cgma
#include <PeriodicParamTool.hpp>
Public Member Functions | |
| PeriodicParamTool (Surface *surf) | |
| ~PeriodicParamTool () | |
| CubitStatus | set_up_space (double u_period, double v_period, double u_offset, double v_offset) |
| CubitStatus | transform_to_uv (const CubitVector &xyz_location, CubitVector &uv_location) |
| CubitStatus | transform_to_xyz (CubitVector &xyz_location, const CubitVector &uv_location) |
| void | mirror_surface (bool true_false) |
| CubitStatus | uv_derivitives (double u_param, double v_param, CubitVector &du, CubitVector &dv) |
Private Attributes | |
| Surface * | refSurf |
| double | uPeriod |
| double | vPeriod |
| double | uOffset |
| double | vOffset |
| bool | mirrorSurface |
Definition at line 26 of file PeriodicParamTool.hpp.
| PeriodicParamTool::PeriodicParamTool | ( | Surface * | surf | ) |
Definition at line 28 of file PeriodicParamTool.cpp.
Definition at line 46 of file PeriodicParamTool.cpp.
| void PeriodicParamTool::mirror_surface | ( | bool | true_false | ) |
Definition at line 134 of file PeriodicParamTool.cpp.
mirrorSurface = true_false;
if (mirrorSurface)
PRINT_INFO("Loops appear backwards, mirroring surface...\n");
| CubitStatus PeriodicParamTool::set_up_space | ( | double | u_period, |
| double | v_period, | ||
| double | u_offset, | ||
| double | v_offset | ||
Definition at line 54 of file PeriodicParamTool.cpp.
// store the u and periods
uPeriod = u_period;
vPeriod = v_period;
uOffset = u_offset;
vOffset = v_offset;
CubitStatus rv = CUBIT_SUCCESS;
return rv;
| CubitStatus PeriodicParamTool::transform_to_uv | ( | const CubitVector & | xyz_location, |
| CubitVector & | uv_location | ||
| ) | [virtual] |
Implements ParamTool.
Definition at line 75 of file PeriodicParamTool.cpp.
double u,v;
CubitStatus rv = refSurf->u_v_from_position(xyz_location, u, v);
// offset values to avoid parameter discontinuity
if (uPeriod && u < uOffset)
u += uPeriod;
// mirror surface if required to get correct loop orientation
if (mirrorSurface)
u = -u;
if (vPeriod && v < vOffset)
v += vPeriod;
uv_location.set(u,v,1.0);
return rv;
| CubitStatus PeriodicParamTool::transform_to_xyz | ( | CubitVector & | xyz_location, |
| const CubitVector & | uv_location | ||
| ) | [virtual] |
Definition at line 112 of file PeriodicParamTool.cpp.
double u = uv_location.x();
if (mirrorSurface)
u = -u;
if (u > uPeriod)
u = u - uPeriod;
double v = uv_location.y();
if (v > vPeriod)
v = v - vPeriod;
xyz_location = refSurf->position_from_u_v(u,v);
return CUBIT_SUCCESS;
| CubitStatus PeriodicParamTool::uv_derivitives | ( | double | u_param, |
| double | v_param, | ||
| CubitVector & | du, | ||
| CubitVector & | dv | ||
| ) | [virtual] |
Reimplemented from ParamTool.
Definition at line 142 of file PeriodicParamTool.cpp.
if (mirrorSurface)
u_param = -u_param;
if (u_param > uPeriod)
u_param = u_param-uPeriod;
if (v_param > vPeriod)
v_param = v_param-vPeriod;
refSurf->uv_derivitives(u_param, v_param, du, dv);
bool PeriodicParamTool::mirrorSurface [private] |
Definition at line 54 of file PeriodicParamTool.hpp.
Surface* PeriodicParamTool::refSurf [private] |
Definition at line 49 of file PeriodicParamTool.hpp.
double PeriodicParamTool::uOffset [private] |
Definition at line 52 of file PeriodicParamTool.hpp.
double PeriodicParamTool::uPeriod [private] |
Definition at line 50 of file PeriodicParamTool.hpp.
double PeriodicParamTool::vOffset [private] |
Definition at line 53 of file PeriodicParamTool.hpp.
double PeriodicParamTool::vPeriod [private] |
Definition at line 51 of file PeriodicParamTool.hpp.
