cgma
#include <ImprintBoundaryTool.hpp>
Definition at line 95 of file ImprintBoundaryTool.hpp.
| ImprintBoundaryTool::ImprintBoundaryTool | ( | RefFace * | ref_face_1, |
| RefFace * | ref_face_2, | ||
| double | tol = GEOMETRY_RESABS |
Definition at line 46 of file ImprintBoundaryTool.cpp.
refFacePtr1 = ref_face_1;
refFacePtr2 = ref_face_2;
myTolerance = tol;
modBound1 = CUBIT_FALSE;
modBound2 = CUBIT_FALSE;
allocatedPointData = new PointList;
allocatedLineData = new SegList;
allocatedPointLoops = new PointLoopList;
allocatedLineLoops = new SegLoopList;
allocatedMatchData = new DLIList<ImprintMatchData*>;
allocatedRefEdge = new DLIList<RefEdge*>;
Definition at line 65 of file ImprintBoundaryTool.cpp.
int ii;
for ( ii = allocatedPointData->size(); ii > 0; ii-- )
delete allocatedPointData->pop();
delete allocatedPointData;
for ( ii = allocatedLineData->size(); ii > 0; ii-- )
delete allocatedLineData->pop();
delete allocatedLineData;
for ( ii = allocatedPointLoops->size(); ii > 0; ii-- )
delete allocatedPointLoops->pop();
delete allocatedPointLoops;
for ( ii = allocatedLineLoops->size(); ii > 0; ii-- )
delete allocatedLineLoops->pop();
delete allocatedLineLoops;
for ( ii = allocatedMatchData->size(); ii > 0; ii-- )
delete allocatedMatchData->pop();
delete allocatedMatchData;
for ( ii = allocatedRefEdge->size(); ii > 0; ii-- )
RefEdge *tmp_edge_ptr = allocatedRefEdge->pop();
if ( tmp_edge_ptr->num_ref_faces() == 0 )
RefEntity *tmp_ent = CAST_TO(tmp_edge_ptr, RefEntity);
GeometryQueryTool::instance()->delete_RefEntity(tmp_ent);
| CubitBoolean ImprintBoundaryTool::are_connected | ( | RefEntity * | ent_1, |
| RefEntity * | ent_2, | ||
| RefFace * | ref_face | ||
| ) | [private] |
Definition at line 3497 of file ImprintBoundaryTool.cpp.
RefEdge *curve_cur, *curve_nex;
RefVertex *vert_cur, *vert_nex;
curve_cur = CAST_TO(ent_1, RefEdge);
curve_nex = CAST_TO(ent_2, RefEdge);
vert_cur = CAST_TO(ent_1, RefVertex);
vert_nex = CAST_TO(ent_2, RefVertex);
//just do some sanity checking first. Really shouldn't happen...
if ( !curve_cur && !vert_cur )
assert(curve_cur || vert_cur);
PRINT_ERROR("messed up logic!!!! in ImprintBoundaryTool::are_connected\n");
return CUBIT_FALSE;
if ( !curve_nex && !vert_nex )
assert(curve_nex || vert_nex);
return CUBIT_FALSE;
if ( curve_cur )
if ( curve_cur == curve_nex )
return CUBIT_TRUE;
if ( !vert_nex && curve_nex )
return CUBIT_FALSE;
if ( vert_nex && !curve_nex )
if ( curve_cur->start_vertex() == vert_nex ||
curve_cur->end_vertex() == vert_nex )
return CUBIT_TRUE;
else
return CUBIT_FALSE;
else if ( vert_cur )
if ( vert_nex == vert_cur )
return CUBIT_TRUE;
if ( !curve_nex && vert_nex )
assert(0);
PRINT_ERROR("Next and cur have same vertex in\n"
"ImprintBoundaryTool::are_connected.\n");
return CUBIT_TRUE;
else if ( vert_cur->common_ref_edge(vert_nex, ref_face) )
return CUBIT_TRUE;
else
return CUBIT_FALSE;
if ( curve_nex->start_vertex() == vert_cur ||
curve_nex->end_vertex() == vert_cur )
return CUBIT_TRUE;
else
return CUBIT_FALSE;
assert(0);
PRINT_ERROR("ImprintBoundaryTool::are_connected failed\n");
return CUBIT_FALSE;
| CubitStatus ImprintBoundaryTool::case_0_2_equal | ( | ImprintLineSegment * | seg_1, |
| ImprintLineSegment * | seg_2, | ||
| ImprintPointData * | imp_point_0, | ||
| ImprintPointData * | imp_point_1, | ||
| ImprintPointData * | imp_point_2, | ||
| ImprintPointData * | imp_point_3, | ||
| MatchType | type_1, | ||
| MatchType | type_3, | ||
| IntersectResult & | int_result, | ||
| ImprintLineSegment ** | new_segments | ||
| ) | [private] |
Definition at line 1793 of file ImprintBoundaryTool.cpp.
//Okay at this point we know that point_0 and point_2 are
//equal, and we know that point_1 doesn't match an end_point.
//We know then that this is either an L or a overlap-join.
//Test to see if point_1 is on seg_2 or point_3 is on seg_1.
//If neither then we have an L, other wise an overlap-join.
CubitBoolean point_1_on_seg_2 =CUBIT_FALSE;
CubitBoolean point_3_on_seg_1 =CUBIT_FALSE;
if ( on_interior_segment(imp_point_1, seg_2) )
point_1_on_seg_2 = CUBIT_TRUE;
if ( on_interior_segment(imp_point_3, seg_1) )
point_3_on_seg_1 = CUBIT_TRUE;
if ( !point_1_on_seg_2 && !point_3_on_seg_1 )
PRINT_DEBUG_129("Found L_INTERSECT_0_2\n");
int_result = L_INTERSECT_0_2;
set_type_for_L(imp_point_0, imp_point_2);
return CUBIT_SUCCESS;
else if (point_1_on_seg_2 )
if (type_1 == MATCH_1_6 )
double dist_1 = (imp_point_1->coordinates() -
seg_2->get_prev()->get_start()->coordinates()).length_squared();
CubitVector point_on_seg_2;
closest_point_interior_seg(imp_point_1, seg_2, point_on_seg_2);
double dist_2 = (imp_point_1->coordinates() - point_on_seg_2).length_squared();
if ( dist_1 < dist_2 )
else if (type_1 == MATCH_1_7 )
seg_2->get_next()->get_end()->coordinates()).length_squared();
else if (point_3_on_seg_1 )
if (type_3 == MATCH_3_4 )
double dist_1 = (imp_point_3->coordinates() -
seg_1->get_prev()->get_start()->coordinates()).length_squared();
CubitVector point_on_seg_1;
closest_point_interior_seg(imp_point_3, seg_1, point_on_seg_1);
double dist_2 = (imp_point_3->coordinates() - point_on_seg_1).length_squared();
else if (type_3 == MATCH_3_5 )
seg_1->get_next()->get_end()->coordinates()).length_squared();
if ( point_1_on_seg_2 )
//This is an overlap_join.
PRINT_DEBUG_129("Found OVERALP_JOIN_02_1_3\n");
int_result = OVERLAP_JOIN_02_1_3;
//Create the new segments, the first segment remains the same so
//leave positions 0 and 1 empty.
ImprintLineSegment *new_seg_2_1, *new_seg_1_3;
//copy point 1 to use on segment 2
CubitVector closest_point;
closest_point_seg( imp_point_1, seg_2, closest_point);
ImprintPointData *new_point_1 = new ImprintPointData(imp_point_1, closest_point);
new_point_1->owner(seg_2->owner());
allocatedPointData->append(new_point_1);
if ( imp_point_1->is_owner_vertex() )
new_point_1->set_point_type(CREATE_NEW_VERTEX);
if ( imp_point_1->get_point_type() != CREATE_NEW_VERTEX )
imp_point_1->set_point_type(VERTEX_ON_BOTH_BOUNDARIES);
else
new_point_1->set_point_type(ON_BOTH_BOUNDARIES);
imp_point_1->set_point_type(ON_BOTH_BOUNDARIES);
new_seg_2_1 = new ImprintLineSegment(imp_point_2, new_point_1,
seg_2->owner());
new_seg_1_3 = new ImprintLineSegment(new_point_1, imp_point_3,
seg_2->owner());
new_segments[2] = new_seg_2_1;
new_segments[3] = new_seg_1_3;
allocatedLineData->append(new_segments[2]);
allocatedLineData->append(new_segments[3]);
//update the lists.
update_list(new_segments, seg_1, seg_2, CUBIT_FALSE);
seg_2->set_inactive(CUBIT_TRUE);
else if ( point_3_on_seg_1 )
PRINT_DEBUG_129("Found OVERALP_JOIN_02_3_1\n");
int_result = OVERLAP_JOIN_02_3_1;
ImprintLineSegment *new_seg_0_3, *new_seg_3_1;
//copy point 3 to use on segment 1
closest_point_seg( imp_point_3, seg_1, closest_point);
ImprintPointData *new_point_3 = new ImprintPointData(imp_point_3, closest_point);
new_point_3->owner(seg_1->owner());
allocatedPointData->append(new_point_3);
if ( imp_point_3->is_owner_vertex() )
new_point_3->set_point_type(CREATE_NEW_VERTEX);
if ( imp_point_3->get_point_type() != CREATE_NEW_VERTEX )
imp_point_3->set_point_type(VERTEX_ON_BOTH_BOUNDARIES);
else
new_point_3->set_point_type(ON_BOTH_BOUNDARIES);
imp_point_3->set_point_type(ON_BOTH_BOUNDARIES);
new_seg_0_3 = new ImprintLineSegment(imp_point_0, new_point_3,
seg_1->owner());
new_seg_3_1 = new ImprintLineSegment(new_point_3, imp_point_1,
seg_1->owner());
new_segments[0] = new_seg_0_3;
new_segments[1] = new_seg_3_1;
allocatedLineData->append(new_segments[0]);
allocatedLineData->append(new_segments[1]);
//update the lists
update_list(new_segments, seg_1, seg_2, CUBIT_TRUE);
seg_1->set_inactive(CUBIT_TRUE);
else
//For this case we must have an L condition.
| CubitStatus ImprintBoundaryTool::case_0_3_equal | ( | ImprintLineSegment * | seg_1, |
| MatchType | type_2, | ||
| ) | [private] |
Definition at line 1974 of file ImprintBoundaryTool.cpp.
//Okay at this point we know that point_0 and point_3 are
//Test to see if point_1 is on seg_2 or point_2 is on seg_1.
CubitBoolean point_2_on_seg_1 =CUBIT_FALSE;
if ( on_interior_segment(imp_point_2, seg_1) )
point_2_on_seg_1 = CUBIT_TRUE;
if ( !point_1_on_seg_2 && !point_2_on_seg_1 )
PRINT_DEBUG_129("Found L_INTERSECT_0_3\n");
int_result = L_INTERSECT_0_3;
set_type_for_L(imp_point_0, imp_point_3);
else if (point_2_on_seg_1 )
if (type_2 == MATCH_2_4 )
double dist_1 = (imp_point_2->coordinates() -
closest_point_interior_seg(imp_point_2, seg_1, point_on_seg_1);
double dist_2 = (imp_point_2->coordinates() - point_on_seg_1).length_squared();
else if (type_2 == MATCH_2_5 )
PRINT_DEBUG_129("Found OVERALP_JOIN_03_1_2\n");
//double dist = (imp_point_1->coordinates() - imp_point_2->coordinates()).length();
int_result = OVERLAP_JOIN_03_1_2;
else
seg_2->owner());
seg_2->owner());
//update the list.
else if ( point_2_on_seg_1 )
PRINT_DEBUG_129("Found OVERALP_JOIN_03_2_1\n");
int_result = OVERLAP_JOIN_03_2_1;
ImprintLineSegment *new_seg_0_2, *new_seg_2_1;
closest_point_seg( imp_point_2, seg_1, closest_point);
ImprintPointData *new_point_2 = new ImprintPointData(imp_point_2, closest_point);
new_point_2->owner(seg_1->owner());
allocatedPointData->append(new_point_2);
if ( imp_point_2->is_owner_vertex() )
new_point_2->set_point_type(CREATE_NEW_VERTEX);
if ( imp_point_2->get_point_type() != CREATE_NEW_VERTEX )
imp_point_2->set_point_type(VERTEX_ON_BOTH_BOUNDARIES);
else
new_point_2->set_point_type(ON_BOTH_BOUNDARIES);
imp_point_2->set_point_type(ON_BOTH_BOUNDARIES);
new_seg_0_2 = new ImprintLineSegment(imp_point_0, new_point_2,
seg_1->owner());
new_seg_2_1 = new ImprintLineSegment(new_point_2, imp_point_1,
seg_1->owner());
new_segments[0] = new_seg_0_2;
new_segments[1] = new_seg_2_1;
//update the list.
else
| CubitStatus ImprintBoundaryTool::case_1_2_equal | ( | ImprintLineSegment * | seg_1, |
| MatchType | type_0, | ||
| ) | [private] |
Definition at line 2158 of file ImprintBoundaryTool.cpp.
//Okay at this point we know that point_1 and point_2 are
//equal, and we know that point_0 doesn't match an end_point.
//Test to see if point_0 is on seg_2 or point_3 is on seg_1.
CubitBoolean point_0_on_seg_2 =CUBIT_FALSE;
if ( on_interior_segment(imp_point_0, seg_2) )
point_0_on_seg_2 = CUBIT_TRUE;
if ( !point_0_on_seg_2 && !point_3_on_seg_1 )
PRINT_DEBUG_129("Found L_INTERSECT_1_2\n");
int_result = L_INTERSECT_1_2;
set_type_for_L(imp_point_1, imp_point_2);
else if (point_0_on_seg_2 )
if (type_0 == MATCH_0_6 )
double dist_1 = (imp_point_0->coordinates() -
closest_point_interior_seg(imp_point_0, seg_2, point_on_seg_2);
double dist_2 = (imp_point_0->coordinates() - point_on_seg_2).length_squared();
else if (type_0 == MATCH_0_7 )
if ( point_0_on_seg_2 )
PRINT_DEBUG_129("Found OVERALP_JOIN_12_0_3\n");
int_result = OVERLAP_JOIN_12_0_3;
ImprintLineSegment *new_seg_2_0, *new_seg_0_3;
closest_point_seg( imp_point_0, seg_2, closest_point);
ImprintPointData *new_point_0 = new ImprintPointData(imp_point_0, closest_point);
new_point_0->owner(seg_2->owner());
allocatedPointData->append(new_point_0);
if ( imp_point_0->is_owner_vertex() )
new_point_0->set_point_type(CREATE_NEW_VERTEX);
if ( imp_point_0->get_point_type() != CREATE_NEW_VERTEX )
imp_point_0->set_point_type(VERTEX_ON_BOTH_BOUNDARIES);
else
new_point_0->set_point_type(ON_BOTH_BOUNDARIES);
imp_point_0->set_point_type(ON_BOTH_BOUNDARIES);
new_seg_2_0 = new ImprintLineSegment(imp_point_2, new_point_0,
seg_2->owner());
new_seg_0_3 = new ImprintLineSegment(new_point_0, imp_point_3,
seg_2->owner());
new_segments[2] = new_seg_2_0;
new_segments[3] = new_seg_0_3;
//update the list.
PRINT_DEBUG_129("Found OVERALP_JOIN_12_3_0\n");
int_result = OVERLAP_JOIN_12_3_0;
ImprintLineSegment *new_seg_3_1, *new_seg_0_3;
else
seg_1->owner());
seg_1->owner());
//update the list.
else
| CubitStatus ImprintBoundaryTool::case_1_3_equal | ( | ImprintLineSegment * | seg_1, |
| ) | [private] |
Definition at line 2489 of file ImprintBoundaryTool.cpp.
//Okay at this point we know that point_1 and point_3 are
//Test to see if point_0 is on seg_2 or point_2 is on seg_1.
//First test to see if they are are on the segments.
if ( !point_0_on_seg_2 && !point_2_on_seg_1 )
PRINT_DEBUG_129("Found L_INTERSECT_1_3\n");
int_result = L_INTERSECT_1_3;
set_type_for_L(imp_point_1, imp_point_3);
//Now resolve if there is a closer match to one of the other
//points.
PRINT_DEBUG_129("Found OVERLAP_JOIN_13_0_2\n");
int_result = OVERLAP_JOIN_13_0_2;
//copy point 0 to use on segment 2
else
seg_2->owner());
seg_2->owner());
//update the list.
PRINT_DEBUG_129("Found OVERLAP_JOIN_13_2_0\n");
int_result = OVERLAP_JOIN_13_2_0;
//copy point 2 to use on segment 1
else
seg_1->owner());
seg_1->owner());
//update the list.
else
| CubitBoolean ImprintBoundaryTool::closest_point_interior_seg | ( | ImprintPointData * | point, |
| ImprintLineSegment * | line, | ||
| CubitVector & | closest_point | ||
| ) | [private] |
Definition at line 2789 of file ImprintBoundaryTool.cpp.
//Find the closest point between this line and the point.
double node[3];
double point_0[3], point_1[3];
CubitVector point_v = point->coordinates();
node[0] = point_v.x();
node[1] = point_v.y();
node[2] = point_v.z();
CubitVector start_v = line->get_start()->coordinates();
CubitVector end_v = line->get_end()->coordinates();
point_0[0] = start_v.x();
point_0[1] = start_v.y();
point_0[2] = start_v.z();
point_1[0] = end_v.x();
point_1[1] = end_v.y();
point_1[2] = end_v.z();
//use geometry_resabs rather than tolerance to get more accuracy.
IntersectionTool new_tool(GEOMETRY_RESABS);
double t;
double dist = new_tool.distance_point_line(node, point_0,
point_1, t);
if ( dist < 0.0 )
return CUBIT_FALSE;
else
CubitVector p_0_1 = end_v - start_v;
closest_point = start_v + t*p_0_1;
return CUBIT_TRUE;
| CubitStatus ImprintBoundaryTool::closest_point_seg | ( | ImprintPointData * | point, |
| ) | [private] |
Definition at line 2824 of file ImprintBoundaryTool.cpp.
double node[3];
double t;
point_1, t);
if ( dist < 0.0 )
//This happens if the point is beyond the line segment, in which
//case we just want the closer end point.
if ( t < 0.0 )
closest_point = start_v;
else
closest_point = end_v;
else
| CubitStatus ImprintBoundaryTool::closest_point_seg | ( | CubitVector & | point_v, |
| ) | [private] |
Definition at line 2868 of file ImprintBoundaryTool.cpp.
double node[3];
double t;
point_1, t);
if ( dist < 0.0 )
if ( t < 0.0 )
else
else
| CubitStatus ImprintBoundaryTool::convert_to_lines | ( | PointLoopList & | boundary_point_loops, |
| SegLoopList & | boundary_line_loops, | ||
| RefFace * | ref_face, | ||
| const CubitBoolean | boundary_1 | ||
| ) | [private] |
Definition at line 2912 of file ImprintBoundaryTool.cpp.
//This does more than just converts the boundary points to line segments. It also
//Sets up a doubily linked list through the ImprintLineSegment data structure.
//Calling codes need to make sure all this data is deleted.
