cgma
00001 00002 #include "CubitAttribManager.hpp" 00003 #include "CubitAttribUser.hpp" 00004 #include "CastTo.hpp" 00005 #include "assert.h" 00006 #include "CADefines.hpp" 00007 00008 #include "RefEntity.hpp" 00009 #include "CubitMessage.hpp" 00010 00011 CubitAttribManager::CubitAttribManager() 00012 : silentFlag(false) 00013 { 00014 } 00015 00016 CubitAttribManager::~CubitAttribManager() 00017 { 00018 /* 00019 std::map<int, CARegisterData*>::iterator iter = mTypeToCAData.begin(); 00020 00021 while (mTypeToCAData.end() != iter) 00022 { 00023 delete iter->second; 00024 iter++; 00025 } 00026 */ 00027 int i; 00028 assert(mTypeNames.size() == mInternalNames.size()); 00029 00030 00031 for (i=mTypeNames.size(); i>0; i--) 00032 { 00033 delete [] mTypeNames.get_and_step(); 00034 delete [] mInternalNames.get_and_step(); 00035 } 00036 00037 } 00038 00039 CubitStatus 00040 CubitAttribManager::register_attrib_type( const int att_type, 00041 const char* att_type_name, 00042 const char* att_internal_name, 00043 CACreateFunction p_create_function, 00044 CubitBoolean auto_actuate_flag, 00045 CubitBoolean auto_update_flag, 00046 CubitBoolean auto_write_flag, 00047 CubitBoolean auto_read_flag, 00048 CubitBoolean actuate_in_constructor, 00049 CubitBoolean actuate_after_geom_changes) 00050 { 00051 assert(CA_UNDEFINED != att_type); 00052 assert(CA_ALL_ATTRIBUTES != att_type); 00053 00054 /* 00055 unsigned int flags = 0; 00056 if (auto_actuate_flag) flags |= CA_AUTOACTUATE; 00057 if (auto_update_flag) flags |= CA_AUTOUPDATE; 00058 if (auto_write_flag) flags |= CA_AUTOWRITE; 00059 if (auto_read_flag) flags |= CA_AUTOREAD; 00060 if (actuate_in_constructor) flags |= CA_ACTUATEINCONSTRUCTOR; 00061 if (actuate_after_geom_changes) flags |= CA_ACTUATEAFTERGEOMCHANGES; 00062 CARegisterData *p_entry = new CARegisterData(att_type_name, att_internal_name, 00063 p_create_function, flags); 00064 00065 std::pair<std::map<int, CARegisterData*>::iterator, bool> result_pair; 00066 result_pair = mTypeToCAData.insert( std::pair<int, CARegisterData*>(att_type, p_entry) ); 00067 00068 if (!result_pair.second) // failed to insert because the type was already registered 00069 { 00070 assert(false); 00071 delete p_entry; 00072 return CUBIT_FAILURE; 00073 } 00074 */ 00075 00076 int index = mTypes.where_is_item(att_type); 00077 if (-1 != index) // type already registered 00078 { 00079 if (!silentFlag) PRINT_ERROR("Attribute type %d already registered\n.", att_type); 00080 return CUBIT_FAILURE; 00081 } 00082 00083 #ifndef NDEBUG 00084 int size = mTypes.size(); 00085 assert (mTypeNames.size() == size); 00086 assert (mCreatorFunctions.size() == size); 00087 assert (mInternalNames.size() == size); 00088 assert (mAutoActuateFlags.size() == size); 00089 assert (mAutoUpdateFlags.size() == size); 00090 assert (mAutoWriteFlags.size() == size); 00091 assert (mAutoReadFlags.size() == size); 00092 assert (mActuateInConstructor.size() == size); 00093 assert (mActuateAfterGeomChanges.size() == size); 00094 // assert (mAttribImported.size() == size); 00095 #endif 00096 00097 mTypes.append(att_type); 00098 00099 int namesize = strlen(att_type_name); 00100 char *stemp = new char[namesize+1]; 00101 strcpy(stemp, att_type_name); 00102 mTypeNames.append(stemp); 00103 00104 namesize = strlen(att_internal_name); 00105 stemp = new char[namesize+1]; 00106 strcpy(stemp, att_internal_name); 00107 mInternalNames.append(stemp); 00108 00109 mCreatorFunctions.append(p_create_function); 00110 00111 mAutoActuateFlags.append(auto_actuate_flag); 00112 mAutoUpdateFlags.append(auto_update_flag); 00113 mAutoWriteFlags.append(auto_write_flag); 00114 mAutoReadFlags.append(auto_read_flag); 00115 mActuateInConstructor.append(actuate_in_constructor); 00116 mActuateAfterGeomChanges.append(actuate_after_geom_changes); 00117 // mAttribImported.append(CUBIT_FALSE); // TODO - get rid of mAttribImported 00118 00119 return CUBIT_SUCCESS; 00120 } 00121 00122 CubitAttrib* 00123 CubitAttribManager::create_cubit_attrib(const int attrib_type, 00124 RefEntity *attrib_user, 00125 const CubitSimpleAttrib &p_csa) 00126 { 00127 CubitAttrib* new_attrib = NULL; 00128 /* 00129 CARegisterData *p_entry = NULL; 00130 CACreateFunction p_creator; 00131 std::map<int, CARegisterData*>::iterator iter; 00132 00133 iter = mTypeToCAData.find(attrib_type); 00134 if (mTypeToCAData.end() == iter) 00135 { 00136 assert(false); 00137 return NULL; 00138 } 00139 00140 p_entry = iter->second; 00141 p_creator = p_entry->mCreateFunction; 00142 new_attrib = (*p_creator)(attrib_user); 00143 return new_attrib; 00144 */ 00145 00146 int index = mTypes.where_is_item(attrib_type); 00147 if (-1 == index) // type not registered 00148 { 00149 if (!silentFlag) PRINT_ERROR("Attribute type %d can't be created because it hasn't been registered.\n", 00150 attrib_type); 00151 return NULL; 00152 } 00153 00154 00155 CACreateFunction p_creator; 00156 mCreatorFunctions.reset(); 00157 p_creator = mCreatorFunctions.next(index); 00158 00159 new_attrib = (*p_creator)(attrib_user, p_csa); 00160 return new_attrib; 00161 00162 } 00163 00164 /* 00165 CubitStatus CubitAttribManager::actuate_list(DLIList<RefEntity*> entity_list) 00166 { 00167 int i, j; 00168 RefEntity * ref_ent; 00169 for(i = entity_list.size(); i > 0; i--) 00170 { 00171 ref_ent = entity_list.get_and_step(); 00172 00173 mTypes.reset(); 00174 for (j = mTypes.size(); j>0; j--) 00175 { 00176 ref_ent->actuate_cubit_attrib(mTypes.get_and_step()); 00177 } 00178 } 00179 return CUBIT_SUCCESS; 00180 } 00181 */ 00182 CubitStatus CubitAttribManager::auto_update_attribs(RefEntity *cau) 00183 { 00184 //- create attribs whose auto update flag is set 00185 00186 CubitStatus status = CUBIT_SUCCESS; 00187 DLIList<CubitAttrib*> attrib_list; 00188 00189 /* 00190 std::map<int, CARegisterData*>::iterator iter = mTypeToCAData.begin(); 00191 00192 while (mTypeToCAData.end() != iter) 00193 { 00194 CubitBoolean auto_update = ((iter->second)->flags) & CA_AUTOUPDATE; 00195 int attrib_type = iter->first; 00196 00197 if (auto_update) 00198 { 00199 attrib_list.clean_out(); 00200 cau->find_cubit_attrib_type(attrib_type, attrib_list); 00201 if (attrib_list.size() == 0) { 00202 create_cubit_attrib(attrib_type, cau); 00203 if (status == CUBIT_FAILURE) break; 00204 } 00205 } 00206 iter++; 00207 } 00208 */ 00209 mAutoUpdateFlags.reset(); 00210 mTypes.reset(); 00211 assert(mTypes.size() == mAutoUpdateFlags.size()); 00212 int index; 00213 for (index=mAutoUpdateFlags.size(); index>0; index--) { 00214 // check the auto update flag first, if not set we can go 00215 if (mAutoUpdateFlags.get() == CUBIT_TRUE) 00216 { 00217 00218 // else we must create a CA of type if there's not one already there 00219 attrib_list.clean_out(); 00220 cau->find_cubit_attrib_type(mTypes.get(), attrib_list); 00221 if (attrib_list.size() == 0) { 00222 create_cubit_attrib(mTypes.get(), cau, CubitSimpleAttrib()); 00223 if (status == CUBIT_FAILURE) break; 00224 } 00225 } 00226 mAutoUpdateFlags.step(); 00227 mTypes.step(); 00228 } 00229 00230 return status; 00231 } 00232 00233 void CubitAttribManager::set_all_auto_actuate_flags(CubitBoolean value) 00234 { 00235 00236 // std::map<int, CARegisterData*>::iterator iter = mTypeToCAData.begin(); 00237 00238 // while (mTypeToCAData.end() != iter) 00239 // { 00240 00241 mAutoActuateFlags.reset(); 00242 for (int i = mAutoActuateFlags.size(); i>0; i--) 00243 { 00244 mAutoActuateFlags.change_to(value); 00245 mAutoActuateFlags.step(); 00246 } 00247 } 00248 00249 CubitStatus CubitAttribManager::set_auto_actuate_flag(int attrib_type, CubitBoolean value) 00250 { 00251 assert(CA_UNDEFINED != attrib_type); 00252 assert(CA_ALL_ATTRIBUTES != attrib_type); 00253 00254 int index = mTypes.where_is_item(attrib_type); 00255 00256 if (-1 == index) 00257 return CUBIT_FAILURE; 00258 00259 mAutoActuateFlags.reset(); 00260 mAutoActuateFlags.step(index); 00261 mAutoActuateFlags.change_to(value); 00262 return CUBIT_SUCCESS; 00263 } 00264 00265 void CubitAttribManager::set_all_auto_update_flags(CubitBoolean value) 00266 { 00267 mAutoUpdateFlags.reset(); 00268 for (int i = mAutoUpdateFlags.size(); i>0; i--) 00269 { 00270 mAutoUpdateFlags.change_to(value); 00271 mAutoUpdateFlags.step(); 00272 } 00273 } 00274 00275 CubitStatus CubitAttribManager::set_auto_update_flag(int attrib_type, CubitBoolean value) 00276 { 00277 assert(CA_UNDEFINED != attrib_type); 00278 assert(CA_ALL_ATTRIBUTES != attrib_type); 00279 00280 int index = mTypes.where_is_item(attrib_type); 00281 00282 if (-1 == index) 00283 return CUBIT_FAILURE; 00284 00285 mAutoUpdateFlags.reset(); 00286 mAutoUpdateFlags.step(index); 00287 mAutoUpdateFlags.change_to(value); 00288 return CUBIT_SUCCESS; 00289 } 00290 00291 void CubitAttribManager::set_all_auto_write_flags(CubitBoolean value) 00292 { 00293 mAutoWriteFlags.reset(); 00294 for (int i = mAutoWriteFlags.size(); i>0; i--) 00295 { 00296 mAutoWriteFlags.change_to(value); 00297 mAutoWriteFlags.step(); 00298 } 00299 } 00300 00301 CubitStatus CubitAttribManager::set_auto_write_flag(int attrib_type, CubitBoolean value) 00302 { 00303 assert(CA_UNDEFINED != attrib_type); 00304 assert(CA_ALL_ATTRIBUTES != attrib_type); 00305 00306 int index = mTypes.where_is_item(attrib_type); 00307 00308 if (-1 == index) 00309 return CUBIT_FAILURE; 00310 00311 mAutoWriteFlags.reset(); 00312 mAutoWriteFlags.step(index); 00313 mAutoWriteFlags.change_to(value); 00314 return CUBIT_SUCCESS; 00315 } 00316 00317 void CubitAttribManager::set_all_auto_read_flags(CubitBoolean value) 00318 { 00319 mAutoReadFlags.reset(); 00320 for (int i = mAutoReadFlags.size(); i>0; i--) 00321 { 00322 mAutoReadFlags.change_to(value); 00323 mAutoReadFlags.step(); 00324 } 00325 } 00326 00327 CubitStatus CubitAttribManager::set_auto_read_flag(int attrib_type, CubitBoolean value) 00328 { 00329 assert(CA_UNDEFINED != attrib_type); 00330 assert(CA_ALL_ATTRIBUTES != attrib_type); 00331 00332 int index = mTypes.where_is_item(attrib_type); 00333 00334 if (-1 == index) 00335 return CUBIT_FAILURE; 00336 00337 mAutoReadFlags.reset(); 00338 mAutoReadFlags.step(index); 00339 mAutoReadFlags.change_to(value); 00340 return CUBIT_SUCCESS; 00341 } 00342 00343 void CubitAttribManager::auto_flag(int flag) 00344 { 00345 if (flag == -1) { 00346 flag = auto_flag(); 00347 if (flag == -1) { 00348 if (!silentFlag) PRINT_ERROR("Can't change attribute flag with toggle, " 00349 "some are already set.\n"); 00350 return; 00351 } 00352 } 00353 00354 CubitBoolean set_flag = (flag == 1 ? CUBIT_TRUE : CUBIT_FALSE); 00355 00356 mAutoUpdateFlags.reset(); 00357 mAutoActuateFlags.reset(); 00358 assert (mAutoUpdateFlags.size() == mAutoActuateFlags.size()); 00359 for (int i = mAutoUpdateFlags.size(); i>0; i--) 00360 { 00361 mAutoUpdateFlags.change_to(set_flag); 00362 mAutoUpdateFlags.step(); 00363 mAutoActuateFlags.change_to(set_flag); 00364 mAutoActuateFlags.step(); 00365 } 00366 00367 if (!set_flag) { 00368 // make sure entity_name flag isn't set false here 00369 00370 int index = mTypes.where_is_item(CA_ENTITY_NAME); 00371 assert(-1 != index); 00372 00373 mAutoUpdateFlags.reset(); 00374 mAutoUpdateFlags.step(index); 00375 mAutoUpdateFlags.change_to(CUBIT_TRUE); 00376 00377 mAutoActuateFlags.reset(); 00378 mAutoActuateFlags.step(index); 00379 mAutoActuateFlags.change_to(CUBIT_TRUE); 00380 } 00381 } 00382 00383 int CubitAttribManager::auto_flag() 00384 { 00385 int sum = 0; 00386 CubitBoolean b_temp; 00387 mAutoUpdateFlags.reset(); 00388 mAutoActuateFlags.reset(); 00389 assert (mAutoUpdateFlags.size() == mAutoActuateFlags.size()); 00390 for (int i = mAutoUpdateFlags.size(); i>0; i--) 00391 { 00392 b_temp = mAutoUpdateFlags.get_and_step(); 00393 if (b_temp) sum++; 00394 b_temp = mAutoActuateFlags.get_and_step(); 00395 if (b_temp) sum++; 00396 } 00397 00398 if (2*mAutoUpdateFlags.size() == sum) return 0; 00399 else if (sum == 0) return 1; 00400 else return -1; 00401 } 00402 00403 int CubitAttribManager::attrib_type(const char* name) 00404 { 00405 int i; 00406 mTypeNames.reset(); 00407 assert (mTypes.size() == mTypeNames.size()); 00408 for (i=0; i<mTypeNames.size(); i++) 00409 { 00410 if (!strcmp(name, mTypeNames.get_and_step())) 00411 { 00412 mTypes.reset(); 00413 mTypes.step(i); 00414 return mTypes.get(); 00415 } 00416 } 00417 00418 return CA_UNDEFINED; 00419 } 00420 00421 int CubitAttribManager::attrib_type(const CubitSimpleAttrib& csa_ptr) 00422 { 00423 CubitString char_type = csa_ptr.character_type(); 00424 return attrib_type_from_internal_name(char_type.c_str()); 00425 } 00426 00427 int CubitAttribManager::attrib_type_from_internal_name(const char* name) 00428 { 00429 int i; 00430 mInternalNames.reset(); 00431 assert (mTypes.size() == mInternalNames.size()); 00432 for (i=0; i<mInternalNames.size(); i++) 00433 { 00434 if (!strcmp(name, mInternalNames.get_and_step())) 00435 { 00436 mTypes.reset(); 00437 mTypes.step(i); 00438 return mTypes.get(); 00439 } 00440 } 00441 00442 return CA_UNDEFINED; 00443 } 00444 00445 CubitBoolean CubitAttribManager::auto_actuate_flag(int attrib_type) 00446 { 00447 int index = mTypes.where_is_item(attrib_type); 00448 if (-1 == index) { 00449 if (!silentFlag) PRINT_ERROR("Attribute type %d not recognized.