cgma
FacetSurface.hpp
00001 //-------------------------------------------------------------------------
00002 // Filename      : FacetSurface.hpp
00003 //
00004 // Purpose       :
00005 //
00006 // Special Notes :
00007 //
00008 // Creator       : David R. White
00009 //
00010 // Creation Date : 06/06/00
00011 //
00012 // Owner         : David R. White
00013 //-------------------------------------------------------------------------
00014
00015 #ifndef SURFACE_Facet_HPP
00016 #define SURFACE_Facet_HPP
00017
00018 #include "CubitDefines.h"
00019 #include "Surface.hpp"
00020 #include "FacetAttribSet.hpp"
00021 #include <map>
00022
00023 class TopologyEntity;
00024 class RefVolume;
00025 class RefFace;
00026 class RefVolume;
00027 class FacetEvalTool;
00028 class FacetShell;
00029 class FacetAttrib;
00030
00031 class FacetBody;
00032 class FacetLump;
00033 class FacetLoop;
00034 class FacetCoEdge;
00035 class FacetCurve;
00036 class FacetPoint;
00037 class CubitFacetEdge;
00038 class CubitFacet;
00039 class CubitPoint;
00040 class CubitTransformMatrix;
00041 class CubitEvaluator;
00042 class CubitEvaluatorData;
00043 class SphereEvaluatorData;
00044 class CylinderEvaluatorData;
00045
00046 class FacetSurface : public Surface
00047 {
00048
00049 private:
00050     //CubitSense sense_;
00051     //- The sense of the RefFace that owns this Surface with respect
00052     //- to the positive sense of the first FACE in FACEPtrList_.
00053     //- When a Surface is first constructed, this value is arbitrarily
00054     //- set to CUBIT_FORWARD.
00055     //- In the case of Surfaces, the normal is used in determining
00056     //- the relative sense value.
00057     //- MJP NOTE:
00058     //- Not only does the RefFace have a sense wrt its Surface, but each
00059     //- Facet FACE has a sense wrt its underlying "surface" object.
00060
00061   //sjowen FacetEvalTool *facetEvalTool;
00062   FacetEvalTool *facetEvalTool;
00063     //For topology traversals we need to have connections to the
00064     //entitities connected to this surface.  From these we can get the rest.
00065   DLIList<LoopSM*> myLoops;
00066   DLIList<ShellSM*> myShells;
00067
00068   FacetAttribSet attribSet;
00069     //List of FacetAttrib*'s instead of CubitSimpleAttribs
00070
00071   // the sense of the surface with respect to the shells in the myShells list
00072   CubitSense myShellSense;
00073
00074   CubitEvaluator *myEvaluator;
00075
00076 protected:
00077
00078 public :
00079
00080   FacetSurface(FacetEvalTool *facet_eval_tool_ptr,
00081                DLIList<ShellSM*> &shellsms,DLIList<LoopSM*> &loopsms );
00082     //I- facet_eval_tool pointer
00083     //I- A pointer to the set of facets that define this surface.
00084
00085   FacetSurface(FacetEvalTool *facet_eval_tool_ptr,
00086                CubitSense sense,
00087                CubitSense shell_sense0,
00088                CubitBoolean use_facets,
00089                DLIList<LoopSM*> &loopsms );
00090
00091
00092   FacetSurface( const CylinderEvaluatorData *cylinder_data,
00093                 FacetEvalTool *facet_tool,
00094                 DLIList<ShellSM*> &shellsms,
00095                 DLIList<LoopSM*> &loopsms );
00096   //-  Constructor used to create a faceted surface representing a cylinder.
00097   //I-  eval_data - radius, base, etc. of cylinder.
00098   //I-  facet_eval_tool_ptr - evaluator to evaluate directly on facets.
00099   //I-  shellsms - the shells in this facet model
00100   //I-  loopsms - the loops in this facet model.
00101
00102   FacetSurface( const SphereEvaluatorData *eval_data,
00103                 FacetEvalTool *facet_eval_tool_ptr,
00104                 DLIList<ShellSM*> &shellsms,
00105                 DLIList<LoopSM*> &loopsms );
00106   //-  Constructor used to create a faceted surface representing a sphere.
00107   //I-  eval_data - radius, center, etc. of sphere.
00108   //I-  facet_eval_tool_ptr - evaluator to evaluate directly on facets.