//This function also sets the PointType for each of the boundary points. This
//will depend also on the boundary_1 flag. If we are doing boundary_1 then,
//the flag will be true, otherwise it will be false.
int ii, jj;
PointList *point_list;
SegList *segment_list;
ImprintLineSegment *new_line, *prev = NULL;
RefEntity *entity_start, *entity_end, *seg_owner;
boundary_point_loops.reset();
PointType vertex_on_boundary, on_boundary;
if ( boundary_1 )
vertex_on_boundary = VERTEX_ON_BOUNDARY_1;
on_boundary = ON_BOUNDARY_1;
else
vertex_on_boundary = VERTEX_ON_BOUNDARY_2;
on_boundary = ON_BOUNDARY_2;
for ( ii = boundary_point_loops.size(); ii > 0; ii-- )
point_list = boundary_point_loops.get_and_step();
segment_list = new SegList;
prev = NULL;
new_line = NULL;
seg_owner = NULL;
for ( jj = point_list->size(); jj > 0; jj-- )
entity_start = point_list->get()->owner();
entity_end = point_list->next()->owner();
seg_owner = CAST_TO(entity_start, RefEdge);
if ( seg_owner == NULL )
seg_owner = CAST_TO(entity_end, RefEdge);
RefVertex *ref_vert_end = CAST_TO(entity_end, RefVertex);
RefVertex *ref_vert_start = CAST_TO(entity_start, RefVertex);
DLIList <RefEdge*> common_edges;
ref_vert_start->common_ref_edges(ref_vert_end,
common_edges,
ref_face);
if ( common_edges.size() == 0 )
PRINT_ERROR("ImprintBoundaryTool::convert_to_lines having problem finding owner of boundary\n"
"segment.\n");
return CUBIT_FAILURE;
if ( common_edges.size() == 1 )
seg_owner = common_edges.get();
else
//Now we have to decide which of these edges is the one.
//Lets take a mid point on this segment and check the distances.
//First find the mid_point of the line segment.
CubitVector start = point_list->get()->coordinates();
CubitVector end = point_list->next()->coordinates();
CubitVector mid = (start+end)/2.0;
//Now test the edges to see which is closest.
RefEdge *closest_edge = NULL, *curr_ref_edge;
double min_dist = CUBIT_DBL_MAX, dist;
int kk;
for ( kk = common_edges.size(); kk > 0; kk-- )
curr_ref_edge = common_edges.get_and_step();
curr_ref_edge->closest_point(mid, closest_point);
dist = (mid - closest_point).length_squared();
if ( dist < min_dist )
min_dist = dist;
closest_edge = curr_ref_edge;
if ( closest_edge == NULL )
PRINT_ERROR("Problems determining segment ownwership.\n"
"Internal problem with virtual imprinting.\n");
boundary_line_loops.clean_out();
seg_owner = closest_edge;
new_line = new ImprintLineSegment( point_list->get(), point_list->next(), seg_owner);
allocatedLineData->append(new_line);
//Now for use later on, set the point type. This will be useful
//when we get to the intersection parts.
if ( CAST_TO(entity_start, RefEdge) != NULL )
new_line->get_start()->set_point_type(on_boundary);
else {
assert( CAST_TO(entity_start, RefVertex) != NULL );
new_line->get_start()->set_point_type(vertex_on_boundary);
if ( CAST_TO(entity_end, RefEdge) != NULL )
new_line->get_end()->set_point_type(on_boundary);
else {
assert( CAST_TO(entity_end, RefVertex) != NULL );
new_line->get_end()->set_point_type(vertex_on_boundary);
point_list->step();
segment_list->append(new_line);
if ( prev != NULL )
prev->set_next(new_line);
new_line->set_prev(prev);
prev = new_line;
if ( prev != NULL )
segment_list->reset();
assert(prev == segment_list->prev());
segment_list->prev()->set_next(segment_list->get());
segment_list->get()->set_prev(segment_list->prev());
assert(segment_list->get()->get_next() != NULL );
if ( segment_list->size() )
boundary_line_loops.append(segment_list);
allocatedLineLoops->append(segment_list);
else
delete segment_list;
| RefEdge * ImprintBoundaryTool::create_virtual_edge | ( | RefVertex * | start, |
| RefVertex * | end, | ||
| DLIList< CubitVector * > & | interior_points | ||
| ) | [private] |
Determine if the match should be ingored or not (if creating the match would make the loop self intersect.)
Definition at line 5949 of file ImprintBoundaryTool.cpp.
//Create CubitPoints for all of these locations.
DLIList<CubitPoint*> point_list;
CubitPoint *start_p = (CubitPoint*) new CubitPointData(start->coordinates());
CubitPoint *end_p = (CubitPoint*) new CubitPointData(end->coordinates());
CubitPoint *new_point, *prev_point;
int ii;
CubitVector *curr_pos;
interior_points.reset();
CubitFacetEdge *new_edge;
prev_point = start_p;
DLIList<CubitFacetEdge*> edge_list;
point_list.append(start_p);
for ( ii = 0; ii < interior_points.size(); ii++ )
curr_pos = interior_points.get_and_step();
new_point = (CubitPoint*) new CubitPointData(*curr_pos);
point_list.append(new_point);
new_edge = (CubitFacetEdge*) new CubitFacetEdgeData(prev_point,
new_point);
edge_list.append(new_edge);
prev_point = new_point;
//create the last edge.
end_p);
point_list.append(end_p);
CurveFacetEvalTool *curve_facet_tool = new CurveFacetEvalTool;
CubitStatus status = curve_facet_tool->initialize( edge_list, point_list );
if ( status != CUBIT_SUCCESS )
PRINT_ERROR("Error in creating new facet curve.\n");
return NULL;
bool start_vertex_is_free = true;
if( start->num_parent_ref_entities() )
start_vertex_is_free = false;
bool end_vertex_is_free = true;
if( end->num_parent_ref_entities() )
end_vertex_is_free = false;
DLIList<CoEdgeSM*> coedgesms;
GeometryEntity *ge = start->get_geometry_entity_ptr();
TBPoint *start_psm = CAST_TO(ge, TBPoint);
ge = end->get_geometry_entity_ptr();
TBPoint *end_psm = CAST_TO(ge, TBPoint);
assert(start_psm && end_psm);
FacetCurve *new_facet_curve = new FacetCurve(curve_facet_tool,
start_psm,
end_psm, coedgesms);
if ( new_facet_curve == NULL )
assert(new_facet_curve != NULL);
return (RefEdge*)NULL;
//if vertices are consumed....notify that they are gone.
if( start_vertex_is_free )
AppUtil::instance()->send_event(GeometryEvent(GeometryEvent::TOP_LEVEL_ENTITY_DESTRUCTED, start) );
if( end_vertex_is_free )
AppUtil::instance()->send_event(GeometryEvent(GeometryEvent::TOP_LEVEL_ENTITY_DESTRUCTED, end));
Curve *new_curve_ptr = (Curve*) new_facet_curve;
return GeometryQueryTool::instance()->make_RefEdge(new_curve_ptr);
| RefVertex * ImprintBoundaryTool::create_virtual_vertex | ( | CubitVector & | pos | ) | [private] |
Definition at line 5932 of file ImprintBoundaryTool.cpp.
//Create a facet point first.
TBPoint *new_point;
if ( FacetModifyEngine::instance()->make_facet_point(pos, new_point)
!= CUBIT_SUCCESS )
PRINT_ERROR("Vertex creation failed.\n");
return (RefVertex*)NULL;
return GeometryQueryTool::instance()->make_free_RefVertex(new_point);
| CubitStatus ImprintBoundaryTool::determine_on_boundary | ( | ImprintLineSegment * | seg_1, |
| MatchType & | type_0, | ||
| MatchType & | type_1, | ||
| MatchType & | type_2, | ||
| MatchType & | type_3 | ||
| ) | [private] |
Definition at line 2339 of file ImprintBoundaryTool.cpp.
//Find out if the points are on the boundary. Also use the matching informatin
//previously calculated, since some of the nodes may match more closely with
//other nodes on the boundary. For instance, if the boundary does a quick
//reversal, a point may match an existing point better than here.
//If the points should be on the segment, set the matchtype flags accordingly.
ImprintPointData* imp_point_0,*imp_point_1,*imp_point_2,*imp_point_3;
imp_point_0 = seg_1->get_start();
imp_point_1 = seg_1->get_end();
imp_point_2 = seg_2->get_start();
imp_point_3 = seg_2->get_end();
if ( type_0 == MATCH_0_6 )
type_0 = NO_MATCH;
else
type_0 = ON_SEG_2;
type_0 = NO_MATCH;
else
type_0 = ON_SEG_2;
else
type_0 = ON_SEG_2;
if ( type_1 == MATCH_1_6 )
type_1 = NO_MATCH;
else
type_1 = ON_SEG_2;
type_1 = NO_MATCH;
else
type_1 = ON_SEG_2;
else
type_1 = ON_SEG_2;
if ( type_2 == MATCH_2_4 )
type_2 = NO_MATCH;
else
type_2 = ON_SEG_1;
type_2 = NO_MATCH;
else
type_2 = ON_SEG_1;
else
type_2 = ON_SEG_1;
if ( type_3 == MATCH_3_4 )
type_3 = NO_MATCH;
else
type_3 = ON_SEG_1;
type_3 = NO_MATCH;
else
type_3 = ON_SEG_1;
else
type_3 = ON_SEG_1;
| CubitStatus ImprintBoundaryTool::do_crossing | ( | ImprintPointData * | imp_point_0, |
| ImprintLineSegment *& | seg_1, | ||
| ImprintLineSegment ** | surf_1_loop_heads, | ||
| int | num_loops_1, | ||
| ImprintLineSegment ** | surf_2_loop_heads, | ||
| int | num_loops_2, | ||
| AbstractTree< ImprintLineSegment * > & | atree, | ||
| CubitBoolean & | modified | ||
| ) | [private] |
Definition at line 5553 of file ImprintBoundaryTool.cpp.
//Okay, Test for the cross intersection. If this isnt'
//within tolerance, then these two segments couldn't
//posibly intersect!
IntersectionTool int_tool(GEOMETRY_RESABS); //use GEOMETRY_RESABS
//rather than myTolerance for calculations...
CubitVector point_0 = imp_point_0->coordinates();
CubitVector point_1 = imp_point_1->coordinates();
CubitVector point_2 = imp_point_2->coordinates();
CubitVector point_3 = imp_point_3->coordinates();
CubitVector closest_point_seg_1, closest_point_seg_2;
double sc, tc;
CubitStatus stat = int_tool.closest_points_on_segments(point_0, point_1,
point_2, point_3,
closest_point_seg_2,
sc, tc);
if (stat != CUBIT_SUCCESS )
PRINT_ERROR("Problems calculation closest points on "
"segments for boundary imprinting.\n");
//Make sure the closest points aren't the end points. If they are
//and we are within tolerance, it may be that the tolerance is too big
//cause we shouldn't be at a cross if the closest point is an end point...
if ( sc > 0. && sc < 1. && tc > 0. && tc < 1. &&
closest_point_seg_1.within_tolerance(closest_point_seg_2,myTolerance) )
ImprintLineSegment *new_segments[4];
//okay, these guys actually do intersect!
PRINT_DEBUG_129("Found CROSS_INTERSECT\n");
int debug = 0;
if ( debug )
GfxDebug::clear();
draw_point(imp_point_0);
draw_point(imp_point_1);
draw_point(imp_point_2);
draw_point(imp_point_3);
draw_seg(seg_1, CUBIT_RED_INDEX);
draw_seg(seg_2, CUBIT_YELLOW_INDEX);
GfxDebug::mouse_xforms();
ImprintPointData *new_point_seg_1, *new_point_seg_2;
new_point_seg_1 = new ImprintPointData(closest_point_seg_1.x(),
closest_point_seg_1.y(),
closest_point_seg_1.z());
allocatedPointData->append(new_point_seg_1);
new_point_seg_1->owner(seg_1->owner());
new_point_seg_1->set_point_type(CREATE_NEW_VERTEX);
new_point_seg_2 = new ImprintPointData(closest_point_seg_2.x(),
closest_point_seg_2.y(),
closest_point_seg_2.z());
allocatedPointData->append(new_point_seg_2);
new_point_seg_2->owner(seg_2->owner());
new_point_seg_2->set_point_type(CREATE_NEW_VERTEX);
new_point_seg_2->set_matching_point(new_point_seg_1);
new_point_seg_1->set_matching_point(new_point_seg_2);
new_segments[0] = new ImprintLineSegment(imp_point_0, new_point_seg_1,
seg_1->owner());
new_segments[1] = new ImprintLineSegment(new_point_seg_1, imp_point_1,
seg_1->owner());
new_segments[2] = new ImprintLineSegment(imp_point_2, new_point_seg_2,
seg_2->owner());
new_segments[3] = new ImprintLineSegment(new_point_seg_2, imp_point_3,
seg_2->owner());
//now update the lists.
//update list 1.
//update list 2.
//seg_1 and seg_2 will no longer be used
//update the atree for the second surface.
atree.remove(seg_2);
atree.add(new_segments[2]);
atree.add(new_segments[3]);
//update the loop heads
int jj;
for (jj = 0; jj < num_loops_1;jj++ )
if ( surf_1_loop_heads[jj] == seg_1 )
surf_1_loop_heads[jj] = new_segments[0];
for (jj = 0; jj < num_loops_2;jj++ )
if ( surf_2_loop_heads[jj] == seg_2 )
surf_2_loop_heads[jj] = new_segments[2];
//now set seg_1 equal to new_segments[0]
//so that we continue looping properly.
seg_1 = new_segments[0];
modified = CUBIT_TRUE;
| void ImprintBoundaryTool::draw_end | ( | ImprintLineSegment * | seg | ) | [private] |
Definition at line 4139 of file ImprintBoundaryTool.cpp.
ImprintPointData *end = seg->get_end();
CubitPoint *point = (CubitPoint*) end;
PointType p_type = end->get_point_type();
int color;
switch ( p_type )
case VERTEX_ON_BOUNDARY_1:
color = CUBIT_RED_INDEX;
break;
case VERTEX_ON_BOUNDARY_2:
color = CUBIT_ORANGE_INDEX;
break;
case VERTEX_ON_BOTH_BOUNDARIES:
color = CUBIT_MAGENTA_INDEX;
break;
case CREATE_NEW_VERTEX:
color = CUBIT_CYAN_INDEX;
break;
case ON_BOUNDARY_1:
color = CUBIT_GREEN_INDEX;
break;
case ON_BOUNDARY_2:
color = CUBIT_YELLOW_INDEX;
break;
case ON_BOTH_BOUNDARIES:
color = CUBIT_BLUE_INDEX;
break;
default:
color = CUBIT_BROWN_INDEX;
int id_val = point->id();
GfxDebug::draw_label(id_val, point->x(), point->y(), point->z(), color);
GfxDebug::flush();
| void ImprintBoundaryTool::draw_loops | ( | PointLoopList & | boundary_loop | ) | [private] |
Definition at line 4085 of file ImprintBoundaryTool.cpp.
int ii, jj;
ImprintPointData *imp_point;
for (ii = 0; ii < boundary_loops.size(); ii++ )
point_list = boundary_loops.get_and_step();
for ( jj = 0; jj < point_list->size(); jj++ )
imp_point = point_list->get_and_step();
draw_point(imp_point);
| void ImprintBoundaryTool::draw_point | ( | ImprintPointData * | imp_point, |
| int | color = -1 |
| ) | [private] |
Definition at line 4101 of file ImprintBoundaryTool.cpp.
CubitPoint *point = (CubitPoint*) imp_point;
PointType p_type = imp_point->get_point_type();
if (color == -1 )
switch ( p_type )
break;
break;
break;
break;
case ON_BOUNDARY_1:
break;
case ON_BOUNDARY_2:
break;
break;
default:
// point->draw(color);
GfxDebug::flush();
| void ImprintBoundaryTool::draw_seg | ( | ImprintLineSegment * | seg, |
| int | color = -1 |
| ) | [private] |
Definition at line 4074 of file ImprintBoundaryTool.cpp.
CubitVector start_point = seg->get_start()->coordinates();
CubitVector end_point = seg->get_end()->coordinates();
if ( color == -1 )
GfxDebug::draw_line( start_point.x(),start_point.y(),start_point.z(),
end_point.x(),end_point.y(),end_point.z(),
color);
GfxDebug::flush();
| CubitStatus ImprintBoundaryTool::final_match | ( | ImprintLineSegment ** | surf_1_loop_heads, |
| AbstractTree< ImprintLineSegment * > & | atree_1, | ||
| AbstractTree< ImprintLineSegment * > & | atree_2 | ||
| ) | [private] |
Definition at line 5017 of file ImprintBoundaryTool.cpp.
CubitStatus stat;
//Match the points on surface 1 with the points on surface 2.
//Resolve cases where more than 1 point match to another point.
//Also resolve where a point on surface 1 matches with a segment
//on surface 2. This will possibly alter the loop_heads of surface 2,
//and the atree of surface2.
stat = final_match_loop( surf_1_loop_heads, num_loops_1,
surf_2_loop_heads, num_loops_2,
atree_1, atree_2);
return stat;
//Now match the points on surface 2 with surface 1.
//This should go faster since hopefully they were done
//at once. But there will be points that match with segments
//that are left...
//This will possibly alter the loop_heads of surface 1 and
//the atree of surface1.
stat = final_match_loop( surf_2_loop_heads, num_loops_2,
atree_2, atree_1);
return stat;
| CubitStatus ImprintBoundaryTool::final_match_loop | ( | ImprintLineSegment ** | surf_1_loop_heads, |
| ) | [private] |
Definition at line 5049 of file ImprintBoundaryTool.cpp.
int ii;
ImprintLineSegment *prev_seg, *curr_seg;
CubitBoolean first = CUBIT_TRUE;
ImprintPointData *start_point;
DLIList<ImprintMatchData*> match_data_list;
ImprintMatchData *start_match;
CubitStatus stat;
for(ii = 0; ii < num_loops_1; ii++ )
prev_seg = surf_1_loop_heads[ii]->get_prev();
first = CUBIT_TRUE;
while(prev_seg != surf_1_loop_heads[ii]->get_prev() || first )
first = CUBIT_FALSE;
curr_seg = prev_seg->get_next();
if ( DEBUG_FLAG(129) )
draw_seg(curr_seg, CUBIT_GREEN_INDEX);
//Setup the next itteration.
prev_seg = curr_seg;
//Now on to the algorithm
//Just check the start point for each segment (so that
//we don't do each point more than once!
start_point = curr_seg->get_start();
if ( start_point->get_matching_point() != NULL )
continue;
//Get the match data.
match_data_list.clean_out();
start_point->get_match_list(match_data_list);
if ( match_data_list.size() == 0 )
start_match = NULL;
else if ( match_data_list.size() == 1 )
start_match = match_data_list.get();
else
PRINT_ERROR("Unresolved match data in final match section. This\n"
"is a bug!. Please report it.\n");
if ( start_match )
CubitBoolean ignore = CUBIT_FALSE;
if ( ignore_match(start_point, start_match, atree_1, ignore)
!= CUBIT_SUCCESS )
if ( ignore )
continue;
if ( start_match->get_closest_point() != NULL )
stat = match_on_point(start_point, start_match,
atree_2);
if ( stat != CUBIT_SUCCESS )
else if ( start_match->get_point_on() != NULL )
//split the segment with start point and update
//the loops heads for surf_2 if it is changed.
stat = match_on_segment(start_point, start_match,
atree_2);
return stat;
else
//There really can't be anything else at this point. Either
//it matches with a node, or it matches on a segment.
PRINT_ERROR("Problems with point matching logic in imprinting.\n");
PRINT_ERROR("MatchData found without closest point or segment.\n");
PRINT_ERROR("Internal Imprint Problem, Please Report.\n");
| CubitStatus ImprintBoundaryTool::find_closest_points | ( | ImprintLineSegment * | curr_seg, |
| ImprintLineSegment * | test_seg | ||
| ) | [private] |
Definition at line 4782 of file ImprintBoundaryTool.cpp.
