cgma
#include <PointGridSearch.hpp>
Definition at line 45 of file PointGridSearch.hpp.
| PointGridSearch::PointGridSearch | ( | DLIList< CubitPoint * > * | point_list, |
| DLIList< CubitFacet * > * | facet_list, | ||
| float | grid_scale = 2.0 |
Definition at line 33 of file PointGridSearch.cpp.
// find the geometric bounding range mesh
assert( point_list && point_list->size() );
bounding_range( *point_list );
//find an estimate of the cell size based on the average square distance
//of the edges on the surface of the geometry
double grid_cell_size = 1.;
// edge lengths
double sum = 0.0;
int i;
maxEdgeLength = CUBIT_DBL_MIN;
assert( facet_list && facet_list->size());
for ( i = 0; i < facet_list->size(); i++)
CubitPoint *p1, *p2;
facet_list->next(i)->get_edge_1(p1, p2);
CubitVector temp = p2->coordinates() - p1->coordinates();
double tmp_lsqrd = temp.length_squared();
sum += tmp_lsqrd;
grid_cell_size = sqrt( sum / facet_list->size() );
maxEdgeLength = grid_cell_size;
// evaluate grid parameters
CubitVector cell(1.0, 1.0, 1.0);
double grid_cell_width = grid_scale * grid_cell_size;
cell *= ( GRID_EXTENSION + 5.0 ) * grid_cell_width;
gridRangeMinimum = boundingRangeMinimum - cell;
gridRangeMaximum = boundingRangeMaximum + cell;
CubitVector range_width = gridRangeMaximum - gridRangeMinimum;
numberGridCellsX = (int) ceil(range_width.x() / grid_cell_width + 0.5);
numberGridCellsY = (int) ceil(range_width.y() / grid_cell_width + 0.5);
numberGridCellsZ = (int) ceil(range_width.z() / grid_cell_width + 0.5);
numberGridCells = numberGridCellsX * numberGridCellsY * numberGridCellsZ;
gridCellWidth.x(range_width.x() / ((double) numberGridCellsX));
gridCellWidth.y(range_width.y() / ((double) numberGridCellsY));
gridCellWidth.z(range_width.z() / ((double) numberGridCellsZ));
gridCellWidthInverse.x(1.0 / gridCellWidth.x());
gridCellWidthInverse.y(1.0 / gridCellWidth.y());
gridCellWidthInverse.z(1.0 / gridCellWidth.z());
// allocate neighborhood list array
neighborhoodList = new DLIList<CubitPoint*>* [numberGridCells];
assert(neighborhoodList != NULL);
for ( i = 0; i < numberGridCells; i++)
neighborhoodList[i] = NULL;
| PointGridSearch::PointGridSearch | ( | DLIList< CubitPoint * > & | point_list, |
| double | grid_cell_size, | ||
| double | grid_scale | ||
Definition at line 92 of file PointGridSearch.cpp.
// find the bounding range of the reference geometry
bounding_range(point_list);
if ( grid_cell_size < CUBIT_RESABS )
grid_cell_size =
(boundingRangeMaximum - boundingRangeMinimum).length() / 5.;
cell *= grid_cell_width;
int i;
| PointGridSearch::~PointGridSearch | ( | ) | [virtual] |
Definition at line 133 of file PointGridSearch.cpp.
// delete each DLIList<CubitPoint*> and the array of pointers containing them
// first, delete the tdcellindex for each point
int i;
for ( i = 0; i < numberGridCells; i++) {
if (!neighborhoodList[i]) continue;
for (int j = neighborhoodList[i]->size(); j > 0; j--)
neighborhoodList[i]->get_and_step()->delete_TD(&TDCellIndex::is_cell_index);
for (i = 0; i < numberGridCells; i++)
delete neighborhoodList[i];
delete [] neighborhoodList;
| void PointGridSearch::add_point | ( | CubitPoint * | point | ) |
Definition at line 290 of file PointGridSearch.cpp.
