cgma
#include <TDOctreeRefFace.hpp>
Definition at line 25 of file TDOctreeRefFace.hpp.
Definition at line 27 of file TDOctreeRefFace.cpp.
ptrCubitPointList = NULL;
ptrCubitFacetEdgeList = NULL;
ptrCubitFacetList = NULL;
visit = CUBIT_FALSE;
create_2dmat = CUBIT_TRUE;
Definition at line 37 of file TDOctreeRefFace.cpp.
if (ptrCubitFacetList != NULL)
FacetDataUtil::delete_facets(*ptrCubitFacetList);
if( ptrCubitFacetList )
delete ptrCubitFacetList;
if( ptrCubitFacetEdgeList )
delete ptrCubitFacetEdgeList;
if( ptrCubitPointList )
delete ptrCubitPointList;
//PRINT_INFO("Inside ~TDOctreeRefFace\n");
| CubitStatus TDOctreeRefFace::add_td | ( | RefFace * | ref_face | ) | [static] |
Definition at line 67 of file TDOctreeRefFace.cpp.
ToolData *td;
td = ref_face->get_TD(&TDOctreeRefFace::is_td_octree_ref_face);
if ( td == NULL )
TDOctreeRefFace *td_gm = new TDOctreeRefFace;
ref_face->add_TD( td_gm);
td_gm->set_ref_face( ref_face );
else
TDOctreeRefFace *td_gm = CAST_TO(td, TDOctreeRefFace);
return CUBIT_SUCCESS;
| void TDOctreeRefFace::append_list_item | ( | int | loop_id | ) | [inline] |
Definition at line 68 of file TDOctreeRefFace.hpp.
| CubitBoolean TDOctreeRefFace::check_valid_facets | ( | CubitBoolean | disable_if_bad | ) |
Definition at line 479 of file TDOctreeRefFace.cpp.
int i;
CubitBoolean good_facets = CUBIT_TRUE;
CubitFacetEdge *facet_edge;
for (i=0; i < ptrCubitFacetEdgeList->size(); ++i)
facet_edge = ptrCubitFacetEdgeList->get_and_step();
if (facet_edge->num_adj_facets() > 2)
good_facets = CUBIT_FALSE;
break;
if (disable_if_bad && !good_facets) {set_create_2dmat(CUBIT_FALSE);}
return good_facets;
| CubitBoolean TDOctreeRefFace::get_create_2dmat | ( | ) | [inline] |
Definition at line 64 of file TDOctreeRefFace.hpp.
{return create_2dmat;}
| DLIList<CubitFacetEdge *>* TDOctreeRefFace::get_ptr_cubit_facet_edge_list | ( | ) | [inline] |
Definition at line 79 of file TDOctreeRefFace.hpp.
{ return ptrCubitFacetEdgeList; }
| DLIList<CubitFacet *>* TDOctreeRefFace::get_ptr_cubit_facet_list | ( | ) | [inline] |
Definition at line 82 of file TDOctreeRefFace.hpp.
{ return ptrCubitFacetList; }
| DLIList<CubitPoint *>* TDOctreeRefFace::get_ptr_cubit_point_list | ( | ) | [inline] |
Definition at line 76 of file TDOctreeRefFace.hpp.
{ return ptrCubitPointList; }
| TDOctreeRefFace * TDOctreeRefFace::get_td | ( | RefFace * | ref_face | ) | [static] |
Definition at line 95 of file TDOctreeRefFace.cpp.
ToolData *td;
if ( td != NULL )
return td_gm;
return (TDOctreeRefFace*) NULL;
| CubitBoolean TDOctreeRefFace::get_visit | ( | void | ) | const [inline] |
Definition at line 60 of file TDOctreeRefFace.hpp.
