parse.cpp File Reference
#include "parse.hpp"
#include <iostream>
#include <cctype>
#include <cstdlib>
#include <cstring>
+ Include dependency graph for parse.cpp:
Functions
void tag_syntax (std::ostream &s)
static bool is_platform_little_endian ()
static void * parse_values (const char *vals, DataType type, int size)
static unsigned char * parse_opaque_value (const char *vals, int size)
template<typename T >
Tparse_values_typed (const char *vals, int size)
int parse_value (const char *&iter, T &value)
static int hexdigit (char c)
template<>
int parse_value< double > (const char *&iter, double &value)
int parse_tag_spec (char *name, TagSpec &result, Interface *iface)
int parse_tag_create (char *name, TagSpec &result, Interface *iface)
Function Documentation
int hexdigit ( char  c) [static]
Definition at line 100 of file parse.cpp.
Referenced by parse_opaque_value().
    if( c >= '0' && c <= '9' )
        return c - '0';
    else if( c >= 'a' && c <= 'f' )
        return 10 + c - 'a';
    else if( c >= 'A' && c <= 'F' )
        return 10 + c - 'A';
    else
        return -1;
static bool is_platform_little_endian ( ) [inline, static]
Definition at line 65 of file parse.cpp.
    static const unsigned int one = 1;
    static const bool little      = !*( (char*)&one );
    return little;
unsigned char * parse_opaque_value ( const char *  vals,
int  size
) [static]
Definition at line 112 of file parse.cpp.
References hexdigit(), is_platform_little_endian(), and size.
Referenced by parse_values().
    unsigned char* data = (unsigned char*)malloc( size );
    if( vals[0] && vals[0] == '0' && vals[1] && toupper( vals[1] ) == 'X' )
        unsigned char *iter, *end;
        int step;
        if( is_platform_little_endian() )
            iter = data;
            end  = data + size;
            step = 1;
        else
            iter = data + size - 1;
            end  = data - 1;
            step = -1;
        const char* vals_end  = vals + 1;
        const char* vals_iter = vals + strlen( vals ) - 1;
        for( ; iter != end; iter += step )
            int less = 0;
            int most = 0;
            if( vals_iter != vals_end )
                less = hexdigit( *vals_iter );
                --vals_iter;
                most = hexdigit( *vals_iter );
                --vals_iter;
            if( less < 0 || most < 0 )
                std::cerr << "Error parsing hex value: " << vals << std::endl;
                free( data );
                return 0;
            *iter = 16 * most + less;
    else
        memset( data, 0, size );
        strcpy( (char*)data, vals + 2 );
    return data;
int parse_tag_create ( char *  name,
TagSpec result,
Interface iface
Definition at line 275 of file parse.cpp.
References ErrorCode, TagSpec::handle, MB_ENTITY_NOT_FOUND, MB_SUCCESS, MB_TAG_ANY, MB_TAG_CREAT, MB_TAG_SPARSE, MB_TYPE_BIT, MB_TYPE_DOUBLE, MB_TYPE_HANDLE, MB_TYPE_INTEGER, MB_TYPE_OPAQUE, parse_values(), moab::Interface::tag_get_data_type(), moab::Interface::tag_get_default_value(), moab::Interface::tag_get_handle(), moab::Interface::tag_get_length(), and TagSpec::value.
Referenced by main().
