iRel.h File Reference
#include "iBase.h"
#include "iRel_protos.h"
+ Include dependency graph for iRel.h:
+ This graph shows which files directly or indirectly include this file:
Defines
#define IREL_VERSION_MAJOR   1
 Compile time version number digits.
#define IREL_VERSION_MINOR   1
#define IREL_VERSION_PATCH   0
#define IREL_MAJOR_VERSION   IREL_VERSION_MAJOR
 Maintain backward compatibility with old version symbol names.
#define IREL_MINOR_VERSION   IREL_VERSION_MINOR
#define IREL_PATCH_VERSION   IREL_VERSION_PATCH
#define IREL_VERSION_GE(Maj, Min, Pat)   ITAPS_VERSION_GE( Maj, Min, Pat )
 Version Comparison.
#define IREL_VERSION_STRING   ITAPS_VERSION_STRING_( iRel )
 Compose string represention of the iRel version number.
#define IREL_VERSION_TAG   ITAPS_VERSION_TAG_( iRel )
 Compose a symbol name derived from the current iRel version number.
#define IREL_CREATE_NAME__(A, B, C)   A##_##B##_##C
 Define iRel_create symbol such that it depends on version number.
#define IREL_CREATE_NAME_(A, B, C)   IREL_CREATE_NAME__( A, B, C )
#define IREL_CREATE_NAME(A)   IREL_CREATE_NAME_( A, IREL_VERSION_MAJOR, IREL_VERSION_MINOR )
Typedefs
typedef void * iRel_Instance
typedef struct
iRel_PairHandle_Private *
iRel_PairHandle
Enumerations
enum  iRel_IfaceType {
  iRel_IfaceType_MIN = 0, iRel_IGEOM_IFACE = iRel_IfaceType_MIN, iRel_IMESH_IFACE, iRel_IFIELD_IFACE,
  iRel_IREL_IFACE, iRel_FBIGEOM_IFACE, iRel_IfaceType_MAX = iRel_FBIGEOM_IFACE
enum  iRel_RelationType {
  iRel_RelationType_MIN = 0, iRel_ENTITY = iRel_RelationType_MIN, iRel_SET, iRel_BOTH,
  iRel_RelationType_MAX = iRel_BOTH
enum  iRel_RelationStatus {
  iRel_RelationStatus_MIN = 0, iRel_ACTIVE = iRel_RelationType_MIN, iRel_INACTIVE, iRel_NOTEXIST,
  iRel_RelationStatus_MAX = iRel_NOTEXIST
Functions
void iRel_getErrorType (iRel_Instance instance, int *error_type)
 Get the error type returned from the last iRel function.
void iRel_getDescription (iRel_Instance instance, char *descr, int descr_len)
 Get a description of the error returned from the last iRel function.
void iRel_create (const char *options, iRel_Instance *instance, int *err, const int options_len)
 Create a new iRel instance.
void iRel_destroy (iRel_Instance instance, int *err)
 Destroy the interface object.
void iRel_createPair (iRel_Instance instance, iBase_Instance iface1, const int ent_or_set1, const int iface_type1, const int irel_status1, iBase_Instance iface2, const int ent_or_set2, const int iface_type2, const int irel_status2, iRel_PairHandle *pair, int *err)
 Create a relation pair between two interfaces.
void iRel_getPairInfo (iRel_Instance instance, iRel_PairHandle pair, iBase_Instance *iface1, int *ent_or_set1, int *iface_type1, int *irel_status1, iBase_Instance *iface2, int *ent_or_set2, int *iface_type2, int *irel_status2, int *err)
 Get information for this relation handle.
void iRel_changePairType (iRel_Instance instance, iRel_PairHandle pair, int ent_or_set1, int ent_or_set2, int *err)
 Change the relation type.
void iRel_changePairStatus (iRel_Instance instance, iRel_PairHandle pair, int irel_status1, int irel_status2, int *err)
 Change the relation status.
void iRel_destroyPair (iRel_Instance instance, iRel_PairHandle pair, int *err)
 Destroy a relation pair.
void iRel_findPairs (iRel_Instance instance, iBase_Instance iface, iRel_PairHandle **pairs, int *pairs_allocated, int *pairs_size, int *err)
 Get relations containing specified interface.
void iRel_setEntEntRelation (iRel_Instance instance, iRel_PairHandle pair, iBase_EntityHandle ent1, iBase_EntityHandle ent2, int *err)
 Set a relation between two entities.
void iRel_setEntSetRelation (iRel_Instance instance, iRel_PairHandle pair, iBase_EntityHandle ent1, iBase_EntitySetHandle entset2, int *err)
 Set a relation between an entity and an entity set.
void iRel_setSetEntRelation (iRel_Instance instance, iRel_PairHandle pair, iBase_EntitySetHandle entset1, iBase_EntityHandle ent2, int *err)
 Set a relation between an entity set an an entity.
void iRel_setSetSetRelation (iRel_Instance instance, iRel_PairHandle pair, iBase_EntitySetHandle entset1, iBase_EntitySetHandle entset2, int *err)
 Set a relation between two entity sets.