{ return visit; }
| CubitBoolean TDOctreeRefFace::is_adj_curves | ( | int | id1, |
| int | id2 | ||
Definition at line 106 of file TDOctreeRefFace.cpp.
int loop_index1, loop_index2;
int i;
int first_curve_id, last_curve_id, start_curve_id;
loopIndex.reset();
loop_index1 = CUBIT_INT_MAX;
// i indicates loop index
for( i = 0; i < loopIndex.size(); i++ ){
start_curve_id = loopIndex.get_and_step();
if( id1 < start_curve_id ){
loop_index1 = i - 1;
break;
if( loop_index1 == CUBIT_INT_MAX ){
loopIndex.reset();
loop_index2 = CUBIT_INT_MAX;
if( id2 < start_curve_id ){
loop_index2 = i - 1;
break;
if( loop_index2 == CUBIT_INT_MAX ){
if( loop_index1 != loop_index2 ){
// curves are not in same loop
return CUBIT_FALSE;
else{
if( abs(id1 - id2) == 1 ){
// adj curves of same loop
return CUBIT_TRUE;
loopIndex.reset();
loopIndex.step( loop_index1 );
first_curve_id = loopIndex.get_and_step();
last_curve_id = loopIndex.get() - 1;
if( last_curve_id < first_curve_id ){
// PRINT_DEBUG_157(" id1 = %d and id2 = %d", id1, id2 );
// PRINT_DEBUG_157(" Note: Last curve id ( %d ) is less than first curve id ( %d ) \n", last_curve_id, first_curve_id );
last_curve_id = lastCurveID;
// PRINT_DEBUG_157(" last_curve_id is reset to %d \n", lastCurveID );
if( abs(id1 - id2) == (last_curve_id - first_curve_id ) ){
// firs and last curve of same loop
return CUBIT_TRUE;
// part of same curve
if( abs(id1 - id2) == 0 ){
return CUBIT_TRUE;
// same loop but non-adj curves
return CUBIT_FALSE;
| static int TDOctreeRefFace::is_td_octree_ref_face | ( | const ToolData * | td | ) | [inline, static] |
Definition at line 70 of file TDOctreeRefFace.hpp.
{return (CAST_TO(const_cast<ToolData*>(td), TDOctreeRefFace) != NULL);}
| void TDOctreeRefFace::set_create_2dmat | ( | const CubitBoolean | new_val | ) | [inline] |
Definition at line 63 of file TDOctreeRefFace.hpp.
{create_2dmat = new_val;}
| void TDOctreeRefFace::set_last_curve_id | ( | int | id | ) | [inline] |
Definition at line 73 of file TDOctreeRefFace.hpp.
{ lastCurveID = id; }
| void TDOctreeRefFace::set_ptr_cubit_facet_edge_list | ( | DLIList< CubitFacetEdge * > * | ptr_cubit_facet_edge_list | ) | [inline] |
Definition at line 80 of file TDOctreeRefFace.hpp.
{ ptrCubitFacetEdgeList = ptr_cubit_facet_edge_list; }
| void TDOctreeRefFace::set_ptr_cubit_facet_list | ( | DLIList< CubitFacet * > * | ptr_cubit_facet_list | ) | [inline] |
Definition at line 83 of file TDOctreeRefFace.hpp.
{ ptrCubitFacetList = ptr_cubit_facet_list; }
| void TDOctreeRefFace::set_ptr_cubit_point_list | ( | DLIList< CubitPoint * > * | ptr_cubit_point_list | ) | [inline] |
Definition at line 77 of file TDOctreeRefFace.hpp.
{ ptrCubitPointList = ptr_cubit_point_list; }
| void TDOctreeRefFace::set_ref_face | ( | RefFace * | ptr_ref_face | ) | [inline] |
Definition at line 66 of file TDOctreeRefFace.hpp.
{ refFace = ptr_ref_face; }
| void TDOctreeRefFace::set_visit | ( | CubitBoolean | type | ) | [inline] |
Definition at line 61 of file TDOctreeRefFace.hpp.
{ visit = type; }
| CubitFacet * TDOctreeRefFace::split_facet_into_two_facets | ( | CubitFacet * | target_facet, |
| CubitPoint * | edge1_pt, | ||
| CubitPoint * | edge2_pt, | ||
| CubitFacetEdge * | boundary_edge, | ||
| CubitPoint * | new_pt, | ||
| DLIList< CubitFacet * > & | facet_list, | ||
| DLIList< CubitFacetEdge * > & | facet_edge_list, | ||
| DLIList< CubitPoint * > & | point_list | ||
Definition at line 304 of file TDOctreeRefFace.cpp.
