cgma
#include <GeometryQueryEngine.hpp>
Public Member Functions | |
| virtual | ~GeometryQueryEngine () |
| virtual CubitStatus | export_solid_model (DLIList< TopologyBridge * > &bridge_list, const char *file_name, Model_File_Type file_type, const CubitString &cubit_version, ModelExportOptions &export_options)=0 |
| virtual CubitStatus | export_solid_model (DLIList< TopologyBridge * > &bridge_list, char *&p_buffer, int &n_buffer_size, bool b_export_buffer)=0 |
| virtual CubitStatus | save_temp_geom_file (DLIList< TopologyBridge * > &ref_entity_list, const char *filename, const CubitString &cubit_version, CubitString &created_file, CubitString &created_file_type)=0 |
| virtual CubitStatus | import_solid_model (const char *file_name, Model_File_Type file_type, DLIList< TopologyBridge * > &imported_entities, ModelImportOptions &import_options)=0 |
| virtual CubitStatus | import_solid_model (DLIList< TopologyBridge * > &imported_entities, const char *pBuffer, const int n_buffer_size)=0 |
| virtual CubitStatus | get_underlying_curves (Curve *curve_ptr, DLIList< TopologyBridge * > &curve_list) |
| virtual CubitStatus | get_underlying_surfaces (Surface *surf_ptr, DLIList< TopologyBridge * > &surf_list) |
| virtual CubitStatus | get_underlying_bridges (TopologyBridge *bridge_ptr, DLIList< TopologyBridge * > &bridge_list) |
| virtual CubitStatus | get_intersections (Curve *ref_edge1, CubitVector &point1, CubitVector &point2, DLIList< CubitVector > &intersection_list, bool bounded=false, bool closest=false)=0 |
| virtual CubitStatus | get_intersections (Curve *ref_edge1, Curve *ref_edge2, DLIList< CubitVector > &intersection_list, bool bounded=false, bool closest=false)=0 |
| virtual CubitStatus | get_intersections (Curve *curve, Surface *surface, DLIList< CubitVector > &intersection_list, bool bounded=false)=0 |
| virtual CubitStatus | entity_extrema (DLIList< GeometryEntity * > &ref_entity_list, const CubitVector *dir1, const CubitVector *dir2, const CubitVector *dir3, CubitVector &extrema, GeometryEntity *&extrema_entity_ptr)=0 |
| virtual CubitStatus | entity_entity_distance (GeometryEntity *ref_entity_ptr1, GeometryEntity *ref_entity_ptr2, CubitVector &pos1, CubitVector &pos2, double &distance)=0 |
| virtual void | validate_geometry_database () const |
| virtual void | delete_solid_model_entities (DLIList< BodySM * > &body_list) const =0 |
| virtual CubitStatus | delete_solid_model_entities (GeometryEntity *ref_entity_ptr) const |
| virtual CubitStatus | delete_solid_model_entities (BodySM *body_ptr) const =0 |
| virtual CubitStatus | delete_solid_model_entities (Surface *surf_ptr) const =0 |
| virtual CubitStatus | delete_solid_model_entities (Curve *curve_ptr) const =0 |
| virtual CubitStatus | delete_solid_model_entities (TBPoint *point_ptr) const =0 |
| virtual CubitStatus | delete_topology_bridge (TopologyBridge *bridge) const |
| virtual CubitStatus | fire_ray (CubitVector &origin, CubitVector &direction, DLIList< TopologyBridge * > &at_entity_list, DLIList< double > &ray_params, int max_hits=0, double ray_radius=0.0, DLIList< TopologyBridge * > *hit_entity_list=0) const =0 |
| virtual void | get_ordered_loops (RefFace *, DLIList< Loop * > &) const |
| virtual CubitStatus | get_isoparametric_points (Surface *ref_face_ptr, int &nu, int &nv, GMem *&gMem) const =0 |
| virtual CubitStatus | get_u_isoparametric_points (Surface *ref_face_ptr, double v, int &n, GMem *&gMem) const =0 |
| virtual CubitStatus | get_v_isoparametric_points (Surface *ref_face_ptr, double u, int &n, GMem *&gMem) const =0 |
| virtual CubitStatus | transform_vec_position (CubitVector const &position_vector, BodySM *OSME_ptr, CubitVector &transform_vector) const =0 |
| virtual int | curve_is_on_ignored_surface (Curve *, Surface *) |
| virtual const char * | modeler_type ()=0 |
| virtual int | get_major_version ()=0 |