00109   //I-  shellsms - the shells in this facet model
00110   //I-  loopsms - the loops in this facet model.
00111
00112   virtual ~FacetSurface() ;
00113     //- The destructor
00114
00115   void add_shell(ShellSM *shell_ptr)
00116     {myShells.append(shell_ptr);}
00117
00118   CubitStatus remove_shell(FacetShell* shell_ptr);
00119
00120   void disconnect_all_loops();
00121
00122   inline bool has_parent_shell() { return myShells.size() > 0; }
00123
00124     //CubitSense get_relative_surface_sense();
00125     //- Return the relative surface sense. (see below)
00126
00127   virtual void append_simple_attribute_virt(const CubitSimpleAttrib&);
00128     //R void
00129     //I
00130     //I-
00131     //I- that is to be appended to this OSME object.
00132     //- The purpose of this function is to append a
00133     //- attribute to the OSME. The  is attached to each of the
00134     //- underlying solid model entities this one points to.
00135
00136   virtual void remove_simple_attribute_virt(const CubitSimpleAttrib&);
00137     //R void
00138     //I CubitSimpleAttrib*
00139     //I- A reference to a CubitSimpleAttrib object which is the object
00140     //I- that is to be removed to this OSME object.
00141     //- The purpose of this function is to remove a simple
00142     //- attribute from the OSME. The attribute is attached to each of the
00143     //- underlying solid model entities this one points to.
00144
00145   virtual void remove_all_simple_attribute_virt();
00146     //R void
00147     //I-
00148     //- The purpose of this function is to remove all simple
00149     //- attributes from the OSME.
00150
00151   virtual CubitStatus get_simple_attribute(DLIList<CubitSimpleAttrib>&);
00152   virtual CubitStatus get_simple_attribute(const CubitString& name,
00153                                            DLIList<CubitSimpleAttrib>&);
00154     //R CubitSimpleAttrib*
00155     //R- the returned cubit simple attribute.
00156     //- The purpose of this function is to get the attributes
00157     //- of the geometry entity. The name is attached to the underlying solid
00158     //- model entity(ies) this one points to.
00159     //- MJP Note:
00160     //- This is the code that implements the requirement that names
00161     //- of VGI Entities propagate across solid model boolean
00162     //- operations.  The success of this relies, of course, on the underlying
00163     //- solid modeler being able to propagate attributes across
00164     //- such operations on its entities. If it cannot, then "names"
00165     //- of VGI entities will not propagate.
00166
00167   virtual CubitBox bounding_box() const ;
00168     // see comments in GeometryEntity.hpp
00169
00170   virtual GeometryQueryEngine*
00171   get_geometry_query_engine() const;
00172     //R GeometryQueryEngine*
00173     //R- A pointer to the geometric modeling engine associated with
00174     //R- the object.
00175     //- This function returns a pointer to the geometric modeling engine
00176     //- associated with the object.
00177
00178   // Added by CAT
00179   virtual CubitStatus get_point_normal( CubitVector& ,
00180                                         CubitVector& );
00181     //- Only valid for planar surfaces
00182     //- Finds the underlying plane's origin and normal vector
00183     //- Returns CubitFailure if not a plane.  The origin and normal
00184     //- are returned directly from the underlying format for a plane.
00185
00186   virtual CubitStatus closest_point_uv_guess(
00187       CubitVector const& location,
00188       double &u, double &v,
00189       CubitVector* closest_location = NULL,
00190       CubitVector* unit_normal = NULL );
00191
00192
00193   virtual void closest_point_trimmed(CubitVector from_point,
00194                                      CubitVector& point_on_surface);
00195     //R void
00196     //I CubitVector
00197     //I- point from which to find closest point on trimmed surface
00198     //O CubitVector
00199     //O- point on trimmed surface closest to passed-in point
00200     //- This function finds the closest point on a TRIMMED surface to the
00201     //- passed-in point.
00202
00203   virtual CubitStatus closest_point_along_vector(CubitVector& from_point,
00204                                          CubitVector& along_vector,
00205                                          CubitVector& point_on_surface);
00206
00207
00208   virtual CubitStatus closest_point(
00209     CubitVector const& location,
00210     CubitVector* closest_location = NULL,
00211     CubitVector* unit_normal_ptr = NULL,
00212     CubitVector* curvature1_ptr = NULL,
00213     CubitVector* curvature2_ptr = NULL);
00214     //R CubitStatus
00215     //R- CUBIT_SUCCESS/FAILURE
00216     //I location
00217     //I- The point to which the closest point on the surface is desired.