void iRel_setEntArrEntArrRelation (iRel_Instance instance, iRel_PairHandle pair, iBase_EntityHandle *ent_array_1, int num_ent1, iBase_EntityHandle *ent_array_2, int num_ent2, int *err)
 Set relations between arrays of entities pairwise, ent_array_1[i]<->ent_array_2[i].
void iRel_setSetArrEntArrRelation (iRel_Instance instance, iRel_PairHandle pair, iBase_EntitySetHandle *entset_array_1, int num_set1, iBase_EntityHandle *ent_array_2, int num_ent2, int *err)
 Set relations between arrays of entity sets and entities.
void iRel_setEntArrSetArrRelation (iRel_Instance instance, iRel_PairHandle pair, iBase_EntityHandle *ent_array_1, int num_ent1, iBase_EntitySetHandle *entset_array_2, int num_set2, int *err)
 Set relations between arrays of entities and entity sets.
void iRel_setSetArrSetArrRelation (iRel_Instance instance, iRel_PairHandle pair, iBase_EntitySetHandle *entset_array_1, int num_set1, iBase_EntitySetHandle *entset_array_2, int num_set2, int *err)
 Set relations between arrays of entity sets pairwise, ent_array_1[i]<->ent_array_2[i].
void iRel_getEntEntRelation (iRel_Instance instance, iRel_PairHandle pair, iBase_EntityHandle ent1, int switch_order, iBase_EntityHandle *ent2, int *err)
 Get entity related to specified entity and relation handle.
void iRel_getEntSetRelation (iRel_Instance instance, iRel_PairHandle pair, iBase_EntityHandle ent1, int switch_order, iBase_EntitySetHandle *entset2, int *err)
 Get entity set related to specified entity and relation handle.
void iRel_getSetEntRelation (iRel_Instance instance, iRel_PairHandle pair, iBase_EntitySetHandle entset1, int switch_order, iBase_EntityHandle *ent2, int *err)
 Get entity related to specified entity set and relation handle.
void iRel_getSetSetRelation (iRel_Instance instance, iRel_PairHandle pair, iBase_EntitySetHandle entset1, int switch_order, iBase_EntitySetHandle *entset2, int *err)
 Get entity set related to specified entity set and relation handle.
void iRel_getEntSetIterRelation (iRel_Instance instance, iRel_PairHandle pair, iBase_EntityHandle ent1, int switch_order, iBase_EntityIterator *entIter, int *err)
 Get entity iterator related to specified entity set and relation handle.
void iRel_getEntArrEntArrRelation (iRel_Instance instance, iRel_PairHandle pair, iBase_EntityHandle *ent_array_1, int ent_array_1_size, int switch_order, iBase_EntityHandle **ent_array_2, int *ent_array_2_allocated, int *ent_array_2_size, int *err)
 Get entities related to those in specified array and relation, pairwise.
void iRel_getEntArrSetArrRelation (iRel_Instance instance, iRel_PairHandle pair, iBase_EntityHandle *ent_array_1, int ent_array_1_size, int switch_order, iBase_EntitySetHandle **entset_array_2, int *entset_array_2_allocated, int *entset_array_2_size, int *err)
 Get entity sets related to entities in specified array and relation, pairwise.
void iRel_getSetArrEntArrRelation (iRel_Instance instance, iRel_PairHandle pair, iBase_EntitySetHandle *entset_array_1, int entset_array_1_size, int switch_order, iBase_EntityHandle **ent_array_2, int *ent_array_2_allocated, int *ent_array_2_size, int *err)
 Get entities related to entity sets in specified array and relation, pairwise.
void iRel_getSetArrSetArrRelation (iRel_Instance instance, iRel_PairHandle pair, iBase_EntitySetHandle *entset_array_1, int entset_array_1_size, int switch_order, iBase_EntitySetHandle **entset_array_2, int *entset_array_2_allocated, int *entset_array_2_size, int *err)
 Get entity sets related to entity sets in specified array and relation, pairwise.
void iRel_getEntArrSetIterArrRelation (iRel_Instance instance, iRel_PairHandle pair, iBase_EntityHandle *ent_array_1, int ent_array_1_size, int switch_order, iBase_EntityIterator **entiter, int *entiter_allocated, int *entiter_size, int *err)
 Get entity iterators related to entity sets in specified array and relation.
void iRel_rmvEntRelation (iRel_Instance instance, iRel_PairHandle pair, iBase_EntityHandle ent, int switch_order, int *err)
 Remove a relation from an entity.
void iRel_rmvSetRelation (iRel_Instance instance, iRel_PairHandle pair, iBase_EntitySetHandle set, int switch_order, int *err)
 Remove a relation from an entity set.
void iRel_rmvEntArrRelation (iRel_Instance instance, iRel_PairHandle pair, iBase_EntityHandle *ent_array_1, int num_ent1, int switch_order, int *err)
 Remove a relation from an array of entities.
void iRel_rmvSetArrRelation (iRel_Instance instance, iRel_PairHandle pair, iBase_EntitySetHandle *entset_array_1, int num_entset1, int switch_order, int *err)
 Remove a relation from an array of entity sets.
void iRel_inferAllRelations (iRel_Instance instance, iRel_PairHandle pair, int *err)
 Infer relations between entities in specified pair of interfaces.
void iRel_inferAllRelationsAndType (iRel_Instance instance, iRel_PairHandle *pair, int *err)
 Infer relations and relation type between entities in specified pair of interfaces.
