MOAB: Mesh Oriented datABase
(version 5.4.1)
#include <ArrayMesh.hpp>
Classes | |
struct | Tag |
Public Member Functions | |
ArrayMesh (int coords_per_vertex, unsigned long num_vertices, double *interleaved_vertex_coords, const int *vertex_fixed_flags, unsigned long num_elements, EntityTopology element_type, const unsigned long *element_connectivity_array, bool one_based_conn_indices=false, unsigned nodes_per_element=0, const int *vertex_slaved_flags=0) | |
ArrayMesh (int coords_per_vertex, unsigned long num_vertices, double *interleaved_vertex_coords, const int *vertex_fixed_flags, unsigned long num_elements, const EntityTopology *element_types, const unsigned long *element_connectivity_array, const unsigned long *element_connectivity_offsets=NULL, bool one_based_conn_indices=false, const int *vertex_slaved_flags=0) | |
ArrayMesh () | |
~ArrayMesh () | |
void | clear_mesh () |
void | set_mesh (int coords_per_vertex, unsigned long num_vertices, double *interleaved_vertex_coords, const int *vertex_fixed_flags, unsigned long num_elements, EntityTopology element_type, const unsigned long *element_connectivity_array, bool one_based_conn_indices=false, unsigned nodes_per_element=0, const int *vertex_slaved_flags=0) |
TagHandle | add_read_only_tag_data (const char *tag_name, TagType data_type, int vals_per_entity, const void *vertex_data, const void *element_data, const void *default_value, MsqError &err) |
Give mesquite access to per-entity application data via a tag. | |
TagHandle | add_writable_tag_data (const char *tag_name, TagType tag_data_type, int vals_per_entity, void *vertex_data, void *element_data, const void *default_value, MsqError &err) |
virtual int | get_geometric_dimension (MsqError &err) |
Returns whether this mesh lies in a 2D or 3D coordinate system. | |
virtual void | get_all_elements (std::vector< ElementHandle > &elements, MsqError &err) |
Get all elements in mesh. | |
virtual void | get_all_vertices (std::vector< VertexHandle > &vertices, MsqError &err) |
Get all vertices in mesh. | |
virtual VertexIterator * | vertex_iterator (MsqError &err) |
virtual ElementIterator * | element_iterator (MsqError &err) |
virtual void | vertices_get_fixed_flag (const VertexHandle vert_array[], std::vector< bool > &fixed_flag_array, size_t num_vtx, MsqError &err) |
virtual void | vertices_get_slaved_flag (const VertexHandle vert_array[], std::vector< bool > &slaved_flag_array, size_t num_vtx, MsqError &err) |
virtual void | vertices_get_coordinates (const VertexHandle vert_array[], MsqVertex *coordinates, size_t num_vtx, MsqError &err) |
Get/set location of a vertex. | |
virtual void | vertex_set_coordinates (VertexHandle vertex, const Vector3D &coordinates, MsqError &err) |
virtual void | vertex_set_byte (VertexHandle vertex, unsigned char byte, MsqError &err) |
virtual void | vertices_set_byte (const VertexHandle *vert_array, const unsigned char *byte_array, size_t array_size, MsqError &err) |
virtual void | vertex_get_byte (const VertexHandle vertex, unsigned char *byte, MsqError &err) |
virtual void | vertices_get_byte (const VertexHandle *vertex, unsigned char *byte_array, size_t array_size, MsqError &err) |
virtual void | vertices_get_attached_elements (const VertexHandle *vertex_array, size_t num_vertex, std::vector< ElementHandle > &elements, std::vector< size_t > &offsets, MsqError &err) |
get elements adjacent to vertices | |
virtual void | elements_get_attached_vertices (const ElementHandle *elem_handles, size_t num_elems, std::vector< VertexHandle > &vert_handles, std::vector< size_t > &offsets, MsqError &err) |
Get element connectivity. | |
virtual void | elements_get_topologies (const ElementHandle *element_handle_array, EntityTopology *element_topologies, size_t num_elements, MsqError &err) |
virtual TagHandle | tag_create (const std::string &tag_name, TagType type, unsigned length, const void *default_value, MsqError &err) |
Create a tag. | |
virtual void | tag_delete (TagHandle handle, MsqError &err) |
Remove a tag and all corresponding data. | |
virtual TagHandle | tag_get (const std::string &name, MsqError &err) |
Get handle for existing tag, by name. | |
virtual void | tag_properties (TagHandle handle, std::string &name_out, TagType &type_out, unsigned &length_out, MsqError &err) |
Get properites of tag. | |
virtual void | tag_set_element_data (TagHandle handle, size_t num_elems, const ElementHandle *elem_array, const void *tag_data, MsqError &err) |
Set tag values on elements. | |
virtual void | tag_set_vertex_data (TagHandle handle, size_t num_elems, const VertexHandle *node_array, const void *tag_data, MsqError &err) |
Set tag values on vertices. | |
virtual void | tag_get_element_data (TagHandle handle, size_t num_elems, const ElementHandle *elem_array, void *tag_data, MsqError &err) |
Get tag values on elements. | |
virtual void | tag_get_vertex_data (TagHandle handle, size_t num_elems, const VertexHandle *node_array, void *tag_data, MsqError &err) |
Get tag values on vertices. | |
virtual void | release_entity_handles (const EntityHandle *handle_array, size_t num_handles, MsqError &err) |
virtual void | release () |
Private Member Functions | |
const unsigned long * | elem_verts (size_t elem_index, int &num_vertex) const |
void | build_vertex_adjacency_list () |
Tag * | allocate_tag (const char *name, bool owned, TagType type, unsigned size, const void *vertex_ro_data, void *vertex_rw_data, const void *element_ro_data, void *element_rw_data, const void *default_value, MsqError &err) |
bool | valid () const |
Static Private Member Functions | |
static unsigned | bytes (TagType type) |
static void | fill (unsigned char *buffer, const unsigned char *value, size_t size, size_t count) |
Private Attributes | |
int | mDimension |
Coordinates per vertex. | |
unsigned long | vertexCount |
Number of vertices. | |
double * | coordArray |
Interleaved vertex coordinates. | |
const int * | fixedFlags |
Vertex fixed flags. | |
const int * | slavedFlags |
Vertex slaved flags. | |
unsigned char * | vertexByteArray |
Vertex bytes. | |
unsigned long | elementCount |
Number of elements. | |
const unsigned long * | connArray |
Element connectivity. | |
const unsigned long * | connOffsets |
unsigned long * | allocConnOffsets |
EntityTopology | elementType |
Type for all elements if connOffsets is NULL. | |
const EntityTopology * | elementTypes |
Type for each element type if connOffsets is not NULL. | |
unsigned | nodesPerElement |
Nodes per element if connOffsets is NULL. | |
bool | oneBasedArrays |
FORTRAN-style array indexing. | |
unsigned long * | vertexAdjacencyList |
unsigned long * | vertexAdjacencyOffsets |
Tag * | tagList |
Definition at line 41 of file ArrayMesh.hpp.
