cgma
#include <BasicTopologyEntity.hpp>
Definition at line 76 of file BasicTopologyEntity.hpp.
| BasicTopologyEntity::BasicTopologyEntity | ( | ) | [inline] |
Definition at line 271 of file BasicTopologyEntity.hpp.
: firstSenseEntity(0), lastSenseEntity(0), firstGroupingEntity(0), lastGroupingEntity(0) {}
| BasicTopologyEntity::~BasicTopologyEntity | ( | ) | [virtual] |
Definition at line 43 of file BasicTopologyEntity.cpp.
while (firstSenseEntity && remove_sense_entity(firstSenseEntity));
while (firstGroupingEntity && remove_grouping_entity(firstGroupingEntity));
assert(!firstSenseEntity && !firstGroupingEntity);
| BasicTopologyEntity::BasicTopologyEntity | ( | const BasicTopologyEntity & | ) | [private] |
Definition at line 107 of file BasicTopologyEntity.cpp.
if (gpe_ptr->dag_type().parent() != dag_type())
return CUBIT_FAILURE;
if (gpe_ptr->get_basic_topology_entity_ptr())
assert(!gpe_ptr->next());
if (firstGroupingEntity)
if (!gpe_ptr->insert_after(lastGroupingEntity))
else
firstGroupingEntity = gpe_ptr;
lastGroupingEntity = gpe_ptr;
gpe_ptr->set_basic_topology_entity_ptr(this);
return CUBIT_SUCCESS;
Definition at line 286 of file BasicTopologyEntity.cpp.
if (se_ptr->dag_type() != dag_type().parent())
if (se_ptr->get_basic_topology_entity_ptr())
assert(!se_ptr->next_on_bte());
if (firstSenseEntity)
assert(!lastSenseEntity->next_on_bte());
lastSenseEntity->set_bte_next(se_ptr);
else
firstSenseEntity = se_ptr;
lastSenseEntity = se_ptr;
se_ptr->set_basic_topology_entity_ptr(this);
| CubitBox BasicTopologyEntity::bounding_box | ( | ) | [virtual] |
Implements CubitEntity.
Definition at line 471 of file BasicTopologyEntity.cpp.
return get_geometry_entity_ptr()->bounding_box() ;
| virtual const char* BasicTopologyEntity::class_name | ( | ) | const [inline, virtual] |
Reimplemented from TopologyEntity.
Reimplemented in RefFace, RefVolume, RefEdge, and RefVertex.
Definition at line 83 of file BasicTopologyEntity.hpp.
{ return get_class_name(); }
| virtual DagType BasicTopologyEntity::dag_type | ( | ) | const [pure virtual] |
| CubitStatus BasicTopologyEntity::disconnect_all_children | ( | DLIList< TopologyEntity * > * | children = 0 | ) | [protected, virtual] |
Implements TopologyEntity.
Definition at line 682 of file BasicTopologyEntity.cpp.
while (firstGroupingEntity)
GroupingEntity* gpe_ptr = firstGroupingEntity;
if (!remove_grouping_entity(gpe_ptr))
if (list)
list->append(gpe_ptr);
| CubitStatus BasicTopologyEntity::disconnect_all_parents | ( | DLIList< TopologyEntity * > * | parents = 0 | ) | [protected, virtual] |
Definition at line 658 of file BasicTopologyEntity.cpp.
while (firstSenseEntity)
SenseEntity* se_ptr = firstSenseEntity;
if (!remove_sense_entity(se_ptr))
if (list)
list->append(se_ptr);
| SenseEntity * BasicTopologyEntity::find_sense_entity | ( | GroupingEntity * | gpe | ) | const |
Definition at line 367 of file BasicTopologyEntity.cpp.
SenseEntity *ptr, *result = 0;
for (ptr = firstSenseEntity; ptr; ptr = ptr->next_on_bte())
if (ptr->get_grouping_entity_ptr() == gpe)
if (result)
return 0;
result = ptr;
return result;
| SenseEntity * BasicTopologyEntity::find_sense_entity | ( | BasicTopologyEntity * | bte | ) | const |
Definition at line 382 of file BasicTopologyEntity.cpp.
GroupingEntity* gpe = ptr->get_grouping_entity_ptr();
BasicTopologyEntity* tmp_bte = gpe ? gpe->get_basic_topology_entity_ptr() : 0;
if (tmp_bte == bte)
if (result)
return 0;
result = ptr;
return result;
Definition at line 447 of file BasicTopologyEntity.cpp.
//- returns type of underlying geometry representation
//- (see GeometryEntity.hpp for list of types)
return get_geometry_entity_ptr()->geometry_type();
| int BasicTopologyEntity::get_children | ( | DLIList< TopologyEntity * > * | list = 0 | ) | const [virtual] |
Definition at line 566 of file BasicTopologyEntity.cpp.
if (!firstGroupingEntity)
return 0;
int count = 0;
GroupingEntity* ptr;
for (ptr = firstGroupingEntity; ptr; ptr = ptr->next())
count++;
if (list)
list->append(ptr);
return count;
| static const char* BasicTopologyEntity::get_class_name | ( | ) | [inline, static] |
Definition at line 80 of file BasicTopologyEntity.hpp.