//add new_pt to point_list
point_list.append( new_pt );
new_pt->marked( abs( edge->marked() ));
// split triangle
CubitFacetData* facet_d = dynamic_cast<CubitFacetData*>(target_facet);
assert(!!facet_d);
// fix up existing facet
int pt2_index = target_facet->point_index( edge2_pt );
bool edge_reversed = ( edge1_pt == target_facet->point( (pt2_index+1) % 3 ) );
int edge_index = (pt2_index + 1 + edge_reversed) % 3;
edge2_pt->remove_facet( target_facet );
facet_d->set_point( new_pt, pt2_index );
new_pt->add_facet( target_facet );
target_facet->update_plane();
// make new facet and update facet list
CubitPoint* other_pt = target_facet->point( edge_index );
CubitFacetData* new_facet;
if( edge_reversed )
new_facet = new CubitFacetData( other_pt, edge2_pt, new_pt );
else
new_facet = new CubitFacetData( other_pt, new_pt, edge2_pt );
// facet constructor takes care of this
// update the facets in points
// this takes care of adj facets of new edges and
// conversely edges of two facets
//edge2_pt->add_facet( new_facet );
//new_pt->add_facet( new_facet );
//other_pt->add_facet( new_facet );
// Facets list in the points should be updated before creating new edge
// the edge constructor generates adjacet facets.
// split edge, if there is one
//CubitFacetEdge* edge = edge1_pt->shared_edge( edge2_pt );
CubitFacetEdgeData* new_edge = 0;
if( edge ){
CubitFacetEdgeData* edge_d = dynamic_cast<CubitFacetEdgeData*>(edge);
assert(!!edge_d);
// make sure new edge has same orientation as old edge
new_edge = dynamic_cast<CubitFacetEdgeData*>(new_pt->shared_edge(edge2_pt));
if( edge->point(0) == edge1_pt ){
edge_d->set_point(new_pt, 1);
if ( !new_edge )
new_edge = new CubitFacetEdgeData( new_pt, edge2_pt );
else if( new_edge->point(0) != new_pt )
new_edge->flip();
else {
edge_d->set_point(new_pt, 0);
if ( !new_edge )
new_edge = new CubitFacetEdgeData( edge2_pt, new_pt );
else if( new_edge->point(1) != new_pt )
new_edge->flip();
new_edge->marked( abs( edge->marked() ) );
facet_edge_list.append( new_edge );
else{
PRINT_INFO("ERROR:Edge is doesn't exist. Splitting is not possible");
int sense;
// constructor takes care of this
if ( new_edge ) {
assert(!new_facet->edge(0));
new_facet->edge( new_edge, 0 );
new_edge->add_facet( new_facet );
sense = new_facet->point( 1 ) == new_edge->point(0) ? 1 : -1;
new_facet->edge_use( sense, 0 );
// facet_list appended
facet_list.append( new_facet );
// move other edge, if there is one
int pt1_index = ( pt2_index + 2 - edge_reversed ) % 3;
CubitFacetEdge* other_edge = target_facet->edge( pt1_index );
int e_index;
if( other_edge ){
other_edge->remove_facet(target_facet);
//target_facet->edge( 0, pt1_index );
e_index = 1 + edge_reversed;
assert(!new_facet->edge(e_index));
new_facet->edge( other_edge, e_index );
other_edge->add_facet( new_facet );
sense = new_facet->point( ( e_index + 1 ) % 3 ) == other_edge->point(0) ? 1 : -1;
new_facet->edge_use( sense, e_index );
// Add new mid edge in two facets
CubitFacetEdgeData *new_mid_edge_data;
CubitFacetEdge *new_mid_edge;
if( edge_reversed )
