cgma
00001 00016 #ifndef GEOMETRYQUERYTOOL_HPP 00017 #define GEOMETRYQUERYTOOL_HPP 00018 00019 #include <stdio.h> 00020 #include <typeinfo> 00021 #include <list> 00022 #include <set> 00023 00024 #include "GeometryDefines.h" 00025 #include "DLIList.hpp" 00026 #include "GeometryQueryEngine.hpp" 00027 #include "IntermediateGeomEngine.hpp" 00028 #include "CGMHistory.hpp" 00029 00030 class RefGroup; 00031 class Body; 00032 class BodySM; 00033 class Lump; 00034 class Shell; 00035 class ShellSM; 00036 class Loop; 00037 class LoopSM; 00038 class Chain; 00039 class Surface; 00040 class Curve; 00041 class TopologyBridge; 00042 class CoEdgeSM; 00043 00044 class GeometryEntity; 00045 00046 class RefGroup; 00047 00048 class TopologyEntity; 00049 class TopologyBridge; 00050 00051 class RefEntity ; 00052 class RefVolume ; 00053 class RefFace ; 00054 class RefEdge ; 00055 class CoEdge; 00056 class RefVertex ; 00057 00058 class SenseEntity; 00059 class BasicTopologyEntity; 00060 class RefVolume ; 00061 class RefFace ; 00062 class RefEdge ; 00063 class RefVertex ; 00064 class TBPoint; 00065 class CubitEntity; 00066 class CoEdgeSM; 00067 00068 class GeometryQueryEngine; 00069 00070 class CubitPlane ; 00071 class CubitBox; 00072 class CubitVector; 00073 class CubitTransformMatrix; 00074 class TBOwner; 00075 00076 #ifdef PROE 00077 class RefPart; 00078 class RefAssembly; 00079 #endif 00080 00082 class CUBIT_GEOM_EXPORT GeometryQueryTool 00083 { 00084 public : 00085 00086 friend class GeometryModifyTool; 00087 00088 bool ige_is_composite(TBOwner *bridge_owner); 00089 bool ige_is_composite(TopologyBridge *bridge); 00090 bool ige_is_partition(TBOwner *bridge_owner); 00091 00092 00093 void ige_remove_modified(DLIList<Surface*> &all_surfs, 00094 DLIList<Curve*> &all_curves, 00095 DLIList<TBPoint*> &all_points); 00096 00097 static GeometryQueryTool* instance( GeometryQueryEngine* gqePtr = NULL); 00113 ~GeometryQueryTool(); 00115 00116 static void delete_instance(); 00117 00121 double estimate_merge_tolerance(DLIList<RefVolume*> &vol_list, 00122 bool accurate_in = false, 00123 bool report_in = false, 00124 double lo_val_in = -1.0, 00125 double hi_val_in = -1.0, 00126 int num_calculations_in = 10, 00127 bool return_calculations_in = false, 00128 DLIList<double> *merge_tols = NULL, 00129 DLIList<int> *num_proximities = NULL); 00130 00134 void find_floating_volumes(DLIList<RefVolume*> &vol_list, 00135 DLIList<RefVolume*> &floating_list); 00136 00140 void find_nonmanifold_curves(DLIList<RefVolume*> &vol_list, DLIList<RefEdge*> &curve_list); 00141 00145 void find_nonmanifold_vertices(DLIList<RefVolume*> &vol_list, DLIList<RefVertex*> &vertex_list); 00146 00147 CubitStatus register_intermediate_engine( IntermediateGeomEngine* engine ); 00148 void unregister_intermediate_engine( IntermediateGeomEngine* engine ); 00149 00150 void ige_remove_imprint_attributes_after_modify(DLIList<BodySM*> &old_sms, 00151 DLIList<BodySM*> &new_sms); 00152 void ige_push_imprint_attributes_before_modify 00153 ( DLIList<BodySM*> &geom_list ); 00154 void ige_push_named_attributes_to_curves_and_points 00155 ( DLIList<TopologyBridge*> &tb_list, const char *name_in ); 00156 void ige_export_geom( DLIList<TopologyBridge*> &geom_list ); 00157 void ige_import_geom( DLIList<TopologyBridge*> &geom_list ); 00158 void ige_remove_attributes( DLIList<TopologyBridge*> &geom_list ); 00159 void ige_attribute_after_imprinting(DLIList<TopologyBridge*> &tb_list, 00160 DLIList<Body*> &old_bodies); 00161 void ige_remove_attributes_from_unmodifed_virtual(DLIList<TopologyBridge*> &bridges); 00162 00163 //Using the source_bridge, finds all bridges that actually have a BridgeManager the owner. 