tags.c File Reference
#include <stdlib.h>
#include <string.h>
#include <H5Tpublic.h>
#include <H5Gpublic.h>
#include <H5Dpublic.h>
#include <H5Spublic.h>
#include <H5Apublic.h>
#include <H5Ppublic.h>
#include "status.h"
#include "file-handle.h"
#include "mhdf.h"
#include "util.h"
#include "names-and-paths.h"
+ Include dependency graph for tags.c:
Functions
hid_t mhdf_getNativeType (hid_t input_type, int size, mhdf_Status *status)
 Make type native-endian.
static hid_t get_tag (mhdf_FileHandle file_handle, const char *tag_name, hid_t *id_type, mhdf_Status *status)
static hid_t get_tag_type (FileHandle *file_ptr, const char *tag_path, mhdf_Status *status)
static int store_tag_val_in_attrib (hid_t tag_id, const char *attrib_name, hid_t type_id, const void *value, hsize_t value_size, mhdf_Status *status)
static hid_t create_tag_common (mhdf_FileHandle file_handle, const char *tag_name, enum mhdf_TagDataType tag_type, int size, int storage, const void *default_value, int default_value_size_in, const void *global_value, int global_value_size_in, hid_t hdf_type, hid_t hdf_base_type, mhdf_Status *status)
hid_t mhdf_getTagDataType (mhdf_FileHandle file_handle, const char *tag_name, mhdf_Status *status)
 Get handle to HDF5 type object for tag data.
void mhdf_createTag (mhdf_FileHandle file_handle, const char *tag_name, enum mhdf_TagDataType tag_type, int size, int storage, const void *default_value, const void *global_value, hid_t hdf_type, hid_t hdf_base_type, mhdf_Status *status)
 Add a tag to the file.
void mhdf_createVarLenTag (mhdf_FileHandle file_handle, const char *tag_name, enum mhdf_TagDataType tag_type, int storage, const void *default_value, int default_value_length, const void *global_value, int global_value_length, hid_t hdf_type, hid_t hdf_base_type, mhdf_Status *status)
 Add variable-length tag to file.
int mhdf_getNumberTags (mhdf_FileHandle file_handle, mhdf_Status *status)
 Get the number of tags in the file.
char ** mhdf_getTagNames (mhdf_FileHandle file_handle, int *num_names_out, mhdf_Status *status)
 Get the name for each tag defined in the file.
static int get_attrib_array_length_handle (hid_t attrib_id)
static int get_attrib_array_length_name (hid_t file, const char *path)
void mhdf_getTagInfo (mhdf_FileHandle file_handle, const char *tag_name, enum mhdf_TagDataType *class_out, int *size_out, int *tstt_storage_out, int *have_default_out, int *have_global_out, int *have_sparse_out, mhdf_Status *status)
 Get the description of a specified tag.
static int read_tag_attrib_data (hid_t tag_id, const char *attrib_name, hid_t type_id, void *data, int is_var_len, mhdf_Status *status)
void mhdf_getTagValues (mhdf_FileHandle file_handle, const char *tag_name, hid_t output_data_type, void *default_value, void *global_value, mhdf_Status *status)
 Get the default and global values of the tag.
int mhdf_haveDenseTag (mhdf_FileHandle file_handle, const char *tag_name, const char *type_handle, mhdf_Status *status)
 Check if the file contains dense tag data for the specified tag and element group.
hid_t mhdf_createDenseTagData (mhdf_FileHandle file_handle, const char *tag_name, const char *type_handle, long num_values, mhdf_Status *status)
 Create an object to hold dense tag values for a given element group.
hid_t mhdf_openDenseTagData (mhdf_FileHandle file_handle, const char *tag_name, const char *type_handle, long *num_values_out, mhdf_Status *status)
 Open the object containing dense tag values for a given element group.
void mhdf_createSparseTagData (mhdf_FileHandle file_handle, const char *tag_name, long num_values, hid_t handles_out[2], mhdf_Status *status)
 Create file objects to store sparse tag data.
void mhdf_createVarLenTagData (mhdf_FileHandle file_handle, const char *tag_name, long num_entities, long num_values, hid_t handles_out[3], mhdf_Status *status)
 Create file objects to store (sparse) variable-length tag data.
void mhdf_openSparseTagData (mhdf_FileHandle file_handle, const char *tag_name, long *num_entity_out, long *num_values_out, hid_t handles_out[3], mhdf_Status *status)
 Create file objects to read sparse tag data.
