moab::IntxUtils Class Reference
#include <IntxUtils.hpp>
Classes
struct  SphereCoords
Static Public Member Functions
static double dist2 (double *a, double *b)
static double area2D (double *a, double *b, double *c)
static int borderPointsOfXinY2 (double *X, int nX, double *Y, int nY, double *P, int *side, double epsilon_area)
static int SortAndRemoveDoubles2 (double *P, int &nP, double epsilon)
static ErrorCode EdgeIntersections2 (double *blue, int nsBlue, double *red, int nsRed, int *markb, int *markr, double *points, int &nPoints)
static ErrorCode EdgeIntxRllCs (double *blue, CartVect *bluec, int *blueEdgeType, int nsBlue, double *red, CartVect *redc, int nsRed, int *markb, int *markr, int plane, double Radius, double *points, int &nPoints)
static void decide_gnomonic_plane (const CartVect &pos, int &oPlane)
static ErrorCode gnomonic_projection (const CartVect &pos, double R, int plane, double &c1, double &c2)
static ErrorCode reverse_gnomonic_projection (const double &c1, const double &c2, double R, int plane, CartVect &pos)
static void gnomonic_unroll (double &c1, double &c2, double R, int plane)
static ErrorCode global_gnomonic_projection (Interface *mb, EntityHandle inSet, double R, bool centers_only, EntityHandle &outSet)
static void transform_coordinates (double *avg_position, int projection_type)
static SphereCoords cart_to_spherical (CartVect &)
static CartVect spherical_to_cart (SphereCoords &)
static ErrorCode ScaleToRadius (Interface *mb, EntityHandle set, double R)
static double distance_on_great_circle (CartVect &p1, CartVect &p2)
static ErrorCode enforce_convexity (Interface *mb, EntityHandle set, int rank=0)
static double oriented_spherical_angle (double *A, double *B, double *C)
static ErrorCode fix_degenerate_quads (Interface *mb, EntityHandle set)
static double distance_on_sphere (double la1, double te1, double la2, double te2)
static ErrorCode intersect_great_circle_arcs (double *A, double *B, double *C, double *D, double R, double *E)
static ErrorCode intersect_great_circle_arc_with_clat_arc (double *A, double *B, double *C, double *D, double R, double *E, int &np)
static int borderPointsOfCSinRLL (CartVect *redc, double *red2dc, int nsRed, CartVect *bluec, int nsBlue, int *blueEdgeType, double *P, int *side, double epsil)
static ErrorCode deep_copy_set_with_quads (Interface *mb, EntityHandle source_set, EntityHandle dest_set)
static ErrorCode remove_duplicate_vertices (Interface *mb, EntityHandle file_set, double merge_tol, std::vector< Tag > &tagList)
static ErrorCode remove_padded_vertices (Interface *mb, EntityHandle file_set, std::vector< Tag > &tagList)
Detailed Description
Definition at line 16 of file IntxUtils.hpp.
Member Function Documentation
int moab::IntxUtils::borderPointsOfCSinRLL ( CartVect redc,
double *  red2dc,
int  nsRed,
CartVect bluec,
int  nsBlue,
int *  blueEdgeType,
double *  P,
int *  side,
double  epsil
) [static]
Definition at line 1750 of file IntxUtils.cpp.
Referenced by moab::IntxRllCssphere::computeIntersectionBetweenTgtAndSrc().
    int extraPoints = 0;
    // first decide the blue z coordinates
    CartVect A( 0. ), B( 0. ), C( 0. ), D( 0. );
    for( int i = 0; i < nsBlue; i++ )
        if( blueEdgeType[i] == 0 )
            int iP1 = ( i + 1 ) % nsBlue;
            if( bluec[i][2] > bluec[iP1][2] )
                A = bluec[i];
                B = bluec[iP1];
                C = bluec[( i + 2 ) % nsBlue];
                D = bluec[( i + 3 ) % nsBlue];  // it could be back to A, if triangle on top
                break;
    if( nsBlue == 3 && B[2] < 0 )
        // select D to be C
        D = C;
        C = B;  // B is the south pole then
    // so we have A, B, C, D, with A at the top, b going down, then C, D, D > C, A > B
    // AB is const longitude, BC and DA constant latitude
    // check now each of the red points if they are inside this rectangle
    for( int i = 0; i < nsRed; i++ )
        CartVect& X = redc[i];
        if( X[2] > A[2] || X[2] < B[2] ) continue;  // it is above or below the rectangle
        // now decide if it is between the planes OAB and OCD
        if( ( ( A * B ) % X >= -epsil ) && ( ( C * D ) % X >= -epsil ) )
            side[i] = 1;  //
            // it means point X is in the rectangle that we want , on the sphere
            // pass the coords 2d
            P[extraPoints * 2]     = red2dc[2 * i];
            P[extraPoints * 2 + 1] = red2dc[2 * i + 1];
            extraPoints++;
    return extraPoints;
int moab::IntxUtils::borderPointsOfXinY2 ( double *  X,
int  nX,
double *  Y,
int  nY,
double *  P,
int *  side,
double  epsilon_area
) [static]
Definition at line 44 of file IntxUtils.cpp.
Referenced by moab::Intx2MeshInPlane::computeIntersectionBetweenTgtAndSrc(), moab::IntxRllCssphere::computeIntersectionBetweenTgtAndSrc(), and moab::Intx2MeshOnSphere::computeIntersectionBetweenTgtAndSrc().
    // 2 triangles, 3 corners, is the corner of X in Y?
    // Y must have a positive area
    int extraPoint = 0;
    for( int i = 0; i < nX; i++ )
        // compute double the area of all nY triangles formed by a side of Y and a corner of X; if
        // one is negative, stop (negative means it is outside; X and Y are all oriented such that
        // they are positive oriented;
        //  if one area is negative, it means it is outside the convex region, for sure)
        double* A = X + 2 * i;
        int inside = 1;
        for( int j = 0; j < nY; j++ )
            double* B = Y + 2 * j;
            int j1    = ( j + 1 ) % nY;
            double* C = Y + 2 * j1;  // no copy of data
            double area2 = ( B[0] - A[0] ) * ( C[1] - A[1] ) - ( C[0] - A[0] ) * ( B[1] - A[1] );
            if( area2 < -epsilon_area * 200 )
                inside = 0;
                break;
        if( inside )
            side[i] = 1;  // so vertex i of X is inside the convex region formed by Y
            // so side has nX dimension (first array)
            P[extraPoint * 2]     = A[0];
            P[extraPoint * 2 + 1] = A[1];
            extraPoint++;
    return extraPoint;
Definition at line 726 of file IntxUtils.cpp.
References moab::IntxUtils::SphereCoords::lat, moab::CartVect::length(), moab::IntxUtils::SphereCoords::lon, and moab::IntxUtils::SphereCoords::R.
Referenced by add_field_value(), IntxUtilsCSLAM::departure_point_case1(), departure_point_swirl(), departure_point_swirl_rot(), distance_on_great_circle(), set_density(), and IntxUtilsCSLAM::velocity_case1().
    SphereCoords res;
    res.R = cart3d.length();
    if( res.R < 0 )
        res.lon = res.lat = 0.;
        return res;
    res.lat = asin( cart3d[2] / res.R );
    res.lon = atan2( cart3d[1], cart3d[0] );
    if( res.lon < 0 ) res.lon += 2 * M_PI;  // M_PI is defined in math.h? it seems to be true, although
    // there are some defines it depends on :(
    // #if defined __USE_BSD || defined __USE_XOPEN ???
    return res;
void moab::IntxUtils::decide_gnomonic_plane ( const CartVect pos,
int &  oPlane
) [static]
Definition at line 349 of file IntxUtils.cpp.