00218     //O closest_location
00219     //O- The point on the Surface, closest to the
00220     //O- input location (which might not be on the Surface).  This is
00221     //O- input as a reference so that the function can modify its
00222     //O- contents.
00223     //O unit_normal_ptr
00224     //O- The normal (represented as a unit vector) at the closest_location.
00225     //O- If this pointer is NULL, the normal is not returned.
00226     //O curvature1_ptr
00227     //O- The first principal curvature of the surface at closest_location.
00228     //O- If this pointer is NULL, this curvature is not returned.
00229     //O curvature2_ptr
00230     //O- The second principal curvature of the surface at closest_location.
00231     //O- If this pointer is NULL, this curvature is not returned.
00232     //- This function computes the point on the surface closest to the input
00233     //- location -- i.e., closest_location.
00234     //- The first Facet FACE in the list
00235     //- is queried.
00236     //-
00237     //- If the input pointer values of unit_normal, curvature1 and
00238     //- curvature2
00239     //- are non-NULL, the normal and principal curvatures, too, are
00240     //- returned.  These are computed at closest_location, not at the
00241     //- input location.
00242     //-
00243     //- NOTE:
00244     //- It is assumed that if the calling code needs the normal or the
00245     //- principal curvatures, it will *allocate* space for the CubitVectors
00246     //- before sending in the pointers.
00247
00248   virtual CubitStatus principal_curvatures(
00249     CubitVector const& location,
00250     double& curvature_1,
00251     double& curvature_2,
00252     CubitVector* closest_location = NULL );
00253     //R CubitStatus
00254     //R- CUBIT_SUCCESS/FAILURE
00255     //I location
00256     //I- The point at which the curvatures are being requested -- it is also
00257     //I- the point to which the closest point on the surface is returned.
00258     //I- curvatures.
00259     //O closest_location
00260     //O- The point on the surface, closest to the input location (this
00261     //O- might not be on the surface).  This is input as a reference
00262     //O- so that the function can modify its contents.
00263     //O curvature_1/2
00264     //O- Returned principal curvature magnitudes.
00265     //- This functions computes the point on the surface that is closest
00266     //- to the input location and then calculates the magnitudes of the
00267     //- principal curvatures at this (possibly, new) point on the surface.
00268
00269
00270
00271   virtual CubitStatus evaluate( double u, double v,
00272     CubitVector *position,
00273     CubitVector *normal,
00274     CubitVector *curvature1,
00275     CubitVector *curvature2 );
00276
00277
00278
00279   virtual CubitVector position_from_u_v (double u, double v);
00280     //R CubitVector
00281     //R- Returned position vector.
00282     //I u, v
00283     //I- Input point in {u.v} space
00284     //- This function returns the coordinates in world space of a point
00285     //- in the parameter space of this Surface object.
00286
00287   virtual CubitStatus u_v_from_position (CubitVector const& location,
00288                                          double& u,
00289                                          double& v,
00290                                          CubitVector*
00291                                          closest_location = NULL );
00292     //R CubitStatus
00293     //R- CUBIT_SUCCESS/FAILURE
00294     //I location
00295     //I- The input point in global space
00296     //O closest_point
00297     //O- The point on the Surface closest to the input location
00298     //O u, v
00299     //O- The returned u, v coordinate values (in local parametric space)
00300     //O- of the closest_point
00301     //I refvolume_ptr
00302     //- This function returns the {u, v} coordinates of the point
00303     //- on the Surface closest to the input point (specified in global
00304     //- space). The closest_location is also returned.
00305
00306   virtual CubitBoolean is_periodic();
00307     //R CubitBoolean
00308     //R- CUBIT_TRUE/CUBIT_FALSE
00309     //- This function determines whether the underlying geometry of the
00310     //- FacetSurface is periodic or not.  Returns CUBIT_TRUE if it is and
00311     //- CUBIT_FALSE if it is not.
00312     //- MJP NOTE:
00313     //- The first Facet FACE in the list is queried.  It is assumed
00314     //- that all the FACEs have the same underlying surface.
00315
00316     virtual CubitBoolean is_periodic_in_U( double& period );
00317     //R CubitBoolean
00318     //R- CUBIT_TRUE/CUBIT_FALSE
00319     //O period
00320     //O- The value of the period in the U direction.