new_mid_edge_data = new CubitFacetEdgeData( other_pt, new_pt );
else
new_mid_edge_data = new CubitFacetEdgeData( new_pt, other_pt );
new_mid_edge = CAST_TO( new_mid_edge_data, CubitFacetEdge );
new_mid_edge->marked(2);
// new_mid_edge is appended
facet_edge_list.append( new_mid_edge );
/* ////edge constructor takes care of this
target_facet->edge( new_mid_edge, pt1_index );
if( !edge_reversed ){ // new_mid_edge index 2
new_facet->edge( new_mid_edge, ( e_index + 1 ) % 3 );
sense = new_facet->point( ( e_index + 2 ) % 3 ) == new_mid_edge->point(0) ? 1 : -1;
new_facet->edge_use( sense, (e_index + 1 ) % 3);
else{ // edge index 1
new_facet->edge( new_mid_edge, ( e_index - 1 ) % 3 );
sense = new_facet->point( ( e_index ) % 3 ) == new_mid_edge->point(0) ? 1 : -1;
new_facet->edge_use( sense, (e_index - 1 ) % 3);
#ifndef NDEBUG
/* ---------------------- TESTING ----------------------- */
// Testing the oerientation of faces w.r.t. the common edge
int index0, index1;
if( new_mid_edge->num_adj_facets() != 2 ){
PRINT_INFO("ERROR:number of adjacent faces of new mid edge is not equal to 2 \n");
assert(0);
CubitFacet *ptr_facet0 = new_mid_edge->adj_facet(0);
CubitFacet *ptr_facet1 = new_mid_edge->adj_facet(1);
for( index0 = 0; index0 < 3; index0++ ){
if( ptr_facet0->edge(index0) == new_mid_edge )
break;
for( index1 = 0; index1 < 3; index1++ ){
if( ptr_facet1->edge(index1) == new_mid_edge )
break;
if( index0 == 3 || index1 == 3 ){
PRINT_INFO("ERROR: new edge doesn't exist at the adjacent facets \n");
assert(0);
if( ptr_facet0->edge_use(index0) == ptr_facet1->edge_use(index1) ){
PRINT_INFO("ERROR: The orientation of edges is adjacent facet is not proper \n");
assert(0);
#endif
//PRINT_DEBUG_157("Passes\n");
return CAST_TO( new_facet, CubitFacet );
| CubitBoolean TDOctreeRefFace::split_facet_locally_along_edge | ( | CubitFacet * | target_facet, |
| int | num_of_segments, | ||
Definition at line 280 of file TDOctreeRefFace.cpp.
int i;
CubitFacet *new_facet;
CubitVector position, delta_length;
delta_length = (edge2_pt->coordinates() - edge1_pt->coordinates()) / num_of_segments;
for( i = num_of_segments - 1; i >= 1; i-- ){
position = edge1_pt->coordinates() + ( delta_length * i );
CubitPointData* new_pt_data = new CubitPointData( position );
// update TD and append the list
CubitPoint *new_pt = CAST_TO(new_pt_data, CubitPoint);
new_facet = split_facet_into_two_facets( target_facet, edge1_pt, edge2_pt, ptr_edge, new_pt, facet_list, facet_edge_list, point_list );
// mark the newly created facets so that they are not checked for
// further splitting. "this" facet is marked in Octree.cpp.
new_facet->marked( -1 );
edge2_pt = new_pt;
return CUBIT_TRUE;
| CubitBoolean TDOctreeRefFace::split_facet_type_00 | ( | CubitFacet * | target_facet, |
| CubitBoolean TDOctreeRefFace::split_facet_type_01 | ( | CubitFacet * | target_facet, |
| CubitBoolean TDOctreeRefFace::split_facet_type_02 | ( | CubitFacet * | target_facet, |
| CubitBoolean TDOctreeRefFace::split_facet_type_03 | ( | CubitFacet * | target_facet, |
Definition at line 177 of file TDOctreeRefFace.cpp.
