cgma
00001 //--------------------------------------------------------------------------- 00002 //- Class: ImprintBoundaryTool 00003 //- Description: Given two surfaces, imprints the boundary loops on each 00004 //- other. Returns the intersection graph. 00005 //- 00006 //- Owner: David R. White 00007 //- Created: 4/15/2002 00008 //--------------------------------------------------------------------------- 00009 #ifndef IMPRINT_BOUNDARY_TOOL_HPP 00010 #define IMPRINT_BOUNDARY_TOOL_HPP 00011 00012 #include "GeometryDefines.h" 00013 #include "AbstractTree.hpp" 00014 #include "CubitDefines.h" 00015 #include "DLIList.hpp" 00016 class CubitVector; 00017 class RefEntity; 00018 class RefFace; 00019 class RefEdge; 00020 class RefVertex; 00021 class ImprintPointData; 00022 class ImprintLineSegment; 00023 class ImprintMatchData; 00024 template <class Y> class KDDTree; 00025 00026 template <class X> class DLIList; 00027 typedef DLIList <ImprintPointData*> PointList; 00028 typedef DLIList <PointList*> PointLoopList; 00029 typedef DLIList <ImprintLineSegment*> SegList; 00030 typedef DLIList <SegList*> SegLoopList; 00031 00032 enum IntersectResult { UNSET_INTERSECT = -1, 00033 NO_INTERSECT = 0, 00034 CROSS_INTERSECT,//Segments intersect like a cross or plus sign, not near end points. 00035 T_INTERSECT_0, //tells which node intersects of segments {0,1} and {2,3} 00036 T_INTERSECT_1, 00037 T_INTERSECT_2, 00038 T_INTERSECT_3, 00039 L_INTERSECT_0_2, // Segments intersect like an L or just at one end. 00040 L_INTERSECT_0_3,// Numbers denote which points of segments intersect of segments {0,1} and {2,3} 00041 L_INTERSECT_1_2, 00042 L_INTERSECT_1_3, 00043 OVERLAP_ALL_0_2_3_1, //One line fits entirely inside the other line. The number denotes 00044 OVERLAP_ALL_2_0_1_3, //which line is the super segment of segments {0,1} or {2,3} 00045 OVERLAP_ALL_2_1_0_3, 00046 OVERLAP_ALL_0_3_2_1, 00047 OVERLAP_PART_0_3, //Lines overlap, number denote which points are exterior of overlap. 00048 OVERLAP_PART_0_2, 00049 OVERLAP_PART_1_2, 00050 OVERLAP_PART_1_3, 00051 OVERLAP_JOIN_02_1_3,//Lines overlap, but are joined at one end. 00052 OVERLAP_JOIN_02_3_1,//First two digits denote nodes that are joined (or ontop of each other) 00053 OVERLAP_JOIN_03_1_2,//Next digit denotes node on segment. 00054 OVERLAP_JOIN_03_2_1,//Last digit denotes node at end that is not on anything. 00055 OVERLAP_JOIN_13_0_2, 00056 OVERLAP_JOIN_13_2_0, 00057 OVERLAP_JOIN_12_0_3, 00058 OVERLAP_JOIN_12_3_0, 00059 SEGS_EQUAL_0_2, //Linesegments are equal and match according to number. 00060 SEGS_EQUAL_0_3}; 00061 00062 // MatchType enum nomen-clature. Match points on segments 1 and 2. 00063 // But use the prev and next of each one also. This is 00064 // for resolve small segments relative to myTolerance. 00065 // 4---prev_seg_1--|0|------seg_1----|1|----next_seg_1---5 00066 // 00067 // 7---next_seg_2--|3|------seg_2----|2|----prev_seg_2---6 00068 // 00069 // OR 00070 // 00071 // 4---prev_seg_1--|0|------seg_1----|1|----next_seg_1---5 00072 // 00073 // 6---prev_seg_2--|2|------seg_2----|3|----next_seg_2---7 00074 enum MatchType { NO_MATCH, 00075 MATCH_0_2, 00076 MATCH_0_3, 00077 MATCH_0_6, 00078 MATCH_0_7, 00079 MATCH_1_2, 00080 MATCH_1_3, 00081 MATCH_1_6, 00082 MATCH_1_7, 00083 MATCH_2_4, 00084 MATCH_2_5, 00085 MATCH_3_4, 00086 MATCH_3_5, 00087 ON_SEG_1, 00088 ON_SEG_2 00089 }; 00090 // Enum for returning during a loop. Continue on, return or get out sucessful or 00091 // report and error. 00092 enum LoopEnum {RETURN_FAILURE, RETURN_SUCCESS, CONTINUE 00093 }; 00094 00095 class ImprintBoundaryTool 00096 { 00097 private: 00098 double myTolerance; 00099 RefFace *refFacePtr1; 00100 RefFace *refFacePtr2; 00101 CubitBoolean modBound1; 00102 CubitBoolean modBound2; 00103 00104 //- Tolerance used for imprinting and snapping imprints together. 