MBMesquite::ArrayMesh::ArrayMesh | ( | int | coords_per_vertex, |
unsigned long | num_vertices, | ||
double * | interleaved_vertex_coords, | ||
const int * | vertex_fixed_flags, | ||
unsigned long | num_elements, | ||
EntityTopology | element_type, | ||
const unsigned long * | element_connectivity_array, | ||
bool | one_based_conn_indices = false , |
unsigned | nodes_per_element = 0 , |
const int * | vertex_slaved_flags = 0 |
Create a MBMesquite::Mesh instance that wraps application-provided arrays.
Note: An instance of this class will reference the passed in arrays. It will not copy them.
coords_per_vertex | Dimension of the mesh (2 or 3) |
num_vertices | Number of vertices in the mesh |
interleaved_vertex_coords | Vertex coordinates. Ordered as [x1, y1, z1, x2, y2, z2, ...] |
vertex_fixed_flags | One value per vertex. Zero if vertex is free, one if the position is fixed. |
num_elements | Number of elements in the mesh |
element_type | The type of the elements |
element_connectivity_array | Element connectivity, specified as vertex indices such that the location of the vertex coordinates in vertex_coords is at 3 times the value in this array. |
one_based_conn_indices | Use one-based (Fortran) array indexing. |
nodes_per_element | Number of nodes in each element. If not specified, number of nodes in a linear element with the type 'element_type' is assumed. |
vertex_slaved_flags | One value per vertex. Zero if vertex is free, one if the vertex is slaved to the logical position of the element mapping/shape function.. |
Definition at line 77 of file ArrayMesh.cpp.
References coordArray, corners, fixedFlags, mDimension, nodesPerElement, oneBasedArrays, valid(), and vertexByteArray.
: mDimension( coords_per_vertex ), vertexCount( num_vertices ), coordArray( interleaved_vertex_coords ), fixedFlags( vertex_fixed_flags ), slavedFlags( vertex_slaved_flags ), vertexByteArray( new unsigned char[num_vertices + one_based_conn_indices] ), elementCount( num_elements ), connArray( element_connectivity_array ), connOffsets( 0 ), allocConnOffsets( 0 ), elementType( element_type ), elementTypes( 0 ), nodesPerElement( nodes_per_element ), oneBasedArrays( one_based_conn_indices ), vertexAdjacencyList( 0 ), vertexAdjacencyOffsets( 0 ), tagList( 0 ) { if( oneBasedArrays ) { coordArray -= mDimension; --fixedFlags; } if( nodesPerElement < 2 ) nodesPerElement = TopologyInfo::corners( element_type ); assert( valid() ); memset( vertexByteArray, 0, num_vertices + one_based_conn_indices ); }
const EntityTopology * | element_types, | ||
const unsigned long * | element_connectivity_offsets = NULL , |
vertex_fixed_flags | One value per vertex. Zero if vertex is free, one if the poistion is fixed. |
element_types | The topological type for each element. |
element_connectivity_offsets | An optional array of length one greater than num_elements. Each entry other than the last should contain the value of the index into element_connectivity_array at which the connectivity data for the corresponding element begins. The last entry in the array must be the next-to-last entry plus the length of the connectivity data for the last element, such that the length of the connectivity data for any element 'e' can be calculated with: n = element_connectivity_offsets[e+1] - element_connectivity_offsets[e] |
If this array is not specified, then it will be assumed that the length of the connectivity data for each element is the number of corners necessary to represent its topological type (that it has no higher-order nodes.)
Definition at line 106 of file ArrayMesh.cpp.
References allocConnOffsets, connArray, connOffsets, coordArray, corners, elementTypes, fixedFlags, mDimension, oneBasedArrays, valid(), and vertexByteArray.
: mDimension( coords_per_vertex ), vertexCount( num_vertices ), coordArray( interleaved_vertex_coords ), fixedFlags( vertex_fixed_flags ), slavedFlags( vertex_slaved_flags ), vertexByteArray( new unsigned char[num_vertices + one_based_conn_indices] ), elementCount( num_elements ), connArray( element_connectivity_array ), connOffsets( element_connectivity_offsets ), allocConnOffsets( 0 ), elementType( MIXED ), elementTypes( element_types ), nodesPerElement( 0 ), oneBasedArrays( one_based_conn_indices ), vertexAdjacencyList( 0 ), vertexAdjacencyOffsets( 0 ), tagList( 0 ) { if( oneBasedArrays ) { coordArray -= mDimension; --fixedFlags; if( element_connectivity_offsets ) --connArray; } if( !element_connectivity_offsets ) { connOffsets = allocConnOffsets = new unsigned long[num_elements + 1]; allocConnOffsets[0] = 0; for( unsigned long i = 1; i <= num_elements; ++i ) allocConnOffsets[i] = allocConnOffsets[i - 1] + TopologyInfo::corners( elementTypes[i - 1] ); } assert( valid() ); memset( vertexByteArray, 0, num_vertices + one_based_conn_indices ); }
Definition at line 69 of file ArrayMesh.cpp.
: mDimension( 0 ), vertexCount( 0 ), coordArray( 0 ), fixedFlags( 0 ), slavedFlags( 0 ), vertexByteArray( 0 ), elementCount( 0 ), connArray( 0 ), connOffsets( 0 ), allocConnOffsets( 0 ), elementType( MIXED ), elementTypes( 0 ), nodesPerElement( 0 ), oneBasedArrays( false ), vertexAdjacencyList( 0 ), vertexAdjacencyOffsets( 0 ), tagList( 0 ) { }
TagHandle MBMesquite::ArrayMesh::add_read_only_tag_data | ( | const char * | tag_name, |
TagType | data_type, | ||
int | vals_per_entity, | ||
const void * | vertex_data, | ||
const void * | element_data, | ||
const void * | default_value, | ||
MsqError & | err | ||
Allow mesquite to access application-owned per-element and/or per-vertex data by assigning a tag name to said data. Mesquite will be allowed to read application-owned data. Any attempt by Mesquite to modify the data will result in an internal error condition.
tag_name | Tag name through which Mesquite can access the data |
data_type | The type of the data |
vals_per_entity | Number of values of type data_type that each entity has Data is assumed to be interleaved such that all values associated with a a single entity are adjacent in memory |
vertex_data | A pointer to the region of memory in which per-vertex values are stored. May be NULL if per-vertex data is not available. Values are assumed to be in the same order as the vertex coordinates passed to the constructor or set_mesh . |
vertex_data | A pointer to the region of memory in which per-element values are stored. May be NULL if per-element data is not available. Values are assumed to be in the same order as the element connetivity passed to the constructor or set_mesh . |
default_value | Value to return for all vertices and/or all elements if the cooresponding data array is null. May be NULL if no default value. |
Definition at line 597 of file ArrayMesh.cpp.