| virtual int | get_minor_version ()=0 |
| virtual int | get_subminor_version ()=0 |
| virtual int | get_allint_version () |
| virtual CubitString | get_engine_version_string ()=0 |
| virtual bool | is_intermediate_engine () |
| virtual CubitStatus | set_export_version (const int major, const int minor) |
| virtual CubitStatus | set_export_allint_version (const int version) |
| virtual CubitStatus | list_engine_versions (CubitString &versions) |
| virtual double | get_sme_resabs_tolerance () const =0 |
| virtual double | set_sme_resabs_tolerance (double new_resabs)=0 |
| virtual CubitStatus | set_int_option (const char *opt_name, int val)=0 |
| virtual CubitStatus | set_dbl_option (const char *opt_name, double val)=0 |
| virtual CubitStatus | set_str_option (const char *opt_name, const char *val)=0 |
| virtual CubitStatus | get_graphics (BodySM *bodysm, GMem *g_mem, std::vector< Surface * > &surface_to_facets_vector, std::vector< TopologyBridge * > &vertex_edge_to_point_vector, std::vector< std::pair< TopologyBridge *, std::pair< int, int > > > &facet_edges_on_curves, unsigned short normal_tolerance, double distance_tolerance, double max_edge_length) const |
| virtual CubitStatus | get_graphics (Surface *surface_ptr, GMem *gMem, unsigned short normal_tolerance=15, double distance_tolerance=0, double longest_edge=0) const =0 |
| virtual CubitStatus | get_graphics (Surface *surface_ptr, GMem *gmem, std::vector< TopologyBridge * > &vertex_edge_to_point_vector, std::vector< std::pair< TopologyBridge *, std::pair< int, int > > > &facet_edges_on_curves, unsigned short normal_tolerance=15, double distance_tolerance=0.0, double max_edge_length=0.0) const |
| virtual CubitStatus | get_graphics (Curve *curve_ptr, GMem *gMem, double angle_tolerance=0, double distance_tolerance=0, double max_edge_length=0) const =0 |
| virtual CubitStatus | translate (BodySM *body, const CubitVector &offset)=0 |
| virtual CubitStatus | rotate (BodySM *body, const CubitVector &axis, double angle)=0 |
| virtual CubitStatus | scale (BodySM *body, double factor)=0 |
| virtual CubitStatus | scale (BodySM *body, const CubitVector &factors)=0 |
| virtual CubitStatus | reflect (BodySM *body, const CubitVector &axis)=0 |
| virtual CubitStatus | restore_transform (BodySM *body)=0 |
| virtual CubitStatus | translate (GeometryEntity *ent, const CubitVector &offset)=0 |
| virtual CubitStatus | rotate (GeometryEntity *ent, const CubitVector &axis, double degrees)=0 |
| virtual CubitStatus | scale (GeometryEntity *ent, double factor)=0 |
| virtual CubitStatus | scale (GeometryEntity *ent, const CubitVector &factors)=0 |
| virtual CubitStatus | reflect (GeometryEntity *ent, const CubitVector &axis)=0 |
| virtual CubitBoolean | bodies_overlap (BodySM *body_ptr_1, BodySM *body_ptr_2) const =0 |
| virtual CubitBoolean | volumes_overlap (Lump *lump1, Lump *lump2) const =0 |
| virtual TopologyBridge * | get_visible_entity_at_point (TopologyBridge *, CubitVector *) |
| virtual CubitStatus | get_visible_entities (TopologyBridge *hidden_tb, DLIList< TopologyBridge * > &real_tbs) |
| virtual CubitStatus | get_point_containment (DLIList< BodySM * > &body_list, DLIList< CubitVector > &point_list, double tolerance, bool allow_pts_in_multiple_bodies, std::vector< std::pair< BodySM *, std::vector< int > > > &bodysm_to_pt_indices) |
Definition at line 135 of file GeometryQueryEngine.hpp.
| virtual GeometryQueryEngine::~GeometryQueryEngine | ( | ) | [inline, virtual] |
| virtual CubitBoolean GeometryQueryEngine::bodies_overlap | ( | BodySM * | body_ptr_1, |
| BodySM * | body_ptr_2 | ||
| ) | const [pure virtual] |
Implemented in FacetQueryEngine, OCCQueryEngine, and VirtualQueryEngine.
| virtual int GeometryQueryEngine::curve_is_on_ignored_surface | ( | Curve * | , |
| Surface * | |||
Reimplemented in VirtualQueryEngine.
