cgma
#include <OCCShapeAttributeSet.hpp>
Public Member Functions | |
| void * | operator new (size_t, void *anAddress) |
| void * | operator new (size_t size) |
| void | operator delete (void *anAddress) |
| OCCShapeAttributeSet () | |
| Builds an empty ShapeAttributeSet. | |
| OCCShapeAttributeSet (const BRep_Builder &B) | |
| ~OCCShapeAttributeSet () | |
| void | AddGeometry (const TopoDS_Shape &S) |
| Stores the goemetry of <S>. | |
| void | WriteAttribute (const TopoDS_Shape &S, Standard_OStream &OS, TDF_Label &l_attr) |
| void | ReadAttribute (TopoDS_Shape &S, Standard_IStream &IS, TDF_Label &l_attr) |
| Standard_Integer | Add (const TopoDS_Shape &S) |
| void | Write (Standard_OStream &OS) |
| void | Read (Standard_IStream &IS, bool print) |
| void | Read (TopoDS_Shape &S, Standard_IStream &IS, const int nbshapes, TDF_Label *l_attr=NULL) |
| void | WriteGeometry (Standard_OStream &OS) |
| void | ReadGeometry (Standard_IStream &IS) |
| void | WriteGeometry (const TopoDS_Shape &S, Standard_OStream &OS) |
| void | ReadGeometry (const TopAbs_ShapeEnum T, Standard_IStream &IS, TopoDS_Shape &S) |
| void | Write (const TopoDS_Shape &S, Standard_OStream &OS, TDF_Label *l_attr=NULL) |
| Standard_EXPORT void | WritePolygon3D (Standard_OStream &OS, const Standard_Boolean Compact=Standard_True) |
| void | ReadPolygon3D (Standard_IStream &IS) |
| Standard_EXPORT void | WritePolygonOnTriangulation (Standard_OStream &OS, const Standard_Boolean Compact=Standard_True) |
| void | ReadPolygonOnTriangulation (Standard_IStream &IS) |
| Standard_EXPORT void | WriteTriangulation (Standard_OStream &OS, const Standard_Boolean Compact=Standard_True) |
| void | ReadTriangulation (Standard_IStream &IS) |
| void | Clear () |
| Clears the content of the set. | |
| void | Check (const TopAbs_ShapeEnum T, TopoDS_Shape &S) |
| int | NbShapes () |
Private Attributes | |
| BRep_Builder | myBuilder |
| TopTools_IndexedMapOfShape | myShapes |
| std::map< int, int > | my_ShapeNum_Location |
| TopTools_LocationSet | myLocations |
| Standard_Integer | myFormatNb |
| GeomTools_SurfaceSet | mySurfaces |
| GeomTools_CurveSet | myCurves |
| GeomTools_Curve2dSet | myCurves2d |
| TColStd_IndexedMapOfTransient | myPolygons2D |
| TColStd_IndexedMapOfTransient | myPolygons3D |
| TColStd_IndexedMapOfTransient | myTriangulations |
| TColStd_IndexedMapOfTransient | myNodes |
Contains a Shape and all its subshapes, locations
and geometries, and attributes.
Definition at line 48 of file OCCShapeAttributeSet.hpp.
Definition at line 308 of file OCCShapeAttributeSet.cpp.
:myFormatNb(1) { }
| OCCShapeAttributeSet::OCCShapeAttributeSet | ( | const BRep_Builder & | B | ) |
Definition at line 318 of file OCCShapeAttributeSet.cpp.
:myBuilder(B) { }
| OCCShapeAttributeSet::~OCCShapeAttributeSet | ( | ) | [inline] |
Definition at line 72 of file OCCShapeAttributeSet.hpp.
{Clear();} ;
| Standard_Integer OCCShapeAttributeSet::Add | ( | const TopoDS_Shape & | S | ) |
Stores <S> and its sub-shape. Returns the index of <S>.
The method AddGeometry is called on each sub-shape.
Definition at line 327 of file OCCShapeAttributeSet.cpp.
if (S.IsNull()) return 0;
myLocations.Add(S.Location());
TopoDS_Shape S2 = S;
S2.Location(TopLoc_Location());
Standard_Integer index = myShapes.FindIndex(S2);
if (index == 0) {
AddGeometry(S2);
for (TopoDS_Iterator its(S2,Standard_False,Standard_False);
its.More(); its.Next())
Add(its.Value());
index = myShapes.Add(S2);
return index;
| void OCCShapeAttributeSet::AddGeometry | ( | const TopoDS_Shape & | S | ) |
Definition at line 351 of file OCCShapeAttributeSet.cpp.
