moab::NCHelperDomain Class Reference
Child helper class for Domain grid. More...
#include <NCHelperDomain.hpp>
+ Inheritance diagram for moab::NCHelperDomain:
+ Collaboration diagram for moab::NCHelperDomain:
Public Member Functions
 NCHelperDomain (ReadNC *readNC, int fileId, const FileOptions &opts, EntityHandle fileSet)
ErrorCode create_mesh (Range &faces)
 Implementation of NCHelper::create_mesh()
Static Public Member Functions
static bool can_read_file (ReadNC *readNC, int fileId)
Private Member Functions
virtual ErrorCode init_mesh_vals ()
 Interfaces to be implemented in child classes.
virtual std::string get_mesh_type_name ()
Private Attributes
int nv
int nvDim
Detailed Description
Definition at line 16 of file NCHelperDomain.hpp.
moab::NCHelperDomain::NCHelperDomain ( ReadNC readNC,
int  fileId,
const FileOptions opts,
) [inline]
Definition at line 19 of file NCHelperDomain.hpp.
        : ScdNCHelper( readNC, fileId, opts, fileSet )
Member Function Documentation
bool moab::NCHelperDomain::can_read_file ( ReadNC readNC,
int  fileId
) [static]
Definition at line 15 of file NCHelperDomain.cpp.
References moab::ReadNC::dimNames, moab::ReadNC::globalAtts, and NCFUNC.
Referenced by moab::NCHelper::get_nc_helper().
    std::vector< std::string >& dimNames = readNC->dimNames;
    // If dimension names "n" AND "ni" AND "nj" AND "nv" exist then it should be the Domain grid
    if( ( std::find( dimNames.begin(), dimNames.end(), std::string( "n" ) ) != dimNames.end() ) &&
        ( std::find( dimNames.begin(), dimNames.end(), std::string( "ni" ) ) != dimNames.end() ) &&
        ( std::find( dimNames.begin(), dimNames.end(), std::string( "nj" ) ) != dimNames.end() ) &&
        ( std::find( dimNames.begin(), dimNames.end(), std::string( "nv" ) ) != dimNames.end() ) )
        // Make sure it is CAM grid
        std::map< std::string, ReadNC::AttData >::iterator attIt = readNC->globalAtts.find( "source" );
        if( attIt == readNC->globalAtts.end() ) return false;
        unsigned int sz = attIt->second.attLen;
        std::string att_data;
        att_data.resize( sz + 1 );
        att_data[sz] = '\000';
        int success =
            NCFUNC( get_att_text )( fileId, attIt->second.attVarId, attIt->second.attName.c_str(), &att_data[0] );
        if( success ) return false;
        /*if (att_data.find("CAM") == std::string::npos)
          return false;*/
        return true;
    return false;
Reimplemented from moab::ScdNCHelper.
Definition at line 237 of file NCHelperDomain.cpp.
References moab::NCHelper::_fileId, moab::NCHelper::_fileSet, moab::NCHelper::_readNC, moab::Core::a_entity_factory(), moab::Interface::add_entities(), moab::ParallelComm::assign_global_ids(), moab::Range::begin(), moab::AEntityFactory::create_vert_elem_adjacencies(), moab::ReadNC::dbgOut, moab::Range::end(), ErrorCode, moab::ScdNCHelper::gDims, moab::Core::get_connectivity(), moab::Interface::get_connectivity(), moab::ReadUtilIface::get_element_connect(), moab::Interface::get_entities_by_dimension(), moab::ReadUtilIface::get_node_coords(), moab::Range::insert(), moab::ScdNCHelper::lCDims, moab::ScdNCHelper::lDims, mb, MB_CHK_ERR, MB_CHK_SET_ERR, MB_SET_ERR, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_DENSE, MB_TYPE_DOUBLE, moab::ReadNC::mbImpl, MBPOLYGON, MBQUAD, MBTRI, MBVERTEX, moab::ParallelMergeMesh::merge(), moab::ReadNC::mGlobalIdTag, NCFUNCAG, moab::AEntityFactory::notify_create_entity(), nv, moab::ReadNC::VarData::readCounts, moab::ReadNC::readMeshIface, moab::ReadNC::VarData::readStarts, moab::IntxUtils::remove_padded_vertices(), moab::Interface::tag_get_handle(), moab::Interface::tag_set_data(), moab::DebugOutput::tprintf(), moab::ReadNC::VarData::varId, moab::ReadNC::varInfo, and moab::AEntityFactory::vert_elem_adjacencies().