References allocate_tag(), and MSQ_ERRZERO.
Referenced by ArrayMeshTest::test_delete_tag(), and ArrayMeshTest::test_tag_data().
{ Tag* tag = allocate_tag( tag_name, false, data_type, vals_per_entity, vertex_data, 0, element_data, 0, default_value, err ); MSQ_ERRZERO( err ); return reinterpret_cast< TagHandle >( tag ); }
TagHandle MBMesquite::ArrayMesh::add_writable_tag_data | ( | const char * | tag_name, |
TagType | tag_data_type, | ||
Allow mesquite to access and/or set application-owned per-element and/or per-vertex data by assigning a tag name to said data.
Definition at line 611 of file ArrayMesh.cpp.
{ Tag* tag = allocate_tag( tag_name, false, data_type, vals_per_entity, 0, vertex_data, 0, element_data, default_value, err ); MSQ_ERRZERO( err ); return reinterpret_cast< TagHandle >( tag ); }
ArrayMesh::Tag * MBMesquite::ArrayMesh::allocate_tag | ( | const char * | name, |
bool | owned, | ||
TagType | type, | ||
unsigned | size, | ||
const void * | vertex_ro_data, | ||
void * | vertex_rw_data, | ||
const void * | element_ro_data, | ||
void * | element_rw_data, | ||
) | [private] |
Definition at line 537 of file ArrayMesh.cpp.
References bytes(), MBMesquite::ArrayMesh::Tag::defaultValue, MBMesquite::ArrayMesh::Tag::eleReadPtr, MBMesquite::ArrayMesh::Tag::eleWritePtr, MSQ_SETERR, MBMesquite::ArrayMesh::Tag::name, MBMesquite::ArrayMesh::Tag::next, MBMesquite::ArrayMesh::Tag::owned, MBMesquite::ArrayMesh::Tag::size, MBMesquite::MsqError::TAG_ALREADY_EXISTS, tagList, MBMesquite::ArrayMesh::Tag::type, MBMesquite::ArrayMesh::Tag::vtxReadPtr, and MBMesquite::ArrayMesh::Tag::vtxWritePtr.
Referenced by add_read_only_tag_data(), add_writable_tag_data(), and tag_create().
{ // check if name is already in use for( Tag* iter = tagList; iter; iter = iter->next ) { if( !strcmp( iter->name, name ) ) { MSQ_SETERR( err )( MsqError::TAG_ALREADY_EXISTS ); return 0; } } // allocate object Tag* result = new Tag; // initialize members result->type = type; result->size = size * bytes( type ); result->owned = owned; result->name = new char[strlen( name ) + 1]; strcpy( result->name, name ); result->vtxWritePtr = reinterpret_cast< unsigned char* >( vertex_rw_data ); if( vertex_rw_data ) result->vtxReadPtr = reinterpret_cast< unsigned char* >( vertex_rw_data ); else result->vtxReadPtr = reinterpret_cast< const unsigned char* >( vertex_ro_data ); result->eleWritePtr = reinterpret_cast< unsigned char* >( element_rw_data ); if( element_rw_data ) result->eleReadPtr = reinterpret_cast< unsigned char* >( element_rw_data ); else result->eleReadPtr = reinterpret_cast< const unsigned char* >( element_ro_data ); if( default_value ) { result->defaultValue = new unsigned char[result->size]; memcpy( result->defaultValue, default_value, result->size ); } else { result->defaultValue = 0; } // prepend to tag list result->next = tagList; tagList = result; return result; }
void MBMesquite::ArrayMesh::build_vertex_adjacency_list | ( | ) | [private] |
Definition at line 470 of file ArrayMesh.cpp.
References conn, elem_verts(), elementCount, n, oneBasedArrays, vertexAdjacencyList, vertexAdjacencyOffsets, and vertexCount.
Referenced by vertices_get_attached_elements().
{ delete[] vertexAdjacencyList; delete[] vertexAdjacencyOffsets; vertexAdjacencyOffsets = new unsigned long[vertexCount + oneBasedArrays + 1]; // for each vertex, store the number of elements the previous // vertex occurs in. memset( vertexAdjacencyOffsets, 0, sizeof( unsigned long ) * ( vertexCount + oneBasedArrays + 1 ) ); for( size_t i = 0; i < elementCount; ++i ) { int n; const unsigned long* conn = elem_verts( i, n ); for( int j = 0; j < n; ++j ) ++vertexAdjacencyOffsets[conn[j] + 1]; } // convert vertexAdjacencyOffsets from a shifted list of counts // to a list of offsts for( size_t i = 1; i <= vertexCount + oneBasedArrays; ++i ) vertexAdjacencyOffsets[i] += vertexAdjacencyOffsets[i - 1]; // allocate space and populate with reverse connectivity vertexAdjacencyList = new unsigned long[vertexAdjacencyOffsets[vertexCount + oneBasedArrays]]; for( size_t i = 0; i < elementCount; ++i ) { int n; const unsigned long* conn = elem_verts( i, n ); for( int j = 0; j < n; ++j ) vertexAdjacencyList[vertexAdjacencyOffsets[conn[j]]++] = i; } for( size_t i = vertexCount + oneBasedArrays; i > 0; --i ) vertexAdjacencyOffsets[i] = vertexAdjacencyOffsets[i - 1]; vertexAdjacencyOffsets[0] = 0; }
unsigned MBMesquite::ArrayMesh::bytes | ( | TagType | type | ) | [static, private] |
Definition at line 507 of file ArrayMesh.cpp.
References MBMesquite::Mesh::BOOL, MBMesquite::Mesh::BYTE, MBMesquite::Mesh::DOUBLE, MBMesquite::Mesh::HANDLE, and MBMesquite::Mesh::INT.