// Do Nothing
// During CAT centroid will give the approximate branch point
return CUBIT_TRUE;
| CubitBoolean TDOctreeRefFace::split_facet_type_12 | ( | CubitFacet * | target_facet, |
| CubitBoolean TDOctreeRefFace::split_facet_type_13 | ( | CubitFacet * | target_facet, |
Definition at line 184 of file TDOctreeRefFace.cpp.
int i;
CubitFacetEdge *boundary_edge = NULL, *ptr_edge;
CubitPoint *boundary_edge_pnt0, *boundary_edge_pnt1, *other_boundary_point;
double internal_angle;
int num_of_segments;
for( i = 0; i < 3; i++ ){
ptr_edge = target_facet->edge(i);
if( abs( ptr_edge->marked() ) == 1 ){
boundary_edge = ptr_edge;
break;
boundary_edge_pnt0 = boundary_edge->point(0);
boundary_edge_pnt1 = boundary_edge->point(1);
other_boundary_point = target_facet->point(i);
if( other_boundary_point->id() != boundary_edge_pnt0->id() && other_boundary_point->id() != boundary_edge_pnt1->id() ){
break;
internal_angle = target_facet->angle( other_boundary_point );
num_of_segments = (int)(floor( (internal_angle / (FACET_SPLITTING_INTERNAL_ANGLE )) + 0.5));
if( num_of_segments > 1 )
split_facet_locally_along_edge( target_facet, boundary_edge_pnt0, boundary_edge_pnt1, boundary_edge, num_of_segments, facet_list, facet_edge_list, point_list );
return CUBIT_TRUE;
| CubitBoolean TDOctreeRefFace::split_facet_type_23 | ( | CubitFacet * | target_facet, |
Definition at line 219 of file TDOctreeRefFace.cpp.
int i;
CubitFacetEdge *ptr_edge, *boundary_edge1, *boundary_edge2 = NULL,
*boundary_split_edge;
CubitPoint *other_boundary_point;
boundary_edge1 = NULL;
if( boundary_edge1 == NULL ){
boundary_edge1 = ptr_edge;
else{
boundary_edge2 = ptr_edge;
break;
CubitFacetEdgeData *boundary_edge1_data = dynamic_cast<CubitFacetEdgeData*>( boundary_edge1 );
CubitFacetEdgeData *boundary_edge2_data = dynamic_cast<CubitFacetEdgeData*>( boundary_edge2 );
if( boundary_edge1_data->length() > boundary_edge2_data->length() ){
boundary_split_edge = boundary_edge1;
else{
boundary_split_edge = boundary_edge2;
if( other_boundary_point->id() != boundary_split_edge->point(0)->id() && other_boundary_point->id() != boundary_split_edge->point(1)->id() ){
break;
split_facet_locally_along_edge( target_facet, boundary_split_edge->point(0), boundary_split_edge->point(1), boundary_split_edge, num_of_segments, facet_list, facet_edge_list, point_list );
return CUBIT_TRUE;
| CubitBoolean TDOctreeRefFace::split_facet_type_33 | ( | CubitFacet * | target_facet, |
Definition at line 270 of file TDOctreeRefFace.cpp.
// Do Nothing
// WARNING: Degenerate Case
// A triangualar surface patch is a facet.
// Skeleton should be calculated by taking circum/in center and radius.
return CUBIT_TRUE;
CubitBoolean TDOctreeRefFace::create_2dmat [private] |
Definition at line 50 of file TDOctreeRefFace.hpp.
int TDOctreeRefFace::lastCurveID [private] |
Definition at line 42 of file TDOctreeRefFace.hpp.
DLIList<int> TDOctreeRefFace::loopIndex [private] |
Definition at line 40 of file TDOctreeRefFace.hpp.
DLIList<CubitFacetEdge *>* TDOctreeRefFace::ptrCubitFacetEdgeList [private] |
Definition at line 34 of file TDOctreeRefFace.hpp.
DLIList<CubitFacet *>* TDOctreeRefFace::ptrCubitFacetList [private] |
Definition at line 36 of file TDOctreeRefFace.hpp.
DLIList<CubitPoint *>* TDOctreeRefFace::ptrCubitPointList [private] |
Definition at line 32 of file TDOctreeRefFace.hpp.
RefFace* TDOctreeRefFace::refFace [private] |
Definition at line 38 of file TDOctreeRefFace.hpp.
CubitBoolean TDOctreeRefFace::visit [private] |
Definition at line 44 of file TDOctreeRefFace.hpp.