    Interface*& mbImpl = _readNC->mbImpl;
    // std::string& fileName = _readNC->fileName;
    Tag& mGlobalIdTag = _readNC->mGlobalIdTag;
    // const Tag*& mpFileIdTag = _readNC->mpFileIdTag;
    DebugOutput& dbgOut = _readNC->dbgOut;
    /*int& gatherSetRank = _readNC->gatherSetRank;
    int& trivialPartitionShift = _readNC->trivialPartitionShift;*/
      int rank = 0;
      int procs = 1;
    #ifdef MOAB_HAVE_MPI
      bool& isParallel = _readNC->isParallel;
      if (isParallel) {
        ParallelComm*& myPcomm = _readNC->myPcomm;
        rank = myPcomm->proc_config().proc_rank();
        procs = myPcomm->proc_config().proc_size();
    #endif
    ErrorCode rval;
    int success = 0;
      bool create_gathers = false;
      if (rank == gatherSetRank)
        create_gathers = true;
      // Shift rank to obtain a rotated trivial partition
      int shifted_rank = rank;
      if (procs >= 2 && trivialPartitionShift > 0)
        shifted_rank = (rank + trivialPartitionShift) % procs;*/
    // how many will have mask 0 or 1
    // how many will have a fraction  ? we will not instantiate all elements; only those with mask 1
    // ? also, not all vertices, only those that belong to mask 1 elements ? we will not care about
    // duplicate vertices; maybe another time ? we will start reading masks, vertices
    int local_elems = ( lDims[4] - lDims[1] ) * ( lDims[3] - lDims[0] );
    dbgOut.tprintf( 1, "local cells: %d \n", local_elems );
    // count how many will be with mask 1 here
    // basically, read the mask variable on the local elements;
    std::string maskstr( "mask" );
    ReadNC::VarData& vmask = _readNC->varInfo[maskstr];
    // mask is (nj, ni)
    vmask.readStarts.push_back( lDims[1] );
    vmask.readStarts.push_back( lDims[0] );
    vmask.readCounts.push_back( lDims[4] - lDims[1] );
    vmask.readCounts.push_back( lDims[3] - lDims[0] );
    std::vector< int > mask( local_elems );
    success = NCFUNCAG( _vara_int )( _fileId, vmask.varId, &vmask.readStarts[0], &vmask.readCounts[0], &mask[0] );
    if( success ) MB_SET_ERR( MB_FAILURE, "Failed to read int data for mask variable " );
    int nb_with_mask1 = 0;
    for( int i = 0; i < local_elems; i++ )
        if( 1 == mask[i] ) nb_with_mask1++;
    dbgOut.tprintf( 1, "local cells with mask 1: %d \n", nb_with_mask1 );
    std::vector< NCDF_SIZE > startsv( 3 );
    startsv[0] = vmask.readStarts[0];
    startsv[1] = vmask.readStarts[1];
    startsv[2] = 0;
    std::vector< NCDF_SIZE > countsv( 3 );
    countsv[0] = vmask.readCounts[0];
    countsv[1] = vmask.readCounts[1];
    countsv[2] = nv;  // number of vertices per element
    // read xv and yv coords for vertices, and create elements;
    std::string xvstr( "xv" );
    ReadNC::VarData& var_xv = _readNC->varInfo[xvstr];
    std::vector< double > xv( local_elems * nv );
    success = NCFUNCAG( _vara_double )( _fileId, var_xv.varId, &startsv[0], &countsv[0], &xv[0] );
    if( success ) MB_SET_ERR( MB_FAILURE, "Failed to read double data for xv variable " );
    std::string yvstr( "yv" );
    ReadNC::VarData& var_yv = _readNC->varInfo[yvstr];
    std::vector< double > yv( local_elems * nv );
    success = NCFUNCAG( _vara_double )( _fileId, var_yv.varId, &startsv[0], &countsv[0], &yv[0] );
    if( success ) MB_SET_ERR( MB_FAILURE, "Failed to read double data for yv variable " );
    // read other variables, like xc, yc, frac, area
    std::string xcstr( "xc" );
    ReadNC::VarData& var_xc = _readNC->varInfo[xcstr];