Referenced by allocate_tag(), and tag_properties().
void MBMesquite::ArrayMesh::clear_mesh | ( | ) |
Definition at line 168 of file ArrayMesh.cpp.
References allocConnOffsets, connOffsets, coordArray, MBMesquite::ArrayMesh::Tag::defaultValue, elementCount, elementType, elementTypes, MBMesquite::ArrayMesh::Tag::eleWritePtr, fixedFlags, mDimension, MBMesquite::MIXED, MBMesquite::ArrayMesh::Tag::name, MBMesquite::ArrayMesh::Tag::next, nodesPerElement, oneBasedArrays, MBMesquite::ArrayMesh::Tag::owned, tagList, vertexAdjacencyList, vertexAdjacencyOffsets, vertexByteArray, vertexCount, and MBMesquite::ArrayMesh::Tag::vtxWritePtr.
Referenced by set_mesh(), and ~ArrayMesh().
{ delete[] vertexByteArray; delete[] vertexAdjacencyList; delete[] vertexAdjacencyOffsets; delete[] allocConnOffsets; while( tagList ) { Tag* dead = tagList; tagList = tagList->next; delete[] dead->name; delete[] dead->defaultValue; if( dead->owned ) { delete[] dead->vtxWritePtr; delete[] dead->eleWritePtr; } delete dead; } mDimension = 0; vertexCount = 0; coordArray = 0; connOffsets = 0; allocConnOffsets = 0; fixedFlags = 0; vertexByteArray = 0; elementCount = 0; elementType = MIXED; elementTypes = 0; nodesPerElement = 0; oneBasedArrays = false; vertexAdjacencyList = 0; vertexAdjacencyOffsets = 0; }
const unsigned long * MBMesquite::ArrayMesh::elem_verts | ( | size_t | elem_index, |
int & | num_vertex | ||
) | const [inline, private] |
Definition at line 246 of file ArrayMesh.cpp.
References connArray, connOffsets, elementCount, and nodesPerElement.
Referenced by build_vertex_adjacency_list(), and elements_get_attached_vertices().
{ assert( e < elementCount ); if( connOffsets ) { n = connOffsets[e + 1] - connOffsets[e]; return connArray + connOffsets[e]; } else { n = nodesPerElement; return connArray + nodesPerElement * e; } }
ElementIterator * MBMesquite::ArrayMesh::element_iterator | ( | MsqError & | err | ) | [virtual] |
Definition at line 285 of file ArrayMesh.cpp.
References elementCount.
{ return new IndexIterator( 0, elementCount ); }
void MBMesquite::ArrayMesh::elements_get_attached_vertices | ( | const ElementHandle * | elem_handles, |
size_t | num_elems, | ||
std::vector< VertexHandle > & | vert_handles, | ||
std::vector< size_t > & | offsets, | ||
) | [virtual] |
Get the connectivity (ordered list of vertex handles) for each element in the input array.
elem_handles | The array of element handles for which to retrieve the connectivity list. |
num_elems | The length of #elem_handles |
vert_handles | Array in which to place the vertex handles in each elements connectivity. |
offsets | For each element in #elem_handles, the value in the same position in this array is the index into #vert_handles at which the connectivity list for that element begins. |
Implements MBMesquite::Mesh.
Definition at line 421 of file ArrayMesh.cpp.
References conn, elem_verts(), and elementCount.
{ const size_t* indices = (const size_t*)elem_handles; offsets.resize( num_elems + 1 ); vert_handles.clear(); for( size_t i = 0; i < num_elems; ++i ) { assert( indices[i] < elementCount ); int count; const unsigned long* conn = elem_verts( indices[i], count ); size_t prev_size = vert_handles.size(); offsets[i] = prev_size; vert_handles.resize( prev_size + count ); std::copy( conn, conn + count, (size_t*)( &vert_handles[prev_size] ) ); } offsets[num_elems] = vert_handles.size(); }
void MBMesquite::ArrayMesh::elements_get_topologies | ( | const ElementHandle * | element_handle_array, |
EntityTopology * | element_topologies, | ||
size_t | num_elements, | ||
) | [virtual] |
Returns the topologies of the given entities. The "entity_topologies" array must be at least "num_elements" in size.
Definition at line 443 of file ArrayMesh.cpp.
References elementCount, elementType, elementTypes, and MBMesquite::MIXED.
{ const size_t* indices = (const size_t*)handles; if( elementType == MIXED ) for( size_t i = 0; i < num_elements; ++i ) { assert( indices[i] < elementCount ); element_topologies[i] = elementTypes[indices[i]]; } else for( size_t i = 0; i < num_elements; ++i ) { assert( indices[i] < elementCount ); element_topologies[i] = elementType; } }
void MBMesquite::ArrayMesh::fill | ( | unsigned char * | buffer, |
const unsigned char * | value, | ||
size_t | size, | ||
size_t | count | ||
Definition at line 524 of file ArrayMesh.cpp.
References size.
Referenced by tag_get_element_data(), tag_get_vertex_data(), tag_set_element_data(), and tag_set_vertex_data().
void MBMesquite::ArrayMesh::get_all_elements | ( | std::vector< ElementHandle > & | elements, |
) | [virtual] |
Get the handles of every element in the active mesh.
Definition at line 266 of file ArrayMesh.cpp.
Referenced by ArrayMeshTest::test_tag_data(), and HigherOrderTest::test_tri_open_domain().
{ elements.resize( elementCount ); for( unsigned long i = 0; i < elementCount; ++i ) elements[i] = (Mesh::ElementHandle)i; }
void MBMesquite::ArrayMesh::get_all_vertices | ( | std::vector< VertexHandle > & | vertices, |
) | [virtual] |
Get the handles of every vertex in the active mesh
Definition at line 273 of file ArrayMesh.cpp.
References oneBasedArrays, and vertexCount.
Referenced by TerminationCriterionTest::test_abs_vtx_movement_culling(), ArrayMeshTest::test_tag_data(), and HigherOrderTest::test_tri_open_domain().
{ vertices.resize( vertexCount ); for( unsigned long i = 0; i < vertexCount; ++i ) vertices[i] = ( Mesh::VertexHandle )( i + oneBasedArrays ); }
int MBMesquite::ArrayMesh::get_geometric_dimension | ( | MsqError & | err | ) | [virtual] |
Definition at line 261 of file ArrayMesh.cpp.
References mDimension.
