sets.c File Reference
#include <H5Tpublic.h>
#include <H5Dpublic.h>
#include <H5Gpublic.h>
#include <H5Spublic.h>
#include <H5Ppublic.h>
#include "mhdf.h"
#include "util.h"
#include "file-handle.h"
#include "status.h"
#include "names-and-paths.h"
+ Include dependency graph for sets.c:
Enumerations
enum  SetMetaCol { CONTENT = 0, CHILDREN = 1, PARENTS = 2, FLAGS = 3 }
Functions
int mhdf_haveSets (mhdf_FileHandle file, int *have_data, int *have_child, int *have_parent, mhdf_Status *status)
 Check if file contains any sets.
hid_t mhdf_createSetMeta (mhdf_FileHandle file, long num_sets, long *first_id_out, mhdf_Status *status)
 Create table holding list of meshsets and their properties.
hid_t mhdf_openSetMeta (mhdf_FileHandle file, long *num_sets, long *first_id_out, mhdf_Status *status)
 Open table holding list of meshsets and their properties.
hid_t mhdf_openSetMetaSimple (mhdf_FileHandle file, mhdf_Status *status)
static int mhdf_readwriteSetMeta (hid_t table_id, int read, long offset, long count, hid_t type, void *data, hid_t prop, mhdf_Status *status)
void mhdf_readSetMeta (hid_t table_id, long offset, long count, hid_t type, void *data, mhdf_Status *status)
 Read list of sets and meta-information about sets.
void mhdf_readSetMetaWithOpt (hid_t table_id, long offset, long count, hid_t type, void *data, hid_t prop, mhdf_Status *status)
void mhdf_writeSetMeta (hid_t table_id, long offset, long count, hid_t type, const void *data, mhdf_Status *status)
 Write list of sets and meta-information about sets.
void mhdf_writeSetMetaWithOpt (hid_t table_id, long offset, long count, hid_t type, const void *data, hid_t prop, mhdf_Status *status)
static int mhdf_readSetMetaColumn (hid_t table_id, enum SetMetaCol column, long offset, long count, hid_t type, void *data, hid_t prop, mhdf_Status *status)
void mhdf_readSetFlags (hid_t table_id, long offset, long count, hid_t type, void *data, mhdf_Status *status)
 Read only the flags portion of the set description table.
void mhdf_readSetFlagsWithOpt (hid_t table_id, long offset, long count, hid_t type, void *data, hid_t prop, mhdf_Status *status)
void mhdf_readSetContentEndIndices (hid_t table_id, long offset, long count, hid_t type, void *data, mhdf_Status *status)
 Read only the content end indices portion of the set description table.
void mhdf_readSetContentEndIndicesWithOpt (hid_t table_id, long offset, long count, hid_t type, void *data, hid_t prop, mhdf_Status *status)
void mhdf_readSetChildEndIndices (hid_t table_id, long offset, long count, hid_t type, void *data, mhdf_Status *status)
 Read only the child end indices portion of the set description table.
void mhdf_readSetChildEndIndicesWithOpt (hid_t table_id, long offset, long count, hid_t type, void *data, hid_t prop, mhdf_Status *status)
void mhdf_readSetParentEndIndices (hid_t table_id, long offset, long count, hid_t type, void *data, mhdf_Status *status)
 Read only the parent end indices portion of the set description table.
void mhdf_readSetParentEndIndicesWithOpt (hid_t table_id, long offset, long count, hid_t type, void *data, hid_t prop, mhdf_Status *status)
hid_t mhdf_createSetData (mhdf_FileHandle file_handle, long data_list_size, mhdf_Status *status)
 Create file object to hold list of meshset contents.
hid_t mhdf_openSetData (mhdf_FileHandle file_handle, long *data_list_size_out, mhdf_Status *status)
 Open the file object for the meshset contents.
void mhdf_writeSetData (hid_t table_id, long offset, long count, hid_t type, const void *data, mhdf_Status *status)
 Write set contents.
void mhdf_writeSetDataWithOpt (hid_t table_id, long offset, long count, hid_t type, const void *data, hid_t prop, mhdf_Status *status)
void mhdf_readSetData (hid_t table_id, long offset, long count, hid_t type, void *data, mhdf_Status *status)
 Read set contents.
void mhdf_readSetDataWithOpt (hid_t table_id, long offset, long count, hid_t type, void *data, hid_t prop, mhdf_Status *status)
hid_t mhdf_createSetChildren (mhdf_FileHandle file_handle, long child_list_size, mhdf_Status *status)
 Create file object for storing the set child list.