Referenced by moab::Intx2MeshOnSphere::computeIntersectionBetweenTgtAndSrc(), get_gnomonic_plane(), global_gnomonic_projection(), moab::IntxRllCssphere::setup_tgt_cell(), moab::Intx2MeshOnSphere::setup_tgt_cell(), transform_coordinates(), and moab::BoundBox::update_box_spherical_elem().
    // decide plane, based on max x, y, z
    if( fabs( pos[0] ) < fabs( pos[1] ) )
        if( fabs( pos[2] ) < fabs( pos[1] ) )
            // pos[1] is biggest
            if( pos[1] > 0 )
                plane = 2;
            else
                plane = 4;
        else
            // pos[2] is biggest
            if( pos[2] < 0 )
                plane = 5;
            else
                plane = 6;
    else
        if( fabs( pos[2] ) < fabs( pos[0] ) )
            // pos[0] is the greatest
            if( pos[0] > 0 )
                plane = 1;
            else
                plane = 3;
        else
            if( pos[2] < 0 )
                plane = 5;
            else
                plane = 6;
    return;
Definition at line 1805 of file IntxUtils.cpp.
References moab::Interface::add_entities(), moab::Range::begin(), CORRTAGNAME, moab::dum, moab::Range::end(), ErrorCode, moab::Interface::get_connectivity(), moab::Interface::get_coords(), moab::ReadUtilIface::get_element_connect(), moab::Interface::get_entities_by_type(), moab::ReadUtilIface::get_node_coords(), moab::Interface::globalId_tag(), MB_CHK_ERR, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_DENSE, MB_TYPE_HANDLE, MBQUAD, moab::Interface::query_interface(), moab::Range::size(), moab::Interface::tag_get_data(), moab::Interface::tag_get_handle(), moab::Interface::tag_set_data(), and moab::ReadUtilIface::update_adjacencies().
    ReadUtilIface* read_iface;
    ErrorCode rval = mb->query_interface( read_iface );MB_CHK_ERR( rval );
    // create the handle tag for the corresponding element / vertex
    EntityHandle dum = 0;
    Tag corrTag      = 0;  // it will be created here
    rval             = mb->tag_get_handle( CORRTAGNAME, 1, MB_TYPE_HANDLE, corrTag, MB_TAG_DENSE | MB_TAG_CREAT, &dum );MB_CHK_ERR( rval );
    // give the same global id to new verts and cells created in the lagr(departure) mesh
    Tag gid = mb->globalId_tag();
    Range quads;
    rval = mb->get_entities_by_type( source_set, MBQUAD, quads );MB_CHK_ERR( rval );
    Range connecVerts;
    rval = mb->get_connectivity( quads, connecVerts );MB_CHK_ERR( rval );
    std::map< EntityHandle, EntityHandle > newNodes;
    std::vector< double* > coords;
    EntityHandle start_vert, start_elem, *connect;
    int num_verts = connecVerts.size();
    rval          = read_iface->get_node_coords( 3, num_verts, 0, start_vert, coords );
    if( MB_SUCCESS != rval ) return rval;
    // fill it up
    int i = 0;
    for( Range::iterator vit = connecVerts.begin(); vit != connecVerts.end(); ++vit, i++ )
        EntityHandle oldV = *vit;
        CartVect posi;
        rval = mb->get_coords( &oldV, 1, &( posi[0] ) );MB_CHK_ERR( rval );
        int global_id;
        rval = mb->tag_get_data( gid, &oldV, 1, &global_id );MB_CHK_ERR( rval );
        EntityHandle new_vert = start_vert + i;
        // Cppcheck warning (false positive): variable coords is assigned a value that is never used
        coords[0][i] = posi[0];
        coords[1][i] = posi[1];
        coords[2][i] = posi[2];
        newNodes[oldV] = new_vert;
        // set also the correspondent tag :)
        rval = mb->tag_set_data( corrTag, &oldV, 1, &new_vert );MB_CHK_ERR( rval );
        // also the other side
        // need to check if we really need this; the new vertex will never need the old vertex
        // we have the global id which is the same
        rval = mb->tag_set_data( corrTag, &new_vert, 1, &oldV );MB_CHK_ERR( rval );
        // set the global id on the corresponding vertex the same as the initial vertex
        rval = mb->tag_set_data( gid, &new_vert, 1, &global_id );MB_CHK_ERR( rval );
    // now create new quads in order (in a sequence)
    rval = read_iface->get_element_connect( quads.size(), 4, MBQUAD, 0, start_elem, connect );
    int ie = 0;
    for( Range::iterator it = quads.begin(); it != quads.end(); ++it, ie++ )
        EntityHandle q = *it;
        int nnodes;
        const EntityHandle* conn;
        rval = mb->get_connectivity( q, conn, nnodes );MB_CHK_ERR( rval );
        int global_id;
        rval = mb->tag_get_data( gid, &q, 1, &global_id );MB_CHK_ERR( rval );
        for( int ii = 0; ii < nnodes; ii++ )
            EntityHandle v1      = conn[ii];
            connect[4 * ie + ii] = newNodes[v1];
        EntityHandle newElement = start_elem + ie;
        // set the corresponding tag; not sure we need this one, from old to new
        rval = mb->tag_set_data( corrTag, &q, 1, &newElement );MB_CHK_ERR( rval );
        rval = mb->tag_set_data( corrTag, &newElement, 1, &q );MB_CHK_ERR( rval );
        rval = mb->tag_set_data( gid, &newElement, 1, &global_id );MB_CHK_ERR( rval );
        rval = mb->add_entities( dest_set, &newElement, 1 );MB_CHK_ERR( rval );
    rval = read_iface->update_adjacencies( start_elem, quads.size(), 4, connect );MB_CHK_ERR( rval );
    return MB_SUCCESS;
static double moab::IntxUtils::dist2 ( double *  a,
double *  b
) [inline, static]
Definition at line 20 of file IntxUtils.hpp.
Referenced by moab::Intx2MeshInPlane::findNodes(), moab::IntxRllCssphere::findNodes(), moab::Intx2MeshOnSphere::findNodes(), and SortAndRemoveDoubles2().
        double abx = b[0] - a[0], aby = b[1] - a[1];
        return sqrt( abx * abx + aby * aby );
double moab::IntxUtils::distance_on_great_circle ( CartVect p1,
CartVect p2
) [static]
Definition at line 1085 of file IntxUtils.cpp.
References cart_to_spherical(), moab::IntxUtils::SphereCoords::lat, moab::IntxUtils::SphereCoords::lon, and moab::IntxUtils::SphereCoords::R.
    SphereCoords sph1 = cart_to_spherical( p1 );
    SphereCoords sph2 = cart_to_spherical( p2 );
    // radius should be the same
    return sph1.R *
           acos( sin( sph1.lon ) * sin( sph2.lon ) + cos( sph1.lat ) * cos( sph2.lat ) * cos( sph2.lon - sph2.lon ) );
double moab::IntxUtils::distance_on_sphere ( double  la1,
double  te1,
double  la2,
double  te2
) [static]
Definition at line 1341 of file IntxUtils.cpp.