{ return mDimension; }
void MBMesquite::ArrayMesh::release | ( | ) | [virtual] |
Instead of deleting a Mesh when you think you are done, call release(). In simple cases, the implementation could just call the destructor. More sophisticated implementations may want to keep the Mesh object to live longer than Mesquite is using it.
Definition at line 468 of file ArrayMesh.cpp.
void MBMesquite::ArrayMesh::release_entity_handles | ( | const EntityHandle * | handle_array, |
size_t | num_handles, | ||
) | [virtual] |
Tells the mesh that the client is finished with a given entity handle.
Definition at line 463 of file ArrayMesh.cpp.
References MSQ_SETERR, and NOT_IMPLEMENTED.
{ MSQ_SETERR( err )( MsqError::NOT_IMPLEMENTED ); }
void MBMesquite::ArrayMesh::set_mesh | ( | int | coords_per_vertex, |
Definition at line 203 of file ArrayMesh.cpp.
References clear_mesh(), connArray, coordArray, corners, elementCount, elementType, fixedFlags, mDimension, nodesPerElement, oneBasedArrays, slavedFlags, valid(), vertexByteArray, and vertexCount.
{ clear_mesh(); mDimension = coords_per_vertex; vertexCount = num_vertices; coordArray = interleaved_vertex_coords; fixedFlags = vertex_fixed_flags; slavedFlags = vertex_slaved_flags; elementCount = num_elements; connArray = element_connectivity_array; elementType = element_type; oneBasedArrays = one_based_conn_indices; if( oneBasedArrays ) { coordArray -= mDimension; --fixedFlags; } if( nodes_per_element < 2 ) nodesPerElement = TopologyInfo::corners( element_type ); else nodesPerElement = nodes_per_element; vertexByteArray = new unsigned char[num_vertices + one_based_conn_indices]; assert( valid() ); memset( vertexByteArray, 0, num_vertices + one_based_conn_indices ); }
TagHandle MBMesquite::ArrayMesh::tag_create | ( | const std::string & | tag_name, |
unsigned | length, | ||
) | [virtual] |
Create a tag.
Create a user-defined data type that can be attached to any element or vertex in the mesh. For an opaque or undefined type, use type=BYTE and length=sizeof(..).
tag_name | A unique name for the data object |
length | Number of values per entity (1->scalar, >1 ->vector) |
default_value | Default value to assign to all entities - may be NULL |
Definition at line 625 of file ArrayMesh.cpp.
References allocate_tag(), MSQ_ERRZERO, and size.
{ Tag* tag = allocate_tag( tag_name.c_str(), true, data_type, size, 0, 0, 0, 0, default_value, err ); MSQ_ERRZERO( err ); return reinterpret_cast< TagHandle >( tag ); }
void MBMesquite::ArrayMesh::tag_delete | ( | TagHandle | handle, |
) | [virtual] |
Delete a tag.
Definition at line 636 of file ArrayMesh.cpp.
References MBMesquite::ArrayMesh::Tag::defaultValue, MBMesquite::ArrayMesh::Tag::eleWritePtr, MSQ_SETERR, MBMesquite::ArrayMesh::Tag::name, MBMesquite::ArrayMesh::Tag::next, MBMesquite::ArrayMesh::Tag::owned, MBMesquite::MsqError::TAG_NOT_FOUND, tagList, and MBMesquite::ArrayMesh::Tag::vtxWritePtr.
Referenced by ArrayMeshTest::test_delete_tag().
{ Tag* ptr = reinterpret_cast< Tag* >( handle ); // find previous tag pointer in list if( !tagList ) { MSQ_SETERR( err )( "Invalid tag handle", MsqError::TAG_NOT_FOUND ); return; } Tag* prev = 0; for( prev = tagList; prev && prev->next != ptr; prev = prev->next ) ; if( !prev && tagList != ptr ) { MSQ_SETERR( err )( "Invalid tag handle", MsqError::TAG_NOT_FOUND ); return; } delete[] ptr->name; delete[] ptr->defaultValue; if( ptr->owned ) { delete[] ptr->vtxWritePtr; delete[] ptr->eleWritePtr; } if( prev ) prev->next = ptr->next; else tagList = ptr->next; delete ptr; }
TagHandle MBMesquite::ArrayMesh::tag_get | ( | const std::string & | name, |
) | [virtual] |
Check for the existance of a tag given it's name and if it exists return a handle for it. If the specified tag does not exist, zero should be returned WITHOUT flagging an error.
Definition at line 667 of file ArrayMesh.cpp.
References MSQ_SETERR, MBMesquite::ArrayMesh::Tag::next, MBMesquite::MsqError::TAG_NOT_FOUND, and tagList.
{ for( Tag* iter = tagList; iter; iter = iter->next ) if( name == iter->name ) return reinterpret_cast< TagHandle >( iter ); MSQ_SETERR( err )( MsqError::TAG_NOT_FOUND ); return 0; }
void MBMesquite::ArrayMesh::tag_get_element_data | ( | TagHandle | handle, |
const ElementHandle * | elem_array, | ||
void * | tag_data, | ||
) | [virtual] |
Get the value of a tag for a list of mesh elements.
handle | The tag |
num_elems | Length of elem_array |
elem_array | Array of elements for which to get the tag value. |
tag_data | Return buffer in which to copy tag data, contiguous in memory. This data is expected to be num_elems*tag_length*sizeof(tag_type) bytes. |
Definition at line 749 of file ArrayMesh.cpp.
References MBMesquite::ArrayMesh::Tag::defaultValue, MBMesquite::ArrayMesh::Tag::eleReadPtr, fill(), MSQ_SETERR, MBMesquite::ArrayMesh::Tag::size, and MBMesquite::MsqError::TAG_NOT_FOUND.
Referenced by ArrayMeshTest::test_tag_data().
{ unsigned char* ptr = reinterpret_cast< unsigned char* >( data ); const Tag* tag = reinterpret_cast< const Tag* >( handle ); if( tag->eleReadPtr ) { for( size_t i = 0; i < count; ++i ) { size_t idx = reinterpret_cast< size_t >( entities[i] ); memcpy( ptr + i * tag->size, tag->eleReadPtr + idx * tag->size, tag->size ); } } else if( tag->defaultValue ) { fill( ptr, tag->defaultValue, tag->size, count ); } else { MSQ_SETERR( err )( MsqError::TAG_NOT_FOUND ); } }
void MBMesquite::ArrayMesh::tag_get_vertex_data | ( | TagHandle | handle, |
const VertexHandle * | node_array, | ||
) | [virtual] |
Get the value of a tag for a list of mesh vertices.
handle | The tag |
elem_array | Array of vertices for which to get the tag value. |
Definition at line 775 of file ArrayMesh.cpp.