void iRel_inferEntRelations (iRel_Instance instance, iRel_PairHandle pair, iBase_EntityHandle entity, int iface_no, int *err)
 Infer relations corresponding to specified entity and relation pair.
void iRel_inferSetRelations (iRel_Instance instance, iRel_PairHandle pair, iBase_EntitySetHandle entity_set, int iface_no, int *err)
 Brief unavailable.
void iRel_inferEntArrRelations (iRel_Instance instance, iRel_PairHandle pair, iBase_EntityHandle *entities, int entities_size, int iface_no, int *err)
 Infer relations corresponding to specified entities and relation pair.
void iRel_inferSetArrRelations (iRel_Instance instance, iRel_PairHandle pair, iBase_EntitySetHandle *entity_sets, int entities_size, int iface_no, int *err)
 Brief unavailable.
Define Documentation
Definition at line 106 of file iRel.h.
#define IREL_CREATE_NAME_ (   A,
  B,
Definition at line 105 of file iRel.h.
#define IREL_CREATE_NAME__ (   A,
  B,
)    A##_##B##_##C
VersionNumbers Note: We ran into problems with this as it influences or is influenced by fortran name mangling and so breaks fortran compilation. So, this is currently disabled.
Definition at line 104 of file iRel.h.
VersionNumbers
Definition at line 45 of file iRel.h.
Definition at line 46 of file iRel.h.
Definition at line 47 of file iRel.h.
#define IREL_VERSION_GE (   Maj,
  Min,
  Pat
Version Comparison.
VersionNumbers Evaluates to true at CPP time if the version of iRel currently being compiled is greater than or equal to the version specified.
Definition at line 63 of file iRel.h.
VersionNumbers iRel maintains a major, minor and patch digit in its version number. Technically speaking, there is not much practical value in patch digit for an interface specification. A patch release is typically only used for bug fix releases. Although it is rare, sometimes a bug fix necessitates an API change. So, we define a patch digit for iRel.
Definition at line 32 of file iRel.h.
Definition at line 33 of file iRel.h.
Definition at line 34 of file iRel.h.
VersionNumbers
Definition at line 73 of file iRel.h.
VersionNumbers
Definition at line 83 of file iRel.h.
Typedef Documentation
typedef void* iRel_Instance
Definition at line 119 of file iRel.h.
typedef struct iRel_PairHandle_Private* iRel_PairHandle
Definition at line 120 of file iRel.h.
Enumeration Type Documentation
Enumerator:
iRel_IfaceType_MIN
facilitates iteration over all values
iRel_IGEOM_IFACE
description unavailable
iRel_IMESH_IFACE
iRel_IFIELD_IFACE
iRel_IREL_IFACE
iRel_FBIGEOM_IFACE
iRel_IfaceType_MAX
Definition at line 141 of file iRel.h.
    /**< facilitates iteration over all values */
    /**< description unavailable */
    iRel_IMESH_IFACE,
    iRel_IFIELD_IFACE,
    iRel_IREL_IFACE,
    iRel_FBIGEOM_IFACE,
Enumerator:
iRel_ACTIVE
the relation on this side is active and up to date
iRel_INACTIVE
the relation on this side is inactive, and may be out of date
iRel_NOTEXIST
the relation on this side is not stored
Definition at line 208 of file iRel.h.
    /**< the relation on this side is active and up to date */
    iRel_INACTIVE,
    /**< the relation on this side is inactive, and may be out of date */
    iRel_NOTEXIST,
    /**< the relation on this side is not stored */
Enumerator:
iRel_ENTITY
iRel_SET
iRel_BOTH
Definition at line 173 of file iRel.h.
    iRel_SET,
    iRel_BOTH,
Function Documentation
void iRel_changePairStatus ( iRel_Instance  instance,
int  irel_status1,
int  irel_status2,
int *  err
Change the status of one or both sides of a relation. It is an error to change the status of both sides to iRel_NOTEXIST. If a side is changed to iRel_NOTEXIST, it will no longer be changeable back to iRel_ACTIVE or iRel_INACTIVE. Changing a side from iRel_INACTIVE to iRel_ACTIVE implies a traversal of all related entities on the other side, to recover the relations on the side being changed. Changing both sides from iRel_ACTIVE to something else is an error, since in that case neither will be able to be updated to iRel_ACTIVE.
Parameters:
[in]instanceiRel instance handle
[in]pairRelation pair handle being changed
[in]irel_status1The new status of side 1 of this relation pair
[in]irel_status2The new status of side 2 of this relation pair
[out]errReturned Error status (see iBase_ErrorType)
Definition at line 122 of file iRel_Lasso.cpp.
References ASSOCPAIRI, CHK_ERROR, and CHK_PAIR.
    CHK_PAIR();
    CHK_ERROR( ASSOCPAIRI->change_status( 0, static_cast< iRel_RelationStatus >( irel_status1 ) ) );CHK_ERROR( ASSOCPAIRI->change_status( 1, static_cast< iRel_RelationStatus >( irel_status2 ) ) );
void iRel_changePairType ( iRel_Instance  instance,
int  ent_or_set1,
int  ent_or_set2,
int *  err
Change the type of one or both sides of a relation. Only changes that result in no lost information are allowed, e.g. changing a type from SET to BOTH or vice versa.