hid_t mhdf_openSetChildren (mhdf_FileHandle file_handle, long *child_list_size, mhdf_Status *status)
 Open the file object containing the set child list.
hid_t mhdf_createSetParents (mhdf_FileHandle file_handle, long parent_list_size, mhdf_Status *status)
 Create file object for storing the set parent list.
hid_t mhdf_openSetParents (mhdf_FileHandle file_handle, long *parent_list_size, mhdf_Status *status)
 Open the file object containing the set parent list.
void mhdf_writeSetParentsChildren (hid_t table_id, long offset, long count, hid_t type, const void *data, mhdf_Status *status)
 Write set parent/child list.
void mhdf_writeSetParentsChildrenWithOpt (hid_t table_id, long offset, long count, hid_t type, const void *data, hid_t prop, mhdf_Status *status)
void mhdf_readSetParentsChildren (hid_t table_id, long offset, long count, hid_t type, void *data, mhdf_Status *status)
 Read set parent/child list.
void mhdf_readSetParentsChildrenWithOpt (hid_t table_id, long offset, long count, hid_t type, void *data, hid_t prop, mhdf_Status *status)
Enumeration Type Documentation
enum SetMetaCol
Enumerator:
CONTENT
CHILDREN
PARENTS
FLAGS
Definition at line 405 of file sets.c.
    CONTENT  = 0,
    CHILDREN = 1,
    PARENTS  = 2,
    FLAGS    = 3
Function Documentation
static int mhdf_readSetMetaColumn ( hid_t  table_id,
long  offset,
long  count,
hid_t  type,
void *  data,
hid_t  prop,
mhdf_Status status
) [static]
Definition at line 413 of file sets.c.
References FLAGS, mhdf_setFail(), mhdf_setOkay(), and PARENTS.
Referenced by mhdf_readSetChildEndIndices(), mhdf_readSetChildEndIndicesWithOpt(), mhdf_readSetContentEndIndices(), mhdf_readSetContentEndIndicesWithOpt(), mhdf_readSetFlags(), mhdf_readSetFlagsWithOpt(), mhdf_readSetParentEndIndices(), and mhdf_readSetParentEndIndicesWithOpt().
    hid_t slab_id, mem_id;
    hsize_t offsets[2], counts[2], mcount = count;
    herr_t rval = 0;
    int dims;
    const int fill_val = -1;
    if( offset < 0 || count < 0 )
        mhdf_setFail( status,
                      "Invalid input for reading set description column: "
                      "offset = %ld, count = %ld\n",
                      offset, count );
        return 0;
    /* Get dimensions of table, and check against requested count and offset */
    slab_id = H5Dget_space( table_id );
    if( slab_id < 0 )
        mhdf_setFail( status, "Internal error calling H5Dget_space." );
        return 0;
    dims = H5Sget_simple_extent_ndims( slab_id );
    if( dims != 2 )
        H5Sclose( slab_id );
        mhdf_setFail( status, "Internal error: unexpected dataset rank: %d.", dims );
        return 0;
    dims = H5Sget_simple_extent_dims( slab_id, counts, NULL );
    if( dims < 0 )
        mhdf_setFail( status, "Internal error calling H5Sget_simple_extend_dims." );
        return 0;
    if( (unsigned long)( offset + count ) > counts[0] )
        mhdf_setFail( status, "Requested read of rows %ld to %ld of a %ld row table.\n", offset, offset + count - 1,
                      (long)counts[0] );
        return 0;
    /* Create a slab definition for the block of memory we're reading into */
    mem_id = H5Screate_simple( 1, &mcount, NULL );
    if( mem_id < 0 )
        mhdf_setFail( status, "Internal error calling H5Screate_simple." );
        return 0;
    /* Old, 3-column table.
     * New table is {contents, children, parents, flags}
     * Old table is {contents, children, flags}
     * If asking for parents, just return zeros.
     * If asking for flags, fix column value.