References MBMesquite::ArrayMesh::Tag::defaultValue, fill(), MSQ_SETERR, oneBasedArrays, MBMesquite::ArrayMesh::Tag::size, MBMesquite::MsqError::TAG_NOT_FOUND, and MBMesquite::ArrayMesh::Tag::vtxReadPtr.
{ unsigned char* ptr = reinterpret_cast< unsigned char* >( data ); const Tag* tag = reinterpret_cast< const Tag* >( handle ); if( tag->vtxReadPtr ) { for( size_t i = 0; i < count; ++i ) { size_t idx = reinterpret_cast< size_t >( entities[i] ) - oneBasedArrays; memcpy( ptr + i * tag->size, tag->vtxReadPtr + idx * tag->size, tag->size ); } } else if( tag->defaultValue ) { fill( ptr, tag->defaultValue, tag->size, count ); } else { MSQ_SETERR( err )( MsqError::TAG_NOT_FOUND ); } }
void MBMesquite::ArrayMesh::tag_properties | ( | TagHandle | handle, |
std::string & | name_out, | ||
TagType & | type_out, | ||
unsigned & | length_out, | ||
) | [virtual] |
Get data type and number of values per entity for tag.
handle | Tag to get properties of. |
name_out | Passed back tag name. |
type_out | Passed back tag type. |
length_out | Passed back number of values per entity. |
Definition at line 675 of file ArrayMesh.cpp.
References bytes(), MBMesquite::ArrayMesh::Tag::name, MBMesquite::ArrayMesh::Tag::size, and MBMesquite::ArrayMesh::Tag::type.
void MBMesquite::ArrayMesh::tag_set_element_data | ( | TagHandle | handle, |
const void * | tag_data, | ||
) | [virtual] |
Set the value of a tag for a list of mesh elements.
handle | The tag |
elem_array | Array of elements for which to set the tag value. |
tag_data | Tag data for each element, contiguous in memory. This data is expected to be num_elems*tag_length*sizeof(tag_type) bytes. |
Definition at line 683 of file ArrayMesh.cpp.
References MBMesquite::ArrayMesh::Tag::defaultValue, elementCount, MBMesquite::ArrayMesh::Tag::eleReadPtr, MBMesquite::ArrayMesh::Tag::eleWritePtr, fill(), MSQ_SETERR, MBMesquite::ArrayMesh::Tag::owned, MBMesquite::ArrayMesh::Tag::size, and MBMesquite::MsqError::TAG_ALREADY_EXISTS.
{ Tag* tag = reinterpret_cast< Tag* >( handle ); if( !tag->eleWritePtr ) { if( !tag->owned ) { MSQ_SETERR( err ) ( "Attempt to set non-writeable (application owned) tag data", MsqError::TAG_ALREADY_EXISTS ); return; } else { assert( !tag->eleReadPtr ); tag->eleReadPtr = tag->eleWritePtr = new unsigned char[elementCount * tag->size]; fill( tag->eleWritePtr, tag->defaultValue, tag->size, elementCount ); } } const unsigned char* ptr = reinterpret_cast< const unsigned char* >( data ); // as we're working with user-supplied arrays, make sure we're not // memcpying overlapping regions assert( ptr + tag->size * elementCount <= tag->eleWritePtr || tag->eleWritePtr + tag->size * elementCount <= ptr ); for( size_t i = 0; i < count; ++i ) { size_t idx = reinterpret_cast< size_t >( entities[i] ); memcpy( tag->eleWritePtr + idx * tag->size, ptr + i * tag->size, tag->size ); } }
void MBMesquite::ArrayMesh::tag_set_vertex_data | ( | TagHandle | handle, |
) | [virtual] |
Set the value of a tag for a list of mesh vertices.
handle | The tag |
num_elems | Length of node_array |
node_array | Array of vertices for which to set the tag value. |
Definition at line 716 of file ArrayMesh.cpp.
References MBMesquite::ArrayMesh::Tag::defaultValue, fill(), MSQ_SETERR, oneBasedArrays, MBMesquite::ArrayMesh::Tag::owned, MBMesquite::ArrayMesh::Tag::size, MBMesquite::MsqError::TAG_ALREADY_EXISTS, vertexCount, MBMesquite::ArrayMesh::Tag::vtxReadPtr, and MBMesquite::ArrayMesh::Tag::vtxWritePtr.
{ Tag* tag = reinterpret_cast< Tag* >( handle ); if( !tag->vtxWritePtr ) { if( !tag->owned ) { MSQ_SETERR( err ) ( "Attempt to set non-writeable (application owned) tag data", MsqError::TAG_ALREADY_EXISTS ); return; } else { assert( !tag->vtxReadPtr ); tag->vtxReadPtr = tag->vtxWritePtr = new unsigned char[vertexCount * tag->size]; fill( tag->vtxWritePtr, tag->defaultValue, tag->size, vertexCount ); } } const unsigned char* ptr = reinterpret_cast< const unsigned char* >( data ); // as we're working with user-supplied arrays, make sure we're not // memcpying overlapping regions assert( ptr + tag->size * vertexCount <= tag->vtxWritePtr || tag->vtxWritePtr + tag->size * vertexCount <= ptr ); for( size_t i = 0; i < count; ++i ) { size_t idx = reinterpret_cast< size_t >( entities[i] ) - oneBasedArrays; memcpy( tag->vtxWritePtr + idx * tag->size, ptr + i * tag->size, tag->size ); } }
bool MBMesquite::ArrayMesh::valid | ( | ) | const [private] |
Definition at line 142 of file ArrayMesh.cpp.
References connArray, elementCount, fixedFlags, nodesPerElement, oneBasedArrays, and vertexCount.
Referenced by ArrayMesh(), and set_mesh().
{ unsigned long off = oneBasedArrays ? 1 : 0; for( unsigned long i = off; i < vertexCount + off; ++i ) { if( fixedFlags[i] != 0 && fixedFlags[i] != 1 ) { std::cerr << "Invalid vertex fixed flag at index " << i << std::endl; return false; } } for( unsigned long i = 0; i < elementCount * nodesPerElement; ++i ) { unsigned long j = connArray[i] - oneBasedArrays; if( j >= vertexCount ) { std::cerr << "Invalid connectivity index at index " << j << "(element " << j / elementCount << " node " << j % elementCount << ')' << std::endl; return false; } } return true; }
void MBMesquite::ArrayMesh::vertex_get_byte | ( | const VertexHandle | vertex, |
unsigned char * | byte, | ||
) | [virtual] |
Retrieve the byte value for the specified vertex or vertices. The byte value is 0 if it has not yet been set via one of the _set_byte() functions.