00164 //This is for obtaining the real TopologyBridge when all you have is a TopologyBridge 00165 //that is Partition Entity. 00166 void get_tbs_with_bridge_manager_as_owner( TopologyBridge *source_bridge, 00167 DLIList<TopologyBridge*> &tbs ); 00168 00171 // 00172 // Returns ref entities in a generic cubit entity list (overwrites list). 00173 // returns CUBIT_FAILURE if keyword is not a ref entity name, and 00174 // optionally prints error message 00175 // 00176 //CubitStatus cubit_entity_list( const char* keyword, 00177 // DLIList<CubitEntity*> &entity_list, 00178 // const CubitBoolean print_errors = CUBIT_TRUE); 00179 00185 00186 CubitStatus ref_entity_list( char const* keyword, 00187 DLIList<RefEntity*> &entity_list, 00188 const CubitBoolean print_errors = CUBIT_TRUE); 00189 00191 CubitBox model_bounding_box(); 00192 00195 00196 CubitBox bounding_box_of_bodies(); 00197 00198 00200 void bodies (DLIList<Body*> &bodies); 00201 00203 void ref_volumes (DLIList<RefVolume*> &ref_volumes); 00204 00206 void ref_groups (DLIList<RefGroup*> &ref_groups); 00207 00209 void ref_faces (DLIList<RefFace*> &ref_faces); 00210 00212 void ref_edges (DLIList<RefEdge*> &ref_edges); 00213 00215 void ref_vertices (DLIList<RefVertex*> &ref_vertices); 00216 00217 void get_ordered_loops(RefFace* face, DLIList<Loop*> &loop_list); 00218 00219 #ifdef PROE 00220 void ref_parts (DLIList<RefPart*> &ref_parts); 00221 void ref_assemblies (DLIList<RefAssembly*> &ref_assemblies); 00222 #endif //PROE 00223 00224 00226 int num_bodies() const; 00227 00229 int num_ref_volumes() const; 00230 00232 int num_ref_groups() const; 00233 00235 int num_ref_faces() const; 00236 00238 int num_ref_edges() const; 00239 00241 int num_ref_vertices() const; 00242 00244 RefEntity *get_ref_entity (const char *type, int id); 00245 00247 RefEntity *get_ref_entity (const std::type_info& type, int id); 00248 00250 Body *get_body ( int id ); 00251 00253 RefVolume *get_ref_volume ( int id ); 00254 00256 RefGroup *get_ref_group ( int id ); 00257 00259 RefFace *get_ref_face ( int id ); 00260 00262 RefEdge *get_ref_edge ( int id ); 00263 00265 RefVertex *get_ref_vertex ( int id ); 00266 00267 00269 Body *get_first_body (); 00271 RefVolume *get_first_ref_volume (); 00273 RefGroup *get_first_ref_group (); 00275 RefFace *get_first_ref_face (); 00277 RefEdge *get_first_ref_edge (); 00279 RefVertex *get_first_ref_vertex (); 00280 00282 Body *get_next_body (); 00284 RefVolume *get_next_ref_volume (); 00286 RefGroup *get_next_ref_group (); 00288 RefFace *get_next_ref_face (); 00290 RefEdge *get_next_ref_edge (); 00292 RefVertex *get_next_ref_vertex (); 00293 00295 Body *get_last_body (); 00297 RefVolume *get_last_ref_volume (); 00299 RefGroup *get_last_ref_group (); 00301 RefFace *get_last_ref_face (); 00303 RefEdge *get_last_ref_edge (); 00305 RefVertex *get_last_ref_vertex (); 00306 00307 