// Add the geometry
if (S.ShapeType() == TopAbs_VERTEX) {
Handle(BRep_TVertex) TV = Handle(BRep_TVertex)::DownCast(S.TShape());
BRep_ListIteratorOfListOfPointRepresentation itrp(TV->Points());
while (itrp.More()) {
const Handle(BRep_PointRepresentation)& PR = itrp.Value();
if (PR->IsPointOnCurve()) {
myCurves.Add(PR->Curve());
else if (PR->IsPointOnCurveOnSurface()) {
myCurves2d.Add(PR->PCurve());
mySurfaces.Add(PR->Surface());
else if (PR->IsPointOnSurface()) {
myLocations.Add(PR->Location());
itrp.Next();
else if (S.ShapeType() == TopAbs_EDGE) {
// Add the curve geometry
Handle(BRep_TEdge) TE = Handle(BRep_TEdge)::DownCast(S.TShape());
BRep_ListIteratorOfListOfCurveRepresentation itrc(TE->Curves());
while (itrc.More()) {
const Handle(BRep_CurveRepresentation)& CR = itrc.Value();
if (CR->IsCurve3D()) {
if (!CR->Curve3D().IsNull()) {
myCurves.Add(CR->Curve3D());
myLocations.Add(CR->Location());
else if (CR->IsCurveOnSurface()) {
mySurfaces.Add(CR->Surface());
myCurves2d.Add(CR->PCurve());
if (CR->IsCurveOnClosedSurface())
myCurves2d.Add(CR->PCurve2());
else if (CR->IsRegularity()) {
mySurfaces.Add(CR->Surface2());
myLocations.Add(CR->Location2());
itrc.Next();
else if (S.ShapeType() == TopAbs_FACE) {
// Add the surface geometry
Handle(BRep_TFace) TF = Handle(BRep_TFace)::DownCast(S.TShape());
if (!TF->Surface().IsNull()) mySurfaces.Add(TF->Surface());
myLocations.Add(TF->Location());
| void OCCShapeAttributeSet::Check | ( | const TopAbs_ShapeEnum | T, |
| TopoDS_Shape & | S | ||
Definition at line 1809 of file OCCShapeAttributeSet.cpp.
if (T == TopAbs_FACE) {
const TopoDS_Face& F = TopoDS::Face(S);
BRepTools::Update(F);
| void OCCShapeAttributeSet::Clear | ( | ) |
Definition at line 1717 of file OCCShapeAttributeSet.cpp.
mySurfaces.Clear();
myCurves.Clear();
myCurves2d.Clear();
myPolygons3D.Clear();
myPolygons2D.Clear();
myNodes.Clear();
myTriangulations.Clear();
myShapes.Clear();
my_ShapeNum_Location.clear();
myLocations.Clear();
| int OCCShapeAttributeSet::NbShapes | ( | ) |
Definition at line 1823 of file OCCShapeAttributeSet.cpp.
return myShapes.Extent();
| void OCCShapeAttributeSet::operator delete | ( | void * | anAddress | ) | [inline] |
Definition at line 60 of file OCCShapeAttributeSet.hpp.
if (anAddress) Standard::Free((Standard_Address&)anAddress);
| void* OCCShapeAttributeSet::operator new | ( | size_t | , |
| void * | anAddress | ||
| ) | [inline] |
Definition at line 52 of file OCCShapeAttributeSet.hpp.
return anAddress;
| void* OCCShapeAttributeSet::operator new | ( | size_t | size | ) | [inline] |
Definition at line 56 of file OCCShapeAttributeSet.hpp.
return Standard::Allocate(size);
| void OCCShapeAttributeSet::Read | ( | Standard_IStream & | IS, |
| bool | |||
Definition at line 712 of file OCCShapeAttributeSet.cpp.
// on sauvegarde l'ancien LC_NUMERIC
char *oldnum,*plocal ;
plocal = setlocale(LC_NUMERIC, NULL) ;
oldnum = new char[strlen(plocal)+1] ;
strcpy(oldnum,plocal);
Clear();
// Check the version
char vers[101];
do {
IS.getline(vers,100,'\n');
// BUC60769 PTV 18.10.2000: remove possible '\r' at the end of the line
//Standard_Integer lv = strlen(vers);
//char *pm;
//if(pm = strchr(vers,'\r'))
// *pm ='\0';
for (Standard_Integer lv = (strlen(vers)- 1); lv > 1 && (vers[lv] == '\r' || vers[lv] == '\n') ;lv--)
vers[lv] = '\0';
} while ( ! IS.fail() && strcmp(vers,dVersion) && strcmp(vers,dVersion2) );
if (IS.fail()) {
if (print_results)
cout << "File was not written with this version of the topology"<<endl;
setlocale(LC_NUMERIC, oldnum) ;
delete[] oldnum;
return;
if (strcmp(vers,dVersion2) == 0) myFormatNb = 2;
else myFormatNb = 1;
// read the locations
myLocations.Read(IS);
// read the geometry
ReadGeometry(IS);
// read the shapes
std::string buffer;
IS >> buffer;
if (buffer != "TShapes") {
if (print_results)
cout << "Not a TShape table"<<endl;
delete[] oldnum;
return;
Standard_Integer i, nbShapes;
IS >> nbShapes;
for (i = 1; i <= nbShapes; i++) {
TopoDS_Shape S;
//Read type and create empty shape.
TopAbs_ShapeEnum T = ReadShapeEnum(IS);
ReadGeometry(T,IS,S);
// Set the flags
IS >> buffer;
// sub-shapes
TopoDS_Shape SS;
do {
Read(SS,IS,nbShapes);
if (!SS.IsNull())
myBuilder.Add(S,SS);
} while(!SS.IsNull());
S.Free (buffer[0] == '1');
S.Modified (buffer[1] == '1');
if (myFormatNb == 2)
S.Checked (buffer[2] == '1');
else
S.Checked (Standard_False); // force check at reading..