Definition at line 381 of file ArrayMesh.cpp.
References oneBasedArrays, vertexByteArray, and vertexCount.
{ assert( (size_t)vertex < vertexCount + oneBasedArrays ); *byte = vertexByteArray[(size_t)vertex]; }
VertexIterator * MBMesquite::ArrayMesh::vertex_iterator | ( | MsqError & | err | ) | [virtual] |
Definition at line 280 of file ArrayMesh.cpp.
{ return new IndexIterator( oneBasedArrays, vertexCount + oneBasedArrays ); }
void MBMesquite::ArrayMesh::vertex_set_byte | ( | VertexHandle | vertex, |
unsigned char | byte, | ||
) | [virtual] |
Each vertex has a byte-sized flag that can be used to store flags. This byte's value is neither set nor used by the mesh implementation. It is intended to be used by Mesquite algorithms. Until a vertex's byte has been explicitly set, its value is 0.
Definition at line 362 of file ArrayMesh.cpp.
{ assert( (size_t)vertex < vertexCount + oneBasedArrays ); vertexByteArray[(size_t)vertex] = byte; }
void MBMesquite::ArrayMesh::vertex_set_coordinates | ( | VertexHandle | vertex, |
const Vector3D & | coordinates, | ||
) | [virtual] |
Definition at line 347 of file ArrayMesh.cpp.
References coordArray, MBMesquite::Vector3D::get_coordinates(), MBMesquite::MsqError::INVALID_STATE, mDimension, MSQ_SETERR, oneBasedArrays, and vertexCount.
{ size_t i = (size_t)vert; assert( i < vertexCount + oneBasedArrays ); if( mDimension == 3 ) coordinates.get_coordinates( coordArray + 3 * i ); else if( mDimension == 2 ) { coordArray[2 * i] = coordinates[0]; coordArray[2 * i + 1] = coordinates[1]; } else MSQ_SETERR( err )( MsqError::INVALID_STATE ); }
void MBMesquite::ArrayMesh::vertices_get_attached_elements | ( | const VertexHandle * | vertex_array, |
size_t | num_vertex, | ||
std::vector< ElementHandle > & | elements, | ||
) | [virtual] |
Get adjacency data for vertices
vertex_array | Array of vertex handles specifying the list of vertices to retrieve adjacency data for. |
num_vertex | Number of vertex handles in #vertex_array |
elements | The array in which to place the handles of elements adjacent to the input vertices. |
offsets | For each vertex in #vertex_array, the value in the corresponding position in this array is the index into #elem_array at which the adjacency list begins for that vertex. |
Definition at line 400 of file ArrayMesh.cpp.
References build_vertex_adjacency_list(), oneBasedArrays, vertexAdjacencyList, vertexAdjacencyOffsets, and vertexCount.
{ const size_t* indices = (const size_t*)vertex_array; if( !vertexAdjacencyList ) build_vertex_adjacency_list(); elements.clear(); offsets.resize( num_vertex + 1 ); for( size_t i = 0; i < num_vertex; ++i ) { offsets[i] = elements.size(); assert( indices[i] < vertexCount + oneBasedArrays ); for( size_t j = vertexAdjacencyOffsets[indices[i]]; j < vertexAdjacencyOffsets[indices[i] + 1]; ++j ) elements.push_back( (ElementHandle)vertexAdjacencyList[j] ); } offsets[num_vertex] = elements.size(); }
void MBMesquite::ArrayMesh::vertices_get_byte | ( | const VertexHandle * | vertex, |
unsigned char * | byte_array, | ||
size_t | array_size, | ||
) | [virtual] |
Definition at line 387 of file ArrayMesh.cpp.
{ const size_t* indices = (const size_t*)vert_array; for( size_t i = 0; i < array_size; ++i ) { assert( indices[i] < vertexCount + oneBasedArrays ); byte_array[i] = vertexByteArray[indices[i]]; } }
void MBMesquite::ArrayMesh::vertices_get_coordinates | ( | const VertexHandle | vert_array[], |
MsqVertex * | coordinates, | ||
size_t | num_vtx, | ||
) | [virtual] |
Definition at line 325 of file ArrayMesh.cpp.
References coordArray, MBMesquite::MsqError::INVALID_STATE, mDimension, MSQ_SETERR, oneBasedArrays, MBMesquite::Vector3D::set(), and vertexCount.
{ const size_t* indices = (const size_t*)vert_array; if( mDimension == 3 ) for( size_t i = 0; i < num_vtx; ++i ) { assert( indices[i] < vertexCount + oneBasedArrays ); coordinates[i].set( coordArray + 3 * indices[i] ); } else if( mDimension == 2 ) for( size_t i = 0; i < num_vtx; ++i ) { assert( indices[i] < vertexCount + oneBasedArrays ); coordinates[i].set( coordArray[2 * indices[i]], coordArray[2 * indices[i] + 1], 0.0 ); } else MSQ_SETERR( err )( MsqError::INVALID_STATE ); }
void MBMesquite::ArrayMesh::vertices_get_fixed_flag | ( | const VertexHandle | vert_array[], |
std::vector< bool > & | fixed_flag_array, | ||
) | [virtual] |
Returns a pointer to an iterator that iterates over the set of all vertices in this mesh. The calling code should delete the returned iterator when it is finished with it. If vertices are added or removed from the Mesh after obtaining an iterator, the behavior of that iterator is undefined. Returns a pointer to an iterator that iterates over the set of all top-level elements in this mesh. The calling code should delete the returned iterator when it is finished with it. If elements are added or removed from the Mesh after obtaining an iterator, the behavior of that iterator is undefined. Returns true or false, indicating whether the vertex is allowed to be repositioned. True indicates that the vertex is fixed and cannot be moved. Note that this is a read-only property; this flag can't be modified by users of the MBMesquite::Mesh interface.
Definition at line 290 of file ArrayMesh.cpp.
References fixedFlags, and vertexCount.
{ fixed_flag_array.resize( num_vtx ); const size_t* indices = (const size_t*)vert_array; for( size_t i = 0; i < num_vtx; ++i ) { assert( indices[i] < vertexCount ); fixed_flag_array[i] = !!fixedFlags[indices[i]]; } }
void MBMesquite::ArrayMesh::vertices_get_slaved_flag | ( | const VertexHandle | vert_array[], |
std::vector< bool > & | slaved_flag_array, | ||
) | [virtual] |
Returns true or false, indicating whether the vertex is a higher-order node that should be slaved to the logical mid-point of the element side it lies on or not, respectively.