    offsets[1] = column;
    if( counts[1] == 3 )
        if( column == PARENTS )
            rval = H5Dfill( &fill_val, H5T_NATIVE_INT, data, type, mem_id );
            H5Sclose( mem_id );
            if( rval < 0 )
                mhdf_setFail( status, "Internal error calling H5Dfill" );
                return 0;
            else
                mhdf_setOkay( status );
                return 1;
        else if( column == FLAGS )
            --offsets[1];
    else if( counts[1] != 4 )
        H5Sclose( mem_id );
        mhdf_setFail( status, "Invalid dimension for meshset metadata table." );
        return 0;
    /* Create a slab defintion for the portion of the table we want to read. */
    /* offsets[1] was initialized in the above block of code. */
    offsets[0] = (hsize_t)offset;
    counts[0]  = (hsize_t)count;
    counts[1]  = 1; /* one column */
    if( count )
        rval = H5Sselect_hyperslab( slab_id, H5S_SELECT_SET, offsets, NULL, counts, NULL );
    else
        rval = H5Sselect_none( slab_id );
    if( rval < 0 )
        H5Sclose( mem_id );
        mhdf_setFail( status, "Internal error calling H5Sselect_hyperslab." );
        return 0;
    /* Read the data */
    rval = H5Dread( table_id, type, mem_id, slab_id, prop, data );
    H5Sclose( mem_id );
    if( rval < 0 )
        mhdf_setFail( status, "Internal error calling H5Dread." );
        return 0;
    return 1;
static int mhdf_readwriteSetMeta ( hid_t  table_id,
int  read,
long  offset,
long  count,
hid_t  type,
void *  data,
hid_t  prop,
mhdf_Status status
) [static]
Definition at line 191 of file sets.c.
References mhdf_setFail(), and mhdf_setOkay().
Referenced by mhdf_readSetMeta(), mhdf_readSetMetaWithOpt(), mhdf_writeSetMeta(), and mhdf_writeSetMetaWithOpt().
    hid_t slab_id, sslab_id, smem_id, mem_id;
    hsize_t offsets[2], counts[2], mcounts[2], moffsets[2] = { 0, 0 };
    herr_t rval = 0;
    int dims, i;
    const hsize_t one  = 1;
    mcounts[0] = count;
    mcounts[1] = 4;
                      "Invalid input for %s: "
                      read ? "read" : "write", offset, count );
        return 0;
    if( slab_id < 0 )
        return 0;
    if( dims != 2 )
        return 0;
    if( dims < 0 )
        return 0;
        mhdf_setFail( status, "Requested %s of rows %ld to %ld of a %ld row table.\n", read ? "read" : "write", offset,
                      offset + count - 1, (long)counts[dims - 1] );
        return 0;
    if( count )
        mem_id = H5Screate_simple( dims, mcounts, NULL );
    else
    { /* special case for 'NULL' read during collective parallel IO */
        mem_id = H5Screate_simple( 1, &one, NULL );
        if( mem_id && 0 > H5Sselect_none( mem_id ) )
            H5Sclose( mem_id );
            mem_id = -1;
    if( mem_id < 0 )
        return 0;
    /* Normal table: 4 columns */
    if( counts[1] == 4 )
        offsets[1] = 0;
        if( count )
        else /* special case for 'NULL' read during collective parallel IO */
        if( rval < 0 )
            H5Sclose( mem_id );
            return 0;
        if( read )
        else
            rval = H5Dwrite( table_id, type, mem_id, slab_id, prop, data );
    /* Old table: 3 columns, no parent link counts */
    else if( counts[1] == 3 )
        rval = 0;
        for( i = 0; i < 3 && rval >= 0; ++i )
            smem_id  = H5Scopy( mem_id );
            sslab_id = H5Scopy( slab_id );
            if( smem_id < 0 || sslab_id < 0 )
                if( smem_id >= 0 ) H5Sclose( smem_id );
                mhdf_setFail( status, "Internal error calling H5Scopy." );
                return 0;
            counts[1]  = 1;
            offsets[1] = i;
            if( count )
                rval = H5Sselect_hyperslab( sslab_id, H5S_SELECT_SET, offsets, NULL, counts, NULL );
            else
                rval = H5Sselect_none( sslab_id );
            if( rval < 0 )
                H5Sclose( mem_id );
                return 0;
            mcounts[1]  = 1;
            moffsets[1] = ( i == 2 ) ? 3 : i;
            rval        = H5Sselect_hyperslab( smem_id, H5S_SELECT_SET, moffsets, NULL, mcounts, NULL );
            if( rval < 0 )
                H5Sclose( sslab_id );
                H5Sclose( mem_id );
                return 0;
            if( read )
                rval = H5Dread( table_id, type, smem_id, sslab_id, prop, data );
            else
                rval = H5Dwrite( table_id, type, smem_id, sslab_id, prop, data );
        if( read && rval >= 0 )
            mcounts[1]  = 1;
            moffsets[1] = 2;
            H5Sselect_hyperslab( mem_id, H5S_SELECT_SET, moffsets, NULL, mcounts, NULL );
    else
        H5Sclose( mem_id );
        return 0;
    H5Sclose( mem_id );
    if( rval < 0 )
        mhdf_setFail( status, "Internal error calling H5D%s.", read ? "read" : "write" );
        return 0;
    return 1;
