cubit_perf.cpp File Reference
#include <sys/resource.h>
#include <cstdlib>
#include <cstdio>
#include <iostream>
#include "CubitNode.hpp"
#include "NodeHex.hpp"
+ Include dependency graph for cubit_perf.cpp:
Defines
#define VINDEX(i, j, k)   ( ( i ) + ( (j)*numv ) + ( (k)*numv_sq ) )
Functions
void __ctype_toupper ()
void print_time (const bool print_em, double &tot_time, double &utime, double &stime)
void build_coords (const int nelem, double *&coords)
void build_connect (const int nelem, int *&connect)
int main (int argc, char *argv[])
Variables
const double LENGTH = 1.0
Define Documentation
#define VINDEX (   i,
  j,
Function Documentation
void __ctype_toupper ( )
Definition at line 41 of file cubit_perf.cpp.
void build_connect ( const int  nelem,
int *&  connect
Definition at line 75 of file cubit_perf.cpp.
References VINDEX.
Referenced by main().
    // allocate the memory
    int nume_tot = nelem * nelem * nelem;
    connect      = new int[8 * nume_tot];
    int numv    = nelem + 1;
    int numv_sq = numv * numv;
    int idx     = 0;
    int vijk;
    for( int i = 0; i < nelem; i++ )
        for( int j = 0; j < nelem; j++ )
            for( int k = 0; k < nelem; k++ )
                vijk           = VINDEX( i, j, k );
                connect[idx++] = vijk;
                connect[idx++] = vijk + 1;
                connect[idx++] = vijk + 1 + numv;
                connect[idx++] = vijk + numv;
                connect[idx++] = vijk + numv * numv;
                connect[idx++] = vijk + 1 + numv * numv;
                connect[idx++] = vijk + 1 + numv + numv * numv;
                connect[idx++] = vijk + numv + numv * numv;
                assert( idx <= 8 * nume_tot );
void build_coords ( const int  nelem,
double *&  coords
Definition at line 46 of file cubit_perf.cpp.
References LENGTH, and VINDEX.
    int tot_numv = numv * numv * numv;
    coords       = new double[3 * tot_numv];
    double scale = LENGTH / nelem;
// use FORTRAN-like indexing
#define VINDEX( i, j, k ) ( ( i ) + ( (j)*numv ) + ( (k)*numv_sq ) )
    int idx;
    for( int i = 0; i < numv; i++ )
        for( int j = 0; j < numv; j++ )
            for( int k = 0; k < numv; k++ )
                idx = VINDEX( i, j, k );
                // interleaved coordinate ordering
                coords[3 * idx]     = i * scale;
                coords[3 * idx + 1] = j * scale;
                coords[3 * idx + 2] = k * scale;
int main ( int  argc,
char *  argv[]
Definition at line 106 of file cubit_perf.cpp.
References build_connect(), build_coords(), and print_time().
    int nelem = 20;
    if( argc > 1 )
        sscanf( argv[1], "%d", &nelem );
    std::cout << "number of elements: " << nelem << std::endl;
    // create a hex mesh in a 1x1x1 cube with nelem number of
    // elements along an edge
    int nnodes = nelem + 1;
    double* coords = NULL;
    int* connect   = NULL;
    // build the coordinates
    build_coords( nelem, coords );
    // build the connectivity
    build_connect( nelem, connect );
    assert( NULL != connect && NULL != coords );
    double ttime0, ttime1, ttime2, ttime3, utime, stime;
    print_time( false, ttime0, utime, stime );
    int nodes_tot          = nnodes * nnodes * nnodes;
    CubitNode** node_array = new CubitNode*[nodes_tot];
    int i;
    for( i = 0; i < nodes_tot; i++ )
        node_array[i] = new CubitNode( coords[3 * i], coords[3 * i + 1], coords[3 * i + 2] );
    int nelem_tot       = nelem * nelem * nelem;
    NodeHex** hex_array = new NodeHex*[nelem_tot];
    int j               = 0;
    CubitNode* conn[8];
    for( i = 0; i < nelem_tot; i++ )
        conn[0] = node_array[connect[j]];
        conn[1] = node_array[connect[j + 1]];
        conn[2] = node_array[connect[j + 2]];
        conn[3] = node_array[connect[j + 3]];
        conn[4] = node_array[connect[j + 4]];
        conn[5] = node_array[connect[j + 5]];
        conn[6] = node_array[connect[j + 6]];
        conn[7] = node_array[connect[j + 7]];
        j += 8;
        hex_array[i] = new NodeHex( conn );
    print_time( false, ttime1, utime, stime );
    // query element to vertex
        double centroid[3] = { 0.0, 0.0, 0.0 };
        hex_array[i]->hex_nodes( conn[0], conn[1], conn[2], conn[3], conn[4], conn[5], conn[6], conn[7] );
        for( j = 0; j < 8; j++ )
            centroid[0] += conn[j]->node_x();
            centroid[1] += conn[j]->node_y();
            centroid[2] += conn[j]->node_z();
    print_time( false, ttime2, utime, stime );
    // need to allocate & populate TDHexKnowing for these
        hex_array[i]->add_hex_to_nodes();
    DLIList< CubitHex* > hexes;
        node_array[i]->all_hexes( hexes );
    print_time( false, ttime3, utime, stime );
    std::cout << "CUBIT: nelem, construct, e_to_v query, v_to_e query = " << nelem << ", " << ttime1 - ttime0 << ", "
              << ttime2 - ttime1 << ", " << ttime3 - ttime2 << " seconds" << std::endl;
    return 0;
void print_time ( const bool  print_em,
double &  tot_time,
double &  utime,
double &  stime
Definition at line 192 of file cubit_perf.cpp.
    struct rusage r_usage;
    getrusage( RUSAGE_SELF, &r_usage );
    utime    = (double)r_usage.ru_utime.tv_sec + ( (double)r_usage.ru_utime.tv_usec / 1.e6 );
    stime    = (double)r_usage.ru_stime.tv_sec + ( (double)r_usage.ru_stime.tv_usec / 1.e6 );
    tot_time = utime + stime;
    if( print_em )
        std::cout << "User, system, total time = " << utime << ", " << stime << ", " << tot_time << std::endl;
#ifndef LINUX
    std::cout << "Max resident set size = " << r_usage.ru_maxrss * 4096 << " bytes" << std::endl;
    std::cout << "Int resident set size = " << r_usage.ru_idrss << std::endl;
#else
    system( "ps o args,drs,rss | grep perf | grep -v grep" );  // RedHat 9.0 doesnt fill in actual
                                                               // memory data
#endif
Variable Documentation
Definition at line 38 of file cubit_perf.cpp.
Referenced by build_coords().
