cgma
#include <CubitAttribManager.hpp>
Definition at line 23 of file CubitAttribManager.hpp.
Definition at line 11 of file CubitAttribManager.cpp.
: silentFlag(false) { }
| CubitAttribManager::~CubitAttribManager | ( | ) | [virtual] |
Definition at line 16 of file CubitAttribManager.cpp.
std::map<int, CARegisterData*>::iterator iter = mTypeToCAData.begin();
while (mTypeToCAData.end() != iter)
delete iter->second;
iter++;
int i;
assert(mTypeNames.size() == mInternalNames.size());
for (i=mTypeNames.size(); i>0; i--)
delete [] mTypeNames.get_and_step();
delete [] mInternalNames.get_and_step();
| CubitBoolean CubitAttribManager::actuate_after_geom_changes | ( | int | attrib_type | ) |
Definition at line 538 of file CubitAttribManager.cpp.
int index = mTypes.where_is_item(attrib_type);
if (-1 == index) {
if (!silentFlag) PRINT_ERROR("Attribute type %d not recognized.\n", attrib_type);
return false;
mActuateAfterGeomChanges.reset();
mActuateAfterGeomChanges.step(index);
return mActuateAfterGeomChanges.get();
| CubitBoolean CubitAttribManager::actuate_in_constructor | ( | int | attrib_type | ) |
Definition at line 525 of file CubitAttribManager.cpp.
if (-1 == index) {
return false;
mActuateInConstructor.reset();
mActuateInConstructor.step(index);
return mActuateInConstructor.get();
| const char * CubitAttribManager::att_internal_name | ( | int | attrib_type | ) |
Definition at line 498 of file CubitAttribManager.cpp.
if (-1 == index) {
return NULL;
mInternalNames.reset();
mInternalNames.step(index);
return mInternalNames.get();
| const char * CubitAttribManager::att_name | ( | int | attrib_type | ) |
Definition at line 512 of file CubitAttribManager.cpp.
if (-1 == index) {
return NULL;
mTypeNames.reset();
mTypeNames.step(index);
return mTypeNames.get();
| int CubitAttribManager::attrib_type | ( | const CubitSimpleAttrib & | csa_ptr | ) |
Definition at line 421 of file CubitAttribManager.cpp.
CubitString char_type = csa_ptr.character_type();
return attrib_type_from_internal_name(char_type.c_str());
| int CubitAttribManager::attrib_type | ( | const char * | name | ) |
Definition at line 403 of file CubitAttribManager.cpp.
int i;
mTypeNames.reset();
assert (mTypes.size() == mTypeNames.size());
for (i=0; i<mTypeNames.size(); i++)
if (!strcmp(name, mTypeNames.get_and_step()))
mTypes.reset();
mTypes.step(i);
return mTypes.get();
return CA_UNDEFINED;
| int CubitAttribManager::attrib_type_from_internal_name | ( | const char * | name | ) |
Definition at line 427 of file CubitAttribManager.cpp.
int i;
assert (mTypes.size() == mInternalNames.size());
for (i=0; i<mInternalNames.size(); i++)
if (!strcmp(name, mInternalNames.get_and_step()))
mTypes.reset();
mTypes.step(i);
| CubitBoolean CubitAttribManager::auto_actuate_flag | ( | int | attrib_type | ) |
Definition at line 445 of file CubitAttribManager.cpp.
if (-1 == index) {
return false;
mAutoActuateFlags.reset();
mAutoActuateFlags.step(index);
return mAutoActuateFlags.get();
| int CubitAttribManager::auto_flag | ( | ) |
Definition at line 383 of file CubitAttribManager.cpp.
int sum = 0;
CubitBoolean b_temp;
mAutoUpdateFlags.reset();
assert (mAutoUpdateFlags.size() == mAutoActuateFlags.size());
for (int i = mAutoUpdateFlags.size(); i>0; i--)
b_temp = mAutoUpdateFlags.get_and_step();
if (b_temp) sum++;
b_temp = mAutoActuateFlags.get_and_step();
if (b_temp) sum++;
if (2*mAutoUpdateFlags.size() == sum) return 0;
else if (sum == 0) return 1;
else return -1;
| void CubitAttribManager::auto_flag | ( | int | flag | ) |
Definition at line 343 of file CubitAttribManager.cpp.
if (flag == -1) {
flag = auto_flag();
if (flag == -1) {
if (!silentFlag) PRINT_ERROR("Can't change attribute flag with toggle, "
"some are already set.\n");
return;
CubitBoolean set_flag = (flag == 1 ? CUBIT_TRUE : CUBIT_FALSE);
mAutoUpdateFlags.change_to(set_flag);
mAutoUpdateFlags.step();
mAutoActuateFlags.change_to(set_flag);
mAutoActuateFlags.step();
if (!set_flag) {
// make sure entity_name flag isn't set false here
int index = mTypes.where_is_item(CA_ENTITY_NAME);
assert(-1 != index);
mAutoUpdateFlags.step(index);
mAutoUpdateFlags.change_to(CUBIT_TRUE);
mAutoActuateFlags.change_to(CUBIT_TRUE);
| CubitBoolean CubitAttribManager::auto_read_flag | ( | int | attrib_type | ) |
Definition at line 484 of file CubitAttribManager.cpp.
if (-1 == index) {
return false;
mAutoReadFlags.reset();
mAutoReadFlags.step(index);
return mAutoReadFlags.get();
Definition at line 182 of file CubitAttribManager.cpp.