00309 CubitStatus get_free_ref_entities(DLIList<RefEntity*> &free_entities); 00310 00315 void get_connected_free_ref_entities( 00316 RefEntity *entity, 00317 const int merge_option, 00318 DLIList<Body*> &body_list, 00319 DLIList<RefFace*> &ref_face_list, 00320 DLIList<RefEdge*> &ref_edge_list, 00321 DLIList<RefVertex*> &ref_vertex_list ); 00322 00323 void validate_geometry_database(); 00324 00327 CubitStatus save_temp_geom_files( DLIList<RefEntity*>& ref_entity_list, 00328 const char* filename, 00329 const CubitString &cubit_version, 00330 std::list<CubitString> &files_written, 00331 std::list<CubitString> &types_written); 00332 00333 00364 CubitStatus export_solid_model( DLIList<RefEntity*>& ref_entity_list, 00365 const char* filename, 00366 Model_File_Type filetype, 00367 int &num_ents_exported, 00368 const CubitString &cubit_version, 00369 ModelExportOptions &export_options ); 00370 00400 CubitStatus export_solid_model(DLIList<RefEntity*>& ref_entity_list, 00401 char*& p_buffer, 00402 int& n_buffer_size, 00403 bool b_export_buffer); 00433 00434 CubitStatus import_solid_model(const char* file_name, 00435 Model_File_Type file_type, 00436 ModelImportOptions &import_options, 00437 DLIList<RefEntity*> *imported_entities = NULL ); 00438 00439 00440 // import entities in a solid model buffer 00441 CubitStatus import_solid_model(DLIList<RefEntity*> *imported_entities, 00442 const char* pBuffer, 00443 const int n_buffer_size); 00444 00468 00469 CubitStatus fire_ray( CubitVector &origin, 00470 CubitVector &direction, 00471 DLIList<RefEntity*> &at_entity_list, 00472 DLIList<double> &ray_params, 00473 int max_hits = 0, 00474 double ray_radius = 0.0, 00475 DLIList<RefEntity*> *hit_entity_list_ptr = 0 ); 00476 00500 00501 CubitStatus fire_ray( CubitVector &origin, 00502 CubitVector &direction, 00503 DLIList<TopologyEntity*> &at_entity_list, 00504 DLIList<double> &ray_params, 00505 int max_hits = 0, 00506 double ray_radius = 0.0, 00507 DLIList<TopologyEntity*> *hit_entity_list_ptr = 0 ); 00508 00510 static void geom_debug( DLIList<TopologyEntity*> ); 00511 00513 static void set_facet_bbox( CubitBoolean pass_flag ) 00514 {useFacetBBox = pass_flag;} 00515 00517 static CubitBoolean get_facet_bbox() 00518 {return useFacetBBox;} 00519 00521 CubitString get_engine_version_string(); 00522 00524 CubitStatus set_export_allint_version(int version); 00525 00527 int get_allint_version(); 00528 00530 CubitStatus list_engine_versions(CubitString &versions); 00531 00533 double get_sme_resabs_tolerance(); 00534 00536 double set_sme_resabs_tolerance( double new_resabs ); 00537 00539 CubitStatus set_sme_int_option( const char* opt_name, int val ); 00541 CubitStatus set_sme_dbl_option( const char* opt_name, double val ); 00543 CubitStatus set_sme_str_option( const char* opt_name, const char* val ); 00544 00545 00547 Body* make_Body(BodySM *bodysm_ptr) const; 00548 RefFace* make_RefFace(Surface* surface_ptr ) const; 00549 RefEdge* make_RefEdge(Curve* curve_ptr) const; 00550 RefVertex* make_RefVertex(TBPoint* point_ptr) const; 00551 00552 static CubitSense relative_sense( Surface* surface1, Surface* surface2 ); 00553 00554 RefFace* make_free_RefFace(Surface *surface_ptr, bool is_free_surface) const; 00555 RefEdge* make_free_RefEdge(Curve *curve_ptr ) const; 00556 RefVertex* make_free_RefVertex(TBPoint *point_ptr) const; 00564 00565 00570 void delete_Body( DLIList<Body*>& body_list ); 00571 00579 00580 CubitStatus delete_Body( Body* body_ptr ); 00581 00588 00589 CubitStatus delete_single_Body( Body* body_ptr ); 00590 00592 CubitStatus delete_RefEntity( RefEntity* ref_entity_ptr ); 00593 00595 CubitStatus delete_RefFace( RefFace* ref_face_ptr ); 00596 00598 CubitStatus delete_RefEdge( RefEdge* ref_edge_ptr ); 00599 00601 CubitStatus delete_RefVertex( RefVertex* ref_vertex_ptr ); 00602 00603 void cleanout_deactivated_geometry(); 00604 void cleanout_temporary_geometry (); 00605 00607 void delete_geometry(); 00608 00609 00614 CubitStatus interpolate_along_surface( CubitVector *vector_1, 00615 CubitVector *vector_2, 00616 DLIList<CubitVector*> &vector_list, 00617 RefFace* ref_face_ptr, 00618 int number_points ) const; 00633 00634 CubitBoolean about_spatially_equal (const CubitVector& Vec1, 00635 const CubitVector& Vec2, 00636 double tolerance_factor = 1.0); 00637 00639 CubitBoolean about_spatially_equal (RefVertex* refVertex1, 00640 RefVertex* refVertex2, 00641 double tolerance_factor = 1.0); 00642 00646 double geometric_angle(RefEdge* ref_edge_1, 00647 RefEdge* ref_edge_2, 00648 RefFace* ref_face ); 00649 00652 double geometric_angle(CoEdge* co_edge_1, 00653 CoEdge* co_edge_2 ); 00654 00657 double surface_angle( RefFace *ref_face_1, RefFace *ref_face_2, 00658 RefEdge *ref_edge = NULL, 00659 RefVolume *ref_volume = NULL, 00660 double frac = 0.5); 00661 00670 00671 CubitStatus get_intersections( RefEdge* ref_edge1, 00672 CubitVector& point1, 00673 CubitVector& point2, 00674 DLIList<CubitVector>& intersection_list, 00675 CubitBoolean bounded = CUBIT_FALSE, 00676 CubitBoolean closest = CUBIT_FALSE); 00677 00688 00689 CubitStatus get_intersections( RefEdge* ref_edge1, RefEdge* ref_edge2, 00690 DLIList<CubitVector>& intersection_list, 00691 CubitBoolean bounded = CUBIT_FALSE, 00692 CubitBoolean closest = CUBIT_FALSE ); 00693 00698 00699 CubitStatus get_intersections( RefEdge* ref_edge, RefFace* ref_face, 00700 DLIList<CubitVector>& intersection_list, 00701 CubitBoolean bounded = CUBIT_FALSE ); 00702 00705 CubitStatus get_intersections( RefEdge* ref_edge, CubitPlane plane, 00706 DLIList<CubitVector>& intersection_list, 00707 CubitBoolean bounded = CUBIT_FALSE, 00708 double extended_percent = 0.0); 00709 00710 00717 00718 CubitStatus entity_extrema( RefEntity *ref_entity_ptr, 00719 const CubitVector *dir1, 00720 const CubitVector *dir2, 00721 const CubitVector *dir3, 00722 CubitVector &extrema, 00723 RefEntity *&extrema_entity_ptr ); 00724 00731 00732 CubitStatus entity_extrema( DLIList<RefEntity*> &ref_entity_list, 00733 const CubitVector *dir1, 00734 const CubitVector *dir2, 00735 const CubitVector *dir3, 00736 CubitVector &extrema, 00737 RefEntity *&extrema_entity_ptr ); 00738 00742 00743 CubitStatus entity_entity_distance( GeometryEntity *ge1, 00744 GeometryEntity *ge2, 00745 CubitVector &pos1, CubitVector &pos2, 00746 double &distance ); 00747 00751 00752 CubitStatus entity_entity_distance( RefEntity *ref_entity_ptr1, 00753 RefEntity *ref_entity_ptr2, 00754 CubitVector &pos1, CubitVector &pos2, 00755 double &distance ); 00756 00757 00759 static void reset_geometry_factor(); 