// append point to the appropriate list
int i = grid_cell_index(point);
if (i < 0 || i > numberGridCells){
return;
ToolData* td_temp = point->get_TD(&TDCellIndex::is_cell_index);
TDCellIndex* td_index;
if(td_temp == NULL){
td_index = new TDCellIndex;
assert(td_index != NULL);
point->add_TD(td_index);
td_index->cell_index(i);
add_point_to_cell(point, i);
else{ // the tool data already exists, avoid multiple listings of point
td_index = CAST_TO(td_temp, TDCellIndex);
assert( td_index != NULL);
int iold = td_index->cell_index();
if(iold != i){
remove_point_from_cell(point,iold);
else{ // iold==i, so check whether the point is already on the list
if (neighborhoodList[i] && neighborhoodList[i]->move_to(point)) return;
else add_point_to_cell(point, i);
| void PointGridSearch::add_point_to_cell | ( | CubitPoint * | point, |
| int | i | ||
| ) | [private] |
Definition at line 667 of file PointGridSearch.cpp.
if (neighborhoodList[i])
neighborhoodList[i]->append(point);
else
neighborhoodList[i] = new DLIList<CubitPoint*>;
Definition at line 634 of file PointGridSearch.cpp.
int total_points = 0;
int occupied_cells = 0;
for (int i = 0; i < numberGridCells; i++)
total_points += neighborhoodList[i]->size();
occupied_cells++;
return ((double) (total_points) / (double) (occupied_cells));
| int PointGridSearch::bounding_cell_maximum_x | ( | ) | [inline] |
Definition at line 205 of file PointGridSearch.hpp.
{return boundingCellMaximumX;}
| int PointGridSearch::bounding_cell_maximum_y | ( | ) | [inline] |
Definition at line 207 of file PointGridSearch.hpp.
{return boundingCellMaximumY;}
| int PointGridSearch::bounding_cell_maximum_z | ( | ) | [inline] |
Definition at line 209 of file PointGridSearch.hpp.
{return boundingCellMaximumZ;}
| int PointGridSearch::bounding_cell_minimum_x | ( | ) | [inline] |
Definition at line 199 of file PointGridSearch.hpp.
{return boundingCellMinimumX;}
| int PointGridSearch::bounding_cell_minimum_y | ( | ) | [inline] |
Definition at line 201 of file PointGridSearch.hpp.
{return boundingCellMinimumY;}
| int PointGridSearch::bounding_cell_minimum_z | ( | ) | [inline] |
Definition at line 203 of file PointGridSearch.hpp.
{return boundingCellMinimumZ;}
| void PointGridSearch::bounding_range | ( | DLIList< CubitPoint * > & | point_list | ) | [protected] |
Definition at line 182 of file PointGridSearch.cpp.
if ( !point_list.size() )
return;
// initialize min and max range values to the first point coordinates
boundingRangeMinimum = point_list.get()->coordinates();
boundingRangeMaximum = point_list.get_and_step()->coordinates();
// find the min and max coordinates that completely encloses the
// point list
for (int i = 1; i < point_list.size(); i++)
bounding_range(point_list.get_and_step());
| void PointGridSearch::bounding_range | ( | DLIList< CubitFacet * > & | facet_list | ) | [protected] |
Definition at line 199 of file PointGridSearch.cpp.
int i, j;
DLIList<CubitPoint*> point_list;
for ( i = 0; i < facet_list.size(); i++)
CubitFacet* facet = facet_list.get_and_step();
DLIList<CubitPoint*> temp_point_list;
facet->points(temp_point_list);
for (j = 0; j < temp_point_list.size(); j++)
CubitPoint* point = temp_point_list.get_and_step();
if (!point->marked())
point->marked(CUBIT_TRUE);
point_list.append(point);
// unmark the found points
for (i = 0; i < point_list.size(); i++)
point_list.get_and_step()->marked(CUBIT_FALSE);
return;
// point list
for (i = 1; i < point_list.size(); i++)
| void PointGridSearch::bounding_range | ( | CubitPoint * | point | ) | [inline, protected] |
Definition at line 242 of file PointGridSearch.hpp.