S.Orientable(buffer[3] == '1');
S.Closed (buffer[4] == '1');
S.Infinite (buffer[5] == '1');
S.Convex (buffer[6] == '1');
// check
if (myFormatNb == 1)
Check(T,S);
myShapes.Add(S);
delete[] oldnum;
| void OCCShapeAttributeSet::Read | ( | TopoDS_Shape & | S, |
| Standard_IStream & | IS, | ||
| const int | nbshapes, | ||
| TDF_Label * | l_attr = NULL |
Definition at line 1736 of file OCCShapeAttributeSet.cpp.
std::string buffer, buffer_attr;
IS >> buffer;
std::map<int,int>::iterator it;
if (buffer[0] == '*')
S = TopoDS_Shape();
else {
char type;
int num;
std::istringstream buffstr(buffer);
buffstr >> type >> num;
S = myShapes(nbshapes - num + 1);
switch (type) {
case '+' :
S.Orientation(TopAbs_FORWARD);
break;
case '-' :
S.Orientation(TopAbs_REVERSED);
break;
case 'i' :
S.Orientation(TopAbs_INTERNAL);
break;
case 'e' :
S.Orientation(TopAbs_EXTERNAL);
break;
Standard_Integer l;
IS >> l;
S.Location(myLocations.Location(l));
int shape_num = nbshapes - num + 1;
typedef std::pair <int,int> sh_loc_pair;
it = my_ShapeNum_Location.find(shape_num);
if(it == my_ShapeNum_Location.end())
my_ShapeNum_Location.insert(sh_loc_pair(shape_num, l));
if(label != NULL)
Standard_Integer i, nbShapes = myShapes.Extent();
for ( i = 1; i <= nbShapes; i++)
TopoDS_Shape Sh = myShapes(i);
IS >> buffer_attr;
if(buffer_attr[0] != '*' && buffer_attr[0] != 'C')
break;
if(buffer_attr[0] == '*') //empty attributes for this shape
continue;
it = my_ShapeNum_Location.find(i);
if(it != my_ShapeNum_Location.end())
int loc_num = it->second;
if (loc_num > 0)
Sh.Location(myLocations.Location(loc_num));
ReadAttribute(Sh, IS,*label);
| void OCCShapeAttributeSet::ReadAttribute | ( | TopoDS_Shape & | S, |
| TDF_Label & | l_attr | ||
Definition at line 427 of file OCCShapeAttributeSet.cpp.
std::string buffer, type, stringdata;
std::vector<CubitString> strings;
std::vector<double> doubles;
std::vector<int> ints;
int c_num, length;
char s;
do {
IS >> c_num; //length of name string
IS.get(); //' '
type.clear();
for(int j = 0; j < c_num; j ++)
IS.get(s);
type.push_back(s);
strings.clear();
strings.push_back(type.c_str());
IS >> length; //number of strings
for(int i =0; i < length; i++)
IS >> c_num ; //length of each string
IS.get(); //' '
stringdata.clear();
IS.get(s);
stringdata.push_back(s);
strings.push_back(stringdata.c_str());
int tmp_int;
double tmp_dbl;
IS >> length; //number of ints
ints.clear();
for (int i = 0; i < length ; i++)
IS >> tmp_int;
ints.push_back( tmp_int );
IS >> length; //number of doubles
doubles.clear();
IS >> tmp_dbl;
doubles.push_back( tmp_dbl );
CubitSimpleAttrib tmp_attrib(&strings, &doubles, &ints);
OCCAttribSet::append_attribute(tmp_attrib, S);
IS >> buffer;
}while(buffer[0] != '*');
| void OCCShapeAttributeSet::ReadGeometry | ( | Standard_IStream & | IS | ) |
Definition at line 839 of file OCCShapeAttributeSet.cpp.
myCurves2d.Read(IS);
myCurves.Read(IS);
ReadPolygon3D(IS);
ReadPolygonOnTriangulation(IS);
mySurfaces.Read(IS);
ReadTriangulation(IS);
| void OCCShapeAttributeSet::ReadGeometry | ( | const TopAbs_ShapeEnum | T, |
Definition at line 1228 of file OCCShapeAttributeSet.cpp.