Definition at line 339 of file GeometryQueryEngine.hpp.
{ return 0; }
| virtual void GeometryQueryEngine::delete_solid_model_entities | ( | DLIList< BodySM * > & | body_list | ) | const [pure virtual] |
Implemented in VirtualQueryEngine, OCCQueryEngine, and FacetQueryEngine.
| CubitStatus GeometryQueryEngine::delete_solid_model_entities | ( | GeometryEntity * | ref_entity_ptr | ) | const [virtual] |
Definition at line 74 of file GeometryQueryEngine.cpp.
return CUBIT_FAILURE;
| virtual CubitStatus GeometryQueryEngine::delete_solid_model_entities | ( | BodySM * | body_ptr | ) | const [pure virtual] |
| virtual CubitStatus GeometryQueryEngine::delete_solid_model_entities | ( | Surface * | surf_ptr | ) | const [pure virtual] |
| virtual CubitStatus GeometryQueryEngine::delete_solid_model_entities | ( | Curve * | curve_ptr | ) | const [pure virtual] |
| virtual CubitStatus GeometryQueryEngine::delete_solid_model_entities | ( | TBPoint * | point_ptr | ) | const [pure virtual] |
| CubitStatus GeometryQueryEngine::delete_topology_bridge | ( | TopologyBridge * | bridge | ) | const [virtual] |
Definition at line 79 of file GeometryQueryEngine.cpp.
// first, try the geometry entity
GeometryEntity* ent = dynamic_cast<GeometryEntity*> (bridge);
if (ent)
return delete_solid_model_entities(ent);
// now, try to cast to a BodySM and call that routine
BodySM* body = dynamic_cast<BodySM*> (bridge);
if (body)
delete_solid_model_entities(body);
return CUBIT_SUCCESS;
PRINT_ERROR("GeometryQueryEngine::delete_solid_model_entities(TopologyBridge* bridge): no deletion...\n");
| virtual CubitStatus GeometryQueryEngine::entity_entity_distance | ( | GeometryEntity * | ref_entity_ptr1, |
| GeometryEntity * | ref_entity_ptr2, | ||
| CubitVector & | pos1, | ||
| CubitVector & | pos2, | ||
| double & | distance | ||
| ) | [pure virtual] |
| virtual CubitStatus GeometryQueryEngine::entity_extrema | ( | DLIList< GeometryEntity * > & | ref_entity_list, |
| const CubitVector * | dir1, | ||
| const CubitVector * | dir2, | ||
| const CubitVector * | dir3, | ||
| CubitVector & | extrema, | ||
| GeometryEntity *& | extrema_entity_ptr | ||
| virtual CubitStatus GeometryQueryEngine::export_solid_model | ( | DLIList< TopologyBridge * > & | bridge_list, |
| const char * | file_name, | ||
| Model_File_Type | file_type, | ||
| const CubitString & | cubit_version, | ||
| ModelExportOptions & | export_options | ||
R CubitStatus R- CUBIT_SUCCESS/CUBIT_FAILURE I ref_entity_list I- A list of RefEntities to be exported or saved to a file. I file_name I- The name of the file to write to. I file_type I- An optional type of file.
| char *& | p_buffer, | ||
| int & | n_buffer_size, | ||
| bool | b_export_buffer | ||
| virtual CubitStatus GeometryQueryEngine::fire_ray | ( | CubitVector & | origin, |
| CubitVector & | direction, | ||
| DLIList< TopologyBridge * > & | at_entity_list, | ||
| DLIList< double > & | ray_params, | ||
| int | max_hits = 0, |
| double | ray_radius = 0.0, |
| DLIList< TopologyBridge * > * | hit_entity_list = 0 |
Implemented in VirtualQueryEngine, FacetQueryEngine, and OCCQueryEngine.
| int GeometryQueryEngine::get_allint_version | ( | ) | [virtual] |
Definition at line 20 of file GeometryQueryEngine.cpp.
return 100*get_major_version() + get_minor_version();
| virtual CubitString GeometryQueryEngine::get_engine_version_string | ( | ) | [pure virtual] |
Implemented in OCCQueryEngine, FacetQueryEngine, and VirtualQueryEngine.
| CubitStatus GeometryQueryEngine::get_graphics | ( | BodySM * | bodysm, |
| GMem * | g_mem, | ||
| std::vector< Surface * > & | surface_to_facets_vector, | ||
| std::vector< TopologyBridge * > & | vertex_edge_to_point_vector, | ||
| std::vector< std::pair< TopologyBridge *, std::pair< int, int > > > & | facet_edges_on_curves, | ||
| unsigned short | normal_tolerance, | ||
| double | distance_tolerance, | ||
| double | max_edge_length | ||
Reimplemented in FacetQueryEngine.