    std::vector< double > xc( local_elems );
    success = NCFUNCAG( _vara_double )( _fileId, var_xc.varId, &vmask.readStarts[0], &vmask.readCounts[0], &xc[0] );
    if( success ) MB_SET_ERR( MB_FAILURE, "Failed to read double data for xc variable " );
    std::string ycstr( "yc" );
    ReadNC::VarData& var_yc = _readNC->varInfo[ycstr];
    std::vector< double > yc( local_elems );
    success = NCFUNCAG( _vara_double )( _fileId, var_yc.varId, &vmask.readStarts[0], &vmask.readCounts[0], &yc[0] );
    if( success ) MB_SET_ERR( MB_FAILURE, "Failed to read double data for yc variable " );
    std::string fracstr( "frac" );
    ReadNC::VarData& var_frac = _readNC->varInfo[fracstr];
    std::vector< double > frac( local_elems );
    success = NCFUNCAG( _vara_double )( _fileId, var_frac.varId, &vmask.readStarts[0], &vmask.readCounts[0], &frac[0] );
    if( success ) MB_SET_ERR( MB_FAILURE, "Failed to read double data for frac variable " );
    std::string areastr( "area" );
    ReadNC::VarData& var_area = _readNC->varInfo[areastr];
    std::vector< double > area( local_elems );
    success = NCFUNCAG( _vara_double )( _fileId, var_area.varId, &vmask.readStarts[0], &vmask.readCounts[0], &area[0] );
    if( success ) MB_SET_ERR( MB_FAILURE, "Failed to read double data for area variable " );
    // create tags for them
    Tag areaTag, fracTag, xcTag, ycTag;
    rval = mbImpl->tag_get_handle( "area", 1, MB_TYPE_DOUBLE, areaTag, MB_TAG_DENSE | MB_TAG_CREAT );MB_CHK_SET_ERR( rval, "Trouble creating area tag" );
    rval = mbImpl->tag_get_handle( "frac", 1, MB_TYPE_DOUBLE, fracTag, MB_TAG_DENSE | MB_TAG_CREAT );MB_CHK_SET_ERR( rval, "Trouble creating frac tag" );
    rval = mbImpl->tag_get_handle( "xc", 1, MB_TYPE_DOUBLE, xcTag, MB_TAG_DENSE | MB_TAG_CREAT );MB_CHK_SET_ERR( rval, "Trouble creating xc tag" );
    rval = mbImpl->tag_get_handle( "yc", 1, MB_TYPE_DOUBLE, ycTag, MB_TAG_DENSE | MB_TAG_CREAT );MB_CHK_SET_ERR( rval, "Trouble creating yc tag" );
    EntityHandle* conn_arr;
    EntityHandle vtx_handle;
    Range tmp_range;
    // set connectivity into that space
    EntityHandle start_cell;
    EntityType mdb_type = MBVERTEX;
    if( nv == 3 )
        mdb_type = MBTRI;
    else if( nv == 4 )
        mdb_type = MBQUAD;
    else if( nv > 4 )  // (nv > 4)
        mdb_type = MBPOLYGON;
    // for nv = 1 , type is vertex
    if( nv > 1 && nb_with_mask1 > 0 )
        rval = _readNC->readMeshIface->get_element_connect( nb_with_mask1, nv, mdb_type, 0, start_cell, conn_arr );MB_CHK_SET_ERR( rval, "Failed to create local cells" );
        tmp_range.insert( start_cell, start_cell + nb_with_mask1 - 1 );
    // Create vertices; first identify different ones, with a tolerance
    std::map< Node3D, EntityHandle > vertex_map;
    if (nb_with_mask1 > 0) {
        // Set vertex coordinates
        // will read all xv, yv, but use only those with correct mask on
        int elem_index     = 0;  // total index in netcdf arrays
        const double pideg = acos( -1.0 ) / 180.0;
        for( ; elem_index < local_elems; elem_index++ )
            if( 0 == mask[elem_index] ) continue;  // nothing to do, do not advance elem_index in actual moab arrays
            // set area and fraction on those elements too
            for( int k = 0; k < nv; k++ )
                int index_v_arr = nv * elem_index + k;
                double x, y;
                if( nv > 1 )
                    x             = xv[index_v_arr];