    // split at '=' signs
    char* eq1 = strrchr( name, '=' );
    if( !eq1 )
        std::cerr << "Invalid tag specification: " << name << std::endl;
        return 1;
    *eq1 = '\0';
    ++eq1;
    char *type_str = eq1, *val = 0;
    char* eq2 = strrchr( name, '=' );
    if( eq2 )
        *eq2 = '\0';
        ++eq2;
        val      = ( '\0' == eq1[0] ) ? 0 : eq1;
        type_str = eq2;
    // parse type data
    char* size_str = strchr( type_str, ':' );
    if( !size_str )
        std::cerr << "Invalid tag type specification: " << type_str << std::endl;
        return 1;
    *size_str = '\0';
    ++size_str;
    DataType type;
    if( !strcmp( type_str, "int" ) )
        type = MB_TYPE_INTEGER;
    else if( !strcmp( type_str, "double" ) )
        type = MB_TYPE_DOUBLE;
    else if( !strcmp( type_str, "bit" ) )
        type = MB_TYPE_BIT;
    else if( !strcmp( type_str, "handle" ) )
        type = MB_TYPE_HANDLE;
    else if( !strcmp( type_str, "opaque" ) )
        type = MB_TYPE_OPAQUE;
    else
        return 1;
    char* end_ptr;
    int count = (int)strtol( size_str, &end_ptr, 0 );
    if( !*size_str || *end_ptr || count < 1 )
        std::cerr << "Invalid tag size specification: " << size_str << std::endl;
        return 1;
    // parse default value
    result.value = 0;
    if( val )
        result.value = parse_values( val, type, count );
        if( !result.value ) return 1;
    // check if tag exists
    if( MB_SUCCESS == iface->tag_get_handle( name, 0, MB_TYPE_OPAQUE, result.handle, MB_TAG_ANY ) )
        // make sure it matches
        DataType etype;
        int esize;
        if( MB_SUCCESS != iface->tag_get_data_type( result.handle, etype ) ||
            MB_SUCCESS != iface->tag_get_length( result.handle, esize ) )
            std::cerr << "Error accessing properties of tag: " << name << std::endl;
            return 3;
        if( etype != type || esize != count )
            std::cerr << "Tag already exists with different type: " << name << std::endl;
            return 1;
        std::vector< unsigned char > value( esize );
        if( result.value )
            ErrorCode rval = iface->tag_get_default_value( result.handle, &value[0] );
            if( rval != MB_ENTITY_NOT_FOUND && rval != MB_SUCCESS )
                std::cerr << "Error checking default value of tag: " << name << std::endl;
                return 3;
            else if( rval == MB_ENTITY_NOT_FOUND || memcmp( &value[0], result.value, esize ) )
                std::cerr << "Tag already exists and default value doesn't match: " << name << std::endl;
                return 1;
    else
        ErrorCode rval =
            iface->tag_get_handle( name, count, type, result.handle, MB_TAG_SPARSE | MB_TAG_CREAT, result.value );
        if( MB_SUCCESS != rval )
            std::cerr << "Failed to create tag: " << name << std::endl;
            return 3;
    return 0;
int parse_tag_spec ( char *  name,
TagSpec result,
Interface iface
Definition at line 218 of file parse.cpp.
References ErrorCode, TagSpec::handle, MB_SUCCESS, MB_TAG_ANY, MB_TAG_NOT_FOUND, MB_TYPE_OPAQUE, parse_values(), size, moab::Interface::tag_get_data_type(), moab::Interface::tag_get_handle(), moab::Interface::tag_get_length(), and TagSpec::value.
    //  Separate optional tag value from tag name
    char* val = strrchr( name, '=' );
    if( val )
        // zero-length tag name>
        if( val == name )
            std::cerr << "Cannot create tag w/out name: " << name << std::endl;
            return 1;
        *val = '\0';
        if( !*++val )  // if name ends with an '=', set val to NULL.
            val = 0;
    // Get tag
    ErrorCode rval = iface->tag_get_handle( name, 0, MB_TYPE_OPAQUE, result.handle, MB_TAG_ANY );
    if( MB_TAG_NOT_FOUND == rval )
        std::cerr << "Tag not found: " << name << std::endl;
        return 2;
    else if( MB_SUCCESS != rval )
        std::cerr << "Error retrieving tag handle: " << name << std::endl;
        return 3;
    // Parse tag value
    result.value = 0;
    if( val )
        DataType type;
        rval = iface->tag_get_data_type( result.handle, type );
            std::cerr << "Error retrieving type for tag: " << name << std::endl;
            return 3;
        int size;
        rval = iface->tag_get_length( result.handle, size );
            std::cerr << "Error retrieving size for tag: " << name << std::endl;
            return 3;
        result.value = parse_values( val, type, size );
    return 0;
int parse_value ( const char *&  iter,
T value
Definition at line 73 of file parse.cpp.