Referenced by IntxUtilsCSLAM::quasi_smooth_field(), and IntxUtilsCSLAM::slotted_cylinder_field().
    return acos( sin( te1 ) * sin( te2 ) + cos( te1 ) * cos( te2 ) * cos( la1 - la2 ) );
ErrorCode moab::IntxUtils::EdgeIntersections2 ( double *  blue,
int  nsBlue,
double *  red,
int  nsRed,
int *  markb,
int *  markr,
double *  points,
int &  nPoints
) [static]
Definition at line 179 of file IntxUtils.cpp.
References MAXEDGES, and MB_SUCCESS.
Referenced by moab::Intx2MeshInPlane::computeIntersectionBetweenTgtAndSrc(), and moab::Intx2MeshOnSphere::computeIntersectionBetweenTgtAndSrc().
    /* EDGEINTERSECTIONS computes edge intersections of two elements
     [P,n]=EdgeIntersections(X,Y) computes for the two given elements  * red
     and blue ( stored column wise )
     (point coordinates are stored column-wise, in counter clock
     order) the points P where their edges intersect. In addition,
     in n the indices of which neighbors of red  are also intersecting
     with blue are given.
    // points is an array with enough slots   (24 * 2 doubles)
    nPoints = 0;
    for( int i = 0; i < MAXEDGES; i++ )
        markb[i] = markr[i] = 0;
        for( int j = 0; j < nsRed; j++ )
            double b[2];
            double a[2][2];  // 2*2
            int iPlus1 = ( i + 1 ) % nsBlue;
            int jPlus1 = ( j + 1 ) % nsRed;
            for( int k = 0; k < 2; k++ )
                b[k] = red[2 * j + k] - blue[2 * i + k];
                // row k of a: a(k, 0), a(k, 1)
                a[k][0] = blue[2 * iPlus1 + k] - blue[2 * i + k];
                a[k][1] = red[2 * j + k] - red[2 * jPlus1 + k];
            double delta = a[0][0] * a[1][1] - a[0][1] * a[1][0];
            if( fabs( delta ) > 1.e-14 )  // this is close to machine epsilon
                // not parallel
                double alfa = ( b[0] * a[1][1] - a[0][1] * b[1] ) / delta;
                double beta = ( -b[0] * a[1][0] + b[1] * a[0][0] ) / delta;
                if( 0 <= alfa && alfa <= 1. && 0 <= beta && beta <= 1. )
                    // the intersection is good
                        points[2 * nPoints + k] = blue[2 * i + k] + alfa * ( blue[2 * iPlus1 + k] - blue[2 * i + k] );
                    markb[i] = 1;  // so neighbor number i of blue will be considered too.
                    markr[j] = 1;  // this will be used in advancing red around blue quad
                    nPoints++;
            // the case delta ~ 0. will be considered by the interior points logic
    return MB_SUCCESS;
ErrorCode moab::IntxUtils::EdgeIntxRllCs ( double *  blue,
CartVect bluec,
int *  blueEdgeType,
int  nsBlue,
double *  red,
CartVect redc,
int  nsRed,
int *  markb,
int *  markr,
int  plane,
double  Radius,
double *  points,
int &  nPoints
) [static]
Definition at line 244 of file IntxUtils.cpp.
References moab::CartVect::array(), moab::E, gnomonic_projection(), intersect_great_circle_arc_with_clat_arc(), MB_SUCCESS, and moab::R.
    // if blue edge type is 1, intersect in 3d then project to 2d by gnomonic projection
    // everything else the same (except if there are 2 points resulting, which is rare)
    for( int i = 0; i < 4; i++ )
    {  // always at most 4 , so maybe don't bother
        if( blueEdgeType[i] == 0 )  // old style, just 2d
                double b[2];
                    // not parallel
                        nPoints++;
                }  // if the edges are too "parallel", skip them
        else  // edge type is 1, so use 3d intersection
            CartVect& C = bluec[i];
            CartVect& D = bluec[iPlus1];
                int jPlus1  = ( j + 1 ) % nsRed;  // nsRed is just 4, forget about it, usually
                CartVect& A = redc[j];
                CartVect& B = redc[jPlus1];
                int np      = 0;
                double E[9];
                intersect_great_circle_arc_with_clat_arc( A.array(), B.array(), C.array(), D.array(), R, E, np );
                if( np == 0 ) continue;
                if( np >= 2 )
                    std::cout << "intersection with 2 points :" << A << B << C << D << "\n";
                for( int k = 0; k < np; k++ )
                    gnomonic_projection( CartVect( E + k * 3 ), R, plane, points[2 * nPoints],
                                         points[2 * nPoints + 1] );
                    nPoints++;
    return MB_SUCCESS;
ErrorCode moab::IntxUtils::enforce_convexity ( Interface mb,
EntityHandle  set,
int  rank = 0
) [static]
Definition at line 1097 of file IntxUtils.cpp.
References moab::Interface::add_entities(), moab::angle(), moab::Range::begin(), CORRTAGNAME, moab::Interface::create_element(), moab::Range::end(), ErrorCode, moab::Interface::get_connectivity(), moab::Interface::get_coords(), moab::Interface::get_entities_by_dimension(), moab::Interface::id_from_handle(), moab::Interface::list_entities(), MAXEDGES, MB_CHK_ERR, MB_SUCCESS, MB_TAG_DENSE, MB_TAG_NOT_FOUND, MB_TYPE_HANDLE, MB_TYPE_INTEGER, MBPOLYGON, MBTRI, oriented_spherical_angle(), moab::Interface::remove_entities(), moab::Interface::tag_get_data(), moab::Interface::tag_get_handle(), moab::Interface::tag_set_data(), and moab::Interface::write_file().
Referenced by main(), and update_tracer().
    // look at each polygon; compute all angles; if one is reflex, break that angle with
    // the next triangle; put the 2 new polys in the set;
    // still look at the next poly
    // replace it with 2 triangles, and remove from set;
    // it should work for all polygons / tested first for case 1, with dt 0.5 (too much deformation)
    // get all entities of dimension 2
    // then get the connectivity, etc
    Range inputRange;
    ErrorCode rval = mb->get_entities_by_dimension( lset, 2, inputRange );MB_CHK_ERR( rval );
    Tag corrTag       = 0;
    EntityHandle dumH = 0;
    rval              = mb->tag_get_handle( CORRTAGNAME, 1, MB_TYPE_HANDLE, corrTag, MB_TAG_DENSE, &dumH );
    if( rval == MB_TAG_NOT_FOUND ) corrTag = 0;
    Tag gidTag;
    rval = mb->tag_get_handle( "GLOBAL_ID", 1, MB_TYPE_INTEGER, gidTag, MB_TAG_DENSE );MB_CHK_ERR( rval );
    std::vector< double > coords;
    coords.resize( 3 * MAXEDGES );  // at most 10 vertices per polygon
    // we should create a queue with new polygons that need processing for reflex angles
    //  (obtuse)
    std::queue< EntityHandle > newPolys;
    int brokenPolys     = 0;
    Range::iterator eit = inputRange.begin();
    while( eit != inputRange.end() || !newPolys.empty() )
        EntityHandle eh;
        if( eit != inputRange.end() )
            eh = *eit;
            ++eit;
        else
            eh = newPolys.front();
            newPolys.pop();
        // get the nodes, then the coordinates
        const EntityHandle* verts;
        int num_nodes;
        rval = mb->get_connectivity( eh, verts, num_nodes );MB_CHK_ERR( rval );
        int nsides = num_nodes;
        // account for possible padded polygons
        while( verts[nsides - 2] == verts[nsides - 1] && nsides > 3 )
            nsides--;
        EntityHandle corrHandle = 0;
        if( corrTag )
            rval = mb->tag_get_data( corrTag, &eh, 1, &corrHandle );MB_CHK_ERR( rval );
        int gid = 0;
        rval    = mb->tag_get_data( gidTag, &eh, 1, &gid );MB_CHK_ERR( rval );
        coords.resize( 3 * nsides );
        if( nsides < 4 ) continue;  // if already triangles, don't bother
        // get coordinates
        rval = mb->get_coords( verts, nsides, &coords[0] );MB_CHK_ERR( rval );
        // compute each angle
        bool alreadyBroken = false;
        for( int i = 0; i < nsides; i++ )
            double* A    = &coords[3 * i];
            double* B    = &coords[3 * ( ( i + 1 ) % nsides )];
            double* C    = &coords[3 * ( ( i + 2 ) % nsides )];
            double angle = IntxUtils::oriented_spherical_angle( A, B, C );
            if( angle - M_PI > 0. )  // even almost reflex is bad; break it!