00321     //- Determines whether the Facet surface object associated
00322     //- with one of the FACEs of this FacetSurface object is
00323     //- periodic in the U direction or not.  If it is, it
00324     //- returns CUBIT_TRUE and the value of the period. Otherwise,
00325     //- it returns CUBIT_FALSE and a value of 0.0 or the period.
00326     //- MJP NOTE:
00327     //- The first Facet FACE in the list is queried.  It is assumed
00328     //- that all the FACEs have the same underlying surface.
00329
00330   virtual CubitBoolean is_periodic_in_V( double& period );
00331     //R CubitBoolean
00332     //R- CUBIT_TRUE/CUBIT_FALSE
00333     //O period
00334     //O- The value of the period in the V direction.
00335     //- Determines whether the Facet surface object associated
00336     //- with one of the FACEs of this FacetSurface object is
00337     //- periodic in the V direction or not.  If it is, it
00338     //- returns CUBIT_TRUE and the value of the period. Otherwise,
00339     //- it returns CUBIT_FALSE and a value of 0.0 or the period.
00340     //- MJP NOTE:
00341     //- The first Facet FACE in the list is queried.  It is assumed
00342     //- that all the FACEs have the same underlying surface.
00343
00344   virtual CubitBoolean is_singular_in_U( double u_param );
00345   virtual CubitBoolean is_singular_in_V( double v_param );
00346     //R CubitBoolean
00347     //R- CUBIT_TRUE/CUBIT_FALSE
00348     //I double u/v parameter value.
00349     //- Determines if the surface is singular in a given direction
00350     //- at a given parameter value.
00351
00352   virtual CubitBoolean is_closed_in_U();
00353   virtual CubitBoolean is_closed_in_V();
00354     //R CubitBoolean
00355     //R- CUBIT_TRUE/CUBIT_FALSE
00356     //- Determines if the surface is closed, smoothly or not in the
00357     //- given parameter direction.
00358     //- A periodic surface is always closed but a closed surface is
00359     //- is not always periodic.
00360
00361   virtual CubitStatus uv_derivitives( double u_param,
00362                                       double v_param,
00363                                       CubitVector &du,
00364                                       CubitVector &dv );
00365     //R CubitStatus
00366     //R- CUBIT_SUCCESS/CUBIT_FAILURE
00367     //O- du, dv
00368     //- Determines the u and v derivitives from the given parameter
00369     //- values.
00370
00371   virtual CubitBoolean is_parametric();
00372     //R CubitBoolean
00373     //R- CUBIT_TRUE/CUBIT_FALSE
00374             //- This method returns CUBIT_TRUE if a parametric representation
00375             //- is available for the surface
00376
00377   virtual CubitBoolean get_param_range_U( double& lower_bound,
00378                                           double& upper_bound );
00379     //R CubitBoolean
00380     //R- CUBIT_TRUE/CUBIT_FALSE
00381     //O lower_bound
00382     //O- The lower bound of the parametric range in the U direction.
00383     //O- This is set to 0.0 if the surface is not parametric.
00384     //O upper_bound
00385     //O- The upper bound of the parametric range in the U direction.
00386     //O- This is set to 0.0 if the surface is not parametric.
00387     //- Returns the lower and upper parametric bounds of the
00388     //- surface in U, if it is parametric.  Otherwise, it returns
00389     //- CUBIT_FALSE and zeroes for the upper and lower parametric
00390     //- bounds.
00391     //- MJP NOTE:
00392     //- The first Facet FACE in the list is queried.  It is assumed
00393     //- that all the FACEs have the same underlying surface.
00394
00395   virtual CubitBoolean get_param_range_V( double& lower_bound,
00396                                           double& upper_bound );
00397     //R CubitBoolean
00398     //R- CUBIT_TRUE/CUBIT_FALSE
00399     //O lower_bound
00400     //O- The lower bound of the parametric range in the V direction.
00401     //O- This is set to 0.0 if the surface is not parametric.
00402     //O upper_bound
00403     //O- The upper bound of the parametric range in the V direction.
00404     //O- This is set to 0.0 if the surface is not parametric.
00405     //- Returns the lower and upper parametric bounds of the
00406     //- surface in V, if it is parametric.  Otherwise, it returns
00407     //- CUBIT_FALSE and zeroes for the upper and lower parametric
00408     //- bounds.
