmoab::ScdNCHelper [protected]
ignoredVarNamesmoab::NCHelper [protected]
ilCValsmoab::ScdNCHelper [protected]
ilValsmoab::ScdNCHelper [protected]
init_mesh_vals()moab::NCHelperDomain [private, virtual]
jCDimmoab::ScdNCHelper [protected]
jDimmoab::ScdNCHelper [protected]
jlCValsmoab::ScdNCHelper [protected]
jlValsmoab::ScdNCHelper [protected]
lCDimsmoab::ScdNCHelper [protected]
lDimsmoab::ScdNCHelper [protected]
levDimmoab::NCHelper [protected]
levValsmoab::NCHelper [protected]
locallyPeriodicmoab::ScdNCHelper [protected]
NCHelper(ReadNC *readNC, int fileId, const FileOptions &opts, EntityHandle fileSet)moab::NCHelper [inline]
NCHelperDomain(ReadNC *readNC, int fileId, const FileOptions &opts, EntityHandle fileSet)moab::NCHelperDomain [inline]
nLevelsmoab::NCHelper [protected]
nTimeStepsmoab::NCHelper [protected]
nvmoab::NCHelperDomain [private]
nvDimmoab::NCHelperDomain [private]
read_coordinate(const char *var_name, int lmin, int lmax, std::vector< double > &cvals)moab::NCHelper [protected]
read_variables_setup(std::vector< std::string > &var_names, std::vector< int > &tstep_nums, std::vector< ReadNC::VarData > &vdatas, std::vector< ReadNC::VarData > &vsetdatas)moab::NCHelper [protected]
read_variables_to_set(std::vector< ReadNC::VarData > &vdatas, std::vector< int > &tstep_nums)moab::NCHelper [protected]
ScdNCHelper(ReadNC *readNC, int fileId, const FileOptions &opts, EntityHandle fileSet)moab::ScdNCHelper [inline]
tDimmoab::NCHelper [protected]
tValsmoab::NCHelper [protected]
update_time_tag_vals()moab::NCHelper
~NCHelper()moab::NCHelper [inline, virtual]
~ScdNCHelper()moab::ScdNCHelper [inline, virtual]