Parameters:
[in]ent_or_set1The new type of side 1 of this relation pair
[in]ent_or_set2The new type of side 2 of this relation pair
Definition at line 115 of file iRel_Lasso.cpp.
    CHK_PAIR();
    CHK_ERROR( ASSOCPAIRI->change_type( 0, static_cast< iRel_RelationType >( ent_or_set1 ) ) );CHK_ERROR( ASSOCPAIRI->change_type( 1, static_cast< iRel_RelationType >( ent_or_set2 ) ) );
void iRel_create ( const char *  options,
int *  err,
Create a new iRel instance. Currently no options are implemented.
Parameters:
optionsconst Options for the implementation
[in]options_lenLength of options string
Definition at line 49 of file iRel_Lasso.cpp.
References iBase_NOT_SUPPORTED, and iBase_SUCCESS.
    if( 0 != options_len )
        *instance = NULL;
        *err      = iBase_NOT_SUPPORTED;
    *instance = new Lasso();
    *err      = iBase_SUCCESS;
void iRel_createPair ( iRel_Instance  instance,
int *  err
Creates a relation pair between two interfaces, passing back a handle to the pair. It is an error to create a relation pair having both sides iRel_NOTEXIST. If a relation pair has a side with status iRel_NOTEXIST, the relation for that side is never stored, and the status cannot change over the life of the relation pair.
Parameters:
[in]iface11st interface object in the relation pair
[in]ent_or_set1This relation relates entities, sets, or both from 1st interface object
[in]iface_type1Type of 1st interface
[in]irel_status1The status of 1st side
[in]iface22nd interface object in the relation pair
[in]ent_or_set2This relation relates entities, sets, or both from 2nd interface object
[in]iface_type2Type of 2nd interface
[in]irel_status2The status of 2nd side
[out]pairPointer to relation pair handle, returned from function
Definition at line 67 of file iRel_Lasso.cpp.
References iBase_SUCCESS, LASSOI, and RETURN.
    AssocPair* assoc_pair = new AssocPair(
        instance, iface1, static_cast< iRel_RelationType >( ent_or_set1 ), static_cast< iRel_IfaceType >( iface_type1 ),
        static_cast< iRel_RelationStatus >( irel_status1 ), iface2, static_cast< iRel_RelationType >( ent_or_set2 ),
        static_cast< iRel_IfaceType >( iface_type2 ), static_cast< iRel_RelationStatus >( irel_status2 ) );
    LASSOI->insert_pair( assoc_pair );
    *pair = reinterpret_cast< iRel_PairHandle >( assoc_pair );
    RETURN( iBase_SUCCESS );
void iRel_destroy ( iRel_Instance  instance,
int *  err
Calls destructor on interface object
Parameters:
Definition at line 61 of file iRel_Lasso.cpp.
References iBase_SUCCESS, and LASSOI.
    delete LASSOI;
void iRel_destroyPair ( iRel_Instance  instance,
int *  err
Destroy the relation pair corresponding to the handle input
Parameters:
[in]pairHandle of relation pair to destroy
Definition at line 129 of file iRel_Lasso.cpp.
References ASSOCPAIRI, CHK_ERROR, CHK_PAIR, and LASSOI.
    CHK_PAIR();
    CHK_ERROR( LASSOI->erase_pair( ASSOCPAIRI ) );
void iRel_findPairs ( iRel_Instance  instance,
iRel_PairHandle **  pairs,
int *  pairs_allocated,
int *  pairs_size,
int *  err
Get relations containing the specified interface
Parameters:
[in]ifaceSpecified interface
[in,out]pairsPointer to array holding returned relation pairs containing specified interface
[in,out]pairs_allocatedPointer to allocated size of relation pairs list
[out]pairs_sizePointer to occupied size of relation pairs list
Definition at line 136 of file iRel_Lasso.cpp.
References ALLOC_CHECK_ARRAY_NOFAIL, iBase_SUCCESS, LASSOI, and RETURN.
    std::vector< AssocPair* > tmp_pairs;
    LASSOI->find_pairs( iface, tmp_pairs );
    ALLOC_CHECK_ARRAY_NOFAIL( pairs, tmp_pairs.size() );
    for( size_t i = 0; i < tmp_pairs.size(); ++i )
        ( *pairs )[i] = reinterpret_cast< iRel_PairHandle >( tmp_pairs[i] );
void iRel_getDescription ( iRel_Instance  instance,
char *  descr,
int  descr_len
Parameters:
[in,out]descrPointer to a character string to be filled with a description of the error from the last iRel function
[in]descr_lenLength of the character string pointed to by descr
Definition at line 35 of file iRel_Lasso.cpp.
References LASSOI.
    if( instance == NULL )
        strcpy( descr, "iRel_getDescription: Invalid instance" );
    else
        unsigned int len = std::min( strlen( LASSOI->lastErrorDescription ), static_cast< size_t >( descr_len ) );
        strncpy( descr, LASSOI->lastErrorDescription, len );
        descr[len] = '\0';
void iRel_getEntArrEntArrRelation ( iRel_Instance  instance,
iBase_EntityHandle ent_array_1,
int  switch_order,
iBase_EntityHandle **  ent_array_2,
int *  ent_array_2_allocated,
int *  ent_array_2_size,
int *  err
Get entities related to those in specified array and relation, pairwise. Returns sets or entities, depending on relation type and entities in ent_array_1. It is an error to get a relation for a side with status iRel_NOTEXIST.
