cgma
#include <vector>#include "InitCGMA.hpp"#include "CGMApp.hpp"#include "CubitCompat.hpp"#include "FacetQueryEngine.hpp"#include "BodySM.hpp"#include "Body.hpp"#include "GeometryQueryTool.hpp"Go to the source code of this file.
Defines | |
| #define | STRINGIFY(S) XSTRINGIFY(S) |
| #define | XSTRINGIFY(S) #S |
| #define | SRCDIR "." |
Functions | |
| int | main (int argc, char **argv) |
| #define SRCDIR "." |
Definition at line 17 of file test_stl.cpp.
| #define STRINGIFY | ( | S | ) | XSTRINGIFY(S) |
Definition at line 14 of file test_stl.cpp.
| #define XSTRINGIFY | ( | S | ) | #S |
Definition at line 15 of file test_stl.cpp.
| int main | ( | int | argc, |
| char ** | argv | ||
Definition at line 20 of file test_stl.cpp.
std::vector<CubitString> args;
CGMApp::instance()->startup(args);
const char* filename = STRINGIFY(SRCDIR) "/unit_cube.stl";
const char *out_file = "unit_cube.facet";
CubitStatus status = InitCGMA::initialize_cgma();
if (CUBIT_SUCCESS != status) return 1;
if (argc>=2)
filename = argv[1];
if (argc>=3)
out_file = argv[2];
DLIList<CubitQuadFacet*> quad_facet_list;
DLIList<CubitFacet*> tri_facet_list;
DLIList<Surface*> surface_list;
FacetQueryEngine* fqe = FacetQueryEngine::instance();
status = fqe->import_facets(filename, CUBIT_TRUE, 135, 1.e-6, 4, CUBIT_TRUE,
CUBIT_FALSE, CUBIT_TRUE, CUBIT_TRUE, quad_facet_list, tri_facet_list,
surface_list, STL_FILE);
// get bodies, then export to a facet file
DLIList<Body*> bodies;
GeometryQueryTool::instance()->bodies(bodies);
PRINT_INFO(" num bodies: %d\n", bodies.size());
//BodySM* bodysm_ptr = body_ptr->get_body_sm_ptr();
DLIList<TopologyBridge*> model;
for (int j=0; j<bodies.size(); j++)
BodySM* bodysm_ptr = bodies[j]->get_body_sm_ptr();
model.append( (TopologyBridge*)bodysm_ptr);
ModelExportOptions opts;
fqe->export_solid_model(
model, out_file, FACET_TYPE,
CubitString(), opts);
PRINT_INFO( "converted stl %s to %s \n", filename, out_file);
return 0;
