cgma
00001 //- Class: CubitBox 00002 //- 00003 //- Description: This file defines the CubitBox class which represents 00004 //- an axis-aligned rectangular box which can be uses as a bounding box. 00005 //- 00006 //- Owner: Greg Sjaardema 00007 //- Checked by: 00008 //- Version: $Id: 00009 00010 #ifndef CUBITBOX_HPP 00011 #define CUBITBOX_HPP 00012 00013 #include "CubitVector.hpp" 00014 #include "CubitBoxStruct.h" 00015 #include "CGMUtilConfigure.h" 00016 #include <vector> 00017 00018 class CUBIT_UTIL_EXPORT CubitBox 00019 { 00020 public: 00021 //- Heading: Constructors and Destructor 00022 CubitBox(); 00023 //- Default constructor. 00024 00025 CubitBox(const CubitVector &min, const CubitVector &max); 00026 //- Constructor: create box from two CubitVectors 00027 00028 CubitBox(const double min[3], const double max[3] ); 00029 //- Constructor: create box from two coordinates 00030 00031 CubitBox(const CubitVector &min_max); 00032 //- Constructor: create box from one CubitVector 00033 00034 CubitBox(const CubitBox& copy_from); //- Copy Constructor 00035 00036 CubitBox(const CubitBoxStruct& from); 00037 00038 CubitBox(const std::vector<CubitVector> & pts); 00039 00040 ~CubitBox(); 00041 //- destructor 00042 00043 CubitBox& bounding_box(); 00044 00045 00046 void reset(const CubitVector &vector); 00047 void reset(const CubitVector &min, const CubitVector &max); 00048 void reset(const CubitBox &box); 00049 void reset(const double min[3], const double max[3]); 00050 //- reset ranges 00051 00052 double max_x() const; 00053 double max_y() const; 00054 double max_z() const; 00055 00056 double min_x() const; 00057 double min_y() const; 00058 double min_z() const; 00059 00060 CubitVector minimum() const; 00061 CubitVector maximum() const; 00062 CubitVector center() const; 00063 CubitVector diagonal() const; 00064 //- Return Box minimum/maximum/center 00065 00066 void get_corners ( CubitVector corners[8] ) const; 00067 //- Fills 'corners' with the corners of this box. 00068 //- The order is: 00069 //- 0) minimum() 00070 //- 1-3) Front face (Constant minimum z-plane), normal out of box 00071 //- using right hand rule, including corner[0]. 00072 //- 4-7) Same as 0-3, but offset to back face 00073 //- (constant maximum z-plane). Normal of these last 4 points 00074 //- is into box relative to back plane (same direction as 00075 //- normal w/ first 4 points). Maximum ends up at index 6. 00076 00077 double x_range() const; 00078 double y_range() const; 00079 double z_range() const; 00080 //- x, y, and z range of the box (max - min) 00081 00082 double minimum_range( void); 00083 double maximum_range( void); 00084 //- returns the maimum and maximum range 00085 00086 bool overlap( double tolerance, const CubitBox& other_box ) const; 00087 //- Check if boxes are within passed tolerance of each other. 00088 //- If tolerance is 0, use && or || operator. 00089 00090 bool intersect(const CubitVector& ray_origin, const CubitVector& ray_direction, 00091 CubitVector& intersection_pt); 00092 //- Check if ray intersects box and returns an intersection point 00093 00094 00095 bool intersect(const CubitVector& ray_origin, const CubitVector& ray_direction); 00096 //- Check if ray intersects box but doesn't calculate an intersection point. 