Parameters:
[in]pairRelation pair handle being queried
[in]ent_array_1Array of entities whose relations are being queried
[in]ent_array_1_sizeNumber of entities in ent_array_1
[in]switch_orderEntities in ent_array_1 are related with 1st (=0) or 2nd (=1) interface of this relation pair
[in,out]ent_array_2Pointer to array of entity handles returned from function
[in,out]ent_array_2_allocatedPointer to allocated size of ent_array_2
[out]ent_array_2_sizePointer to occupied size of ent_array_2
Definition at line 371 of file iRel_Lasso.cpp.
References ALLOC_CHECK_ARRAY, ASSOCPAIRI, CHK_ERROR, CHK_PAIR, iBase_SUCCESS, KEEP_ARRAY, and RETURN.
    CHK_PAIR();
    int iface_no = ( switch_order ? 1 : 0 );
    ALLOC_CHECK_ARRAY( ent_array_2, ent_array_1_size );CHK_ERROR( ASSOCPAIRI->get_relation( iface_no, ent_array_1, ent_array_1_size, *ent_array_2 ) );
    KEEP_ARRAY( ent_array_2 );
void iRel_getEntArrSetArrRelation ( iRel_Instance  instance,
int  switch_order,
iBase_EntitySetHandle **  entset_array_2,
int *  entset_array_2_allocated,
int *  entset_array_2_size,
int *  err
Description unavailable.
Parameters:
[in,out]entset_array_2Pointer to array of entity set handles returned from function
[in,out]entset_array_2_allocatedPointer to allocated size of entset_array_2
[out]entset_array_2_sizePointer to occupied size of entset_array_2
Definition at line 390 of file iRel_Lasso.cpp.
    CHK_PAIR();
    ALLOC_CHECK_ARRAY( set_array_2, ent_array_1_size );CHK_ERROR( ASSOCPAIRI->get_relation( iface_no, ent_array_1, ent_array_1_size, *set_array_2 ) );
    KEEP_ARRAY( set_array_2 );
void iRel_getEntArrSetIterArrRelation ( iRel_Instance  instance,
int  switch_order,
iBase_EntityIterator **  entiter,
int *  entiter_allocated,
int *  entiter_size,
int *  err
Parameters:
[in,out]entiterPointer to array of entity iterator handles returned from function
[in,out]entiter_allocatedPointer to allocated size of entiter
[out]entiter_sizePointer to occupied size of entiter
Definition at line 447 of file iRel_Lasso.cpp.
    CHK_PAIR();
    ALLOC_CHECK_ARRAY( entiter, ent_array_1_size );CHK_ERROR( ASSOCPAIRI->get_relation( iface_no, ent_array_1, ent_array_1_size, *entiter ) );
    KEEP_ARRAY( entiter );
void iRel_getEntEntRelation ( iRel_Instance  instance,
int  switch_order,
int *  err
Get entity related to specified entity and relation handle. Also returns whether the related entity is an entity or a set. It is an error to get a relation for a side with status iRel_NOTEXIST.
Parameters:
[in]ent11st entity of relation being queried
[in]switch_order1st entity is related to 1st interface (=0) or 2nd interface (=1) of relation pair
[out]ent2Pointer to entity related to ent1
Definition at line 311 of file iRel_Lasso.cpp.
    CHK_PAIR();
    int iface_no = ( switch_order ? 1 : 0 );CHK_ERROR( ASSOCPAIRI->get_relation( iface_no, &ent1, 1, ent2 ) );
void iRel_getEntSetIterRelation ( iRel_Instance  instance,
int  switch_order,
iBase_EntityIterator entIter,
int *  err
Parameters:
[in]ent1ent1 1st entity set of relation being queried
[out]entIterReturned entity iterator
Definition at line 359 of file iRel_Lasso.cpp.
    CHK_PAIR();
    int iface_no = ( switch_order ? 1 : 0 );CHK_ERROR( ASSOCPAIRI->get_relation( iface_no, &ent1, 1, entset2 ) );
void iRel_getEntSetRelation ( iRel_Instance  instance,
int  switch_order,
int *  err
Parameters:
[in]ent1entity of relation being queried
[out]entset2Pointer to entity set related to ent1
Definition at line 323 of file iRel_Lasso.cpp.
    CHK_PAIR();
    int iface_no = ( switch_order ? 1 : 0 );CHK_ERROR( ASSOCPAIRI->get_relation( iface_no, &ent1, 1, set2 ) );
void iRel_getErrorType ( iRel_Instance  instance,
int *  error_type
Get the error type returned from the last iRel function. Value returned is a member of the iBase_ErrorType enumeration.
Parameters:
[out]error_typeError type returned from last iRel function
Definition at line 27 of file iRel_Lasso.cpp.
References iBase_FAILURE, and LASSOI.