                if( alreadyBroken )
                    mb->list_entities( &eh, 1 );
                    mb->list_entities( verts, nsides );
                    double* D = &coords[3 * ( ( i + 3 ) % nsides )];
                    std::cout << "ABC: " << angle << " \n";
                    std::cout << "BCD: " << IntxUtils::oriented_spherical_angle( B, C, D ) << " \n";
                    std::cout << "CDA: " << IntxUtils::oriented_spherical_angle( C, D, A ) << " \n";
                    std::cout << "DAB: " << IntxUtils::oriented_spherical_angle( D, A, B ) << " \n";
                    std::cout << " this cell has at least 2 angles > 180, it has serious issues\n";
                    return MB_FAILURE;
                // the bad angle is at i+1;
                // create 1 triangle and one polygon; add the polygon to the input range, so
                // it will be processed too
                // also, add both to the set :) and remove the original polygon from the set
                // break the next triangle, even though not optimal
                // so create the triangle i+1, i+2, i+3; remove i+2 from original list
                // even though not optimal in general, it is good enough.
                EntityHandle conn3[3] = {verts[( i + 1 ) % nsides], verts[( i + 2 ) % nsides],
                                         verts[( i + 3 ) % nsides]};
                // create a polygon with num_nodes-1 vertices, and connectivity
                // verts[i+1], verts[i+3], (all except i+2)
                std::vector< EntityHandle > conn( nsides - 1 );
                for( int j = 1; j < nsides; j++ )
                    conn[j - 1] = verts[( i + j + 2 ) % nsides];
                EntityHandle newElement;
                rval = mb->create_element( MBTRI, conn3, 3, newElement );MB_CHK_ERR( rval );
                rval = mb->add_entities( lset, &newElement, 1 );MB_CHK_ERR( rval );
                if( corrTag )
                    rval = mb->tag_set_data( corrTag, &newElement, 1, &corrHandle );MB_CHK_ERR( rval );
                rval = mb->tag_set_data( gidTag, &newElement, 1, &gid );MB_CHK_ERR( rval );
                if( nsides == 4 )
                    // create another triangle
                    rval = mb->create_element( MBTRI, &conn[0], 3, newElement );MB_CHK_ERR( rval );
                else
                    // create another polygon, and add it to the inputRange
                    rval = mb->create_element( MBPOLYGON, &conn[0], nsides - 1, newElement );MB_CHK_ERR( rval );
                    newPolys.push( newElement );  // because it has less number of edges, the
                    // reverse should work to find it.
                if( corrTag )
                rval = mb->remove_entities( lset, &eh, 1 );MB_CHK_ERR( rval );
                brokenPolys++;
                alreadyBroken = true;  // get out of the loop, element is broken
    if( brokenPolys > 0 )
        std::cout << "on local process " << my_rank << ", " << brokenPolys
                  << " concave polygons were decomposed in convex ones \n";
#ifdef VERBOSE
        std::stringstream fff;
        fff << "file_set" << mb->id_from_handle( lset ) << "rk_" << my_rank << ".h5m";
        rval = mb->write_file( fff.str().c_str(), 0, 0, &lset, 1 );MB_CHK_ERR( rval );
        std::cout << "wrote new file set: " << fff.str() << "\n";
#endif
    return MB_SUCCESS;
Definition at line 1246 of file IntxUtils.cpp.
References moab::Interface::add_entities(), moab::Range::begin(), moab::Interface::create_element(), moab::Interface::delete_entities(), moab::Range::end(), ErrorCode, moab::Interface::get_connectivity(), moab::Interface::get_entities_by_type(), moab::Interface::globalId_tag(), MB_CHK_ERR, MB_SUCCESS, MBQUAD, MBTRI, moab::Interface::remove_entities(), moab::Interface::tag_get_data(), and moab::Interface::tag_set_data().
Referenced by moab::TempestRemapper::ComputeOverlapMesh(), and main().
    Range quads;
    ErrorCode rval = mb->get_entities_by_type( set, MBQUAD, quads );MB_CHK_ERR( rval );
    Tag gid;
    for( Range::iterator qit = quads.begin(); qit != quads.end(); ++qit )
        EntityHandle quad         = *qit;
        const EntityHandle* conn4 = NULL;
        int num_nodes             = 0;
        rval                      = mb->get_connectivity( quad, conn4, num_nodes );MB_CHK_ERR( rval );
        for( int i = 0; i < num_nodes; i++ )
            int next_node_index = ( i + 1 ) % num_nodes;
            if( conn4[i] == conn4[next_node_index] )
                // form a triangle and delete the quad
                // first get the global id, to set it on triangle later
                int global_id = 0;
                rval          = mb->tag_get_data( gid, &quad, 1, &global_id );MB_CHK_ERR( rval );
                int i2                = ( i + 2 ) % num_nodes;
                int i3                = ( i + 3 ) % num_nodes;
                EntityHandle conn3[3] = {conn4[i], conn4[i2], conn4[i3]};
                EntityHandle tri;
                rval = mb->create_element( MBTRI, conn3, 3, tri );MB_CHK_ERR( rval );
                mb->add_entities( set, &tri, 1 );
                mb->remove_entities( set, &quad, 1 );
                mb->delete_entities( &quad, 1 );
                rval = mb->tag_set_data( gid, &tri, 1, &global_id );MB_CHK_ERR( rval );
    return MB_SUCCESS;
ErrorCode moab::IntxUtils::global_gnomonic_projection ( Interface mb,
EntityHandle  inSet,
double  R,
bool  centers_only,
EntityHandle outSet
) [static]
Definition at line 549 of file IntxUtils.cpp.