//Given the two
ImprintPointData *curr_data_a, *curr_data_b;
curr_data_a = curr_seg->get_start();
curr_data_b = curr_seg->get_end();
ImprintMatchData *point_a_match = NULL;
ImprintMatchData *point_b_match = NULL;
CubitStatus stat1 = match_seg_points(curr_seg, test_seg, point_a_match,
point_b_match);
if ( stat1 != CUBIT_SUCCESS )
return stat1;
if ( !curr_data_a->is_matched() &&
point_a_match != NULL )
curr_data_a->add_match_data(point_a_match);
if ( !curr_data_b->is_matched() &&
point_b_match != NULL )
curr_data_b->add_match_data(point_b_match);
| CubitStatus ImprintBoundaryTool::find_crossings | ( | ImprintLineSegment ** | surf_1_loop_heads, |
| AbstractTree< ImprintLineSegment * > & | atree | ||
| ) | [private] |
Definition at line 5482 of file ImprintBoundaryTool.cpp.
int ii, jj;
ImprintLineSegment *curr_seg, *prev_seg, *test_seg;
DLIList <ImprintLineSegment*> close_segments;
CubitBox curr_box;
ImprintPointData *imp_point_0, *imp_point_1;
ImprintPointData *imp_point_2, *imp_point_3;
first = CUBIT_TRUE;
curr_box = curr_seg->bounding_box();
close_segments.clean_out();
atree.find(curr_box, close_segments);
imp_point_0 = curr_seg->get_start();
imp_point_1 = curr_seg->get_end();
for ( jj = 0; jj < close_segments.size(); jj++ )
test_seg = close_segments.pop();
imp_point_2 = test_seg->get_start();
imp_point_3 = test_seg->get_end();
//don't test if these already match.
if ( imp_point_0->get_matching_point() == imp_point_2 ||
imp_point_0->get_matching_point() == imp_point_3 ||
imp_point_1->get_matching_point() == imp_point_2 ||
imp_point_1->get_matching_point() == imp_point_3 )
continue;
CubitBoolean modified = CUBIT_FALSE;
//Test and resolve. Note that only one of the atrees
//is getting updated (this atree is for surface 2. )
//The loop heads are updated, and curr_seg will
//get modified if the a crossing intersect occurs.
CubitStatus stat = do_crossing( imp_point_0, imp_point_1,
imp_point_2, imp_point_3,
curr_seg, test_seg,
atree, modified );
if ( modified )
//curr_seg was modified in the do_crossing (the original
//was split.). Make sure we start again to check for
//crossings with this item. To do that, set prev seg
//to it's previous segment. The result is that the next
//time through it will be curr_seg.
prev_seg = curr_seg->get_prev();
| CubitStatus ImprintBoundaryTool::find_graph_for_surf | ( | PointLoopList & | boundary_loops_1, |
| PointLoopList & | boundary_loops_2, | ||
| PointLoopList & | part_segs, | ||
| PointList & | partition_points, | ||
| CubitBoolean | surf_1 | ||
| ) | [private] |
Definition at line 3067 of file ImprintBoundaryTool.cpp.
//Traverse the boundary_line_loops_2.
//First search for intersections. If an intersection is found,
//traverse from there until another intersection is found.
//If no intersection is found for a loop, test to see if the
//nodes lie inside the surface. If they do, then the intire loop
//should be used for partitioning.
int ii, jj;
//ASSUME my boundary is loop_2.
CubitBoolean start_recording = CUBIT_FALSE;
CubitBoolean found_start = CUBIT_FALSE;
PointList *loop_1_ptr, *loop_2_ptr, *new_part_line;
ImprintPointData *curr_point, *next_point;
for ( ii = boundary_loops_2.size(); ii > 0; ii-- )
loop_2_ptr = boundary_loops_2.get_and_step();
new_part_line = NULL;
//find a good place to start. It messes things
//up if we start the loop at a non-meeting spot.
for ( jj = loop_2_ptr->size(); jj > 0; jj-- )
curr_point = loop_2_ptr->get_and_step();
if ( curr_point->get_point_type() == CREATE_NEW_VERTEX ||
curr_point->get_point_type() == VERTEX_ON_BOTH_BOUNDARIES )
loop_2_ptr->back();
found_start = CUBIT_TRUE;
break;
if ( found_start )
next_point = loop_2_ptr->get();
draw_point(curr_point);
CubitStatus stat;
//This section of the code just got too big. So it may change
//the loop_2_ptr position, the loop counter jj and other things.
stat = point_intersects_case( curr_point, next_point,
ref_face,
part_segs, new_part_line,
start_recording, surf_1 );
if (CUBIT_SUCCESS != stat) {
PRINT_ERROR("ImprintBoundaryTool::point_intersects_case failed.\n");
return stat;
else
if (start_recording)
if ( !new_part_line )
PRINT_ERROR("Bad Logic ImprintBoundaryTool::find_graph_for_surf.\n");
assert(new_part_line != NULL);
CubitBox surf_box = ref_face->bounding_box();
CubitBox curr_box(curr_point->coordinates());
if( surf_box.overlap(myTolerance, curr_box ) &&
on_surface(curr_point, ref_face) )
new_part_line->append(curr_point);
if ( jj == 1 &&
(next_point->get_point_type() == CREATE_NEW_VERTEX ||
next_point->get_point_type() == VERTEX_ON_BOTH_BOUNDARIES) )
//Do the last node since that is where we have to go to inorder
//to stop the partitioning.
jj++;
else
//remove new_part_line from the part_segs list and
//break out of this loop.
part_segs.pop();
break;
if ( start_recording )
//This is bad news. We never should finish the loop and still
//be recording...
assert(!start_recording);
else
//Okay this is an interior hole to the ref_face. Just add the
//entire loop.
int mm;
int debug = 0;
if ( debug )
GfxDebug::clear();
GfxDebug::draw_box(surf_box, CUBIT_RED_INDEX);
GfxDebug::flush();
CubitBox curr_box;
//Getting the first point is important. Make
//sure it is a vertex.
CubitBoolean start = CUBIT_FALSE;
for ( mm = loop_2_ptr->size(); mm > 0; mm-- )
curr_box.reset(curr_point->coordinates());
if ( debug )
if ( surf_box.overlap(myTolerance,curr_box) )
if ( on_surface(curr_point, ref_face) &&
curr_point->is_owner_vertex() )
loop_2_ptr->back();
start = CUBIT_TRUE;
break;
if ( !start )
//this loop has no affect on the surface. (no points
//are on the boundary and are vertices...)
continue;
else
new_part_line = new PointList;
allocatedPointLoops->append(new_part_line);
//Test one the nodes to see if they are interior to the surface.
loop_2_ptr->get()->set_start_partition();
loop_2_ptr->get()->set_end_partition();
part_segs.append(new_part_line);
CubitBoolean valid_loop = CUBIT_TRUE;
if ( surf_box.overlap(myTolerance, curr_box) )
if ( on_surface(curr_point, ref_face) )
else
valid_loop = CUBIT_FALSE;
else
if ( !valid_loop )
//remove the part_line. The
//entire loop must go into the surface.
part_segs.pop();
//Otherwise just ignore this loop it has no affect on the ref_face.
//Okay now go through and find the points that are needed to create as imprints on the boundary.
for ( ii = boundary_loops_1.size(); ii > 0; ii-- )
loop_1_ptr = boundary_loops_1.get_and_step();
for ( jj = loop_1_ptr->size(); jj > 0; jj-- )
curr_point = loop_1_ptr->get_and_step();
if ( curr_point->get_point_type() == CREATE_NEW_VERTEX )
partition_points.append(curr_point);
//Okay, we should be set now!
| CubitStatus ImprintBoundaryTool::find_matching_points | ( | SegLoopList & | seg_loops, |
| ) | [private] |
Definition at line 4715 of file ImprintBoundaryTool.cpp.
//Loop over seg_loops. For each segment loop, find the closest matching point
//from the segments in the atree.
int ii, jj, kk;
SegList *loop_ptr;
ImprintLineSegment *curr_seg, *test_seg;
SegList close_segments;
CubitBox curr_box;
CubitStatus stat;
for ( ii = 0; ii < seg_loops.size(); ii++ )
loop_ptr = seg_loops.get_and_step();
for ( jj = 0; jj < loop_ptr->size(); jj++ )
curr_seg = loop_ptr->get_and_step();
if ( close_segments.size() == 0 )
continue;
for ( kk = 0; kk < close_segments.size(); kk++ )
test_seg = close_segments.get_and_step();
stat = find_closest_points(curr_seg, test_seg);
return stat;
//Now given those closest points,
//find the match for point 0.
if (!imp_point_0->is_matched() )
set_closest_point(imp_point_0);
//find the match for point 1.
if (!imp_point_1->is_matched() )
set_closest_point(imp_point_1);
| CubitStatus ImprintBoundaryTool::get_boundary_points | ( | RefFace * | ref_face, |
| PointLoopList & | boundary_point_loops | ||
| ) | [private] |
Definition at line 205 of file ImprintBoundaryTool.cpp.
DLIList<DLIList<CoEdge*> > co_edge_loops;
ref_face->co_edge_loops(co_edge_loops);
int ii, jj;
PointList *new_point_loop_ptr, tmp_point_list;
RefEdge *ref_edge_ptr;
CoEdge *co_edge_ptr;
CubitStatus stat;
CubitSense sense;
RefEntity *temp_ref;
RefVertex *temp_vert;
for ( ii = co_edge_loops.size(); ii > 0; ii-- )
DLIList <CoEdge*> &co_edge_list_ptr = co_edge_loops.get_and_step();
new_point_loop_ptr = new PointList;
allocatedPointLoops->append(new_point_loop_ptr);
for ( jj = co_edge_list_ptr.size(); jj > 0; jj-- )
co_edge_ptr = co_edge_list_ptr.get_and_step();
ref_edge_ptr = co_edge_ptr->get_ref_edge_ptr();
tmp_point_list.clean_out();
stat = get_curve_facets( ref_edge_ptr, tmp_point_list );
PRINT_DEBUG_129("curve %d has %d points\n",
ref_edge_ptr->id(),
tmp_point_list.size());
if ( stat != CUBIT_SUCCESS ) {
tmp_point_list.reset();
//the points are in order from start vertex to end vertex.
//append them now according to the loop.
//Assign the points to be part owned by the vertex, rather than the
//curve.
if ( ref_edge_ptr->start_vertex() !=
ref_edge_ptr->end_vertex() )
ImprintPointData *temp_point = tmp_point_list.get();
CubitVector v1 = temp_point->coordinates();
CubitVector v2 = ref_edge_ptr->start_vertex()->coordinates();
if ( !v1.within_tolerance(v2, myTolerance) )
PRINT_ERROR("Problem with surface geometry\n"
"Check surface %d and %d, especially curve %d\n",
refFacePtr1->id(), refFacePtr2->id(), ref_edge_ptr->id());
temp_vert = ref_edge_ptr->start_vertex();
temp_ref = CAST_TO(temp_vert, RefEntity);
temp_point->owner(temp_ref);
temp_point = tmp_point_list.prev();
v2 = ref_edge_ptr->end_vertex()->coordinates();
if (!v1.within_tolerance(v2, myTolerance))
temp_vert = ref_edge_ptr->end_vertex();
else
if ( !v1.about_equal(v2) )
assert(v1.about_equal(v2));
temp_ref = CAST_TO( temp_vert, RefEntity );
sense = co_edge_ptr->get_sense();
if ( CUBIT_FORWARD != sense )
tmp_point_list.reverse();
//Now take off the last point as it is a duplicate with the
//other list...
if ( co_edge_list_ptr.size() != 1 )
tmp_point_list.pop();
(*new_point_loop_ptr) += tmp_point_list;
if ( num_coedges_on_face(ref_edge_ptr, ref_face) > 1 )
PRINT_ERROR("Surface %d has a sipe or hard line.\n"
"Virtual imprinting does not support that type\n"
"of surface.\n", ref_face->id());
CubitVector curr, prev;
for ( jj = new_point_loop_ptr->size(); jj > 0; jj-- )
prev = new_point_loop_ptr->prev()->coordinates();
curr = new_point_loop_ptr->get_and_step()->coordinates();
if ( prev.about_equal(curr) )
PRINT_DEBUG_129("Points within tolerance in boundaryloop.\n");
int debug = 0;
if ( debug )
GfxDebug::draw_point(new_point_loop_ptr->prev(3)->coordinates(), CUBIT_RED_INDEX);
GfxDebug::draw_point(new_point_loop_ptr->prev(2)->coordinates(), CUBIT_YELLOW_INDEX);
GfxDebug::draw_point(new_point_loop_ptr->prev()->coordinates(), CUBIT_BLUE_INDEX);
GfxDebug::draw_point(new_point_loop_ptr->get()->coordinates(), CUBIT_GREEN_INDEX);
new_point_loop_ptr->back();
new_point_loop_ptr->remove();
boundary_point_loops.append(new_point_loop_ptr);
CubitVector curr1, curr2;
int kk, ll;
PointList *check_list;
double min_dist = CUBIT_DBL_MAX;
PointLoopList boundary_point_loops2 = boundary_point_loops;
new_point_loop_ptr = boundary_point_loops.get_and_step();
for ( kk = boundary_point_loops.size(); kk > 0; kk-- )
check_list = boundary_point_loops2.get_and_step();
if ( new_point_loop_ptr == check_list )
continue;
curr1 = new_point_loop_ptr->get_and_step()->coordinates();
for ( ll = check_list->size(); ll > 0; ll-- )
curr2 = check_list->get_and_step()->coordinates();
if (curr1.about_equal(curr2, myTolerance) )
double dist = (curr1-curr2).length();
min_dist = dist;
if ( min_dist < CUBIT_DBL_MAX && min_dist < myTolerance )
PRINT_INFO("Two loops on Surface %d are within tolerance of each other!\n",
ref_face->id());
PRINT_INFO("Changing the tolerance to less than %f\n"
"(the smallest distance between the two loops.)\n",
min_dist);
myTolerance = min_dist/4;
PRINT_INFO("For surface %d and %d tolerance changed to %f\n",
refFacePtr1->id(), refFacePtr2->id(), myTolerance);
//return CUBIT_FAILURE;
| CubitStatus ImprintBoundaryTool::get_curve_facets | ( | RefEdge * | curve, |
| PointList & | segments | ||
| ) | [private] |
Definition at line 375 of file ImprintBoundaryTool.cpp.
// const double COS_ANGLE_TOL = 0.965925826289068312213715; // cos(15)
// const double COS_ANGLE_TOL = 0.984807753012208020315654; // cos(10)
//const double COS_ANGLE_TOL = 0.996194698091745545198705; // cos(5)
GMem curve_graphics;
//make this tol bigger than myTolerance, to
//make sure the segments are larger than the tolerance.
const double dist_tol = 2*myTolerance + .5*myTolerance;// + .05*myTolerance;
//const double dist_tol_sqr = dist_tol*dist_tol;
Curve* curve_ptr = curve->get_curve_ptr();
curve_ptr->get_geometry_query_engine()->get_graphics( curve_ptr, &curve_graphics );
GPoint* gp = curve_graphics.point_list();
ImprintPointData* last = new ImprintPointData( gp[0].x, gp[0].y, gp[0].z );
allocatedPointData->append(last);
last->owner(dynamic_cast<RefEntity*>(curve));
CubitVector lastv = last->coordinates();
int num_points = curve_graphics.pointListCount;
segments.append( last );
int ii;
CubitBoolean remove_second_to_end = CUBIT_FALSE;
for ( ii = 1; ii < num_points; ii++ )
CubitVector pos( gp[ii].x, gp[ii].y, gp[ii].z );
CubitVector step1 = (pos - lastv);
double len1 = step1.length();
if( len1 < dist_tol && ii != num_points - 1)
continue;
else if ( len1 < dist_tol && ii == num_points-1 )
remove_second_to_end = CUBIT_TRUE;
last = new ImprintPointData( pos );
draw_point(last);
// Now check if the segment list is reversed wrt the curve direction.
segments.reset();
if ( remove_second_to_end )
if ( segments.size() == 2 )
PRINT_DEBUG_129("Tolerance size is small for imprinting\n"
"(curve %d is small)\n",
curve->id());
double leng = curve->measure();
if ( leng < myTolerance )
PRINT_ERROR("Tolerance for surfaces %d and %d is too small.\n"
"Curve %d is of size %f. Try making the tolerance\n"
"1/4 of that value or (%f).\n", refFacePtr1->id(),
refFacePtr2->id(), curve->id(), leng, leng/4.0);
else
//Remove the second to last one. To do
//this efficiently (don't do remove), pop
//the last one, then save that and
//re-add it after poping the second one.
ImprintPointData *temp = segments.pop();
segments.pop();
segments.append(temp);
segments.reset();
if( curve->start_vertex() != curve->end_vertex() )
CubitVector start_vec, end_vec;
start_vec = curve->start_vertex()->coordinates();
end_vec = curve->end_vertex()->coordinates();
CubitVector start_seg = segments.get()->coordinates();
double dist_1 = (start_seg - start_vec).length_squared();
double dist_2 = (start_seg - end_vec).length_squared();
if ( dist_1 > dist_2 )
segments.reverse();
//Now make sure that the start and end vertices are "right-on" with
//the facet representations...
segments.reset();
CubitVector end_seg = segments.prev()->coordinates();
//make sure the start and end positions match up "exactly"
//with the vertex coordinates of the curves. The facets sometimes
//aren't really "right-on"
segments.get()->set(start_vec);
segments.prev()->set(end_seg);
else
double u1, u2;
u1 = curve->u_from_position( (segments.next(1)->coordinates()) );
u2 = curve->u_from_position( (segments.next(2)->coordinates()) );
if( (u2 < u1) && (curve->start_param() <= curve->end_param()) )
segments.reverse();
//clean up the periodic curve case (last seg may be too small.)
if ( curve->start_vertex() == curve->end_vertex() )
segments.reset();
CubitVector start_v = segments.get()->coordinates();
CubitVector last_v = segments.prev()->coordinates();
double dist = (start_v - last_v).length();
if ( dist < dist_tol )
//remove the last one.
segments.pop();
//now make sure the one vertex matches up "exactly" with the
//first segement.
segments.reset();
CubitVector start_vec = curve->start_vertex()->coordinates();
//replace start_seg with start_vec.
//Make sure we don't have duplicate points.
int jj;
for ( jj = segments.size(); jj > 0; jj-- )
prev = segments.prev()->coordinates();
curr = segments.get_and_step()->coordinates();
PRINT_DEBUG_129("Points on curve %d within tolerance...\n", curve->id());
segments.back();
segments.remove();
if ( segments.size() < 2 )
PRINT_ERROR("Tolerance size is too small for imprinting\n"
curve->id());
| CubitStatus ImprintBoundaryTool::ignore_match | ( | ImprintPointData * | start_point, |
| ImprintMatchData * | start_match, | ||
| CubitBoolean & | ignore | ||
| ) | [private] |
Definition at line 5699 of file ImprintBoundaryTool.cpp.
ignore = CUBIT_TRUE;
//assume that start_point is in atree_1 (here 1 and 2 don't neccesaryily mean
//loopFacePtr1 and loopFacePtr2 because this is called for both faces.
//First determine what type of match, point to point or point to segment.
ImprintMatchData *temp_match;
ImprintPointData *closest_point;
DLIList <ImprintMatchData*> match_data_list;
closest_point = start_match->get_closest_point();
closest_point->get_match_list(match_data_list);
temp_match = match_data_list.get();
//if they match don't ignore this.
if ( temp_match->get_closest_point() == start_point )
else
//Now we have a conflict. Start matches with closest_point,
//but closest_point doesn't match with start.