double xpos = point->x();
double ypos = point->y();
double zpos = point->z();
if (xpos < boundingRangeMinimum.x())
boundingRangeMinimum.x(xpos);
else if (xpos > boundingRangeMaximum.x())
boundingRangeMaximum.x(xpos);
if (ypos < boundingRangeMinimum.y())
boundingRangeMinimum.y(ypos);
else if (ypos > boundingRangeMaximum.y())
boundingRangeMaximum.y(ypos);
if (zpos < boundingRangeMinimum.z())
boundingRangeMinimum.z(zpos);
else if (zpos > boundingRangeMaximum.z())
boundingRangeMaximum.z(zpos);
| void PointGridSearch::bounding_range | ( | const CubitVector & | vec | ) | [inline, protected] |
Definition at line 224 of file PointGridSearch.hpp.
if (vec.x() < boundingRangeMinimum.x())
boundingRangeMinimum.x(vec.x());
else if (vec.x() > boundingRangeMaximum.x())
boundingRangeMaximum.x(vec.x());
if (vec.y() < boundingRangeMinimum.y())
boundingRangeMinimum.y(vec.y());
else if (vec.y() > boundingRangeMaximum.y())
boundingRangeMaximum.y(vec.y());
if (vec.z() < boundingRangeMinimum.z())
boundingRangeMinimum.z(vec.z());
else if (vec.z() > boundingRangeMaximum.z())
boundingRangeMaximum.z(vec.z());
| CubitVector PointGridSearch::bounding_range_maximum | ( | ) | [inline] |
Definition at line 197 of file PointGridSearch.hpp.
{return boundingRangeMaximum;}
| CubitVector PointGridSearch::bounding_range_minimum | ( | ) | [inline] |
Definition at line 195 of file PointGridSearch.hpp.
{return boundingRangeMinimum;}
| void PointGridSearch::cell_from_range | ( | ) | [protected, virtual] |
Definition at line 155 of file PointGridSearch.cpp.
// Evaluate boundingCellMin and Max from the boundingRangeMin and Max
// parameters
CubitVector range_vec = boundingRangeMinimum - gridRangeMinimum;
boundingCellMinimumX = (int) (range_vec.x() * gridCellWidthInverse.x());
boundingCellMinimumY = (int) (range_vec.y() * gridCellWidthInverse.y());
boundingCellMinimumZ = (int) (range_vec.z() * gridCellWidthInverse.z());
if (boundingCellMinimumX < 0) boundingCellMinimumX = 0;
if (boundingCellMinimumY < 0) boundingCellMinimumY = 0;
if (boundingCellMinimumZ < 0) boundingCellMinimumZ = 0;
range_vec = boundingRangeMaximum - gridRangeMinimum;
boundingCellMaximumX = (int) (range_vec.x() * gridCellWidthInverse.x());
boundingCellMaximumY = (int) (range_vec.y() * gridCellWidthInverse.y());
boundingCellMaximumZ = (int) (range_vec.z() * gridCellWidthInverse.z());
if (boundingCellMaximumX >= numberGridCellsX)
boundingCellMaximumX = numberGridCellsX - 1;
if (boundingCellMaximumY >= numberGridCellsY)
boundingCellMaximumY = numberGridCellsY - 1;
if (boundingCellMaximumZ >= numberGridCellsZ)
boundingCellMaximumZ = numberGridCellsZ - 1;
| void PointGridSearch::change_cell | ( | CubitPoint * | point | ) |
Definition at line 245 of file PointGridSearch.cpp.
int old_cell, current_cell;
// if cell index has changed then swap lists
ToolData* td_temp = point->get_TD( &TDCellIndex::is_cell_index);
TDCellIndex* td_index = CAST_TO(td_temp, TDCellIndex);
if (td_temp == NULL) {
assert( td_index != NULL );
old_cell = td_index->cell_index();
current_cell = grid_cell_index(point);
if (current_cell >= 0 && current_cell < numberGridCells)
if (current_cell != old_cell)
remove_point_from_cell(point, old_cell);
add_point_to_cell(point, current_cell);
td_index->cell_index(current_cell);
| double PointGridSearch::fraction_empty_cells | ( | ) |
Definition at line 622 of file PointGridSearch.cpp.
int empty_cell = 0;
if (!neighborhoodList[i]) empty_cell++;
return ((double) (empty_cell) / (double) (numberGridCells));
| void PointGridSearch::get_neighborhood_facets | ( | DLIList< CubitFacet * > & | facet_list | ) |
Definition at line 584 of file PointGridSearch.cpp.