00760 00762 static void set_geometry_factor( double fac ); 00763 00765 static double get_geometry_factor(); 00766 00768 static void set_merge_test_bbox(CubitBoolean tof); 00769 00771 static CubitBoolean get_merge_test_bbox(); 00772 00773 static void set_merge_test_internal(int tof); 00774 static int get_merge_test_internal(); 00775 static void set_sliver_curve_cleanup_tolerance( double tol ); 00776 static void set_sliver_surface_cleanup_tolerance( double tol ); 00777 static double get_sliver_curve_cleanup_tolerance(); 00778 static double get_sliver_surface_cleanup_tolerance(); 00779 00781 static void initialize_settings(); 00782 00784 static CubitStatus import_actuate( DLIList<RefEntity*> &entity_list ); 00785 00788 CubitBoolean same_query_engine(DLIList<TopologyEntity*> &topo_list) const; 00789 00813 00814 GeometryQueryEngine* common_query_engine( 00815 DLIList<TopologyEntity*>& topology_list, 00816 DLIList<TopologyBridge*>& engine_bridges, 00817 CubitBoolean allow_default_engine 00818 = CUBIT_FALSE ) const; 00819 00821 CubitBoolean does_geom_contain_query_engine(DLIList<TopologyEntity*> &topo_list, 00822 GeometryQueryEngine *engine) const; 00823 00825 CubitBoolean does_geom_contain_query_engine(DLIList<RefEntity*> &ref_entity_list, 00826 GeometryQueryEngine *engine, 00827 CubitBoolean children_too = CUBIT_FALSE) const; 00828 00830 TopologyEntity* entity_from_bridge( TopologyBridge* bridge_ptr ) const; 00831 00833 void add_gqe(GeometryQueryEngine *gqe_ptr); 00834 00837 CubitStatus remove_gqe(GeometryQueryEngine *gqe_ptr); 00838 00840 void get_gqe_list(DLIList<GeometryQueryEngine*> &gqe_list); 00841 00843 GeometryQueryEngine *get_gqe(); 00844 00846 CubitStatus set_default_gqe(GeometryQueryEngine* gqe); 00847 00848 bool contains_intermediate_geometry(RefEntity*) const; 00849 bool contains_intermediate_geometry(DLIList<RefEntity*>& ref_entitylist) const; 00850 bool is_intermediate_geometry(RefEntity*) const; 00851 bool is_intermediate_geometry(TopologyBridge*) const; 00852 00855 CubitStatus destroy_dead_entity( TopologyEntity* topo_ent, bool top = true ) const; 00856 00858 CubitStatus translate( DLIList<Body*> &bodies, 00859 const CubitVector& delta, 00860 DLIList<Body*> *bodies_translated = NULL, 00861 bool check_to_transform = true, 00862 bool preview = false ); 00863 00865 CubitStatus translate( DLIList<BasicTopologyEntity*> &btes, 00866 const CubitVector& delta, 00867 DLIList<BasicTopologyEntity*> *btes_translated = NULL, 00868 bool check_to_transform = true, 00869 bool preview = false ); 00870 00871 void translate( DLIList<RefEntity*> &entities_to_transform, 00872 double x, double y, double z, 00873 bool check_before_transforming, 00874 DLIList<RefEntity*> &entities_transformed, 00875 bool preview = false ); 00876 00878 CubitStatus rotate( DLIList<Body*> &bodies, 00879 const CubitVector& axis, 00880 double degrees, 00881 DLIList<Body*> *bodies_rotated = NULL, 00882 bool check_to_transform = true, 00883 bool preview = false ); 00884 00887 CubitStatus rotate( DLIList<Body*> &bodies, 00888 const CubitVector& point, 00889 const CubitVector& normal, 00890 double degrees, 00891 DLIList<Body*> *bodies_rotated = NULL, 00892 bool check_to_transform = true, 00893 bool preview = false); 00894 00895 CubitStatus