cgma
test_occ.cpp
00001 #undef NDEBUG
00002 #include <cassert>
00003 #include <cstdio>
00004 #include <cstdlib>
00005 #include <list>
00006 #include <map>
00007 #include <string>
00008
00009 #include "GeometryModifyTool.hpp"
00010 #include "GeometryQueryTool.hpp"
00011 #include "GMem.hpp"
00012 #include "OCCModifyEngine.hpp"
00013 #include "OCCQueryEngine.hpp"
00014 #include "RefVertex.hpp"
00015 #include "RefEdge.hpp"
00016 #include "RefFace.hpp"
00017 #include "RefVolume.hpp"
00018 #include "InitCGMA.hpp"
00019 #include "CubitCompat.hpp"
00020
00021 #define STRINGIFY(S) XSTRINGIFY(S)
00022 #define XSTRINGIFY(S) #S
00023 #ifndef SRCDIR
00024 #  define SRCDIR "."
00025 #endif
00026
00027 using std::list;
00028 using std::pair;
00029 using std::set;
00030 using std::map;
00031 using std::vector;
00032
00033 int main( int argc, char** argv ) {
00034
00035   CubitStatus status = InitCGMA::initialize_cgma("OCC");
00036   if (CUBIT_SUCCESS != status) return 1;
00037   GeometryQueryTool *gti = GeometryQueryTool::instance();
00038
00039   // Read in the geometry from files specified on the command line
00040   const char* filename = STRINGIFY(SRCDIR) "/LeverArm.brep";
00041   status = CubitCompat_import_solid_model(filename, "OCC");
00042   if (status != CUBIT_SUCCESS) {
00043     PRINT_ERROR("Problems reading geometry file %s.\n", filename);
00044     return 1;
00045   }
00046
00047   DLIList<RefEdge*> my_curvs;
00048   DLIList<RefFace*> my_surfs;
00049   gti->ref_edges(my_curvs);
00050   gti->ref_faces(my_surfs);
00051
00052   // ***** Discretize the curves ***** //
00053
00054   map< RefEdge*, list<double> > discrete_curves;
00055
00056   for(int i = 0; i < my_curvs.size(); ++i) {
00057
00058     list<double> sample_params;
00059     RefEdge* this_curv = my_curvs.get_and_step();
00060     //Insert nine arbitrary points on each curves
00061     double delta = this_curv->end_param() - this_curv->start_param();
00062     for(int j = 1; j < 10; ++j)
00063       sample_params.push_back( this_curv->start_param() + (static_cast<double>(j) * delta / 10.) );
00064
00065     discrete_curves.insert( std::make_pair(this_curv, sample_params) );
00066
00067   }
00068
00069   //Pick one of the surfaces arbitrarily and attempt to find the u-v coordinates
00070   //of the points discretizing the boundary of this surface.
00071
00072   {
00073
00074     RefFace* this_surf = my_surfs.next(7);
00075     DLIList<RefVertex*> surf_points;
00076     DLIList<RefEdge*> surf_curves;
00077     this_surf->ref_vertices(surf_points);
00078     this_surf->ref_edges(surf_curves);
00079
00080     CubitVector coord0, coord1;
00081     double u, v;
00082
00083     double max_u, min_u, max_v, min_v;
00084     this_surf->get_param_range_U(min_u, max_u);
00085     this_surf->get_param_range_V(min_v, max_v);
00086
00087     //Deals with curve end points.
00088
00089     for(int i = 0; i < surf_points.size(); ++i) {
00090
00091       RefVertex* this_point = surf_points.get_and_step();
00092
00093       u = v = -1.e300;
00094       coord0 = this_point->coordinates();
00095       this_surf->u_v_from_position(coord0, u, v, &coord1);
00096
00097       if( u < min_u || v < min_v ) {
00098     printf("Failed to find a parameter with valid range for an apex point\n");
00099     printf("  point coords:     %e %e %e\n", coord0.x(), coord0.y(), coord0.z());
00100     printf("  projected coords: %e %e %e\n", coord1.x(), coord1.y(), coord1.z());
00101     printf("  params returned:  %e %e\n\n", u, v);
00102         return 1;
00103       }
00104
00105     }
00106
00107     //Deals with discretization points on curves.
00108
00109     for(int i = 0; i < surf_curves.size(); ++i) {
00110
00111       RefEdge* this_curv = surf_curves.get_and_step();
00112
00113       assert(discrete_curves.count(this_curv) == 1);
00114       list<double> curve_params = discrete_curves.find(this_curv)->second;
00115       list<double>::iterator it = curve_params.begin(), it_end = curve_params.end();
00116
00117       for( ; it != it_end; ++it) {
00118
00119     u = v = -1.e300;
00120     this_curv->position_from_u(*it, coord0);
00121     this_surf->u_v_from_position(coord0, u, v, &coord1);
00122
00123     if( u < min_u || v < min_v ) {
00124       printf("Failed to find a parameter with valid range for a curve point\n");
00125       printf("  point coords:     %e %e %e\n", coord0.x(), coord0.y(), coord0.z());
00126       printf("  projected coords: %e %e %e\n", coord1.x(), coord1.y(), coord1.z());
00127       printf("  params returned:  %e %e\n\n", u, v);
00128           return 1;
00129     }
00130
00131       }
00132
00133     }
00134
00135   }
00136
00137   printf("done...\n");
00138
00139   return(0);
00140
00141 }