// retrieve points over the current bounding box range
facet_list.clean_out();
get_neighborhood_points( point_list );
// retrieve all faces attached to the points in point_list
for (int i = 0; i < point_list.size(); i++)
CubitPoint* point = point_list.get_and_step();
DLIList<CubitFacet*> temp_facet_list;
point->facets(temp_facet_list);
for (int j = 0; j < temp_facet_list.size(); j++)
CubitFacet* facet = temp_facet_list.get_and_step();
if (!facet->marked())
facet->marked(CUBIT_TRUE);
facet_list.append(facet);
// unmark the found faces and return face_list
for (int m = 0; m < facet_list.size(); m++)
facet_list.get_and_step()->marked(CUBIT_FALSE);
| void PointGridSearch::get_neighborhood_points | ( | DLIList< CubitPoint * > & | point_list | ) |
Definition at line 501 of file PointGridSearch.cpp.
point_list.clean_out();
for (int k = boundingCellMinimumZ; k <= boundingCellMaximumZ; k++)
int kn = numberGridCellsY * k;
for (int j = boundingCellMinimumY; j <= boundingCellMaximumY; j++)
int jn = numberGridCellsX * (kn + j);
for (int i = boundingCellMinimumX; i <= boundingCellMaximumX; i++)
int in = jn + i;
assert( in >= 0 && in < numberGridCells );
if (neighborhoodList[in])
point_list += *(neighborhoodList[in]);
| void PointGridSearch::get_neighborhood_points_sorted | ( | DLIList< CubitPoint * > & | point_list, |
| const CubitVector & | center, | ||
| double | cut_off | ||
Definition at line 535 of file PointGridSearch.cpp.
int i;
for ( i = boundingCellMinimumX; i <= boundingCellMaximumX; i++)
int in = jn + i;
temp_point_list += *(neighborhoodList[in]);
// evaluate point distance to center ... remove those larger than cut_off
std::vector< std::pair<int, double> > sorted_index_list;
CubitVector vec;
cut_off *= cut_off;
temp_point_list.reset();
for ( i = 0; i < temp_point_list.size(); i++)
vec = center - temp_point_list.get_and_step()->coordinates();
double distance = vec.length_squared();
if (distance < cut_off)
sorted_index_list.push_back( std::make_pair( i, distance ) );
std::sort(sorted_index_list.begin(), sorted_index_list.end(), sort_by_second<std::pair<int, double> >());
for ( size_t j = 0; j < sorted_index_list.size(); j++ )
int index = sorted_index_list[j].first;
point_list.append( temp_point_list.next( index ) );
| int PointGridSearch::grid_cell_index | ( | CubitPoint * | point | ) | [inline, protected] |
Definition at line 212 of file PointGridSearch.hpp.
CubitVector range_vec = point->coordinates();
range_vec -= gridRangeMinimum;
int i = (int) (range_vec.x() * gridCellWidthInverse.x());
int j = (int) (range_vec.y() * gridCellWidthInverse.y());
int k = (int) (range_vec.z() * gridCellWidthInverse.z());
return numberGridCellsX * (numberGridCellsY * k + j) + i;
| CubitVector PointGridSearch::grid_cell_width | ( | ) | [inline] |
Definition at line 189 of file PointGridSearch.hpp.
{return gridCellWidth;}
| CubitVector PointGridSearch::grid_range_maximum | ( | ) | [inline] |
Definition at line 188 of file PointGridSearch.hpp.