        *error_type = iBase_FAILURE;
    else
        *error_type = LASSOI->lastErrorType;
void iRel_getPairInfo ( iRel_Instance  instance,
int *  ent_or_set1,
int *  iface_type1,
int *  irel_status1,
int *  ent_or_set2,
int *  iface_type2,
int *  irel_status2,
int *  err
Get information about the interfaces and relation type for this relation. Relation type for each side is passed back as integers, but values will be from RelationType enumeration.
Parameters:
[in]pairhandle of relation pair being queried
[out]iface1Side 1 instance for this relation
[out]ent_or_set1relation type for side 1 of this relation
[out]iface_type1Interface type for side 1 of this relation
[out]irel_status1The status of the first side of this relation
[out]iface2Side 2 instance for this relation
[out]ent_or_set2Relation type for side 2 of this relation
[out]iface_type2Interface type for side 2 of this relation
[out]irel_status2Status of the 2nd side of this relation
Definition at line 89 of file iRel_Lasso.cpp.
References ASSOCPAIRI, CHK_PAIR, iBase_SUCCESS, and RETURN.
    CHK_PAIR();
    *iface1       = ASSOCPAIRI->iface_instance( 0 );
    *ent_or_set1  = ASSOCPAIRI->relation_type( 0 );
    *iface_type1  = ASSOCPAIRI->iface_type( 0 );
    *irel_status1 = ASSOCPAIRI->relation_status( 0 );
    *iface2       = ASSOCPAIRI->iface_instance( 1 );
    *iface_type2  = ASSOCPAIRI->iface_type( 1 );
    *ent_or_set2  = ASSOCPAIRI->relation_type( 1 );
    *irel_status2 = ASSOCPAIRI->relation_status( 1 );
void iRel_getSetArrEntArrRelation ( iRel_Instance  instance,
iBase_EntitySetHandle entset_array_1,
int  switch_order,
int *  err
Parameters:
[in]entset_array_1Array of entity sets whose relations are being queried
[in]entset_array_1_sizeNumber of entity sets in entset_array_1
Definition at line 409 of file iRel_Lasso.cpp.
    CHK_PAIR();
    ALLOC_CHECK_ARRAY( ent_array_2, set_array_1_size );CHK_ERROR( ASSOCPAIRI->get_relation( iface_no, set_array_1, set_array_1_size, *ent_array_2 ) );
void iRel_getSetArrSetArrRelation ( iRel_Instance  instance,
int  switch_order,
int *  err
Parameters:
[in,out]entset_array_2Pointer to array of entity handles returned from function
Definition at line 428 of file iRel_Lasso.cpp.
    CHK_PAIR();
    ALLOC_CHECK_ARRAY( set_array_2, set_array_1_size );CHK_ERROR( ASSOCPAIRI->get_relation( iface_no, set_array_1, set_array_1_size, *set_array_2 ) );
void iRel_getSetEntRelation ( iRel_Instance  instance,
int  switch_order,
int *  err
Parameters:
[in]entset1entity set of relation being queried
[out]ent2Pointer to entity related to entset1
Definition at line 335 of file iRel_Lasso.cpp.
    CHK_PAIR();
    int iface_no = ( switch_order ? 1 : 0 );CHK_ERROR( ASSOCPAIRI->get_relation( iface_no, &set1, 1, ent2 ) );
void iRel_getSetSetRelation ( iRel_Instance  instance,
int  switch_order,
int *  err
Parameters:
[in]entset11st entity set of relation being queried
[out]entset2Pointer to entity set related to entset1
Definition at line 347 of file iRel_Lasso.cpp.
    CHK_PAIR();
    int iface_no = ( switch_order ? 1 : 0 );CHK_ERROR( ASSOCPAIRI->get_relation( iface_no, &set1, 1, set2 ) );
void iRel_inferAllRelations ( iRel_Instance  instance,
int *  err
Infer relations between entities in specified pair of interfaces. The criteria used to infer these relations depends on the interfaces in the pair, the iRel implementation, and the source of the data in those interfaces.
Parameters:
Definition at line 660 of file iRel_Lasso.cpp.
References ASSOCPAIRI, CHK_ERROR, CHK_PAIR, iRel_ENTITY, and iRel_inferArrArrRelations().
    CHK_PAIR();
    // get all entities in those interfaces
    int result;
    iBase_EntityHandle* ents1 = NULL;
    int ents1_alloc           = 0, ents1_size;
    if( ASSOCPAIRI->relation_type( 0 ) != iRel_ENTITY )
        result = ASSOCPAIRI->get_all_sets( 0, (iBase_EntitySetHandle**)&ents1, &ents1_alloc, &ents1_size );
    else
        result = ASSOCPAIRI->get_all_entities( 0, -1, &ents1, &ents1_alloc, &ents1_size );CHK_ERROR( result );
    iBase_EntityHandle* ents2 = NULL;
    int ents2_alloc           = 0, ents2_size;
    if( ASSOCPAIRI->relation_type( 1 ) != iRel_ENTITY )
        result = ASSOCPAIRI->get_all_sets( 1, (iBase_EntitySetHandle**)&ents2, &ents2_alloc, &ents2_size );
    else
        result = ASSOCPAIRI->get_all_entities( 1, -1, &ents2, &ents2_alloc, &ents2_size );CHK_ERROR( result );
    iRel_inferArrArrRelations( instance, pair, ents1, ents1_size, ASSOCPAIRI->relation_type( 0 ), ents2, ents2_size,
                               ASSOCPAIRI->relation_type( 1 ), &result );
    free( ents1 );
    free( ents2 );CHK_ERROR( result );
void iRel_inferAllRelationsAndType ( iRel_Instance  instance,
int *  err
Infer relations between entities in specified pair of interfaces, and the relation type used by this iRel implementation. The criteria used to infer these relations depends on the interfaces in the pair, the iRel implementation, and the source of the data in those interfaces.