References moab::Interface::add_entities(), moab::CartVect::array(), moab::Range::begin(), center(), moab::Interface::create_element(), moab::Interface::create_meshset(), moab::Interface::create_vertex(), decide_gnomonic_plane(), moab::Range::empty(), moab::Range::end(), ErrorCode, moab::Interface::get_connectivity(), moab::Interface::get_coords(), moab::Interface::get_entities_by_dimension(), moab::Interface::get_entities_by_handle(), moab::Interface::get_entities_by_type_and_tag(), gnomonic_projection(), gnomonic_unroll(), moab::Range::insert(), MB_CHK_ERR, MB_SUCCESS, MBENTITYSET, MESHSET_SET, ScaleToRadius(), moab::Interface::tag_get_data(), moab::Interface::tag_get_handle(), moab::Interface::tag_set_data(), moab::Interface::type_from_handle(), and moab::Interface::UNION.
    std::string parTagName( "PARALLEL_PARTITION" );
    Tag part_tag;
    Range partSets;
    ErrorCode rval = mb->tag_get_handle( parTagName.c_str(), part_tag );
    if( MB_SUCCESS == rval && part_tag != 0 )
        rval = mb->get_entities_by_type_and_tag( inSet, MBENTITYSET, &part_tag, NULL, 1, partSets, Interface::UNION );MB_CHK_ERR( rval );
    rval = ScaleToRadius( mb, inSet, 1.0 );MB_CHK_ERR( rval );
    // Get all entities of dimension 2
    Range inputRange;  // get
    rval = mb->get_entities_by_dimension( inSet, 1, inputRange );MB_CHK_ERR( rval );
    rval = mb->get_entities_by_dimension( inSet, 2, inputRange );MB_CHK_ERR( rval );
    std::map< EntityHandle, int > partsAssign;
    std::map< int, EntityHandle > newPartSets;
    if( !partSets.empty() )
        // get all cells, and assign parts
        for( Range::iterator setIt = partSets.begin(); setIt != partSets.end(); ++setIt )
            EntityHandle pSet = *setIt;
            Range ents;
            rval = mb->get_entities_by_handle( pSet, ents );MB_CHK_ERR( rval );
            int val;
            rval = mb->tag_get_data( part_tag, &pSet, 1, &val );MB_CHK_ERR( rval );
            // create a new set with the same part id tag, in the outSet
            EntityHandle newPartSet;
            rval = mb->create_meshset( MESHSET_SET, newPartSet );MB_CHK_ERR( rval );
            rval = mb->tag_set_data( part_tag, &newPartSet, 1, &val );MB_CHK_ERR( rval );
            newPartSets[val] = newPartSet;
            rval             = mb->add_entities( outSet, &newPartSet, 1 );MB_CHK_ERR( rval );
            for( Range::iterator it = ents.begin(); it != ents.end(); ++it )
                partsAssign[*it] = val;
    if( centers_only )
        for( Range::iterator it = inputRange.begin(); it != inputRange.end(); ++it )
            CartVect center;
            EntityHandle cell = *it;
            rval              = mb->get_coords( &cell, 1, center.array() );MB_CHK_ERR( rval );
            int plane;
            decide_gnomonic_plane( center, plane );
            double c[3];
            c[2] = 0.;
            gnomonic_projection( center, R, plane, c[0], c[1] );
            gnomonic_unroll( c[0], c[1], R, plane );
            EntityHandle vertex;
            rval = mb->create_vertex( c, vertex );MB_CHK_ERR( rval );
            rval = mb->add_entities( outSet, &vertex, 1 );MB_CHK_ERR( rval );
    else
        // distribute the cells to 6 planes, based on the center
        Range subranges[6];
            CartVect center;
            int plane;
            subranges[plane - 1].insert( cell );
        for( int i = 1; i <= 6; i++ )
            Range verts;
            rval = mb->get_connectivity( subranges[i - 1], verts );MB_CHK_ERR( rval );
            std::map< EntityHandle, EntityHandle > corr;
            for( Range::iterator vt = verts.begin(); vt != verts.end(); ++vt )
                CartVect vect;
                EntityHandle v = *vt;
                rval           = mb->get_coords( &v, 1, vect.array() );MB_CHK_ERR( rval );
                double c[3];
                c[2] = 0.;
                gnomonic_projection( vect, R, i, c[0], c[1] );
                gnomonic_unroll( c[0], c[1], R, i );
                corr[v] = vertex;  // for new connectivity
            EntityHandle new_conn[20];  // max edges in 2d ?
            for( Range::iterator eit = subranges[i - 1].begin(); eit != subranges[i - 1].end(); ++eit )
                EntityHandle eh          = *eit;
                const EntityHandle* conn = NULL;
                int num_nodes;
                rval = mb->get_connectivity( eh, conn, num_nodes );MB_CHK_ERR( rval );
                // build a new vertex array
                for( int j = 0; j < num_nodes; j++ )
                    new_conn[j] = corr[conn[j]];
                EntityType type = mb->type_from_handle( eh );
                EntityHandle newCell;
                rval = mb->create_element( type, new_conn, num_nodes, newCell );MB_CHK_ERR( rval );
                rval = mb->add_entities( outSet, &newCell, 1 );MB_CHK_ERR( rval );
                std::map< EntityHandle, int >::iterator mit = partsAssign.find( eh );
                if( mit != partsAssign.end() )
                    int val = mit->second;
                    rval    = mb->add_entities( newPartSets[val], &newCell, 1 );MB_CHK_ERR( rval );
    return MB_SUCCESS;
ErrorCode moab::IntxUtils::gnomonic_projection ( const CartVect pos,
double  R,
int  plane,
double &  c1,
double &  c2
) [static]
Definition at line 394 of file IntxUtils.cpp.
References MB_SUCCESS.
Referenced by moab::IntxRllCssphere::computeIntersectionBetweenTgtAndSrc(), moab::Intx2MeshOnSphere::computeIntersectionBetweenTgtAndSrc(), EdgeIntxRllCs(), get_barycenters(), get_intersection_weights(), get_linear_reconstruction(), global_gnomonic_projection(), moab::IntxRllCssphere::setup_tgt_cell(), moab::Intx2MeshOnSphere::setup_tgt_cell(), test_linear_reconstruction(), transform_coordinates(), and moab::BoundBox::update_box_spherical_elem().
    double alfa = 1.;  // the new point will be on line alfa*pos
    switch( plane )
        case 1: {
            // the plane with x = R; x>y, x>z
            // c1->y, c2->z
            alfa = R / pos[0];
            c1   = alfa * pos[1];
            c2   = alfa * pos[2];
            break;
        case 2: {
            // y = R -> zx
            alfa = R / pos[1];
            c1   = alfa * pos[2];
            c2   = alfa * pos[0];
            break;
        case 3: {
            // x=-R, -> yz
            alfa = -R / pos[0];
            c1   = -alfa * pos[1];  // the sign is to preserve orientation
            c2   = alfa * pos[2];
            break;
        case 4: {
            // y = -R
            alfa = -R / pos[1];
            c1   = -alfa * pos[2];  // the sign is to preserve orientation
            c2   = alfa * pos[0];
            break;
        case 5: {
            // z = -R
            alfa = -R / pos[2];
            c1   = -alfa * pos[0];  // the sign is to preserve orientation
            c2   = alfa * pos[1];
            break;
        case 6: {
            alfa = R / pos[2];
            c1   = alfa * pos[0];
            c2   = alfa * pos[1];
            break;
        default:
            return MB_FAILURE;  // error
    return MB_SUCCESS;  // no error
void moab::IntxUtils::gnomonic_unroll ( double &  c1,
double &  c2,
double  R,
int  plane
) [static]
Definition at line 512 of file IntxUtils.cpp.
References moab::R.
Referenced by global_gnomonic_projection(), and transform_coordinates().
    double tmp;
    switch( plane )
        case 1:
            break;  // nothing
        case 2:     // rotate + 90
            tmp = c1;
            c1  = -c2;
            c2  = tmp;
            c1  = c1 + 2 * R;
            break;
        case 3:
            c1 = c1 + 4 * R;
            break;
        case 4:  // rotate with -90 x-> -y; y -> x
            tmp = c1;
            c1  = c2;
            c2  = -tmp;
            c1  = c1 - 2 * R;
            break;
        case 5:  // South Pole
            // rotate 180 then move to (-2, -2)
            c1 = -c1 - 2. * R;
            c2 = -c2 - 2. * R;
            break;
        case 6:  // North Pole
            c1 = c1 - 2. * R;
            c2 = c2 + 2. * R;
            break;
    return;
ErrorCode moab::IntxUtils::intersect_great_circle_arc_with_clat_arc ( double *  A,
double *  B,
double *  C,
double *  D,
double  R,
double *  E,
int &  np
) [static]
Definition at line 1437 of file IntxUtils.cpp.