{return gridRangeMaximum;}
| CubitVector PointGridSearch::grid_range_minimum | ( | ) | [inline] |
Definition at line 187 of file PointGridSearch.hpp.
{return gridRangeMinimum;}
| int PointGridSearch::in_grid | ( | const CubitVector & | position | ) |
Definition at line 270 of file PointGridSearch.cpp.
CubitVector range_vec;
int i, j, k, index;
range_vec = position - gridRangeMinimum;
index = numberGridCellsX * (numberGridCellsY * k + j) + i;
if(index >= 0 && index < numberGridCells)
return CUBIT_TRUE;
else
return CUBIT_FALSE;
| int PointGridSearch::number_grid_cells | ( | ) | [inline] |
Definition at line 193 of file PointGridSearch.hpp.
{return numberGridCells;}
| int PointGridSearch::number_grid_cells_x | ( | ) | [inline] |
Definition at line 190 of file PointGridSearch.hpp.
{return numberGridCellsX;}
| int PointGridSearch::number_grid_cells_y | ( | ) | [inline] |
Definition at line 191 of file PointGridSearch.hpp.
{return numberGridCellsY;}
| int PointGridSearch::number_grid_cells_z | ( | ) | [inline] |
Definition at line 192 of file PointGridSearch.hpp.
{return numberGridCellsZ;}
| void PointGridSearch::remove_point | ( | CubitPoint * | point | ) |
Definition at line 326 of file PointGridSearch.cpp.
// remove point from the appropriate list
int index = -1;
if (!td_temp)
return;
if( td_index ){
index = td_index->cell_index();
point->delete_TD( &TDCellIndex::is_cell_index );
remove_point_from_cell(point, index);
| void PointGridSearch::remove_point_from_cell | ( | CubitPoint * | point, |
| int | i | ||
| ) | [private] |
Definition at line 679 of file PointGridSearch.cpp.
if( i < 0 ) return;
if (neighborhoodList[i]->move_to(point))
neighborhoodList[i]->extract();
if (!neighborhoodList[i]->size())
| void PointGridSearch::set_neighborhood_bounds | ( | CubitVector & | vec | ) |
Definition at line 341 of file PointGridSearch.cpp.
// set the range and cell min and max values for the vector
boundingRangeMinimum = vec;
boundingRangeMaximum = vec;
cell_from_range();
| void PointGridSearch::set_neighborhood_bounds | ( | const CubitVector & | center, |
| double | size | ||
Definition at line 351 of file PointGridSearch.cpp.
// set the range and cell min and max values as a cube of breadth =
// 2 * size centered at center
CubitVector search_extent_box(size, size, size);
boundingRangeMinimum = center - search_extent_box;
boundingRangeMaximum = center + search_extent_box;
cell_from_range();
| void PointGridSearch::set_neighborhood_bounds | ( | CubitVector & | center, |
| double | x, | ||
| double | y, | ||
| double | z | ||
Definition at line 378 of file PointGridSearch.cpp.
// set the range and cell min and max values as a box of size 2x, 2y, and
// 2z, centered at center
CubitVector search_extent_box(x, y, z);
cell_from_range();
| void PointGridSearch::set_neighborhood_bounds | ( | CubitVector & | vec_1, |
| CubitVector & | vec_2 | ||
Definition at line 391 of file PointGridSearch.cpp.
// initialize min and max range values to the first vectors coordinates
boundingRangeMinimum = vec_1;
boundingRangeMaximum = vec_1;
// find the range and cell min and max values for the two vectors
bounding_range(vec_2);
cell_from_range();
| void PointGridSearch::set_neighborhood_bounds | ( | CubitPoint * | point, |
| CubitVector & | vec | ||
Definition at line 405 of file PointGridSearch.cpp.
// initialize min and max range values to the point coordinates
boundingRangeMinimum = point->coordinates();
boundingRangeMaximum = point->coordinates();
// find the range and cell min and max values for the point and vector
bounding_range(vec);
cell_from_range();
| void PointGridSearch::set_neighborhood_bounds | ( | CubitPoint * | point | ) |
Definition at line 418 of file PointGridSearch.cpp.