Parameters:
[in]pairRelation pair handle created by implementation
Definition at line 688 of file iRel_Lasso.cpp.
References ERROR, and iBase_NOT_SUPPORTED.
    ERROR( iBase_NOT_SUPPORTED, "Not currently supported." );
void iRel_inferEntArrRelations ( iRel_Instance  instance,
iBase_EntityHandle entities,
int  entities_size,
int  iface_no,
int *  err
Infer relations corresponding to specified entities and relation pair. The criteria used to infer these relations depends on the interfaces in the pair, the iRel implementation, and the source of the data in those interfaces.
Parameters:
[in]entitiesArray of entities whose relation are being inferred
[in]entities_sizeNumber of entities in array
[in]iface_noEntities correspond to 1st (=0) or 2nd (=1) interface in relation pair
Definition at line 759 of file iRel_Lasso.cpp.
References iRel_inferArrRelations().
    iRel_inferArrRelations( instance, pair, entities, entities_size, false, iface_no, err );
void iRel_inferEntRelations ( iRel_Instance  instance,
int  iface_no,
int *  err
Infer relations corresponding to specified entity and relation pair. The criteria used to infer these relations depends on the interfaces in the pair, the iRel implementation, and the source of the data in those interfaces.
Parameters:
[in]entityEntity whose relations are being inferred
[in]iface_noEntity corresponds to 1st (=0) or 2nd (=1) interface in relation pair
Definition at line 693 of file iRel_Lasso.cpp.
References iRel_inferEntArrRelations.
    iRel_inferEntArrRelations( instance, pair, &entity, 1, iface_no, err );
void iRel_inferSetArrRelations ( iRel_Instance  instance,
iBase_EntitySetHandle entity_sets,
int  entities_size,
int  iface_no,
int *  err
Brief unavailable.
Parameters:
[in]pairdescription unknown
[in]entity_setsdescription unknown
[in]entities_sizedescription unknown
[in]iface_nodescription unknown
Definition at line 769 of file iRel_Lasso.cpp.
    iRel_inferArrRelations( instance, pair, (iBase_EntityHandle*)entities, entities_size, true, iface_no, err );
void iRel_inferSetRelations ( iRel_Instance  instance,
int  iface_no,
int *  err
Brief unavailable.
Parameters:
[in]entity_setdescription unknown
Definition at line 702 of file iRel_Lasso.cpp.
References iRel_inferSetArrRelations.
    iRel_inferSetArrRelations( instance, pair, &entity, 1, iface_no, err );
void iRel_rmvEntArrRelation ( iRel_Instance  instance,
int  num_ent1,
int  switch_order,
int *  err
Parameters:
[in]ent_array_1Array of entities of relation being removed
[in]num_ent1Number of entities in array
[in]switch_orderentities are related to 1st interface (=0) or 2nd interface (=1) of relation pair
Definition at line 489 of file iRel_Lasso.cpp.
    CHK_PAIR();
    int iface_no = ( switch_order ? 1 : 0 );CHK_ERROR( ASSOCPAIRI->rmv_relation( iface_no, ent_array, num_ent ) );
void iRel_rmvEntRelation ( iRel_Instance  instance,
int  switch_order,
int *  err
Parameters:
[in]ententity of relation being removed
[in]switch_orderentity is related to 1st interface (=0) or 2nd interface (=1) of relation pair
Definition at line 467 of file iRel_Lasso.cpp.
    CHK_PAIR();
    int iface_no = ( switch_order ? 1 : 0 );CHK_ERROR( ASSOCPAIRI->rmv_relation( iface_no, &ent, 1 ) );
void iRel_rmvSetArrRelation ( iRel_Instance  instance,
int  num_entset1,
int  switch_order,
int *  err
Parameters:
[in]entset_array_1Array of entity sets of relation being removed
[in]num_entset1Number of entity sets in array
[in]switch_orderentity sets are related to 1st interface (=0) or 2nd interface (=1) of relation pair
Definition at line 501 of file iRel_Lasso.cpp.
    CHK_PAIR();
    int iface_no = ( switch_order ? 1 : 0 );CHK_ERROR( ASSOCPAIRI->rmv_relation( iface_no, entset_array, num_ent ) );
void iRel_rmvSetRelation ( iRel_Instance  instance,
int  switch_order,
int *  err
Parameters:
[in]setentity set of relation being removed
[in]switch_orderentity set is related to 1st interface (=0) or 2nd interface (=1) of relation pair
Definition at line 478 of file iRel_Lasso.cpp.