References moab::CartVect::length_squared(), MB_SUCCESS, moab::R, and moab::verify().
Referenced by EdgeIntxRllCs().
    const double distTol   = R * 1.e-6;
    const double Tolerance = R * R * 1.e-12;  // radius should be 1, usually
    np                     = 0;               // number of points in intersection
    CartVect a( A ), b( B ), c( C ), d( D );
    // check input first
    double R2 = R * R;
    if( fabs( a.length_squared() - R2 ) + fabs( b.length_squared() - R2 ) + fabs( c.length_squared() - R2 ) +
            fabs( d.length_squared() - R2 ) >
        10 * Tolerance )
        return MB_FAILURE;
    if( ( a - b ).length_squared() < Tolerance ) return MB_FAILURE;
    if( ( c - d ).length_squared() < Tolerance )  // edges are too short
        return MB_FAILURE;
    // CD is the const latitude arc
    if( fabs( C[2] - D[2] ) > distTol )  // cd is not on the same z (constant latitude)
        return MB_FAILURE;
    if( fabs( R - C[2] ) < distTol || fabs( R + C[2] ) < distTol ) return MB_FAILURE;  // too close to the poles
    // find the points on the circle P(teta) = (r*sin(teta), r*cos(teta), C[2]) that are on the
    // great circle arc AB normal to the AB circle:
    CartVect n1 = a * b;  // the normal to the great circle arc (circle)
    // solve the system of equations:
     *    n1%(x, y, z) = 0  // on the great circle
     *     z = C[2];
     *    x^2+y^2+z^2 = R^2
    double z = C[2];
    if( fabs( n1[0] ) + fabs( n1[1] ) < 2 * Tolerance )
        // it is the Equator; check if the const lat edge is Equator too
        if( fabs( C[2] ) > distTol )
            return MB_FAILURE;  // no intx, too far from Eq
        else
            // all points are on the equator
            CartVect cd = c * d;
            // by convention,  c<d, positive is from c to d
            // is a or b between c , d?
            CartVect ca = c * a;
            CartVect ad = a * d;
            CartVect cb = c * b;
            CartVect bd = b * d;
            bool agtc   = ( ca % cd >= -Tolerance );  // a>c?
            bool dgta   = ( ad % cd >= -Tolerance );  // d>a?
            bool bgtc   = ( cb % cd >= -Tolerance );  // b>c?
            bool dgtb   = ( bd % cd >= -Tolerance );  // d>b?
            if( agtc )
                if( dgta )
                    // a is for sure a point
                    E[0] = a[0];
                    E[1] = a[1];
                    E[2] = a[2];
                    np++;
                    if( bgtc )
                        if( dgtb )
                            // b is also in between c and d
                            E[3] = b[0];
                            E[4] = b[1];
                            E[5] = b[2];
                            np++;
                        else
                            // then order is c a d b, intx is ad
                            E[3] = d[0];
                            E[4] = d[1];
                            E[5] = d[2];
                            np++;
                    else
                        // b is less than c, so b c a d, intx is ac
                        E[3] = c[0];
                        E[4] = c[1];
                        E[5] = c[2];
                        np++;  // what if E[0] is E[3]?
                else  // c < d < a
                    if( dgtb )  // d is for sure in
                        E[0] = d[0];
                        E[1] = d[1];
                        E[2] = d[2];
                        np++;
                        if( bgtc )  // c<b<d<a
                            // another point is b
                            E[3] = b[0];
                            E[4] = b[1];
                            E[5] = b[2];
                            np++;
                        else  // b<c<d<a
                            // another point is c
                            E[3] = c[0];
                            E[4] = c[1];
                            E[5] = c[2];
                            np++;
                    else
                        // nothing, order is c, d < a, b
            else  // a < c < d
                if( bgtc )
                    // c is for sure in
                    E[0] = c[0];
                    E[1] = c[1];
                    E[2] = c[2];
                    np++;
                    if( dgtb )
                        // a < c < b < d; second point is b
                        E[3] = b[0];
                        E[4] = b[1];
                        E[5] = b[2];
                        np++;
                    else
                        // a < c < d < b; second point is d
                        E[3] = d[0];
                        E[4] = d[1];
                        E[5] = d[2];
                        np++;
                else  // a, b < c < d
                    // nothing
        // for the 2 points selected, see if it is only one?
        // no problem, maybe it will be collapsed later anyway
        if( np > 0 ) return MB_SUCCESS;
        return MB_FAILURE;  // no intersection
        if( fabs( n1[0] ) <= fabs( n1[1] ) )
            // resolve eq in x:  n0 * x + n1 * y +n2*z = 0; y = -n2/n1*z -n0/n1*x
            //  (u+v*x)^2+x^2=R2-z^2
            //  (v^2+1)*x^2 + 2*u*v *x + u^2+z^2-R^2 = 0
            //  delta = 4*u^2*v^2 - 4*(v^2-1)(u^2+z^2-R^2)
            // x1,2 =
            double u = -n1[2] / n1[1] * z, v = -n1[0] / n1[1];
            double a1 = v * v + 1, b1 = 2 * u * v, c1 = u * u + z * z - R2;
            double delta = b1 * b1 - 4 * a1 * c1;
            if( delta < -Tolerance ) return MB_FAILURE;  // no intersection
            if( delta > Tolerance )                      // 2 solutions possible
                double x1 = ( -b1 + sqrt( delta ) ) / 2 / a1;
                double x2 = ( -b1 - sqrt( delta ) ) / 2 / a1;
                double y1 = u + v * x1;
                double y2 = u + v * x2;
                if( verify( a, b, c, d, x1, y1, z ) )
                    E[0] = x1;
                    E[1] = y1;
                    E[2] = z;
                    np++;
                if( verify( a, b, c, d, x2, y2, z ) )
                    E[3 * np + 0] = x2;
                    E[3 * np + 1] = y2;
                    E[3 * np + 2] = z;
                    np++;
            else
                // one solution
                double x1 = -b1 / 2 / a1;
                    E[0] = x1;
                    E[1] = y1;
                    E[2] = z;
                    np++;
        else
            // resolve eq in y, reverse
            //   n0 * x + n1 * y +n2*z = 0; x = -n2/n0*z -n1/n0*y = u+v*y
            //  (u+v*y)^2+y^2 -R2+z^2 =0
            //  (v^2+1)*y^2 + 2*u*v *y + u^2+z^2-R^2 = 0
            // x1,2 =
            double u = -n1[2] / n1[0] * z, v = -n1[1] / n1[0];
                double y1 = ( -b1 + sqrt( delta ) ) / 2 / a1;
                double y2 = ( -b1 - sqrt( delta ) ) / 2 / a1;
                double x1 = u + v * y1;
                double x2 = u + v * y2;
                    E[0] = x1;
                    E[1] = y1;
                    E[2] = z;
                    np++;
                    E[3 * np + 0] = x2;
                    E[3 * np + 1] = y2;
                    E[3 * np + 2] = z;
                    np++;
            else
                // one solution
                double y1 = -b1 / 2 / a1;
                    E[0] = x1;
                    E[1] = y1;
                    E[2] = z;
                    np++;
    if( np <= 0 ) return MB_FAILURE;
    return MB_SUCCESS;
ErrorCode moab::IntxUtils::intersect_great_circle_arcs ( double *  A,
double *  B,
double *  C,
double *  D,
double  R,
double *  E
) [static]
Definition at line 1350 of file IntxUtils.cpp.