Note: This function will never be called unless this behavior is requested by calling: InstructionQueue::set_slaved_ho_node_mode( Settings::SLAVE_FLAG )
Definition at line 304 of file ArrayMesh.cpp.
References MBMesquite::MsqError::INVALID_STATE, MSQ_SETERR, slavedFlags, and vertexCount.
{ if( !slavedFlags ) { MSQ_SETERR( err ) ( "No data provided to ArrayMesh for Settings::SLAVE_FLAG", MsqError::INVALID_STATE ); return; } slaved_flags.resize( num_vtx ); const size_t* indices = (const size_t*)vert_array; for( size_t i = 0; i < num_vtx; ++i ) { assert( indices[i] < vertexCount ); slaved_flags[i] = !!slavedFlags[indices[i]]; } }
void MBMesquite::ArrayMesh::vertices_set_byte | ( | const VertexHandle * | vert_array, |
const unsigned char * | byte_array, | ||
) | [virtual] |
Definition at line 368 of file ArrayMesh.cpp.
Referenced by TerminationCriterionTest::test_abs_vtx_movement_culling().
{ const size_t* indices = (const size_t*)vert_array; for( size_t i = 0; i < array_size; ++i ) { assert( indices[i] < vertexCount + oneBasedArrays ); vertexByteArray[indices[i]] = byte_array[i]; } }
unsigned long* MBMesquite::ArrayMesh::allocConnOffsets [private] |
Same as connOffsets if allocated by constructor. NULL if connOffsets is either NULL or application-provided data.
Definition at line 333 of file ArrayMesh.hpp.
Referenced by ArrayMesh(), and clear_mesh().
const unsigned long* MBMesquite::ArrayMesh::connArray [private] |
Definition at line 328 of file ArrayMesh.hpp.
Referenced by ArrayMesh(), elem_verts(), set_mesh(), and valid().
const unsigned long* MBMesquite::ArrayMesh::connOffsets [private] |
Offsets into connectivity array for each element. If NULL, then all elements are of the same type and have the same number of vertices.
Definition at line 329 of file ArrayMesh.hpp.
Referenced by ArrayMesh(), clear_mesh(), and elem_verts().
double* MBMesquite::ArrayMesh::coordArray [private] |
Definition at line 322 of file ArrayMesh.hpp.
Referenced by ArrayMesh(), clear_mesh(), set_mesh(), vertex_set_coordinates(), and vertices_get_coordinates().
unsigned long MBMesquite::ArrayMesh::elementCount [private] |
Number of elements.
Definition at line 327 of file ArrayMesh.hpp.
Referenced by build_vertex_adjacency_list(), clear_mesh(), elem_verts(), element_iterator(), elements_get_attached_vertices(), elements_get_topologies(), get_all_elements(), set_mesh(), tag_set_element_data(), and valid().
Definition at line 337 of file ArrayMesh.hpp.
Referenced by clear_mesh(), elements_get_topologies(), and set_mesh().
const EntityTopology* MBMesquite::ArrayMesh::elementTypes [private] |
Definition at line 338 of file ArrayMesh.hpp.
Referenced by ArrayMesh(), clear_mesh(), and elements_get_topologies().
const int* MBMesquite::ArrayMesh::fixedFlags [private] |
Vertex fixed flags.
Definition at line 323 of file ArrayMesh.hpp.
Referenced by ArrayMesh(), clear_mesh(), set_mesh(), valid(), and vertices_get_fixed_flag().
int MBMesquite::ArrayMesh::mDimension [private] |
Definition at line 320 of file ArrayMesh.hpp.
Referenced by ArrayMesh(), clear_mesh(), get_geometric_dimension(), set_mesh(), vertex_set_coordinates(), and vertices_get_coordinates().
unsigned MBMesquite::ArrayMesh::nodesPerElement [private] |
Definition at line 339 of file ArrayMesh.hpp.
Referenced by ArrayMesh(), clear_mesh(), elem_verts(), set_mesh(), and valid().
bool MBMesquite::ArrayMesh::oneBasedArrays [private] |
Definition at line 340 of file ArrayMesh.hpp.
Referenced by ArrayMesh(), build_vertex_adjacency_list(), clear_mesh(), get_all_vertices(), set_mesh(), tag_get_vertex_data(), tag_set_vertex_data(), valid(), vertex_get_byte(), vertex_iterator(), vertex_set_byte(), vertex_set_coordinates(), vertices_get_attached_elements(), vertices_get_byte(), vertices_get_coordinates(), and vertices_set_byte().
const int* MBMesquite::ArrayMesh::slavedFlags [private] |
Definition at line 324 of file ArrayMesh.hpp.
Referenced by set_mesh(), and vertices_get_slaved_flag().
Tag* MBMesquite::ArrayMesh::tagList [private] |
Definition at line 374 of file ArrayMesh.hpp.
Referenced by allocate_tag(), clear_mesh(), tag_delete(), and tag_get().
unsigned long* MBMesquite::ArrayMesh::vertexAdjacencyList [private] |
Definition at line 342 of file ArrayMesh.hpp.
Referenced by build_vertex_adjacency_list(), clear_mesh(), and vertices_get_attached_elements().
unsigned long* MBMesquite::ArrayMesh::vertexAdjacencyOffsets [private] |
Definition at line 343 of file ArrayMesh.hpp.
unsigned char* MBMesquite::ArrayMesh::vertexByteArray [private] |
Vertex bytes.
Definition at line 325 of file ArrayMesh.hpp.
Referenced by ArrayMesh(), clear_mesh(), set_mesh(), vertex_get_byte(), vertex_set_byte(), vertices_get_byte(), and vertices_set_byte().
unsigned long MBMesquite::ArrayMesh::vertexCount [private] |
Number of vertices.
Definition at line 321 of file ArrayMesh.hpp.
Referenced by build_vertex_adjacency_list(), clear_mesh(), get_all_vertices(), set_mesh(), tag_set_vertex_data(), valid(), vertex_get_byte(), vertex_iterator(), vertex_set_byte(), vertex_set_coordinates(), vertices_get_attached_elements(), vertices_get_byte(), vertices_get_coordinates(), vertices_get_fixed_flag(), vertices_get_slaved_flag(), and vertices_set_byte().