//Find out if there is a segment in atree_1 that is closer
//to closest_point. If there isn't, then we need to
//match start with one of the two linesegments attached to closest
//point.
//If there is a closer line segment to closest_point, then don't
//match.
//First, define the search area as the area around the start_point.
ImprintLineSegment *start_prev_seg = start_point->get_prev_seg();
ImprintLineSegment *start_next_seg = start_point->get_next_seg();
CubitBox curr_box = start_prev_seg->bounding_box();
curr_box |= start_next_seg->bounding_box();
DLIList<ImprintLineSegment*> closest_segments;
atree_1.find(curr_box, closest_segments);
//Find the segment that is closest to closest_point.
ImprintLineSegment *closest_seg = NULL, *close_seg;
double dist;
int ii;
CubitVector closest_vec, closest_point_vec = closest_point->coordinates();
for ( ii = closest_segments.size(); ii > 0; ii-- )
close_seg = closest_segments.pop();
if ( !closest_point_seg(closest_point, close_seg,
closest_vec) )
dist = (closest_vec - closest_point_vec).length_squared();
min_dist = dist;
closest_seg = close_seg;
if ( closest_seg == NULL )
PRINT_ERROR("Couldn't find a closest segment.(bug)\n");
assert(closest_seg != NULL);
if ( closest_seg != start_prev_seg ||
closest_seg != start_next_seg )
//okay this we need to ignore. Just say start point doesn't match with anything.
start_point->set_unmatched();
start_point->set_matching_point(NULL);
else
//okay, now we actually want to match start point with one of the segments
//attached to closest_point.
ImprintLineSegment *next_close_seg, *prev_close_seg;
next_close_seg = closest_point->get_next_seg();
prev_close_seg = closest_point->get_prev_seg();
//determine which is closer...
CubitVector closest_next, closest_prev, start_vec = start_point->coordinates();
if ( !closest_point_seg(start_point, next_close_seg,
closest_next) )
if ( !closest_point_seg(start_point, prev_close_seg,
closest_prev) )
double dist_prev, dist_next;
CubitVector point_on;
dist_next = (start_vec - closest_next).length_squared();
dist_prev = (start_vec - closest_prev).length_squared();
closest_seg = NULL;
if ( dist_next < dist_prev )
closest_seg = next_close_seg;
min_dist = dist_next;
point_on = closest_next;
else
closest_seg = prev_close_seg;
min_dist = dist_prev;
point_on = closest_prev;
//make sure the point_on isn't the same location as the closest_point.
CubitVector closest_point_vec = closest_point->coordinates();
if ( closest_point_vec.within_tolerance(point_on, myTolerance/10.0) )
//make sure point_on and start point are within tolerances.
dist = (point_on - start_vec).length_squared();
if ( dist > myTolerance*myTolerance )
PRINT_ERROR("Bad logic in ignore_match in ImprintImprintTool.\n");
assert(dist <= myTolerance*myTolerance);
start_match->set_closest_point(NULL);
start_match->set_closest_dist(min_dist);
start_match->set_point_on(point_on);
start_match->set_closest_seg(closest_seg);
else
else
PRINT_ERROR("More than one match in final match(%d).\n",match_data_list.size() );
PRINT_ERROR("This is a bug in loop imprinting, try reducing\n"
"the size for decomposition.\n");
if ( start_point->get_matching_point() )
ImprintPointData *closest_point = start_point->get_matching_point();
if ( closest_point->get_matching_point() == start_point )
//this must mean we match on a segment.
//Determine if there is a segment on 1, that is closer to this
//point than start_point is. If there is, ignore this match.
point_on.set(*(start_match->get_point_on()));
double dist;
int ii;
//dflush();
CubitVector closest_vec;
//CubitVector start_vec = start_point->coordinates();
// dclear();
// dseg(start_prev_seg);
// dseg(start_next_seg);
//dvec(point_on);
//dmouse();
if ( !closest_point_seg(point_on, close_seg,
closest_vec) )
dist = (closest_vec - point_on).length_squared();
min_dist = dist;
if ( closest_seg == start_prev_seg ||
closest_seg == start_next_seg )
else
| CubitStatus ImprintBoundaryTool::imprint | ( | DLIList< RefFace * > & | results, |
| CubitBoolean | merge = CUBIT_FALSE |
Definition at line 100 of file ImprintBoundaryTool.cpp.
CubitBox ref_box1 = refFacePtr1->bounding_box();
CubitBox ref_box2 = refFacePtr2->bounding_box();
if ( !ref_box1.overlap(myTolerance, ref_box2 ) )
if ( refFacePtr1->num_loops() == 0 ||
refFacePtr2->num_loops() == 0 )
PRINT_WARNING("Virtual imprinting currently can't imprint\n"
"surfaces that have no boundary curves (surfaces %d or %d\n"
"has no boundary curves.\n", refFacePtr1->id(), refFacePtr2->id());
if ( merge )
PRINT_WARNING("Can't merge while virtual imprinting yet.\n");
PRINT_DEBUG_129("Imprinting surfaces: %d and %d\n",
refFacePtr1->id(),
refFacePtr2->id() );
int debug5 = 0;
if ( debug5)
GfxDebug::clear();
GfxDebug::draw_ref_face_edges(refFacePtr1, CUBIT_GREEN_INDEX);
GfxDebug::draw_ref_face_edges(refFacePtr2, CUBIT_YELLOW_INDEX);
GfxDebug::flush();
CubitMessage::instance()->debug_flag(129, CUBIT_TRUE);
int ii, jj;
PointLoopList boundary_point_loops1;
PointLoopList boundary_point_loops2;
CubitStatus stat = get_boundary_points(refFacePtr1,
boundary_point_loops1);
return stat;
stat = get_boundary_points(refFacePtr2,
boundary_point_loops2);
return stat;
boundary_point_loops1.reset();
boundary_point_loops2.reset();
//Drawing the boundary loops.
GfxDebug::clear();
GfxDebug::flush();
for ( ii = boundary_point_loops1.size(); ii > 0; ii-- )
point_list = boundary_point_loops1.get_and_step();
ImprintPointData *point = point_list->get_and_step();
//RefEntity *entity = point->owner();
draw_point(point);
if (debug5)
GfxDebug::clear();
GfxDebug::draw_ref_face_edges(refFacePtr2);
GfxDebug::flush();
for ( ii = boundary_point_loops2.size(); ii > 0; ii-- )
point_list = boundary_point_loops2.get_and_step();
draw_point(point);
if (debug5)
//Now intersect the two boundary loops. Either mark the nodes
//that are intersecting, or insert new nodes into the boundary loops,
//that intersect the boundaries.
stat = imprint_boundaries( boundary_point_loops1,
boundary_point_loops2,
refFacePtr1, refFacePtr2,
results);
if ( results.size() == 0 )
if ( modBound1 )
results.append(refFacePtr1);
if ( modBound2 )
results.append(refFacePtr2);
PRINT_ERROR("Imprinting Surface %d and %d failed\n",
refFacePtr1->id(), refFacePtr2->id() );
| CubitStatus ImprintBoundaryTool::imprint_boundaries | ( | PointLoopList & | boundary_loops_1, |
| RefFace * | ref_face_1, | ||
| DLIList< RefFace * > & | results | ||
| ) | [private] |
Definition at line 528 of file ImprintBoundaryTool.cpp.
int ii, jj;
SegLoopList boundary_line_loops_1, boundary_line_loops_2;
//Now convert the point lists to line segments.
//REMEMBER, delete all the data from boundary_line_loops, the lists and the data...
CubitStatus st = convert_to_lines( boundary_loops_1, boundary_line_loops_1, ref_face_1, CUBIT_TRUE);
if ( st != CUBIT_SUCCESS )
st = convert_to_lines( boundary_loops_2, boundary_line_loops_2, ref_face_2, CUBIT_FALSE);
if ( boundary_line_loops_1.size() == 0 || boundary_line_loops_2.size() == 0 )
//Do the actual intersecting and imprinting. Basically splits segments and
//matches the points on the two boundaries. Also classifies the connections.
CubitStatus stat = imprint_segments( boundary_line_loops_1,
boundary_loops_1,
boundary_loops_2);
//Note that the boundary_line_loops are outof date at this point and shouldn't be used.
//These lists are also stored in the allocatedLineLoops list and the memory will be
//cleaned up in the destructor. Just clean them out to avoid useing the data.
boundary_line_loops_1.clean_out();
boundary_line_loops_2.clean_out();
//Mark each node as to which loop its in and its position
//for efficient searching.
PointList *point_loop;
for ( ii = 0; ii < boundary_loops_1.size(); ii++ )
point_loop = boundary_loops_1.get_and_step();
int loop_size = point_loop->size();
for ( jj = 0; jj < loop_size; jj++ )
point_loop->get_and_step()->set_loop_pos(ii,jj, loop_size);
for ( ii = 0; ii < boundary_loops_2.size(); ii++ )
point_loop = boundary_loops_2.get_and_step();
//Now go through and find the curves that need to be created, and vertices
//that need to be imprinted for each surface.
PointLoopList part_segs_1, part_segs_2;
PointList partition_points_1, partition_points_2;
stat = find_graph_for_surf( boundary_loops_1,
boundary_loops_2,
ref_face_1,
part_segs_1,
partition_points_1,
CUBIT_TRUE);
stat = find_graph_for_surf( boundary_loops_2,
boundary_loops_1,
ref_face_2,
part_segs_2,
partition_points_2,
CUBIT_FALSE);
//Okay now go through and partition the boundaries.
CubitBoolean mod_bound1, mod_bound2;
stat = imprint_boundary_vertices( partition_points_1,
mod_bound1);
stat = imprint_boundary_vertices( partition_points_2,
mod_bound2);
//Now go through and paritition the surfaces.
DLIList<RefFace*> results_1, results_2;
stat = imprint_surface(ref_face_1, part_segs_1, results_1);
stat = imprint_surface(ref_face_2, part_segs_2, results_2);
if ( mod_bound1 || results_1.size() )
modBound1 = CUBIT_TRUE;
if ( mod_bound2 || results_2.size() )
modBound2 = CUBIT_TRUE;
results += results_1;
results += results_2;
| CubitStatus ImprintBoundaryTool::imprint_boundary_vertices | ( | PointList & | partition_points, |
| CubitBoolean & | modified_boundary | ||
| ) | [private] |
Definition at line 3566 of file ImprintBoundaryTool.cpp.
ImprintPointData *curr_point;
RefEntity *ref_ent;
int ii;
RefEdge *ref_edge, *edge1, *edge2;
modified_boundary = CUBIT_FALSE;
while( partition_points.size() > 0 )
curr_point = partition_points.pop();
ref_ent = curr_point->owner();
ref_edge = CAST_TO(ref_ent, RefEdge);
if ( ref_edge == NULL )
PRINT_ERROR("Bad logic in point owners for ImprintBoundaryTool.\n");
assert(ref_edge != NULL);
CubitVector part_vec = curr_point->coordinates();
ref_edge->closest_point(part_vec, closest_point);
double dist = (part_vec - closest_point).length_squared();
PRINT_ERROR("Curve %d may have bad geometry.\n"
"While try to partition the curve the move_to operation\n"
"returned a move distance larger than the tolerance.\n"
"Please try healing or using mesh based geometry for curve %d.\n",
ref_edge->id(), ref_edge->id());
PRINT_DEBUG_129("Partitioning curve %d\n",
ref_edge->id());
RefVertex *vtx_ptr= PartitionTool::instance()->partition(ref_edge,
part_vec,
edge1, edge2);
if ( vtx_ptr == NULL )
PRINT_ERROR("Partitioning curve failed.\n");
if ( edge1->measure() < myTolerance ||
edge2->measure() < myTolerance )
PRINT_WARNING("Virtual imprinting created an edge smaller than\n"
" the tolerance value. This could be an error.\n"
" Check curve %d or %d, imprinting surfs %d and %d.\n",
edge1->id(), edge2->id(), refFacePtr1->id(),
refFacePtr2->id());
modified_boundary = CUBIT_TRUE;
curr_point->owner(vtx_ptr);
//Now readjust owners cause they can change if we partition more
//than one curve.
for ( ii = partition_points.size(); ii > 0; ii-- )
curr_point = partition_points.get_and_step();
if( curr_point->owner() == ref_ent )
if ( on_curve(curr_point, edge1) )
curr_point->owner(dynamic_cast<RefEntity*>(edge1));
else
curr_point->owner(dynamic_cast<RefEntity*>(edge2));
| CubitStatus ImprintBoundaryTool::imprint_segments | ( | SegLoopList & | boundary_line_loops_1, |
| SegLoopList & | boundary_line_loops_2, | ||
| PointLoopList & | boundary_loops_1, | ||
| PointLoopList & | boundary_loops_2 | ||
| ) | [private] |
Definition at line 4602 of file ImprintBoundaryTool.cpp.
int ii, jj;
ImprintLineSegment **surf_1_loop_heads, **surf_2_loop_heads;
surf_1_loop_heads = new ImprintLineSegment*[boundary_line_loops_1.size()];
surf_2_loop_heads = new ImprintLineSegment*[boundary_line_loops_2.size()];
SegList *line_loop_1, *line_loop_2;
ImprintLineSegment *curr_seg;
for ( ii = 0; ii < boundary_line_loops_1.size(); ii++ )
line_loop_1 = boundary_line_loops_1.get_and_step();
surf_1_loop_heads[ii] = line_loop_1->get();
for ( ii = 0; ii < boundary_line_loops_2.size(); ii++ )
line_loop_2 = boundary_line_loops_2.get_and_step();
surf_2_loop_heads[ii] = line_loop_2->get();
KDDTree <ImprintLineSegment*> atree_1(myTolerance, true);
KDDTree <ImprintLineSegment*> atree_2(myTolerance, true);
//Insert all of the segments on for the boundary line loops into
//their respective R-Tree.
for ( jj = 0; jj < line_loop_1->size(); jj++ )
curr_seg = line_loop_1->get_and_step();
atree_1.add(curr_seg);
atree_1.balance();
for ( jj = 0; jj < line_loop_2->size(); jj++ )
curr_seg = line_loop_2->get_and_step();
atree_2.add(curr_seg);
atree_2.balance();
//Now for each segment on boundary 1, find the closest segments on
//boundary 2. Determine for each point on boundary 1 the closest
//point on boundary 2 if it is within tolerance. Set this
//data in the pointmatched data in ImprintPointData.
CubitStatus stat = find_matching_points(boundary_line_loops_1,
atree_2 );
return stat;
//Now for each segment on boundary 2, find the closest segments on
//boundary 1. Determine for each point on boundary 2 the closest
//point on boundary 1 if it is within tolerance. Set this
stat = find_matching_points(boundary_line_loops_2,
atree_1 );
return stat;
//Now we need to go over each node on the boundaries and resolve
//descripensies. Find nodes that match each other and set them
//to match each other. Also at this time. Nodes that have
//closest points on the interior of a segment will get the
//segment split. Also as segments are modified, update the
//atree.
int num_loops_1 = boundary_line_loops_1.size();
int num_loops_2 = boundary_line_loops_2.size();
stat = final_match( surf_1_loop_heads, num_loops_1,
atree_1, atree_2);
return stat;
//Unfortunately, we are not done. We now need to find
//cross intersections. These are where two segments of different
//surfaces intersect. They don't intersect at the points themselves,
//so they weren't captured previously. If I could do this in any other
//part of the previous code, I would. I just can't figure out
//how to do it without sacrificing robustness.
//Note that only atree_2 is passed in. After this point,
//atree_1 will be out of date.
stat = find_crossings(surf_1_loop_heads, num_loops_1,
atree_2);
return stat;
//Recaputure the linked list into the DLIList structure.
update_boundary_loops( boundary_loops_1, surf_1_loop_heads);
update_boundary_loops( boundary_loops_2, surf_2_loop_heads);
delete [] surf_1_loop_heads;
delete [] surf_2_loop_heads;
stat = resolve_on_boundaries( boundary_loops_1,
boundary_loops_2);
return stat;
GfxDebug::clear();
draw_loops(boundary_loops_1);
draw_loops(boundary_loops_2);
| CubitStatus ImprintBoundaryTool::imprint_surface | ( | RefFace * | ref_face, |
| ) | [private] |
Definition at line 3635 of file ImprintBoundaryTool.cpp.
//Now go through and create refedges for partitioning.
int ii, jj, counter;
DLIList<RefFace*> tmp_results;
DLIList<RefEdge*> ref_edges;
ImprintPointData *start_imp, *end_imp, *curr_imp, *matching_start, *matching_end;
PointList *loop_ptr;
DLIList<CubitVector*> curve_vectors;
CubitBoolean first_on_loop;
RefVertex *prev_end;
RefVertex *first_v_on_loop = NULL;
for ( ii = part_segs.size(); ii > 0; ii-- )
loop_ptr = part_segs.get_and_step();
loop_ptr->reset();
first_on_loop = CUBIT_TRUE;
prev_end = NULL;
for ( jj = loop_ptr->size(); jj > 0; jj-- )
start_imp = loop_ptr->get_and_step();
if ( !start_imp->is_owner_vertex() )
PRINT_ERROR("Bad logic in imprint_surface for ImprintBoundaryTool\n");
assert( start_imp->is_owner_vertex() );
end_imp = NULL;
curve_vectors.clean_out();
counter = 0;
//For the last point, only create another edge if the
//the start is also an end...
if ( jj == 1 && loop_ptr->get()->get_end_partition() != CUBIT_TRUE )
continue;
//Loop until we get to the end of the partition or
//till we have to create a new ref_edge.
while( loop_ptr->get()->get_end_partition() != CUBIT_TRUE )
counter++;
curr_imp = loop_ptr->get_and_step();
if (curr_imp->is_owner_vertex())
end_imp = curr_imp;
counter--;
loop_ptr->back();
break;
else
CubitVector *temp = new CubitVector(curr_imp->coordinates());
curve_vectors.append(temp);
jj -= counter;
CubitBoolean verts_same = CUBIT_FALSE;
if ( end_imp == NULL )
if ( loop_ptr->get()->get_end_partition() == CUBIT_TRUE )
//Do this last segment. This means that we have a complete loop
//for partitioning.
end_imp = loop_ptr->get();
if ( curve_vectors.size() == loop_ptr->size() - 1)
verts_same = CUBIT_TRUE;
else {
//Either we have a screw-up or we have
//a periodic boundary.
//Lets say end_imp is the last in the loop.
loop_ptr->reset();
end_imp = loop_ptr->prev();
//Now make sure that end_imp and start_imp are connected.
RefEntity *ent_1 = start_imp->owner();
RefEntity *ent_2 = end_imp->owner();
if ( are_connected( ent_1, ent_2, ref_face ) )
end_imp = start_imp;
else {
PRINT_ERROR("Problems extracting parition edge in ImprintBoundaryTool.\n");
//Create vertices from the first and last vectors.
CubitVector tmp_vec = start_imp->coordinates();
matching_start = start_imp->get_matching_point();
if ( matching_start != NULL )
//use this location instead. This should be on
//the other boundary and will insure that the point
// intersects it...
tmp_vec = matching_start->coordinates();
RefVertex *first_ref = create_virtual_vertex(tmp_vec);
//It is tempting to update the start_imp's owner at this point,
//but DON'T. These vertices belong to this surfaces boundary. The
//start_imp really belongs to the other boundary that is intersecting
//with this boundary. If you change the owner, you'll end up merging
//vertices accross boundaries. Don't do that...