// Read the geometry
Standard_Integer val,c,pc,pc2,s,s2,l,l2,t, pt, pt2;
Standard_Real tol,X,Y,Z,first,last,p1,p2;
Standard_Real PfX,PfY,PlX,PlY;
gp_Pnt2d aPf, aPl;
Standard_Boolean closed;
#ifndef DEB
GeomAbs_Shape reg = GeomAbs_C0;
#else
GeomAbs_Shape reg;
#endif
switch (T) {
// vertex
case TopAbs_VERTEX :
TopoDS_Vertex& V = TopoDS::Vertex(S);
// Read the point geometry
IS >> tol;
IS >> X >> Y >> Z;
myBuilder.MakeVertex(V,gp_Pnt(X,Y,Z),tol);
Handle(BRep_TVertex) TV = Handle(BRep_TVertex)::DownCast(V.TShape());
BRep_ListOfPointRepresentation& lpr = TV->ChangePoints();
TopLoc_Location L;
do {
IS >> p1 >> val;
Handle(BRep_PointRepresentation) PR;
switch (val) {
case 1 :
IS >> c;
if (myCurves.Curve(c).IsNull())
break;
Handle(BRep_PointOnCurve) POC =
new BRep_PointOnCurve(p1,
myCurves.Curve(c),
L);
PR = POC;
break;
case 2 :
IS >> pc >> s;
if (myCurves2d.Curve2d(pc).IsNull() ||
mySurfaces.Surface(s).IsNull())
break;
Handle(BRep_PointOnCurveOnSurface) POC =
new BRep_PointOnCurveOnSurface(p1,
myCurves2d.Curve2d(pc),
mySurfaces.Surface(s),
L);
PR = POC;
break;
case 3 :
IS >> p2 >> s;
if (mySurfaces.Surface(s).IsNull())
break;
Handle(BRep_PointOnSurface) POC =
new BRep_PointOnSurface(p1,p2,
L);
PR = POC;
break;
if (val > 0) {
IS >> l;
if (!PR.IsNull()) {
PR->Location(myLocations.Location(l));
lpr.Append(PR);
} while (val > 0);
break;
// edge
case TopAbs_EDGE :
// Create an edge
TopoDS_Edge& E = TopoDS::Edge(S);
myBuilder.MakeEdge(E);
// Read the curve geometry
IS >> tol;
IS >> val;
myBuilder.SameParameter(E,(val == 1));
IS >> val;
myBuilder.SameRange(E,(val == 1));
IS >> val;
myBuilder.Degenerated(E,(val == 1));
do {
IS >> val;
switch (val) {
case 1 : // -1- Curve 3D
IS >> c >> l;
if (!myCurves.Curve(c).IsNull()) {
myBuilder.UpdateEdge(E,myCurves.Curve(c),
myLocations.Location(l),tol);
IS >> first >> last;
Standard_Boolean Only3d = Standard_True;
myBuilder.Range(E,first,last,Only3d);
break;
case 2 : // -2- Curve on surf
case 3 : // -3- Curve on closed surf
closed = (val == 3);
IS >> pc;
if (closed) {
IS >> pc2;
reg = ReadRegularity(IS);
// surface, location
IS >> s >> l;
// range
// read UV Points // for XML Persistence higher performance
IS >> PfX >> PfY >> PlX >> PlY;
aPf = gp_Pnt2d(PfX,PfY);
aPl = gp_Pnt2d(PlX,PlY);
(closed && myCurves2d.Curve2d(pc2).IsNull()) ||
break;
if (closed) {
myBuilder.UpdateEdge(E,myCurves2d.Curve2d(pc),
myCurves2d.Curve2d(pc2),
myLocations.Location(l),tol,
aPf, aPl);
else
myBuilder.Continuity(E,
reg);
else
aPf, aPl);
else
myBuilder.Range(E,
first,last);
break;
case 4 : // -4- Regularity
IS >> s >> l >> s2 >> l2;
if (mySurfaces.Surface(s).IsNull() ||
mySurfaces.Surface(s2).IsNull())
break;
mySurfaces.Surface(s2),
myLocations.Location(l2),
reg);
break;
case 5 : // -5- Polygon3D
IS >> c >> l;
myBuilder.UpdateEdge(E,Handle(Poly_Polygon3D)::DownCast(myPolygons3D(c)), myLocations.Location(l));
break;
case 6 :
case 7 :
closed = (val == 7);
IS >> pt;
if (closed) {
IS >> pt2;
IS >> t >> l;
if (closed) {
(E, Handle(Poly_PolygonOnTriangulation)::DownCast(myNodes(pt)),
Handle(Poly_PolygonOnTriangulation)::DownCast(myNodes(pt2)),
Handle(Poly_Triangulation)::DownCast(myTriangulations(t)),
else {
(E,Handle(Poly_PolygonOnTriangulation)::DownCast(myNodes(pt)),
// range
break;
} while (val > 0);
break;
// wire
case TopAbs_WIRE :
myBuilder.MakeWire(TopoDS::Wire(S));
break;
// face
case TopAbs_FACE :
// create a face :
myBuilder.MakeFace(F);
IS >> val; // natural restriction
if (val == 0 || val == 1) {
IS >> tol >> s >> l;
if (!mySurfaces.Surface(s).IsNull()) {
myBuilder.UpdateFace(TopoDS::Face(S),
myBuilder.NaturalRestriction(TopoDS::Face(S),(val == 1));
// BUC60769
std::string line;
std::getline( IS, line );
std::istringstream str( line );
if (str.get() == '2') {
// cas triangulation
str >> s;
Handle(Poly_Triangulation)::DownCast(myTriangulations(s)));
// else IS.seekg(pos);
break;
// shell
case TopAbs_SHELL :
myBuilder.MakeShell(TopoDS::Shell(S));
break;
// solid
case TopAbs_SOLID :
myBuilder.MakeSolid(TopoDS::Solid(S));
break;
// compsolid
case TopAbs_COMPSOLID :
myBuilder.MakeCompSolid(TopoDS::CompSolid(S));
break;
// compound
case TopAbs_COMPOUND :
myBuilder.MakeCompound(TopoDS::Compound(S));
break;
default:
break;
| void OCCShapeAttributeSet::ReadPolygon3D | ( | Standard_IStream & | IS | ) |
Definition at line 1621 of file OCCShapeAttributeSet.cpp.
