cgma
#include "CubitObserver.hpp"#include "CubitDefines.h"#include "GeometryDefines.h"#include "CubitMessage.hpp"#include "CGMGeomConfigure.h"#include "CubitCompat.h"Go to the source code of this file.
Classes | |
| class | GeometryQueryEngine |
Enumerations | |
| enum | Model_File_Type { MFT_NOT_DEFINED = 0, IGES_TYPE, CATIA_TYPE, STEP_TYPE, PROE_TYPE, GRANITE_TYPE, GRANITE_G_TYPE, GRANITE_SAT_TYPE, GRANITE_PROE_PART_TYPE, GRANITE_PROE_ASM_TYPE, GRANITE_NEUTRAL_TYPE, NCGM_TYPE, CATIA_NCGM_TYPE, CATPART_TYPE, CATPRODUCT_TYPE, FACET_TYPE, SOLIDWORKS_TYPE, OCC_TYPE, KCM_TYPE } |
Functions | |
| const char * | get_MFT_string (Model_File_Type) |
Variables | |
| static const char *const | GRANITE_G = ".g" |
| static const char *const | GRANITE_PROE_PART = ".prt" |
| static const char *const | GRANITE_PROE_ASM = ".asm" |
| static const char *const | GRANITE_PROE_NEUTRAL = ".neu" |
| static const char *const | STEP_IMPORT_DEFAULT_LOG = "step_import.log" |
| static const char *const | IGES_IMPORT_DEFAULT_LOG = "iges_import.log" |
| static const char *const | CATIA_IMPORT_DEFAULT_LOG = "catia_import.log" |
| static const char *const | GRANITE_EXPORT_DEFAULT_LOG = "granite_export.log" |
| static const char *const | STEP_EXPORT_DEFAULT_LOG = "step_export.log" |
| static const char *const | IGES_EXPORT_DEFAULT_LOG = "iges_export.log" |
| static const char *const | OCC_EXPORT_DEFAULT_LOG = "occ_export.log" |
| static const char *const | KCM_EXPORT_DEFAULT_LOG = "kcm_export.log" |
| static const char *const | STEP_IGES_TRANSLATOR = "step_iges_translator" |
| static const char *const | TRANSLATOR_DIR = "/translator/" |
| enum Model_File_Type |
Definition at line 43 of file GeometryQueryEngine.hpp.
| const char * get_MFT_string | ( | Model_File_Type | type | ) | [inline] |
Definition at line 70 of file GeometryQueryEngine.hpp.
switch (type)
case MFT_NOT_DEFINED :
return "Model File Type NOT DEFINED";
case IGES_TYPE :
return "IGES";
case CATIA_TYPE :
return "CATIA";
case STEP_TYPE :
return "STEP";
case PROE_TYPE :
return "PROE";
case GRANITE_TYPE :
return "GRANITE";
case GRANITE_G_TYPE :
return "GRANITE_G";
case GRANITE_SAT_TYPE :
return "GRANITE_SAT";
case GRANITE_PROE_PART_TYPE :
return "GRANITE_PROE_PART";
case GRANITE_PROE_ASM_TYPE :
return "GRANITE_PROE_ASM";
case GRANITE_NEUTRAL_TYPE :
return "GRANITE_NEUTRAL";
case NCGM_TYPE :
return "NCGM";
case CATIA_NCGM_TYPE :
return "CATIA_NCGM";
case CATPART_TYPE :
return "CATPART";
case CATPRODUCT_TYPE :
return "CATPRODUCT";
case FACET_TYPE :
return "FACET";
case SOLIDWORKS_TYPE :
return "SOLIDWORKS";
case OCC_TYPE:
return "OCC";
case KCM_TYPE:
return "KCM";
default :
PRINT_ERROR("Model_File_Type index %i is not handled properly in get_MFT_string()\n", type);
return "";
} // get_MFT_string()
const char* const CATIA_IMPORT_DEFAULT_LOG = "catia_import.log" [static] |
Definition at line 126 of file GeometryQueryEngine.hpp.
const char* const GRANITE_EXPORT_DEFAULT_LOG = "granite_export.log" [static] |
Definition at line 127 of file GeometryQueryEngine.hpp.
const char* const GRANITE_G = ".g" [static] |
Definition at line 120 of file GeometryQueryEngine.hpp.
const char* const GRANITE_PROE_ASM = ".asm" [static] |
Definition at line 122 of file GeometryQueryEngine.hpp.
const char* const GRANITE_PROE_NEUTRAL = ".neu" [static] |
Definition at line 123 of file GeometryQueryEngine.hpp.
const char* const GRANITE_PROE_PART = ".prt" [static] |
Definition at line 121 of file GeometryQueryEngine.hpp.
const char* const IGES_EXPORT_DEFAULT_LOG = "iges_export.log" [static] |
Definition at line 129 of file GeometryQueryEngine.hpp.
const char* const IGES_IMPORT_DEFAULT_LOG = "iges_import.log" [static] |
Definition at line 125 of file GeometryQueryEngine.hpp.
const char* const KCM_EXPORT_DEFAULT_LOG = "kcm_export.log" [static] |
Definition at line 131 of file GeometryQueryEngine.hpp.
const char* const OCC_EXPORT_DEFAULT_LOG = "occ_export.log" [static] |
Definition at line 130 of file GeometryQueryEngine.hpp.
const char* const STEP_EXPORT_DEFAULT_LOG = "step_export.log" [static] |
Definition at line 128 of file GeometryQueryEngine.hpp.
const char* const STEP_IGES_TRANSLATOR = "step_iges_translator" [static] |
Definition at line 132 of file GeometryQueryEngine.hpp.
const char* const STEP_IMPORT_DEFAULT_LOG = "step_import.log" [static] |
Definition at line 124 of file GeometryQueryEngine.hpp.
const char* const TRANSLATOR_DIR = "/translator/" [static] |
Definition at line 133 of file GeometryQueryEngine.hpp.