                    y             = yv[index_v_arr];
                    double cosphi = cos( pideg * y );
                    double zmult  = sin( pideg * y );
                    double xmult  = cosphi * cos( x * pideg );
                    double ymult  = cosphi * sin( x * pideg );
                    Node3D pt( xmult, ymult, zmult );
                    vertex_map[pt] = 0;
                else
                    x = xc[elem_index];
                    y = yc[elem_index];
                    Node3D pt( x, y, 0 );
                    vertex_map[pt] = 0;
        int nLocalVertices = (int)vertex_map.size();
        std::vector< double* > arrays;
        EntityHandle start_vertex;
        rval = _readNC->readMeshIface->get_node_coords( 3, nLocalVertices, 0, start_vertex, arrays );MB_CHK_SET_ERR( rval, "Failed to create local vertices" );
        vtx_handle = start_vertex;
        // Copy vertex coordinates into entity sequence coordinate arrays
        // and copy handle into vertex_map.
        double *x = arrays[0], *y = arrays[1], *z = arrays[2];
        for( auto i = vertex_map.begin(); i != vertex_map.end(); ++i )
            i->second = vtx_handle;
            ++vtx_handle;
            *x = i->first.coords[0];
            ++x;
            *y = i->first.coords[1];
            ++y;
            *z = i->first.coords[2];
            ++z;
        // int nj = gDims[4]-gDims[1]; // is it about 1 in irregular cases
        int local_row_size = lCDims[3] - lCDims[0];
        int global_row_size = gDims[3] - gDims[0]; // this is along
        elem_index         = -1;
        int index          = 0;  // consider the mask for advancing in moab arrays;
        //printf(" map size :%ld \n", vertex_map.size());
        // create now vertex arrays, size vertex_map.size()
        for (int j = lCDims[1]; j<lCDims[4]; j++)
            for (int i = lCDims[0]; i<lCDims[3]; i++)
                elem_index++;
                    if( nv > 1 )
                        double x      = xv[index_v_arr];
                        double y      = yv[index_v_arr];
                        conn_arr[index * nv + k] = vertex_map[pt];
                EntityHandle cell = start_vertex + index;
                if( nv > 1 ) cell = start_cell + index;
                // set other tags, like xc, yc, frac, area
                rval = mbImpl->tag_set_data( xcTag, &cell, 1, &xc[elem_index] );MB_CHK_SET_ERR( rval, "Failed to set xc tag" );
                rval = mbImpl->tag_set_data( ycTag, &cell, 1, &yc[elem_index] );MB_CHK_SET_ERR( rval, "Failed to set yc tag" );
                rval = mbImpl->tag_set_data( areaTag, &cell, 1, &area[elem_index] );MB_CHK_SET_ERR( rval, "Failed to set area tag" );
                rval = mbImpl->tag_set_data( fracTag, &cell, 1, &frac[elem_index] );MB_CHK_SET_ERR( rval, "Failed to set frac tag" );
                // set the global id too:
                int globalId = j * global_row_size + i + 1;
                rval = mbImpl->tag_set_data( mGlobalIdTag, &cell, 1, &globalId );MB_CHK_SET_ERR( rval, "Failed to set global id tag" );
                index++;
        rval = mbImpl->add_entities( _fileSet, tmp_range );MB_CHK_SET_ERR( rval, "Failed to add new cells to current file set" );
        // modify local file set, to merge coincident vertices, and to correct repeated vertices in elements
        std::vector< Tag > tagList;
        tagList.push_back( mGlobalIdTag );
        tagList.push_back( xcTag );
        tagList.push_back( ycTag );