std::string buffer;
// Standard_Integer i, j, p, val, nbpol, nbnodes, hasparameters;
Standard_Integer i, j, p, nbpol=0, nbnodes =0, hasparameters = Standard_False; Standard_Real d, x, y, z;
IS >> buffer;
if (buffer.find("Polygon3D") == std::string::npos)
return;
Handle(Poly_Polygon3D) P;
IS >> nbpol;
for (i=1; i<=nbpol; i++) {
IS >> nbnodes;
IS >> hasparameters;
TColgp_Array1OfPnt Nodes(1, nbnodes);
IS >> d;
for (j = 1; j <= nbnodes; j++) {
IS >> x >> y >> z;
Nodes(j).SetCoord(x,y,z);
if (hasparameters) {
TColStd_Array1OfReal Param(1,nbnodes);
for (p = 1; p <= nbnodes; p++) {
IS >> Param(p);
P = new Poly_Polygon3D(Nodes, Param);
else P = new Poly_Polygon3D(Nodes);
P->Deflection(d);
myPolygons3D.Add(P);
| void OCCShapeAttributeSet::ReadPolygonOnTriangulation | ( | Standard_IStream & | IS | ) |
Definition at line 1578 of file OCCShapeAttributeSet.cpp.
std::string buffer;
IS >> buffer;
if (buffer.find("PolygonOnTriangulations") == std::string::npos)
return;
Standard_Integer i, j, val, nbpol = 0, nbnodes =0;
Standard_Integer hasparameters;
Standard_Real par;
Handle(TColStd_HArray1OfReal) Param;
Handle(Poly_PolygonOnTriangulation) Poly;
IS >> nbpol;
IS >> nbnodes;
TColStd_Array1OfInteger Nodes(1, nbnodes);
IS >> val;
Nodes(j) = val;
IS >> buffer;
Standard_Real def;
IS >> def;
TColStd_Array1OfReal Param1(1, nbnodes);
IS >> par;
Param1(j) = par;
Poly = new Poly_PolygonOnTriangulation(Nodes, Param1);
else Poly = new Poly_PolygonOnTriangulation(Nodes);
Poly->Deflection(def);
myNodes.Add(Poly);
| void OCCShapeAttributeSet::ReadTriangulation | ( | Standard_IStream & | IS | ) |
Definition at line 1660 of file OCCShapeAttributeSet.cpp.
std::string buffer;
// Standard_Integer i, j, val, nbtri;
Standard_Integer i, j, nbtri =0;
Standard_Integer nbNodes =0, nbTriangles=0;
Standard_Boolean hasUV= Standard_False;
Handle(Poly_Triangulation) T;
IS >> buffer;
if (buffer.find("Triangulations") != std::string::npos) {
IS >> nbtri;
for (i=1; i<=nbtri; i++) {
IS >> nbNodes >> nbTriangles >> hasUV;
IS >> d;
TColgp_Array1OfPnt Nodes(1, nbNodes);
TColgp_Array1OfPnt2d UVNodes(1, nbNodes);
for (j = 1; j <= nbNodes; j++) {
IS >> x >> y >> z;
if (hasUV) {
IS >> x >> y;
UVNodes(j).SetCoord(x,y);
// read the triangles
Standard_Integer n1,n2,n3;
Poly_Array1OfTriangle Triangles(1, nbTriangles);
for (j = 1; j <= nbTriangles; j++) {
IS >> n1 >> n2 >> n3;
Triangles(j).Set(n1,n2,n3);
if (hasUV) T = new Poly_Triangulation(Nodes,UVNodes,Triangles);
else T = new Poly_Triangulation(Nodes,Triangles);
T->Deflection(d);
myTriangulations.Add(T);
| void OCCShapeAttributeSet::Write | ( | Standard_OStream & | OS | ) |
Definition at line 620 of file OCCShapeAttributeSet.cpp.
//on sauvegarde l'ancien LC_NUMERIC
// on positionne LC_NUMERIC a "C" (point decimal)
setlocale(LC_NUMERIC, "C") ;
int prec = OS.precision(15);
// write the copyright
OS << "\n" << dVersion2 << endl;
else
OS << "\n" << dVersion << endl;
// write the locations
myLocations.Write(OS);
// write the geometry
WriteGeometry(OS);
// write the shapes
OS << "\nTShapes " << nbShapes << "\n";
// subshapes are written first
const TopoDS_Shape& S = myShapes(i);
// Type
PrintShapeEnum(S.ShapeType(),OS,Standard_True);
OS << "\n";
// Geometry
WriteGeometry(S,OS);
// Flags
OS << "\n";
OS << (S.Free() ? 1 : 0);
OS << (S.Modified() ? 1 : 0);
OS << (S.Checked() ? 1 : 0);
OS << (S.Orientable() ? 1 : 0);
OS << (S.Closed() ? 1 : 0);
OS << (S.Infinite() ? 1 : 0);
OS << (S.Convex() ? 1 : 0);
OS << "\n";
// sub-shapes
Standard_Integer l = 0;
TopoDS_Iterator its(S,Standard_False,Standard_False);
while (its.More()) {
Write(its.Value(),OS);
l++;
if (l == 10) {
OS << "\n";
l = 0;
its.Next();
Write(TopoDS_Shape(),OS); // Null shape to end the list
OS << "\n";
OS << endl;
OS.precision(prec);
// on remet le LC_NUMERIC a la precedente valeur
delete[] oldnum;
| void OCCShapeAttributeSet::Write | ( | const TopoDS_Shape & | S, |
| Standard_OStream & | OS, | ||
Writes on <OS> the shape <S>. Writes the
orientation, the index of the TShape and the index
of the Location.