00409     //- MJP NOTE:
00410     //- The first Facet FACE in the list is queried.  It is assumed
00411     //- that all the FACEs have the same underlying surface.
00412
00413   virtual CubitBoolean is_position_on( CubitVector &test_position );
00414     //R CubitBoolean
00415     //R- CUBIT_TRUE/CUBIT_FALSE
00416     //I CubitVector
00417     //I- position, point where we want to test, whether or not it
00418     //- is on the surface.
00419
00420   virtual CubitPointContainment point_containment( const CubitVector &point );
00421   virtual CubitPointContainment point_containment( double u, double v );
00422 //  virtual CubitPointContainment point_containment( const CubitVector &point,
00423 //                                                   double u, double v );
00424     //R CubitPointContainment - is the point outside, inside or on the boundary?
00425     //R- CUBIT_PNT_OUTSIDE, CUBIT_PNT_INSIDE, CUBIT_PNT_BOUNDARY,
00426     //   CUBIT_PNT_UNKNOWN
00427     //I CubitVector
00428     //I- position to check, known to be on the Surface
00429     //I double
00430     //I- u coordinate, if known (significantly faster, if this is known - however
00431     //                           if not known let the function figure it out)
00432     //I double
00433     //I- v coordinate, if known (significantly faster, if this is known - however
00434     //                           if not known let the function figure it out)
00435     // NOTE: POINT MUST LIE ON THE SURFACE FOR THIS FUNCTION TO WORK PROPERLY.
00436
00437   GeometryType geometry_type();
00438     //R GeometryType (enum)
00439     //R- The enumerated type of the geometric representation
00440
00441   virtual double measure();
00442     //R double
00443     //R- The numeric value of the measure (its units depend on the dimension
00444     //R- of the RefEntity being "measured")
00445     //- A generic geometric extent function.
00446     //- Returns volume for Lump, area for Surface, length for Curve and
00447     //- 1.0 for Point
00448
00449
00450   virtual CubitStatus get_projected_distance_on_surface( CubitVector *pos1,
00451                                                          CubitVector *pos2,
00452                                                          double &distance );
00453
00454   void update_measurement();
00455     //Make sure we don't retain an out-dated measurement.
00456
00457   virtual CubitSense get_geometry_sense();
00458     //- Return the relative surface sense. (see below)
00459
00460   virtual void reverse_sense();
00461     //- Switch the sense of this Surface wrt the RefFace that owns it:
00462     //- For Facet, this means switch the sense of the RefFace that
00463     //- owns this Surface with respect to the positive sense of the
00464     //- first FACE in FACEPtrList_.
00465
00466   CubitStatus save_attribs( FILE* file_ptr );
00467     // Write FactAttribs out to file
00468
00469   CubitStatus restore_attribs( FILE* file_ptr, unsigned int endian );
00470     // Read FactAttribs from file
00471
00472   void get_bodies  ( DLIList<FacetBody   *>& bodies   );
00473   void get_lumps   ( DLIList<FacetLump   *>& lumps    );
00474   void get_shells  ( DLIList<FacetShell  *>& shells   );
00475   void get_loops   ( DLIList<FacetLoop   *>& loops    );
00476   void get_coedges ( DLIList<FacetCoEdge *>& coedges  );
00477   void get_curves  ( DLIList<FacetCurve  *>& curves   );
00478
00479   void get_parents_virt( DLIList<TopologyBridge*>& parents );
00480   void get_children_virt( DLIList<TopologyBridge*>& children );
00481
00482   CubitStatus get_my_facets(DLIList<CubitFacet*>& facet_list,
00483                             DLIList<CubitPoint*>& point_list);
00484     //- Gets the list of facets describing this surface.
00485   void tris(DLIList<CubitFacet*> &facet_list);
00486   void get_my_points(DLIList<CubitPoint*>& point_list);
00487     //- Gets the list of points describing this surface.
00488   void get_my_facetedges(DLIList<CubitFacetEdge*>& edge_list);
00489     //- Gets the list of points describing this surface.
