cgma
#include "CubitCompat.h"#include "CubitCompat.hpp"#include "GeometryQueryTool.hpp"#include <string.h>Go to the source code of this file.
Defines | |
| #define | CUBIT_COMPAT_FT_ELIF(TYPE) |
Functions | |
| static Model_File_Type | CubitCompat_file_type (const char *file_type) |
| CubitStatus | CubitCompat_import_solid_model (const char *file_name, const char *file_type, const char *logfile_name, CubitBoolean heal_step, CubitBoolean import_bodies, CubitBoolean import_surfaces, CubitBoolean import_curves, CubitBoolean import_vertices, CubitBoolean free_surfaces, DLIList< RefEntity * > *imported_entities) |
| CubitStatus | CubitCompat_export_solid_model (DLIList< RefEntity * > &ref_entity_list, const char *filename, const char *filetype, int &num_ents_exported, const CubitString &cubit_version, const char *logfile_name) |
| #define CUBIT_COMPAT_FT_ELIF | ( | TYPE | ) |
else if (!strcmp(file_type,#TYPE)) \ return TYPE ## _TYPE
Definition at line 6 of file CubitCompat.cpp.
| CubitStatus CubitCompat_export_solid_model | ( | DLIList< RefEntity * > & | ref_entity_list, |
| const char * | filename, | ||
| const char * | filetype, | ||
| int & | num_ents_exported, | ||
| const CubitString & | cubit_version, | ||
| const char * | logfile_name | ||
Definition at line 70 of file CubitCompat.cpp.
// const bool print_results = false;
// const bool merge_globally = false;
// const bool no_assembly_level_features = false;
ModelExportOptions CubitCompat_opts = {1, logfile_name ? logfile_name : "" };
return GeometryQueryTool::instance()->export_solid_model(
ref_entity_list,
filename,
CubitCompat_file_type(filetype),
num_ents_exported,
cubit_version,
CubitCompat_opts );
| static Model_File_Type CubitCompat_file_type | ( | const char * | file_type | ) | [static] |
Definition at line 11 of file CubitCompat.cpp.
if (!file_type)
return MFT_NOT_DEFINED;
CUBIT_COMPAT_FT_ELIF(IGES);
CUBIT_COMPAT_FT_ELIF(CATIA);
CUBIT_COMPAT_FT_ELIF(STEP);
CUBIT_COMPAT_FT_ELIF(PROE);
CUBIT_COMPAT_FT_ELIF(GRANITE);
CUBIT_COMPAT_FT_ELIF(GRANITE_G);
CUBIT_COMPAT_FT_ELIF(GRANITE_SAT);
CUBIT_COMPAT_FT_ELIF(GRANITE_PROE_PART);
CUBIT_COMPAT_FT_ELIF(GRANITE_PROE_ASM);
CUBIT_COMPAT_FT_ELIF(GRANITE_NEUTRAL);
CUBIT_COMPAT_FT_ELIF(NCGM);
CUBIT_COMPAT_FT_ELIF(CATIA_NCGM);
CUBIT_COMPAT_FT_ELIF(CATPART);
CUBIT_COMPAT_FT_ELIF(CATPRODUCT);
CUBIT_COMPAT_FT_ELIF(FACET);
CUBIT_COMPAT_FT_ELIF(SOLIDWORKS);
CUBIT_COMPAT_FT_ELIF(OCC);
else
| CubitStatus CubitCompat_import_solid_model | ( | const char * | file_name, |
| const char * | file_type, | ||
| const char * | logfile_name, | ||
| CubitBoolean | heal_step, | ||
| CubitBoolean | import_bodies, | ||
| CubitBoolean | import_surfaces, | ||
| CubitBoolean | import_curves, | ||
| CubitBoolean | import_vertices, | ||
| CubitBoolean | free_surfaces, | ||
| DLIList< RefEntity * > * | imported_entities | ||
Definition at line 37 of file CubitCompat.cpp.
ModelImportOptions CubitCompat_opts = { heal_step,
print_results,
import_bodies,
import_surfaces,
import_curves,
import_vertices,
free_surfaces,
merge_globally,
no_assembly_level_features,
return GeometryQueryTool::instance()->import_solid_model(
file_name,
CubitCompat_file_type(file_type),
CubitCompat_opts,
imported_entities );