RefVertex *last_ref=NULL;
if ( verts_same )
last_ref = first_ref;
prev_end = last_ref;
else
tmp_vec = end_imp->coordinates();
matching_end = end_imp->get_matching_point();
if ( matching_end != NULL )
// intersects it...
tmp_vec = matching_end->coordinates();
last_ref = create_virtual_vertex(tmp_vec);
//again don't update the end_imp owner either., see above comment.
assert( first_ref && last_ref );
RefEdge *ref_edge = NULL;
//if curve_vectors is empty, this is just a straight line
//curve.
ref_edge = create_virtual_edge(first_ref, last_ref, curve_vectors);
allocatedRefEdge->append(ref_edge);
int tt;
for ( tt = curve_vectors.size(); tt > 0; tt-- )
delete curve_vectors.pop();
PRINT_ERROR("Problem creating virtual edge in imprinting.\n");
ref_edges.append(ref_edge);
if ( first_on_loop )
first_on_loop = CUBIT_FALSE;
//merge the start_imp's vertex with it's matching vertex.
RefEntity *other_ent = matching_start->owner();
RefVertex *matching_vert = CAST_TO(other_ent, RefVertex);
if ( matching_vert == NULL )
PRINT_ERROR("Problems mergeing partition to boundary on imprint.\n");
assert(matching_vert != NULL);
CubitBoolean kept_1 = CUBIT_TRUE;
CubitStatus temp_stat = merge_vertices(matching_vert, first_ref, kept_1);
if ( temp_stat != CUBIT_SUCCESS )
RefVertex *owner_v = kept_1 ? matching_vert : first_ref;
//Update the matching_start cause the matching imprint point data IS on
//this boundary. (which is why we had to merge with it!).
matching_start->owner(owner_v);
if ( start_imp->get_start_partition() &&
start_imp->get_end_partition() )
first_v_on_loop = owner_v;
else
first_v_on_loop = first_ref;
else if ( prev_end && last_ref != first_ref)
//merge the prev_end vert and first_ref verts.
CubitStatus temp_stat = merge_vertices(prev_end, first_ref, kept_1);
prev_end = kept_1 ? prev_end : first_ref;
//Don't update any imprint point data owners, nothing changed for this
//boundary.
if ( last_ref != first_ref )
//Merge the end vertex to the boundary.
loop_ptr->reset();
if ( end_imp->is_owner_vertex() &&
(end_imp->get_point_type() == CREATE_NEW_VERTEX ||
end_imp->get_point_type() == VERTEX_ON_BOTH_BOUNDARIES )
&& end_imp->get_matching_point() )
RefEntity *other_ent = matching_end->owner();
//use prev_end, hope its still valid!!!
assert(prev_end != NULL);
RefVertex *end_vertex = prev_end;
if ( matching_vert == NULL || end_vertex == NULL )
assert(end_vertex != NULL);
CubitStatus temp_stat = merge_vertices(matching_vert, end_vertex, kept_1);
RefVertex *owner_v = kept_1 ? matching_vert : end_vertex;
//Again just update the matching_end since it is on this boundary.
matching_end->owner(owner_v);
else if ( loop_ptr->get()->get_start_partition() &&
loop_ptr->get()->get_end_partition() )
assert(first_v_on_loop != NULL);
//Merge the prev_end and this vertex.
CubitBoolean kept_1;
CubitStatus temp_stat = merge_vertices(first_v_on_loop, prev_end, kept_1);
CubitStatus stat;
//Okay, these should all be merged properly and ready to partition!
if ( ref_edges.size() > 0 )
//Make sure that either the ref_edge_list touches the boundary at least
//twice or is a complete loop...
if ( valid_partition( ref_edges, ref_face ) )
PRINT_DEBUG_129("Partitioning surface %d\n",
ref_face->id());
int tmp_debug = 0;
if (tmp_debug)
GfxDebug::clear();
GfxDebug::draw_ref_face(ref_face);
int oo;
for (oo=0; oo < ref_edges.size(); oo++ )
GfxDebug::draw_ref_edge(ref_edges.next(oo), CUBIT_RED_INDEX);
GfxDebug::flush();
stat = PartitionTool::instance()->partition(ref_face, ref_edges,
tmp_results, CUBIT_FALSE, NULL, CUBIT_TRUE);
PRINT_ERROR("Partitioning surface %d failed\n", ref_face->id());
return stat;
else
results += tmp_results;
return CUBIT_SUCCESS;
| CubitStatus ImprintBoundaryTool::intersect_segments | ( | ImprintLineSegment * | seg_1, |
| ImprintLineSegment * | seg_2, | ||
| IntersectResult & | int_result, | ||
| ImprintLineSegment ** | new_segments | ||
| ) | [private] |
Definition at line 633 of file ImprintBoundaryTool.cpp.
int ii;
//initialize the results first.
for ( ii = 0; ii < 4; ii++)
new_segments[ii] = NULL;
ImprintPointData* imp_point_0 = seg_1->get_start();
ImprintPointData* imp_point_1 = seg_1->get_end();
ImprintPointData* imp_point_2 = seg_2->get_start();
ImprintPointData* imp_point_3 = seg_2->get_end();
int debug4 = 0;
if ( debug4 )
int debug = 0;
//First go through and test the end points.
//This will test for cases L_INTERSECT, and SEGS_EQUAL, and OVERLAP_JOIN.
MatchType type_0, type_1, type_2, type_3;
CubitStatus stat1 = match_points(seg_1, seg_2,type_0,
type_1, type_2, type_3);
//First handle the basic stuff;
if ( type_0 == MATCH_0_2 && type_1 == MATCH_1_3 &&
type_2 == MATCH_0_2 && type_3 == MATCH_1_3 )
imp_point_0->set_matching_point(imp_point_2);
imp_point_2->set_matching_point(imp_point_0);
imp_point_1->set_matching_point(imp_point_3);
imp_point_3->set_matching_point(imp_point_1);
//These segments are equal.
set_type_for_equal(imp_point_0, imp_point_2,
int_result = SEGS_EQUAL_0_2;
PRINT_DEBUG_129("Found SEGS_EQUAL_0_2\n");
else if ( type_0 == MATCH_0_3 && type_1 == MATCH_1_2 &&
type_3 == MATCH_0_3 && type_2 == MATCH_1_2 )
imp_point_0->set_matching_point(imp_point_3);
imp_point_3->set_matching_point(imp_point_0);
imp_point_1->set_matching_point(imp_point_2);
imp_point_2->set_matching_point(imp_point_1);
set_type_for_equal(imp_point_0, imp_point_3,
imp_point_1, imp_point_2);
int_result = SEGS_EQUAL_0_3;
PRINT_DEBUG_129("Found SEGS_EQUAL_0_3\n");
else if ( type_0 == MATCH_0_2 && type_2 == MATCH_0_2 &&
(type_1 == NO_MATCH || type_1 == MATCH_1_6 ||
type_1 == MATCH_1_7) &&
(type_3 == NO_MATCH || type_3 == MATCH_3_4 ||
type_3 == MATCH_3_5) )
return case_0_2_equal(seg_1, seg_2,
type_1, type_3,
int_result, new_segments);
else if ( type_0 == MATCH_0_3 && type_3 == MATCH_0_3 &&
(type_2 == NO_MATCH || type_2 == MATCH_2_4 ||
type_2 == MATCH_2_5) )
return case_0_3_equal(seg_1, seg_2,
type_1, type_2,
else if ( type_1 == MATCH_1_2 && type_2 == MATCH_1_2 &&
(type_0 == NO_MATCH || type_0 == MATCH_0_6 ||
type_0 == MATCH_0_7) &&
return case_1_2_equal(seg_1, seg_2,
type_0, type_3,
else if ( type_1 == MATCH_1_3 && type_3 == MATCH_1_3 &&
return case_1_3_equal(seg_1, seg_2,
type_0, type_2,
else if ( type_0 != NO_MATCH || type_1 != NO_MATCH ||
type_2 != NO_MATCH || type_3 != NO_MATCH )
if ( type_0 == MATCH_0_2 || type_0 == MATCH_0_3 ||
type_1 == MATCH_1_2 || type_1 == MATCH_1_3 ||
type_2 == MATCH_1_2 || type_2 == MATCH_0_2 ||
type_3 == MATCH_0_3 || type_3 == MATCH_1_3 )
if (debug )
draw_point(seg_1->get_prev()->get_start());
draw_point(seg_1->get_next()->get_end());
draw_point(seg_2->get_prev()->get_start());
draw_point(seg_2->get_next()->get_end());
imp_point_1->get_matching_point() == imp_point_2 )
if ( type_0 == MATCH_0_3 && type_3 == MATCH_3_5 )
int_result = NO_INTERSECT;
else if ( type_3 == MATCH_0_3 && type_0 == MATCH_0_7 )
else
if (( type_0 == MATCH_0_2 || type_3 == MATCH_1_3 ) ||
( type_0 == MATCH_0_3 && type_3 == MATCH_3_4 ) ||
( type_0 == MATCH_0_7 && type_3 == MATCH_0_3 ) ||
( type_0 == MATCH_0_6 && type_3 == MATCH_0_3 ) ||
( type_0 == MATCH_0_3 && type_3 == MATCH_3_5 ) )
//This means that 0 and 2 are within tolerance
//but 1 and 2 are closer. For now just ignore this...
//or...
//This means that 1 and 3 are within tolerance
type_0, type_3,
else
PRINT_ERROR("Problems with tolerance. (Need special match code.)\n");
imp_point_0->get_matching_point() == imp_point_3 )
if ( type_1 == MATCH_1_2 && type_2 == MATCH_2_4 )
else if ( type_2 == MATCH_1_2 && type_1 == MATCH_1_7 )
else
if (( type_1 == MATCH_1_3 || type_2 == MATCH_0_2 ) ||
( type_1 == MATCH_1_2 && type_2 == MATCH_2_5 ) ||
( type_1 == MATCH_1_2 && type_2 == MATCH_2_4 ) ||
( type_1 == MATCH_1_6 && type_2 == MATCH_1_2 ) ||
( type_1 == MATCH_1_7 && type_2 == MATCH_1_2 ) )
//but 0 and 3 are closer. For now just ignore this...
//or...
type_1, type_2,
else
if ( type_0 == MATCH_0_2 && type_2 == MATCH_2_5 )
else if ( type_2 == MATCH_0_2 && type_0 == MATCH_0_7 )
else
if (( type_0 == MATCH_0_3 || type_2 == MATCH_1_2 ) ||
( type_0 == MATCH_0_2 && type_2 == MATCH_2_4 ) ||
( type_0 == MATCH_0_2 && type_2 == MATCH_2_5 ) ||
( type_0 == MATCH_0_6 && type_2 == MATCH_0_2 ) ||
( type_0 == MATCH_0_7 && type_2 == MATCH_0_2 ) )
//This means that 0 and 3 are within tolerance
//but 1 and 3 are closer. For now just ignore this...
//or...
//This means that 1 and 2 are within tolerance
type_0, type_2,
else
imp_point_0->get_matching_point() == imp_point_2 )
if ( type_1 == MATCH_1_3 && type_3 == MATCH_3_4 )
else if ( type_3 == MATCH_1_3 && type_1 == MATCH_1_6 )
else
if (( type_1 == MATCH_1_2 || type_3 == MATCH_0_3 ) ||
( type_1 == MATCH_1_3 && type_3 == MATCH_3_5) ||
( type_1 == MATCH_1_3 && type_3 == MATCH_3_4) ||
( type_1 == MATCH_1_6 && type_3 == MATCH_1_3) ||
( type_1 == MATCH_1_7 && type_3 == MATCH_1_3) )
//but 0 and 2 are closer. For now just ignore this...
//or...
type_1, type_3,
else
else if ( type_0 == MATCH_0_2 || ( type_0 == MATCH_0_3 &&
(type_2 != MATCH_0_2 && type_3 != MATCH_0_3 ) ) )
if ( type_2 != MATCH_1_2 && type_3 != MATCH_1_3 &&
type_1 != MATCH_1_2 && type_1 != MATCH_1_3 )
else
else if ( type_1 == MATCH_1_2 || ( type_1 == MATCH_1_3 &&
(type_2 != MATCH_1_2 && type_3 != MATCH_1_3 ) ) )
if ( type_2 != MATCH_0_2 && type_3 != MATCH_0_3 &&
type_0 != MATCH_0_2 && type_1 != MATCH_0_3 )
else
else if ( type_2 == MATCH_0_2 || ( type_2 == MATCH_1_2 &&
(type_0 != MATCH_0_2 && type_1 != MATCH_1_2) ) )
if ( type_0 != MATCH_0_2 && type_1 != MATCH_1_2 &&
type_3 != MATCH_0_3 && type_3 != MATCH_1_3 )
else
else if ( type_3 == MATCH_0_3 || ( type_3 == MATCH_1_3 &&
(type_0 != MATCH_0_3 && type_1 != MATCH_1_3) ) )
if ( type_0 != MATCH_0_3 && type_1 != MATCH_1_3 &&
type_2 != MATCH_0_2 && type_2 != MATCH_1_2 )
else
else
//At this point we know that none of the end points of the
//line segements are within tolerance. The remaining possibilities
//Are: T_INTERSECT, OVERLAP_PART, OVERLAP_ALL, or CROSS_INTERSECT.
CubitBoolean point_0_on_seg_2 = CUBIT_FALSE;
CubitBoolean point_1_on_seg_2 = CUBIT_FALSE;
CubitBoolean point_2_on_seg_1 = CUBIT_FALSE;
CubitBoolean point_3_on_seg_1 = CUBIT_FALSE;
//Test to get the correct values for these flags. From the above
//flags we can figure out everything except for CROSS_INTERSECT.
stat1 = determine_on_boundary( seg_1, seg_2, type_0, type_1,
type_2, type_3 );
return stat1;
if ( type_0 == ON_SEG_2 )
point_0_on_seg_2 = CUBIT_TRUE;
if ( type_1 == ON_SEG_2 )
point_1_on_seg_2 = CUBIT_TRUE;
if ( type_2 == ON_SEG_1 )
point_2_on_seg_1 = CUBIT_TRUE;
if ( type_3 == ON_SEG_1 )
point_3_on_seg_1 = CUBIT_TRUE;
//Okay, test for T_INTERSECT.
if ( point_0_on_seg_2 && !point_1_on_seg_2 &&
!point_2_on_seg_1 && !point_3_on_seg_1 )
PRINT_DEBUG_129("Found T_INTERSECT_0\n");
int_result = T_INTERSECT_0;
//split seg_2
ImprintLineSegment *new_seg_2_0, *new_seg_0_3;
//copy imp_point_0 to use it in list 2.
CubitVector closest_point;
closest_point_seg( imp_point_0, seg_2, closest_point);
ImprintPointData *new_point_0 = new ImprintPointData(imp_point_0, closest_point);
new_point_0->owner(seg_2->owner());
allocatedPointData->append(new_point_0);
//set the point type to be so we create a vertex here.
new_point_0->set_point_type(CREATE_NEW_VERTEX);
if ( imp_point_0->is_owner_vertex() &&
imp_point_0->get_point_type() != CREATE_NEW_VERTEX )
imp_point_0->set_point_type(VERTEX_ON_BOTH_BOUNDARIES);
else
imp_point_0->set_point_type(CREATE_NEW_VERTEX);
new_seg_2_0 = new ImprintLineSegment(imp_point_2, new_point_0, seg_2->owner());
new_seg_0_3 = new ImprintLineSegment(new_point_0, imp_point_3, seg_2->owner());
allocatedLineData->append(new_seg_2_0);
allocatedLineData->append(new_seg_0_3);
new_segments[2] = new_seg_2_0;
new_segments[3] = new_seg_0_3;
//update the linked list.
update_list(new_segments, seg_1, seg_2, CUBIT_FALSE);
seg_2->set_inactive(CUBIT_TRUE);
else if ( point_1_on_seg_2 && !point_0_on_seg_2 &&
//split seg_2
PRINT_DEBUG_129("Found T_INTERSECT_1\n");
int_result = T_INTERSECT_1;
ImprintLineSegment *new_seg_2_1, *new_seg_1_3;
//copy imp_point_1 to use it in list 2.
closest_point_seg( imp_point_1, seg_2, closest_point);
ImprintPointData *new_point_1 = new ImprintPointData(imp_point_1, closest_point);
new_point_1->owner(seg_2->owner());
allocatedPointData->append(new_point_1);
new_point_1->set_point_type(CREATE_NEW_VERTEX);
if ( imp_point_1->is_owner_vertex() &&
imp_point_1->get_point_type() != CREATE_NEW_VERTEX )
imp_point_1->set_point_type(VERTEX_ON_BOTH_BOUNDARIES);
else
imp_point_1->set_point_type(CREATE_NEW_VERTEX);
new_seg_2_1 = new ImprintLineSegment(imp_point_2,
new_point_1, seg_2->owner());
new_seg_1_3 = new ImprintLineSegment(new_point_1,
allocatedLineData->append(new_seg_2_1);
allocatedLineData->append(new_seg_1_3);
new_segments[2] = new_seg_2_1;
new_segments[3] = new_seg_1_3;
else if ( point_2_on_seg_1 && !point_0_on_seg_2 &&
!point_1_on_seg_2 && !point_3_on_seg_1 )
PRINT_DEBUG_129("Found T_INTERSECT_2\n");
int_result = T_INTERSECT_2;
//split seg_1
ImprintLineSegment *new_seg_0_2, *new_seg_2_1;
//copy imp_point_2 to use it in list 1.
closest_point_seg( imp_point_2, seg_1, closest_point);
ImprintPointData *new_point_2 = new ImprintPointData(imp_point_2, closest_point);
new_point_2->owner(seg_1->owner());
allocatedPointData->append(new_point_2);
new_point_2->set_point_type(CREATE_NEW_VERTEX);
if ( imp_point_2->is_owner_vertex() &&
imp_point_2->get_point_type() != CREATE_NEW_VERTEX )
imp_point_2->set_point_type(VERTEX_ON_BOTH_BOUNDARIES);
else
imp_point_2->set_point_type(CREATE_NEW_VERTEX);
new_seg_0_2 = new ImprintLineSegment(imp_point_0, new_point_2,
seg_1->owner());
new_seg_2_1 = new ImprintLineSegment(new_point_2, imp_point_1,
seg_1->owner());
allocatedLineData->append(new_seg_0_2);
new_segments[0] = new_seg_0_2;
new_segments[1] = new_seg_2_1;
update_list(new_segments, seg_1, seg_2, CUBIT_TRUE);
seg_1->set_inactive(CUBIT_TRUE);
else if ( point_3_on_seg_1 && !point_0_on_seg_2 &&
!point_1_on_seg_2 && !point_2_on_seg_1 )
PRINT_DEBUG_129("Found T_INTERSECT_3\n");
int_result = T_INTERSECT_3;
//split seg_1
//copy imp_point_3 to use it in list 1.
closest_point_seg( imp_point_3, seg_1, closest_point);
ImprintPointData *new_point_3 = new ImprintPointData(imp_point_3, closest_point);
new_point_3->owner(seg_1->owner());
allocatedPointData->append(new_point_3);
new_point_3->set_point_type(CREATE_NEW_VERTEX);
if ( imp_point_3->is_owner_vertex() &&
imp_point_3->get_point_type() != CREATE_NEW_VERTEX )
imp_point_3->set_point_type(VERTEX_ON_BOTH_BOUNDARIES);
else
imp_point_3->set_point_type(CREATE_NEW_VERTEX);
ImprintLineSegment *new_seg_0_3, *new_seg_3_1;
new_seg_0_3 = new ImprintLineSegment(imp_point_0, new_point_3,
seg_1->owner());
new_seg_3_1 = new ImprintLineSegment(new_point_3, imp_point_1,
seg_1->owner());
allocatedLineData->append(new_seg_3_1);
new_segments[0] = new_seg_0_3;
new_segments[1] = new_seg_3_1;
//Okay, we are done with T intersections, it now must be one
//of the remaining overlaps (part or all.) or the cross intersection.