References T.
    char* endptr;
    long parsed_val = strtol( iter, &endptr, 0 );
    if( endptr == iter ) return 1;
    iter = endptr;
    value = (T)parsed_val;
    if( (long)value != parsed_val )
        std::cerr << "Value too large: " << iter << std::endl;
        return 2;
    return 0;
template<>
int parse_value< double > ( const char *&  iter,
double &  value
Definition at line 91 of file parse.cpp.
    char* endptr;
    value = strtod( iter, &endptr );
    iter = endptr;
    return 0;
void * parse_values ( const char *  vals,
DataType  type,
int  size
) [static]
Definition at line 198 of file parse.cpp.
References MB_TYPE_BIT, MB_TYPE_DOUBLE, MB_TYPE_HANDLE, MB_TYPE_INTEGER, MB_TYPE_OPAQUE, parse_opaque_value(), and size.
Referenced by parse_tag_create(), and parse_tag_spec().
    switch( type )
        case MB_TYPE_OPAQUE:
            return parse_opaque_value( vals, size );
        case MB_TYPE_INTEGER:
            return parse_values_typed< int >( vals, size );
        case MB_TYPE_DOUBLE:
            return parse_values_typed< double >( vals, size );
        case MB_TYPE_BIT:
            return parse_values_typed< bittype >( vals, size );
        case MB_TYPE_HANDLE:
            return parse_values_typed< EntityHandle >( vals, size );
        default:
            std::cerr << "Unknown tag data type: " << (int)type << std::endl;
            return 0;
T * parse_values_typed ( const char *  vals,
int  size
Definition at line 168 of file parse.cpp.
References T.
    if( !count ) return 0;
    T* data = (T*)malloc( count * sizeof( T ) );
    T* end  = data + count;
    if( parse_value< T >( vals, *data ) )
        free( data );
        return 0;
    for( T* ptr = data + 1; ptr != end; ++ptr )
        if( *vals != ',' )
            std::cerr << "Expected ',' separating tag values: " << vals << std::endl;
            free( data );
            return 0;
        ++vals;
        if( parse_value< T >( vals, *ptr ) )
            free( data );
            return 0;
    return data;
void tag_syntax ( std::ostream &  s)
Definition at line 10 of file parse.cpp.
Referenced by usage().
    s << "Tags are specified as <name>=[value], where the tag value " << std::endl
      << "is optional." << std::endl
      << std::endl
      << "Values of integral types (INTEGER, BIT, and HANDLE) are " << std::endl
      << "specified using standard C integer notation (a 0x prefix " << std::endl
      << "for hexidecimal, 0 prefix for octal, and no prefix for " << std::endl
      << "decimal.)  The value of an opaque tag is interpreted as " << std::endl
      << "either a integral value or a character string. If the tag " << std::endl
      << "value begins with the prefix 0x it will be interpreted as a " << std::endl
      << "hexidecimal (base-16) number.  If the value does not begin " << std::endl
      << "with the 0x prefix, it is interpreted as a character string." << std::endl
      << "Characater strings will be padded with null characters as" << std::endl
      << "necessary to fill the tag." << std::endl
      << "Floating-point (real) values must be specified in base-10." << std::endl
      << "C exponential notation (e.g. 1e-10) is accepted." << std::endl
      << std::endl
      << "If the tag is an array of integral or floating-point values " << std::endl
      << "then the tag value must be specified as a comma-separated " << std::endl
      << "list, with NO spaces." << std::endl
      << std::endl
      << "Tags are created with the syntax name=type:size[=default_value]." << std::endl
      << "where type is one of {int,double,opaque,handle,bit} and size is " << std::endl
      << "the number of values of the specified type, or the number of " << std::endl
      << "bytes if the type is 'opaque',  A default value for the tag may " << std::endl
      << "be specified." << std::endl;
