cgma
#include <Standard_Version.hxx>#include <Standard_Stream.hxx>#include "TDataStd_Shape.hxx"#include "BRep_Tool.hxx"#include "gp_Pnt.hxx"#include "gp_Ax1.hxx"#include "gp_Ax2.hxx"#include "Geom_Surface.hxx"#include "Geom_Curve.hxx"#include "Interface_Static.hxx"#include "BRepBuilderAPI.hxx"#include "BRepBuilderAPI_Transform.hxx"#include "BRepBuilderAPI_GTransform.hxx"#include "BRepBuilderAPI_ModifyShape.hxx"#include "BRepBuilderAPI_MakeSolid.hxx"#include "OCCShapeAttributeSet.hpp"#include "BRepBuilderAPI_MakeShell.hxx"#include "GProp_GProps.hxx"#include "BRepGProp.hxx"#include "BRepTools_WireExplorer.hxx"#include "TColgp_Array1OfPnt.hxx"#include "Poly_Array1OfTriangle.hxx"#include "Poly_Triangle.hxx"#include "BRepAlgoAPI_BooleanOperation.hxx"#include "Handle_Poly_Triangulation.hxx"#include "GCPnts_TangentialDeflection.hxx"#include "BRepAdaptor_Curve.hxx"#include "TopExp.hxx"#include "IFSelect_ReturnStatus.hxx"#include "BndLib_Add3dCurve.hxx"#include "Poly_Polygon3D.hxx"#include "Handle_Poly_Polygon3D.hxx"#include "BRepMesh_FastDiscret.hxx"#include "OCCQueryEngine.hpp"#include "OCCModifyEngine.hpp"#include "Poly_Triangulation.hxx"#include "TopologyEntity.hpp"#include "TopologyBridge.hpp"#include "RefEntity.hpp"#include "Body.hpp"#include "Shell.hpp"#include "Loop.hpp"#include "Chain.hpp"#include "RefVolume.hpp"#include "RefFace.hpp"#include "RefEdge.hpp"#include "RefVertex.hpp"#include "GeometryEntity.hpp"#include "DLIList.hpp"#include "CubitBox.hpp"#include "CubitString.hpp"#include "OCCPoint.hpp"#include "OCCCurve.hpp"#include "OCCCoEdge.hpp"#include "OCCLoop.hpp"#include "OCCSurface.hpp"#include "OCCShell.hpp"#include "OCCLump.hpp"#include "OCCBody.hpp"#include "OCCAttribSet.hpp"#include "GMem.hpp"#include "GeometryQueryTool.hpp"#include "CubitObserver.hpp"#include "GfxDebug.hpp"#include <stdio.h>#include <errno.h>#include <BRep_Builder.hxx>#include <BRepTools.hxx>#include <TopExp_Explorer.hxx>#include <TopoDS.hxx>#include "TopoDS_Compound.hxx"#include <TopoDS_CompSolid.hxx>#include <TopoDS_Solid.hxx>#include <TopoDS_Shell.hxx>#include <TopoDS_Face.hxx>#include <TopoDS_Wire.hxx>#include <TopoDS_Edge.hxx>#include <TopoDS_Vertex.hxx>#include <Bnd_Box.hxx>#include <BndLib_AddSurface.hxx>#include <Precision.hxx>#include <BRepAdaptor_Surface.hxx>#include <TDF_ChildIterator.hxx>#include <BinTools_ShapeSet.hxx>#include "Standard_Boolean.hxx"#include "TDF_Label.hxx"#include "TopTools_DataMapOfShapeInteger.hxx"#include "BRepExtrema_DistShapeShape.hxx"#include "BRepAlgoAPI_Section.hxx"#include "BRepBuilderAPI_MakeEdge.hxx"#include "TDocStd_Document.hxx"#include "TCollection_ExtendedString.hxx"#include "gp_Lin.hxx"#include "CGMEngineDynamicLoader.hpp"Go to the source code of this file.
Defines | |
| #define | NUM_PTS_UV 30 |
Typedefs | |
| typedef TDataStd_Shape | TDataXtd_Shape |
| typedef Handle_TDataStd_Shape | Handle_TDataXtd_Shape |
| typedef std::map< int, TopologyBridge * >::value_type | valType |
| typedef std::map< int, TDF_Label >::value_type | labType |
Functions | |
| CGM_ENGINE_EXPORT_CREATE_GQE (OpenCascade) | |
| #define NUM_PTS_UV 30 |
Definition at line 147 of file OCCQueryEngine.cpp.
| typedef Handle_TDataStd_Shape Handle_TDataXtd_Shape |
Definition at line 24 of file OCCQueryEngine.cpp.
| typedef std::map<int, TDF_Label>::value_type labType |
Definition at line 144 of file OCCQueryEngine.cpp.
| typedef TDataStd_Shape TDataXtd_Shape |
Definition at line 23 of file OCCQueryEngine.cpp.
| typedef std::map<int, TopologyBridge*>::value_type valType |
Definition at line 143 of file OCCQueryEngine.cpp.
| CGM_ENGINE_EXPORT_CREATE_GQE | ( | OpenCascade | ) |
Definition at line 136 of file OCCQueryEngine.cpp.
return OCCQueryEngine::instance();