00490   FacetEvalTool *get_eval_tool()
00491     { return facetEvalTool; }
00492   const FacetEvalTool *get_eval_tool() const
00493     { return facetEvalTool; }
00494     //- return the facet evaluation tool for this surface
00495
00496   CubitSense get_shell_sense( ShellSM *facet_shell ) const;
00497     // return the sense with respect to the given shell
00498
00499   void get_shell_sense( CubitSense &sense0 );
00500     // return senses
00501
00502   void set_shell_sense( FacetShell *facet_shell,
00503                         CubitSense thesense );
00504     // set the sense of the surface with respect to the shell
00505
00506   CubitStatus copy_facets(DLIList<CubitFacet*>&copy_facet_list,
00507                           DLIList<CubitPoint*>&copy_point_list,
00508                           std::map<CubitPoint*, CubitPoint*>&old_to_new_cubit_pts);
00509     // create a copy of the points and facets
00510
00511   int interp_order();
00512   double min_dot();
00513
00514   CubitBoolean is_flat();
00515   CubitBoolean is_spherical();
00516   CubitBoolean is_conical();
00517
00518   virtual CubitStatus get_nurb_params( bool &rational,
00519                                        int &degree_u,
00520                                        int &degree_v,
00521                                        int &num_cntrl_pts_u,
00522                                        int &num_cntrl_pts_v,
00523                                        DLIList<CubitVector> &cntrl_pts,
00524                                        DLIList<double> &weights,
00525                                        DLIList<double> &u_knots,
00526                                        DLIList<double> &v_knots ) const;
00527   //- Only valid for nurbs surfaces
00528   //O rational
00529   //O-   True if the nurb is rational
00530   //O degree_u
00531   //O-   The degree of the nurb in the u direction
00532   //O degree_v
00533   //O-   The degree of the nurb in the v direction
00534   //O num_cntrl_pts_u
00535   //O-   Number of control points in the u direction
00536   //O num_cntrl_pts_v
00537   //O-   Number of control points in the v direction
00538   //O cntrl_pts
00539   //O-   The control points stored as
00540   //O-           cntrl_pts[0                ] = pt[u=0][v=0]
00541   //O-           cntrl_pts[1                ] = pt[u=1][v=0]
00542   //O-               ...
00543   //O-           cntrl_pts[num_cntrl_pts_u-1] = pt[u=?][v=0]
00544   //O-           cntrl_pts[num_cntrl_pts_u  ] = pt[u=0][v=1]
00545   //O-               ...
00546   //O weights
00547   //O-   If rational, weights for each control point, stored in the same
00548   //O-   order as the control points.  No weights are returned if
00549   //O-   rational == false
00550   //O u_knots
00551   //O-   knot vector in the u direction
00552   //O v_knots
00553   //O-   knot vector in the v direction
00554
00555   virtual CubitStatus get_sphere_params( CubitVector &center,
00556                                          double &radius ) const;
00557     //- Only valid for spherical surfaces
00558     //O center
00559     //O- The center of the sphere
00560     //O radius
00561     //O- The radius of the sphere
00562
00563   virtual CubitStatus get_cone_params( CubitVector &center,
00564                                        CubitVector &normal,
00565                                        CubitVector &major_axis,
00566                                        double &radius_ratio,
00567                                        double &sine_angle,
00568                                        double &cos_angle ) const;
00569     //- Only valid for conical surfaces.  Cylinders are a special case of conicals.
00570     //O center
00571     //O-
00572     //O normal
00573     //O-
00574     //O major_axis
00575     //O-
00576     //O radius_ratio
00577     //O-
00578     //O sine_angle
00579     //O-
00580     //O cos_angle
00581     //O-
00582
00583   virtual CubitStatus get_torus_params( CubitVector &center,
00584                                         CubitVector &normal,
00585                                         double &major_radius,
00586                                         double &minor_radius ) const;
00587     //- Only valid for torus surfaces.
00588     //O center
00589     //O-
00590     //O normal
00591     //O-
00592     //O major_radius
00593     //O-
00594     //O minor_radius
00595     //O-
00596
00597   const CubitEvaluatorData *evaluator_data();
00598   void add_transformation( CubitTransformMatrix &tfmat );
00599
00600 };
00601
00602
00603 // ********** BEGIN INLINE FUNCTIONS       **********
00604 // ********** END INLINE FUNCTIONS         **********
00605
00606 // ********** BEGIN FRIEND FUNCTIONS       **********
00607 // ********** END FRIEND FUNCTIONS         **********
00608
00609 // ********** BEGIN EXTERN FUNCTIONS       **********
00610 // ********** END EXTERN FUNCTIONS         **********
00611
00612 #endif
00613