    CHK_PAIR();
    int iface_no = ( switch_order ? 1 : 0 );CHK_ERROR( ASSOCPAIRI->rmv_relation( iface_no, &entset, 1 ) );
void iRel_setEntArrEntArrRelation ( iRel_Instance  instance,
int  num_ent1,
iBase_EntityHandle ent_array_2,
int  num_ent2,
int *  err
Set relations between arrays of entities pairwise, ent_array_1[i]<->ent_array_2[i]. If either array contains sets and that side of the relation is 'both'-type, set relations for individual entities in those sets too. It is an error to set a relation on a pair with both sides not iRel_ACTIVE.
Parameters:
[in]ent_array_11st array of entities of relation being set
[in]num_ent1Number of entities in 1st array
[in]ent_array_22nd array of entities of relation being set
[in]num_ent2Number of entities in 2nd array
Definition at line 191 of file iRel_Lasso.cpp.
References ASSOCPAIRI, CHK_PAIR, ERROR, iBase_INVALID_ENTITY_COUNT, iBase_SUCCESS, iRel_getDescription, and RETURN.
    CHK_PAIR();
    if( num_entities1 != num_entities2 )
        ERROR( iBase_INVALID_ENTITY_COUNT, "setEntArrEntArrRelation doesn't support "
                                           "different #'s of entities." );
    int result = iBase_SUCCESS;
    char descr[200];
    for( int i = 0; i < num_entities1; i++ )
        int tmp_result = ASSOCPAIRI->set_relation( ent_array_1[i], ent_array_2[i] );
        if( result == iBase_SUCCESS && tmp_result != iBase_SUCCESS )
            result = tmp_result;
            iRel_getDescription( instance, descr, sizeof( descr ) );
    if( result != iBase_SUCCESS ) ERROR( result, descr );
void iRel_setEntArrSetArrRelation ( iRel_Instance  instance,
int  num_ent1,
iBase_EntitySetHandle entset_array_2,
int  num_set2,
int *  err
Parameters:
[in]entset_array_22nd array of entities of relation being set
[in]num_set2Number of entity sets in 2nd array
Definition at line 221 of file iRel_Lasso.cpp.
    CHK_PAIR();
    if( num_entities1 != num_sets2 )
        ERROR( iBase_INVALID_ENTITY_COUNT, "setEntArrSetArrRelation doesn't support "
    char descr[200];
        int tmp_result = ASSOCPAIRI->set_relation( ent_array_1[i], set_array_2[i] );
void iRel_setEntEntRelation ( iRel_Instance  instance,
int *  err
Set a relation between an entity and several entities. It is an error to set a relation on a pair with both sides not iRel_ACTIVE.
Parameters:
[in]ent11st entity of relation being set
[in]ent22nd entity of relation being set
Definition at line 155 of file iRel_Lasso.cpp.
    CHK_PAIR();CHK_ERROR( ASSOCPAIRI->set_relation( ent1, ent2 ) );
void iRel_setEntSetRelation ( iRel_Instance  instance,
int *  err
Parameters:
[in]ent1entity of relation being set
[in]entset2entity set of relation being set
Definition at line 164 of file iRel_Lasso.cpp.
    CHK_PAIR();CHK_ERROR( ASSOCPAIRI->set_relation( ent1, set2 ) );
void iRel_setSetArrEntArrRelation ( iRel_Instance  instance,
int  num_set1,
int  num_ent2,
int *  err
Parameters:
[in]entset_array_11st array of entities of relation being set
[in]num_set1Number of entity sets in 1st array
Definition at line 251 of file iRel_Lasso.cpp.
    CHK_PAIR();
    if( num_sets1 != num_entities2 )
        ERROR( iBase_INVALID_ENTITY_COUNT, "setSetArrEntArrRelation doesn't support "
    char descr[200];
    for( int i = 0; i < num_sets1; i++ )
        int tmp_result = ASSOCPAIRI->set_relation( set_array_1[i], ent_array_2[i] );
void iRel_setSetArrSetArrRelation ( iRel_Instance  instance,
int  num_set1,
int  num_set2,
int *  err
Parameters:
[in]num_set1Number of entities in 1st array
[in]num_set2Number of entities in 2nd array
Definition at line 281 of file iRel_Lasso.cpp.
    CHK_PAIR();
    if( num_sets1 != num_sets2 )
        ERROR( iBase_INVALID_ENTITY_COUNT, "setSetArrSetArrRelation doesn't support "
    char descr[200];
        int tmp_result = ASSOCPAIRI->set_relation( set_array_1[i], set_array_2[i] );
void iRel_setSetEntRelation ( iRel_Instance  instance,
int *  err
Parameters:
[in]entset1entity set of relation being set
[in]ent2entity of relation being set
Definition at line 173 of file iRel_Lasso.cpp.
    CHK_PAIR();CHK_ERROR( ASSOCPAIRI->set_relation( set1, ent2 ) );
void iRel_setSetSetRelation ( iRel_Instance  instance,
int *  err
Description unavailable. Set a relation between an entity and several entities. It is an error to set a relation on a pair with both sides not iRel_ACTIVE.
Parameters:
[in]entset11st entity set of relation being set
[in]entset22nd entity set of relation being set
Definition at line 182 of file iRel_Lasso.cpp.
    CHK_PAIR();CHK_ERROR( ASSOCPAIRI->set_relation( set1, set2 ) );
