cgma
#include <ImprintPointData.hpp>
Definition at line 48 of file ImprintPointData.hpp.
| ImprintPointData::ImprintPointData | ( | double | x_val, |
| double | y_val, | ||
| double | z_val | ||
Definition at line 20 of file ImprintPointData.cpp.
: coords( x_val, y_val, z_val ) { initialize_imprint_data(); }
| ImprintPointData::ImprintPointData | ( | const CubitVector & | new_point | ) |
Definition at line 60 of file ImprintPointData.cpp.
: coords( new_point ) { initialize_imprint_data(); }
| ImprintPointData::ImprintPointData | ( | ImprintPointData * | copy, |
| CubitVector & | new_coords | ||
Definition at line 74 of file ImprintPointData.cpp.
coords = new_coords;
myPointType=copy->myPointType;
owner(copy->myOwner);
set_matching_point(copy);
copy->set_matching_point(this);
Definition at line 93 of file ImprintPointData.cpp.
if ( attachedFacets )
delete attachedFacets;
if ( pointMatches )
delete pointMatches;
| void ImprintPointData::add_facet | ( | CubitFacet * | facet | ) | [virtual] |
Implements CubitPoint.
Definition at line 124 of file ImprintPointData.cpp.
if ( attachedFacets == NULL )
attachedFacets = new DLIList<CubitFacet*>(8);
attachedFacets->append(facet);
return;
| void ImprintPointData::add_match_data | ( | ImprintMatchData * | match_data | ) |
Definition at line 207 of file ImprintPointData.cpp.
if ( !pointMatches )
pointMatches = new DLIList<ImprintMatchData*>;
pointMatches->append(match_data);
| void ImprintPointData::compute_avg_normal | ( | ) |
Reimplemented from CubitPoint.
| CubitVector ImprintPointData::coordinates | ( | void | ) | const [inline, virtual] |
| void ImprintPointData::coordinates | ( | double | point_array[3] | ) | [virtual] |
Definition at line 109 of file ImprintPointData.cpp.
| void ImprintPointData::edges | ( | DLIList< CubitFacetEdge * > & | edge_list | ) | [virtual] |
Definition at line 156 of file ImprintPointData.cpp.
int ii, jj, kk;
CubitFacet *facet_ptr;
CubitFacetEdge *edge_ptr, *check_edge_ptr;
for (ii=0; ii<attachedFacets->size(); ii++)
facet_ptr = attachedFacets->get_and_step();
for (jj=0; jj<3; jj++)
edge_ptr = facet_ptr->edge( jj );
if (edge_ptr)
if (edge_ptr->point(0) == this ||
edge_ptr->point(1) == this)
int found = 0;
for (kk=0; kk<edge_list.size() && !found; kk++)
check_edge_ptr = edge_list.get_and_step();
if (check_edge_ptr == edge_ptr)
found = 1;
if (!found)
edge_list.append( edge_ptr );
return;
| void ImprintPointData::facets | ( | DLIList< CubitFacet * > & | facet_list | ) | [inline, virtual] |
Definition at line 104 of file ImprintPointData.hpp.
{ if (attachedFacets) facet_list += *attachedFacets; }
| CubitBoolean ImprintPointData::get_end_partition | ( | ) | [inline] |
Definition at line 141 of file ImprintPointData.hpp.
{return endPartition;}
| int ImprintPointData::get_list_loop_pos | ( | ) | [inline] |
Definition at line 149 of file ImprintPointData.hpp.
{return listLoopPos;}
| int ImprintPointData::get_loop_pos | ( | ) | [inline] |
Definition at line 151 of file ImprintPointData.hpp.
{return loopPos;}
| int ImprintPointData::get_loop_size | ( | ) | [inline] |
Definition at line 153 of file ImprintPointData.hpp.