        tagList.push_back( areaTag );
        tagList.push_back( fracTag );
        rval = IntxUtils::remove_padded_vertices( mbImpl, _fileSet, tagList );MB_CHK_SET_ERR( rval, "Failed to remove duplicate vertices" );
        rval = mbImpl->get_entities_by_dimension( _fileSet, 2, faces );MB_CHK_ERR( rval );
        Range all_verts;
        rval = mbImpl->get_connectivity( faces, all_verts );MB_CHK_ERR( rval );
        //printf(" range vert size :%ld \n", all_verts.size());
        rval = mbImpl->add_entities( _fileSet, all_verts );MB_CHK_ERR( rval );
        // need to add adjacencies; TODO: fix this for all nc readers
        // copy this logic from migrate mesh in par comm graph
        Core* mb                 = (Core*)mbImpl;
        AEntityFactory* adj_fact = mb->a_entity_factory();
        if( !adj_fact->vert_elem_adjacencies() )
            adj_fact->create_vert_elem_adjacencies();
        else
            for( Range::iterator it = faces.begin(); it != faces.end(); ++it )
                EntityHandle eh          = *it;
                const EntityHandle* conn = NULL;
                int num_nodes            = 0;
                rval                     = mb->get_connectivity( eh, conn, num_nodes );MB_CHK_ERR( rval );
                adj_fact->notify_create_entity( eh, conn, num_nodes );
    if( myPcomm )
        double tol = 1.e-12;  // this is the same as static tolerance in NCHelper
        ParallelMergeMesh pmm( myPcomm, tol );
        rval = pmm.merge( _fileSet,
                          /* do not do local merge*/ false,
                          /*  2d cells*/ 2 );MB_CHK_SET_ERR( rval, "Failed to merge vertices in parallel" );
        // assign global ids only for vertices, cells have them fine
        rval = myPcomm->assign_global_ids( _fileSet, /*dim*/ 0 );MB_CHK_ERR( rval );
#endif
    return MB_SUCCESS;
virtual std::string moab::NCHelperDomain::get_mesh_type_name ( ) [inline, private, virtual]
Implements moab::NCHelper.
Definition at line 29 of file NCHelperDomain.hpp.
        return "DOMAIN";
Definition at line 44 of file NCHelperDomain.cpp.
References moab::NCHelper::_fileSet, moab::NCHelper::_readNC, moab::ScdInterface::compute_partition(), moab::ReadNC::dbgOut, moab::ReadNC::dimLens, moab::ReadNC::dimNames, moab::ReadNC::VarData::entLoc, moab::ReadNC::ENTLOCEWEDGE, moab::ReadNC::ENTLOCFACE, moab::ReadNC::ENTLOCNSEDGE, ErrorCode, moab::ScdParData::gDims, moab::ScdNCHelper::gDims, moab::ScdNCHelper::globallyPeriodic, moab::ScdNCHelper::iCDim, moab::ScdNCHelper::iDim, moab::ScdNCHelper::ilCVals, moab::ScdNCHelper::ilVals, moab::ReadNC::isParallel, moab::ScdNCHelper::jCDim, moab::ScdNCHelper::jDim, moab::ScdNCHelper::jlCVals, moab::ScdNCHelper::jlVals, moab::ScdNCHelper::lCDims, moab::ScdNCHelper::lDims, moab::NCHelper::levDim, moab::ScdNCHelper::locallyPeriodic, MB_CHK_ERR, MB_CHK_SET_ERR, MB_SET_ERR, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_SPARSE, MB_TYPE_INTEGER, moab::ReadNC::mbImpl, moab::NCHelper::nLevels, moab::NCHelper::nTimeSteps, moab::ReadNC::VarData::numLev, nv, nvDim, moab::ReadNC::parData, moab::ScdParData::partMethod, moab::ReadNC::partMethod, moab::ScdParData::pDims, moab::ParallelComm::proc_config(), moab::ProcConfig::proc_rank(), moab::ProcConfig::proc_size(), moab::Interface::tag_get_handle(), moab::Interface::tag_set_data(), moab::NCHelper::tDim, moab::DebugOutput::tprintf(), moab::NCHelper::tVals, moab::ReadNC::VarData::varDims, and moab::ReadNC::varInfo.