rotate( DLIList<RefEntity*> &entities_to_transform, 00896 const CubitVector& point, 00897 const CubitVector& normal, 00898 double degrees, 00899 bool check_to_transform, 00900 DLIList<RefEntity*> &entities_transformed, 00901 bool preview = false); 00902 00904 CubitStatus rotate( DLIList<BasicTopologyEntity*> &btes, 00905 const CubitVector& axis, 00906 double degrees, 00907 DLIList<BasicTopologyEntity*> *btes_rotated = NULL, 00908 bool check_to_transform = true, 00909 bool preview = false); 00910 00911 CubitStatus rotate( DLIList<BasicTopologyEntity*> &btes, 00912 const CubitVector& point, 00913 const CubitVector& normal, 00914 double degrees, 00915 DLIList<BasicTopologyEntity*> *btes_rotated = NULL, 00916 bool check_to_transform = true, 00917 bool preview = false); 00918 00920 CubitStatus scale( Body* entity,const CubitVector& point, double factor, bool check_to_transform = true, bool preview = false); 00921 00923 CubitStatus scale( Body* entity,const CubitVector& point, const CubitVector& factors, bool check_to_transform = true, bool preview = false); 00924 00926 CubitStatus scale( BasicTopologyEntity* entity,const CubitVector& point, double factor, bool check_to_transform = true, bool preview = false); 00927 00929 CubitStatus scale( BasicTopologyEntity* entity,const CubitVector& point, const CubitVector& factors,bool check_to_transform = true, 00930 bool preview = false); 00931 00932 void scale( DLIList<RefEntity*> &entities_to_transform, 00933 const CubitVector& point, 00934 double scale_x, double scale_y, double scale_z, 00935 bool check_to_transform, 00936 DLIList<RefEntity*> &entities_scaled, 00937 bool preview = false); 00938 00940 CubitStatus reflect( DLIList<Body*> &bodies, 00941 const CubitVector& point, 00942 const CubitVector& axis, 00943 DLIList<Body*> *bodies_reflected = NULL, 00944 bool preview = false ); 00945 00947 CubitStatus reflect( DLIList<BasicTopologyEntity*> &btes, 00948 const CubitVector& point, 00949 const CubitVector& axis, 00950 DLIList<BasicTopologyEntity*> *btes_reflected = NULL, 00951 bool check_to_transform = true, 00952 bool preview = false); 00953 00954 void reflect( DLIList<RefEntity*> &entities_to_transform, 00955 const CubitVector& point, 00956 const CubitVector& axis, 00957 bool check_before_transforming, 00958 DLIList<RefEntity*> &entities_transformed, 00959 bool preview = false); 00960 00962 CubitStatus restore_transform( Body* body ); 00963 00973 00974 CubitBoolean volumes_overlap( RefVolume *volume_1, RefVolume *volume_2); 00975 00984 00985 CubitBoolean bodies_overlap( Body *body_ptr_1, Body *body_ptr_2 ); 00986 00989 CubitStatus construct_refentities(DLIList<TopologyBridge*> &topology_bridges, 00990 DLIList<RefEntity*> *imported_entities = NULL); 00991 01001 static CubitBoolean trackMergedAwayEnts; 01002 static CubitBoolean importingSolidModel; 01003 01004 //Before calling import_solid_model, normally we want to clear out the 01005 //map in CAUniqueId, but not when we are importing a cub file. 01006 static CubitBoolean clearUidMapBeforeImport; 01007 01008 //variable defining scope of merge...if true, 01009 //merge entities you are importing with any entity (i.e. 01010 //entities already in the cubit session), otherwise 01011 //only merge entities that are importing with other