{return loopSize;}
| void ImprintPointData::get_match_list | ( | DLIList< ImprintMatchData * > & | match_data_list | ) |
Definition at line 213 of file ImprintPointData.cpp.
if ( pointMatches != NULL )
match_data_list += *pointMatches;
| ImprintPointData* ImprintPointData::get_matching_point | ( | ) | [inline] |
Definition at line 133 of file ImprintPointData.hpp.
{return matchingPoint;}
| ImprintLineSegment* ImprintPointData::get_next_seg | ( | ) | [inline] |
Definition at line 167 of file ImprintPointData.hpp.
{return nextSeg;}
| PointType ImprintPointData::get_point_type | ( | ) | [inline] |
Definition at line 130 of file ImprintPointData.hpp.
{return myPointType;}
| ImprintLineSegment* ImprintPointData::get_prev_seg | ( | ) | [inline] |
Definition at line 162 of file ImprintPointData.hpp.
{return prevSeg;}
| CubitBoolean ImprintPointData::get_start_partition | ( | ) | [inline] |
Definition at line 139 of file ImprintPointData.hpp.
{return startPartition;}
| void ImprintPointData::initialize_imprint_data | ( | ) | [private] |
Definition at line 25 of file ImprintPointData.cpp.
attachedFacets = NULL;
point_counter++;
entityId = point_counter;
myOwner = NULL;
myPointType = UNSET_POINT;
ownerRefVertex = CUBIT_FALSE;
matchingPoint = NULL;
startPartition = CUBIT_FALSE;
endPartition = CUBIT_FALSE;
listLoopPos = 0;
loopPos = 0;
pointMatches = NULL;
isMatched = CUBIT_FALSE;
prevSeg = NULL;
nextSeg = NULL;
| CubitBoolean ImprintPointData::is_matched | ( | ) | [inline] |
Definition at line 160 of file ImprintPointData.hpp.
{return isMatched;}
| CubitBoolean ImprintPointData::is_owner_vertex | ( | ) | [inline] |
Definition at line 119 of file ImprintPointData.hpp.
{if (myPointType == CREATE_NEW_VERTEX ||
myPointType == VERTEX_ON_BOUNDARY_1 ||
myPointType == VERTEX_ON_BOUNDARY_2 ||
myPointType == VERTEX_ON_BOTH_BOUNDARIES )
return CUBIT_TRUE;
else
return CUBIT_FALSE;
| void ImprintPointData::marked | ( | int | marked | ) | [inline, virtual] |
Definition at line 94 of file ImprintPointData.hpp.
{ markedFlag = marked;}
| int ImprintPointData::marked | ( | ) | [inline, virtual] |
Definition at line 95 of file ImprintPointData.hpp.
{return markedFlag;}
| int ImprintPointData::num_adj_facets | ( | ) | [virtual] |
Definition at line 199 of file ImprintPointData.cpp.
if (attachedFacets == NULL)
return 0;
else
return attachedFacets->size();
| void ImprintPointData::owner | ( | RefEntity * | my_owner | ) | [inline] |
Definition at line 113 of file ImprintPointData.hpp.
myOwner = my_owner;
| RefEntity* ImprintPointData::owner | ( | ) | [inline] |
Definition at line 117 of file ImprintPointData.hpp.
{return myOwner;}
| void ImprintPointData::points | ( | DLIList< CubitPoint * > & | point_list | ) | [inline, virtual] |
Definition at line 107 of file ImprintPointData.hpp.
{ point_list.append( this ); }
| void ImprintPointData::remove_facet | ( | CubitFacet * | facet | ) | [virtual] |
Definition at line 140 of file ImprintPointData.cpp.
return;
attachedFacets->remove(facet);
return;
| void ImprintPointData::set | ( | const CubitVector & | pos | ) | [inline, virtual] |
| void ImprintPointData::set_end_partition | ( | ) | [inline] |
Definition at line 137 of file ImprintPointData.hpp.