00105 PointList *allocatedPointData; 00106 SegList *allocatedLineData; 00107 PointLoopList *allocatedPointLoops; 00108 SegLoopList *allocatedLineLoops; 00109 DLIList <ImprintMatchData*> *allocatedMatchData; 00110 DLIList <RefEdge*> *allocatedRefEdge; 00111 00112 00113 CubitStatus imprint_boundaries(PointLoopList &boundary_loops_1, 00114 PointLoopList &boundary_loops_2, 00115 RefFace *ref_face_1, 00116 RefFace *ref_face_2, 00117 DLIList <RefFace*> &results); 00118 //- Intersects the two boundary point loops. May delete point data or add point data to 00119 //- the loops. 00120 00121 CubitStatus get_boundary_points( RefFace *ref_face, 00122 PointLoopList &boundary_point_loops ); 00123 //- Gets the boundary points for the given surface. 00124 00125 CubitStatus get_curve_facets( RefEdge* curve, PointList& segments ); 00126 //- Gets the points that facet this curve. 00127 CubitStatus convert_to_lines( PointLoopList &boundary_point_loops, 00128 SegLoopList &boundary_line_loops, 00129 RefFace *ref_face, 00130 const CubitBoolean boundary_1); 00131 CubitStatus imprint_segments( SegLoopList &boundary_line_loops_1, 00132 SegLoopList &boundary_line_loops_2, 00133 PointLoopList &boundary_loops_1, 00134 PointLoopList &boundary_loops_2); 00135 //- Does the imprinting of the segments through finding the closest 00136 //- segments and closest points to match. Utilizes the AbstractTree for 00137 //- efficiency. 00138 00139 CubitStatus find_matching_points( SegLoopList &seg_loops, 00140 AbstractTree <ImprintLineSegment*>& atree ); 00141 //- Finds the matching points for a segments with those segments stored 00142 //- in the AbstractTree. The seg_loops contain the segments for one surface 00143 //- and the AbstractTree contains them for the other surface. 00144 00145 void set_closest_point(ImprintPointData *imp_point_0); 00146 //- Given the point, and the match data that has been added to it, find 00147 //- the point that is closest, and set that for the point. This is 00148 //- in preparation to actually setting the matching point... 00149 00150 CubitStatus find_closest_points(ImprintLineSegment *curr_seg, 00151 ImprintLineSegment *test_seg ); 00152 //- For the two segments. Finds the closest points between the 00153 //- segments for curr_seg. (Doesn't do anything for test_seg.) 00154 00155 CubitStatus match_seg_points( ImprintLineSegment *seg_1, 00156 ImprintLineSegment *seg_2, 00157 ImprintMatchData *&point_0_match, 00158 ImprintMatchData *&point_1_match ); 00159 //- Finds the match information between seg_1 and seg_2. The 00160 //- ImprintMatchData returned stores how the points for seg_1 00161 //- line up with seg_2 (do they match with points on seg2, do 00162 //- they match along seg_2, do they not match at all...). 00163 00164 CubitStatus final_match( ImprintLineSegment **surf_1_loop_heads, 00165 int num_loops_1, 00166 ImprintLineSegment **surf_2_loop_heads, 00167 int num_loops_2, 00168 AbstractTree <ImprintLineSegment*>& atree_1, 00169 AbstractTree <ImprintLineSegment*>& atree_2); 00170 //- Finally sets the matching point information for both of the loops. 00171 //- Makes sure that if a point matches one boundary with a point 00172 //- on the other boundary, that that point also matches with it. 00173 //- Does this for both surfaces. 00174 00175 CubitStatus final_match_loop(ImprintLineSegment **surf_1_loop_heads, 00176 int num_loops_1, 00177 ImprintLineSegment **surf_2_loop_heads, 00178 int num_loops_2, 00179 AbstractTree <ImprintLineSegment*>& atree_1, 00180 AbstractTree <ImprintLineSegment*>& atree_2); 00181 //- Resolve the matching points for loop_1, with the points in surface 2. 00182 //- If the match is determined to be on a segment, update the AbstractTree by 00183 //- removing split segments and adding the new segments. 