00097 00098 00099 00100 00101 //- Heading: Operators 00102 00103 // Operators that modify {this} 00104 CubitBox& operator=(const CubitBox &box); 00105 CubitBox& operator|=(const CubitBox& box); 00106 CubitBox& operator|=(const CubitVector& vector); 00107 CubitBox& operator&=(const CubitBox& box); 00108 CubitBox& operator*=(double scale); 00109 CubitBox& operator/=(double scale); 00110 CubitBox& operator+=(const CubitVector& offset); 00111 CubitBox& operator-=(const CubitVector& offset); 00112 //- {=} - Assignment 00113 //- {|=} - Union of {this} and {box} 00114 //- {&=} - Intersection (overlap) of {this} and {box} 00115 //- {*=} - Scale {this} about box center 00116 //- {/=} - Scale {this} about box center 00117 //- {+=} - Move {this} by {offset} CubitVector 00118 //- {-=} - Move {this} by {-offset} CubitVector 00119 00120 // Operators that check for containment 00121 int operator< (const CubitBox& box) const; 00122 int operator<=(const CubitBox& box) const; 00123 int operator> (const CubitBox& box) const; 00124 int operator>=(const CubitBox& box) const; 00125 int operator> (const CubitVector& vect) const; 00126 int operator>=(const CubitVector& vect) const; 00127 int operator<=(const CubitVector& vect) const; 00128 int operator&&(const CubitBox& box) const; 00129 int operator||(const CubitBox& box) const; 00130 //- {<} - Is {this} completely surrounded by {box}? 00131 //- {>} - Does {this} completely surround {box}? 00132 //- {<=,>=} - As above, but inner box may touch 00133 //- boundary of outer box. 00134 //- {>} - Is {vect} contained within {this}, but not on boundary? 00135 //- {>=} - Is {vect} contained within or on the boundary of {this}? 00136 //- {<=} - Is {vect} outside or on boundary of {this}? 00137 //- {&&} - Do {this} and {box} intersect? Just butting against each 00138 //- other also counts as an intersection. See {||}. 00139 //- {||} - Do {this} and {box} intersect? Just butting against each 00140 //- other does NOT count as an intersection. See {&&}. 00141 00142 CubitBox &operator=(const CubitBoxStruct &from); 00143 00144 operator CubitBoxStruct() 00145 { 00146 CubitBoxStruct to; 00147 to.minimum_ = minimum_; 00148 to.maximum_ = maximum_; 00149 return to; 00150 } 00151 00152 // Operators that return a modification of {this}. 00153 // {this} itself is not modified. 00154 friend CUBIT_UTIL_EXPORT CubitBox operator|(const CubitBox& lhs, const CubitBox& rhs); 00155 friend CUBIT_UTIL_EXPORT CubitBox operator|(const CubitBox& lhs, const CubitVector& rhs); 00156 friend CUBIT_UTIL_EXPORT CubitBox operator&(const CubitBox& lhs, const CubitBox& rhs); 00157 friend CUBIT_UTIL_EXPORT CubitBox operator*(const CubitBox& lhs, double rhs); 00158 friend CUBIT_UTIL_EXPORT CubitBox operator*(double rhs, const CubitBox& lhs); 00159 friend CUBIT_UTIL_EXPORT CubitBox operator/(const CubitBox& lhs, double rhs); 00160 friend CUBIT_UTIL_EXPORT CubitBox operator+(const CubitBox& lhs, const CubitVector& rhs); 00161 friend CUBIT_UTIL_EXPORT CubitBox operator-(const CubitBox& lhs, const CubitVector& rhs); 00162 00163 double distance_squared( const CubitVector& position ) const; 00164 00165 CubitVector closest_point( const CubitVector& position ) const; 00166 //R CubitVector 00167 //R- The closest point on the box to the passed position. 00168 //R- The passed position will be returned if it is within 00169 //R- the box. 00170 //I- A position from which to evaluate the closest point 00171 //I- on the box. 00172 00173 private: 00174 00175 CubitVector minimum_; //- X, Y, and Z position of minimum corner 00176 CubitVector maximum_; //- X, Y, and Z position of maximum corner 00177 }; 00178 00179 inline CubitBox& CubitBox::operator=(const CubitBoxStruct &from) 00180 { 00181 minimum_ = from.minimum_; 00182 maximum_ = from.maximum_; 00183 return *this; 00184 } 00185 00186 inline CubitBox::CubitBox(const CubitBoxStruct &from) 00187 { 00188 minimum_ = from.minimum_; 00189 maximum_ = from.maximum_; 00190 } 00191 #endif
