cgma
00001 #include "ImprintPointData.hpp" 00002 #include "CubitFacet.hpp" 00003 #include "CubitFacetEdge.hpp" 00004 #include "ToolData.hpp" 00005 #include "CubitFacetData.hpp" 00006 #include "CastTo.hpp" 00007 #include "RefEntity.hpp" 00008 #include "CubitMessage.hpp" 00009 00010 static int point_counter = 0; 00011 00012 //=========================================================================== 00013 // Function Name: ImprintPointData 00014 // 00015 // Member Type: PUBLIC 00016 // Description: constructor 00017 // Author: 00018 // Date: 00019 //=========================================================================== 00020 ImprintPointData::ImprintPointData( double x_val, double y_val, double z_val ) 00021 : coords( x_val, y_val, z_val ) 00022 { 00023 initialize_imprint_data(); 00024 } 00025 void ImprintPointData::initialize_imprint_data() 00026 { 00027 attachedFacets = NULL; 00028 point_counter++; 00029 entityId = point_counter; 00030 myOwner = NULL; 00031 myPointType = UNSET_POINT; 00032 ownerRefVertex = CUBIT_FALSE; 00033 matchingPoint = NULL; 00034 startPartition = CUBIT_FALSE; 00035 endPartition = CUBIT_FALSE; 00036 listLoopPos = 0; 00037 loopPos = 0; 00038 pointMatches = NULL; 00039 isMatched = CUBIT_FALSE; 00040 prevSeg = NULL; 00041 nextSeg = NULL; 00042 } 00043 00044 00045 00046 CubitStatus ImprintPointData::set_matching_point(ImprintPointData *other) 00047 { 00048 // assert(matchingPoint == NULL|| other == matchingPoint); 00049 matchingPoint = other; 00050 return CUBIT_SUCCESS; 00051 } 00052 //=========================================================================== 00053 // Function Name: ImprintPointData 00054 // 00055 // Member Type: PUBLIC 00056 // Description: constructor 00057 // Author: 00058 // Date: 00059 //=========================================================================== 00060 ImprintPointData::ImprintPointData( const CubitVector &new_point ) 00061 : coords( new_point ) 00062 { 00063 initialize_imprint_data(); 00064 } 00065 00066 //=========================================================================== 00067 // Function Name: ImprintPointData 00068 // 00069 // Member Type: PUBLIC 00070 // Description: copy constructor 00071 // Author: 00072 // Date: 00073 //=========================================================================== 00074 ImprintPointData::ImprintPointData( ImprintPointData *copy, CubitVector &new_coords ) 00075 { 00076 coords = new_coords; 00077 initialize_imprint_data(); 00078 myPointType=copy->myPointType; 00079 owner(copy->myOwner); 00080 set_matching_point(copy); 00081 copy->set_matching_point(this); 00082 } 00083 00084 00085 //=========================================================================== 00086 // Function Name: ~CubitPoint 00087 // 00088 // Member Type: PUBLIC 00089 // Description: destructor 00090 // Author: 00091 // Date: 00092 //=========================================================================== 00093 ImprintPointData::~ImprintPointData() 00094 { 00095 if ( attachedFacets ) 00096 delete attachedFacets; 00097 if ( pointMatches ) 00098 delete pointMatches; 00099 } 00100 00101 //=========================================================================== 00102 // Function Name: coordinates 00103 // 00104 // Member Type: PUBLIC 00105 // Description: return coordinates of point in form of array 00106 // Author: 00107 // Date: 00108 //=========================================================================== 00109 void ImprintPointData::coordinates(double point_array[3]) 00110 { 00111 point_array[0] = coords.x(); 00112 point_array[1] = coords.y(); 00113 point_array[2] = coords.z(); 00114 } 00115 00116 //=========================================================================== 00117 // Function Name: add_facet 00118 // 00119 // Member Type: PUBLIC 00120 // Description: add a facet to the point's adjacency list 00121 // Author: 00122 // Date: 00123 //=========================================================================== 00124 void ImprintPointData::add_facet( CubitFacet *facet ) 00125 { 00126 if ( attachedFacets == NULL ) 00127 attachedFacets = new DLIList<CubitFacet*>(8); 00128 attachedFacets->append(facet); 00129 return; 00130 } 00131 00132 //=========================================================================== 00133 // Function Name: remove_facet 00134 // 00135 // Member Type: PUBLIC 00136 // Description: remove a facet to the point's adjacency list 00137 // Author: 00138 // Date: 00139 //=========================================================================== 00140 void ImprintPointData::remove_facet( CubitFacet *facet ) 00141 { 00142 if ( attachedFacets == NULL ) 00143 return; 00144 attachedFacets->remove(facet); 00145 return; 00146 } 00147 00148 //=========================================================================== 00149 // Function Name: edges 00150 // 00151 // Member Type: PUBLIC 00152 // Description: return the list of facet-edges attached to this point 00153 // Author: sjowen 00154 // Date: 4/28/01 00155 //=========================================================================== 00156 void ImprintPointData::edges( DLIList<CubitFacetEdge *> &edge_list) 00157 { 00158 int ii, jj, kk; 00159 CubitFacet *facet_ptr; 00160 CubitFacetEdge *edge_ptr, *check_edge_ptr; 00161 for (ii=0; ii<attachedFacets->size(); ii++) 00162 { 00163 facet_ptr = attachedFacets->get_and_step(); 00164 for (jj=0; jj<3; jj++) 00165 { 00166 edge_ptr = facet_ptr->edge( jj ); 00167 if (edge_ptr) 00168 { 00169 if (edge_ptr->point(0) == this || 00170 edge_ptr->point(1) == this) 00171 { 00172 int found = 0; 00173 for (kk=0; kk<edge_list.size() && !found; kk++) 00174 { 00175 check_edge_ptr = edge_list.get_and_step(); 00176 if (check_edge_ptr == edge_ptr) 00177 found = 1; 00178 } 00179 if (!found) 00180 { 00181 edge_list.append( edge_ptr ); 00182 } 00183 } 00184 } 00185 } 00186 } 00187 00188 return; 00189 } 00190 00191 //=========================================================================== 00192 // Function Name: num_adj_facets 00193 // 00194 // Member Type: PUBLIC 00195 // Description: return the number of facets attached to the point 00196 // Author: 00197 // Date: 00198 //=========================================================================== 00199 int ImprintPointData::num_adj_facets() 00200 { 00201 if (attachedFacets == NULL) 00202 return 0; 00203 else 00204 return attachedFacets->size(); 00205 } 00206 00207 void ImprintPointData::add_match_data(ImprintMatchData *match_data) 00208 { 00209 if ( !pointMatches ) 00210 pointMatches = new DLIList<ImprintMatchData*>; 00211 pointMatches->append(match_data); 00212 } 00213 void ImprintPointData::get_match_list(DLIList <ImprintMatchData*> &match_data_list) 00214 { 00215 if ( pointMatches != NULL ) 00216 { 00217 match_data_list += *pointMatches; 00218 } 00219 } 00220 void ImprintPointData::set_unmatched() 00221 { 00222 if ( pointMatches != NULL) 00223 { 00224 pointMatches->clean_out(); 00225 } 00226 isMatched = CUBIT_FALSE; 00227 } 00228 void ImprintPointData::set_matched(ImprintMatchData *match_data) 00229 { 00230 if ( !pointMatches ) 00231 pointMatches = new DLIList<ImprintMatchData*>; 00232 else 00233 { 00234 pointMatches->clean_out(); 00235 } 00236 pointMatches->append(match_data); 00237 isMatched = CUBIT_TRUE; 00238 }