void mhdf_writeSparseTagEntities (hid_t table_id, long offset, long count, hid_t int_type, const void *id_list, mhdf_Status *status)
 Write Global ID list for sparse tag data.
void mhdf_writeSparseTagEntitiesWithOpt (hid_t table_id, long offset, long count, hid_t int_type, const void *id_list, hid_t io_prop, mhdf_Status *status)
void mhdf_writeTagValues (hid_t table_id, long offset, long count, hid_t tag_type, const void *tag_data, mhdf_Status *status)
 Write tag values.
void mhdf_writeTagValuesWithOpt (hid_t table_id, long offset, long count, hid_t tag_type, const void *tag_data, hid_t io_prop, mhdf_Status *status)
void mhdf_writeSparseTagIndices (hid_t table_id, long offset, long count, hid_t int_type, const void *indices, mhdf_Status *status)
 Write sparse tag end indices for variable-length tag data.
void mhdf_writeSparseTagIndicesWithOpt (hid_t table_id, long offset, long count, hid_t int_type, const void *indices, hid_t io_prop, mhdf_Status *status)
void mhdf_readSparseTagEntities (hid_t table_id, long offset, long count, hid_t int_type, void *id_list, mhdf_Status *status)
 Read Global ID list for sparse tag data.
void mhdf_readSparseTagEntitiesWithOpt (hid_t table_id, long offset, long count, hid_t int_type, void *id_list, hid_t io_prop, mhdf_Status *status)
void mhdf_readTagValues (hid_t table_id, long offset, long count, hid_t tag_type, void *tag_data, mhdf_Status *status)
 Read tag values.
void mhdf_readTagValuesWithOpt (hid_t table_id, long offset, long count, hid_t tag_type, void *tag_data, hid_t io_prop, mhdf_Status *status)
void mhdf_readSparseTagIndices (hid_t table_id, long offset, long count, hid_t int_type, void *indices, mhdf_Status *status)
 Read sparse tag end indices for variable-length tag data.
void mhdf_readSparseTagIndicesWithOpt (hid_t table_id, long offset, long count, hid_t int_type, void *indices, hid_t io_prop, mhdf_Status *status)
Function Documentation
static hid_t create_tag_common ( mhdf_FileHandle  file_handle,
const char *  tag_name,
int  size,
int  storage,
const void *  default_value,
const void *  global_value,
hid_t  hdf_type,
mhdf_Status status
) [static]
Definition at line 235 of file tags.c.
References struct_FileHandle::hdf_handle, mhdf_BITFIELD, mhdf_BOOLEAN, mhdf_check_valid_file(), mhdf_create_scalar_attrib(), mhdf_ENTITY_ID, mhdf_FLOAT, mhdf_INTEGER, mhdf_name_to_path_copy(), mhdf_OPAQUE, mhdf_setFail(), mhdf_setOkay(), store_tag_val_in_attrib(), TAG_DEFAULT_ATTRIB, TAG_GLOBAL_ATTRIB, TAG_GROUP, TAG_HANDLE_TYPE_ATTRIB, TAG_TYPE_ATTRIB, and TAG_TYPE_NAME.
Referenced by mhdf_createTag(), and mhdf_createVarLenTag().
    hid_t temp_id, group_id, tag_id;
    char* path;
    FileHandle* file_ptr;
    herr_t rval;
    hsize_t arr_len;
    int one = 1, var_len = 0;
    hsize_t default_value_size = default_value_size_in;
    hsize_t global_value_size  = global_value_size_in;
    int close_base_type        = 0;
    /* Force standard data types over user-specified types */
    if( tag_type != mhdf_OPAQUE ) hdf_type = 0;
    if( tag_type != mhdf_ENTITY_ID ) hdf_base_type = 0;
    /* Validate input */
    file_ptr = (FileHandle*)file_handle;
    if( !mhdf_check_valid_file( file_ptr, status ) ) return -1;
    if( !tag_name || !*tag_name )
        mhdf_setFail( status, "Invalid tag name" );
        return -1;
    /* Open the tag group */
#if defined( H5Gopen_vers ) && H5Gopen_vers > 1
    group_id = H5Gopen2( file_ptr->hdf_handle, TAG_GROUP, H5P_DEFAULT );
#else
    group_id = H5Gopen( file_ptr->hdf_handle, TAG_GROUP );
#endif
    if( group_id < 0 )