Definition at line 1200 of file OCCShapeAttributeSet.cpp.
if (S.IsNull()) OS << "*";
else {
PrintOrientation(S.Orientation(),OS,Standard_True);
OS << myShapes.Extent() - myShapes.FindIndex(S.Located(TopLoc_Location())) + 1;
OS << " " << myLocations.Index(S.Location()) << " ";
//Write Attributes
if(l_attr != NULL)
const TopoDS_Shape& Sh = myShapes(i);
WriteAttribute(Sh, OS, *l_attr);
| void OCCShapeAttributeSet::WriteAttribute | ( | const TopoDS_Shape & | S, |
Writes the attributs of <S> on the stream <OS> in a
format that can be read back by Read.
Definition at line 495 of file OCCShapeAttributeSet.cpp.
if(l_attr.IsNull())
return;
Standard_Boolean found = Standard_False;
TDF_Label myLabel;
for (TDF_ChildIterator it1(l_attr,Standard_False); it1.More(); it1.Next())
//find the same shape attribute first
myLabel = it1.Value();
Handle_TDataXtd_Shape attr_shape;
TopoDS_Shape exsiting_shape;
if(TDataXtd_Shape::Find(myLabel, attr_shape))
exsiting_shape = attr_shape->Get(myLabel);
if(!exsiting_shape.IsNull())
if(exsiting_shape.IsPartner(S))
//It's possible that the myLabel found in this way wasn't the bounded
//lable with the shape. Find the bounded one now.
if(!OCCQueryEngine::instance()->OCCMap->IsBound(exsiting_shape))
continue;
int k = OCCQueryEngine::instance()->OCCMap->Find(exsiting_shape);
std::map<int, TDF_Label>::iterator it =
OCCQueryEngine::instance()->Shape_Label_Map->find(k);
if(it != OCCQueryEngine::instance()->Shape_Label_Map->end())
found = Standard_True;
myLabel = (*it).second;
break;
if(!found)
OS << "\n*";
return;
if(!myLabel.HasChild())
OS << "\n*";
return;
for (TDF_ChildIterator it2(myLabel,Standard_False); it2.More(); it2.Next())
TDF_Label child = it2.Value();
//Write out all attributes
Handle_TDataStd_Name attr_name;
TCollection_ExtendedString name_string;
if(child.FindAttribute(TDataStd_Name::GetID(), attr_name))
OS << "\n";
OS << "CGM_ATTRIB ";
name_string = attr_name->Get();
int length = name_string.Length();
OS << length << ' ';
name_string.Print(OS);
OS << ' ' ;
else
continue;
Handle_TDataStd_ExtStringArray attr_strings;
if(child.FindAttribute(TDataStd_ExtStringArray::GetID(), attr_strings))
Standard_Integer i = attr_strings->Lower();
TCollection_ExtendedString string;
int size = attr_strings->Upper();
OS << size -i + 1 << " ";
for(; i <= size; i++)
string = attr_strings->Value(i);
int length = string.Length();
string.Print(OS);
OS << ' ';
else
OS << "0 " ;
Handle_TDataStd_IntegerArray attr_ints;
if(child.FindAttribute(TDataStd_IntegerArray::GetID(), attr_ints))
Standard_Integer i = attr_ints->Lower();
int size = attr_ints->Upper();
OS << attr_ints->Value(i) << ' ';
else
OS << "0 " ;
Handle_TDataStd_RealArray attr_doubles;
if(child.FindAttribute(TDataStd_RealArray::GetID(), attr_doubles))
Standard_Integer i = attr_doubles->Lower();
Standard_Integer size = attr_doubles->Upper();
for(;i <= size; i++)
OS << attr_doubles->Value(i) << ' ';
else
OS << "0 " ;
OS << "\n*";
| void OCCShapeAttributeSet::WriteGeometry | ( | Standard_OStream & | OS | ) |
Writes the geometry of me on the stream <OS> in a
Definition at line 824 of file OCCShapeAttributeSet.cpp.
myCurves2d.Write(OS);
myCurves.Write(OS);
WritePolygon3D(OS);
WritePolygonOnTriangulation(OS);
mySurfaces.Write(OS);
WriteTriangulation(OS);
| void OCCShapeAttributeSet::WriteGeometry | ( | const TopoDS_Shape & | S, |
| Standard_OStream & | OS | ||
Writes the geometry of <S> on the stream <OS> in a
Definition at line 1059 of file OCCShapeAttributeSet.cpp.
