test_both.cpp
00001 #include "iGeom.h"
00002 #include "iMesh.h"
00003 #include "iRel.h"
00004
00005 #include "TestUtil.hpp"
00006
00007 #include <cstdlib>
00008
00009 using namespace moab;
00010 iGeom_Instance geom;
00011 iMesh_Instance mesh;
00012 iRel_Instance rel;
00013
00014 iBase_EntityHandle geom_ent;
00015 iBase_EntityHandle mesh_ents[4];
00016 iBase_EntitySetHandle mesh_set;
00017
00018 void test_both()
00019 {
00020     int err;
00021     iRel_PairHandle pair;
00022
00023     iRel_createPair( rel, geom, iRel_ENTITY, iRel_IGEOM_IFACE, iRel_ACTIVE, mesh, iRel_BOTH, iRel_IMESH_IFACE,
00024                      iRel_ACTIVE, &pair, &err );CHECK_ERR( err );
00025
00026     iRel_setEntSetRelation( rel, pair, geom_ent, mesh_set, &err );CHECK_ERR( err );
00027
00028     iBase_EntityHandle* related_ents = NULL;
00029     int related_ents_alloc           = 0, related_ents_size;
00030     iRel_getEntArrEntArrRelation( rel, pair, mesh_ents, 4, 1, &related_ents, &related_ents_alloc, &related_ents_size,
00031                                   &err );CHECK_ERR( err );
00032
00033     for( int i = 0; i < related_ents_size; i++ )
00034         CHECK_EQUAL( related_ents[i], geom_ent );
00035
00036     free( related_ents );
00037 }
00038
00039 void test_change_to_both()
00040 {
00041     int err;
00042     iRel_PairHandle pair;
00043
00044     iRel_createPair( rel, geom, iRel_ENTITY, iRel_IGEOM_IFACE, iRel_ACTIVE, mesh, iRel_SET, iRel_IMESH_IFACE,
00045                      iRel_ACTIVE, &pair, &err );CHECK_ERR( err );
00046
00047     iRel_setEntSetRelation( rel, pair, geom_ent, mesh_set, &err );CHECK_ERR( err );
00048
00049     iRel_changePairType( rel, pair, iRel_ENTITY, iRel_BOTH, &err );CHECK_ERR( err );
00050
00051     iBase_EntityHandle* related_ents = NULL;
00052     int related_ents_alloc           = 0, related_ents_size;
00053     iRel_getEntArrEntArrRelation( rel, pair, mesh_ents, 4, 1, &related_ents, &related_ents_alloc, &related_ents_size,
00054                                   &err );CHECK_ERR( err );
00055
00056     for( int i = 0; i < related_ents_size; i++ )
00057         CHECK_EQUAL( related_ents[i], geom_ent );
00058
00059     free( related_ents );
00060 }
00061
00062 void test_change_to_set()
00063 {
00064     int err;
00065     iRel_PairHandle pair;
00066
00067     iRel_createPair( rel, geom, iRel_ENTITY, iRel_IGEOM_IFACE, iRel_ACTIVE, mesh, iRel_BOTH, iRel_IMESH_IFACE,
00068                      iRel_ACTIVE, &pair, &err );CHECK_ERR( err );
00069
00070     iRel_setEntSetRelation( rel, pair, geom_ent, mesh_set, &err );CHECK_ERR( err );
00071
00072     iRel_changePairType( rel, pair, iRel_ENTITY, iRel_SET, &err );CHECK_ERR( err );
00073
00074     for( int i = 0; i < 4; i++ )
00075     {
00076         iBase_EntityHandle related_ent;
00077         iRel_getEntEntRelation( rel, pair, mesh_ents[i], 1, &related_ent, &err );
00078         CHECK( err != iBase_SUCCESS );
00079     }
00080 }
00081
00082 int main()
00083 {
00084     int err;
00085     int num_fail = 0;
00086
00087     iGeom_newGeom( 0, &geom, &err, 0 );
00088     iMesh_newMesh( 0, &mesh, &err, 0 );
00089     iRel_create( 0, &rel, &err, 0 );
00090
00091     iGeom_createBrick( geom, 2, 2, 2, &geom_ent, &err );
00092
00093     double coords[] = {
00094         0, 0, 0, 0, 1, 0, 1, 1, 0, 1, 0, 0,
00095     };
00096
00097     iBase_EntityHandle* mesh_ents_ptr = mesh_ents;
00098     int mesh_ents_alloc               = 4, mesh_ents_size;
00099     iMesh_createVtxArr( mesh, 4, iBase_INTERLEAVED, coords, 12, &mesh_ents_ptr, &mesh_ents_alloc, &mesh_ents_size,
00100                         &err );
00101
00102     iMesh_createEntSet( mesh, false, &mesh_set, &err );
00103     iMesh_addEntArrToSet( mesh, mesh_ents, mesh_ents_size, mesh_set, &err );
00104
00105     num_fail += RUN_TEST( test_both );
00106     num_fail += RUN_TEST( test_change_to_both );
00107     num_fail += RUN_TEST( test_change_to_set );
00108
00109     iRel_destroy( rel, &err );
00110     iMesh_dtor( mesh, &err );
00111     iGeom_dtor( geom, &err );
00112
00113     return num_fail;
00114 }
