cgma
provides functionality from cgm engines residing in dynamically loadable libraries More...
#include <CGMEngineDynamicLoader.hpp>
Public Member Functions | |
| CGMEngineDynamicLoader (const CubitString &engine_name) | |
| create an instance of this engine loader with an engine name | |
| virtual | ~CGMEngineDynamicLoader () |
| delete this and unload the library if it is loaded | |
| CubitString | get_engine_name () |
| get the name of this engine | |
| void | set_library_base_name (const CubitString &libname) |
| CubitString | get_library_base_name () |
| CubitBoolean | engine_exists () |
| check to see if the engine exists | |
| CubitStatus | load_engine () |
| load the engine, returns success or failure | |
| CubitStatus | unload_engine () |
| unload the engine, returns success or failure | |
| GeometryQueryEngine * | get_gqe () |
| GeometryModifyEngine * | get_gme () |
Protected Member Functions | |
| CubitBoolean | check_engine_version () |
Protected Attributes | |
| const CubitString | mEngineName |
| CubitString | mEngineLibrary |
| CubitDynamicLoader::LibraryHandle | mLibraryHandle |
| CubitBoolean | mLoadAttempted |
| GeometryQueryEngine * | mQueryEngine |
| GeometryModifyEngine * | mModifyEngine |
Definition at line 14 of file CGMEngineDynamicLoader.hpp.
| CGMEngineDynamicLoader::CGMEngineDynamicLoader | ( | const CubitString & | engine_name | ) |
Definition at line 16 of file CGMEngineDynamicLoader.cpp.
: mEngineName(engine_name), mEngineLibrary(CubitString("CGM") + engine_name), mLibraryHandle(CubitDynamicLoader::InvalidLibraryHandle), mLoadAttempted(CUBIT_FALSE), mQueryEngine(NULL), mModifyEngine(NULL) { }
| CGMEngineDynamicLoader::~CGMEngineDynamicLoader | ( | ) | [virtual] |
Definition at line 27 of file CGMEngineDynamicLoader.cpp.
if(mLibraryHandle != CubitDynamicLoader::InvalidLibraryHandle)
unload_engine();
| CubitBoolean CGMEngineDynamicLoader::check_engine_version | ( | ) | [protected] |
Definition at line 143 of file CGMEngineDynamicLoader.cpp.
// library was already loaded, so just look up the version function
CubitString symbol = CubitString("dynamic_") + mEngineName + CubitString("_get_cgm_version");
// Note: this is a nasty hack to avoid the warning:
// ISO C++ forbids casting between pointer-to-function and pointer-to-object
// Even with reinterpret_cast, this warning is still generated
// GCC accepts reinterpret_cast for purposes like in dlsym calls as an extension,
// but that might not work for other compilers
// This union-trick has been applied to some open source code, like:
// https://mail.gnome.org/archives/commits-list/2011-February/msg06409.html
// http://sourceforge.net/p/scstudio/mailman/message/29083334/
union {
void* ptr;
FpVersion func;
} cast_u;
cast_u.ptr = CubitDynamicLoader::get_symbol_address(mLibraryHandle, symbol.c_str());
FpVersion fp_version = cast_u.func;
if(!fp_version)
PRINT_ERROR("Failed to load CGM %s engine : Can't find version\n", mEngineName.c_str());
return CUBIT_FALSE;
// TODO -- use real versioning system
if(strcmp((*fp_version)(), "1.0") != 0)
PRINT_ERROR("Failed to load CGM %s engine : wrong version number\n", mEngineName.c_str());
return CUBIT_FALSE;
return TRUE;
Definition at line 54 of file CGMEngineDynamicLoader.cpp.
return CUBIT_TRUE;
// try for a debug version with _d on it first.