{ return "BasicTopologyEntity"; }
| GroupingEntity * BasicTopologyEntity::get_first_grouping_entity_ptr | ( | ) | const [inline] |
Definition at line 281 of file BasicTopologyEntity.hpp.
{ return firstGroupingEntity; }
| SenseEntity * BasicTopologyEntity::get_first_sense_entity_ptr | ( | ) | const [inline] |
Definition at line 278 of file BasicTopologyEntity.hpp.
{ return firstSenseEntity; }
Definition at line 464 of file BasicTopologyEntity.cpp.
TopologyBridge* bridge = bridge_manager()->topology_bridge();
return dynamic_cast<GeometryEntity*>(bridge);
| CubitStatus BasicTopologyEntity::get_grouping_entity_list | ( | DLIList< GroupingEntity * > & | groupingEntityList | ) | const |
Definition at line 66 of file BasicTopologyEntity.cpp.
for (GroupingEntity* ptr = firstGroupingEntity; ptr; ptr = ptr->next())
assert(ptr->get_basic_topology_entity_ptr() == this);
list.append(ptr);
| int BasicTopologyEntity::get_parents | ( | DLIList< TopologyEntity * > * | list = 0 | ) | const [virtual] |
Definition at line 537 of file BasicTopologyEntity.cpp.
if (!firstSenseEntity)
return 0;
int count = 0;
SenseEntity* ptr;
count++;
if (list)
list->append(ptr);
return count;
| CubitStatus BasicTopologyEntity::get_sense_entities | ( | DLIList< SenseEntity * > & | result, |
| GroupingEntity * | in_this | ||
Definition at line 400 of file BasicTopologyEntity.cpp.
int input_size = result.size();
for (SenseEntity* ptr = firstSenseEntity; ptr; ptr = ptr->next_on_bte())
if (!in_this || ptr->get_grouping_entity_ptr() == in_this)
result.append(ptr);
return result.size() > input_size ? CUBIT_SUCCESS : CUBIT_FAILURE;
| BasicTopologyEntity * | in_this | ||
Definition at line 413 of file BasicTopologyEntity.cpp.
if (!in_this || ptr->get_parent_basic_topology_entity_ptr() == in_this)
result.append(ptr);
| CubitStatus BasicTopologyEntity::get_sense_entity_list | ( | DLIList< SenseEntity * > & | senseEntityList | ) | const |
Definition at line 87 of file BasicTopologyEntity.cpp.
list.append(ptr);
| CubitBoolean BasicTopologyEntity::is_nonmanifold | ( | GroupingEntity * | in_this_parent | ) |
Definition at line 436 of file BasicTopologyEntity.cpp.
int count = 0;
count++;
assert(count);
return count == 1 ? CUBIT_FALSE : CUBIT_TRUE;
| double BasicTopologyEntity::measure | ( | ) | [virtual] |
A generic geometric extent function. Returns volume for RefVolumes, area for RefFaces, length for RefEdge, and 1.0 for RefVertices A RefGroup calculates the maximum dimension of its contained entities and returns the sum of the measures() of all entities of that dimension. Default return value is 0.0 for all other entities.
Reimplemented from RefEntity.
Reimplemented in RefFace, and RefEdge.
Definition at line 525 of file BasicTopologyEntity.cpp.
{ return get_geometry_entity_ptr()->measure(); }
| void BasicTopologyEntity::operator= | ( | const BasicTopologyEntity & | ) | [private] |
| CubitBoolean BasicTopologyEntity::query_append_children | ( | DLIList< TopologyEntity * > & | list | ) | [protected, virtual] |
Definition at line 610 of file BasicTopologyEntity.cpp.
return 0;
CubitBoolean found_some = CUBIT_FALSE;
ModelQueryEngine *const mqe = ModelQueryEngine::instance();
if (!mqe->encountered(ptr))
found_some = CUBIT_TRUE;
list.append(ptr);
return found_some;
| CubitBoolean BasicTopologyEntity::query_append_parents | ( | DLIList< TopologyEntity * > & | list | ) | [protected, virtual] |
Definition at line 593 of file BasicTopologyEntity.cpp.
return CUBIT_FALSE;
list.append(ptr);
return found_some;
| CubitStatus BasicTopologyEntity::remove_child_link | ( | TopologyEntity * | entity_ptr | ) | [protected, virtual] |
Definition at line 640 of file BasicTopologyEntity.cpp.