        mhdf_setFail( status, "H5Gopen(\"%s\") failed.", TAG_GROUP );
        return -1;
    /* Create path string for tag object */
    path = mhdf_name_to_path_copy( tag_name, status );
    if( !path )
        H5Gclose( group_id );
        return -1;
    /* Create group for this tag */
#if defined( H5Gcreate_vers ) && H5Gcreate_vers > 1
    tag_id = H5Gcreate2( group_id, path, H5P_DEFAULT, H5P_DEFAULT, H5P_DEFAULT );
#else
    tag_id   = H5Gcreate( group_id, path, 3 );
#endif
    if( tag_id < 0 )
        mhdf_setFail( status, "H5Gcreate( \"%s\" ) failed.", path );
        free( path );
        return -1;
    /* Store the tag name as the comment on the group entry */
    rval = H5Gset_comment( group_id, path, tag_name );
    free( path );
    if( rval < 0 )
        mhdf_setFail( status, "H5Gset_comment failed for tag \"%s\"", tag_name );
        H5Gclose( tag_id );
        return -1;
    /* Store TSTT tag type as attribute */
    rval = mhdf_create_scalar_attrib( tag_id, TAG_TYPE_ATTRIB, H5T_NATIVE_INT, &storage, status );
    if( !rval )
        H5Gclose( tag_id );
        return -1;
    if( hdf_type )
        hdf_type = H5Tcopy( hdf_type );
        arr_len  = 1;
    else
        switch( tag_type )
            default:
            case mhdf_OPAQUE:
                arr_len  = 1;
                hdf_type = H5Tcreate( H5T_OPAQUE, abs( size ) );
                H5Tset_tag( hdf_type, "tag_data" );
                break;
            case mhdf_BITFIELD:
                arr_len = 1;
                if( size <= 0 )
                    mhdf_setFail( status, "Invalid size (%d) for bit tag.", (int)size );
                    return -1;
                else if( size <= 8 )
                    hdf_type = H5Tcopy( H5T_NATIVE_B8 );
                else if( size <= 16 )
                    hdf_type = H5Tcopy( H5T_NATIVE_B16 );
                else if( size <= 32 )
                    hdf_type = H5Tcopy( H5T_NATIVE_B32 );
                else if( size <= 64 )
                    hdf_type = H5Tcopy( H5T_NATIVE_B64 );
                else
                    mhdf_setFail( status, "Cannot create a bit tag larger than 64-bits.  %d bits requested.\n",
                                  (int)size );
                    return -1;
                if( 0 > H5Tset_precision( hdf_type, size ) )
                    mhdf_setFail( status, "H5Tset_precision failed." );
                    return -1;
                break;
            case mhdf_ENTITY_ID:
                arr_len  = abs( size );
                hdf_type = H5Tcopy( H5T_NATIVE_ULONG );
                break;
            case mhdf_BOOLEAN:
                hdf_type = H5Tcopy( H5T_NATIVE_UCHAR );
                break;
            case mhdf_INTEGER:
                hdf_type = H5Tcopy( H5T_NATIVE_INT );
                break;
            case mhdf_FLOAT:
                hdf_type = H5Tcopy( H5T_NATIVE_DOUBLE );
                break;
    if( hdf_type <= 0 )
        mhdf_setFail( status, "Failed to create tag type object." );
        H5Gclose( tag_id );
        return -1;
    if( hdf_base_type && H5Tget_class( hdf_type ) != H5Tget_class( hdf_base_type ) )
        mhdf_setFail( status, "Invalid base type for tag default/global data" );
        H5Gclose( tag_id );
        return -1;
    if( size < -1 || !arr_len )
        mhdf_setFail( status, "Invalid 'size' parameter passed to mhdf_createTag (%d)", (int)size );
        H5Gclose( tag_id );
        return -1;
    else if( size == -1 )
        /* Note: we don't do anything with this here.  We rely on
         *       the app to ask us to create the index table later.