//- create attribs whose auto update flag is set
CubitStatus status = CUBIT_SUCCESS;
DLIList<CubitAttrib*> attrib_list;
CubitBoolean auto_update = ((iter->second)->flags) & CA_AUTOUPDATE;
int attrib_type = iter->first;
if (auto_update)
attrib_list.clean_out();
cau->find_cubit_attrib_type(attrib_type, attrib_list);
if (attrib_list.size() == 0) {
create_cubit_attrib(attrib_type, cau);
if (status == CUBIT_FAILURE) break;
iter++;
mTypes.reset();
assert(mTypes.size() == mAutoUpdateFlags.size());
int index;
for (index=mAutoUpdateFlags.size(); index>0; index--) {
// check the auto update flag first, if not set we can go
if (mAutoUpdateFlags.get() == CUBIT_TRUE)
// else we must create a CA of type if there's not one already there
cau->find_cubit_attrib_type(mTypes.get(), attrib_list);
create_cubit_attrib(mTypes.get(), cau, CubitSimpleAttrib());
mTypes.step();
return status;
| CubitBoolean CubitAttribManager::auto_update_flag | ( | int | attrib_type | ) |
Definition at line 458 of file CubitAttribManager.cpp.
if (-1 == index) {
return false;
return mAutoUpdateFlags.get();
| CubitBoolean CubitAttribManager::auto_write_flag | ( | int | attrib_type | ) |
Definition at line 471 of file CubitAttribManager.cpp.
if (-1 == index) {
return false;
mAutoWriteFlags.reset();
mAutoWriteFlags.step(index);
return mAutoWriteFlags.get();
| CubitAttrib * CubitAttribManager::create_cubit_attrib | ( | const int | attrib_type, |
| RefEntity * | attrib_user, | ||
| const CubitSimpleAttrib & | p_csa | ||
Definition at line 123 of file CubitAttribManager.cpp.
CubitAttrib* new_attrib = NULL;
CARegisterData *p_entry = NULL;
CACreateFunction p_creator;
std::map<int, CARegisterData*>::iterator iter;
iter = mTypeToCAData.find(attrib_type);
if (mTypeToCAData.end() == iter)
assert(false);
return NULL;
p_entry = iter->second;
p_creator = p_entry->mCreateFunction;
new_attrib = (*p_creator)(attrib_user);
return new_attrib;
if (-1 == index) // type not registered
if (!silentFlag) PRINT_ERROR("Attribute type %d can't be created because it hasn't been registered.\n",
attrib_type);
return NULL;
mCreatorFunctions.reset();
p_creator = mCreatorFunctions.next(index);
new_attrib = (*p_creator)(attrib_user, p_csa);
return new_attrib;
| void CubitAttribManager::get_registered_types | ( | DLIList< int > & | types | ) |
Definition at line 551 of file CubitAttribManager.cpp.
| CubitStatus CubitAttribManager::register_attrib_type | ( | const int | att_type, |
| const char * | att_type_name, | ||
| const char * | att_internal_name, | ||
| CACreateFunction | p_create_function, | ||
| CubitBoolean | auto_actuate_flag, | ||
| CubitBoolean | auto_update_flag, | ||
| CubitBoolean | auto_write_flag, | ||
| CubitBoolean | auto_read_flag, | ||
| CubitBoolean | actuate_in_constructor, | ||
| CubitBoolean | actuate_after_geom_changes | ||
Definition at line 40 of file CubitAttribManager.cpp.
