cgma
OCCShell.hpp
00001 //-------------------------------------------------------------------------
00002 // Filename      : OCCShell.hpp
00003 //
00004 // Purpose       :
00005 //
00006 // Special Notes :
00007 //
00008 // Creator       : Jane Hu
00009 //
00010 // Creation Date : 11/16/07
00011 //
00012 // Owner         :
00013 //-------------------------------------------------------------------------
00014
00015 #ifndef OCC_SHELL_HPP
00016 #define OCC_SHELL_HPP
00017
00018 // ********** BEGIN STANDARD INCLUDES      **********
00019 // ********** END STANDARD INCLUDES        **********
00020
00021 // ********** BEGIN CUBIT INCLUDES         **********
00022 #include "CubitDefines.h"
00023 #include "ShellSM.hpp"
00024
00025 #include "TopoDS_Shell.hxx"
00026
00027 class OCCBody;
00028 class OCCLump;
00029 class OCCSurface;
00030 class OCCLoop;
00031 class OCCCurve;
00032 class OCCPoint;
00033 class BRepAlgoAPI_BooleanOperation;
00034 class BRepBuilderAPI_ModifyShape;
00035 class BRepBuilderAPI_MakeShape;
00036 class LocOpe_SplitShape;
00037 // ********** END CUBIT INCLUDES           **********
00038
00039 class OCCShell : public ShellSM
00040 {
00041 public:
00042
00043   OCCShell(TopoDS_Shell *theShell, OCCSurface* surface = NULL);
00044
00045   virtual ~OCCShell() ;
00046     //- Destructor.
00047
00048   TopoDS_Shell* get_TopoDS_Shell()
00049   {if(myTopoDSShell && !myTopoDSShell->IsNull()) assert (myTopoDSShell->ShapeType() == TopAbs_SHELL); return myTopoDSShell;}
00050   void set_TopoDS_Shell(TopoDS_Shell shell);
00051
00052   OCCLump* my_lump() {return myLump;}
00053   OCCBody* my_body() {return myBody;}
00054   OCCSurface* my_surface() {return mySheetSurface;}
00055   void set_sheet_surface (OCCSurface* surface) {mySheetSurface = surface;}
00056
00057   void set_lump(OCCLump* lump) {myLump = lump;}
00058   void set_body(OCCBody* body) {myBody = body;}
00059
00060   bool is_sheet() const { return mySheetSurface != 0; }
00061
00062   virtual GeometryQueryEngine*
00063   get_geometry_query_engine() const;
00064     //R GeometryQueryEngine*
00065     //R- A pointer to the geometric modeling engine associated with
00066     //R- the object.
00067     //- This function returns a pointer to the geometric modeling engine
00068     //- associated with the object.
00069
00070   virtual void append_simple_attribute_virt(const CubitSimpleAttrib&);
00071     //R void
00072     //I
00073     //I-
00074     //I- that is to be appended to this OSME object.
00075     //- The purpose of this function is to append a
00076     //- attribute to the OSME. The  is attached to each of the
00077     //- underlying solid model entities this one points to.
00078
00079   virtual void remove_simple_attribute_virt(const CubitSimpleAttrib&);
00080     //R void
00081     //I CubitSimpleAttrib*
00082     //I- A reference to a CubitSimpleAttrib object which is the object
00083     //I- that is to be removed to this OSME object.
00084     //- The purpose of this function is to remove a simple
00085     //- attribute from the OSME. The attribute is attached to each of the
00086     //- underlying solid model entities this one points to.
00087
00088   virtual void remove_all_simple_attribute_virt();
00089     //R void
00090     //I-
00091     //- The purpose of this function is to remove all simple
00092     //- attributes from the OSME.
00093
00094   virtual CubitStatus get_simple_attribute(DLIList<CubitSimpleAttrib>&);
00095   virtual CubitStatus get_simple_attribute(const CubitString& name,
00096                                            DLIList<CubitSimpleAttrib>&);
00097     //R CubitSimpleAttrib*
00098     //R- the returned cubit simple attribute.
00099     //- The purpose of this function is to get the attributes
00100     //- of the geometry entity. The name is attached to the underlying solid
00101     //- model entity(ies) this one points to.
00102     //- MJP Note:
00103     //- This is the code that implements the requirement that names
00104     //- of VGI Entities propagate across solid model boolean
00105     //- operations.  The success of this relies, of course, on the underlying
00106     //- solid modeler being able to propagate attributes across
00107     //- such operations on its entities. If it cannot, then "names"
00108     //- of VGI entities will not propagate.
00109
00110   virtual void get_parents_virt( DLIList<TopologyBridge*>& parents );
00111   virtual void get_children_virt( DLIList<TopologyBridge*>& children );
00112
00113   //ModifyShape refers only to Transform and GTransform for now 1/10/11)
00114   CubitStatus update_OCC_entity( BRepBuilderAPI_ModifyShape *aBRepTrsf,
00115                                  BRepAlgoAPI_BooleanOperation *op = NULL);
00116   double measure(); //area of the shell
00117   static CubitStatus update_OCC_entity(TopoDS_Shell& old_shell,
00118                                        TopoDS_Shape& new_shell,
00119                                        BRepBuilderAPI_MakeShape *op,
00120                                        LocOpe_SplitShape* sp = NULL);
00121
00122   DLIList<OCCSurface*> getMemberSurfaces() { return memberSurfaces; }
00123   void setMemberSurfaces(DLIList<OCCSurface*> surfaceList)
00124   {
00125     memberSurfaces = surfaceList;
00126   }
00127 protected:
00128
00129 private:
00130   TopoDS_Shell *myTopoDSShell;
00131   OCCSurface* mySheetSurface;
00132   OCCLump*    myLump;
00133   OCCBody*    myBody;
00134   DLIList<OCCSurface*> memberSurfaces;
00135 };
00136
00137 #endif
00138