// Write the geometry
// Write the point geometry
TopoDS_Vertex V = TopoDS::Vertex(S);
OS << BRep_Tool::Tolerance(V) << "\n";
gp_Pnt p = BRep_Tool::Pnt(V);
OS<<p.X()<<" "<<p.Y()<<" "<<p.Z()<<"\n";
OS << PR->Parameter();
OS << " 1 " << myCurves.Index(PR->Curve());
OS << " 2 " << myCurves2d.Index(PR->PCurve());
OS << " " << mySurfaces.Index(PR->Surface());
OS << " 3 " << PR->Parameter2() << " ";
OS << mySurfaces.Index(PR->Surface());
OS << " " << myLocations.Index(PR->Location());
OS << "\n";
itrp.Next();
OS << "0 0\n"; // end representations
// Write the curve geometry
OS << " " << TE->Tolerance() << " ";
OS << ((TE->SameParameter()) ? 1 : 0) << " ";
OS << ((TE->SameRange()) ? 1 : 0) << " ";
OS << ((TE->Degenerated()) ? 1 : 0) << "\n";
Standard_Real first, last;
BRep_ListIteratorOfListOfCurveRepresentation itrc = TE->Curves();
Handle(BRep_GCurve) GC = Handle(BRep_GCurve)::DownCast(itrc.Value());
GC->Range(first, last);
OS << "1 "; // -1- Curve 3D
OS << " "<<myCurves.Index(CR->Curve3D());
OS << " "<<myLocations.Index(CR->Location());
OS << " "<<first<<" "<<last;
OS << "\n";
if (!CR->IsCurveOnClosedSurface())
OS << "2 "; // -2- Curve on surf
else
OS << "3 "; // -3- Curve on closed surf
OS <<" "<<myCurves2d.Index(CR->PCurve());
if (CR->IsCurveOnClosedSurface()) {
OS <<" " << myCurves2d.Index(CR->PCurve2());
PrintRegularity(CR->Continuity(),OS);
OS << " " << mySurfaces.Index(CR->Surface());
OS << " " << myLocations.Index(CR->Location());
OS << "\n";
// Write UV Points // for XML Persistence higher performance
gp_Pnt2d Pf,Pl;
Handle(BRep_CurveOnClosedSurface) COCS =
Handle(BRep_CurveOnClosedSurface)::DownCast(CR);
COCS->UVPoints2(Pf,Pl);
else {
Handle(BRep_CurveOnSurface) COS =
Handle(BRep_CurveOnSurface)::DownCast(CR);
COS->UVPoints(Pf,Pl);
OS << Pf.X() << " " << Pf.Y() << " " << Pl.X() << " " << Pl.Y() << "\n";
OS << "4 "; // -4- Regularity
OS << " "<<mySurfaces.Index(CR->Surface());
OS << " "<<mySurfaces.Index(CR->Surface2());
OS << " "<<myLocations.Index(CR->Location2());
OS << "\n";
itrc.Next();
OS << "0\n"; // end of the list of representations
if (!(TF->Surface()).IsNull()) {
OS << ((BRep_Tool::NaturalRestriction(F)) ? 1 : 0);
OS << " ";
// Write the surface geometry
OS << " " <<TF->Tolerance();
OS << " " <<mySurfaces.Index(TF->Surface());
OS << " " <<myLocations.Index(TF->Location());
OS << "\n";
| void OCCShapeAttributeSet::WritePolygon3D | ( | Standard_OStream & | OS, |
| const Standard_Boolean | Compact = Standard_True |
Writes the 3d polygons
on the stream <OS> in a format that can
Definition at line 854 of file OCCShapeAttributeSet.cpp.
Standard_Integer i, j, nbpol = myPolygons3D.Extent();
if (Compact)
OS << "Polygon3D " << nbpol << endl;
else {
OS << " -------\n";
OS <<"Dump of " << nbpol << " Polygon3Ds\n";
OS << " -------\n";
for (i = 1; i <= nbpol; i++) {
P = Handle(Poly_Polygon3D)::DownCast(myPolygons3D(i));
if (Compact) {
OS << P->NbNodes() << " ";
OS << ((P->HasParameters()) ? "1" : "0") << "\n";
else {
OS << " "<< i << " : Polygon3D with " << P->NbNodes() << " Nodes\n";
OS << ((P->HasParameters()) ? "with" : "without") << " parameters\n";
// write the deflection
if (!Compact) OS << "Deflection : ";
OS << P->Deflection() << "\n";
// write the nodes
if (!Compact) OS << "\nNodes :\n";
Standard_Integer i1, nbNodes = P->NbNodes();
const TColgp_Array1OfPnt& Nodes = P->Nodes();
if (!Compact) OS << setw(10) << j << " : ";
if (!Compact) OS << setw(17);
OS << Nodes(j).X() << " ";
OS << Nodes(j).Y() << " ";
OS << Nodes(j).Z();
if (!Compact) OS << "\n";
else OS << " ";
OS <<"\n";
if (P->HasParameters()) {
if (!Compact) OS << "\nParameters :\n";
const TColStd_Array1OfReal& Param = P->Parameters();
for ( i1 = 1; i1 <= nbNodes; i1++ ) {
OS << Param(i1) << " ";
OS <<"\n";
| void OCCShapeAttributeSet::WritePolygonOnTriangulation | ( | Standard_OStream & | OS, |
Writes the polygons on triangulation
Definition at line 917 of file OCCShapeAttributeSet.cpp.