        arr_len = 1;
        /* need to know this later, when storing default/global values */
        var_len = 1;
    else if( arr_len > 1 )
#if defined( H5Tarray_create_vers ) && H5Tarray_create_vers > 1
        temp_id = H5Tarray_create2( hdf_type, 1, &arr_len );
#else
        temp_id = H5Tarray_create( hdf_type, 1, &arr_len, NULL );
#endif
        H5Tclose( hdf_type );
        if( temp_id < 0 )
            H5Gclose( tag_id );
            return -1;
        hdf_type = temp_id;
        if( hdf_base_type )
            if( H5Tequal( hdf_base_type, hdf_type ) > 0 )
                hdf_base_type = hdf_type;
            else
                temp_id = H5Tarray_create2( hdf_base_type, 1, &arr_len );
#else
                temp_id = H5Tarray_create( hdf_base_type, 1, &arr_len, NULL );
#endif
                if( temp_id < 0 )
                    H5Gclose( tag_id );
                    return -1;
                hdf_base_type   = temp_id;
                close_base_type = 1;
    if( !hdf_base_type ) hdf_base_type = hdf_type;
        /* Create tag type object, or write attribute if opaque */
#if defined( H5Tcommit_vers ) && H5Tcommit_vers > 1
    rval = H5Tcommit2( tag_id, TAG_TYPE_NAME, hdf_type, H5P_DEFAULT, H5P_DEFAULT, H5P_DEFAULT );
#else
    rval     = H5Tcommit( tag_id, TAG_TYPE_NAME, hdf_type );
#endif
    if( rval < 0 )
        mhdf_setFail( status, "H5Tcommit failed for tag \"%s\"", tag_name );
        if( close_base_type ) H5Tclose( hdf_base_type );
        H5Gclose( tag_id );
        return -1;
    /* If tag is entity handle, make note of it */
    if( tag_type == mhdf_ENTITY_ID )
        rval = mhdf_create_scalar_attrib( tag_id, TAG_HANDLE_TYPE_ATTRIB, H5T_NATIVE_INT, &one, status );
        if( !rval )
            H5Gclose( tag_id );
            return -1;
    /* Store the default value as a attribute of the tag group */
    if( default_value )
        rval = store_tag_val_in_attrib( tag_id, TAG_DEFAULT_ATTRIB, hdf_base_type, default_value,
                                        var_len ? default_value_size : 1, status );
        if( !rval )
            H5Gclose( tag_id );
            return -1;
    /* Store global tag value as attribute */
    if( global_value )
        rval = store_tag_val_in_attrib( tag_id, TAG_GLOBAL_ATTRIB, hdf_base_type, global_value,
                                        var_len ? global_value_size : 1, status );
        if( !rval )
            H5Gclose( tag_id );
            return -1;
    mhdf_setOkay( status );
    return tag_id;
static int get_attrib_array_length_handle ( hid_t  attrib_id) [static]
Definition at line 741 of file tags.c.
Referenced by get_attrib_array_length_name().
    hid_t type_id;
    int rank;
    hsize_t dims[H5S_MAX_RANK];
    int perm[H5S_MAX_RANK];
    type_id = H5Aget_type( attrib_id );
    switch( H5Tget_class( type_id ) )
        case H5T_NO_CLASS:
            dims[0] = -1;
            break;
        case H5T_OPAQUE:
            dims[0] = H5Tget_size( type_id );
            break;
        case H5T_ARRAY:
#if defined( H5Tget_array_dims_vers ) && H5Tget_array_dims_vers > 1
            (void)perm; /* suppress warning */
            rank = H5Tget_array_dims2( type_id, dims );
#else
            rank = H5Tget_array_dims( type_id, dims, perm );
#endif
            if( rank == 1 )
                break;
            else
                return -1;
        default:
            dims[0] = 1;
            break;
    H5Tclose( type_id );
    return dims[0];
static int get_attrib_array_length_name ( hid_t  file,
const char *  path
) [static]
Definition at line 793 of file tags.c.
References get_attrib_array_length_handle().
Referenced by mhdf_getTagInfo(), and read_tag_attrib_data().
    hid_t attrib_id;
    int result;
    attrib_id = H5Aopen_name( file, path );
    if( attrib_id < 0 ) return -1;
    result = get_attrib_array_length_handle( attrib_id );
    H5Aclose( attrib_id );
    return result;
static hid_t get_tag ( mhdf_FileHandle  file_handle,
hid_t *  id_type,
mhdf_Status status
) [static]
Definition at line 106 of file tags.c.
References struct_FileHandle::hdf_handle, struct_FileHandle::id_type, mhdf_check_valid_file(), mhdf_name_to_path_copy(), mhdf_setFail(), mhdf_setOkay(), and TAG_GROUP.
Referenced by mhdf_createSparseTagData(), mhdf_createVarLenTagData(), mhdf_getTagInfo(), mhdf_getTagValues(), and mhdf_openSparseTagData().
    hid_t group_id, tag_id;
    char* path;
    if( NULL != id_type ) *id_type = file_ptr->id_type;
    if( NULL == path ) return -1;
#else
#endif
    if( group_id < 0 )
        mhdf_setFail( status, "Failed to open tag group." );
        free( path );
        return -1;
    tag_id = H5Gopen2( group_id, path, H5P_DEFAULT );
#else
    tag_id   = H5Gopen( group_id, path );
#endif
    free( path );
    if( tag_id < 0 )
        mhdf_setFail( status, "Failed to open tag data for tag \"%s\".", tag_name );
        return -1;
    return tag_id;
static hid_t get_tag_type ( FileHandle file_ptr,
const char *  tag_path,
mhdf_Status status
) [static]
Definition at line 149 of file tags.c.
