MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /* ***************************************************************** 00002 MESQUITE -- The Mesh Quality Improvement Toolkit 00003 00004 Copyright 2004 Sandia Corporation and Argonne National 00005 Laboratory. Under the terms of Contract DE-AC04-94AL85000 00006 with Sandia Corporation, the U.S. Government retains certain 00007 rights in this software. 00008 00009 This library is free software; you can redistribute it and/or 00010 modify it under the terms of the GNU Lesser General Public 00011 License as published by the Free Software Foundation; either 00012 version 2.1 of the License, or (at your option) any later version. 00013 00014 This library is distributed in the hope that it will be useful, 00015 but WITHOUT ANY WARRANTY; without even the implied warranty of 00016 MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00017 Lesser General Public License for more details. 00018 00019 You should have received a copy of the GNU Lesser General Public License 00020 (lgpl.txt) along with this library; if not, write to the Free Software 00021 Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA 00022 00023 [email protected], [email protected], [email protected], 00024 [email protected], [email protected], [email protected] 00025 00026 ***************************************************************** */ 00027 // -*- Mode : c++; tab-width: 2; c-tab-always-indent: t; indent-tabs-mode: nil; c-basic-offset: 2 00028 // -*- 00029 // 00030 // SUMMARY: 00031 // USAGE: 00032 // 00033 // ORIG-DATE: 24-Jan-12 00034 // LAST-MOD: 26-Jan-1 by Stephen Kennon 00035 // 00036 // 00037 // DESCRIPTION: 00038 // ============ 00039 /*! \file par_hex.cpp 00040 00041 A test of MBMesquite's parallel capabilities. Reads a split vtk file, smooths in parallel using 00042 Laplace smoothing, writes out the result (which can be compared with the "gold" copy of the same 00043 name in the meshFiles VTK directory). 00044 00045 See the MBMesquite User's Guide, section "Using MBMesquite in Parallel" - this code is very similar 00046 to the example code shown therein. 00047 00048 */ 00049 // DESCRIP-END. 00050 // 00051 00052 #include "TestUtil.hpp" 00053 #include "MeshImpl.hpp" 00054 #include "MeshUtil.hpp" 00055 #include "MsqTimer.hpp" 00056 #include "MsqDebug.hpp" 00057 #include "Mesquite.hpp" 00058 #include "MsqError.hpp" 00059 #include "Vector3D.hpp" 00060 #include "InstructionQueue.hpp" 00061 #include "LaplaceWrapper.hpp" 00062 #include "PatchData.hpp" 00063 #include "TerminationCriterion.hpp" 00064 #include "QualityAssessor.hpp" 00065 00066 /* MBMesquite includes */ 00067 #include "ParallelMeshImpl.hpp" 00068 #include "ParallelHelper.hpp" 00069 00070 // algorithms 00071 #include "Randomize.hpp" 00072 #include "ConditionNumberQualityMetric.hpp" 00073 #include "UntangleBetaQualityMetric.hpp" 00074 #include "LPtoPTemplate.hpp" 00075 #include "LInfTemplate.hpp" 00076 #include "SteepestDescent.hpp" 00077 #include "ConjugateGradient.hpp" 00078 #include "PlanarDomain.hpp" 00079 00080 #include <iostream> 00081 using std::cout; 00082 using std::endl; 00083 #include <cstdlib> 00084 00085 #include <mpi.h> 00086 #include <sstream> 00087 00088 using namespace MBMesquite; 00089 00090 std::string VTK_3D_DIR = TestDir + "unittest/mesquite/3D/vtk/hexes/tangled/"; 00091 00092 using namespace std; 00093 00094 int main( int argc, char* argv[] ) 00095 { 00096 /* init MPI */ 00097 int rank, nprocs; 00098 if( MPI_SUCCESS != MPI_Init( &argc, &argv ) ) 00099 { 00100 cerr << "MPI_Init failed." << endl; 00101 return 2; 00102 } 00103 MPI_Comm_rank( MPI_COMM_WORLD, &rank ); 00104 MPI_Comm_size( MPI_COMM_WORLD, &nprocs ); 00105 00106 if( nprocs > 2 ) 00107 { 00108 cerr << "parallel_laplace_smooth test can only be run with 1 or 2 processors" << std::endl; 00109 return 0; 00110 } 00111 00112 const int debug = 0; // 1,2,3 for more debug info 00113 if( debug ) 00114 { 00115 MsqDebug::enable( 1 ); 00116 if( debug > 1 ) MsqDebug::enable( 2 ); 00117 if( debug > 2 ) MsqDebug::enable( 3 ); 00118 } 00119 00120 /* create processor-specific file names */ 00121 ostringstream in_name, out_name, gold_name; 00122 in_name << VTK_3D_DIR << "par_original_hex_mesh." << nprocs << "." << rank << ".vtk"; 00123 gold_name << VTK_3D_DIR << "par_smoothed_hex_mesh." << nprocs << "." << rank << ".vtk"; 00124 out_name << "par_smoothed_hex_mesh." << nprocs << "." << rank << ".vtk"; 00125 00126 /* load different mesh files on each processor */ 00127 MBMesquite::MsqError err; 00128 MBMesquite::MeshImpl mesh; 00129 mesh.read_vtk( in_name.str().c_str(), err ); 00130 if( err ) 00131 { 00132 cerr << err << endl; 00133 return 1; 00134 } 00135 00136 /* create parallel mesh instance, specifying tags 00137 * containing parallel data */ 00138 MBMesquite::ParallelMeshImpl parallel_mesh( &mesh, "GLOBAL_ID", "PROCESSOR_ID" ); 00139 MBMesquite::ParallelHelperImpl helper; 00140 helper.set_communicator( MPI_COMM_WORLD ); 00141 helper.set_parallel_mesh( ¶llel_mesh ); 00142 parallel_mesh.set_parallel_helper( &helper ); 00143 00144 /* do Laplacian smooth */ 00145 LaplaceWrapper optimizer; 00146 optimizer.set_vertex_movement_limit_factor( 1.e-10 ); 00147 optimizer.set_iteration_limit( 2000 ); 00148 optimizer.enable_culling( false ); 00149 optimizer.run_instructions( ¶llel_mesh, err ); 00150 if( err ) 00151 { 00152 cerr << err << endl; 00153 return 1; 00154 } 00155 00156 /* write mesh */ 00157 mesh.write_vtk( out_name.str().c_str(), err ); 00158 if( err ) 00159 { 00160 cerr << err << endl; 00161 return 1; 00162 } 00163 00164 /* compare mesh with gold copy */ 00165 MeshImpl gold; 00166 gold.read_vtk( gold_name.str().c_str(), err ); 00167 if( err ) 00168 { 00169 cerr << err << endl; 00170 return 1; 00171 } 00172 00173 bool do_print = true; 00174 double tol = 1.e-4; 00175 bool diff = MeshUtil::meshes_are_different( mesh, gold, err, tol, do_print ); 00176 if( err ) 00177 { 00178 cerr << err << endl; 00179 return 1; 00180 } 00181 00182 if( diff ) 00183 { 00184 cerr << "Error, computed mesh different from gold copy" << std::endl; 00185 return 1; 00186 } 00187 00188 print_timing_diagnostics( cout ); 00189 00190 MPI_Finalize(); 00191 return 0; 00192 }