// find the cell min and max values
cell_from_range();
| void PointGridSearch::set_neighborhood_bounds | ( | CubitPoint * | point_1, |
| CubitPoint * | point_2 | ||
Definition at line 430 of file PointGridSearch.cpp.
boundingRangeMinimum = point_1->coordinates();
boundingRangeMaximum = point_1->coordinates();
// find the range and cell min and max values for the two points
bounding_range(point_2);
cell_from_range();
| void PointGridSearch::set_neighborhood_bounds | ( | DLIList< CubitPoint * > & | point_list | ) |
Definition at line 443 of file PointGridSearch.cpp.
// find the range and cell min and max values for the point list
cell_from_range();
| void PointGridSearch::set_neighborhood_bounds | ( | CubitFacet * | facet | ) |
Definition at line 451 of file PointGridSearch.cpp.
// find the points belonging to the face
facet->points(point_list);
// find the bounding range and cell min and max values for the point list
cell_from_range();
| void PointGridSearch::set_neighborhood_bounds | ( | DLIList< CubitFacet * > & | facet_list | ) |
Definition at line 464 of file PointGridSearch.cpp.
// find all points belonging to the faces in face_list
int i;
for (int j = 0; j < temp_point_list.size(); j++)
cell_from_range();
| void PointGridSearch::set_neighborhood_bounds_max_edge | ( | const CubitVector & | center, |
| double | factor = 1.0 |
Definition at line 363 of file PointGridSearch.cpp.
CubitVector search_extent_box(maxEdgeLength*factor,
maxEdgeLength*factor);
cell_from_range();
Definition at line 651 of file PointGridSearch.cpp.
return total_points;
int PointGridSearch::boundingCellMaximumX [protected] |
Definition at line 78 of file PointGridSearch.hpp.
int PointGridSearch::boundingCellMaximumY [protected] |
Definition at line 79 of file PointGridSearch.hpp.
int PointGridSearch::boundingCellMaximumZ [protected] |
Definition at line 80 of file PointGridSearch.hpp.
int PointGridSearch::boundingCellMinimumX [protected] |
Definition at line 75 of file PointGridSearch.hpp.
int PointGridSearch::boundingCellMinimumY [protected] |
Definition at line 76 of file PointGridSearch.hpp.
int PointGridSearch::boundingCellMinimumZ [protected] |
Definition at line 77 of file PointGridSearch.hpp.
CubitVector PointGridSearch::boundingRangeMaximum [protected] |
Definition at line 74 of file PointGridSearch.hpp.
CubitVector PointGridSearch::boundingRangeMinimum [protected] |
Definition at line 73 of file PointGridSearch.hpp.
CubitVector PointGridSearch::gridCellWidth [protected] |
Definition at line 64 of file PointGridSearch.hpp.
CubitVector PointGridSearch::gridCellWidthInverse [protected] |
Definition at line 65 of file PointGridSearch.hpp.
CubitVector PointGridSearch::gridRangeMaximum [protected] |
Definition at line 63 of file PointGridSearch.hpp.
CubitVector PointGridSearch::gridRangeMinimum [protected] |
Definition at line 62 of file PointGridSearch.hpp.
double PointGridSearch::maxEdgeLength [private] |
Definition at line 52 of file PointGridSearch.hpp.
DLIList<CubitPoint*>** PointGridSearch::neighborhoodList [private] |
Definition at line 49 of file PointGridSearch.hpp.
int PointGridSearch::numberGridCells [protected] |
Definition at line 69 of file PointGridSearch.hpp.
int PointGridSearch::numberGridCellsX [protected] |
Definition at line 66 of file PointGridSearch.hpp.
int PointGridSearch::numberGridCellsY [protected] |
Definition at line 67 of file PointGridSearch.hpp.
int PointGridSearch::numberGridCellsZ [protected] |
Definition at line 68 of file PointGridSearch.hpp.