References moab::CartVect::length_squared(), MB_SUCCESS, moab::CartVect::normalize(), and moab::R.
    // first verify A, B, C, D are on the same sphere
    double R2              = R * R;
    const double Tolerance = 1.e-12 * R2;
        10 * Tolerance )
        return MB_FAILURE;
    if( n1.length_squared() < Tolerance ) return MB_FAILURE;
    CartVect n2 = c * d;
    if( n2.length_squared() < Tolerance ) return MB_FAILURE;
    CartVect n3 = n1 * n2;
    n3.normalize();
    n3 = R * n3;
    // the intersection is either n3 or -n3
    CartVect n4 = a * n3, n5 = n3 * b;
    if( n1 % n4 >= -Tolerance && n1 % n5 >= -Tolerance )
        // n3 is good for ab, see if it is good for cd
        n4 = c * n3;
        n5 = n3 * d;
        if( n2 % n4 >= -Tolerance && n2 % n5 >= -Tolerance )
            E[0] = n3[0];
            E[1] = n3[1];
            E[2] = n3[2];
        else
            return MB_FAILURE;
    else
        // try -n3
        n3 = -n3;
            n4 = c * n3;
            n5 = n3 * d;
                E[0] = n3[0];
                E[1] = n3[1];
                E[2] = n3[2];
            else
                return MB_FAILURE;
        else
            return MB_FAILURE;
    return MB_SUCCESS;
double moab::IntxUtils::oriented_spherical_angle ( double *  A,
double *  B,
double *  C
) [static]
Definition at line 814 of file IntxUtils.cpp.
References moab::angle().
Referenced by moab::IntxAreaUtils::area_spherical_polygon_girard(), and enforce_convexity().
    // assume the same radius, sphere at origin
    CartVect a( A ), b( B ), c( C );
    CartVect normalOAB = a * b;
    CartVect normalOCB = c * b;
    CartVect orient    = ( c - b ) * ( a - b );
    double ang         = angle( normalOAB, normalOCB );  // this is between 0 and M_PI
    if( ang != ang )
        // signal of a nan
        std::cout << a << " " << b << " " << c << "\n";
        std::cout << ang << "\n";
    if( orient % b < 0 ) return ( 2 * M_PI - ang );  // the other angle, supplement
    return ang;
ErrorCode moab::IntxUtils::remove_duplicate_vertices ( Interface mb,
double  merge_tol,
std::vector< Tag > &  tagList
) [static]
Definition at line 1894 of file IntxUtils.cpp.
References ErrorCode, moab::Interface::get_entities_by_dimension(), MB_CHK_ERR, MB_SUCCESS, moab::MergeMesh::merge_all(), moab::Interface::remove_entities(), and remove_padded_vertices().
    Range verts;
    ErrorCode rval = mb->get_entities_by_dimension( file_set, 0, verts );MB_CHK_ERR( rval );
    rval = mb->remove_entities( file_set, verts );MB_CHK_ERR( rval );
    MergeMesh mm( mb );
    // remove the vertices from the set, before merging
    rval = mm.merge_all( file_set, merge_tol );MB_CHK_ERR( rval );
    // now correct vertices that are repeated in polygons
    rval = remove_padded_vertices( mb, file_set, tagList );
    return MB_SUCCESS;
ErrorCode moab::IntxUtils::remove_padded_vertices ( Interface mb,
) [static]
Definition at line 1914 of file IntxUtils.cpp.
References moab::Interface::add_entities(), moab::Range::begin(), moab::Interface::create_element(), moab::Interface::delete_entities(), moab::Range::end(), ErrorCode, moab::Interface::get_connectivity(), moab::Interface::get_entities_by_dimension(), moab::Range::insert(), MB_CHK_ERR, MB_CHK_SET_ERR, MB_SUCCESS, MBPOLYGON, MBQUAD, MBTRI, moab::Interface::remove_entities(), moab::Interface::tag_get_data(), and moab::Interface::tag_set_data().
Referenced by moab::NCHelperDomain::create_mesh(), moab::NCHelperScrip::create_mesh(), and remove_duplicate_vertices().
    Range cells;
    ErrorCode rval = mb->get_entities_by_dimension( file_set, 2, cells );MB_CHK_ERR( rval );
    Range verts;
    rval = mb->get_connectivity( cells, verts );MB_CHK_ERR( rval );
    Range modifiedCells;  // will be deleted at the end; keep the gid
    Range newCells;
    for( Range::iterator cit = cells.begin(); cit != cells.end(); ++cit )
        EntityHandle cell          = *cit;
        const EntityHandle* connec = NULL;
        int num_verts              = 0;
        rval                       = mb->get_connectivity( cell, connec, num_verts );MB_CHK_SET_ERR( rval, "Failed to get connectivity" );
        std::vector< EntityHandle > newConnec;
        newConnec.push_back( connec[0] );  // at least one vertex
        int index    = 0;
        int new_size = 1;
        while( index < num_verts - 2 )
            int next_index = ( index + 1 );
            if( connec[next_index] != newConnec[new_size - 1] )
                newConnec.push_back( connec[next_index] );
                new_size++;
            index++;
        // add the last one only if different from previous and first node
        if( ( connec[num_verts - 1] != connec[num_verts - 2] ) && ( connec[num_verts - 1] != connec[0] ) )
            newConnec.push_back( connec[num_verts - 1] );
            new_size++;
        if( new_size < num_verts )
            // cout << "new cell from " << cell << " has only " << new_size << " vertices \n";
            modifiedCells.insert( cell );
            // create a new cell with type triangle, quad or polygon
            EntityType type = MBTRI;
            if( new_size == 3 )
                type = MBTRI;
            else if( new_size == 4 )
                type = MBQUAD;
            else if( new_size > 4 )
                type = MBPOLYGON;
            // create new cell
            rval = mb->create_element( type, &newConnec[0], new_size, newCell );MB_CHK_SET_ERR( rval, "Failed to create new cell" );
            // set the old id to the new element
            newCells.insert( newCell );
            double value;  // use the same value to reset the tags, even if the tags are int (like Global ID)
            for( size_t i = 0; i < tagList.size(); i++ )
                rval = mb->tag_get_data( tagList[i], &cell, 1, (void*)( &value ) );MB_CHK_SET_ERR( rval, "Failed to get tag value" );
                rval = mb->tag_set_data( tagList[i], &newCell, 1, (void*)( &value ) );MB_CHK_SET_ERR( rval, "Failed to set tag value on new cell" );
    rval = mb->remove_entities( file_set, modifiedCells );MB_CHK_SET_ERR( rval, "Failed to remove old cells from file set" );
    rval = mb->delete_entities( modifiedCells );MB_CHK_SET_ERR( rval, "Failed to delete old cells" );
    rval = mb->add_entities( file_set, newCells );MB_CHK_SET_ERR( rval, "Failed to add new cells to file set" );
    rval = mb->add_entities( file_set, verts );MB_CHK_SET_ERR( rval, "Failed to add verts to the file set" );
    return MB_SUCCESS;
ErrorCode moab::IntxUtils::reverse_gnomonic_projection ( const double &  c1,
const double &  c2,
double  R,
int  plane,
CartVect pos
) [static]
Definition at line 450 of file IntxUtils.cpp.