//First test for the part overlaps.
if ( point_1_on_seg_2 && point_2_on_seg_1 &&
!point_0_on_seg_2 && !point_3_on_seg_1 )
PRINT_DEBUG_129("Found OVEVERLAP_PART_0_3\n");
int_result = OVERLAP_PART_0_3;
ImprintLineSegment *new_seg_2_1_v2, *new_seg_1_3;
//Copy point 2 to use on seg_1
if ( imp_point_2->is_owner_vertex() )
if ( imp_point_2->get_point_type() != CREATE_NEW_VERTEX )
else
new_point_2->set_point_type(ON_BOTH_BOUNDARIES);
imp_point_2->set_point_type(ON_BOTH_BOUNDARIES);
//split both segs 1 and 2.
seg_1->owner());
seg_1->owner());
//Copy point 1 to use on seg_2
if ( imp_point_1->is_owner_vertex() )
if ( imp_point_1->get_point_type() != CREATE_NEW_VERTEX )
else
new_point_1->set_point_type(ON_BOTH_BOUNDARIES);
new_seg_2_1_v2 = new ImprintLineSegment(imp_point_2, new_point_1,
seg_2->owner());
new_seg_1_3 = new ImprintLineSegment(new_point_1, imp_point_3,
seg_2->owner());
allocatedLineData->append(new_seg_2_1_v2);
new_segments[2] = new_seg_2_1_v2;
//now update both linked lists.
else if ( point_1_on_seg_2 && !point_2_on_seg_1 &&
!point_0_on_seg_2 && point_3_on_seg_1 )
PRINT_DEBUG_129("Found OVEVERLAP_PART_0_2\n");
int_result = OVERLAP_PART_0_2;
int debug1 = 0;
if ( debug1 )
GfxDebug::clear();
draw_seg(seg_1);
draw_seg(seg_2);
if ( imp_point_3->is_owner_vertex() )
if ( imp_point_3->get_point_type() != CREATE_NEW_VERTEX )
else
new_point_3->set_point_type(ON_BOTH_BOUNDARIES);
imp_point_3->set_point_type(ON_BOTH_BOUNDARIES);
seg_1->owner());
seg_1->owner());
else
new_seg_2_1 = new ImprintLineSegment(imp_point_2, new_point_1,
seg_2->owner());
seg_2->owner());
else if ( !point_1_on_seg_2 && !point_2_on_seg_1 &&
PRINT_DEBUG_129("Found OVERLAP_PART_1_2\n");
int_result = OVERLAP_PART_1_2;
ImprintLineSegment *new_seg_2_0, *new_seg_0_3_v2;
//Copy point_3 to use on seg 1.
else
seg_1->owner());
seg_1->owner());
//Copy point_0 to use on seg 2.
if ( imp_point_0->is_owner_vertex() )
if ( imp_point_0->get_point_type() != CREATE_NEW_VERTEX )
else
new_point_0->set_point_type(ON_BOTH_BOUNDARIES);
imp_point_0->set_point_type(ON_BOTH_BOUNDARIES);
seg_2->owner());
new_seg_0_3_v2 = new ImprintLineSegment(new_point_0, imp_point_3,
seg_2->owner());
allocatedLineData->append(new_seg_0_3_v2);
new_segments[3] = new_seg_0_3_v2;
//update both lists.
else if ( !point_1_on_seg_2 && point_2_on_seg_1 &&
PRINT_DEBUG_129("Found OVERLAP_PART_1_3\n");
int_result = OVERLAP_PART_1_3;
else
seg_1->owner());
seg_1->owner());
else
seg_2->owner());
seg_2->owner());
//Now test for the overlap all conditions.
else if ( !point_0_on_seg_2 && !point_1_on_seg_2 &&
point_2_on_seg_1 && point_3_on_seg_1 )
//First we know that for either of the next cases, we
//have to copy points 2 and 3, do that first then
//decide the particular intersection case.
//copy points 2 and 3 to use on segment 1.
else
else
//IMPORTANT: Now breaking up the line segments is special for the
//overlap all case. This is the one situation where
//the one exterior segment gets broken into *3* new segments.
//Every other instance in this function only breaks each segment
//into two...
//To distinguish between OVERLAP_ALL_0_2_3_1 and OVERLAP_ALL_0_3_2_1,
//test to see which value is closer to point_0 (2 or 3).
CubitVector point_0 = imp_point_0->coordinates();
CubitVector point_2 = imp_point_2->coordinates();
CubitVector point_3 = imp_point_3->coordinates();
double dist_1_sq = (point_0 - point_2).length_squared();
double dist_2_sq = (point_0 - point_3).length_squared();
if ( dist_1_sq < dist_2_sq )
PRINT_DEBUG_129("Found OVERLAP_ALL_0_2_3_1\n");
int_result = OVERLAP_ALL_0_2_3_1;
ImprintLineSegment *new_seg_0_2, *new_seg_2_3, *new_seg_3_1;
//split seg_1
seg_1->owner());
//Yes this is really just a copy of seg_2, but do it this
//way to make the data separate.
new_seg_2_3 = new ImprintLineSegment(new_point_2, new_point_3,
seg_1->owner());
seg_1->owner());
allocatedLineData->append(new_seg_2_3);
new_segments[1] = new_seg_2_3;
new_segments[2] = new_seg_3_1;
//Don't use the update_list function here
//since this is our special case...
//update list 1.
//prev
new_seg_0_2->set_prev(seg_1->get_prev());
seg_1->get_prev()->set_next(new_seg_0_2);
//next
new_seg_0_2->set_next(new_seg_2_3);
new_seg_2_3->set_prev(new_seg_0_2);
new_seg_2_3->set_next(new_seg_3_1);
new_seg_3_1->set_prev(new_seg_2_3);
new_seg_3_1->set_next(seg_1->get_next());
seg_1->get_next()->set_prev(new_seg_3_1);
//seg_1 will no longer be used
else
PRINT_DEBUG_129("Found OVERLAP_ALL_0_3_2_1\n");
int_result = OVERLAP_ALL_0_3_2_1;
ImprintLineSegment *new_seg_0_3, *new_seg_3_2, *new_seg_2_1;
seg_1->owner());
new_seg_3_2 = new ImprintLineSegment(new_point_3, new_point_2,
seg_1->owner());
seg_1->owner());
allocatedLineData->append(new_seg_3_2);
new_segments[1] = new_seg_3_2;
//don't use special function since this is special case.
//update list 1
//prev
new_seg_0_3->set_prev(seg_1->get_prev());
seg_1->get_prev()->set_next(new_seg_0_3);
//next
new_seg_0_3->set_next(new_seg_3_2);
new_seg_3_2->set_prev(new_seg_0_3);
new_seg_3_2->set_next(new_seg_2_1);
new_seg_2_1->set_prev(new_seg_3_2);
new_seg_2_1->set_next(seg_1->get_next());
seg_1->get_next()->set_prev(new_seg_2_1);
else if ( point_0_on_seg_2 && point_1_on_seg_2 &&
//have to copy points 0 and 1, do that first then
//copy points 0 and 1 to use on segment 2.
else
else
imp_point_1->set_point_type(ON_BOTH_BOUNDARIES);
//into two...
//To distinguish between OVERLAP_ALL_2_0_1_3 and OVERLAP_ALL_2_1_0_3,
//test to see which value is closer to point_2 (0 or 1).
CubitVector point_1 = imp_point_1->coordinates();
double dist_1_sq = (point_2 - point_0).length_squared();
double dist_2_sq = (point_2 - point_1).length_squared();
PRINT_DEBUG_129("Found OVERLAP_ALL_2_0_1_3\n");
int_result = OVERLAP_ALL_2_0_1_3;
ImprintLineSegment *new_seg_2_0, *new_seg_0_1, *new_seg_1_3;
seg_2->owner());
new_seg_0_1 = new ImprintLineSegment(new_point_0, new_point_1,
seg_2->owner());
seg_2->owner());
allocatedLineData->append(new_seg_0_1);
new_segments[1] = new_seg_2_0;
new_segments[2] = new_seg_0_1;
//Don't use update list function since this is special case.
//update list 2.
//prev
new_seg_2_0->set_prev(seg_2->get_prev());
seg_2->get_prev()->set_next(new_seg_2_0);
//next
new_seg_2_0->set_next(new_seg_0_1);
new_seg_0_1->set_prev(new_seg_2_0);
new_seg_0_1->set_next(new_seg_1_3);
new_seg_1_3->set_prev(new_seg_0_1);
new_seg_1_3->set_next(seg_2->get_next());
seg_2->get_next()->set_prev(new_seg_1_3);
//seg_2 will no longer be used
else
PRINT_DEBUG_129("Found OVERLAP_ALL_2_1_0_3\n");
int_result = OVERLAP_ALL_2_1_0_3;
ImprintLineSegment *new_seg_2_1, *new_seg_1_0, *new_seg_0_3;
seg_2->owner());
new_seg_1_0 = new ImprintLineSegment(new_point_1, new_point_0,
seg_2->owner());
seg_2->owner());
allocatedLineData->append(new_seg_1_0);
new_segments[2] = new_seg_1_0;
//Don't use update_list function since this is special case.
//update list 2.
//prev
new_seg_2_1->set_prev(seg_2->get_prev());
seg_2->get_prev()->set_next(new_seg_2_1);
//next
new_seg_2_1->set_next(new_seg_1_0);
new_seg_1_0->set_prev(new_seg_2_1);
new_seg_1_0->set_next(new_seg_0_3);
new_seg_0_3->set_prev(new_seg_1_0);
new_seg_0_3->set_next(seg_2->get_next());
seg_2->get_next()->set_prev(new_seg_0_3);
if ( point_0_on_seg_2 || point_1_on_seg_2 ||
point_2_on_seg_1 || point_3_on_seg_1 )
PRINT_ERROR("Intersection problem, case not handled.\n");
//Okay, finally test for the cross intersection. If this isnt'
//within tolerance, then these two segments couldn't
//posibly intersect!
IntersectionTool int_tool(GEOMETRY_RESABS); //use GEOMETRY_RESABS
//rather than myTolerance for calculations...
CubitVector closest_point_seg_1, closest_point_seg_2;
double sc, tc;
CubitStatus stat = int_tool.closest_points_on_segments(point_0, point_1,
point_2, point_3,
closest_point_seg_2,
sc, tc);
if (stat != CUBIT_SUCCESS )
PRINT_ERROR("Problems calculation closest points on "
"segments for boundary imprinting.\n");
//Make sure the closest points aren't the end points. If they are
//and we are within tolerance, it may be that the tolerance is too big
//cause we shouldn't be at a cross if the closest point is an end point...
if ( sc > 0. && sc < 1. && tc > 0. && tc < 1. &&
closest_point_seg_1.within_tolerance(closest_point_seg_2,myTolerance) )
//okay, these guys actually do intersect!
PRINT_DEBUG_129("Found CROSS_INTERSECT\n");
int_result = CROSS_INTERSECT;
ImprintPointData *new_point_seg_1, *new_point_seg_2;
new_point_seg_1 = new ImprintPointData(closest_point_seg_1.x(),
closest_point_seg_1.y(),
closest_point_seg_1.z());
allocatedPointData->append(new_point_seg_1);
new_point_seg_1->owner(seg_1->owner());
new_point_seg_1->set_point_type(CREATE_NEW_VERTEX);
new_point_seg_2 = new ImprintPointData(closest_point_seg_2.x(),
closest_point_seg_2.y(),
closest_point_seg_2.z());
allocatedPointData->append(new_point_seg_2);
new_point_seg_2->owner(seg_2->owner());
new_point_seg_2->set_point_type(CREATE_NEW_VERTEX);
new_point_seg_2->set_matching_point(new_point_seg_1);
new_point_seg_1->set_matching_point(new_point_seg_2);
new_segments[0] = new ImprintLineSegment(imp_point_0, new_point_seg_1,
seg_1->owner());
new_segments[1] = new ImprintLineSegment(new_point_seg_1, imp_point_1,
seg_1->owner());
new_segments[2] = new ImprintLineSegment(imp_point_2, new_point_seg_2,
seg_2->owner());
new_segments[3] = new ImprintLineSegment(new_point_seg_2, imp_point_3,
seg_2->owner());
allocatedLineData->append(new_segments[0]);
allocatedLineData->append(new_segments[1]);
allocatedLineData->append(new_segments[2]);
allocatedLineData->append(new_segments[3]);
//now update the lists.
//update list 1.
//update list 2.
//seg_1 and seg_2 will no longer be used
else
//All that for nothing! Some how I need to find this out
//earlier to avoid all the comparisions... Will have
//to check at least for the intersection though..
PRINT_DEBUG_129("Found NO_INTERSECT\n");
| void ImprintBoundaryTool::just_match_two_points | ( | ImprintPointData * | point_1, |
| ImprintPointData * | point_2 | ||
| ) | [private] |
Definition at line 5442 of file ImprintBoundaryTool.cpp.
//Okay, we need to match up point_2 and
//point_1.
//Set the actual matching point for the imprinting
//algorithm
point_1->set_matching_point(point_2);
point_2->set_matching_point(point_1);
//Clear out the possible match lists.
if ( point_1->id() == 681 ||
point_1->id() == 150 )
int temp = 0;
temp++;
if ( point_1->is_owner_vertex() &&
!point_2->is_owner_vertex() )
else if(!point_1->is_owner_vertex() &&
else if ( point_1->is_owner_vertex() &&
else // Both aren't vertices...
| CubitStatus ImprintBoundaryTool::match_on_point | ( | ImprintPointData * | start_point, |
| ImprintLineSegment ** | loop_heads, | ||
| int | num_loops, | ||
| AbstractTree< ImprintLineSegment * > & | atree_2 | ||
| ) | [private] |
Definition at line 5138 of file ImprintBoundaryTool.cpp.
//This point matches with a point on the other boundary. Find
//the other point, and make sure that the other point, also
//matches with start_point. If it doesn't, it is that the tolerance
//is big for the features and that we have points that match up
//improperly.
if ( match_data_list.size() == 1 )
//Great. We have a solid match. Setup the data
//structure.
just_match_two_points(start_point, closest_point);
else
// start_point is point D.
//Basically there can be one of two conditions.
//1) A--------------------------------------B
// C----------D------------------------------E
//This condition, D is within tolerance of A, but
//A's closest point is C. To resolve this, we need
//to match D with the segment A-B.
//2)
// D
// E-----------C-------
// B----------A--------------F
//For this condition, D matches with A, but A matches
//with the C. This case we want to ignore.
ImprintLineSegment *line_seg = temp_match->get_closest_seg();
if ( line_seg == NULL )
PRINT_ERROR("Bad logic in ImprintBoundaryTool::match_point, bug...\n");
assert(line_seg != NULL);
ImprintPointData *point_D = start_point;
//ImprintPointData *point_A = closest_point;
ImprintPointData *point_C = temp_match->get_closest_point();
//Find if D and C are on the same segment. If they
//are assume we have condition 1, else assume condition 2.
ImprintLineSegment *prev_seg = line_seg->get_prev();
ImprintLineSegment *next_seg = line_seg->get_next();
CubitBoolean ignore = CUBIT_TRUE;
if ( (point_D == prev_seg->get_start() ||
point_D == prev_seg->get_end() ) &&
(point_C == prev_seg->get_start() ||
point_C == prev_seg->get_end() ) )
ignore = CUBIT_FALSE;
else if ((point_D == line_seg->get_start() ||
point_D == line_seg->get_end() ) &&
(point_C == line_seg->get_start() ||
point_C == line_seg->get_end() ) )
else if ((point_D == next_seg->get_start() ||
point_D == next_seg->get_end() ) &&
(point_C == next_seg->get_start() ||
point_C == next_seg->get_end() ) )
// if ( ignore )
// start_point->set_unmatched();
if ( !ignore )
line_seg = start_match->get_closest_seg();
ImprintLineSegment *other_seg;
if ( closest_point == line_seg->get_start() )
other_seg = line_seg->get_prev();
else
other_seg = line_seg->get_next();
//Find out which segment start_point is closest to.
CubitVector close_1, close_2, start_v = start_point->coordinates();
CubitBoolean on_line_seg = CUBIT_FALSE;
CubitBoolean on_other_seg = CUBIT_FALSE;
if ( closest_point_interior_seg(start_point,
line_seg, close_1 ) )
if ( start_v.within_tolerance(close_1, myTolerance) )
on_line_seg = CUBIT_TRUE;
other_seg, close_2 ) )
if ( start_v.within_tolerance(close_2, myTolerance) )
on_other_seg = CUBIT_TRUE;
ImprintLineSegment *the_seg = NULL;
CubitVector the_point;
if ( on_line_seg && !on_other_seg )
the_seg = line_seg;
the_point = close_1;
else if ( !on_line_seg && on_other_seg )
the_seg = other_seg;
the_point = close_2;
else if ( on_line_seg && on_other_seg )
double dist_1 = (start_v-close_1).length_squared();
double dist_2 = (start_v-close_2).length_squared();
if ( dist_1 < dist_2 )
the_seg = line_seg;
else
if ( the_point.within_tolerance(closest_point->coordinates(),
GEOMETRY_RESABS*500 ) )
PRINT_ERROR("The tolerance is too large for virtual imprinting\n"
"Surface %d and %d\n", refFacePtr1->id(),
refFacePtr2->id());
start_match->set_closest_seg(the_seg);
start_match->set_point_on(the_point);
return match_on_segment(start_point, start_match,
loop_heads, num_loops,
atree_2);
else
if ( match_data_list.size() == 0 )
else
PRINT_ERROR("This is a bug in virtual imprinting, try reducing\n"
"the tolerance.\n");
| CubitStatus ImprintBoundaryTool::match_on_segment | ( | ImprintPointData * | start_point, |
| ) | [private] |
Definition at line 5303 of file ImprintBoundaryTool.cpp.
//Closest point is on a segment on the other boundary.
//Split that segment at the closest point.
//Adjust the data...
ImprintLineSegment *new_seg_1,*new_seg_2;
ImprintLineSegment* closest_seg = start_match->get_closest_seg();
CubitVector closest_vec(*(start_match->get_point_on()));
ImprintPointData *new_point = new ImprintPointData(start_point,
closest_vec);
allocatedPointData->append(new_point);
new_point->owner(closest_seg->owner());
if ( start_point->is_owner_vertex() )
new_point->set_point_type(CREATE_NEW_VERTEX);
if ( start_point->get_point_type() != CREATE_NEW_VERTEX )
start_point->set_point_type(VERTEX_ON_BOTH_BOUNDARIES);
else
new_point->set_point_type(ON_BOTH_BOUNDARIES);
start_point->set_point_type(ON_BOTH_BOUNDARIES);
new_seg_1 = new ImprintLineSegment( closest_seg->get_start(),
new_point,
new_seg_2 = new ImprintLineSegment( new_point,
closest_seg->get_end(),
allocatedLineData->append(new_seg_1);
allocatedLineData->append(new_seg_2);
//update the linked list structure to leave out the closest_seg
//but include the new segs instead.
update_linked_list(closest_seg, new_seg_1, new_seg_2);
//update the ImprintMatchData that reference the closest_seg
//to reference new_seg_1 or new_seg_2.