entities 01012 //that are importing 01013 static CubitBoolean mergeGloballyOnImport; 01014 01015 static DLIList<int> uidsOfImportingEnts; 01016 static int entitiesMergedAway; 01017 01018 CGMHistory& history(); 01019 01020 CubitStatus get_graphics( Body *body, 01021 GMem *g_mem, 01022 std::vector<RefFace*> &face_to_facet_vector, 01023 std::vector<RefEntity*> &facet_point_ownership_vector, 01024 std::vector<std::pair<RefEntity*, std::pair<int,int> > > &facetedges_on_refedges, 01025 unsigned short normal_tolerance, 01026 double distance_tolerance, 01027 double max_edge_length ); 01028 01029 CubitStatus get_graphics( RefFace *ref_face, 01030 GMem *gmem, 01031 std::vector<RefEntity*> &facet_point_ownership_vector, 01032 std::vector<std::pair< RefEntity*, std::pair<int,int> > > &facetedges_on_refedges, 01033 unsigned short normal_tolerance = 15, 01034 double distance_tolerance = 0.0, 01035 double max_edge_length = 0.0 ); 01036 01037 CubitStatus get_point_containment( DLIList<Body*> &body_list, 01038 DLIList<CubitVector> &point_list, 01039 double tolerance, 01040 bool allow_pts_in_multiple_bodies, 01041 std::vector< std::pair<Body*, std::vector<int> > > &body_to_pt_indices ); 01042 01043 protected : 01044 01045 GeometryQueryTool(GeometryQueryEngine* GQEPtr); 01049 private : 01050 01051 CubitBoolean okay_to_transform( Body* body ) const; 01052 CubitBoolean okay_to_transform( BasicTopologyEntity* bte ) const; 01053 void notify_observers_of_transform(RefEntity* ref_entity, const CubitTransformMatrix *transform = NULL ) const; 01054 void notify_observers_of_transform(DLIList<RefEntity*> &ref_ents, 01055 const CubitTransformMatrix *xform = NULL) const; 01056 01057 CubitStatus notify_intermediate_of_transform( TopologyEntity* bte, 01058 const CubitTransformMatrix& xform 01059 ) const; 01060 01061 Shell* make_Shell(ShellSM *shellsm_ptr, bool& shell_modified ) const; 01062 RefVolume* make_RefVolume( Lump* lump_ptr, bool& vol_modified ) const; 01063 01064 CubitStatus make_merged_RefFace( Surface* surface_ptr ) const; 01065 // Helper function for make_RefFace(Surface*) 01066 // For a merged RefFace, check if the passed surface topology 01067 // is still compatible. If so, remerge any unmerged child 01068 // entities and return CUBIT_SUCCESS. If not, return CUBIT_FAILURE. 01069 01070 RefEntity *check_mergeable_refentity(GeometryEntity *bridge) const; 01071 // check for mergeable ref entity, indicated by a merge attribute on the 01072 // bridge 01073 01074 CoEdgeSM *find_merged_coedgesm( Surface* on_this_surface, 01075 CoEdgeSM* merged_with_this ) const; 01076 // check for mergeable sense entity, which is a child of the entity pointed 01077 // to by a merge attribute on bridge, which corresponds to re_ptr 01078 01079 01080 void get_merged_away_free_entities( DLIList<RefEntity*> &ref_ents, 01081 DLIList<TopologyBridge*> &free_ents ); 01082 01083 01084 CubitStatus straightline_intersections( RefEdge* ref_edge1, 01085 CubitVector & origin2, 01086 CubitVector & dir2, 01087 DLIList<CubitVector>& intersection_list, 01088 CubitBoolean bounded = CUBIT_FALSE, 01089 CubitBoolean closest = CUBIT_FALSE); 01090 01092 static GeometryQueryTool* instance_; 01093 01096 static CubitBoolean useFacetBBox; 01097 01099 DLIList<GeometryQueryEngine*> gqeList; 