\n", attrib_type); 00450 return false; 00451 } 00452 00453 mAutoActuateFlags.reset(); 00454 mAutoActuateFlags.step(index); 00455 return mAutoActuateFlags.get(); 00456 } 00457 00458 CubitBoolean CubitAttribManager::auto_update_flag(int attrib_type) 00459 { 00460 int index = mTypes.where_is_item(attrib_type); 00461 if (-1 == index) { 00462 if (!silentFlag) PRINT_ERROR("Attribute type %d not recognized.\n", attrib_type); 00463 return false; 00464 } 00465 00466 mAutoUpdateFlags.reset(); 00467 mAutoUpdateFlags.step(index); 00468 return mAutoUpdateFlags.get(); 00469 } 00470 00471 CubitBoolean CubitAttribManager::auto_write_flag(int attrib_type) 00472 { 00473 int index = mTypes.where_is_item(attrib_type); 00474 if (-1 == index) { 00475 if (!silentFlag) PRINT_ERROR("Attribute type %d not recognized.\n", attrib_type); 00476 return false; 00477 } 00478 00479 mAutoWriteFlags.reset(); 00480 mAutoWriteFlags.step(index); 00481 return mAutoWriteFlags.get(); 00482 } 00483 00484 CubitBoolean CubitAttribManager::auto_read_flag(int attrib_type) 00485 { 00486 int index = mTypes.where_is_item(attrib_type); 00487 if (-1 == index) { 00488 if (!silentFlag) PRINT_ERROR("Attribute type %d not recognized.\n", attrib_type); 00489 return false; 00490 } 00491 00492 mAutoReadFlags.reset(); 00493 mAutoReadFlags.step(index); 00494 return mAutoReadFlags.get(); 00495 } 00496 00497 //- return the internal name of this CA given the enumerated attribute type 00498 const char * CubitAttribManager::att_internal_name(int attrib_type) 00499 { 00500 int index = mTypes.where_is_item(attrib_type); 00501 if (-1 == index) { 00502 if (!silentFlag) PRINT_ERROR("Attribute type %d not recognized.\n", attrib_type); 00503 return NULL; 00504 } 00505 00506 mInternalNames.reset(); 00507 mInternalNames.step(index); 00508 return mInternalNames.get(); 00509 } 00510 00511 //- return the name of this CA given the enumerated attribute type 00512 const char * CubitAttribManager::att_name(int attrib_type) 00513 { 00514 int index = mTypes.where_is_item(attrib_type); 00515 if (-1 == index) { 00516 if (!silentFlag) PRINT_ERROR("Attribute type %d not recognized.\n", attrib_type); 00517 return NULL; 00518 } 00519 00520 mTypeNames.reset(); 00521 mTypeNames.step(index); 00522 return mTypeNames.get(); 00523 } 00524 00525 CubitBoolean CubitAttribManager::actuate_in_constructor(int attrib_type) 00526 { 00527 int index = mTypes.where_is_item(attrib_type); 00528 if (-1 == index) { 00529 if (!silentFlag) PRINT_ERROR("Attribute type %d not recognized.\n", attrib_type); 00530 return false; 00531 } 00532 00533 mActuateInConstructor.reset(); 00534 mActuateInConstructor.step(index); 00535 return mActuateInConstructor.get(); 00536 } 00537 00538 CubitBoolean CubitAttribManager::actuate_after_geom_changes(int attrib_type) 00539 { 00540 int index = mTypes.where_is_item(attrib_type); 00541 if (-1 == index) { 00542 if (!silentFlag) PRINT_ERROR("Attribute type %d not recognized.\n", attrib_type); 00543 return false; 00544 } 00545 00546 mActuateAfterGeomChanges.reset(); 00547 mActuateAfterGeomChanges.step(index); 00548 return mActuateAfterGeomChanges.get(); 00549 } 00550 00551 void CubitAttribManager::get_registered_types(DLIList<int> &types) 00552 { 00553 types = mTypes; 00554 types.reset(); 00555 } 00556 00557