assert(CA_UNDEFINED != att_type);
assert(CA_ALL_ATTRIBUTES != att_type);
unsigned int flags = 0;
if (auto_actuate_flag) flags |= CA_AUTOACTUATE;
if (auto_update_flag) flags |= CA_AUTOUPDATE;
if (auto_write_flag) flags |= CA_AUTOWRITE;
if (auto_read_flag) flags |= CA_AUTOREAD;
if (actuate_in_constructor) flags |= CA_ACTUATEINCONSTRUCTOR;
if (actuate_after_geom_changes) flags |= CA_ACTUATEAFTERGEOMCHANGES;
CARegisterData *p_entry = new CARegisterData(att_type_name, att_internal_name,
p_create_function, flags);
std::pair<std::map<int, CARegisterData*>::iterator, bool> result_pair;
result_pair = mTypeToCAData.insert( std::pair<int, CARegisterData*>(att_type, p_entry) );
if (!result_pair.second) // failed to insert because the type was already registered
assert(false);
delete p_entry;
return CUBIT_FAILURE;
int index = mTypes.where_is_item(att_type);
if (-1 != index) // type already registered
if (!silentFlag) PRINT_ERROR("Attribute type %d already registered\n.", att_type);
#ifndef NDEBUG
int size = mTypes.size();
assert (mTypeNames.size() == size);
assert (mCreatorFunctions.size() == size);
assert (mInternalNames.size() == size);
assert (mAutoActuateFlags.size() == size);
assert (mAutoUpdateFlags.size() == size);
assert (mAutoWriteFlags.size() == size);
assert (mAutoReadFlags.size() == size);
assert (mActuateInConstructor.size() == size);
assert (mActuateAfterGeomChanges.size() == size);
// assert (mAttribImported.size() == size);
#endif
mTypes.append(att_type);
int namesize = strlen(att_type_name);
char *stemp = new char[namesize+1];
strcpy(stemp, att_type_name);
mTypeNames.append(stemp);
namesize = strlen(att_internal_name);
strcpy(stemp, att_internal_name);
mInternalNames.append(stemp);
mCreatorFunctions.append(p_create_function);
mAutoActuateFlags.append(auto_actuate_flag);
mAutoUpdateFlags.append(auto_update_flag);
mAutoWriteFlags.append(auto_write_flag);
mAutoReadFlags.append(auto_read_flag);
mActuateInConstructor.append(actuate_in_constructor);
mActuateAfterGeomChanges.append(actuate_after_geom_changes);
// mAttribImported.append(CUBIT_FALSE); // TODO - get rid of mAttribImported
return CUBIT_SUCCESS;
| void CubitAttribManager::set_all_auto_actuate_flags | ( | CubitBoolean | value | ) |
Definition at line 233 of file CubitAttribManager.cpp.
// std::map<int, CARegisterData*>::iterator iter = mTypeToCAData.begin();
// while (mTypeToCAData.end() != iter)
for (int i = mAutoActuateFlags.size(); i>0; i--)
mAutoActuateFlags.change_to(value);
| void CubitAttribManager::set_all_auto_read_flags | ( | CubitBoolean | value | ) |
Definition at line 317 of file CubitAttribManager.cpp.
for (int i = mAutoReadFlags.size(); i>0; i--)
mAutoReadFlags.change_to(value);
mAutoReadFlags.step();
| void CubitAttribManager::set_all_auto_update_flags | ( | CubitBoolean | value | ) |
Definition at line 265 of file CubitAttribManager.cpp.
mAutoUpdateFlags.change_to(value);
| void CubitAttribManager::set_all_auto_write_flags | ( | CubitBoolean | value | ) |
Definition at line 291 of file CubitAttribManager.cpp.
for (int i = mAutoWriteFlags.size(); i>0; i--)
mAutoWriteFlags.change_to(value);
mAutoWriteFlags.step();
| CubitStatus CubitAttribManager::set_auto_actuate_flag | ( | int | attrib_type, |
| CubitBoolean | value | ||
Definition at line 249 of file CubitAttribManager.cpp.
assert(CA_UNDEFINED != attrib_type);
assert(CA_ALL_ATTRIBUTES != attrib_type);
if (-1 == index)
| CubitStatus CubitAttribManager::set_auto_read_flag | ( | int | attrib_type, |
Definition at line 327 of file CubitAttribManager.cpp.
if (-1 == index)
| CubitStatus CubitAttribManager::set_auto_update_flag | ( | int | attrib_type, |
Definition at line 275 of file CubitAttribManager.cpp.
if (-1 == index)
| CubitStatus CubitAttribManager::set_auto_write_flag | ( | int | attrib_type, |
Definition at line 301 of file CubitAttribManager.cpp.
if (-1 == index)
| bool CubitAttribManager::silent_flag | ( | ) | [inline] |
Definition at line 95 of file CubitAttribManager.hpp.
{return silentFlag;}
| void CubitAttribManager::silent_flag | ( | const bool | flag | ) | [inline] |
Definition at line 96 of file CubitAttribManager.hpp.
{silentFlag = flag;}
Definition at line 150 of file CubitAttribManager.hpp.
Definition at line 149 of file CubitAttribManager.hpp.
Definition at line 145 of file CubitAttribManager.hpp.
Definition at line 148 of file CubitAttribManager.hpp.
Definition at line 146 of file CubitAttribManager.hpp.
Definition at line 147 of file CubitAttribManager.hpp.
Definition at line 144 of file CubitAttribManager.hpp.
DLIList<char*> CubitAttribManager::mInternalNames [private] |
Definition at line 143 of file CubitAttribManager.hpp.
DLIList<char*> CubitAttribManager::mTypeNames [private] |
Definition at line 142 of file CubitAttribManager.hpp.
DLIList<int> CubitAttribManager::mTypes [private] |
Definition at line 141 of file CubitAttribManager.hpp.
bool CubitAttribManager::silentFlag [private] |
Definition at line 155 of file CubitAttribManager.hpp.