00184 00185 CubitStatus match_on_point(ImprintPointData *start_point, 00186 ImprintMatchData *start_match, 00187 ImprintLineSegment **loop_heads, 00188 int num_loops, 00189 AbstractTree <ImprintLineSegment*>& atree_2); 00190 //- Match the start_point with the point stored in start match. Set 00191 //- the matching point data. This function may call match_on_segment if 00192 //- a point is matched up incorrectly. 00193 00194 CubitStatus match_on_segment(ImprintPointData *start_point, 00195 ImprintMatchData *start_match, 00196 ImprintLineSegment **loop_heads, 00197 int num_loops, 00198 AbstractTree <ImprintLineSegment*>& atree_2); 00199 //- Match the start point with the segment stored in startmatch. Split 00200 //- the segment and update the loops heads and AbstractTree accordingly. 00201 00202 CubitStatus update_seg_matches(ImprintLineSegment *old_seg, 00203 ImprintLineSegment *new_seg_1, 00204 ImprintLineSegment *new_seg_2, 00205 ImprintMatchData *curr_match_data); 00206 //- As the segments get split, match data points to it. Update 00207 //- the match data that may point to the old segment to point to 00208 //- the new_seg_1 or new_seg_2. curr_match_data is not updated 00209 //- since it was already used (passed in to ignore). 00210 00211 void update_linked_list(ImprintLineSegment *old_seg, 00212 ImprintLineSegment *new_seg_1, 00213 ImprintLineSegment *new_seg_2 ); 00214 //- With new_seg_1 and new_seg_2 replacing old_seg, add them 00215 //- in the proper places to the segment linked list. 00216 00217 void just_match_two_points(ImprintPointData *point_1, 00218 ImprintPointData *point_2 ); 00219 //- Does the low level data assignments for matching point_1 and point_2. 00220 00221 CubitStatus find_crossings(ImprintLineSegment **surf_1_loop_heads, 00222 int num_loops_1, 00223 ImprintLineSegment **surf_2_loop_heads, 00224 int num_loops_2, 00225 AbstractTree <ImprintLineSegment*>& atree ); 00226 //- Finds the crossings (segments that don't having any matching 00227 //- end points, but cross each other.). Splits the segments that 00228 //- cross and updates the data lists etc. Uses the atree of surface2. 00229 00230 CubitStatus do_crossing( ImprintPointData *imp_point_0, 00231 ImprintPointData *imp_point_1, 00232 ImprintPointData *imp_point_2, 00233 ImprintPointData *imp_point_3, 00234 ImprintLineSegment *&seg_1, 00235 ImprintLineSegment *seg_2, 00236 ImprintLineSegment **surf_1_loop_heads, 00237 int num_loops_1, 00238 ImprintLineSegment **surf_2_loop_heads, 00239 int num_loops_2, 00240 AbstractTree <ImprintLineSegment*>& atree, 00241 CubitBoolean &modified); 00242 00243 //- Computes the intersection of the two segments and does tha actual 00244 //- Crossing data updates. 00245 00246 void update_boundary_loops( PointLoopList &boundary_loops, 00247 ImprintLineSegment **surf_loop_heads); 00248 //- Updates the boundary_loops or rather replaces them with the 00249 //- data stored in the line segment linked lists. Remember all 00250 //- the allocated memory is tracked by the class and deleted for 00251 //- the class so no memory is cleaned at this time. 00252 00253 CubitStatus intersect_segments( ImprintLineSegment *seg_1, 00254 ImprintLineSegment *seg_2, 00255 IntersectResult &int_result, 00256 ImprintLineSegment **new_segments); 00257 //- Finds the intersection between seg_1 and seg_2. The possible intersections 00258 //- are enumerated in the IntersectResult enum and the function assigns 00259 //- the appropriate result to int_result. Also, if the intersection 00260 //- status requires it, the line segments are broken up into the new_segments 00261 //- array. This array is assumed to be previously allocated and to 00262 //- be of size 4. The first two positioins in the array are reserved for 00263 //- breaking up segment 1, the last two are for segment two. They are 00264 //- assumed to be properly ordered (the first positions line segment should 00265 //- have the same start point as seg_1). There is one exception to this. In 00266 //- the case of OVERLAP_ALL_*, one line segment fits entirely inside another 00267 //- line segment. The result is that one line segment gets split into *3* segments 00268 //- while the other is not split at all. In that case, the new_segments array, 00269 //- will have three entries. If the first segment is split into three, the new 00270 //- segments will occupy positions 0, 1, and 2. If it is the second, the new segments 00271 //- will occupy positions, 1, 2, and 3. Again these are also properly ordered. 