cgma
#include <PartitionEntity.hpp>
Public Member Functions | |
| virtual | ~PartitionEntity () |
| TopologyBridge * | partitioned_entity () const |
| SubEntitySet & | sub_entity_set () const |
| virtual CubitStatus | move_to_geometry (CubitVector &position) |
| CubitStatus | relax_to_geometry (CubitPoint *facet_point, const CubitVector *input_position=0) |
| virtual void | print_debug_info (const char *prefix=0, bool print_subentity_set=true) const |
| void | print_partitioned_entity (const char *prefix=0) const |
| virtual void | transform (const CubitTransformMatrix &xform)=0 |
| virtual void | reverse_sense ()=0 |
| virtual void | notify_split (FacetEntity *old_entity, FacetEntity *new_entity)=0 |
| virtual CubitStatus | save (CubitSimpleAttrib &attrib)=0 |
| virtual CubitBox | bounding_box () const =0 |
Public Attributes | |
| int | mark |
Protected Member Functions | |
| PartitionEntity () | |
Private Member Functions | |
| PartitionEntity (const PartitionEntity &) | |
| void | operator= (const PartitionEntity &) |
Private Attributes | |
| SubEntitySet * | entitySet |
| PartitionEntity * | entitySetNext |
| int | entitySetId |
Friends | |
| class | SubEntitySet |
Definition at line 22 of file PartitionEntity.hpp.
| PartitionEntity::~PartitionEntity | ( | ) | [virtual] |
Definition at line 20 of file PartitionEntity.cpp.
| PartitionEntity::PartitionEntity | ( | ) | [protected] |
Definition at line 25 of file PartitionEntity.cpp.
: mark(0), entitySet(0), entitySetNext(0), entitySetId(0) { }
| PartitionEntity::PartitionEntity | ( | const PartitionEntity & | ) | [private] |
| virtual CubitBox PartitionEntity::bounding_box | ( | ) | const [pure virtual] |
Implemented in PartitionBody, SegmentedCurve, PartitionSurface, PartitionLump, PartitionCoEdge, PartPTCurve, SubCurve, and PartitionPoint.
| CubitStatus PartitionEntity::move_to_geometry | ( | CubitVector & | position | ) | [virtual] |
Reimplemented in PartitionSurface, PartitionCurve, and PartitionPoint.
Definition at line 51 of file PartitionEntity.cpp.
{ return CUBIT_SUCCESS; }
| virtual void PartitionEntity::notify_split | ( | FacetEntity * | old_entity, |
| FacetEntity * | new_entity | ||
| ) | [pure virtual] |
Implemented in PartitionSurface, PartitionCurve, PartitionBody, PartitionCoEdge, PartitionLump, and PartitionPoint.
| void PartitionEntity::operator= | ( | const PartitionEntity & | ) | [private] |
| TopologyBridge * PartitionEntity::partitioned_entity | ( | ) | const [inline] |
Definition at line 76 of file PartitionEntity.hpp.
return entitySet->get_entity();
| void PartitionEntity::print_debug_info | ( | const char * | prefix = 0, |
| bool | print_subentity_set = true |
| ) | const [virtual] |
Reimplemented in PartitionSurface, SegmentedCurve, PartitionCurve, and PartitionPoint.
Definition at line 30 of file PartitionEntity.cpp.
if( !prefix ) prefix = "";
PRINT_INFO("%sPartitionEntity %p\n", prefix, (void*)this );
if( print_subent_set )
sub_entity_set().print_debug_info(prefix);
else
print_partitioned_entity( prefix );
| void PartitionEntity::print_partitioned_entity | ( | const char * | prefix = 0 | ) | const |
Definition at line 41 of file PartitionEntity.cpp.
if(!prefix) prefix = "";
PRINT_INFO("%sPartitioned Entity: %s %p\n",
prefix,
partitioned_entity() ?
fix_type_name(typeid(*partitioned_entity()).name()) : "TopologyBridge",
(void*)partitioned_entity() );
| CubitStatus PartitionEntity::relax_to_geometry | ( | CubitPoint * | facet_point, |
| const CubitVector * | input_position = 0 |
Definition at line 54 of file PartitionEntity.cpp.
if (input_pos)
CubitVector closest(*input_pos);
if (move_to_geometry(closest) &&
facet_point->check_inverted_facets(closest))
facet_point->set(closest);
CubitVector facet_pos(facet_point->coordinates());
if (move_to_geometry(facet_pos) &&
facet_point->check_inverted_facets(facet_pos))
facet_point->set(facet_pos);
return CUBIT_FAILURE;
| virtual void PartitionEntity::reverse_sense | ( | ) | [pure virtual] |
Implemented in PartitionSurface, SubSurface, SegmentedCurve, PartPTCurve, PartitionBody, PartitionLump, PartitionCoEdge, PartitionPoint, and SubCurve.
| virtual CubitStatus PartitionEntity::save | ( | CubitSimpleAttrib & | attrib | ) | [pure virtual] |
Implemented in PartitionBody, PartitionSurface, PartitionCoEdge, PartitionPoint, PartitionLump, SubCurve, PartPTCurve, SegmentedCurve, and SubSurface.
| SubEntitySet & PartitionEntity::sub_entity_set | ( | ) | const [inline] |
Definition at line 81 of file PartitionEntity.hpp.
return *entitySet;
| virtual void PartitionEntity::transform | ( | const CubitTransformMatrix & | xform | ) | [pure virtual] |
Implemented in PartitionSurface, SegmentedCurve, PartitionCurve, PartitionBody, PartitionLump, PartitionCoEdge, and PartitionPoint.
friend class SubEntitySet [friend] |
Definition at line 65 of file PartitionEntity.hpp.
SubEntitySet* PartitionEntity::entitySet [private] |
Definition at line 67 of file PartitionEntity.hpp.
int PartitionEntity::entitySetId [private] |
Definition at line 72 of file PartitionEntity.hpp.
PartitionEntity* PartitionEntity::entitySetNext [private] |
Definition at line 68 of file PartitionEntity.hpp.
Definition at line 38 of file PartitionEntity.hpp.