01100 01101 struct IGEComp : public std::binary_function<IntermediateGeomEngine*, 01102 IntermediateGeomEngine*, 01103 bool> { 01104 bool operator() ( const IntermediateGeomEngine* ptr1, 01105 const IntermediateGeomEngine* ptr2 ) const 01106 { return ptr1->level() < ptr2->level(); } 01107 }; 01108 typedef std::set<IntermediateGeomEngine*,IGEComp> IGESet; 01109 IGESet igeSet; 01110 01112 GeometryQueryEngine *default_gqe; 01113 01116 static double curveSliverCleanUpTolerance; 01117 01121 static double surfaceSliverCleanUpTolerance; 01122 01126 static double geometryToleranceFactor; 01127 01128 static CubitBoolean bboxMergeTest; 01129 01132 static int internalSurfaceMergeTest; 01133 01134 int maxPersistentBodyId; 01135 int maxPersistentRefVolumeId; 01136 int maxPersistentRefGroupId; 01137 int maxPersistentRefFaceId; 01138 int maxPersistentRefEdgeId; 01139 int maxPersistentRefVertexId; 01140 01141 CGMHistory mHistory; 01142 }; 01143 01144 inline void GeometryQueryTool::reset_geometry_factor() 01145 { 01146 geometryToleranceFactor = DEFAULT_GEOM_FACTOR; 01147 } 01148 01149 inline void GeometryQueryTool::set_geometry_factor( double factor ) 01150 { 01151 if ( factor < .0099999999999 ) 01152 return; 01153 else 01154 geometryToleranceFactor = factor; 01155 } 01156 inline double GeometryQueryTool::get_geometry_factor() 01157 { 01158 return geometryToleranceFactor; 01159 } 01160 01161 inline void GeometryQueryTool::set_sliver_surface_cleanup_tolerance( double tol ) 01162 { 01163 surfaceSliverCleanUpTolerance = tol; 01164 } 01165 01166 inline void GeometryQueryTool::set_sliver_curve_cleanup_tolerance( double tol ) 01167 { 01168 curveSliverCleanUpTolerance = tol; 01169 } 01170 01171 inline double GeometryQueryTool::get_sliver_curve_cleanup_tolerance() 01172 { 01173 return curveSliverCleanUpTolerance; 01174 } 01175 01176 inline double GeometryQueryTool::get_sliver_surface_cleanup_tolerance() 01177 { 01178 return surfaceSliverCleanUpTolerance; 01179 } 01180 01181 inline CubitBoolean GeometryQueryTool::get_merge_test_bbox() 01182 {return bboxMergeTest;} 01183 inline int GeometryQueryTool::get_merge_test_internal() 01184 {return internalSurfaceMergeTest;} 01185 inline void GeometryQueryTool::set_merge_test_bbox(CubitBoolean tof) 01186 {bboxMergeTest = tof;} 01187 inline void GeometryQueryTool::set_merge_test_internal(int tof) 01188 {internalSurfaceMergeTest = tof;} 01189 01190 inline void GeometryQueryTool::add_gqe(GeometryQueryEngine *gqe_ptr) 01191 { 01192 assert(gqe_ptr != 0); 01193 if (!gqeList.move_to(gqe_ptr)) gqeList.append(gqe_ptr); 01194 } 01198 inline CubitStatus GeometryQueryTool::remove_gqe(GeometryQueryEngine *gqe_ptr) 01199 { 01200 assert(gqe_ptr != 0); 01201 CubitStatus status = CUBIT_FAILURE; 01202 if (gqeList.move_to(gqe_ptr)) { 01203 gqeList.remove(); 01204 status = CUBIT_SUCCESS; 01205 } 01206 return status; 01207 } 01208 01209 inline void GeometryQueryTool::get_gqe_list(DLIList<GeometryQueryEngine*> &gqe_list) 01210 { 01211 gqe_list += gqeList; 01212 } 01216 inline GeometryQueryEngine *GeometryQueryTool::get_gqe() 01217 { 01218 GeometryQueryEngine *gqe = NULL; 01219 if (gqeList.size()) { 01220 gqeList.reset(); 01221 gqe = gqeList.get(); 01222 } 01223 return gqe; 01224 } 01225 01229 #endif 01230 01231 01232