    std::vector< std::string >& dimNames              = _readNC->dimNames;
    std::vector< int >& dimLens                       = _readNC->dimLens;
    std::map< std::string, ReadNC::VarData >& varInfo = _readNC->varInfo;
#endif
    int& partMethod     = _readNC->partMethod;
    ScdParData& parData = _readNC->parData;
    ErrorCode rval;
    // Look for names of i/j dimensions
    // First i
    std::vector< std::string >::iterator vit;
    unsigned int idx;
    if( ( vit = std::find( dimNames.begin(), dimNames.end(), "ni" ) ) != dimNames.end() )
        idx = vit - dimNames.begin();
    else
        MB_SET_ERR( MB_FAILURE, "Couldn't find 'ni' variable" );
    iDim     = idx;
    gDims[0] = 0;
    gDims[3] = dimLens[idx];
    // Then j
    if( ( vit = std::find( dimNames.begin(), dimNames.end(), "nj" ) ) != dimNames.end() )
    else
        MB_SET_ERR( MB_FAILURE, "Couldn't find 'nj' variable" );
    jDim     = idx;
    gDims[1] = 0;
    gDims[4] = dimLens[idx];  // Add 2 for the pole points ? not needed
    // do not use gcdims ? or use only gcdims?
    // Try a truly 2D mesh
    gDims[2] = -1;
    gDims[5] = -1;
    // Get number of vertices per cell
    if( ( vit = std::find( dimNames.begin(), dimNames.end(), "nv" ) ) != dimNames.end() )
    else
        MB_SET_ERR( MB_FAILURE, "Couldn't find 'nv' dimension" );
    nvDim = idx;
    nv    = dimLens[idx];
    // Parse options to get subset
    int rank = 0, procs = 1;
    if( isParallel )
#endif
    if( procs > 1 )
        for( int i = 0; i < 6; i++ )
            parData.gDims[i] = gDims[i];
        parData.partMethod = partMethod;
        int pdims[3];
        locallyPeriodic[0] = locallyPeriodic[1] = locallyPeriodic[2] = 0;
        rval = ScdInterface::compute_partition( procs, rank, parData, lDims, locallyPeriodic, pdims );MB_CHK_ERR( rval );
        for( int i = 0; i < 3; i++ )
            parData.pDims[i] = pdims[i];
        dbgOut.tprintf( 1, "Partition: %dx%d (out of %dx%d)\n", lDims[3] - lDims[0], lDims[4] - lDims[1],
                        gDims[3] - gDims[0], gDims[4] - gDims[1] );
        if( 0 == rank )
            dbgOut.tprintf( 1, "Contiguous chunks of size %d bytes.\n",
                            8 * ( lDims[3] - lDims[0] ) * ( lDims[4] - lDims[1] ) );
    else
            lDims[i] = gDims[i];
        locallyPeriodic[0] = globallyPeriodic[0];
    // Now get actual coordinate values for vertices and cell centers
    lCDims[0] = lDims[0];
    lCDims[3] = lDims[3];
    // For FV models, will always be non-periodic in j
    lCDims[1] = lDims[1];
    lCDims[4] = lDims[4];
#if 0
  // Resize vectors to store values later
  if (-1 != lDims[0])
    ilVals.resize(lDims[3] - lDims[0] + 1);
  if (-1 != lCDims[0])
    ilCVals.resize(lCDims[3] - lCDims[0] + 1);
  if (-1 != lDims[1])
    jlVals.resize(lDims[4] - lDims[1] + 1);
  if (-1 != lCDims[1])
    jlCVals.resize(lCDims[4] - lCDims[1] + 1);
  if (nTimeSteps > 0)
    tVals.resize(nTimeSteps);
#endif
    dbgOut.tprintf( 1, "I=%d-%d, J=%d-%d\n", lDims[0], lDims[3], lDims[1], lDims[4] );
    dbgOut.tprintf( 1, "%d elements, %d vertices\n", ( lDims[3] - lDims[0] ) * ( lDims[4] - lDims[1] ),
                    ( lDims[3] - lDims[0] ) * ( lDims[4] - lDims[1] ) * nv );
    // For each variable, determine the entity location type and number of levels
    std::map< std::string, ReadNC::VarData >::iterator mit;
    for( mit = varInfo.begin(); mit != varInfo.end(); ++mit )