CubitStatus stat = update_seg_matches(closest_seg, new_seg_1, new_seg_2, start_match);
return stat;
closest_seg->set_inactive(CUBIT_TRUE);
int jj;
for (jj = 0; jj < num_loops; jj++ )
if ( loop_heads[jj] == closest_seg )
loop_heads[jj] = new_seg_1;
//update the atree.
atree_2.remove(closest_seg);
atree_2.add(new_seg_1);
atree_2.add(new_seg_2);
| CubitStatus ImprintBoundaryTool::match_points | ( | ImprintLineSegment * | seg_1, |
| MatchType & | type_0, | ||
| MatchType & | type_1, | ||
| MatchType & | type_2, | ||
| MatchType & | type_3 | ||
| ) | [private] |
Definition at line 4382 of file ImprintBoundaryTool.cpp.
ImprintPointData *imp_point_0, *imp_point_1, *imp_point_2, *imp_point_3;
ImprintPointData *imp_point_4, *imp_point_5, *imp_point_6, *imp_point_7;
ImprintLineSegment *prev_seg_1 = seg_1->get_prev();
ImprintLineSegment *next_seg_1 = seg_1->get_next();
ImprintLineSegment *prev_seg_2 = seg_2->get_prev();
ImprintLineSegment *next_seg_2 = seg_2->get_next();
imp_point_4 = prev_seg_1->get_start();
imp_point_5 = next_seg_1->get_end();
imp_point_6 = prev_seg_2->get_start();
imp_point_7 = next_seg_2->get_end();
CubitVector point_0, point_1, point_2, point_3;
CubitVector point_4, point_5, point_6, point_7;
point_4 = imp_point_4->coordinates();
point_5 = imp_point_5->coordinates();
point_6 = imp_point_6->coordinates();
point_7 = imp_point_7->coordinates();
//There are four possible matches for each of the points (0,1,2,and3).
//Find out which ones match.
CubitBoolean match_02=CUBIT_FALSE, match_03=CUBIT_FALSE,
match_06=CUBIT_FALSE, match_07=CUBIT_FALSE;
CubitBoolean match_12=CUBIT_FALSE, match_13=CUBIT_FALSE,
match_16=CUBIT_FALSE, match_17=CUBIT_FALSE;
CubitBoolean match_24=CUBIT_FALSE, match_25=CUBIT_FALSE;
CubitBoolean match_34=CUBIT_FALSE, match_35=CUBIT_FALSE;
//compute the matching.
if (point_0.within_tolerance(point_2, myTolerance) )
match_02=CUBIT_TRUE;
if (point_0.within_tolerance(point_3, myTolerance) )
match_03=CUBIT_TRUE;
if (point_0.within_tolerance(point_6, myTolerance) )
match_06=CUBIT_TRUE;
if (point_0.within_tolerance(point_7, myTolerance) )
match_07=CUBIT_TRUE;
if (point_1.within_tolerance(point_2, myTolerance) )
match_12=CUBIT_TRUE;
if (point_1.within_tolerance(point_3, myTolerance) )
match_13=CUBIT_TRUE;
if (point_1.within_tolerance(point_6, myTolerance) )
match_16=CUBIT_TRUE;
if (point_1.within_tolerance(point_7, myTolerance) )
match_17=CUBIT_TRUE;
if (point_2.within_tolerance(point_4, myTolerance) )
match_24=CUBIT_TRUE;
if (point_2.within_tolerance(point_5, myTolerance) )
match_25=CUBIT_TRUE;
if (point_3.within_tolerance(point_4, myTolerance) )
match_34=CUBIT_TRUE;
if (point_3.within_tolerance(point_5, myTolerance) )
match_35=CUBIT_TRUE;
//Now for those that match, compute the distances.
double dist_02 = 0.0, dist_03 = 0.0, dist_06 = 0.0, dist_07 = 0.0;
double dist_12 = 0.0, dist_13 = 0.0, dist_16 = 0.0, dist_17 = 0.0;
double dist_24 = 0.0, dist_25 = 0.0;
double dist_34 = 0.0, dist_35 = 0.0;
if ( match_02 )
dist_02 = (point_0-point_2).length_squared();
if ( match_03 )
dist_03 = (point_0-point_3).length_squared();
if ( match_06 )
dist_06 = (point_0-point_6).length_squared();
if ( match_07 )
dist_07 = (point_0-point_7).length_squared();
if ( match_12 )
dist_12 = (point_1-point_2).length_squared();
if ( match_13 )
dist_13 = (point_1-point_3).length_squared();
if ( match_16 )
dist_16 = (point_1-point_6).length_squared();
if ( match_17 )
dist_17 = (point_1-point_7).length_squared();
if ( match_24 )
dist_24 = (point_2-point_4).length_squared();
if ( match_25 )
dist_25 = (point_2-point_5).length_squared();
if ( match_34 )
dist_34 = (point_3-point_4).length_squared();
if ( match_35 )
dist_35 = (point_3-point_5).length_squared();
//Okay, determine the solution by finding the closest
//points, and then determining the final four results;
//point 0
type_0 = NO_MATCH;
type_1 = NO_MATCH;
type_2 = NO_MATCH;
type_3 = NO_MATCH;
if ( match_02 && dist_02 < min_dist )
min_dist = dist_02;
type_0 = MATCH_0_2;
if ( match_03 && dist_03 < min_dist )
min_dist = dist_03;
type_0 = MATCH_0_3;
if ( match_06 && dist_06 < min_dist )
min_dist = dist_06;
type_0 = MATCH_0_6;
if ( match_07 && dist_07 < min_dist )
min_dist = dist_07;
type_0 = MATCH_0_7;
//point 1
type_1 = NO_MATCH;
if ( match_12 && dist_12 < min_dist )
min_dist = dist_12;
type_1 = MATCH_1_2;
if ( match_13 && dist_13 < min_dist )
min_dist = dist_13;
type_1 = MATCH_1_3;
if ( match_16 && dist_16 < min_dist )
min_dist = dist_16;
type_1 = MATCH_1_6;
if ( match_17 && dist_17 < min_dist )
min_dist = dist_17;
type_1 = MATCH_1_7;
//point 2
type_2 = NO_MATCH;
min_dist = dist_02;
type_2 = MATCH_0_2;
min_dist = dist_12;
type_2 = MATCH_1_2;
if ( match_24 && dist_24 < min_dist )
min_dist = dist_24;
type_2 = MATCH_2_4;
if ( match_25 && dist_25 < min_dist )
min_dist = dist_25;
type_2 = MATCH_2_5;
//point 3
type_3 = NO_MATCH;
min_dist = dist_03;
type_3 = MATCH_0_3;
min_dist = dist_13;
type_3 = MATCH_1_3;
if ( match_34 && dist_34 < min_dist )
min_dist = dist_34;
type_3 = MATCH_3_4;
if ( match_35 && dist_35 < min_dist )
min_dist = dist_35;
type_3 = MATCH_3_5;
| CubitStatus ImprintBoundaryTool::match_seg_points | ( | ImprintLineSegment * | seg_1, |
| ImprintMatchData *& | point_0_match, | ||
| ImprintMatchData *& | point_1_match | ||
| ) | [private] |
Definition at line 4804 of file ImprintBoundaryTool.cpp.
CubitBoolean dont_test_0 = imp_point_0->is_matched();
CubitBoolean dont_test_1 = imp_point_1->is_matched();
point_0_match = NULL;
point_1_match = NULL;
if ( dont_test_0 && dont_test_1 )
int debug = 0;
if ( debug )
draw_seg(seg_1, CUBIT_GREEN_INDEX);
draw_seg(seg_2, CUBIT_YELLOW_INDEX);
draw_point(imp_point_0, CUBIT_GREEN_INDEX);
draw_point(imp_point_1, CUBIT_GREEN_INDEX);
draw_point(imp_point_2, CUBIT_YELLOW_INDEX);
draw_point(imp_point_3, CUBIT_YELLOW_INDEX);
GfxDebug::mouse_xforms();
CubitBoolean match_02=CUBIT_FALSE, match_03=CUBIT_FALSE;
CubitBoolean match_12=CUBIT_FALSE, match_13=CUBIT_FALSE;
if ( !dont_test_0 )
if ( !dont_test_1 )
double dist_02 = 0.0, dist_03 = 0.0;
double dist_12 = 0.0, dist_13 = 0.0;
if ( match_02 )
if ( match_03 )
if ( match_12 )
if ( match_13 )
if ( match_02 && match_03 )
if ( dist_02 < dist_03 )
match_03 = CUBIT_FALSE;
else
match_02 = CUBIT_FALSE;
if ( match_12 && match_13 )
if ( dist_12 < dist_13 )
match_13 = CUBIT_FALSE;
else
match_12 = CUBIT_FALSE;
//Now find the closest points on the segment.
CubitBoolean on_interior_0 = CUBIT_FALSE;
CubitBoolean on_interior_1 = CUBIT_FALSE;
CubitVector closest_point_0, closest_point_1;
if ( !dont_test_0 && closest_point_interior_seg(imp_point_0,
seg_2,
closest_point_0 ) )
if ( point_0.within_tolerance(closest_point_0,
myTolerance) )
//There is a close point on the interior.
on_interior_0 = CUBIT_TRUE;
if ( !dont_test_1 && closest_point_interior_seg(imp_point_1,
seg_2,
closest_point_1 ) )
//This means the closest_point is perpendicular
//to the segment. Now test if the point is within
//tolerance.
if ( point_1.within_tolerance(closest_point_1,
myTolerance) )
on_interior_1 = CUBIT_TRUE;
//point 0
//double min_dist = CUBIT_DBL_MAX;
if ( match_02 )
point_0_match = new ImprintMatchData;
if ( on_interior_0 )
//set the distance to be equal to the
//distance to the closest_point_0 and point_0 rather
//than 2 and 0. 0 and 2 should snap together but
//for finding the min distance, we want to make sure
//we get the closest segment.
dist_02 = (point_0 - closest_point_0).length_squared();
allocatedMatchData->append(point_0_match);
point_0_match->set_closest_point(imp_point_2);
point_0_match->set_closest_dist(dist_02);
point_0_match->set_closest_seg(seg_2);
seg_2->add_match_data(point_0_match);
else if ( match_03 )
//than 3 and 0. 0 and 3 should snap together but
dist_03 = (point_0 - closest_point_0).length_squared();
point_0_match->set_closest_point(imp_point_3);
point_0_match->set_closest_dist(dist_03);
else if ( on_interior_0 && !match_02 && !match_03 )
double dist = (point_0 - closest_point_0).length_squared();
point_0_match->set_point_on(closest_point_0);
point_0_match->set_closest_dist(dist);
if ( match_12 )
point_1_match = new ImprintMatchData;
if ( on_interior_1 )
//distance to the closest_point_1 and point_1 rather
//than 2 and 1. 1 and 2 should snap together but
dist_12 = (point_1 - closest_point_1).length_squared();
allocatedMatchData->append(point_1_match);
point_1_match->set_closest_point(imp_point_2);
point_1_match->set_closest_dist(dist_12);
point_1_match->set_closest_seg(seg_2);
seg_2->add_match_data(point_1_match);
else if ( match_13 )
//than 3 and 1. 1 and 3 should snap together but
dist_13 = (point_1 - closest_point_1).length_squared();
point_1_match->set_closest_point(imp_point_3);
point_1_match->set_closest_dist(dist_13);
else if ( on_interior_1 && !match_12 && !match_13 )
double dist = (point_1 - closest_point_1).length_squared();
//double debug_dist = (point_0 - point_2).length();
point_1_match->set_point_on(closest_point_1);
point_1_match->set_closest_dist(dist);
| CubitStatus ImprintBoundaryTool::merge_vertices | ( | DLIList< RefVertex * > & | ref_verts | ) | [private] |
Definition at line 4044 of file ImprintBoundaryTool.cpp.
//This is simply a function to reduce code bloat...
double tol_factor = myTolerance / GEOMETRY_RESABS;
double old_geometry_factor = GeometryQueryTool::get_geometry_factor();
GeometryQueryTool::set_geometry_factor( tol_factor );
//merge the vertices to get a connected intersection graph.
CubitStatus stat = MergeTool::instance()->merge_refvertices( ref_verts );
GeometryQueryTool::set_geometry_factor( old_geometry_factor );
if ( stat != CUBIT_SUCCESS )
return stat;
| CubitStatus ImprintBoundaryTool::merge_vertices | ( | RefVertex * | ref_vertex1, |
| RefVertex * | ref_vertex2, | ||
| CubitBoolean & | kept_1 | ||
| ) | [private] |
Definition at line 4057 of file ImprintBoundaryTool.cpp.
//force merge the vertices
RefVertex* result = MergeTool::instance()->
force_merge( ref_vertex1, ref_vertex2 );
if (result == ref_vertex1)
else if(result == ref_vertex2)
kept_1 = CUBIT_FALSE;
else
return CUBIT_FAILURE;
| CubitBoolean ImprintBoundaryTool::modified_bound_1 | ( | ) | [inline] |
Definition at line 519 of file ImprintBoundaryTool.hpp.
{return modBound1;}
| CubitBoolean ImprintBoundaryTool::modified_bound_2 | ( | ) | [inline] |
Definition at line 521 of file ImprintBoundaryTool.hpp.
{return modBound2;}
| int ImprintBoundaryTool::num_coedges_on_face | ( | RefEdge * | edge_ptr, |
| RefFace * | ref_face | ||
| ) | [private] |
Definition at line 4587 of file ImprintBoundaryTool.cpp.
DLIList <CoEdge*> coedges;
edge_ptr->co_edges(coedges);
int ii;
int count = 0;
for ( ii = coedges.size(); ii > 0; ii-- )
if ( coedges.get_and_step()->get_ref_face() == ref_face )
count++;
return count;
| CubitBoolean ImprintBoundaryTool::on_curve | ( | ImprintPointData * | point, |
| RefEdge * | ref_edge | ||
| ) | [private] |
Definition at line 3470 of file ImprintBoundaryTool.cpp.
CubitBoolean on_boundary = CUBIT_FALSE;
//Determine if the vertex is on the curve within the feature size...
CubitVector vert_point = point->coordinates();
CubitVector point_on = point->coordinates();
//Move the point to the curve and check the distance.
ref_edge->closest_point_trimmed(vert_point, point_on);
CubitVector distance = vert_point - point_on;
double leng = distance.length();
if ( leng < myTolerance )
on_boundary = CUBIT_TRUE;
return on_boundary;
| CubitBoolean ImprintBoundaryTool::on_interior_segment | ( | ImprintPointData * | point, |
| ImprintLineSegment * | line | ||
| ) | [private] |
Definition at line 2774 of file ImprintBoundaryTool.cpp.
//Find the closest point on the line segement.
CubitBoolean on_interior = closest_point_interior_seg( point, line, closest_point);
if (!on_interior )
return CUBIT_FALSE;
CubitVector my_point = point->coordinates();
if ( my_point.within_tolerance( closest_point, myTolerance ) )
return CUBIT_TRUE;
else
return CUBIT_FALSE;
| CubitBoolean ImprintBoundaryTool::on_surface | ( | ImprintPointData * | point, |
| ) | [private] |
Definition at line 3445 of file ImprintBoundaryTool.cpp.
CubitVector point_on = vert_point;
ref_face->find_closest_point_trimmed(vert_point, point_on);
if ( vert_point.within_tolerance(point_on, myTolerance) )
return CUBIT_TRUE;
else
return CUBIT_FALSE;
| CubitBoolean ImprintBoundaryTool::on_surface | ( | CubitVector & | vert_point, |
| ) | [private] |
Definition at line 3458 of file ImprintBoundaryTool.cpp.
return CUBIT_TRUE;
else
return CUBIT_FALSE;
| CubitStatus ImprintBoundaryTool::point_intersects_case | ( | ImprintPointData * | curr_point, |
| ImprintPointData * | next_point, | ||
| RefFace * | ref_face, | ||
| PointLoopList & | part_segs, | ||
| PointList *& | new_part_line, | ||
| CubitBoolean & | start_recording, | ||
| CubitBoolean | surf_1 | ||
| ) | [private] |
Definition at line 3273 of file ImprintBoundaryTool.cpp.
PointType vertex_my_boundary = surf_1 ? VERTEX_ON_BOUNDARY_2 : VERTEX_ON_BOUNDARY_1;
PointType edge_my_boundary = surf_1 ? ON_BOUNDARY_2 : ON_BOUNDARY_1;
CubitBoolean do_nothing = CUBIT_FALSE;
ImprintPointData *match_point_cur, *match_point_nex;
if ( !start_recording )
//Okay. This is an intersection. The possible outcomes are:
//1) This is the end of a paritition :-> do nothing.
//2) This is the begining of a short partition (one segment)
//3) This is the begining of a parition :-> start recording it.
//4) This is a vertex imprint from our surface. :-> do nothing.
//For case 1 resolution, we need to test to see if the next node is either:
// a) on the boundary of both surf 1 and surf 2.
// b) outside surf 1 and not intersecting surf_1's boundary.
// If case a, then we need to find out if its matching point
// and the matching point of the next point are on the same
// segment.
//For case 2, we need to test the underlying refentities to
//see if we really are splitting a surface or on a the boundary.
//For case 3, we need to test the next node to see if it is
//only on loop 2's boundary and INTERIOR to the ref_face.
//For case 4, that will be the counter examples of case 3 or
//rather when their interior or refentity traversals fail.
//Also if the next node is on both boundaries but not as
//a vertex. This is a simple overlap.
//Both points are vertices. Need to find out if this is a
//single segment split or on the boundary.
if ( next_point->get_point_type() == CREATE_NEW_VERTEX ||
next_point->get_point_type() == VERTEX_ON_BOTH_BOUNDARIES )
//To decifer, determine this from the topology of the points
//these match with on boundary 1.
match_point_cur = curr_point->get_matching_point();
match_point_nex = next_point->get_matching_point();
int list_id_1 = match_point_cur->get_loop_pos();
int list_id_2 = match_point_nex->get_loop_pos();
if ( list_id_1 == 0 )
if (list_id_2 == match_point_nex->get_loop_size() - 1 )
//okay force this to work, we just went around the loop.
list_id_2 = 1;
if ( list_id_2 == 0 )
if (list_id_1 == match_point_nex->get_loop_size() - 1 )
list_id_1 = 1;
int diff;
if ( list_id_1 > list_id_2 )
diff = list_id_1 - list_id_2;
else
diff = list_id_2 - list_id_1;
if ( (match_point_cur->get_list_loop_pos() ==
match_point_nex->get_list_loop_pos()) &&
diff == 1 )
//CASE 1
//This is the case that curr_point and next_point are
//both create vertices or matched with vertices.
//If the points that they match with, are also right
//next to each other, then don't partition them since
//they all match prefectly.
do_nothing = CUBIT_TRUE;
else
//Also, this may be a case where the one boundary is
//curved and the segment croses the curve portion.
//We'll have to do a surface check mid-way through
//the segment.
CubitVector p0 = curr_point->coordinates();
CubitVector p1 = next_point->coordinates();
CubitVector point_q = p0 + (p1-p0)*.5;
if ( on_surface(point_q, ref_face) )
//CASE 2
//So they aren't connected. This means that
//we need to have a single segment where we
//partition with just these two points.
new_part_line = new PointList;
allocatedPointLoops->append(new_part_line);
new_part_line->append(curr_point);
new_part_line->append(next_point);
curr_point->set_start_partition();
next_point->set_end_partition();
part_segs.append(new_part_line);
new_part_line = NULL;
else
else if ( next_point->get_point_type() == ON_BOTH_BOUNDARIES )
//CASE 4.
//hmmm. This has got to be a simple imprint so do nothing here.
else if ( next_point->get_point_type() == edge_my_boundary ||
next_point->get_point_type() == vertex_my_boundary )
//We need to test to see if this point is on the ref_face or not.