GroupingEntity* gpe_ptr = dynamic_cast<GroupingEntity*>(entity_ptr);
if (!gpe_ptr)
return remove_grouping_entity(gpe_ptr);
Definition at line 141 of file BasicTopologyEntity.cpp.
if (gpe_ptr->get_basic_topology_entity_ptr() != this)
GroupingEntity* next_gpe_ptr = gpe_ptr->next();
GroupingEntity* prev_gpe_ptr = gpe_ptr->previous();
if (!gpe_ptr->remove_from_list())
if (firstGroupingEntity == gpe_ptr)
firstGroupingEntity = next_gpe_ptr;
if (lastGroupingEntity == gpe_ptr)
lastGroupingEntity = prev_gpe_ptr;
gpe_ptr->set_basic_topology_entity_ptr(0);
Definition at line 319 of file BasicTopologyEntity.cpp.
if (se_ptr->get_basic_topology_entity_ptr() != this)
{ assert(0); return CUBIT_FAILURE; }
if (firstSenseEntity == se_ptr)
if (lastSenseEntity == se_ptr)
firstSenseEntity = lastSenseEntity = 0;
else
firstSenseEntity = se_ptr->next_on_bte();
else
SenseEntity* prev = firstSenseEntity;
while (prev->next_on_bte() != se_ptr)
prev = prev->next_on_bte();
if (!prev)
prev->set_bte_next( se_ptr->next_on_bte() );
lastSenseEntity = prev;
se_ptr->set_bte_next(0);
se_ptr->set_basic_topology_entity_ptr(0);
| CubitStatus BasicTopologyEntity::set_geometry_entity_ptr | ( | GeometryEntity * | geometryEntityPtr | ) |
Definition at line 513 of file BasicTopologyEntity.cpp.
// if (dag_type().dimension() != GE_ptr.dimension())
// PRINT_ERROR("Internal Error: %s:%d: Mismatched BTE/GeometryEntity.\n",
// __FILE__,__LINE__);
// return CUBIT_FAILURE;
return TopologyEntity::set_topology_bridge(GE_ptr);
| CubitStatus BasicTopologyEntity::set_grouping_entity_list | ( | DLIList< GroupingEntity * > & | new_list, |
| DLIList< GroupingEntity * > & | removed_list | ||
Definition at line 170 of file BasicTopologyEntity.cpp.
int i;
// Remove all?
if (list.size() == 0)
get_grouping_entity_list( removed );
return disconnect_all_children();
// Check for error conditions before modifying anything
list.reset();
for (i = list.size(); i--; )
GroupingEntity* grouping_entity = list.get_and_step();
// Check to make sure that we are getting the correct type of
// GroupingEntity.
if ( dag_type() != grouping_entity->dag_type().parent() )
return CUBIT_FAILURE ;
// Check that the grouping entity is not already in some other
// basic topology entity
if ( grouping_entity->get_basic_topology_entity_ptr() &&
grouping_entity->get_basic_topology_entity_ptr() != this )
// Special case for first entity in list.
list.reset();
GroupingEntity* new_first = list.get_and_step();
// No sense entities currently attached...
firstGroupingEntity = lastGroupingEntity = new_first;
new_first->set_basic_topology_entity_ptr(this);
// Already attached, but not first in list...
else if( firstGroupingEntity != new_first )
if (!new_first->get_basic_topology_entity_ptr())
else
if (lastGroupingEntity == new_first)
lastGroupingEntity = new_first->previous();
new_first->remove_from_list();
new_first->insert_before(firstGroupingEntity);
firstGroupingEntity = new_first;
// Now loop through remaining sense entities.
GroupingEntity* prev = new_first;
for (i = list.size() - 1; i--; )
GroupingEntity* curr = list.get_and_step();
// If next grouping entity in input list is not
// next grouping entity in this BTE...
if (prev->next() != curr)
if (!curr->get_basic_topology_entity_ptr())
curr->set_basic_topology_entity_ptr(this);
else
if (lastGroupingEntity == curr)
lastGroupingEntity = curr->previous();
curr->remove_from_list();
curr->insert_after(prev);
// update lastSenseEntity if necessary...
if (lastGroupingEntity == prev)
lastGroupingEntity = curr;
// iterate
prev = curr;
// Disconnect any grouping entities in this BTE
// that were not in in the input list (they should now
// be at the end of the list of grouping entities in this)
// and pass them back in the 'removed' list.
CubitStatus result = CUBIT_SUCCESS;
while (prev != lastGroupingEntity)
removed.append(prev->next());
if (!remove_grouping_entity(prev->next()))
assert(0);
result = CUBIT_FAILURE;
prev = prev->next();
return result;
| CubitBox BasicTopologyEntity::unmerged_bounding_box | ( | ) | [virtual] |
Definition at line 479 of file BasicTopologyEntity.cpp.
if(bridge_manager()->number_of_bridges() == 1)
else
CubitBox aggregate_box;
DLIList<TopologyBridge*> bridges;
bridge_manager()->get_bridge_list(bridges);
GeometryEntity *ge = dynamic_cast<GeometryEntity*>(bridges.get_and_step());
if(ge)
aggregate_box = ge->bounding_box();
int i;
for(i=bridges.size(); i>1; i--)
if(ge)
aggregate_box |= ge->bounding_box();
return aggregate_box;
Definition at line 262 of file BasicTopologyEntity.hpp.
SenseEntity* BasicTopologyEntity::firstSenseEntity [private] |
Definition at line 260 of file BasicTopologyEntity.hpp.
Definition at line 263 of file BasicTopologyEntity.hpp.
SenseEntity* BasicTopologyEntity::lastSenseEntity [private] |
Definition at line 261 of file BasicTopologyEntity.hpp.