        ReadNC::VarData& vd = ( *mit ).second;
        // Default entLoc is ENTLOCSET
        if( std::find( vd.varDims.begin(), vd.varDims.end(), tDim ) != vd.varDims.end() )
            if( ( std::find( vd.varDims.begin(), vd.varDims.end(), iCDim ) != vd.varDims.end() ) &&
                ( std::find( vd.varDims.begin(), vd.varDims.end(), jCDim ) != vd.varDims.end() ) )
                vd.entLoc = ReadNC::ENTLOCFACE;
            else if( ( std::find( vd.varDims.begin(), vd.varDims.end(), jDim ) != vd.varDims.end() ) &&
                     ( std::find( vd.varDims.begin(), vd.varDims.end(), iCDim ) != vd.varDims.end() ) )
                vd.entLoc = ReadNC::ENTLOCNSEDGE;
            else if( ( std::find( vd.varDims.begin(), vd.varDims.end(), jCDim ) != vd.varDims.end() ) &&
                     ( std::find( vd.varDims.begin(), vd.varDims.end(), iDim ) != vd.varDims.end() ) )
                vd.entLoc = ReadNC::ENTLOCEWEDGE;
        // Default numLev is 0
        if( std::find( vd.varDims.begin(), vd.varDims.end(), levDim ) != vd.varDims.end() ) vd.numLev = nLevels;
    std::vector< std::string > ijdimNames( 2 );
    ijdimNames[0] = "__ni";
    ijdimNames[1] = "__nj";
    std::string tag_name;
    Tag tagh;
    // __<dim_name>_LOC_MINMAX (for slon, slat, lon and lat)
    for( unsigned int i = 0; i != ijdimNames.size(); i++ )
        std::vector< int > val( 2, 0 );
        if( ijdimNames[i] == "__ni" )
            val[0] = lDims[0];
            val[1] = lDims[3];
        else if( ijdimNames[i] == "__nj" )
            val[0] = lDims[1];
            val[1] = lDims[4];
        std::stringstream ss_tag_name;
        ss_tag_name << ijdimNames[i] << "_LOC_MINMAX";
        tag_name = ss_tag_name.str();
        rval     = mbImpl->tag_get_handle( tag_name.c_str(), 2, MB_TYPE_INTEGER, tagh, MB_TAG_SPARSE | MB_TAG_CREAT );MB_CHK_SET_ERR( rval, "Trouble creating conventional tag " << tag_name );
        rval = mbImpl->tag_set_data( tagh, &_fileSet, 1, &val[0] );MB_CHK_SET_ERR( rval, "Trouble setting data to conventional tag " << tag_name );
        if( MB_SUCCESS == rval ) dbgOut.tprintf( 2, "Conventional tag %s is created.\n", tag_name.c_str() );
    // __<dim_name>_LOC_VALS (for slon, slat, lon and lat)
    // Assume all have the same data type as lon (expected type is float or double)
    switch( varInfo["xc"].varDataType )
        case NC_FLOAT:
        case NC_DOUBLE:
            break;
        default:
            MB_SET_ERR( MB_FAILURE, "Unexpected variable data type for 'lon'" );
    // do not need conventional tags
    Tag convTagsCreated = 0;
    int def_val         = 0;
    rval                = mbImpl->tag_get_handle( "__CONV_TAGS_CREATED", 1, MB_TYPE_INTEGER, convTagsCreated,
                                                  MB_TAG_SPARSE | MB_TAG_CREAT, &def_val );MB_CHK_SET_ERR( rval, "Trouble getting _CONV_TAGS_CREATED tag" );
    int create_conv_tags_flag = 1;
    rval                      = mbImpl->tag_set_data( convTagsCreated, &_fileSet, 1, &create_conv_tags_flag );MB_CHK_SET_ERR( rval, "Trouble setting _CONV_TAGS_CREATED tag" );
    return MB_SUCCESS;
Member Data Documentation
int moab::NCHelperDomain::nv [private]
Definition at line 34 of file NCHelperDomain.hpp.
Referenced by create_mesh(), and init_mesh_vals().
Definition at line 35 of file NCHelperDomain.hpp.
Referenced by init_mesh_vals().
List of all members.