//If it is, then we need to start recording. If it
//isn't then we can do nothing.
if ( on_surface(next_point, ref_face) )
//CASE 3
start_recording = CUBIT_TRUE;
else
//CASE 4
else
PRINT_ERROR("Bad Logic ImprintBoundaryTool::find_graph_for_surf.\n");
assert(0);
if ( do_nothing )
assert(start_recording);
//Okay start recording. Create a new list. Put the curr_point
//into that list and continue.
else {
//Now we need to terminate the recording.
curr_point->set_end_partition();
if ( !curr_point->get_start_partition() )
else{
//case where circle loop imprints an edge at just one point.
//do nothing.
start_recording = CUBIT_FALSE;
| CubitBoolean ImprintBoundaryTool::resolve_match_conflict_other | ( | ImprintPointData * | this_point, |
| ImprintPointData * | other, | ||
| CubitBoolean | this_is_1 | ||
| ) | [private] |
Definition at line 4239 of file ImprintBoundaryTool.cpp.
CubitVector other_v = other->coordinates();
CubitVector coords = this_point->coordinates();
ImprintPointData *conflict_match = other->get_matching_point();
CubitVector c_match_vec = conflict_match->coordinates();
double dist_1 = (other_v - c_match_vec).length_squared();
double dist_2 = (other_v - coords).length_squared();
if ( dist_1 < dist_2 ) //this says leave it alone, and don't match these two.
//The conflict match and other should be left matching. Don't
//match this_point and other...
return CUBIT_FALSE;
else
//Okay we need to clean this up.
//It used to be that conflict_match and other were paired
//up. But now we need to undo that and match other and this_point.
//To do that find out what the correct PointType setting should be
//for conflict_match. Try setting it back to its original.
RefEntity* owner_conflict = conflict_match->owner();
//Use the this_is_1 flag. Assume conflict_match and
//this_point are on the same boundary.
if( CAST_TO(owner_conflict, RefEdge) )
if ( this_is_1 )
conflict_match->set_point_type(ON_BOUNDARY_1);
else
conflict_match->set_point_type(ON_BOUNDARY_2);
else if ( CAST_TO(owner_conflict, RefVertex) )
if ( this_is_1 )
conflict_match->set_point_type(VERTEX_ON_BOUNDARY_1);
else
conflict_match->set_point_type(VERTEX_ON_BOUNDARY_2);
else
PRINT_ERROR("Problems resolving matching point type.\n");
return CUBIT_FALSE;
//Now do the same thing for other. Clean it back to its
//preset types. (except use the opposite of this_is_1 flag
//since it is on the other boundary of this_point.)
RefEntity* owner_other = other->owner();
if( CAST_TO(owner_other,RefEdge) )
if ( this_is_1 )
other->set_point_type(ON_BOUNDARY_2);
else
other->set_point_type(ON_BOUNDARY_1);
else if ( CAST_TO(owner_other,RefVertex))
if ( this_is_1 )
other->set_point_type(VERTEX_ON_BOUNDARY_2);
else
other->set_point_type(VERTEX_ON_BOUNDARY_1);
else
return CUBIT_FALSE;
return CUBIT_TRUE;
| CubitBoolean ImprintBoundaryTool::resolve_match_conflict_this | ( | ImprintPointData * | this_point, |
| ) | [private] |
Definition at line 4311 of file ImprintBoundaryTool.cpp.
ImprintPointData *conflict_match = this_point->get_matching_point();
double dist_1 = (coords - c_match_vec).length_squared();
double dist_2 = (coords - other_v).length_squared();
//The conflict match and this_point should be left matching. Don't
return CUBIT_FALSE;
else
//It used to be that conflict_match and this_point were paired
//other are on the same boundary.
if( CAST_TO(owner_conflict,RefEdge) )
if ( this_is_1 )
else
else if ( CAST_TO(owner_conflict,RefVertex) )
if ( this_is_1 )
else
else
return CUBIT_FALSE;
//Now do the same thing for this_point. Clean it back to its
RefEntity* owner_this = this_point->owner();
if( CAST_TO(owner_this,RefEdge))
if ( this_is_1 )
this_point->set_point_type(ON_BOUNDARY_1);
else
this_point->set_point_type(ON_BOUNDARY_2);
else if (CAST_TO(owner_this,RefVertex) )
if ( this_is_1 )
this_point->set_point_type(VERTEX_ON_BOUNDARY_1);
else
this_point->set_point_type(VERTEX_ON_BOUNDARY_2);
else
return CUBIT_FALSE;
return CUBIT_TRUE;
| CubitStatus ImprintBoundaryTool::resolve_on_boundaries | ( | PointLoopList & | boundary_loops_1, |
| ) | [private] |
Definition at line 4175 of file ImprintBoundaryTool.cpp.
int ii, jj;
ImprintPointData *curr_point, *next_point, *prev_point, *matching_point;
//loop around the boundaries, if the point goes from on both boundaries to just on boundary,
//then we know we need to create a vertex there.
for ( ii = boundary_loops_1.size(); ii > 0; ii-- )
loop_ptr = boundary_loops_1.get_and_step();
curr_point = loop_ptr->get_and_step();
if ( curr_point->get_point_type() == ON_BOTH_BOUNDARIES )
next_point = loop_ptr->get();
prev_point = loop_ptr->prev(2);
if ( (next_point->get_point_type() == ON_BOUNDARY_1 ||
next_point->get_point_type() == VERTEX_ON_BOUNDARY_1) ||
(prev_point->get_point_type() == ON_BOUNDARY_1 ||
prev_point->get_point_type() == VERTEX_ON_BOUNDARY_1 ) )
curr_point->set_point_type(CREATE_NEW_VERTEX);
//If curr_point is on both boundaries, then the
//matching point cant be a vertex either so
//create a new vertex there too.
matching_point =curr_point->get_matching_point();
matching_point->set_point_type(CREATE_NEW_VERTEX);
for ( ii = boundary_loops_2.size(); ii > 0; ii-- )
loop_ptr = boundary_loops_2.get_and_step();
if ( (next_point->get_point_type() == ON_BOUNDARY_2 ||
next_point->get_point_type() == VERTEX_ON_BOUNDARY_2) ||
(prev_point->get_point_type() == ON_BOUNDARY_2 ||
prev_point->get_point_type() == VERTEX_ON_BOUNDARY_2 ) )
| void ImprintBoundaryTool::set_closest_point | ( | ImprintPointData * | imp_point_0 | ) | [private] |
Definition at line 4760 of file ImprintBoundaryTool.cpp.
DLIList <ImprintMatchData*> closest_points;
int kk;
imp_point_0->get_match_list(closest_points);
ImprintMatchData *closest_point = NULL, *close_point;
for ( kk = 0; kk < closest_points.size(); kk++ )
close_point = closest_points.get_and_step();
if ( close_point->get_closest_dist() < min_dist )
min_dist = close_point->get_closest_dist();
closest_point = close_point;
if ( closest_point )
imp_point_0->set_matched(closest_point);
| CubitStatus ImprintBoundaryTool::set_type_for_equal | ( | ImprintPointData * | pair_1_1, |
| ImprintPointData * | pair_1_2, | ||
| ImprintPointData * | pair_2_1, | ||
| ImprintPointData * | pair_2_2 | ||
| ) | [private] |
Definition at line 2674 of file ImprintBoundaryTool.cpp.
//Set the point types accoridingly.
if ( pair_1_1->is_owner_vertex() &&
!pair_1_2->is_owner_vertex() )
pair_1_2->set_point_type(CREATE_NEW_VERTEX);
if ( pair_1_1->get_point_type() != CREATE_NEW_VERTEX )
pair_1_1->set_point_type(VERTEX_ON_BOTH_BOUNDARIES);
else if (!pair_1_1->is_owner_vertex() &&
pair_1_1->set_point_type(CREATE_NEW_VERTEX);
if ( pair_1_2->get_point_type() != CREATE_NEW_VERTEX )
pair_1_2->set_point_type(VERTEX_ON_BOTH_BOUNDARIES);
else if ( pair_1_1->is_owner_vertex() &&
if (pair_1_2->get_point_type() != CREATE_NEW_VERTEX )
else
pair_1_1->set_point_type(ON_BOTH_BOUNDARIES);
pair_1_2->set_point_type(ON_BOTH_BOUNDARIES);
if ( pair_2_1->is_owner_vertex() &&
!pair_2_2->is_owner_vertex() )
pair_2_2->set_point_type(CREATE_NEW_VERTEX);
if ( pair_2_1->get_point_type() != CREATE_NEW_VERTEX )
pair_2_1->set_point_type(VERTEX_ON_BOTH_BOUNDARIES);
else if (!pair_2_1->is_owner_vertex() &&
pair_2_1->set_point_type(CREATE_NEW_VERTEX);
if ( pair_2_2->get_point_type() != CREATE_NEW_VERTEX )
pair_2_2->set_point_type(VERTEX_ON_BOTH_BOUNDARIES);
else if ( pair_2_1->is_owner_vertex() &&
else
pair_2_1->set_point_type(ON_BOTH_BOUNDARIES);
pair_2_2->set_point_type(ON_BOTH_BOUNDARIES);
| CubitStatus ImprintBoundaryTool::set_type_for_L | ( | ImprintPointData * | imp_point_1, |
| ImprintPointData * | imp_point_2 | ||
| ) | [private] |
Definition at line 2737 of file ImprintBoundaryTool.cpp.
CubitBoolean owner_vert_1 = imp_point_1->is_owner_vertex();
CubitBoolean owner_vert_2 = imp_point_2->is_owner_vertex();
if ( owner_vert_1 && !owner_vert_2 )
if (imp_point_1->get_point_type() != CREATE_NEW_VERTEX )
else if (!owner_vert_1 && owner_vert_2 )
if (imp_point_2->get_point_type() != CREATE_NEW_VERTEX )
else if ( owner_vert_1 && owner_vert_2 )
//Only make them verts on both boundaries if
//they aready all vertices. Their owner could
//have been set previously by some other intersection
//like a cross or a T. It is important that points
//that need vertices on them end up being marked
//as a vertex on the other boundary...
if(imp_point_1->get_point_type() != CREATE_NEW_VERTEX )
if(imp_point_2->get_point_type() != CREATE_NEW_VERTEX )
else
| void ImprintBoundaryTool::update_boundary_loops | ( | PointLoopList & | boundary_loops, |
| ImprintLineSegment ** | surf_loop_heads | ||
| ) | [private] |
Definition at line 5671 of file ImprintBoundaryTool.cpp.
int ii;
PointList *point_loop;
ImprintLineSegment *prev_seg, *seg;
CubitBoolean first = CUBIT_TRUE;
boundary_loops.reset();
for ( ii = 0; ii < boundary_loops.size(); ii++ )
point_loop = boundary_loops.get_and_step();
point_loop->clean_out();
//now from the linked list get the line loop.
prev_seg = surf_loop_heads[ii]->get_prev();
first = CUBIT_TRUE;
while( prev_seg != surf_loop_heads[ii]->get_prev() || first )
first = CUBIT_FALSE;
seg = prev_seg->get_next();
point_loop->append(seg->get_end());
if ( DEBUG_FLAG(129) )
draw_end(seg);
prev_seg = seg;
| void ImprintBoundaryTool::update_linked_list | ( | ImprintLineSegment * | old_seg, |
| ImprintLineSegment * | new_seg_1, | ||
| ImprintLineSegment * | new_seg_2 | ||
| ) | [private] |
| void ImprintBoundaryTool::update_list | ( | ImprintLineSegment ** | new_segments, |
| ImprintLineSegment * | seg_1, | ||
| const CubitBoolean | list_1 | ||
| ) | [private] |
Definition at line 1769 of file ImprintBoundaryTool.cpp.
if (list_1)
new_segments[0]->set_prev(seg_1->get_prev());
seg_1->get_prev()->set_next(new_segments[0]);
new_segments[0]->set_next(new_segments[1]);
new_segments[1]->set_prev(new_segments[0]);
new_segments[1]->set_next(seg_1->get_next());
seg_1->get_next()->set_prev(new_segments[1]);
else
new_segments[2]->set_prev(seg_2->get_prev());
seg_2->get_prev()->set_next(new_segments[2]);
new_segments[2]->set_next(new_segments[3]);
new_segments[3]->set_prev(new_segments[2]);
new_segments[3]->set_next(seg_2->get_next());
seg_2->get_next()->set_prev(new_segments[3]);
| CubitStatus ImprintBoundaryTool::update_seg_matches | ( | ImprintLineSegment * | old_seg, |
| ImprintLineSegment * | new_seg_2, | ||
| ImprintMatchData * | curr_match_data | ||
| ) | [private] |
Definition at line 5363 of file ImprintBoundaryTool.cpp.
DLIList <ImprintMatchData*> seg_match_data;
old_seg->get_match_data(seg_match_data);
if ( seg_match_data.size() == 0 )
//get the equation of the line.
CubitVector split_coord = new_seg_1->get_end()->coordinates();
CubitVector start_v = old_seg->get_start()->coordinates();
CubitVector end_v = old_seg->get_end()->coordinates();
CubitVector diff_end_start = end_v - start_v;
double dot1 = diff_end_start%diff_end_start;
if ( dot1 > -CUBIT_RESABS && dot1 < CUBIT_RESABS )
//This is bad. It means that the start and end
//vectors are really close together.
PRINT_ERROR("Segment used for imprinting is corrupted.\n");
PRINT_ERROR("Internal Imprint Problem, Please Report.\n");
CubitVector diff_split_start = split_coord - start_v;
double split_t = (diff_split_start%diff_end_start)/dot1;
int ii;
ImprintMatchData *match_data;
CubitVector *closest_point, diff_curr_start, temp_v;
double curr_t;
for ( ii = seg_match_data.size(); ii > 0; ii-- )
match_data = seg_match_data.get_and_step();
if ( match_data == curr_match_data )
continue;
closest_point = match_data->get_point_on();
if (closest_point == NULL )
temp_v = match_data->get_closest_point()->coordinates();
closest_point = &temp_v;
//Find the parametric position on the old_seg for this
//point.
diff_curr_start = (*closest_point) - start_v;
curr_t = (diff_curr_start%diff_end_start)/dot1;
if ( curr_t < split_t )
match_data->set_closest_seg(new_seg_1);
new_seg_1->add_match_data(match_data);
else if (curr_t > split_t )
match_data->set_closest_seg(new_seg_2);
new_seg_2->add_match_data(match_data);
else
//hmm two match datas at the same point. That is
//an error.
PRINT_ERROR("Bad logic in match data.\n");
| CubitBoolean ImprintBoundaryTool::valid_partition | ( | DLIList< RefEdge * > & | ref_edges, |
| ) | [private] |
Definition at line 3898 of file ImprintBoundaryTool.cpp.
//Test to make sure the vertices of the ref_edges hit at least twice
//on the boundary of the ref_face_ptr.
DLIList <RefVertex*> boundary_verts;
RefEdge *curr_edge;
RefVertex *ref_vert1, *ref_vert2;
int ii;
//int vert_boundary_count = 0;
for ( ii = ref_edges.size(); ii > 0; ii-- )
curr_edge = ref_edges.get_and_step();
ref_vert1 = curr_edge->start_vertex();
ref_vert2 = curr_edge->end_vertex();
if ( ref_vert1 == ref_vert2 )
continue;
if ( ref_vert1->num_ref_edges() < 2 )
return CUBIT_FALSE;
if ( ref_vert1->num_ref_faces() > 0)
boundary_verts.append(ref_vert1);
if ( ref_vert2->num_ref_edges() < 2 )
return CUBIT_FALSE;
if ( ref_vert2->num_ref_faces() > 0 )
boundary_verts.append(ref_vert2);
if ( ref_face->num_loops() > 1 )
//Walk on the surface. Determine if this partition is
//creating a sipeish partition. We can't handle that right
//now.
//Start with a boundary_vert. Determine the loop that it is
//on. Go on it accross the imprint. Find its imprint.
DLIList <Loop*> loop_list;
DLIList <RefEdge*> ref_edge_list;
Loop *start_loop = NULL;
while (boundary_verts.size())
ref_vert1 = boundary_verts.pop();
loop_list.clean_out();
ref_vert1->loops(loop_list);
for ( ii = loop_list.size(); ii > 0; ii-- )
if ( loop_list.get()->get_ref_face_ptr() == ref_face )
break;
else
loop_list.step();
if ( loop_list.get()->get_ref_face_ptr() != ref_face )
PRINT_ERROR("Problems in valid partition logic...");
return CUBIT_FALSE;
start_loop = loop_list.get();
do {
ref_edge_list.clean_out();
ref_vert1->ref_edges(ref_edge_list);
//Find the ref_edge that has no surfaces.
for ( ii = ref_edge_list.size(); ii > 0; ii--)
if ( ref_edge_list.get()->num_ref_faces() == 0 )
break;
else
ref_edge_list.step();
if ( ref_edge_list.get()->num_ref_faces() != 0 )
return CUBIT_FALSE;
curr_edge = ref_edge_list.get();
if ( curr_edge->start_vertex() ==
curr_edge->end_vertex() )
continue;
if ( curr_edge->start_vertex() == ref_vert1 )
else
ref_vert2 = curr_edge->start_vertex();
//This is a boundary vert. Remove it...
if ( !boundary_verts.move_to(ref_vert2) )
//If this has already been removed,
//then we have a bad partition.
return CUBIT_FALSE;
boundary_verts.remove(ref_vert2);
ref_vert2->loops(loop_list);
break;
else
loop_list.step();
return CUBIT_FALSE;
if ( loop_list.get() == start_loop )
//This isn't a bad partition. Break out to the outer loop.
//The partition splits its own loop which is fine...
break;
else if ( loop_list.get() != start_loop &&
boundary_verts.size() == 0 )
return CUBIT_FALSE;
//Okay, find a vertex on this loop that is a partition vertex.
DLIList <RefVertex*> ref_vertices;
loop_list.get()->ref_vertices(ref_vertices);
for ( ii = ref_vertices.size(); ii > 0; ii-- )
ref_vert1 = ref_vertices.get_and_step();
if ( ref_vert1 != ref_vert2 &&
boundary_verts.move_to(ref_vert1) )
break;
if ( ref_vert1 == ref_vert2 ||
!boundary_verts.move_to(ref_vert1) )
//if the vert had been removed or we have a loop
//this is a bad partition.
return CUBIT_FALSE;
//ref_vert1 is now set to continue on...
boundary_verts.remove(ref_vert1);
else
ref_vert1 = ref_vert2;
} while (ref_vert1 != NULL );
return CUBIT_TRUE;
SegList* ImprintBoundaryTool::allocatedLineData [private] |
Definition at line 106 of file ImprintBoundaryTool.hpp.
Definition at line 108 of file ImprintBoundaryTool.hpp.
Definition at line 109 of file ImprintBoundaryTool.hpp.
PointList* ImprintBoundaryTool::allocatedPointData [private] |
Definition at line 105 of file ImprintBoundaryTool.hpp.
Definition at line 107 of file ImprintBoundaryTool.hpp.
DLIList<RefEdge*>* ImprintBoundaryTool::allocatedRefEdge [private] |
Definition at line 110 of file ImprintBoundaryTool.hpp.
CubitBoolean ImprintBoundaryTool::modBound1 [private] |
Definition at line 101 of file ImprintBoundaryTool.hpp.
CubitBoolean ImprintBoundaryTool::modBound2 [private] |
Definition at line 102 of file ImprintBoundaryTool.hpp.
double ImprintBoundaryTool::myTolerance [private] |
Definition at line 98 of file ImprintBoundaryTool.hpp.
RefFace* ImprintBoundaryTool::refFacePtr1 [private] |
Definition at line 99 of file ImprintBoundaryTool.hpp.
RefFace* ImprintBoundaryTool::refFacePtr2 [private] |
Definition at line 100 of file ImprintBoundaryTool.hpp.