#if defined(_WIN32) && defined(_DEBUG)
CubitString debug_libname = CubitDynamicLoader::library_prefix() +
mEngineLibrary +
CubitString("_d") +
CubitDynamicLoader::library_extension();
if(CubitDynamicLoader::library_exists(debug_libname.c_str()))
return CUBIT_TRUE;
#endif
CubitString libname = CubitDynamicLoader::library_prefix() +
mEngineLibrary +
if(CubitDynamicLoader::library_exists(libname.c_str()))
return CUBIT_TRUE;
return CUBIT_FALSE;
Definition at line 35 of file CGMEngineDynamicLoader.cpp.
return mEngineName;
get the GeometryModifyEngine instance from the engine calls load_engine if it hasn't been called yet returns NULL if library failed to load, or an engine couldn't be made
Definition at line 229 of file CGMEngineDynamicLoader.cpp.
if(mModifyEngine)
return mModifyEngine;
if(mLoadAttempted == CUBIT_FALSE)
load_engine();
if(mLibraryHandle == CubitDynamicLoader::InvalidLibraryHandle)
PRINT_ERROR("Failed to load CGM %s engine\n", mEngineName.c_str());
return NULL;
// check for incompatible CGM version
if(check_engine_version() == CUBIT_FALSE)
return NULL;
CubitString symbol = CubitString("dynamic_") + mEngineName + CubitString("_create_gme");
union {
void* ptr;
CGMEngineCreateModifyEngine func;
} cast_u;
CGMEngineCreateModifyEngine create_modify_engine = cast_u.func;
if(!create_modify_engine)
PRINT_ERROR("Failed to get %s modify engine\n", mEngineName.c_str());
return NULL;
mModifyEngine = (*create_modify_engine)();
get the GeometryQueryEngine instance from the engine calls load_engine if it hasn't been called yet returns NULL if library failed to load, or an engine couldn't be made
Definition at line 181 of file CGMEngineDynamicLoader.cpp.
if(mQueryEngine)
return mQueryEngine;
load_engine();
return NULL;
return NULL;
CubitString symbol = CubitString("dynamic_") + mEngineName + CubitString("_create_gqe");
union {
void* ptr;
CGMEngineCreateQueryEngine func;
} cast_u;
CGMEngineCreateQueryEngine create_query_engine = cast_u.func;
if(!create_query_engine)
PRINT_ERROR("Failed to get %s query engine\n", mEngineName.c_str());
return NULL;
mQueryEngine = (*create_query_engine)();
Definition at line 40 of file CGMEngineDynamicLoader.cpp.
return mEngineLibrary;
Definition at line 78 of file CGMEngineDynamicLoader.cpp.
mEngineLibrary +
CubitString("_d") +
mLibraryHandle = CubitDynamicLoader::load_library(debug_libname.c_str());
#endif
mEngineLibrary +
mLibraryHandle = CubitDynamicLoader::load_library(libname.c_str());
mLoadAttempted = CUBIT_TRUE;
CubitString error = CubitDynamicLoader::get_error();
if(error != CubitString())
PRINT_ERROR("%s\n", error.c_str());
return CUBIT_FAILURE;
return CUBIT_SUCCESS;
| void CGMEngineDynamicLoader::set_library_base_name | ( | const CubitString & | libname | ) |
can set library name for the engine if it is different than the engine name
Definition at line 45 of file CGMEngineDynamicLoader.cpp.
mEngineLibrary = libname;
mLoadAttempted = CUBIT_FALSE;
Definition at line 114 of file CGMEngineDynamicLoader.cpp.
//don't unload cubitcatia.dll
#ifdef CATIA
if( mEngineName == "CATIA")
#endif
CubitDynamicLoader::unload_library(mLibraryHandle);
mLibraryHandle = CubitDynamicLoader::InvalidLibraryHandle;
mQueryEngine = NULL;
mModifyEngine = NULL;
CubitString CGMEngineDynamicLoader::mEngineLibrary [protected] |
Definition at line 54 of file CGMEngineDynamicLoader.hpp.
const CubitString CGMEngineDynamicLoader::mEngineName [protected] |
Definition at line 51 of file CGMEngineDynamicLoader.hpp.
Definition at line 57 of file CGMEngineDynamicLoader.hpp.
CubitBoolean CGMEngineDynamicLoader::mLoadAttempted [protected] |
Definition at line 60 of file CGMEngineDynamicLoader.hpp.
Definition at line 67 of file CGMEngineDynamicLoader.hpp.
GeometryQueryEngine* CGMEngineDynamicLoader::mQueryEngine [protected] |
Definition at line 66 of file CGMEngineDynamicLoader.hpp.