Definition at line 47 of file GeometryQueryEngine.cpp.
| virtual CubitStatus GeometryQueryEngine::get_graphics | ( | Surface * | surface_ptr, |
| GMem * | gMem, | ||
| unsigned short | normal_tolerance = 15, |
| double | distance_tolerance = 0, |
| double | longest_edge = 0 |
| GMem * | gmem, | ||
| double | distance_tolerance = 0.0, |
| double | max_edge_length = 0.0 |
Definition at line 57 of file GeometryQueryEngine.cpp.
| virtual CubitStatus GeometryQueryEngine::get_graphics | ( | Curve * | curve_ptr, |
| GMem * | gMem, | ||
| double | angle_tolerance = 0, |
| double | max_edge_length = 0 |
| virtual CubitStatus GeometryQueryEngine::get_intersections | ( | Curve * | ref_edge1, |
| CubitVector & | point1, | ||
| CubitVector & | point2, | ||
| DLIList< CubitVector > & | intersection_list, | ||
| bool | bounded = false, |
| bool | closest = false |
| Curve * | ref_edge2, | ||
Implemented in VirtualQueryEngine.
| virtual CubitStatus GeometryQueryEngine::get_intersections | ( | Curve * | curve, |
| Surface * | surface, | ||
| bool | bounded = false |
| virtual CubitStatus GeometryQueryEngine::get_isoparametric_points | ( | Surface * | ref_face_ptr, |
| int & | nu, | ||
| int & | nv, | ||
| GMem *& | gMem | ||
| virtual int GeometryQueryEngine::get_major_version | ( | ) | [pure virtual] |
| virtual int GeometryQueryEngine::get_minor_version | ( | ) | [pure virtual] |
| virtual void GeometryQueryEngine::get_ordered_loops | ( | RefFace * | , |
| DLIList< Loop * > & | |||
| ) | const [inline, virtual] |
Definition at line 315 of file GeometryQueryEngine.hpp.
| CubitStatus GeometryQueryEngine::get_point_containment | ( | DLIList< BodySM * > & | body_list, |
| DLIList< CubitVector > & | point_list, | ||
| double | tolerance, | ||
| bool | allow_pts_in_multiple_bodies, | ||
| std::vector< std::pair< BodySM *, std::vector< int > > > & | bodysm_to_pt_indices | ||
| ) | [virtual] |
Definition at line 103 of file GeometryQueryEngine.cpp.
| virtual double GeometryQueryEngine::get_sme_resabs_tolerance | ( | ) | const [pure virtual] |
| virtual int GeometryQueryEngine::get_subminor_version | ( | ) | [pure virtual] |
| virtual CubitStatus GeometryQueryEngine::get_u_isoparametric_points | ( | Surface * | ref_face_ptr, |
| double | v, | ||
| int & | n, | ||
| GMem *& | gMem | ||
| CubitStatus GeometryQueryEngine::get_underlying_bridges | ( | TopologyBridge * | bridge_ptr, |
| DLIList< TopologyBridge * > & | bridge_list | ||
| ) | [virtual] |
Definition at line 42 of file GeometryQueryEngine.cpp.
{ return CUBIT_SUCCESS; }
| CubitStatus GeometryQueryEngine::get_underlying_curves | ( | Curve * | curve_ptr, |
| DLIList< TopologyBridge * > & | curve_list | ||
| ) | [virtual] |
Definition at line 34 of file GeometryQueryEngine.cpp.
| CubitStatus GeometryQueryEngine::get_underlying_surfaces | ( | Surface * | surf_ptr, |
| DLIList< TopologyBridge * > & | surf_list | ||
| ) | [virtual] |
Definition at line 38 of file GeometryQueryEngine.cpp.
| virtual CubitStatus GeometryQueryEngine::get_v_isoparametric_points | ( | Surface * | ref_face_ptr, |
| double | u, | ||
| int & | n, | ||
| GMem *& | gMem | ||
| CubitStatus GeometryQueryEngine::get_visible_entities | ( | TopologyBridge * | hidden_tb, |
| DLIList< TopologyBridge * > & | real_tbs | ||
| ) | [virtual] |
Definition at line 68 of file GeometryQueryEngine.cpp.
| virtual TopologyBridge* GeometryQueryEngine::get_visible_entity_at_point | ( | TopologyBridge * | , |
| CubitVector * | |||
Definition at line 445 of file GeometryQueryEngine.hpp.