References struct_FileHandle::hdf_handle, mhdf_setFail(), TAG_GROUP, and TAG_TYPE_NAME.
Referenced by mhdf_createDenseTagData(), and mhdf_getTagDataType().
    hid_t group_id, tag_id, type_id;
#else
#endif
    if( group_id < 0 )
        return -1;
    tag_id = H5Gopen2( group_id, tag_path, H5P_DEFAULT );
#else
    tag_id   = H5Gopen( group_id, tag_path );
#endif
    if( tag_id < 0 )
        mhdf_setFail( status, "Failed to open group for tag \"%s\".", tag_path );
        return -1;
#if defined( H5Topen_vers ) && H5Topen_vers > 1
    type_id = H5Topen2( tag_id, TAG_TYPE_NAME, H5P_DEFAULT );
#else
    type_id  = H5Topen( tag_id, TAG_TYPE_NAME );
#endif
    H5Gclose( tag_id );
    if( type_id < 0 )
        mhdf_setFail( status, "Failed to open type data for tag \"%s\".", tag_path );
        return -1;
    return type_id;
static int read_tag_attrib_data ( hid_t  tag_id,
const char *  attrib_name,
hid_t  type_id,
void *  data,
int  is_var_len,
mhdf_Status status
) [static]
Definition at line 1075 of file tags.c.
References get_attrib_array_length_name(), mhdf_find_attribute(), mhdf_read_scalar_attrib(), and mhdf_setFail().
Referenced by mhdf_getTagValues().
    int rval, ilen;
    unsigned idx;
    hid_t read_type = type_id;
    hsize_t len;
    /* Check if tag has attribute */
    rval = mhdf_find_attribute( tag_id, attrib_name, &idx, status );
    if( rval < 0 )
        return 0;
    else if( 0 == rval )
        return 1;
    if( NULL == data )
        mhdf_setFail( status, "Invalid input." );
        return 0;
    if( is_var_len )
        /* len = get_attrib_array_length_index(tag_id, index); */
        ilen = get_attrib_array_length_name( tag_id, attrib_name );
        if( ilen < 0 )
            mhdf_setFail( status, "Failed to read length of default/mesh value for tag" );
            return 0;
        len = ilen;
        /* caller passes type_id == 0 for OPAQUE */
        if( 0 == type_id )
            read_type = H5Tcreate( H5T_OPAQUE, len );
        else
            read_type = H5Tarray_create2( type_id, 1, &len );
#else
            read_type = H5Tarray_create( type_id, 1, &len, 0 );
#endif
        if( read_type < 0 )
            mhdf_setFail( status, "Failed to read mesh/default value for tag" );
            return 0;
    rval = mhdf_read_scalar_attrib( tag_id, attrib_name, read_type, data, status );
    if( is_var_len ) H5Tclose( read_type );
    return rval;
static int store_tag_val_in_attrib ( hid_t  tag_id,
hid_t  type_id,
const void *  value,
hsize_t  value_size,
mhdf_Status status
) [static]
Helper function to write default and mesh values for tag
Parameters:
tag_idThe file object upon which to attach the attribute
attrib_nameThe name of the attribute object
type_idThe data type of the attribute data
valuePointer to attribute data
value_sizeSize of attribute data, as multiple of type indicated by type_id. Should be 1 except for variable-length tag data.
Definition at line 199 of file tags.c.
References mhdf_create_scalar_attrib(), and mhdf_setFail().
Referenced by create_tag_common().
    hid_t write_type;
    int rval;
    if( value_size == 1 )
        write_type = type_id;
    else if( H5Tget_class( type_id ) == H5T_OPAQUE )
        write_type = H5Tcreate( H5T_OPAQUE, value_size );
    else
        write_type = H5Tarray_create2( type_id, 1, &value_size );
#else
        write_type = H5Tarray_create( type_id, 1, &value_size, 0 );
#endif
    if( write_type < 0 )
        mhdf_setFail( status, "Error constructing type object for tag mesh/default value" );
        return -1;
    rval = mhdf_create_scalar_attrib( tag_id, attrib_name, write_type, value, status );
    if( write_type != type_id ) H5Tclose( write_type );
    return rval;