{endPartition = CUBIT_TRUE;}
| void ImprintPointData::set_loop_pos | ( | int | ii, |
| int | jj, | ||
| int | loop_size | ||
| ) | [inline] |
Definition at line 143 of file ImprintPointData.hpp.
listLoopPos = ii;
loopPos = jj;
loopSize = loop_size;
| void ImprintPointData::set_matched | ( | ImprintMatchData * | match_data | ) |
Definition at line 228 of file ImprintPointData.cpp.
else
pointMatches->clean_out();
isMatched = CUBIT_TRUE;
Definition at line 46 of file ImprintPointData.cpp.
// assert(matchingPoint == NULL|| other == matchingPoint);
matchingPoint = other;
return CUBIT_SUCCESS;
| void ImprintPointData::set_next_seg | ( | ImprintLineSegment * | next_seg | ) | [inline] |
Definition at line 169 of file ImprintPointData.hpp.
{nextSeg = next_seg;}
| void ImprintPointData::set_point_type | ( | PointType | type | ) | [inline] |
Definition at line 128 of file ImprintPointData.hpp.
{myPointType = type;}
| void ImprintPointData::set_prev_seg | ( | ImprintLineSegment * | prev_seg | ) | [inline] |
Definition at line 164 of file ImprintPointData.hpp.
{prevSeg = prev_seg;}
| void ImprintPointData::set_start_partition | ( | ) | [inline] |
Definition at line 135 of file ImprintPointData.hpp.
{startPartition = CUBIT_TRUE;}
| void ImprintPointData::set_unmatched | ( | ) |
Definition at line 220 of file ImprintPointData.cpp.
if ( pointMatches != NULL)
Definition at line 84 of file ImprintPointData.hpp.
{ return entityId;}
| double ImprintPointData::x | ( | void | ) | [inline, virtual] |
| double ImprintPointData::y | ( | void | ) | [inline, virtual] |
| double ImprintPointData::z | ( | void | ) | [inline, virtual] |
DLIList<CubitFacet*>* ImprintPointData::attachedFacets [private] |
Definition at line 53 of file ImprintPointData.hpp.
CubitVector ImprintPointData::coords [private] |
Definition at line 52 of file ImprintPointData.hpp.
CubitBoolean ImprintPointData::endPartition [private] |
Definition at line 59 of file ImprintPointData.hpp.
int ImprintPointData::entityId [private] |
Definition at line 69 of file ImprintPointData.hpp.
CubitBoolean ImprintPointData::isMatched [private] |
Definition at line 61 of file ImprintPointData.hpp.
int ImprintPointData::listLoopPos [private] |
Definition at line 65 of file ImprintPointData.hpp.
int ImprintPointData::loopPos [private] |
Definition at line 66 of file ImprintPointData.hpp.
int ImprintPointData::loopSize [private] |
Definition at line 67 of file ImprintPointData.hpp.
ImprintPointData* ImprintPointData::matchingPoint [private] |
Definition at line 57 of file ImprintPointData.hpp.
MemoryManager ImprintPointData::memoryManager [static, private] |
Definition at line 73 of file ImprintPointData.hpp.
RefEntity* ImprintPointData::myOwner [private] |
Definition at line 54 of file ImprintPointData.hpp.
PointType ImprintPointData::myPointType [private] |
Definition at line 55 of file ImprintPointData.hpp.
ImprintLineSegment* ImprintPointData::nextSeg [private] |
Definition at line 63 of file ImprintPointData.hpp.
CubitBoolean ImprintPointData::ownerRefVertex [private] |
Definition at line 56 of file ImprintPointData.hpp.
DLIList<ImprintMatchData*>* ImprintPointData::pointMatches [private] |
Definition at line 60 of file ImprintPointData.hpp.
ImprintLineSegment* ImprintPointData::prevSeg [private] |
Definition at line 62 of file ImprintPointData.hpp.
CubitBoolean ImprintPointData::startPartition [private] |
Definition at line 58 of file ImprintPointData.hpp.