References MB_SUCCESS, and moab::R.
Referenced by moab::IntxRllCssphere::findNodes(), moab::Intx2MeshOnSphere::findNodes(), get_barycenters(), and moab::BoundBox::update_box_spherical_elem().
    // the new point will be on line beta*pos
    double len  = sqrt( c1 * c1 + c2 * c2 + R * R );
    double beta = R / len;  // it is less than 1, in general
    switch( plane )
        case 1: {
            // c1->y, c2->z
            pos[0] = beta * R;
            pos[1] = c1 * beta;
            pos[2] = c2 * beta;
            break;
        case 2: {
            // y = R -> zx
            pos[1] = R * beta;
            pos[2] = c1 * beta;
            pos[0] = c2 * beta;
            break;
        case 3: {
            // x=-R, -> yz
            pos[0] = -R * beta;
            pos[1] = -c1 * beta;  // the sign is to preserve orientation
            pos[2] = c2 * beta;
            break;
        case 4: {
            // y = -R
            pos[1] = -R * beta;
            pos[2] = -c1 * beta;  // the sign is to preserve orientation
            pos[0] = c2 * beta;
            break;
        case 5: {
            // z = -R
            pos[2] = -R * beta;
            pos[0] = -c1 * beta;  // the sign is to preserve orientation
            pos[1] = c2 * beta;
            break;
        case 6: {
            pos[2] = R * beta;
            pos[0] = c1 * beta;
            pos[1] = c2 * beta;
            break;
        default:
ErrorCode moab::IntxUtils::ScaleToRadius ( Interface mb,
EntityHandle  set,
double  R
) [static]
Definition at line 771 of file IntxUtils.cpp.
References moab::Range::begin(), moab::Range::end(), ErrorCode, moab::Interface::get_coords(), moab::Interface::get_entities_by_type(), moab::CartVect::length(), MB_SUCCESS, MBVERTEX, and moab::Interface::set_coords().
Referenced by CreateTempestMesh(), global_gnomonic_projection(), and main().
    Range nodes;
    ErrorCode rval = mb->get_entities_by_type( set, MBVERTEX, nodes, true );  // recursive
    if( rval != moab::MB_SUCCESS ) return rval;
    // one by one, get the node and project it on the sphere, with a radius given
    // the center of the sphere is at 0,0,0
    for( Range::iterator nit = nodes.begin(); nit != nodes.end(); ++nit )
        EntityHandle nd = *nit;
        CartVect pos;
        rval = mb->get_coords( &nd, 1, (double*)&( pos[0] ) );
        double len = pos.length();
        if( len == 0. ) return MB_FAILURE;
        pos  = R / len * pos;
        rval = mb->set_coords( &nd, 1, (double*)&( pos[0] ) );
    return MB_SUCCESS;
int moab::IntxUtils::SortAndRemoveDoubles2 ( double *  P,
int &  nP,
double  epsilon
) [static]
Definition at line 98 of file IntxUtils.cpp.
References moab::angleAndIndex::angle, moab::angleCompare(), dist2(), moab::angleAndIndex::index, and MAXEDGES.
    if( nP < 2 ) return 0;  // nothing to do
    // center of gravity for the points
    double c[2] = {0., 0.};
    int k       = 0;
    for( k = 0; k < nP; k++ )
        c[0] += P[2 * k];
        c[1] += P[2 * k + 1];
    c[0] /= nP;
    c[1] /= nP;
    // how many? we dimensioned P at MAXEDGES*10; so we imply we could have at most 5*MAXEDGES
    // intersection points
    struct angleAndIndex pairAngleIndex[5 * MAXEDGES];
        double x = P[2 * k] - c[0], y = P[2 * k + 1] - c[1];
        if( x != 0. || y != 0. )
            pairAngleIndex[k].angle = atan2( y, x );
        else
            pairAngleIndex[k].angle = 0;
            // it would mean that the cells are touching at a vertex
        pairAngleIndex[k].index = k;
    // this should be faster than the bubble sort we had before
    std::sort( pairAngleIndex, pairAngleIndex + nP, angleCompare );
    // copy now to a new double array
    double PCopy[10 * MAXEDGES];  // the same dimension as P; very conservative, but faster than
                                  // reallocate for a vector
    for( k = 0; k < nP; k++ )     // index will show where it should go now;
        int ck           = pairAngleIndex[k].index;
        PCopy[2 * k]     = P[2 * ck];
        PCopy[2 * k + 1] = P[2 * ck + 1];
    // now copy from PCopy over original P location
    std::copy( PCopy, PCopy + 2 * nP, P );
    // eliminate duplicates, finally
    int i = 0, j = 1;  // the next one; j may advance faster than i
    // check the unit
    // double epsilon_1 = 1.e-5; // these are cm; 2 points are the same if the distance is less
    // than 1.e-5 cm
    while( j < nP )
        double d2 = dist2( &P[2 * i], &P[2 * j] );
        if( d2 > epsilon_1 )
            i++;
            P[2 * i]     = P[2 * j];
            P[2 * i + 1] = P[2 * j + 1];
        j++;
    // test also the last point with the first one (index 0)
    // the first one could be at -PI; last one could be at +PI, according to atan2 span
    double d2 = dist2( P, &P[2 * i] );  // check the first and last points (ordered from -pi to +pi)
        nP = i + 1;
    else
        nP = i;            // effectively delete the last point (that would have been the same with first)
    if( nP == 0 ) nP = 1;  // we should be left with at least one point we already tested if nP is 0 originally
    return 0;
Definition at line 762 of file IntxUtils.cpp.
References moab::IntxUtils::SphereCoords::lat, moab::IntxUtils::SphereCoords::lon, and moab::IntxUtils::SphereCoords::R.
Referenced by add_field_value(), IntxUtilsCSLAM::departure_point_case1(), departure_point_swirl(), departure_point_swirl_rot(), main(), set_density(), and IntxUtilsCSLAM::smooth_field().
    CartVect res;
    res[0] = sc.R * cos( sc.lat ) * cos( sc.lon );  // x coordinate
    res[1] = sc.R * cos( sc.lat ) * sin( sc.lon );  // y
    res[2] = sc.R * sin( sc.lat );                  // z
    return res;
void moab::IntxUtils::transform_coordinates ( double *  avg_position,
int  projection_type
) [static]
Definition at line 671 of file IntxUtils.cpp.
References decide_gnomonic_plane(), gnomonic_projection(), gnomonic_unroll(), and moab::R.
    if( projection_type == 1 )
        double R =
            avg_position[0] * avg_position[0] + avg_position[1] * avg_position[1] + avg_position[2] * avg_position[2];
        R               = sqrt( R );
        double lat      = asin( avg_position[2] / R );
        double lon      = atan2( avg_position[1], avg_position[0] );
        avg_position[0] = lon;
        avg_position[1] = lat;
        avg_position[2] = R;
    else if( projection_type == 2 )  // gnomonic projection
        CartVect pos( avg_position );
        int gplane;
        IntxUtils::decide_gnomonic_plane( pos, gplane );
        IntxUtils::gnomonic_projection( pos, 1.0, gplane, avg_position[0], avg_position[1] );
        avg_position[2] = 0;
        IntxUtils::gnomonic_unroll( avg_position[0], avg_position[1], 1.0, gplane );
List of all members.