{return NULL;};
| virtual CubitStatus GeometryQueryEngine::import_solid_model | ( | const char * | file_name, |
| DLIList< TopologyBridge * > & | imported_entities, | ||
| ModelImportOptions & | import_options | ||
R CubitStatus R- CUBIT_SUCCESS/CUBIT_FAILURE I file_ptr I- A pointer to the file to read (can be NULL for IGES and STEP files). I file_type I- Type of file.
| virtual CubitStatus GeometryQueryEngine::import_solid_model | ( | DLIList< TopologyBridge * > & | imported_entities, |
| const char * | pBuffer, | ||
| const int | n_buffer_size | ||
| virtual bool GeometryQueryEngine::is_intermediate_engine | ( | ) | [inline, virtual] |
Definition at line 349 of file GeometryQueryEngine.hpp.
{return FALSE;}
| CubitStatus GeometryQueryEngine::list_engine_versions | ( | CubitString & | versions | ) | [virtual] |
Definition at line 25 of file GeometryQueryEngine.cpp.
versions = "(none specified)";
| virtual const char* GeometryQueryEngine::modeler_type | ( | ) | [pure virtual] |
| virtual CubitStatus GeometryQueryEngine::reflect | ( | BodySM * | body, |
| const CubitVector & | axis | ||
| virtual CubitStatus GeometryQueryEngine::reflect | ( | GeometryEntity * | ent, |
| virtual CubitStatus GeometryQueryEngine::restore_transform | ( | BodySM * | body | ) | [pure virtual] |
Implemented in FacetQueryEngine, VirtualQueryEngine, and OCCQueryEngine.
| virtual CubitStatus GeometryQueryEngine::rotate | ( | BodySM * | body, |
| const CubitVector & | axis, | ||
| double | angle | ||
| virtual CubitStatus GeometryQueryEngine::rotate | ( | GeometryEntity * | ent, |
| double | degrees | ||
| virtual CubitStatus GeometryQueryEngine::save_temp_geom_file | ( | DLIList< TopologyBridge * > & | ref_entity_list, |
| const char * | filename, | ||
| CubitString & | created_file, | ||
| CubitString & | created_file_type | ||
Saves out a temporary geometry file. Entities in list must all be of same modeling engine.
| virtual CubitStatus GeometryQueryEngine::scale | ( | BodySM * | body, |
| double | factor | ||
| const CubitVector & | factors | ||
| virtual CubitStatus GeometryQueryEngine::scale | ( | GeometryEntity * | ent, |
| virtual CubitStatus GeometryQueryEngine::set_dbl_option | ( | const char * | opt_name, |
| double | val | ||
| CubitStatus GeometryQueryEngine::set_export_allint_version | ( | const int | version | ) | [virtual] |
Definition at line 15 of file GeometryQueryEngine.cpp.
| CubitStatus GeometryQueryEngine::set_export_version | ( | const int | major, |
| const int | minor | ||
| ) | [virtual] |
Definition at line 9 of file GeometryQueryEngine.cpp.
| virtual CubitStatus GeometryQueryEngine::set_int_option | ( | const char * | opt_name, |
| int | val | ||
| virtual double GeometryQueryEngine::set_sme_resabs_tolerance | ( | double | new_resabs | ) | [pure virtual] |
| virtual CubitStatus GeometryQueryEngine::set_str_option | ( | const char * | opt_name, |
| const char * | val | ||
| virtual CubitStatus GeometryQueryEngine::transform_vec_position | ( | CubitVector const & | position_vector, |
| BodySM * | OSME_ptr, | ||
| CubitVector & | transform_vector | ||
| virtual CubitStatus GeometryQueryEngine::translate | ( | BodySM * | body, |
| const CubitVector & | offset | ||
| virtual CubitStatus GeometryQueryEngine::translate | ( | GeometryEntity * | ent, |
| virtual void GeometryQueryEngine::validate_geometry_database | ( | ) | const [inline, virtual] |
Definition at line 286 of file GeometryQueryEngine.hpp.
| virtual CubitBoolean GeometryQueryEngine::volumes_overlap | ( | Lump * | lump1, |
| Lump * | lump2 | ||