00272 00273 void update_list(ImprintLineSegment **new_segments, 00274 ImprintLineSegment *seg_1, 00275 ImprintLineSegment *seg_2, 00276 const CubitBoolean list_1 ); 00277 //- utility function to update the linked list structure of the 00278 //- new segments. List 1 flag tells which list to update. 00279 00280 CubitStatus determine_on_boundary( ImprintLineSegment *seg_1, 00281 ImprintLineSegment *seg_2, 00282 MatchType &type_0, MatchType &type_1, 00283 MatchType &type_2, MatchType &type_3 ); 00284 //- Checks the nodes to find if they are on seg_1 or 2. They also 00285 //- determine based on the MatchType if the nodes should be matched 00286 //- with the segment or not. 00287 00288 CubitStatus case_0_2_equal( ImprintLineSegment *seg_1, 00289 ImprintLineSegment *seg_2, 00290 ImprintPointData* imp_point_0, 00291 ImprintPointData* imp_point_1, 00292 ImprintPointData* imp_point_2, 00293 ImprintPointData* imp_point_3, 00294 MatchType type_1, MatchType type_3, 00295 IntersectResult &int_result, 00296 ImprintLineSegment **new_segments); 00297 //- This function resolves the intersections cases where points 0 and 00298 //- 2 are known to be equal and the other two nodes are not within tolerance. 00299 //- Basically two types of intersections can be occuring. Either one of two 00300 //- OVERLAP_JOIN cases or an L_INTERSECT case. 00301 00302 CubitStatus case_0_3_equal( ImprintLineSegment *seg_1, 00303 ImprintLineSegment *seg_2, 00304 ImprintPointData* imp_point_0, 00305 ImprintPointData* imp_point_1, 00306 ImprintPointData* imp_point_2, 00307 ImprintPointData* imp_point_3, 00308 MatchType type_1, MatchType type_2, 00309 IntersectResult &int_result, 00310 ImprintLineSegment **new_segments); 00311 //- This function resolves the intersections cases where points 0 and 00312 //- 2 are known to be equal and the other two nodes are not within tolerance. 00313 //- Basically two types of intersections can be occuring. Either one of two 00314 //- OVERLAP_JOIN cases or an L_INTERSECT case. 00315 00316 CubitStatus case_1_2_equal( ImprintLineSegment *seg_1, 00317 ImprintLineSegment *seg_2, 00318 ImprintPointData* imp_point_0, 00319 ImprintPointData* imp_point_1, 00320 ImprintPointData* imp_point_2, 00321 ImprintPointData* imp_point_3, 00322 MatchType type_0, MatchType type_3, 00323 IntersectResult &int_result, 00324 ImprintLineSegment **new_segments); 00325 //- This function resolves the intersections cases where points 0 and 00326 //- 2 are known to be equal and the other two nodes are not within tolerance. 00327 //- Basically two types of intersections can be occuring. Either one of two 00328 //- OVERLAP_JOIN cases or an L_INTERSECT case. 00329 00330 CubitStatus case_1_3_equal( ImprintLineSegment *seg_1, 00331 ImprintLineSegment *seg_2, 00332 ImprintPointData* imp_point_0, 00333 ImprintPointData* imp_point_1, 00334 ImprintPointData* imp_point_2, 00335 ImprintPointData* imp_point_3, 00336 MatchType type_0, MatchType type_2, 00337 IntersectResult &int_result, 00338 ImprintLineSegment **new_segments); 00339 //- This function resolves the intersections cases where points 0 and 00340 //- 2 are known to be equal and the other two nodes are not within tolerance. 