Standard_Integer i, j, nbpOntri = myNodes.Extent();
if (Compact)
OS << "PolygonOnTriangulations " << nbpOntri << endl;
else {
OS << " -------\n";
OS <<"Dump of " << nbpOntri << " PolygonOnTriangulations\n";
OS << " -------\n";
for (i=1; i<=nbpOntri; i++) {
Poly = Handle(Poly_PolygonOnTriangulation)::DownCast(myNodes(i));
const TColStd_Array1OfInteger& Nodes = Poly->Nodes();
if (!Compact) {
OS << " "<< i << " : PolygonOnTriangulation with " << Nodes.Length() << " Nodes\n";
else OS << Nodes.Length()<<" ";
if (!Compact) OS <<" ";
for (j=1; j <= Nodes.Length(); j++) OS << Nodes.Value(j) << " ";
OS << "\n";
// writing parameters:
Param = Poly->Parameters();
if (Compact) OS <<"p ";
if (!Compact) OS << " Deflection : ";
OS <<Poly->Deflection() << " ";
if (!Param.IsNull()) {
if (!Compact) {
OS << " "<< "Parameters :";
else OS << "1 " ;
for (j=1; j <= Param->Length(); j++) OS << Param->Value(j) << " ";
OS << "\n";
else OS <<"0 \n";
| void OCCShapeAttributeSet::WriteTriangulation | ( | Standard_OStream & | OS, |
Writes the triangulation
Definition at line 972 of file OCCShapeAttributeSet.cpp.
Standard_Integer i, j, nbNodes, nbtri = myTriangulations.Extent();
Standard_Integer nbTriangles = 0, n1, n2, n3;
if (Compact)
OS << "Triangulations " << nbtri << endl;
else {
OS << " -------\n";
OS <<"Dump of " << nbtri << " Triangulations\n";
OS << " -------\n";
for (i = 1; i <= nbtri; i++) {
T = Handle(Poly_Triangulation)::DownCast(myTriangulations(i));
if (Compact) {
OS << T->NbNodes() << " " << T->NbTriangles() << " ";
OS << ((T->HasUVNodes()) ? "1" : "0") << " ";
else {
OS << " "<< i << " : Triangulation with " << T->NbNodes() << " Nodes and "
<< T->NbTriangles() <<" Triangles\n";
OS << " "<<((T->HasUVNodes()) ? "with" : "without") << " UV nodes\n";
OS <<T->Deflection() << "\n";
// write the 3d nodes
if (!Compact) OS << "\n3D Nodes :\n";
nbNodes = T->NbNodes();
const TColgp_Array1OfPnt& Nodes = T->Nodes();
OS << Nodes(j).Z();
else OS << " ";
if (T->HasUVNodes()) {
if (!Compact) OS << "\nUV Nodes :\n";
const TColgp_Array1OfPnt2d& UVNodes = T->UVNodes();
OS << UVNodes(j).X() << " ";
OS << UVNodes(j).Y();
else OS << " ";
if (!Compact) OS << "\nTriangles :\n";
nbTriangles = T->NbTriangles();
const Poly_Array1OfTriangle& Triangles = T->Triangles();
Triangles(j).Get(n1, n2, n3);
if (!Compact) OS << setw(10);
OS << n1 << " ";
OS << n2 << " ";
OS << n3;
else OS << " ";
OS << "\n";
std::map<int,int> OCCShapeAttributeSet::my_ShapeNum_Location [private] |
Definition at line 166 of file OCCShapeAttributeSet.hpp.
BRep_Builder OCCShapeAttributeSet::myBuilder [private] |
Definition at line 164 of file OCCShapeAttributeSet.hpp.
GeomTools_CurveSet OCCShapeAttributeSet::myCurves [private] |
Definition at line 170 of file OCCShapeAttributeSet.hpp.
GeomTools_Curve2dSet OCCShapeAttributeSet::myCurves2d [private] |
Definition at line 171 of file OCCShapeAttributeSet.hpp.
Standard_Integer OCCShapeAttributeSet::myFormatNb [private] |
Definition at line 168 of file OCCShapeAttributeSet.hpp.
TopTools_LocationSet OCCShapeAttributeSet::myLocations [private] |
Definition at line 167 of file OCCShapeAttributeSet.hpp.
TColStd_IndexedMapOfTransient OCCShapeAttributeSet::myNodes [private] |
Definition at line 175 of file OCCShapeAttributeSet.hpp.
TColStd_IndexedMapOfTransient OCCShapeAttributeSet::myPolygons2D [private] |
Definition at line 172 of file OCCShapeAttributeSet.hpp.
TColStd_IndexedMapOfTransient OCCShapeAttributeSet::myPolygons3D [private] |
Definition at line 173 of file OCCShapeAttributeSet.hpp.
TopTools_IndexedMapOfShape OCCShapeAttributeSet::myShapes [private] |
Definition at line 165 of file OCCShapeAttributeSet.hpp.
GeomTools_SurfaceSet OCCShapeAttributeSet::mySurfaces [private] |
Definition at line 169 of file OCCShapeAttributeSet.hpp.
TColStd_IndexedMapOfTransient OCCShapeAttributeSet::myTriangulations [private] |
Definition at line 174 of file OCCShapeAttributeSet.hpp.