00341 //- Basically two types of intersections can be occuring. Either one of two 00342 //- OVERLAP_JOIN cases or an L_INTERSECT case. 00343 00344 CubitStatus set_type_for_equal(ImprintPointData *pair_1_1, 00345 ImprintPointData *pair_1_2, 00346 ImprintPointData *pair_2_1, 00347 ImprintPointData *pair_2_2); 00348 //- Given the two pairs of points that are equal on the 00349 //- respective boundaries (_1_1 is pair 1, point on boundary 1, 00350 //- _1_2 is pair 1, point on boundary 2, _2_1 is pair 2, point 00351 //- on boundary 2, etc...), set up the correct PointTypes for 00352 //- the nodes for the EQUAL case. 00353 00354 CubitStatus set_type_for_L(ImprintPointData *imp_point_1, 00355 ImprintPointData *imp_point_2); 00356 //- Given point_1 on boundary 1 and point_2 on boundary 2, set 00357 //- the correct point type for each point given the two points 00358 //- meet at an L condition. 00359 00360 CubitBoolean on_interior_segment(ImprintPointData *point, 00361 ImprintLineSegment *line ); 00362 //- Determines if the point is within myTolerance of the line segment. 00363 00364 CubitStatus closest_point_seg( ImprintPointData *point, 00365 ImprintLineSegment *line, 00366 CubitVector &closest_point ); 00367 //- Finds the closest point to the line segment. 00368 00369 CubitStatus closest_point_seg( CubitVector &point_v, 00370 ImprintLineSegment *line, 00371 CubitVector &closest_point ); 00372 //- Finds the closest point to the line segment. 00373 CubitBoolean closest_point_interior_seg( ImprintPointData *point, 00374 ImprintLineSegment *line, 00375 CubitVector &closest_point ); 00376 //- Finds the closest point to the line segment. 00377 00378 CubitStatus find_graph_for_surf(PointLoopList &boundary_loops_1, 00379 PointLoopList &boundary_loops_2, 00380 RefFace *ref_face, 00381 PointLoopList &part_segs, 00382 PointList &partition_points, 00383 CubitBoolean surf_1); 00384 //-Given the boundary_line_loops for a surface 00385 //-that have already been intersected against another 00386 //-surface, and the boundary_line_loops for that surface, 00387 //-determine the line segments that are needed 00388 //-to perform the actual imprint. Also find points 00389 //-That are need to partition or imprint the existing boundaries. 00390 //-These points will also include the points of the segments 00391 //-that touch against the boundary, if necessary. The 00392 //-RefFace is pretty important as it is used to determine 00393 //-if the points are inside or outside the surface. 00394 00395 CubitStatus point_intersects_case( ImprintPointData *curr_point, 00396 ImprintPointData *next_point, 00397 RefFace *ref_face, 00398 PointLoopList &part_segs, 00399 PointList *&new_part_line, 00400 CubitBoolean &start_recording, 00401 CubitBoolean surf_1 ); 00402 //-Given the fact that curr_point's PointType shows 00403 //-that it is a vertex on both boundaries or a new vertex, 00404 //-Resolve how the partition curves are extraced from the 00405 //-boundary loop 2 on surface 1. 00406 00407 CubitBoolean on_surface( ImprintPointData *point, 00408 RefFace *ref_face ); 00409 //-Determines through the find_closest_point_trimmed 00410 //-function if a point is inside or outside a surface. 00411 //-This is not a very efficient method but since the 00412 //-surface can be non-planar, we can't do a simple test. 00413 00414 CubitBoolean on_surface( CubitVector &vert_point, 00415 RefFace *ref_face ); 00416 //-Determines through the find_closest_point_trimmed 00417 //-function if a point is inside or outside a surface. 00418 //-This is not a very efficient method but since the 00419 //-surface can be non-planar, we can't do a simple test. 00420 00421 CubitBoolean on_curve( ImprintPointData *point, 00422 RefEdge *ref_edge ); 00423 00424 //- Determine if the point is within tolerance of the ref_edge. 00425 00426 CubitBoolean are_connected( RefEntity *ent_1, 00427 RefEntity *ent_2, 00428 RefFace *ref_face ); 00429 //-Determines through topology traversals 00430 //-if the two refentities are directly 00431 //-connected. The function assumes 00432 //-that the RefEntities are either RefVerticies or 00433 //-RefEdges. The entites must be connected within 00434 //-one entity for vertices or the same for 00435 //-curves... 00436 00437 CubitStatus imprint_boundary_vertices( PointList &partition_points, 00438 CubitBoolean &modified_boundary ); 00439 //-Given the data in the partition_points, partition the curves that the data points 00440 //-point to as their owner's. Reasign owners as RefVertices. 00441 00442 CubitStatus imprint_surface(RefFace *ref_face, 00443 PointLoopList &part_segs, 00444 DLIList <RefFace*> &results); 00445 //- Given the sorted partition segments, create refedges, then partition the 00446 //- surface. Also merge appropriate vertices. Relies on owner data, and matching 00447 //- data in the ImprintPointData class. 00448 00449 CubitBoolean valid_partition(DLIList <RefEdge*> &ref_edges, RefFace *ref_face ); 00450 //- Tests to see if the ref_edges are a valid parition, are there hard lines or unmerged 00451 //- lines in the lists of ref_edges. 00452 00453 CubitStatus merge_vertices(DLIList <RefVertex*> &ref_verts); 00454 //- Do the normal merging but use myTolerance as the merge tolerance. 00455 00456 CubitStatus merge_vertices(RefVertex *ref_vertex1, 00457 RefVertex *ref_vertex2, 00458 CubitBoolean &kept_1); 00459 //- Merge the two vertices. Do a force for speed. 00460 //- Assigns kept_1 if ref_vertex1 is the vertex that survives the 00461 //- merge. 00462 00463 CubitStatus resolve_on_boundaries( PointLoopList &boundary_loops_1, 00464 PointLoopList &boundary_loops_2); 00465 00466 CubitBoolean resolve_match_conflict_this(ImprintPointData *this_point, 00467 ImprintPointData *other, 00468 CubitBoolean this_is_1 ); 00469 CubitBoolean resolve_match_conflict_other(ImprintPointData *this_point, 00470 ImprintPointData *other, 00471 CubitBoolean this_is_1 ); 00472 CubitStatus match_points( ImprintLineSegment *seg_1, 00473 ImprintLineSegment *seg_2, 00474 MatchType &type_0, 00475 MatchType &type_1, 00476 MatchType &type_2, 00477 MatchType &type_3); 00478 //Computes how the end points between the segments match. If 00479 //The segments are small, points may match with previous or next nodes 00480 //along the boundary and are indicated by the MatchType. 00481 00482 void draw_seg(ImprintLineSegment *seg, int color = -1); 00483 //- draws the end node colored according to it's point type. 00484 void draw_point(ImprintPointData *imp_point, int color = -1); 00485 //- draws the end node colored according to it's point type. 00486 void draw_end(ImprintLineSegment *seg); 00487 //- draws the end node colored according to it's point type. 00488 void draw_loops(PointLoopList &boundary_loop); 00489 //- draws the loops of nodes. 00490 00491 int num_coedges_on_face(RefEdge *edge_ptr, 00492 RefFace *ref_face); 00493 //- Counts number of coedges this edge_ptr has that are also part of 00494 //- just this refface. 00495 00496 00497 CubitStatus ignore_match( ImprintPointData *start_point, 00498 ImprintMatchData *start_match, 00499 AbstractTree <ImprintLineSegment*>& atree_1, 00500 CubitBoolean &ignore); 00505 00506 RefEdge* create_virtual_edge(RefVertex *start, 00507 RefVertex *end, 00508 DLIList<CubitVector*> &interior_points); 00509 RefVertex* create_virtual_vertex(CubitVector &pos); 00510 00511 00512 00513 00514 public: 00515 ImprintBoundaryTool(RefFace *ref_face_1, 00516 RefFace *ref_face_2, 00517 double tol = GEOMETRY_RESABS); 00518 ~ImprintBoundaryTool(); 00519 CubitBoolean modified_bound_1() 00520 {return modBound1;} 00521 CubitBoolean modified_bound_2() 00522 {return modBound2;} 00523 00524 CubitStatus imprint(DLIList <RefFace*> &results, 00525 CubitBoolean merge = CUBIT_FALSE); 00526 //- Main interface function for imprinting the boundary loops 00527 //- of two refFaces. It is assumed that if the reffaces intersect 00528 //- at any where else other than the boundary loops, this will 00529 //- not be found. 00530 00531 00532 }; 00533 00534 #endif
